[GRASS-SVN] r65763 - in grass/trunk/gui/wxpython: lmgr tplot
svn_grass at osgeo.org
Tue Jul 21 11:09:35 PDT 2015
Author: lucadelu
Date: 2015-07-21 11:09:35 -0700 (Tue, 21 Jul 2015)
New Revision: 65763
grass/trunk/gui/wxpython/lmgr/frame.py
grass/trunk/gui/wxpython/tplot/frame.py
g.gui.tplot: fixed bugs; fixed start up from GUI
Modified: grass/trunk/gui/wxpython/lmgr/frame.py
--- grass/trunk/gui/wxpython/lmgr/frame.py 2015-07-21 18:01:41 UTC (rev 65762)
+++ grass/trunk/gui/wxpython/lmgr/frame.py 2015-07-21 18:09:35 UTC (rev 65763)
@@ -1636,7 +1636,7 @@
except ImportError:
GError(parent=self, message=_("Unable to start Temporal Plot Tool."))
return
- frame = TplotFrame(None)
+ frame = TplotFrame(parent=self, giface=self._giface)
frame.Show()
def OnHistogram(self, event):
Modified: grass/trunk/gui/wxpython/tplot/frame.py
--- grass/trunk/gui/wxpython/tplot/frame.py 2015-07-21 18:01:41 UTC (rev 65762)
+++ grass/trunk/gui/wxpython/tplot/frame.py 2015-07-21 18:09:35 UTC (rev 65763)
@@ -344,7 +344,7 @@
for line in vdb.splitlines():
lsplit = line.split('|')
layer = lsplit[0].split('/')[0]
- if layer == layerInp:
+ if str(layer) == str(layerInp):
return lsplit[2]
return None
@@ -435,12 +435,14 @@
totcat = len(cats)
ncat = 1
for cat in cats:
- if ncat == 1:
- wherequery += 'cat={c} or'.format(c=cat)
+ if ncat == 1 and totcat != 1:
+ wherequery += '{k}={c} or'.format(c=cat, k="{key}")
+ elif ncat == 1 and totcat == 1:
+ wherequery += '{k}={c}'.format(c=cat, k="{key}")
elif ncat == totcat:
- wherequery += ' cat={c}'.format(c=cat)
+ wherequery += ' {k}={c}'.format(c=cat, k="{key}")
else:
- wherequery += ' cat={c} or'.format(c=cat)
+ wherequery += ' {k}={c} or'.format(c=cat, k="{key}")
catn = "cat{num}".format(num=cat)
self.plotNameListV.append("{na}+{cat}".format(na=name,
cat=catn))
@@ -448,8 +450,15 @@
ncat += 1
for row in rows:
lay = int(row['layer'])
+ catkey = self.parseVDbConn(row['name'], lay)
+ if not catkey:
+ GError(parent=self, showTraceback=False,
+ message=_("No connection between vector map {vmap} "
+ "and layer {la}".format(vmap=row['name'],
+ la=lay)))
+ return
vals = grass.vector_db_select(map=row['name'], layer=lay,
- where=wherequery,
+ where=wherequery.format(key=catkey),
columns=attribute)
layn = "lay{num}".format(num=lay)
for cat in cats:
