[GRASS-SVN] r65699 - in grass-addons/grass7/raster: . r.agent.aco r.agent.aco/libagent
svn_grass at osgeo.org
Mon Jul 20 04:19:53 PDT 2015
Author: annalisapg
Date: 2015-07-20 04:19:53 -0700 (Mon, 20 Jul 2015)
New Revision: 65699
Added:
grass-addons/grass7/raster/r.agent.aco/
grass-addons/grass7/raster/r.agent.aco/r.agent.aco.html
grass-addons/grass7/raster/r.agent.aco/r.agent.aco.py
Removed:
grass-addons/grass7/raster/r.agent.aco/libold/
grass-addons/grass7/raster/r.agent.aco/Makefile
grass-addons/grass7/raster/r.agent.aco/libagent/Makefile
rename of the module and fix of makefiles
Modified: grass-addons/grass7/raster/r.agent.aco/Makefile
--- grass-addons/grass7/raster/r.agent/Makefile 2015-07-19 19:25:42 UTC (rev 65665)
+++ grass-addons/grass7/raster/r.agent.aco/Makefile 2015-07-20 11:19:53 UTC (rev 65699)
@@ -1,13 +1,13 @@
MODULE_TOPDIR =../..
-PGM = r.agent
+PGM = r.agent.aco
-SUBDIRS = \
- libagent \
- libold
+SUBDIRS = libagent
include $(MODULE_TOPDIR)/include/Make/Dir.make
+include $(MODULE_TOPDIR)/include/Make/Script.make
-default: parsubdirs htmldir
+default: script parsubdirs
install: installsubdirs
Modified: grass-addons/grass7/raster/r.agent.aco/libagent/Makefile
--- grass-addons/grass7/raster/r.agent/libagent/Makefile 2015-07-19 19:25:42 UTC (rev 65665)
+++ grass-addons/grass7/raster/r.agent.aco/libagent/Makefile 2015-07-20 11:19:53 UTC (rev 65699)
@@ -5,7 +5,7 @@
MODULES = agent anthill ant error grassland playground world
-ETCDIR = $(ETC)/r.agent
+ETCDIR = $(ETC)/r.agent.aco
PYFILES := $(patsubst %,$(ETCDIR)/%.py,$(MODULES))
PYCFILES := $(patsubst %,$(ETCDIR)/%.pyc,$(MODULES))
Deleted: grass-addons/grass7/raster/r.agent.aco/r.agent.aco
--- grass-addons/grass7/raster/r.agent/r.agent.aco 2015-07-19 19:25:42 UTC (rev 65665)
+++ grass-addons/grass7/raster/r.agent.aco/r.agent.aco 2015-07-20 11:19:53 UTC (rev 65699)
@@ -1,373 +0,0 @@
-#!/usr/bin/env python
-MODULE: r.agent.aco
-AUTHOR(S): michael lustenberger inofix.ch
-PURPOSE: r.agent.aco is used to organize ant-like agents in a raster
- based playground. As decribed by the Ant Colony Optimization
- algorithm, the ants wander around looking for attractors,
- marking their paths if they find any.
-COPYRIGHT: (C) 2011 by Michael Lustenberger and the GRASS Development Team
- This program is free software under the GNU General Public
- License (>=v2). Read the file COPYING that comes with GRASS
- for details.
-##TODO it is time to make this all multithreaded..
-#%Module
-#% description: Agents wander around on the terrain, marking paths to new locations.
-#%End
-#%option
-#% key: outputmap
-#% type: string
-#% gisprompt: old,cell,raster
-#% description: Name of pheromone output map
-#% required : yes
-#%end
-#%option
-#% key: inputmap
-#% type: string
-#% description: Name of input pheromone raster map (e.g. from prior run)
-#% required : no
-#%end
-#%flag
-#% key: p
-#% description: Allow overwriting existing pheromone maps
-#%end
-#%flag
-#% key: s
-#% description: Produce a sequence of pheromone maps (by appending a number)
-#%end
-#%flag
-#% key: c
-#% description: Overwrite existing cost map (only used with penalty conversion)
-#%end
-#%option
-#% key: costmap
-#% type: string
-#% description: Name of penalty resp. cost raster map (note conversion checkbox)
-#% required : yes
-#%end
-#%flag
-#% key: a
-#% description: Auto-convert cost (slope..) to penalty map (using "tobler", see docu)
-#%end
-#%option
-#% key: sitesmap
-#% type: string
-#% gisprompt: old,vect,vector
-#% description: Name of sites map, vector data with possible points of origin
-#% required : yes
-#%end
-#%option
-#% key: rounds
-#% type: integer
-#% gisprompt: number
-#% description: Number of iterations/rounds to run
-#% answer: 999
-#% options: 0-999999
-#% required : yes
-#%end
-#%option
-#% key: outrounds
-#% type: integer
-#% description: Produce output after running this number of iterations/rounds
-#% required : no
-#%end
-#%option
-#TODO evaluate..
-#% key: targetvisibility
-#% type: integer
-#% description: Distance to target from where it might be 'sensed'
-#% required : no
-#%end
-#%option
-#% key: highcostlimit
-#% type: integer
-#% description: Penalty values above this point an ant considers as illegal/bogus when in 'costlymarked' modus
-#% options: 0-<max integer on system would make sense>
-#% required : no
-#%end
-#%option
-#% key: lowcostlimit
-#% type: integer
-#% description: Penalty values below this point an ant considers as illegal/bogus when in 'costlymarked' modus
-#% options: -99999-99999
-#% required : no
-#%end
-#%option
-#% key: maxpheromone
-#% type: integer
-#% description: Absolute maximum of pheromone intensity a position may have
-#% options: <minpheromone>-<max integer on system would make sense>
-#% required : no
-#%end
-#%option
-#% key: minpheromone
-#% type: integer
-#% description: Absolute minimum of pheromone intensity to leave on playground
-#% options: 0-<maxpheromone>
-#% required : no
-#%end
-#%option
-#% key: volatilizationtime
-#% type: integer
-#% description: Half-life for pheromone to volatize (e.g. =rounds)
-#% required : no
-#%end
-#%option
-#% key: stepintensity
-#% type: integer
-#% description: Pheromone intensity to leave on each step
-#% required : no
-#%end
-#%option
-#% key: pathintensity
-#% type: integer
-#% description: Pheromone intensity to leave on found paths
-#% required : no
-#%end
-#%option
-#% key: maxants
-#% type: integer
-#% description: Maximum amount of ants that may live concurrently (x*y)
-#% options: 0-<the bigger the playground, the more space they have>
-#% required : no
-#%end
-#%option
-#% key: antslife
-#% type: integer
-#% description: Time to live for an ant (e.g. four times points distance)
-#% required : no
-#%end
-#%option
-#% key: decisionalgorithm
-#% type: string
-#% gisprompt: algorithm
-#% description: Algorithm used for walking step
-#% answer: standard
-#% options: standard,marked,costlymarked,random,test
-#% required : yes
-#%end
-#%option
-#% key: evaluateposition
-#% type: string
-#% description: Algorithm used for finding and remembering paths
-#% answer: avoidorforgetloop
-#% options: standard,avoidloop,forgetloop,avoidorforgetloop
-#% required : yes
-#%end
-#%option
-#% key: agentfreedom
-#% type: integer
-#% description: Number of possible directions the ant can take (4 or 8)
-#% options: 4,8
-#% required : no
-#%end
-#%option
-#% key: pheromoneweight
-#% type: integer
-#% description: How is the pheromone value (P) weighted when walking (p*P:r*R:c*C)
-#% answer: 1
-#% required : yes
-#%end
-#%option
-#% key: randomnessweight
-#% type: integer
-#% description: How is the random value (R) weighted when walking (p*P:r*R:c*C)
-#% answer: 1
-#% required : yes
-#%end
-#%option
-#% key: costweight
-#% type: integer
-#% description: How is the penalty value (C) weighted when walking (p*P:r*R:c*C)
-#% answer: 0
-#% required : yes
-#%end
-from sys import exit, maxsize
-from math import sqrt
-from math import exp
-from random import randint
-from libagent import error, grassland, anthill
-try:
- from grass.script import core as grass
-except ImportError:
- raise error.EnvError("r.agent.aco:", "Please run inside GRASS.")
-world = anthill.Anthill(grassland.Grassland())
-def setmaps(site, cost, wastecosts, inphero, outphero, wastephero):
- Set the user maps in place
- if site:
- if -1 == site.find('@'):
- site = site + '@' + grass.gisenv()['MAPSET']
- # set sitemap and site list
- world.sites = world.playground.parsevectorlayer(anthill.Anthill.SITE,
- site, -1, True)
- if not world.sites:
- raise error.DataError("r.agent.aco:",
- "There were no sites in" + site)
- else:
- raise error.DataError("r.agent.aco:", "The site map is mandatory.")
- if cost:
- if -1 == cost.find('@'):
- cost = cost + '@' + grass.gisenv()['MAPSET']
- # set cost/penalty layer
- world.playground.setgrasslayer(anthill.Anthill.COST, cost, True)
- world.overwritepenalty = wastecosts
- else:
- raise error.DataError("r.agent.aco:", "The cost map is mandatory.")
- if outphero:
- if -1 == outphero.find('@'):
- outphero = outphero + '@' + grass.gisenv()['MAPSET']
- else:
- raise error.DataError("r.agent.aco:", "The output map is mandatory.")
- if inphero == outphero:
- if not wastephero:
- raise error.DataError("aco:", "May not overwrite the output map.")
- if inphero:
- if -1 == inphero.find('@'):
- inphero = inphero + '@' + grass.gisenv()['MAPSET']
- world.playground.setgrasslayer(anthill.Anthill.RESULT, inphero, True)
- world.playground.grassmapnames[anthill.Anthill.RESULT] = outphero
- #TODO hopefully not really needed - workaround for broken(?) garray
- world.playground.createlayer("copy", outphero, True)
- world.playground.grassmapnames["copy"] = outphero
- world.overwritepheormone = wastephero
-def letantsdance(rounds, outrounds):
- Organize the agents and the pheromone on the playground.
- if world.addsequencenumber:
- outputmapbasename = \
- world.playground.grassmapnames[anthill.Anthill.RESULT].split("@")
- else:
- outputmapbasename = False
- outputmapname = False
- if 0 < outrounds < rounds:
- # calculate when to write output
- mainloops = rounds / outrounds
- nextwrite = outrounds
- else:
- # produce output only at the end
- mainloops = 1
- nextwrite = rounds
- run = 0
- while run < mainloops:
- if outputmapbasename:
- outputmapname = outputmapbasename[0] + str(run) + "@" + \
- outputmapbasename[1]
- # loop and write out the contents at the end
- world.letantsdance(nextwrite)
- # Print the number of found paths
- grass.info("Number of found paths: " + str(world.numberofpaths))
- # export the value maps
- for i in range(len(world.playground.layers[anthill.Anthill.RESULT])):
- for j in range(len(
- world.playground.layers[anthill.Anthill.RESULT][0])):
- world.playground.layers["copy"][i][j] = \
- world.playground.layers[anthill.Anthill.RESULT][i][j]
- world.playground.writelayer("copy", outputmapname,
- world.overwritepheormone)
- #TODO world.playground.writelayer(anthill.Anthill.RESULT, False,
- #TODO world.overwritepheormone)
-# print "nrofpaths:", world.nrop
- # count down outer
- run += 1
-# print "nrofrounds", nrofrounds
-def main():
- try:
- setmaps(options['sitesmap'],
- options['costmap'], flags['c'],
- options['inputmap'], options['outputmap'], flags['p'])
-# world.playground.setboundsfromlayer("costs")
- if not options['outrounds']:
- options['outrounds'] = 0
- elif flags['s'] and options['outrounds'] > 0:
- world.addsequencenumber = True
- if options['lowcostlimit']:
- world.minpenalty = int(options['lowcostlimit'])
- if options['highcostlimit']:
- world.maxpenalty = int(options['highcostlimit'])
- if options['maxpheromone']:
- world.maxpheromone = int(options['maxpheromone'])
- world.maxrandom = world.maxpheromone
- if options['minpheromone']:
- world.minpheromone = int(options['minpheromone'])
- world.minrandom = world.minpheromone
- if options['volatilizationtime']:
- world.volatilizationtime = int(options['volatilizationtime'])
- if options['stepintensity']:
- world.stepintensity = int(options['stepintensity'])
- if options['pathintensity']:
- world.pathintensity = int(options['pathintensity'])
- if options['maxants']:
- world.maxants = int(options['maxants'])
- if options['antslife']:
- world.antslife = int(options['antslife'])
- if options['decisionalgorithm']:
- world.decisionbase = str(options['decisionalgorithm'])
- if options['evaluateposition']:
- world.evaluationbase = str(options['evaluateposition'])
-# if options['agentfreedom']:
-# world.globalfreedom = int(options['agentfreedom'])
- if options['pheromoneweight']:
- world.pheroweight = int(options['pheromoneweight'])
- if options['randomnessweight']:
- world.randomweight = int(options['randomnessweight'])
- if options['costweight']:
- world.costweight = int(options['costweight'])
- #if arglist[0] == "stability":
- #TODO ask silvia..
-# world.checkvalues()
- except error.DataError:
- grass.fatal("Failed to parse args..")
- sys.exit(1)
- letantsdance(int(options['rounds']), int(options['outrounds']))
- grass.message("FINISH")
-if __name__ == "__main__":
- options, flags = grass.parser()
- main()
Added: grass-addons/grass7/raster/r.agent.aco/r.agent.aco.html
--- grass-addons/grass7/raster/r.agent.aco/r.agent.aco.html (rev 0)
+++ grass-addons/grass7/raster/r.agent.aco/r.agent.aco.html 2015-07-20 11:19:53 UTC (rev 65699)
@@ -0,0 +1,98 @@
+<h2>DESCRIPTION</h2>
+<em>r.agent</em> shall provide an inital base for organizing worlds
+with raster playgrounds and agents in.
+<p>
+As this is only a first implementation the encapsulation that grants
+a modular usage is still suffering..
+<p>
+<em>r.agent</em> is written in python for more transparency and
+better extendability.
+<p>
+As a first world example there is an ACO-based environment
+(see <a href="http://en.wikipedia.org/wiki/Ant_colony_optimization_algorithms">Ant Colony Optimization</a>)
+available (in <em>libold</em> see below..).
+<p>
+The basic concept of such an ACO world, is to take some cost surface
+and transform it to a penalty layer - where for human ants for example
+this penalty layer may be expressed by the walking velocity, e.g. calculated
+with the algorithm proposed by
+<a href="http://www.geodyssey.com/papers/tobler93.html">Tobler1993</a>.
+The actors on the playground will wander around on the playground
+using the time for their paths that correspond with the values in the penalty
+grid.
+If they find some attractor, they walk home to the position they
+originated, marking their way with pheromones. While this
+pheromone vanishes over time, the following agents are more likely
+to choose their next steps to a position that smells most.
+<p>
+This first toolset was mainly developed for
+<a href="http://www.topoi.org/group/a-iii-4/">Topoi Project A-III-4</a>,
+with some
+inspirations from previous work conducted at the
+<a href="http://www.unibe.ch/">Uni Bern</a> in 2008.
+<h2>NOTES</h2>
+The state of this software is: "first do it".
+This is work in progress and its structure will probably change quite a lot
+in the future due to a better integration in GRASS and other refactoring.
+<p>
+The refactoring causes <em>r.agent</em> to not work for the moment. The general
+behaviour can be seen by changeing the imports in <em>r.agent.aco</em>
+to the old library <em>libold</em> -- <em>libagent</em> is coming soon.
+<p>
+Unfortunately the colletion is not very well included in GRASS yet.
+At the moment <em>libold</em> only handles ASCII grid and vector in- and
+output data. With a better GRASS integration (arrays) not only will the code
+get lighter but also these drawbacks shall vanish.
+<p>
+ACO works best on dynamic maps -- it constantly tries to improve paths...
+<h2>EXAMPLE</h2>
+A fictive usecase could look something like this
+(note: at the moment the
+in- and output variables with <em>libold</em>, are still ascii-files):
+<p>
+<div class="code"><pre>
+r.agent.aco outputmap=out.map penaltymap=testpenalty.grid \
+ sitesmap=sites.vect rounds=100 outrounds=100 volatilizationtime=5000 \
+ antslife=2000 maxants=400 pathintensity=1000000
+</pre></div>
+<p>
+For running the total test suite on the libraries,
+i.e. to run all the tests that are at the end
+of each python file, use this test collection
+(for certain tests, the following files must exist though:
+ "elev.grid", and "arch.vect"):
+<p>
+user at host:~$ cd /<pathtoaddons>/r.agent/libagent
+user at host:libold$ ./alltests.py
+</pre></div>
+<h2>TODO</h2>
+Integrate it directly within grass.
+<p>
+Improve encapsulation of classes.
+<p>
+Find good parameters, or parameter finding strategies for the ACO part.
+Try to avoid high penalty fields.
+Think about heuristics too.
+<p>
+Implement other ABM scenarios.
+<h2>SEE ALSO</h2>
+<h2>AUTHORS</h2>
+Michael Lustenberger inofix.ch
+<p><i>Last changed: $Date: 2011-11-13 16:47:34 +0100(dom, 13 nov 2011) $</i>
Copied: grass-addons/grass7/raster/r.agent.aco/r.agent.aco.py (from rev 65646, grass-addons/grass7/raster/r.agent/r.agent.aco)
--- grass-addons/grass7/raster/r.agent.aco/r.agent.aco.py (rev 0)
+++ grass-addons/grass7/raster/r.agent.aco/r.agent.aco.py 2015-07-20 11:19:53 UTC (rev 65699)
@@ -0,0 +1,381 @@
+#!/usr/bin/env python
+MODULE: r.agent.aco
+AUTHOR(S): michael lustenberger inofix.ch
+PURPOSE: r.agent.aco is used to organize ant-like agents in a raster
+ based playground. As decribed by the Ant Colony Optimization
+ algorithm, the ants wander around looking for attractors,
+ marking their paths if they find any.
+COPYRIGHT: (C) 2011 by Michael Lustenberger and the GRASS Development Team
+ This program is free software under the GNU General Public
+ License (>=v2). Read the file COPYING that comes with GRASS
+ for details.
+##TODO it is time to make this all multithreaded..
+#%Module
+#% description: Agents wander around on the terrain, marking paths to new locations.
+#%End
+#%option
+#% key: outputmap
+#% type: string
+#% gisprompt: old,cell,raster
+#% description: Name of pheromone output map
+#% required : yes
+#%end
+#%option
+#% key: inputmap
+#% type: string
+#% description: Name of input pheromone raster map (e.g. from prior run)
+#% required : no
+#%end
+#%flag
+#% key: p
+#% description: Allow overwriting existing pheromone maps
+#%end
+#%flag
+#% key: s
+#% description: Produce a sequence of pheromone maps (by appending a number)
+#%end
+#%flag
+#% key: c
+#% description: Overwrite existing cost map (only used with penalty conversion)
+#%end
+#%option
+#% key: costmap
+#% type: string
+#% description: Name of penalty resp. cost raster map (note conversion checkbox)
+#% required : yes
+#%end
+#%flag
+#% key: a
+#% description: Auto-convert cost (slope..) to penalty map (using "tobler", see docu)
+#%end
+#%option
+#% key: sitesmap
+#% type: string
+#% gisprompt: old,vect,vector
+#% description: Name of sites map, vector data with possible points of origin
+#% required : yes
+#%end
+#%option
+#% key: rounds
+#% type: integer
+#% gisprompt: number
+#% description: Number of iterations/rounds to run
+#% answer: 999
+#% options: 0-999999
+#% required : yes
+#%end
+#%option
+#% key: outrounds
+#% type: integer
+#% description: Produce output after running this number of iterations/rounds
+#% required : no
+#%end
+#%option
+#TODO evaluate..
+#% key: targetvisibility
+#% type: integer
+#% description: Distance to target from where it might be 'sensed'
+#% required : no
+#%end
+#%option
+#% key: highcostlimit
+#% type: integer
+#% description: Penalty values above this point an ant considers as illegal/bogus when in 'costlymarked' modus
+#% options: 0-<max integer on system would make sense>
+#% required : no
+#%end
+#%option
+#% key: lowcostlimit
+#% type: integer
+#% description: Penalty values below this point an ant considers as illegal/bogus when in 'costlymarked' modus
+#% options: -99999-99999
+#% required : no
+#%end
+#%option
+#% key: maxpheromone
+#% type: integer
+#% description: Absolute maximum of pheromone intensity a position may have
+#% options: <minpheromone>-<max integer on system would make sense>
+#% required : no
+#%end
+#%option
+#% key: minpheromone
+#% type: integer
+#% description: Absolute minimum of pheromone intensity to leave on playground
+#% options: 0-<maxpheromone>
+#% required : no
+#%end
+#%option
+#% key: volatilizationtime
+#% type: integer
+#% description: Half-life for pheromone to volatize (e.g. =rounds)
+#% required : no
+#%end
+#%option
+#% key: stepintensity
+#% type: integer
+#% description: Pheromone intensity to leave on each step
+#% required : no
+#%end
+#%option
+#% key: pathintensity
+#% type: integer
+#% description: Pheromone intensity to leave on found paths
+#% required : no
+#%end
+#%option
+#% key: maxants
+#% type: integer
+#% description: Maximum amount of ants that may live concurrently (x*y)
+#% options: 0-<the bigger the playground, the more space they have>
+#% required : no
+#%end
+#%option
+#% key: antslife
+#% type: integer
+#% description: Time to live for an ant (e.g. four times points distance)
+#% required : no
+#%end
+#%option
+#% key: decisionalgorithm
+#% type: string
+#% gisprompt: algorithm
+#% description: Algorithm used for walking step
+#% answer: standard
+#% options: standard,marked,costlymarked,random,test
+#% required : yes
+#%end
+#%option
+#% key: evaluateposition
+#% type: string
+#% description: Algorithm used for finding and remembering paths
+#% answer: avoidorforgetloop
+#% options: standard,avoidloop,forgetloop,avoidorforgetloop
+#% required : yes
+#%end
+#%option
+#% key: agentfreedom
+#% type: integer
+#% description: Number of possible directions the ant can take (4 or 8)
+#% options: 4,8
+#% required : no
+#%end
+#%option
+#% key: pheromoneweight
+#% type: integer
+#% description: How is the pheromone value (P) weighted when walking (p*P:r*R:c*C)
+#% answer: 1
+#% required : yes
+#%end
+#%option
+#% key: randomnessweight
+#% type: integer
+#% description: How is the random value (R) weighted when walking (p*P:r*R:c*C)
+#% answer: 1
+#% required : yes
+#%end
+#%option
+#% key: costweight
+#% type: integer
+#% description: How is the penalty value (C) weighted when walking (p*P:r*R:c*C)
+#% answer: 0
+#% required : yes
+#%end
+import sys
+from sys import exit, maxsize
+from math import sqrt
+from math import exp
+from random import randint
+import grass.script as grass
+from grass.pygrass.utils import get_lib_path
+path = get_lib_path(modname='r.agent.aco', libname='libagent')
+if path is None:
+ grass.fatal("Not able to find the agent library directory.")
+sys.path.append(path)
+import error, grassland, anthill
+try:
+ from grass.script import core as grass
+except ImportError:
+ raise error.EnvError("r.agent.aco:", "Please run inside GRASS.")
+world = anthill.Anthill(grassland.Grassland())
+def setmaps(site, cost, wastecosts, inphero, outphero, wastephero):
+ Set the user maps in place
+ if site:
+ if -1 == site.find('@'):
+ site = site + '@' + grass.gisenv()['MAPSET']
+ # set sitemap and site list
+ world.sites = world.playground.parsevectorlayer(anthill.Anthill.SITE,
+ site, -1, True)
+ if not world.sites:
+ raise error.DataError("r.agent.aco:",
+ "There were no sites in" + site)
+ else:
+ raise error.DataError("r.agent.aco:", "The site map is mandatory.")
+ if cost:
+ if -1 == cost.find('@'):
+ cost = cost + '@' + grass.gisenv()['MAPSET']
+ # set cost/penalty layer
+ world.playground.setgrasslayer(anthill.Anthill.COST, cost, True)
+ world.overwritepenalty = wastecosts
+ else:
+ raise error.DataError("r.agent.aco:", "The cost map is mandatory.")
+ if outphero:
+ if -1 == outphero.find('@'):
+ outphero = outphero + '@' + grass.gisenv()['MAPSET']
+ else:
+ raise error.DataError("r.agent.aco:", "The output map is mandatory.")
+ if inphero == outphero:
+ if not wastephero:
+ raise error.DataError("aco:", "May not overwrite the output map.")
+ if inphero:
+ if -1 == inphero.find('@'):
+ inphero = inphero + '@' + grass.gisenv()['MAPSET']
+ world.playground.setgrasslayer(anthill.Anthill.RESULT, inphero, True)
+ world.playground.grassmapnames[anthill.Anthill.RESULT] = outphero
+ #TODO hopefully not really needed - workaround for broken(?) garray
+ world.playground.createlayer("copy", outphero, True)
+ world.playground.grassmapnames["copy"] = outphero
+ world.overwritepheormone = wastephero
+def letantsdance(rounds, outrounds):
+ Organize the agents and the pheromone on the playground.
+ if world.addsequencenumber:
+ outputmapbasename = \
+ world.playground.grassmapnames[anthill.Anthill.RESULT].split("@")
+ else:
+ outputmapbasename = False
+ outputmapname = False
+ if 0 < outrounds < rounds:
+ # calculate when to write output
+ mainloops = rounds / outrounds
+ nextwrite = outrounds
+ else:
+ # produce output only at the end
+ mainloops = 1
+ nextwrite = rounds
+ run = 0
+ while run < mainloops:
+ if outputmapbasename:
+ outputmapname = outputmapbasename[0] + str(run) + "@" + \
+ outputmapbasename[1]
+ # loop and write out the contents at the end
+ world.letantsdance(nextwrite)
+ # Print the number of found paths
+ grass.info("Number of found paths: " + str(world.numberofpaths))
+ # export the value maps
+ for i in range(len(world.playground.layers[anthill.Anthill.RESULT])):
+ for j in range(len(
+ world.playground.layers[anthill.Anthill.RESULT][0])):
+ world.playground.layers["copy"][i][j] = \
+ world.playground.layers[anthill.Anthill.RESULT][i][j]
+ world.playground.writelayer("copy", outputmapname,
+ world.overwritepheormone)
+ #TODO world.playground.writelayer(anthill.Anthill.RESULT, False,
+ #TODO world.overwritepheormone)
+# print "nrofpaths:", world.nrop
+ # count down outer
+ run += 1
+# print "nrofrounds", nrofrounds
+def main():
+ try:
+ setmaps(options['sitesmap'],
+ options['costmap'], flags['c'],
+ options['inputmap'], options['outputmap'], flags['p'])
+# world.playground.setboundsfromlayer("costs")
+ if not options['outrounds']:
+ options['outrounds'] = 0
+ elif flags['s'] and options['outrounds'] > 0:
+ world.addsequencenumber = True
+ if options['lowcostlimit']:
+ world.minpenalty = int(options['lowcostlimit'])
+ if options['highcostlimit']:
+ world.maxpenalty = int(options['highcostlimit'])
+ if options['maxpheromone']:
+ world.maxpheromone = int(options['maxpheromone'])
+ world.maxrandom = world.maxpheromone
+ if options['minpheromone']:
+ world.minpheromone = int(options['minpheromone'])
+ world.minrandom = world.minpheromone
+ if options['volatilizationtime']:
+ world.volatilizationtime = int(options['volatilizationtime'])
+ if options['stepintensity']:
+ world.stepintensity = int(options['stepintensity'])
+ if options['pathintensity']:
+ world.pathintensity = int(options['pathintensity'])
+ if options['maxants']:
+ world.maxants = int(options['maxants'])
+ if options['antslife']:
+ world.antslife = int(options['antslife'])
+ if options['decisionalgorithm']:
+ world.decisionbase = str(options['decisionalgorithm'])
+ if options['evaluateposition']:
+ world.evaluationbase = str(options['evaluateposition'])
+# if options['agentfreedom']:
+# world.globalfreedom = int(options['agentfreedom'])
+ if options['pheromoneweight']:
+ world.pheroweight = int(options['pheromoneweight'])
+ if options['randomnessweight']:
+ world.randomweight = int(options['randomnessweight'])
+ if options['costweight']:
+ world.costweight = int(options['costweight'])
+ #if arglist[0] == "stability":
+ #TODO ask silvia..
+# world.checkvalues()
+ except error.DataError:
+ grass.fatal("Failed to parse args..")
+ sys.exit(1)
+ letantsdance(int(options['rounds']), int(options['outrounds']))
+ grass.message("FINISH")
+if __name__ == "__main__":
+ options, flags = grass.parser()
+ main()
