[GRASS-SVN] r65780 - grass/trunk/lib/init
svn_grass at osgeo.org
Mon Jul 27 01:37:53 PDT 2015
Author: zarch
Date: 2015-07-27 01:37:53 -0700 (Mon, 27 Jul 2015)
New Revision: 65780
grass/trunk/lib/init/grass.py
Changes to add Python3 compatibility
Modified: grass/trunk/lib/init/grass.py
--- grass/trunk/lib/init/grass.py 2015-07-24 08:06:18 UTC (rev 65779)
+++ grass/trunk/lib/init/grass.py 2015-07-27 08:37:53 UTC (rev 65780)
@@ -37,6 +37,7 @@
# (this makes it more stable since we have to set up paths first)
# pylint: disable=too-many-lines
+from __future__ import print_function
import sys
import os
import atexit
@@ -45,7 +46,50 @@
import re
import platform
import tempfile
+import locale
+# ----+- Python 3 compatibility start -+----
+PY2 = sys.version[0] == '2'
+ENCODING = locale.getdefaultlocale()[1]
+def to_text_string(obj, encoding=ENCODING):
+ """Convert `obj` to (unicode) text string"""
+ if PY2:
+ # Python 2
+ if encoding is None:
+ return unicode(obj)
+ else:
+ return unicode(obj, encoding)
+ else:
+ # Python 3
+ return str(obj)
+ elif isinstance(obj, str):
+ # In case this function is not used properly, this could happen
+ return obj
+ else:
+ return str(obj, encoding)
+if PY2:
+ import types
+ string_types = basestring,
+ integer_types = (int, long)
+ class_types = (type, types.ClassType)
+ text_type = unicode
+ binary_type = str
+else:
+ string_types = str,
+ integer_types = int,
+ class_types = type,
+ text_type = str
+ binary_type = bytes
+ MAXSIZE = sys.maxsize
+# ----+- Python 3 compatibility end -+----
# Variables substituted during build process
if 'GISBASE' in os.environ:
gisbase = os.environ['GISBASE']
@@ -88,7 +132,7 @@
def clean_env(gisrc):
env_curr = read_gisrc(gisrc)
env_new = {}
- for k,v in env_curr.iteritems():
+ for k,v in env_curr.items():
if 'MONITOR' not in k:
env_new[k] = v
@@ -359,7 +403,7 @@
tmpdir = os.path.join(tmp, "grass7-%(user)s-%(lock)s" % {'user': user,
'lock': gis_lock})
try:
- os.mkdir(tmpdir, 0700)
+ os.mkdir(tmpdir, 0o700)
except:
tmp = None
@@ -369,7 +413,7 @@
'user': user, 'lock': gis_lock})
try:
except:
tmp = None
if tmp:
@@ -451,7 +495,7 @@
def write_gisrc(kv, filename):
f = open(filename, 'w')
- for k, v in kv.iteritems():
+ for k, v in kv.items():
f.write("%s: %s\n" % (k, v))
f.close()
@@ -554,11 +598,11 @@
pass
if sys_man_path:
- os.environ['MANPATH'] = sys_man_path
+ os.environ['MANPATH'] = to_text_string(sys_man_path)
path_prepend(addons_man_path, 'MANPATH')
path_prepend(grass_man_path, 'MANPATH')
else:
- os.environ['MANPATH'] = addons_man_path
+ os.environ['MANPATH'] = to_text_string(addons_man_path)
# Set LD_LIBRARY_PATH (etc) to find GRASS shared libraries
@@ -675,7 +719,7 @@
p = Popen([os.environ['GRASS_PYTHON']], stdin=subprocess.PIPE,
stdout=nul, stderr=nul)
nul.close()
- p.stdin.write("variable=True")
+ p.stdin.write("variable=True".encode(ENCODING))
p.stdin.close()
p.wait()
if p.returncode != 0:
@@ -888,7 +932,7 @@
gui_startup(grass_gui)
else:
# Shouldn't need this but you never know
- fatal(_("Invalid user interface specified - <%s>. "
+ fatal(_("Invalid user interface specified - <%s>. "
"Use the --help option to see valid interface names.") % grass_gui)
@@ -984,10 +1028,10 @@
k, v = map(lambda x: x.strip(), line.strip().split(' ', 1)[1].split('=', 1))
except:
continue
debug("Environmental variable set {}={}".format(k, v))
os.environ[k] = v
# Allow for mixed ISIS-GRASS Environment
if os.getenv('ISISROOT'):
isis = os.getenv('ISISROOT')
@@ -1010,8 +1054,6 @@
# thus it always on Vista and XP will print an error.
# See discussion for Windows not following its own documentation and
# not accepting ISO codes as valid locale identifiers http://bugs.python.org/issue10466
- import locale
language = 'None' # Such string sometimes is present in wx file
encoding = None
@@ -1029,7 +1071,7 @@
language = ''.join(line.split(';')[-1:])
break
fd.close()
if language == 'None' or language == '' or not language:
# Language override is disabled (system language specified)
# As by default program runs with C locale, but users expect to
@@ -1040,8 +1082,9 @@
# If we get here, system locale settings are terribly wrong
# There is no point to continue as GRASS/Python will fail
# in some other unpredictable way.
- print "System locale is not usable. It indicates misconfigured environment."
- print "Reported error message: %s" % e
+ print("System locale is not usable. "
+ "It indicates misconfigured environment.")
+ print("Reported error message: %s" % e)
sys.exit("Fix system locale settings and then try again.")
language, encoding = locale.getdefaultlocale()
@@ -1101,7 +1144,7 @@
del os.environ['LC_ALL'] # Remove LC_ALL to not override LC_NUMERIC
# From now on enforce the new language
- if encoding:
+ if encoding:
gettext.install('grasslibs', gpath('locale'), codeset=encoding)
else:
gettext.install('grasslibs', gpath('locale'))
@@ -1310,9 +1353,9 @@
sys.stderr.write(r"""
__________ ___ __________ _______________
/ ____/ __ \/ | / ___/ ___/ / ____/ _/ ___/
- / / __/ /_/ / /| | \__ \\_ \ / / __ / / \__ \
- / /_/ / _, _/ ___ |___/ /__/ / / /_/ // / ___/ /
- \____/_/ |_/_/ |_/____/____/ \____/___//____/
+ / / __/ /_/ / /| | \__ \\_ \ / / __ / / \__ \
+ / /_/ / _, _/ ___ |___/ /__/ / / /_/ // / ___/ /
+ \____/_/ |_/_/ |_/____/____/ \____/___//____/
@@ -1450,7 +1493,7 @@
for line in readfile(env_file).splitlines():
if not line.startswith('export'):
f.write(line + '\n')
f.write("export PATH=\"%s\"\n" % os.getenv('PATH'))
f.write("export HOME=\"%s\"\n" % userhome) # restore user home path
@@ -1638,7 +1681,7 @@
# TODO: it is OK to remove this?
# at the beginning of this file were are happily getting GISBASE
# from the environment and we don't care about inconsistencies it might cause
-### commented-out: broken winGRASS
+### commented-out: broken winGRASS
# if 'GISBASE' in os.environ:
# sys.exit(_("ERROR: GRASS GIS is already running "
# "(environmental variable GISBASE found)"))
