[GRASS-SVN] r65704 - in grass/trunk/scripts/v.what.strds: . testsuite
svn_grass at osgeo.org
Mon Jul 20 06:19:00 PDT 2015
Author: lucadelu
Date: 2015-07-20 06:19:00 -0700 (Mon, 20 Jul 2015)
New Revision: 65704
Added:
grass/trunk/scripts/v.what.strds/testsuite/
grass/trunk/scripts/v.what.strds/testsuite/test_what_strds.py
v.what.strds: added test suite
Added: grass/trunk/scripts/v.what.strds/testsuite/test_what_strds.py
--- grass/trunk/scripts/v.what.strds/testsuite/test_what_strds.py (rev 0)
+++ grass/trunk/scripts/v.what.strds/testsuite/test_what_strds.py 2015-07-20 13:19:00 UTC (rev 65704)
@@ -0,0 +1,70 @@
+# -*- coding: utf-8 -*-
+"""Test v.what.strds
+(C) 2014 by the GRASS Development Team
+This program is free software under the GNU General Public
+License (>=v2). Read the file COPYING that comes with GRASS
+for details.
+ at author Luca Delucchi
+from grass.gunittest.case import TestCase
+from grass.gunittest.gmodules import SimpleModule
+import grass.script as gscript
+class TestWhatStrds(TestCase):
+ @classmethod
+ def setUpClass(cls):
+ """Initiate the temporal GIS and set the region
+ cls.use_temp_region()
+ cls.runModule("g.region", s=0, n=80, w=0, e=120, b=0, t=50,
+ res=10, res3=10)
+ cls.runModule("r.mapcalc", expression="a_1 = 100", overwrite=True)
+ cls.runModule("r.mapcalc", expression="a_2 = 200", overwrite=True)
+ cls.runModule("r.mapcalc", expression="a_3 = 300", overwrite=True)
+ cls.runModule("r.mapcalc", expression="a_4 = 400", overwrite=True)
+ cls.runModule("v.random", output="points", npoints=3, seed=1,
+ overwrite=True)
+ cls.runModule("t.create", type="strds", temporaltype="absolute",
+ output="A", title="A test", description="A test",
+ overwrite=True)
+ cls.runModule("t.register", flags="i", type="raster", input="A",
+ maps="a_1,a_2,a_3,a_4", start="2001-01-01",
+ increment="3 months", overwrite=True)
+ @classmethod
+ def tearDownClass(cls):
+ """Remove the temporary region
+ cls.runModule("t.remove", flags="rf", type="strds", inputs="A")
+ cls.del_temp_region()
+ def test_output(self):
+ self.assertModule("v.what.strds", input="points", strds="A",
+ output="what_strds", overwrite=True)
+ maps = gscript.list_strings('vector')
+ self.assertIn('what_strds@{ma}'.format(ma=gscript.gisenv()['MAPSET']),
+ maps)
+ def test_values(self):
+ db_sel = SimpleModule("v.db.select", map="what_strds")
+ self.assertModule(db_sel)
+ output = """cat|A_2001_01_01|A_2001_04_01|A_2001_07_01|A_2001_10_01
+1|100|200|300|400
+2|100|200|300|400
+3|100|200|300|400
+ self.assertLooksLike(output, db_sel.outputs.stdout)
+if __name__ == '__main__':
+ from grass.gunittest.main import test
+ test()
