[GRASS-SVN] r65776 - grass/trunk/lib/raster
svn_grass at osgeo.org
Thu Jul 23 14:08:45 PDT 2015
Author: neteler
Date: 2015-07-23 14:08:45 -0700 (Thu, 23 Jul 2015)
New Revision: 65776
grass/trunk/lib/raster/rasterlib.dox
rasterlib doxygen: added Null/NaN explanations from https://lists.osgeo.org/pipermail/grass-dev/2015-July/075790.html
Modified: grass/trunk/lib/raster/rasterlib.dox
--- grass/trunk/lib/raster/rasterlib.dox 2015-07-23 12:07:49 UTC (rev 65775)
+++ grass/trunk/lib/raster/rasterlib.dox 2015-07-23 21:08:45 UTC (rev 65776)
@@ -1232,13 +1232,24 @@
and either sign).
So far as arithmetic is concerned, any value with an all-ones exponent
-and a non-zero mantissa is treated as NaN. But the GRASS
-Rast_is_[fd]_null_value() functions only consider the all-ones bit
-pattern to be null. I intend to change this in 7.x so that all FP NaN
-values are treated as null. This will mean that code which can
-generate NaNs doesn't have to explicitly convert them to the GRASS
-null value.
+and a non-zero mantissa is treated as NaN.
+Rast_set_d_null_value() and Rast_set_f_null_value() use the all-ones
+bit pattern. This is one of the many NaN values (anything with an
+all-ones exponent and a non-zero mantissa is NaN). As the topmost bit
+(i.e. the sign bit) is set, it is possible that some code would
+consider that to be "-NaN". E.g. code which writes a leading "-" based
+upon the sign bit before considering the other components would do so.
+Rast_is_d_null_value() and Rast_is_f_null_value() treat any NaN as
+null (specifically, they test whether the value is unequal to itself).
+At one time, these functions (or rather, their predecessors) checked
+explicitly for the all-ones pattern, but this was changed (in r33717
+and r33752) to improve robustness. Apart from code explicitly setting
+a value to "null", NaNs can arise from calculations (0.0/0.0, sqrt(x)
+or log(x) for x<0, asin(x) or acos(x) for abs(x)>1, etc), and there's
+no guarantee as to exactly which NaN representation will result.
<b>Presence or absence of <tt>null</tt> file:</b>
For an integer map, any cells which were null will become zero, but
