[GRASS-SVN] r65748 - grass-addons/grass7/vector/v.import
svn_grass at osgeo.org
Tue Jul 21 03:41:10 PDT 2015
Author: martinl
Date: 2015-07-21 03:41:10 -0700 (Tue, 21 Jul 2015)
New Revision: 65748
grass-addons/grass7/vector/v.import/v.import.py
v.import (addons): sync'ed with trunk
Modified: grass-addons/grass7/vector/v.import/v.import.py
--- grass-addons/grass7/vector/v.import/v.import.py 2015-07-21 10:40:34 UTC (rev 65747)
+++ grass-addons/grass7/vector/v.import/v.import.py 2015-07-21 10:41:10 UTC (rev 65748)
@@ -51,6 +51,13 @@
#% descriptions: input;extents of input map;region;extents of current region
#% guisection: Output
#%end
+#%option
+#% key: encoding
+#% type: string
+#% label: Encoding value for attribute data
+#% descriptions: Overrides encoding interpretation, useful when importing ESRI Shapefile
+#% guisection: Output
+#%end
#%flag
#% key: f
#% description: List supported OGR formats and exit
@@ -103,7 +110,10 @@
vflags = None
if options['extents'] == 'region':
vflags = 'r'
+ vopts = {}
+ if options['encoding']:
+ vopts['encoding'] = options['encoding']
grassenv = grass.gisenv()
tgtloc = grassenv['LOCATION_NAME']
tgtmapset = grassenv['MAPSET']
@@ -124,13 +134,12 @@
# create temp location from input without import
grass.message(_("Creating temporary location for <%s>...") % OGRdatasource)
- v_in_kwargs = dict()
if layers:
- v_in_kwargs['layer'] = layers
+ vopts['layer'] = layers
if output:
- v_in_kwargs['output'] = output
+ vopts['output'] = output
returncode = grass.run_command('v.in.ogr', input = OGRdatasource,
- location = tmploc, flags = 'i', quiet = True, **v_in_kwargs)
+ location = tmploc, flags = 'i', quiet = True, **vopts)
# if it fails, return
if returncode != 0:
grass.fatal(_("Unable to create location from OGR datasource <%s>") % OGRdatasource)
@@ -148,7 +157,7 @@
# try v.in.ogr directly
grass.message(_("Importing <%s>...") % OGRdatasource)
- flags = vflags, **v_in_kwargs)
+ flags = vflags, **vopts)
# if it succeeds, return
if returncode == 0:
grass.message(_("Input <%s> successfully imported without reprojection") % OGRdatasource)
@@ -192,7 +201,7 @@
# import into temp location
grass.message(_("Importing <%s> ...") % OGRdatasource)
if returncode != 0:
