[GRASS-SVN] r65713 - grass/trunk/man
svn_grass at osgeo.org
Mon Jul 20 10:41:35 PDT 2015
Author: lucadelu
Date: 2015-07-20 10:41:35 -0700 (Mon, 20 Jul 2015)
New Revision: 65713
grass/trunk/man/build_keywords.py
added TOC to keywords page
Modified: grass/trunk/man/build_keywords.py
--- grass/trunk/man/build_keywords.py 2015-07-20 16:19:31 UTC (rev 65712)
+++ grass/trunk/man/build_keywords.py 2015-07-20 17:41:35 UTC (rev 65713)
@@ -19,6 +19,8 @@
htmlfiles = glob.glob1(path, '*.html')
+char_list = {}
for fname in htmlfiles:
fil = open(os.path.join(path, fname))
# TODO maybe move to Python re (regex)
@@ -40,7 +42,6 @@
key = key.split('>')[1].split('<')[0]
except:
pass
- #key = "%s%s" % (key[0].upper(), key[1:])
if key not in keywords.keys():
keywords[key] = []
keywords[key].append(fname)
@@ -51,22 +52,57 @@
try:
del keywords[black]
except:
- continue
+ try:
+ del keywords[black.lower()]
+ except:
+ continue
+for key in sorted(keywords.keys()):
+ # this list it is useful to create the TOC using only the first
+ # character for keyword
+ firstchar = key[0].lower()
+ if firstchar not in char_list.keys():
+ char_list[str(firstchar)] = key
+ elif firstchar in char_list.keys():
+ if key.lower() < char_list[str(firstchar)].lower():
+ char_list[str(firstchar.lower())] = key
keywordsfile = open(os.path.join(path, 'keywords.html'), 'w')
-keywordsfile.write(header1_tmpl.substitute(title = "GRASS GIS " \
- "%s Reference Manual: Keywords index" % grass_version))
+keywordsfile.write(header1_tmpl.substitute(title="GRASS GIS %s Reference "
+ "Manual: Keywords index" % grass_version))
keywordsfile.write(headerkeywords_tmpl)
keywordsfile.write('<dl>')
-for key, values in sorted(keywords.iteritems()):
- keyword_line = '<dt><b><a name="%s" class="urlblack">%s</a></b></dt><dd>' % (key, key)
- for value in sorted(values):
- keyword_line += ' <a href="%s">%s</a>,' % (value, value.replace('.html',
+sortedKeys = keywords.keys()
+sortedKeys.sort(key=lambda s: s.lower())
+for key in sortedKeys:
+ keyword_line = '<dt><b><a name="%s" class="urlblack">%s</a></b></dt>' \
+ '<dd>' % (key, key)
+ for value in sorted(keywords[key]):
+ keyword_line += ' <a href="%s">%s</a>,' % (value,
+ value.replace('.html', ''))
keyword_line = keyword_line.rstrip(',')
keyword_line += '</dd>\n'
keywordsfile.write(keyword_line)
+keywordsfile.write("</dl>\n")
+# create toc
+toc = '<div class="toc">\n<h4 class="toc">Table of contents</h4><p class="toc">'
+test_lenght = 0
+all_keys = len(char_list.keys())
+for k in sorted(char_list.keys()):
+ test_lenght += 1
+# toc += '<li><a href="#%s" class="toc">%s</a></li>' % (char_list[k], k)
+ if test_lenght % 4 == 0 and not test_lenght == all_keys:
+ toc += '\n<a href="#%s" class="toc">%s</a>, ' % (char_list[k], k)
+ elif test_lenght % 4 == 0 and test_lenght == all_keys:
+ toc += '\n<a href="#%s" class="toc">%s</a>' % (char_list[k], k)
+ elif test_lenght == all_keys:
+ toc += '<a href="#%s" class="toc">%s</a>' % (char_list[k], k)
+ else:
+ toc += '<a href="#%s" class="toc">%s</a>, ' % (char_list[k], k)
+toc += '</p></div>\n'
+keywordsfile.write(toc)
-keywordsfile.write("</dl>\n")
write_html_footer(keywordsfile, "index.html", year)
keywordsfile.close()
