[GRASS-SVN] r65683 - grass/trunk/raster/r.flow
svn_grass at osgeo.org
Mon Jul 20 03:04:18 PDT 2015
Author: neteler
Date: 2015-07-20 03:04:18 -0700 (Mon, 20 Jul 2015)
New Revision: 65683
grass/trunk/raster/r.flow/r.flow.html
r.flow manual: wording fixes; HTML cosmetics
Modified: grass/trunk/raster/r.flow/r.flow.html
--- grass/trunk/raster/r.flow/r.flow.html 2015-07-20 10:01:56 UTC (rev 65682)
+++ grass/trunk/raster/r.flow/r.flow.html 2015-07-20 10:04:18 UTC (rev 65683)
@@ -13,9 +13,9 @@
There are three possible output raster maps which can be produced in any
combination simultaneously: a vector map <b>flowline</b> of flowlines,
a raster map
-<b>flowlength</b> of flowpath lengths, and a raster map <b>flowaccumulation</b> of flowline
-densities (which are equal upslope contributed areas per unit width, when
-multiplied by resolution).
+<b>flowlength</b> of flowpath lengths, and a raster map
+<b>flowaccumulation</b> of flowline densities (which are equal upslope
+contributed areas per unit width, when multiplied by resolution).
<h2>NOTES</h2>
@@ -43,14 +43,14 @@
is taken into account in calculating the length of each segment.
<p>Flowline density downhill or uphill output is given in a raster map
-<b>flowaccumulation.</b> The value in each grid cell is the number of flowlines which
-pass through that grid cell, that means the number of flowlines from the
-entire map which have segment endpoints within that cell.
+<b>flowaccumulation.</b> The value in each grid cell is the number of
+flowlines which pass through that grid cell, that means the number of
+flowlines from thec entire map which have segment endpoints within that cell.
-With the <b>-m</b> flag less memory is used as aspect at each cell is computed
-on the fly. This option incurs a severe performance penalty. If this flag is given,
-the <b>aspect</b> input map (if any) will be ignored.
+With the <b>-m</b> flag less memory is used as aspect at each cell is
+computed on the fly. This option incurs a severe performance penalty. If
+this flag is given, the <b>aspect</b> input map (if any) will be ignored.
<!-- doesn't exist
<p><b>-M</b> Use a fixed size memory and utilize page-swapping to handle
@@ -156,13 +156,16 @@
great that quantization error is larger than one of the
dimensions. Resample the map and try again.
-<h2>EXAMPLES</h2>
+<h2>EXAMPLE</h2>
-User can compute flow line vector map, flow path length raster map and flow accumulation raster map from an elevation raster map:
+In this example a flow line vector map, a flow path length raster map and
+a flow accumulation raster map are computed from an elevation raster map
+(North Carolina sample dataset):
<div class="code"><pre>
-g.region raster=elevation
-r.flow elevation=elevation skip=3 flowline=flowline flowlength=flowlength flowaccumulation=flowaccumulation
+g.region raster=elevation -p
+r.flow elevation=elevation skip=3 flowline=flowline flowlength=flowlength \
+ flowaccumulation=flowaccumulation
</pre></div>
<center>
@@ -170,7 +173,9 @@
<img src="r_flow_length.png" alt="flow path length">
<img src="r_flow_accumulation.png" alt="flow accumulation map">
<p>
-Figure: Flow lines underlaid with an elevation map, flow lines underlaid with flow path lengths and flow accumulation map (North Carolina dataset)
+Figure: Flow lines with underlying elevation map;
+flow lines with underlying flow path lengths (in map units: meters);
+flow accumulation map (zoomed view)
</center>
@@ -188,7 +193,8 @@
<li>Mitasova and Hofierka 1993 : Interpolation by Regularized Spline with
Tension: II. Application to Terrain Modeling and Surface Geometry Analysis.
-Mathematical Geology 25(6), 657-669. (<a href="http://www4.ncsu.edu/~hmitaso/gmslab/papers/hmg.rev1.ps">online</a>)
+Mathematical Geology 25(6), 657-669
+(<a href="http://www4.ncsu.edu/~hmitaso/gmslab/papers/hmg.rev1.ps">online</a>).
<li>Mitasova, H., Mitas, L., Brown, W.M., Gerdes, D.P., Kosinovsky, I.,
Baker, T., 1995: Modeling spatially and temporally distributed phenomena:
@@ -225,8 +231,9 @@
<p>
<i>The current version of the program (adapted for GRASS 5.0)</i>:
Joshua Caplan, Mark Ruesink, Helena Mitasova, University of Illinois
-at Urbana-Champaign with support from USA CERL. <a href="http://www4.ncsu.edu/~hmitaso/gmslab/">GMSL/University of Illinois at
-Urbana-Champaign</a>
+at Urbana-Champaign with support from USA CERL.
+<a href="http://www4.ncsu.edu/~hmitaso/gmslab/">GMSL/University of Illinois
+at Urbana-Champaign</a>
<p>
<i>Last changed: $Date$</i>
