[GRASS-SVN] r65769 - grass/trunk/scripts/g.extension
svn_grass at osgeo.org
Tue Jul 21 15:36:22 PDT 2015
Author: wenzeslaus
Date: 2015-07-21 15:36:22 -0700 (Tue, 21 Jul 2015)
New Revision: 65769
grass/trunk/scripts/g.extension/g.extension.py
g.extension: use Trac directory ZIP files by default
Subversion (svn command) is not longer a requied dependency. However, it is still possible to use it (so it will fail with traceback if it is not installed).
Modified: grass/trunk/scripts/g.extension/g.extension.py
--- grass/trunk/scripts/g.extension/g.extension.py 2015-07-21 22:08:08 UTC (rev 65768)
+++ grass/trunk/scripts/g.extension/g.extension.py 2015-07-21 22:36:22 UTC (rev 65769)
@@ -46,7 +46,6 @@
#% type: string
#% key_desc: url
#% description: SVN Addons repository URL
-#% answer: http://svn.osgeo.org/grass/grass-addons/grass7
#%end
#%option
#% key: prefix
@@ -173,7 +172,7 @@
def check_progs():
"""Check if the necessary programs are available"""
- for prog in ('svn', 'make', 'gcc'):
+ for prog in ('make', 'gcc'):
if not grass.find_program(prog, '--help'):
grass.fatal(_("'%s' required. Please install '%s' first.")
% (prog, prog))
@@ -210,6 +209,20 @@
return name.get(class_letters, class_letters)
+def get_module_class_name(module_name):
+ """Return class (family) name for a module
+ The names are used in directories in Addons but also in the source code.
+ >>> get_module_class_name('r.slope.aspect')
+ 'raster'
+ >>> get_module_class_name('v.to.rast')
+ 'vector'
+ classchar = module_name.split('.', 1)[0]
+ return expand_module_class_name(classchar)
def get_installed_extensions(force=False):
"""Get list of installed extensions or toolboxes (if -t is set)"""
if flags['t']:
@@ -999,7 +1012,7 @@
"""Get source code to a local directory for compilation"""
if source == 'svn':
download_source_code_svn(url, name, outdev, directory)
- elif source == 'remote_zip':
+ elif source in ['remote_zip', 'official']:
# we expect that the module.zip file is not by chance in the archive
zip_name = os.path.join(tmpdir, 'extension.zip')
urlretrieve(url, zip_name)
@@ -1372,7 +1385,7 @@
return os.path.abspath(path) # make likes absolute paths
-def resolve_xmlurl_prefix(url):
+def resolve_xmlurl_prefix(url, source=None):
"""Determine and check the URL where the XML metadata files are stored
It ensures that there is a single slash at the end of URL, so we can attach
@@ -1383,9 +1396,9 @@
>>> resolve_xmlurl_prefix('http://grass.osgeo.org/addons/')
- if 'svn.osgeo.org/grass/grass-addons/grass7' in url:
+ if source == 'official':
# use pregenerated modules XML file
- url = 'http://grass.osgeo.org/addons/grass%s' % version[0]
+ url = 'http://grass.osgeo.org/addons/grass%s/' % version[0]
# else try to get modules XMl from SVN repository (provided URL)
# the exact action depends on subsequent code (somewhere)
@@ -1466,7 +1479,7 @@
return None, None
-def resolve_source_code(url):
+def resolve_source_code(url=None, name=None):
"""Return type and URL or path of the source code
Local paths are not presented as URLs to be usable in standard functions.
@@ -1479,6 +1492,11 @@
:returns: tuple with type of source and full URL or path
+ Official repository:
+ >>> resolve_source_code(name='g.example') # doctest: +SKIP
+ ('official', 'https://trac.osgeo.org/.../general/g.example')
Subversion:
>>> resolve_source_code('http://svn.osgeo.org/grass/grass-addons/grass7')
@@ -1528,6 +1546,13 @@
>>> resolve_source_code('https://bitbucket.org/joe-user/grass-module')
('remote_zip', 'https://bitbucket.org/joe-user/grass-module/get/default.zip')
+ if not url and name:
+ module_class = get_module_class_name(name)
+ trac_url = 'https://trac.osgeo.org/grass/browser/grass-addons/' \
+ 'grass{version}/{module_class}/{module_name}?format=zip' \
+ .format(version=version[0],
+ module_class=module_class, module_name=name)
+ return 'official', trac_url
if os.path.isdir(url):
return 'dir', os.path.abspath(url)
elif os.path.exists(url):
@@ -1587,8 +1612,9 @@
if options['operation'] == 'add':
check_dirs()
- source, url = resolve_source_code(options['svnurl'])
- xmlurl = resolve_xmlurl_prefix(options['svnurl'])
+ source, url = resolve_source_code(name=options['extension'],
+ url=options['svnurl'])
+ xmlurl = resolve_xmlurl_prefix(options['svnurl'], source=source)
install_extension(source=source, url=url, xmlurl=xmlurl)
else: # remove
remove_extension(force=flags['f'])
