[GRASS-SVN] r65730 - grass/trunk/scripts/g.extension
Mon Jul 20 13:01:42 PDT 2015
Author: wenzeslaus
Date: 2015-07-20 13:01:42 -0700 (Mon, 20 Jul 2015)
New Revision: 65730
   grass/trunk/scripts/g.extension/g.extension.py
g.extension: add other source code sources
Local directories supported by copying the data over to tmp dir (doesn't mess with user files and doesn't require changes in the source code). Support for short GitHub URLs. Local zip, tar and other archives and general URLs with archives supported too but not tested. Subversion access still works and is the default. Trac zips are not supported because the files have CRLF in them.
g.extension r.local.relief svnurl=/home/.../grass-addons/grass7/raster/r.local.relief/
g.extension r.sun.hourly
g.extension g.remote svnurl=github.com/wenzeslaus/g.remote
Modified: grass/trunk/scripts/g.extension/g.extension.py
--- grass/trunk/scripts/g.extension/g.extension.py	2015-07-20 20:01:31 UTC (rev 65729)
+++ grass/trunk/scripts/g.extension/g.extension.py	2015-07-20 20:01:42 UTC (rev 65730)
@@ -132,9 +132,9 @@
 try:
     from urllib2 import HTTPError
-    from urllib import urlopen
+    from urllib import urlopen, urlretrieve
 except ImportError:
-    from urllib.request import HTTPError, urlopen
+    from urllib.request import HTTPError, urlopen, urlretrieve
 try:
     import xml.etree.ElementTree as etree
@@ -561,7 +561,7 @@
     fo.close()
-def install_extension(url):
+def install_extension(source, url, xmlurl):
     """Install extension (e.g. one module) or a toolbox (list of modules)"""
     gisbase = os.getenv('GISBASE')
     if not gisbase:
@@ -573,7 +573,7 @@
     if flags['t']:
         grass.message(_("Installing toolbox <%s>...") % options['extension'])
-        mlist = get_toolbox_modules(url, options['extension'])
+        mlist = get_toolbox_modules(xmlurl, options['extension'])
     else:
         mlist = [options['extension']]
     if not mlist:
@@ -585,7 +585,8 @@
         if sys.platform == "win32":
             ret += install_extension_win(module)
         else:
-            ret += install_extension_std_platforms(module)
+            ret += install_extension_std_platforms(module,
+                                                   source=source, url=url)
         if len(mlist) > 1:
             print('-' * 60)
@@ -597,7 +598,7 @@
                         ' Please check above error messages.'))
     else:
         grass.message(_("Updating addons metadata file..."))
-        blist = install_extension_xml(url, mlist)
+        blist = install_extension_xml(xmlurl, mlist)
         for module in blist:
             update_manual_page(module)
@@ -903,7 +904,83 @@
     return directory
-def install_extension_std_platforms(name):
+def move_extracted_files(extract_dir, target_dir, files):
+    """Fix state of extracted file by moving them to different diretcory
+    When extracting, it is not clear what will be the root directory
+    or if there will be one at all. So this function moves the files to
+    a different directory in the way that if there was one direcory extracted,
+    the contained files are moved.
+    if len(files) == 1:
+        shutil.copytree(os.path.join(extract_dir, files[0]), target_dir)
+        print("copytree:", os.path.join(extract_dir, files[0]), target_dir)
+    else:
+        for file_name in files:
+            actual_file = os.path.join(extract_dir, file_name)
+            if os.path.isdir(actual_file):
+                shutil.copytree(actual_file, os.path.join(target_dir, file_name))
+            else:
+                shutil.copy(actual_file, target_dir)
+def extract_zip(name, directory, tmpdir):
+    """Extract a ZIP file into a directory"""
+    zip_file = zipfile.ZipFile(name, mode='r')
+    file_list = zip_file.namelist()
+    # we suppose we can write to parent of the given dir (supposing a tmp dir)
+    extract_dir = os.path.join(tmpdir, 'extract_dir')
+    os.mkdir(extract_dir)
+    for subfile in file_list:
+        # this should be safe in Python 2.7.4
+        zip_file.extract(subfile, extract_dir)
+    files = os.listdir(extract_dir)
+    move_extracted_files(extract_dir=extract_dir,
+                         target_dir=directory, files=files)
+# TODO: solve the other related formats
+def extract_tar(name, directory, tmpdir):
+    """Extract a TAR or a similar file into a directory"""
+    import tarfile
+    tar = tarfile.open(name, "r:gz")
+    tar.extractall()
+    files = os.listdir(tmpdir)
+    move_extracted_files(extract_dir=tmpdir,
+def download_source_code(source, url, name, outdev,
+                         directory=None, tmpdir=None):
+    """Get source code to a local directory for compilation"""
+    if source == 'svn':
+        download_source_code_svn(url, name, outdev, directory)
+    elif source == 'remote_zip':
+        # we expect that the module.zip file is not by chance in the archive
+        zip_name = os.path.join(tmpdir, 'module.zip')
+        urlretrieve(url, zip_name)
+        extract_zip(name=zip_name, directory=directory, tmpdir=tmpdir)
+    elif source == 'remote_tar.gz':
+        # we expect that the module.tar.gz file is not by chance in the archive
+        archive_name = os.path.join(tmpdir, 'module.tar.gz')
+        urlretrieve(url, archive_name)
+        extract_tar(name=archive_name, directory=directory, tmpdir=tmpdir)
+    elif source == 'zip':
+        os.mkdir(directory)
+        extract_zip(name=url, directory=directory)
+    elif source == 'tar':
+        extract_tar(name=url, directory=directory)
+    elif source == 'dir':
+        shutil.copytree(url, directory)
+    else:
+        # probably programmer error
+        grass.fatal(_("Unknown extension (addon) source '{}'."
+                      " Please report this to grass-user mailing list.")
+                    .format(source))
+def install_extension_std_platforms(name, source, url):
     """Install extension on standard plaforms"""
     grass.message(_("Fetching <%s> from"
@@ -915,9 +992,10 @@
     else:
         outdev = sys.stdout
+    os.chdir(TMPDIR)  # this is just to not leave something behind
     srcdir = os.path.join(TMPDIR, name)
-    download_source_code_svn(url=options['svnurl'], name=name,
-                             outdev=outdev, directory=srcdir)
+    download_source_code(source=source, url=url, name=name,
+                         outdev=outdev, directory=srcdir, tmpdir=TMPDIR)
     os.chdir(srcdir)
     dirs = {'bin': os.path.join(TMPDIR, name, 'bin'),
@@ -1266,6 +1344,30 @@
     return url
+def resolve_source_code(url):
+    if os.path.isdir(url):
+        return 'dir', url
+    elif os.path.exists(url):
+        for suffix in ['.zip', '.tar.gz']:
+            if url.endswith(suffix):
+                return suffix.lstrip('.'), url
+    # https://trac.osgeo.org/grass/browser/grass-addons/grass7/raster/r.modis?format=zip
+    # return 'remote_zip', url
+    # https://github.com/user/module
+    # https://github.com/user/module/archive/master.zip
+    elif url.startswith('github.com') and \
+            not (url.endswith('.zip') or url.endswith('.tar.gz')):
+        url = 'https://{}/archive/master.zip'.format(url)
+        return 'remote_zip', url
+    else:
+        for suffix in ['zip', 'tar.gz']:
+                print(suffix)
+                return 'remote_' + suffix, url
+        # fallback to classic behavior
+        return 'svn', url
 def main():
     # check dependecies
     if sys.platform != "win32":
@@ -1301,8 +1403,9 @@
     if options['operation'] == 'add':
         check_dirs()
+        source, url = resolve_source_code(options['svnurl'])
         xmlurl = resolve_xmlurl_prefix(options['svnurl'])
-        install_extension(xmlurl)
+        install_extension(source=source, url=url, xmlurl=xmlurl)
     else:  # remove
         remove_extension(force=flags['f'])
