[GRASS-SVN] r65742 - grass/trunk/gui/wxpython/animation
svn_grass at osgeo.org
Tue Jul 21 02:47:39 PDT 2015
Author: annakrat
Date: 2015-07-21 02:47:39 -0700 (Tue, 21 Jul 2015)
New Revision: 65742
grass/trunk/gui/wxpython/animation/mapwindow.py
wxGUI/animation: resize images when window size changes without rerendering them
Modified: grass/trunk/gui/wxpython/animation/mapwindow.py
--- grass/trunk/gui/wxpython/animation/mapwindow.py 2015-07-21 09:46:46 UTC (rev 65741)
+++ grass/trunk/gui/wxpython/animation/mapwindow.py 2015-07-21 09:47:39 UTC (rev 65742)
@@ -17,6 +17,7 @@
import wx
from core.debug import Debug
+from utils import ComputeScaledRect
class BufferedWindow(wx.Window):
@@ -107,6 +108,8 @@
self._pdc = wx.PseudoDC()
self._overlay = None
self._tmpMousePos = None
+ self.x = self.y = 0
+ self.bitmap_overlay = None
BufferedWindow.__init__(self, parent=parent, id=id, style=style)
self.SetBackgroundColour(wx.BLACK)
@@ -119,21 +122,40 @@
Debug.msg(5, "AnimationWindow.Draw()")
dc.Clear() # make sure you clear the bitmap!
- dc.DrawBitmap(self.bitmap, x=0, y=0)
+ dc.DrawBitmap(self.bitmap, x=self.x, y=self.y)
def OnSize(self, event):
Debug.msg(5, "AnimationWindow.OnSize()")
- self.DrawBitmap(self.bitmap)
BufferedWindow.OnSize(self, event)
if event:
event.Skip()
+ def _rescaleIfNeeded(self, bitmap):
+ """!If the bitmap has different size than the window, rescale it."""
+ bW, bH = bitmap.GetSize()
+ wW, wH = self.GetClientSize()
+ if abs(bW - wW) > 5 or abs(bH - wH) > 5:
+ params = ComputeScaledRect((bW, bH), (wW, wH))
+ im = wx.ImageFromBitmap(bitmap)
+ im.Rescale(params['width'], params['height'])
+ self.x = params['x']
+ self.y = params['y']
+ bitmap = wx.BitmapFromImage(im)
+ if self._overlay:
+ im = wx.ImageFromBitmap(self.bitmap_overlay)
+ im.Rescale(im.GetWidth() * params['scale'], im.GetHeight() * params['scale'])
+ self._setOverlay(wx.BitmapFromImage(im), xperc=self.perc[0], yperc=self.perc[1])
+ else:
+ self.x = 0
+ self.y = 0
+ return bitmap
def DrawBitmap(self, bitmap):
"""Draws bitmap.
Does not draw the bitmap if it is the same one as last time.
+ bitmap = self._rescaleIfNeeded(bitmap)
if self.bitmap == bitmap:
return
@@ -148,6 +170,15 @@
self._overlay.GetHeight()))
self._pdc.EndDrawing()
+ def _setOverlay(self, bitmap, xperc, yperc):
+ if self._overlay:
+ self._pdc.RemoveAll()
+ self._overlay = bitmap
+ size = self.GetClientSize()
+ x = xperc * size[0]
+ y = yperc * size[1]
+ self.DrawOverlay(x, y)
def SetOverlay(self, bitmap, xperc, yperc):
"""Sets overlay bitmap (legend)
@@ -157,22 +188,20 @@
Debug.msg(3, "AnimationWindow.SetOverlay()")
if bitmap:
- if self._overlay:
- self._pdc.RemoveAll()
- self._overlay = bitmap
- size = self.GetClientSize()
- x = xperc * size[0]
- y = yperc * size[1]
- self.DrawOverlay(x, y)
+ self._setOverlay(bitmap, xperc, yperc)
+ self.bitmap_overlay = bitmap
+ self.perc = (xperc, yperc)
else:
self.UpdateDrawing()
def ClearOverlay(self):
"""Clear overlay (legend) """
Debug.msg(3, "AnimationWindow.ClearOverlay()")
