[GRASS-SVN] r65782 - grass/trunk/lib/python/gunittest
svn_grass at osgeo.org
Mon Jul 27 04:56:12 PDT 2015
Author: zarch
Date: 2015-07-27 04:56:12 -0700 (Mon, 27 Jul 2015)
New Revision: 65782
grass/trunk/lib/python/gunittest/case.py
grass/trunk/lib/python/gunittest/invoker.py
grass/trunk/lib/python/gunittest/main.py
grass/trunk/lib/python/gunittest/reporters.py
grass/trunk/lib/python/gunittest/runner.py
grass/trunk/lib/python/gunittest/utils.py
gunittest: Support also Python3
Modified: grass/trunk/lib/python/gunittest/case.py
--- grass/trunk/lib/python/gunittest/case.py 2015-07-27 10:15:03 UTC (rev 65781)
+++ grass/trunk/lib/python/gunittest/case.py 2015-07-27 11:56:12 UTC (rev 65782)
@@ -8,10 +8,11 @@
:authors: Vaclav Petras
+from __future__ import print_function
import os
import subprocess
-import StringIO
+import sys
import hashlib
import uuid
import unittest
@@ -27,6 +28,12 @@
from .gutils import is_map_in_mapset
+if sys.version_info[0] == 2:
+ import StringIO
+else:
+ from io import StringIO
class TestCase(unittest.TestCase):
# we dissable R0904 for all TestCase classes because their purpose is to
# provide a lot of assert methods
@@ -624,7 +631,7 @@
name and should be always provided.
# TODO: possible improvement is to require some descriptive name
- # and ensure uniqueness by add UUID
+ # and ensure uniqueness by add UUID
if self.readable_names:
return 'tmp_' + self.id().replace('.', '_') + '_' + name
else:
@@ -1117,8 +1124,8 @@
module.run()
self.grass_modules.append(module.name)
except CalledModuleError:
- print module.outputs.stdout
- print module.outputs.stderr
+ print(module.outputs.stdout)
+ print(module.outputs.stderr)
# TODO: message format
# TODO: stderr?
stdmsg = ('Running <{m.name}> module ended'
@@ -1130,8 +1137,8 @@
errors=module.outputs.stderr
self.fail(self._formatMessage(msg, stdmsg))
# log these to final report
# TODO: always or only if the calling test method failed?
# in any case, this must be done before self.fail()
@@ -1151,11 +1158,11 @@
module.run()
else:
stdmsg = ('Running <%s> ended with zero (successful) return code'
' when expecting module to fail' % module.get_python())
Modified: grass/trunk/lib/python/gunittest/invoker.py
--- grass/trunk/lib/python/gunittest/invoker.py 2015-07-27 10:15:03 UTC (rev 65781)
+++ grass/trunk/lib/python/gunittest/invoker.py 2015-07-27 11:56:12 UTC (rev 65782)
@@ -12,7 +12,6 @@
import os
import sys
import shutil
-import string
import subprocess
from .checkers import text_to_keyvalue
@@ -25,6 +24,11 @@
NoopFileAnonymizer, keyvalue_to_text)
from .utils import silent_rmtree, ensure_dir
+try:
+ from string import maketrans
+except ImportError:
+ maketrans = str.maketrans
# needed for write_gisrc
# TODO: it would be good to find some way of writing rc without the need to
# have GRASS proprly set (anything from grass.script requires translations to
@@ -104,7 +108,7 @@
# replace . to get rid of unclean path
# TODO: clean paths
# note that backslash cannot be at the end of raw string
- dir_as_name = module.tested_dir.translate(string.maketrans(r'/\.', '___'))
+ dir_as_name = module.tested_dir.translate(maketrans(r'/\.', '___'))
mapset = dir_as_name + '_' + module.name
# TODO: use grass module to do this? but we are not in the right gisdbase
mapset_dir = os.path.join(gisdbase, location, mapset)
Modified: grass/trunk/lib/python/gunittest/main.py
--- grass/trunk/lib/python/gunittest/main.py 2015-07-27 10:15:03 UTC (rev 65781)
+++ grass/trunk/lib/python/gunittest/main.py 2015-07-27 11:56:12 UTC (rev 65782)
@@ -15,6 +15,7 @@
from unittest.main import TestProgram
from .loader import GrassTestLoader
from .runner import (GrassTestRunner, MultiTestResult,
TextTestResult, KeyValueTestResult)
@@ -55,16 +56,15 @@
failfast=failfast,
buffer=buffer_stdout_stderr,
result=result)
super(GrassTestProgram, self).__init__(module=module,
- argv=unittest_argv,
- testLoader=grass_loader,
- testRunner=grass_runner,
- exit=exit_at_end,
- verbosity=verbosity,
- failfast=failfast,
- catchbreak=catchbreak,
- buffer=buffer_stdout_stderr)
+ argv=unittest_argv,
+ testLoader=grass_loader,
+ testRunner=grass_runner,
+ exit=exit_at_end,
+ verbosity=verbosity,
+ failfast=failfast,
+ catchbreak=catchbreak,
+ buffer=buffer_stdout_stderr)
keyval_file.close()
Modified: grass/trunk/lib/python/gunittest/reporters.py
--- grass/trunk/lib/python/gunittest/reporters.py 2015-07-27 10:15:03 UTC (rev 65781)
+++ grass/trunk/lib/python/gunittest/reporters.py 2015-07-27 11:56:12 UTC (rev 65782)
@@ -14,15 +14,21 @@
import xml.sax.saxutils as saxutils
import xml.etree.ElementTree as et
import subprocess
-import StringIO
+import sys
import collections
-import types
import re
from .utils import ensure_dir
+ from StringIO import StringIO
+else:
+ basestring = str
# TODO: change text_to_keyvalue to same sep as here
# TODO: create keyvalue file and move it there together with things from checkers
def keyvalue_to_text(keyvalue, sep='=', vsep='\n', isep=',',
@@ -30,9 +36,9 @@
if not last_vertical:
last_vertical = vsep == '\n'
items = []
- for key, value in keyvalue.iteritems():
+ for key, value in keyvalue.items():
# TODO: use isep for iterables other than strings
- if (not isinstance(value, types.StringTypes)
+ if (not isinstance(value, basestring)
and isinstance(value, collections.Iterable)):
# TODO: this does not work for list of non-strings
value = isep.join(value)
@@ -444,7 +450,7 @@
if not size:
return '<p style="color: red>File %s is empty<p>' % filename
max_size = 10000
- html = StringIO.StringIO()
+ html = StringIO()
html.write(before)
if size < max_size:
with open(filename) as text:
@@ -582,7 +588,7 @@
st=self.successes, ft=self.failures + self.errors,
total=self.total, pt=pass_per
# this is the second place with this function
# TODO: provide one implementation
def format_percentage(percentage):
@@ -835,7 +841,7 @@
# TODO: add some general metadata here (passed in constructor)
# add additional information
- for key, value in self._info.iteritems():
+ for key, value in self._info.items():
summary[key] = value
summary_filename = os.path.join(self.result_dir,
@@ -1150,7 +1156,7 @@
page.write(head)
page.write(tests_table_head)
- for directory, test_files in directories.iteritems():
+ for directory, test_files in directories.items():
row = self.report_for_dir(root=root, directory=directory,
test_files=test_files)
page.write(row)
Modified: grass/trunk/lib/python/gunittest/runner.py
--- grass/trunk/lib/python/gunittest/runner.py 2015-07-27 10:15:03 UTC (rev 65781)
+++ grass/trunk/lib/python/gunittest/runner.py 2015-07-27 11:56:12 UTC (rev 65782)
@@ -43,8 +43,9 @@
# where are also unused, so perhaps we can remove them
# stream set to None and not included in interface, it would not make sense
def __init__(self, stream=None, descriptions=None, verbosity=None):
- super(TestResult, self).__init__(
- stream=stream, descriptions=descriptions, verbosity=verbosity)
+ super(TestResult, self).__init__(stream=stream,
+ descriptions=descriptions,
+ verbosity=verbosity)
self.successes = []
def addSuccess(self, test):
Modified: grass/trunk/lib/python/gunittest/utils.py
--- grass/trunk/lib/python/gunittest/utils.py 2015-07-27 10:15:03 UTC (rev 65781)
+++ grass/trunk/lib/python/gunittest/utils.py 2015-07-27 11:56:12 UTC (rev 65782)
@@ -54,7 +54,10 @@
sys.displayhook = new_displayhook
- import __builtin__
+ try:
+ import __builtin__
+ except ImportError:
+ import builtins as __builtin__
__builtin__._ = new_translator
