[GRASS-SVN] r65746 - grass/trunk/scripts/v.import
svn_grass at osgeo.org
Tue Jul 21 03:36:19 PDT 2015
Author: martinl
Date: 2015-07-21 03:36:19 -0700 (Tue, 21 Jul 2015)
New Revision: 65746
grass/trunk/scripts/v.import/v.import.py
v.import: sync with addons
Modified: grass/trunk/scripts/v.import/v.import.py
--- grass/trunk/scripts/v.import/v.import.py 2015-07-21 10:23:25 UTC (rev 65745)
+++ grass/trunk/scripts/v.import/v.import.py 2015-07-21 10:36:19 UTC (rev 65746)
@@ -39,17 +39,27 @@
#%end
#%option G_OPT_V_OUTPUT
#% description: Name for output vector map (default: input)
+#% required: no
#% guisection: Output
#%end
#%option
#% key: extents
#% type: string
-#% required: yes
#% options: input,region
+#% answer: input
#% description: Ouput vector map extents
-#% descriptions: region;extents of current region;input;extents of input map
+#% descriptions: input;extents of input map;region;extents of current region
#%end
+#%flag
+#% key: f
+#% description: List supported OGR formats and exit
+#% suppress_required: yes
+#%end
+#%flag
+#% key: l
+#% description: List available OGR layers in data source and exit
+#%end
import sys
@@ -71,15 +81,25 @@
def main():
global tmploc, srcgisrc, gisdbase
- OGRdatasource = options['input']
- output = options['output']
- layers = options['layer']
# initialize global vars
tmploc = None
srcgisrc = None
gisdbase = None
+ # list formats and exit
+ if flags['f']:
+ grass.run_command('v.in.ogr', flags='f')
+ return 0
+ # list layers and exit
+ if flags['l']:
+ grass.run_command('v.in.ogr', flags='l', input=options['input'])
+ return 0
+ OGRdatasource = options['input']
+ output = options['output']
+ layers = options['layer']
vflags = None
if options['extents'] == 'region':
vflags = 'r'
@@ -103,10 +123,14 @@
tgtsrs = grass.read_command('g.proj', flags = 'j', quiet = True)
# create temp location from input without import
- grass.message(_("Creating temporary location for <%s>...") % OGRdatasource)
+ grass.message(_("Creating temporary location for <%s>...") % OGRdatasource)
+ v_in_kwargs = dict()
+ if layers:
+ v_in_kwargs['layer'] = layers
+ if output:
+ v_in_kwargs['output'] = output
returncode = grass.run_command('v.in.ogr', input = OGRdatasource,
- layer = layers, output = output,
- location = tmploc, flags = 'i', quiet = True)
+ location = tmploc, flags = 'i', quiet = True, **v_in_kwargs)
# if it fails, return
if returncode != 0:
grass.fatal(_("Unable to create location from OGR datasource <%s>") % OGRdatasource)
@@ -124,8 +148,7 @@
# try v.in.ogr directly
grass.message(_("Importing <%s>...") % OGRdatasource)
- flags = vflags)
+ flags = vflags, **v_in_kwargs)
# if it succeeds, return
if returncode == 0:
grass.message(_("Input <%s> successfully imported without reprojection") % OGRdatasource)
@@ -169,16 +192,24 @@
# import into temp location
grass.message(_("Importing <%s> ...") % OGRdatasource)
- flags = vflags, verbose = True)
if returncode != 0:
grass.fatal(_("Unable to import OGR datasource <%s>") % OGRdatasource)
+ # if output is not define check source mapset
+ if not output:
+ output = grass.list_grouped('vector')['PERMANENT'][0]
# switch to target location
os.environ['GISRC'] = str(tgtgisrc)
+ # check if map exists
+ if not grass.overwrite() and \
+ grass.find_file(output, element='vector', mapset='.')['mapset']:
+ grass.fatal(_("option <%s>: <%s> exists.") % ('output', output))
grass.run_command('g.remove', type = 'vector', name = vreg,
flags = 'f', quiet = True)
