[GRASS-SVN] r65715 - grass/trunk/vector/v.buffer
svn_grass at osgeo.org
Mon Jul 20 11:24:47 PDT 2015
Author: martinl
Date: 2015-07-20 11:24:47 -0700 (Mon, 20 Jul 2015)
New Revision: 65715
grass/trunk/vector/v.buffer/geos.c
grass/trunk/vector/v.buffer/local_proto.h
grass/trunk/vector/v.buffer/main.c
fix v.buffer to be compiled with GEOS < 3.2 (see r65710)
Modified: grass/trunk/vector/v.buffer/geos.c
--- grass/trunk/vector/v.buffer/geos.c 2015-07-20 17:50:07 UTC (rev 65714)
+++ grass/trunk/vector/v.buffer/geos.c 2015-07-20 18:24:47 UTC (rev 65715)
@@ -158,6 +158,7 @@
* A value of 8 gives less than 2% max error in the buffer distance.
* For a max error of < 1%, use QS = 12.
* For a max error of < 0.1%, use QS = 18. */
+#ifdef GEOS_3_3
if (flat || no_caps) {
GEOSBufferParams* geos_params = GEOSBufferParams_create();
GEOSBufferParams_setEndCapStyle(geos_params,
@@ -166,9 +167,10 @@
OGeom = GEOSBufferWithParams(IGeom, geos_params, da);
GEOSBufferParams_destroy(geos_params);
- else {
+ else
+#else
OGeom = GEOSBuffer(IGeom, da, 12);
+#endif
if (!OGeom) {
G_fatal_error(_("Buffering failed"));
Modified: grass/trunk/vector/v.buffer/local_proto.h
--- grass/trunk/vector/v.buffer/local_proto.h 2015-07-20 17:50:07 UTC (rev 65714)
+++ grass/trunk/vector/v.buffer/local_proto.h 2015-07-20 18:24:47 UTC (rev 65715)
@@ -1,3 +1,6 @@
+#if (GEOS_VERSION_MAJOR >= 3 && GEOS_VERSION_MINOR >= 3)
+#define GEOS_3_3
+#endif
struct buf_contours
Modified: grass/trunk/vector/v.buffer/main.c
--- grass/trunk/vector/v.buffer/main.c 2015-07-20 17:50:07 UTC (rev 65714)
+++ grass/trunk/vector/v.buffer/main.c 2015-07-20 18:24:47 UTC (rev 65715)
@@ -474,7 +474,13 @@
#ifdef HAVE_GEOS
initGEOS(G_message, G_fatal_error);
+ /* check required version for -s/-c flag */
+#ifndef GEOS_3_3
+ G_warning(_("Flags -%c/%c ignored by this version, GEOS >= 3.3 is required"),
+ 's', 'c');
#endif
+#endif
if(!use_geos && (da < 0. || db < 0.)) {
G_warning(_("Negative distances for internal buffers are not supported "
"and converted to positive values."));
