[GRASS-SVN] r65784 - grass/branches/releasebranch_7_0/locale/po
svn_grass at osgeo.org
Tue Jul 28 07:56:25 PDT 2015
Author: neteler
Date: 2015-07-28 07:56:24 -0700 (Tue, 28 Jul 2015)
New Revision: 65784
grass/branches/releasebranch_7_0/locale/po/grasslibs_fr.po
grass/branches/releasebranch_7_0/locale/po/grasswxpy_fr.po
Sylvain Maillard: FR translation cont'ed
Modified: grass/branches/releasebranch_7_0/locale/po/grasslibs_fr.po
--- grass/branches/releasebranch_7_0/locale/po/grasslibs_fr.po 2015-07-27 12:27:02 UTC (rev 65783)
+++ grass/branches/releasebranch_7_0/locale/po/grasslibs_fr.po 2015-07-28 14:56:24 UTC (rev 65784)
@@ -12,7 +12,7 @@
"Project-Id-Version: grasslibs_fr\n"
"Report-Msgid-Bugs-To: \n"
"POT-Creation-Date: 2015-07-20 21:44+0200\n"
-"PO-Revision-Date: 2014-06-01 00:12+0100\n"
+"PO-Revision-Date: 2015-06-07 15:53+0100\n"
"Last-Translator: Sylvain Maillard <sylvain.maillard at gmail.com>\n"
"Language-Team: French <grass-translations at lists.osgeo.org>\n"
"Language: fr\n"
@@ -192,8 +192,7 @@
#: ../lib/db/dbmi_base/legal_dbname.c:54
#, fuzzy, c-format
msgid "Illegal table map name <%s>. Character <%c> not allowed."
-msgstr ""
-"Nom de couche table illégal <%s>. Le caractère <%c> n'est pas autorisé.\n"
+msgstr "Nom de couche table illégal <%s>. Le caractère <%c> n'est pas autorisé.\n"
#: ../lib/db/dbmi_base/valuefmt.c:52
msgid "db_convert_Cstring_to_value(): unrecognized sqltype"
@@ -394,8 +393,7 @@
#: ../lib/cairodriver/read_ppm.c:56
#, c-format
-msgid ""
-"Cairo: input mask file has incorrect dimensions: expected: %dx%d got: %dx%d"
+msgid "Cairo: input mask file has incorrect dimensions: expected: %dx%d got: %dx%d"
msgstr ""
#: ../lib/cairodriver/write_xid.c:14
@@ -435,9 +433,7 @@
#: ../lib/driver/parse_ftcap.c:84
#, c-format
msgid "%s: Unable to read font definition file; use the default"
-msgstr ""
-"%s: Impossible de lire le fichier de définition de police, utilisation de "
-"celle par défaut"
+msgstr "%s: Impossible de lire le fichier de définition de police, utilisation de celle par défaut"
#: ../lib/driver/parse_ftcap.c:90
#, c-format
@@ -485,14 +481,14 @@
msgstr "Outil de recherche inconnu"
#: ../lib/vector/vedit/delete.c:40
-#, fuzzy, c-format
+#, c-format
msgid "Attempt to delete dead feature (%d)"
-msgstr "Tentative de supprimer une surface morte"
+msgstr "Tentative de supprimer une surface inactive (%d)"
#: ../lib/vector/vedit/delete.c:72
-#, fuzzy, c-format
+#, c-format
msgid "No area found for centroid %d"
-msgstr "Nombre de surfaces sans centroïde : %d"
+msgstr "Pas de surface trouvée pour le centroïde %d"
#: ../lib/vector/vedit/delete.c:76
#, c-format
@@ -500,14 +496,14 @@
msgstr ""
#: ../lib/vector/vedit/delete.c:105
-#, fuzzy, c-format
+#, c-format
msgid "Area %d without centroid"
+msgstr "Surface %d sans centroïde"
#: ../lib/vector/vedit/delete.c:121
-#, fuzzy, c-format
+#, c-format
msgid "Area %d has no boundaries"
-msgstr "Matrices non autorisées"
+msgstr "Surface %d sans contours"
#: ../lib/vector/diglib/port_init.c:158
#, fuzzy, c-format
@@ -521,23 +517,17 @@
#: ../lib/vector/diglib/spindex_rw.c:302
#, c-format
-msgid ""
-"This version of GRASS (%d.%d) is too old to read this spatial index format. "
-"Try to rebuild topology or upgrade GRASS to at least version %d."
+msgid "This version of GRASS (%d.%d) is too old to read this spatial index format. Try to rebuild topology or upgrade GRASS to at least version %d."
msgstr ""
#: ../lib/vector/diglib/spindex_rw.c:308
#, c-format
-msgid ""
-"Your GRASS version does not fully support spatial index format %d.%d of the "
-"vector. Consider to rebuild topology or upgrade GRASS."
+msgid "Your GRASS version does not fully support spatial index format %d.%d of the vector. Consider to rebuild topology or upgrade GRASS."
msgstr ""
#: ../lib/vector/diglib/spindex_rw.c:317
#, c-format
-msgid ""
-"Spatial index format version %d.%d is not supported by this release. Please "
-"rebuild topology."
+msgid "Spatial index format version %d.%d is not supported by this release. Please rebuild topology."
msgstr ""
#: ../lib/vector/diglib/file.c:159
@@ -554,19 +544,13 @@
#: ../lib/vector/diglib/cindex_rw.c:156
#, c-format
-msgid ""
-"This version of GRASS (%d.%d) is too old to read this category index format. "
+msgid "This version of GRASS (%d.%d) is too old to read this category index format. Try to rebuild topology or upgrade GRASS to at least version %d."
msgstr ""
#: ../lib/vector/diglib/plus_node.c:214
#, c-format
-msgid ""
-"Attempt to read line angle for the line which is not connected to the node: "
-"node %d, line %d"
-msgstr ""
-"Tentative de lire l'angle d'une ligne qui n'est pas connectée au noeud: "
-"noeud %d, ligne %d"
+msgid "Attempt to read line angle for the line which is not connected to the node: node %d, line %d"
+msgstr "Tentative de lire l'angle d'une ligne qui n'est pas connectée au noeud: noeud %d, ligne %d"
#: ../lib/vector/diglib/portable.c:208 ../lib/vector/diglib/portable.c:241
#: ../lib/vector/diglib/portable.c:683 ../lib/vector/diglib/plus_struct.c:563
@@ -659,20 +643,17 @@
#: ../lib/vector/diglib/plus_area.c:408
#, c-format
msgid "Dead centroid %d registered for area (bug in the vector library)"
-msgstr ""
-"Centroïde mort %d enregistré pour une surface (bug dans la librairie vecteur)"
+msgstr "Centroïde mort %d enregistré pour une surface (bug dans la librairie vecteur)"
#: ../lib/vector/diglib/plus_area.c:431
#, c-format
msgid "Attempt to delete area %d info from dead isle %d"
-msgstr ""
-"Tentative de suppression des information de la surface %d de l'île morte %d"
+msgstr "Tentative de suppression des information de la surface %d de l'île morte %d"
#: ../lib/vector/diglib/plus_area.c:777
#, c-format
msgid "Attempt to delete isle %d info from dead area %d"
-msgstr ""
-"Tentative de suppression des informations de l'île % de la surface morte %d"
+msgstr "Tentative de suppression des informations de l'île % de la surface morte %d"
#: ../lib/vector/diglib/frmt.c:45 ../lib/vector/diglib/frmt.c:70
#, fuzzy, c-format
@@ -701,28 +682,22 @@
#: ../lib/vector/diglib/test.c:75
#, c-format
-msgid ""
-"Error in read/write portable double, byte_order = %d Written: %.16e3E Read: "
-"%.16e3E"
+msgid "Error in read/write portable double, byte_order = %d Written: %.16e3E Read: %.16e3E"
msgstr ""
#: ../lib/vector/diglib/test.c:89
#, c-format
-msgid ""
-"Error in read/write portable float, byte_order = %d Written: %.8e3E Read: "
-"%.8e3E"
+msgid "Error in read/write portable float, byte_order = %d Written: %.8e3E Read: %.8e3E"
msgstr ""
#: ../lib/vector/diglib/test.c:104
#, c-format
-msgid ""
-"Error in read/write portable off_t, byte_order = %d Written: %lu Read: %lu"
+msgid "Error in read/write portable off_t, byte_order = %d Written: %lu Read: %lu"
msgstr ""
#: ../lib/vector/diglib/test.c:119
#, c-format
-msgid ""
-"Error in read/write portable long, byte_order = %d Written: %lu Read: %lu"
+msgid "Error in read/write portable long, byte_order = %d Written: %lu Read: %lu"
msgstr ""
#: ../lib/vector/diglib/test.c:134
@@ -732,8 +707,7 @@
#: ../lib/vector/diglib/test.c:150
#, c-format
-msgid ""
-"Error in read/write portable short, byte_order = %d Written: %d Read: %d"
+msgid "Error in read/write portable short, byte_order = %d Written: %d Read: %d"
msgstr ""
#: ../lib/vector/diglib/test.c:165
@@ -767,26 +741,18 @@
#: ../lib/vector/diglib/plus_struct.c:523
#, c-format
-msgid ""
-"This version of GRASS (%d.%d) is too old to read this topology format. Try "
-"to rebuild topology or upgrade GRASS to at least version %d."
+msgid "This version of GRASS (%d.%d) is too old to read this topology format. Try to rebuild topology or upgrade GRASS to at least version %d."
msgstr ""
#: ../lib/vector/diglib/plus_struct.c:529
#, c-format
-msgid ""
-"Your GRASS version does not fully support topology format %d.%d of the "
+msgid "Your GRASS version does not fully support topology format %d.%d of the vector. Consider to rebuild topology or upgrade GRASS."
msgstr ""
#: ../lib/vector/diglib/plus_struct.c:539
#, fuzzy, c-format
-msgid ""
-"Old topology format version %d.%d is not supported by this release. Try to "
-"rebuild topology using v.build or v.build.all module."
-msgstr ""
-"Le format d'index %d.%d n'est pas supporté par cette version. Essayez de "
-"reconstruire la topologie ou de mettre à jour GRASS."
+msgid "Old topology format version %d.%d is not supported by this release. Try to rebuild topology using v.build or v.build.all module."
+msgstr "Le format d'index %d.%d n'est pas supporté par cette version. Essayez de reconstruire la topologie ou de mettre à jour GRASS."
#: ../lib/vector/neta/flow.c:64 ../lib/vector/neta/flow.c:179
#: ../lib/vector/neta/spanningtree.c:99 ../lib/vector/neta/timetables.c:69
@@ -861,9 +827,7 @@
#: ../lib/vector/Vlib/cindex.c:489
#, fuzzy, c-format
msgid "Unable to create category index file for vector map <%s>"
-msgstr ""
-"Impossible d'ouvrir le fichier des catégories d'index pour la couche "
-"vectorielle <%s>"
+msgstr "Impossible d'ouvrir le fichier des catégories d'index pour la couche vectorielle <%s>"
#: ../lib/vector/Vlib/cindex.c:498
#, fuzzy
@@ -873,9 +837,7 @@
#: ../lib/vector/Vlib/cindex.c:542 ../lib/vector/Vlib/open.c:382
#, c-format
msgid "Unable to open category index file for vector map <%s>"
-msgstr ""
-"vectorielle <%s>"
#: ../lib/vector/Vlib/build.c:37 ../lib/vector/Vlib/rewind.c:29
#: ../lib/vector/Vlib/close.c:38 ../lib/vector/Vlib/open.c:59
@@ -885,9 +847,8 @@
msgstr "Le format demandé n'est pas compatible avec cette version"
#: ../lib/vector/Vlib/build.c:115
-#, fuzzy
msgid "Area of size = 0.0 (less than 4 vertices) ignored"
-msgstr "Surface de taille = 0.0 ignorée"
+msgstr "Surfaces de taille = 0.0 (moins de 4 sommets) ignorées"
#: ../lib/vector/Vlib/build.c:131
msgid "Unable to add area (map closed, topo saved)"
@@ -903,8 +864,7 @@
#: ../lib/vector/Vlib/build.c:200
msgid "Request to find area outside nonexistent isle"
-msgstr ""
-"Requête pour trouver des surfaces à l'extérieur d'une île non-existante"
+msgstr "Requête pour trouver des surfaces à l'extérieur d'une île non-existante"
#: ../lib/vector/Vlib/build.c:351
msgid "Larger bbox but smaller area!!!"
@@ -915,19 +875,19 @@
msgstr ""
#: ../lib/vector/Vlib/build.c:641
-#, fuzzy, c-format
+#, c-format
msgid "Number of lines of length zero: %d"
-msgstr "Nombre de lignes :%d"
+msgstr "Nombre de lignes de longueur nulle : %d"
#: ../lib/vector/Vlib/build.c:643
-#, fuzzy, c-format
+#, c-format
msgid "Number of boundaries of length zero: %d"
-msgstr "Nombre de contours : %d"
+msgstr "Nombre de contours de longueur nulle : %d"
#: ../lib/vector/Vlib/build.c:652
-#, fuzzy, c-format
+#, c-format
msgid "Number of boundary intersections: %d"
+msgstr "Nombre d'intersections de contours : %d"
#: ../lib/vector/Vlib/build.c:676
#, fuzzy
@@ -935,17 +895,15 @@
msgstr "Nombre de contours incorrects : %d"
#: ../lib/vector/Vlib/build.c:726
-#, fuzzy, c-format
+#, c-format
msgid "Number of redundant holes: %d"
+msgstr "Nombre de trous redondants : %d"
#: ../lib/vector/Vlib/build.c:865 ../lib/vector/Vlib/open.c:356
#: ../lib/vector/Vlib/open.c:860
-#, fuzzy, c-format
+#, c-format
msgid "Unable to open spatial index file for vector map <%s>"
-msgstr ""
-"vectorielle <%s>"
+msgstr "Impossible d'ouvrir le fichier d'index pour la carte vecteur <%s>"
#: ../lib/vector/Vlib/build.c:871
#, c-format
@@ -1012,9 +970,9 @@
msgstr "Nombre de surfaces sans centroïde: %d"
#: ../lib/vector/Vlib/build.c:968
-#, fuzzy, c-format
+#, c-format
msgid "Number of centroids exceeds number of areas: %d > %d"
-msgstr "Nombre de centroïdes en dehors de surfaces : %d"
+msgstr "Le nombre de centroïdes dépasse le nombre de surfaces : %d > %d"
#: ../lib/vector/Vlib/build.c:972
#, c-format
@@ -1040,21 +998,17 @@
msgstr "Nombre d'îles: -"
#: ../lib/vector/Vlib/build.c:1014
-#, fuzzy, c-format
+#, c-format
msgid "Unable to create topo file for vector map <%s>"
-msgstr "Impossible de créer l'en-tête de fichier pour [%s dans %s]"
+msgstr "Impossible de créer le fichier topo pour la carte vecteur <%s>"
#: ../lib/vector/Vlib/build.c:1022
msgid "Error writing out topo file"
msgstr "Erreur à l'écriture du fichier topo."
#: ../lib/vector/Vlib/build.c:1211
-#, fuzzy
-msgid ""
-"Unable to build spatial index from topology, vector map is not opened at "
-"topology level 2"
-msgstr ""
-"Impossible d'ouvrir la couche vectorielle <%s> au niveau topologique %d"
+msgid "Unable to build spatial index from topology, vector map is not opened at topology level 2"
+msgstr "Impossible de construire l'index spatial depuis la topologie, la couche vecteur n'est pas ouverte au niveau topologique 2"
#: ../lib/vector/Vlib/build.c:1234
#, c-format
@@ -1066,11 +1020,9 @@
msgstr ""
#: ../lib/vector/Vlib/build.c:1270
-#, fuzzy, c-format
+#, c-format
msgid "Unable to create spatial index file for vector map <%s>"
-msgstr ""
-"vectorielle <%s>"
+msgstr "Impossible de créer le fichier d'index spatial pour la couche vectorielle <%s>"
#: ../lib/vector/Vlib/build.c:1279
msgid "Error writing out spatial index file"
@@ -1147,9 +1099,9 @@
msgstr "Connexion à la base de données indéfinie pour la couche %d"
#: ../lib/vector/Vlib/ascii.c:465
-#, fuzzy, c-format
+#, c-format
msgid "Column <%s> does not exist"
-msgstr "La colonne <%s> n'est pas de type entier"
+msgstr "La colonne <%s> n'existe pas"
#: ../lib/vector/Vlib/ascii.c:467
msgid "Available columns:"
@@ -1160,9 +1112,9 @@
msgstr ""
#: ../lib/vector/Vlib/ascii.c:505
-#, fuzzy, c-format
+#, c-format
msgid "Unknown type of column <%s>, export cancelled"
-msgstr "Impossible de lire le type de colonne de la colonne de lissage"
+msgstr "Type de colonne <%s> inconnu, export annulé"
#: ../lib/vector/Vlib/ascii.c:539
#, fuzzy, c-format
@@ -1170,9 +1122,9 @@
msgstr "Impossible de créer l'index de la table <%s>, clef <%s>"
#: ../lib/vector/Vlib/ascii.c:661
-#, fuzzy, c-format
+#, c-format
msgid "Unknown feature type %d"
-msgstr "Type vectoriel inconnu."
+msgstr "Type d'objet %d inconnu"
#: ../lib/vector/Vlib/ascii.c:701
#, c-format
@@ -1180,9 +1132,9 @@
msgstr ""
#: ../lib/vector/Vlib/ascii.c:718
-#, fuzzy, c-format
+#, c-format
msgid "Cannot select attributes for cat = %d"
-msgstr "Impossible de sélectionner les attributs"
+msgstr "Impossible de sélectionner les attributs pour cat = %d"
#: ../lib/vector/Vlib/ascii.c:724
#, fuzzy
@@ -1196,38 +1148,31 @@
msgstr "Colonne <%s> non trouvée dans la table <%s>"
#: ../lib/vector/Vlib/ascii.c:758
-#, fuzzy, c-format
+#, c-format
msgid "Column <%s>: unsupported data type"
-msgstr "La couche vectorielle <%s> n'a pas été trouvée"
+msgstr "Colonne <%s> : type de données non supporté"
#: ../lib/vector/Vlib/ascii.c:840
-#, fuzzy
msgid "Unknown format"
-msgstr "Erreur inconnue"
+msgstr "Format inconnu"
#: ../lib/vector/Vlib/ascii.c:850
msgid "Topology not available, unable to process areas"
msgstr ""
#: ../lib/vector/Vlib/ascii.c:863
-#, fuzzy, c-format
+#, c-format
msgid "Unable to get boundary of area id %d"
-msgstr ""
-"vectorielle <%s>"
+msgstr "Impossible d'obtenir le contour pour la surface d'id %d"
#: ../lib/vector/Vlib/ascii.c:875
#, fuzzy, c-format
msgid "Unable to get boundary of isle id %d (area id %d)"
-msgstr ""
-"vectorielle <%s>"
#: ../lib/vector/Vlib/ascii.c:889
#, c-format
-msgid ""
-"%d features without category skipped. To export also features without "
-"category use '%s=-1'."
+msgid "%d features without category skipped. To export also features without category use '%s=-1'."
msgstr ""
#: ../lib/vector/Vlib/graph.c:138
@@ -1242,20 +1187,16 @@
#: ../lib/vector/Vlib/open_nat.c:57
#, fuzzy, c-format
msgid "Unable to open coor file for vector map <%s>"
-msgstr ""
-"Impossible d'ouvrir le fichier d'historique pour la couche vectorielle <%s>"
+msgstr "Impossible d'ouvrir le fichier d'historique pour la couche vectorielle <%s>"
#: ../lib/vector/Vlib/open_nat.c:154
#, c-format
-msgid ""
-"Coor file of vector map <%s@%s> is larger than it should be (%ld bytes "
-"excess)"
+msgid "Coor file of vector map <%s@%s> is larger than it should be (%ld bytes excess)"
msgstr ""
#: ../lib/vector/Vlib/open_nat.c:158
#, c-format
-msgid ""
-"Coor file of vector <%s@%s> is shorter than it should be (%ld bytes missing)."
+msgid "Coor file of vector <%s@%s> is shorter than it should be (%ld bytes missing)."
msgstr ""
#: ../lib/vector/Vlib/area.c:50
@@ -1313,11 +1254,9 @@
msgstr ""
#: ../lib/vector/Vlib/close_ogr.c:104 ../lib/vector/Vlib/close_pg.c:140
-#, fuzzy, c-format
+#, c-format
msgid "Unable to save feature index file for vector map <%s>"
-msgstr ""
-"vectorielle <%s>"
+msgstr "Impossible d'enregistrer le fichier d'index des objets pour la carte vecteur <%s>"
#: ../lib/vector/Vlib/write_sfa.c:117
#, fuzzy
@@ -1377,9 +1316,7 @@
#: ../lib/vector/Vlib/array.c:292
#, c-format
msgid "Unable to select record from table <%s> (key %s, where %s)"
-msgstr ""
-"Impossible de sélectionner un enregistrement depuis la table <%s> (clef %s, "
-"où %s)"
+msgstr "Impossible de sélectionner un enregistrement depuis la table <%s> (clef %s, où %s)"
#: ../lib/vector/Vlib/clean_nodes.c:248
#, c-format
@@ -1635,12 +1572,8 @@
#: ../lib/vector/Vlib/geos.c:55
#, c-format
-msgid ""
-"Vect_read_line_geos(): feature id %d is not reasonable (max features in "
-"vector map <%s>: %d)"
-msgstr ""
-"Vect_read_line_geos(): l'id d'objet %d n'est pas plausible (nombre maxi "
-"d'objets dans la carte vecteur <%s>: %d)"
+msgid "Vect_read_line_geos(): feature id %d is not reasonable (max features in vector map <%s>: %d)"
+msgstr "Vect_read_line_geos(): l'id d'objet %d n'est pas plausible (nombre maxi d'objets dans la carte vecteur <%s>: %d)"
#: ../lib/vector/Vlib/geos.c:60
msgid "only native format supported"
@@ -1658,8 +1591,7 @@
#: ../lib/vector/Vlib/geos.c:104
#, c-format
msgid "Vect_read_area_geos(): unable to read isle id %d of area id %d"
-msgstr ""
-"Vect_read_area_geos(): impossible de lire l'île d'id %d de la surface d'id %d"
+msgstr "Vect_read_area_geos(): impossible de lire l'île d'id %d de la surface d'id %d"
#: ../lib/vector/Vlib/geos.c:206
#, c-format
@@ -1687,9 +1619,9 @@
msgstr "Nouveau sommet : %d"
#: ../lib/vector/Vlib/close_pg.c:66 ../lib/vector/Vlib/read_pg.c:1405
-#, fuzzy, c-format
+#, c-format
msgid "Unable to close cursor %s"
-msgstr "Impossible d'ouvrir %s"
+msgstr "Impossible de fermer le curseur %s"
#: ../lib/vector/Vlib/intersect2.c:1177 ../lib/vector/Vlib/intersect2.c:1183
#: ../lib/vector/Vlib/intersect2.c:1185 ../lib/vector/Vlib/intersect2.c:1237
@@ -1707,12 +1639,11 @@
msgstr "Impossible de créer la couche vectorielle <%s>"
#: ../lib/vector/Vlib/close.c:108
-#, fuzzy
msgid "Copying features failed"
-msgstr "Construction du graphique ..."
+msgstr "Échec de la copie des objets"
#: ../lib/vector/Vlib/close.c:141
-#, fuzzy, c-format
+#, c-format
msgid "Unable to open %s file"
msgstr "Impossible d'ouvrir le fichier %s"
@@ -1727,9 +1658,9 @@
msgstr ""
#: ../lib/vector/Vlib/close.c:289
-#, fuzzy, c-format
+#, c-format
msgid "Link to vector map <%s> created"
-msgstr "Impossible d'ouvrir la couche vectorielle <%s>"
+msgstr "Lien vers la carte vecteur <%s> créé"
#: ../lib/vector/Vlib/read_ogr.c:215 ../lib/vector/Vlib/read_ogr.c:224
#, fuzzy, c-format
@@ -1766,8 +1697,7 @@
msgstr ""
#: ../lib/vector/Vlib/build_ogr.c:82
-msgid ""
-"Random read is not supported by OGR for this layer. Unable to build topology."
+msgid "Random read is not supported by OGR for this layer. Unable to build topology."
msgstr ""
#: ../lib/vector/Vlib/build_ogr.c:88 ../lib/vector/Vlib/build_pg.c:101
@@ -1799,19 +1729,19 @@
msgstr "Échec des conditions."
#: ../lib/vector/Vlib/copy.c:81
-#, fuzzy, c-format
+#, c-format
msgid "Unable to copy features. Input vector map <%s> is not open"
-msgstr "Impossible d'écrire l'entité, la couche n'est pas ouverte"
+msgstr "Impossible de copier les objets. La carte vecteur <%s> en entrée n'est pas ouverte"
#: ../lib/vector/Vlib/copy.c:104
-#, fuzzy, c-format
+#, c-format
msgid "Unable to create PostGIS layer <%s>"
-msgstr "Impossible d'ouvrir le fichier %s"
+msgstr "Impossible de créer la couche PostGIS <%s>"
#: ../lib/vector/Vlib/copy.c:133
-#, fuzzy, c-format
+#, c-format
msgid "Vector map <%s> not open on topological level. Areas will be skipped!"
+msgstr "La carte vecteur <%s> n'est pas ouverte au niveau topologique. Les surfaces seront ignorées !"
#: ../lib/vector/Vlib/copy.c:168 ../lib/vector/Vlib/copy.c:245
#: ../lib/ogsf/gp3.c:92
@@ -1820,9 +1750,8 @@
msgstr "Impossible de lire la carte vecteur <%s>"
#: ../lib/vector/Vlib/copy.c:229 ../lib/vector/Vlib/copy.c:234
-#, fuzzy
msgid "Copying features..."
+msgstr "Copie des objets ..."
#: ../lib/vector/Vlib/copy.c:231
#, c-format
@@ -1834,34 +1763,32 @@
msgstr ""
#: ../lib/vector/Vlib/copy.c:340
-#, fuzzy, c-format
+#, c-format
msgid "%d features without category or from different layer skipped"
-msgstr "L'objet %d sans géométrie a été ignoré"
+msgstr "%d objets sans catégories ou d'une autre couche ont été ignorés"
#: ../lib/vector/Vlib/copy.c:372
-#, fuzzy
msgid "Exporting nodes..."
-msgstr "Réglage des coûts du noeud..."
+msgstr "Export des noeuds ..."
#: ../lib/vector/Vlib/copy.c:400
-#, fuzzy, c-format
+#, c-format
msgid "Writing node %d failed"
-msgstr "Impossible de copier la table <%s>"
+msgstr "L'écriture du noeud %d a échoué"
#: ../lib/vector/Vlib/copy.c:478
-#, fuzzy
msgid "Exporting areas..."
+msgstr "Export des surfaces ..."
#: ../lib/vector/Vlib/copy.c:505
-#, fuzzy, c-format
+#, c-format
msgid "No centroid defined for area %d. Area not exported."
-msgstr "Connexion à la base de données indéfinie pour la couche %d"
+msgstr "Pas de centroïds pour la surface %d. Surface non exportée."
#: ../lib/vector/Vlib/copy.c:534 ../lib/vector/Vlib/copy.c:542
-#, fuzzy, c-format
+#, c-format
msgid "Writing area %d failed"
+msgstr "Écriture de la surface %d a échoué"
#: ../lib/vector/Vlib/copy.c:550
#, fuzzy, c-format
@@ -1869,9 +1796,9 @@
#: ../lib/vector/Vlib/copy.c:604
-#, fuzzy, c-format
+#, c-format
msgid "Unable to copy table <%s> for layer %d from <%s> to <%s>"
-msgstr "Impossible de copier la couche vectorielle <%s> vers <%s>"
+msgstr "Impossible de copier la table <%s> pour la couche %d de <%s> à <%s>"
#: ../lib/vector/Vlib/copy.c:723
#, c-format
@@ -1884,19 +1811,18 @@
#: ../lib/vector/Vlib/copy.c:747
-#, fuzzy, c-format
+#, c-format
msgid "Unable to open database <%s> with driver <%s>"
msgstr "Impossible d'ouvrir la base de données <%s> avec le driver <%s>"
#: ../lib/vector/Vlib/copy.c:754
-#, fuzzy
msgid "Unable to create index"
-msgstr "Impossible de créer un nouveau processus"
+msgstr "Impossible de créer l'index"
#: ../lib/vector/Vlib/copy.c:760
-#, fuzzy, c-format
+#, c-format
msgid "Unable to grant privileges on table <%s>"
-msgstr "Impossible de créer la table <%s>"
+msgstr "Impossible de donner les privilèges sur la carte <%s>"
#: ../lib/vector/Vlib/overlay.c:72
msgid "unknown operator"
@@ -1911,9 +1837,8 @@
msgstr "Supperposer : type surface x surface non supporté par l'opérateur AND"
#: ../lib/vector/Vlib/open_ogr.c:60
-#, fuzzy
msgid "OGR datasource not defined"
-msgstr "L'objet OGR sans ID a été ignoré"
+msgstr "Source de données OGR non définie"
#: ../lib/vector/Vlib/open_ogr.c:65 ../lib/vector/Vlib/write_ogr.c:129
msgid "OGR layer not defined"
@@ -1925,60 +1850,49 @@
msgstr "Impossible d'ouvrir la source de données OGR '%s'"
#: ../lib/vector/Vlib/open_ogr.c:97
-#, fuzzy, c-format
+#, c-format
msgid "OGR layer <%s> not found"
+msgstr "Couche OGR <%s> non trouvée"
#: ../lib/vector/Vlib/open_ogr.c:145 ../lib/vector/Vlib/open_pg.c:193
#, fuzzy, c-format
msgid "Unable to open feature index file for vector map <%s>"
-msgstr ""
-"vectorielle <%s>"
#: ../lib/vector/Vlib/open_ogr.c:191
-#, fuzzy, c-format
+#, c-format
msgid "Unable to get OGR driver <%s>"
+msgstr "Impossible d'obtenir le driver OGR <%s>"
#: ../lib/vector/Vlib/open_ogr.c:199
-#, fuzzy, c-format
+#, c-format
msgid "Unable to create OGR data source '%s'"
-msgstr "Impossible d'ouvrir le répertoire '%s'"
+msgstr "Impossible de créer la source de données OGR '%s'"
#: ../lib/vector/Vlib/open_ogr.c:211
-#, fuzzy, c-format
+#, c-format
msgid "OGR layer <%s> already exists and will be overwritten"
-msgstr "La couche vectorielle <%s> existe déjà et va être écrasé"
+msgstr "La couche OGR <%s> existe déjà et sera écrasée"
#: ../lib/vector/Vlib/open_ogr.c:215
-#, fuzzy, c-format
+#, c-format
msgid "Unable to delete OGR layer <%s>"
+msgstr "Impossible de supprimer la couche OGR <%s>"
#: ../lib/vector/Vlib/open_ogr.c:221
-#, fuzzy, c-format
+#, c-format
msgid "OGR layer <%s> already exists in datasource '%s'"
-msgstr "impossible d'ouvrir le fichier de l'ellipsoïde: %s"
+msgstr "La couche OGR <%s> existe déjà dans les données source '%s'"
#: ../lib/vector/Vlib/open_ogr.c:279
#, c-format
-msgid ""
-"Feature index format version %d.%d is not supported by this release. Try to "
-"rebuild topology or upgrade GRASS."
-msgstr ""
+msgid "Feature index format version %d.%d is not supported by this release. Try to rebuild topology or upgrade GRASS."
#: ../lib/vector/Vlib/open_ogr.c:284
#, c-format
-msgid ""
-"Your GRASS version does not fully support feature index format %d.%d of the "
-msgstr ""
-"Votre version de GRASS ne supporte pas complétement le format d'index %d.%d "
-"pour le vecteur. Reconstruisez la topologie ou faites une mise à jour de "
-"GRASS."
+msgid "Your GRASS version does not fully support feature index format %d.%d of the vector. Consider to rebuild topology or upgrade GRASS."
+msgstr "Votre version de GRASS ne supporte pas complétement le format d'index %d.%d pour le vecteur. Reconstruisez la topologie ou faites une mise à jour de GRASS."
#: ../lib/vector/Vlib/intersect.c:127
msgid "3D not supported by Vect_segment_intersection()"
@@ -1990,8 +1904,7 @@
#: ../lib/vector/Vlib/intersect.c:407
msgid "Vect_segment_intersection() ERROR (collinear non vertical segments)"
-msgstr ""
-"Vect_segment_intersection() ERREUR (segments verticaux non colinéaires)"
+msgstr "Vect_segment_intersection() ERREUR (segments verticaux non colinéaires)"
#: ../lib/vector/Vlib/simple_features.c:225
#, fuzzy, c-format
@@ -2001,9 +1914,7 @@
#: ../lib/vector/Vlib/simple_features.c:332
#, fuzzy
msgid "Unable to get number of simple features"
-msgstr ""
-"vectorielle <%s>"
#: ../lib/vector/Vlib/simple_features.c:341
#, fuzzy, c-format
@@ -2020,9 +1931,8 @@
msgstr ""
#: ../lib/vector/Vlib/build_pg.c:105
-#, fuzzy
msgid "Building pseudo-topology over simple features..."
-msgstr "Veuillez reconstruire la topologie pour la couche vectorielle <%s@%s>"
+msgstr "Reconstruction de la pseudo-topologie sur les objets simples ..."
#: ../lib/vector/Vlib/build_pg.c:107
#, fuzzy, c-format
@@ -2035,9 +1945,8 @@
msgstr ""
#: ../lib/vector/Vlib/build_pg.c:237
-#, fuzzy
msgid "Cleaning-up topology schema..."
+msgstr "Nettoyage du schéma de topologie ..."
#: ../lib/vector/Vlib/build_pg.c:282
#, fuzzy
@@ -2060,12 +1969,12 @@
#: ../lib/vector/Vlib/build_pg.c:462
#, fuzzy, c-format
msgid "Unsupported topo geometry type %d"
-msgstr "Type(s) d'entité(s)"
+msgstr "Type de topologie %d non supportée"
#: ../lib/vector/Vlib/build_pg.c:491
-#, fuzzy, c-format
+#, c-format
msgid "Unable to create <%s.%s>"
+msgstr "Impossible de créer <%s.%s>"
#: ../lib/vector/Vlib/build_pg.c:642
#, fuzzy
@@ -2073,24 +1982,22 @@
msgstr "Impossible d'écrire le noeud dans le fichier plus"
#: ../lib/vector/Vlib/build_pg.c:671
-#, fuzzy
msgid "Unable to write nodes"
-msgstr "Impossible de lire le fichier d'en-tête"
+msgstr "Impossible d'écrire les noeuds"
#: ../lib/vector/Vlib/build_pg.c:716
-#, fuzzy, c-format
+#, c-format
msgid "Inconsistency in topology: number of boundaries %d (should be %d)"
+msgstr "Topologie inconsistente : nombre de contours %d (devrait être %d)"
#: ../lib/vector/Vlib/build_pg.c:739
-#, fuzzy
msgid "Unable to write lines"
+msgstr "Impossible d'écrire les lignes"
#: ../lib/vector/Vlib/build_pg.c:790
-#, fuzzy, c-format
+#, c-format
msgid "Topology for centroid %d not available. Area %d skipped"
-msgstr "Aucune aide disponible pour la commande [%s]\n"
+msgstr "La topologie du centroïde %d n'ets pas disponible. Surface %d sautée"
#: ../lib/vector/Vlib/build_pg.c:1000
msgid "Create simple features topology from topogeometry data..."
@@ -2098,8 +2005,7 @@
#: ../lib/vector/Vlib/build_pg.c:1018
#, c-format
-msgid ""
-"Unable to build simple features from topogeometry data. Unsupported type %d."
+msgid "Unable to build simple features from topogeometry data. Unsupported type %d."
msgstr ""
#: ../lib/vector/Vlib/level_two.c:23
@@ -2200,14 +2106,14 @@
msgstr "Nombre de lignes : %d\n"
#: ../lib/vector/Vlib/open.c:138
-#, fuzzy, c-format
+#, c-format
msgid "Programmer requested unknown access level %d"
-msgstr "Le programmeur a demandé un open level inconnu %d"
+msgstr "Le programmeur a demandé accès à un niveau inconnu %d"
#: ../lib/vector/Vlib/open.c:232
-#, fuzzy, c-format
+#, c-format
msgid "Vector map <%s> not found in current mapset"
-msgstr "pas de fichier %s disponible dans le jeu de données actuel\n"
+msgstr "Carte vecteur <%s> non trouvé dans le jeu de données courant"
#: ../lib/vector/Vlib/open.c:235 ../lib/vector/Vlib/legal_vname.c:141
#: ../lib/vector/Vlib/legal_vname.c:144 ../lib/vector/Vlib/map.c:227
@@ -2219,16 +2125,12 @@
#: ../lib/vector/Vlib/open.c:252
-#, fuzzy
msgid "Temporary vector maps can be accessed only in the current mapset"
+msgstr "Les cartes vecteur temporaires ne sont accessibles que dans le jeu de cartes courant"
#: ../lib/vector/Vlib/open.c:266
-msgid ""
-"Vector map which is not in the current mapset cannot be opened for update"
-msgstr ""
-"Une couche vectorielle qui n'est pas dans le jeu de données courant ne peut "
-"pas être ouverte pour une mise à jour"
+msgid "Vector map which is not in the current mapset cannot be opened for update"
+msgstr "Une couche vectorielle qui n'est pas dans le jeu de données courant ne peut pas être ouverte pour une mise à jour"
#: ../lib/vector/Vlib/open.c:290 ../lib/vector/Vlib/open.c:426
#: ../lib/vector/Vlib/map.c:156 ../lib/vector/Vlib/map.c:166
@@ -2240,51 +2142,44 @@
#: ../lib/vector/Vlib/open.c:300
-#, fuzzy, c-format
+#, c-format
msgid "Unable to read header file of vector map <%s>"
-msgstr ""
+msgstr "Impossible de lire le fichier d'en-tête pour la carte vecteur <%s>"
#: ../lib/vector/Vlib/open.c:341
#, c-format
msgid "Unable to open topology file for vector map <%s>"
-msgstr ""
-"Impossible d'ouvrir le fichier topologique pour la couche vectorielle <%s>"
+msgstr "Impossible d'ouvrir le fichier topologique pour la couche vectorielle <%s>"
#: ../lib/vector/Vlib/open.c:408
-#, fuzzy, c-format
-msgid ""
-"Unable to open vector map <%s> on level %d. Try to rebuild vector topology "
-"with v.build."
-msgstr ""
-"Impossible d'ouvrir la carte vectorielle <%s> au niveau %d. Essayez de "
-"reconstruire la topologie avec v.build."
+#, c-format
+msgid "Unable to open vector map <%s> on level %d. Try to rebuild vector topology with v.build."
+msgstr "Impossible d'ouvrir la carte vecteur <%s> au niveau %d. Essayez de reconstruire la topologie avec v.build."
#: ../lib/vector/Vlib/open.c:434
-#, fuzzy, c-format
+#, c-format
msgid "Building topology for OGR layer <%s> from datasource '%s'..."
+msgstr "Construction de la topologie pour la couche OGR <%s> à partir dans la source '%s' ..."
#: ../lib/vector/Vlib/open.c:442
-#, fuzzy, c-format
+#, c-format
msgid "Unable to open vector map <%s> on level %d"
+msgstr "Impossible d'ouvrir la couche vecteur <%s> au niveau %d"
#: ../lib/vector/Vlib/open.c:496
#, c-format
msgid "Unable to open history file for vector map <%s>"
-msgstr ""
#: ../lib/vector/Vlib/open.c:768
-#, fuzzy, c-format
+#, c-format
msgid "Unable to create vector map: <%s> is not in the current mapset (%s)"
-msgstr "La carte raster <%s> n'est pas dans le jeux de carte courant (%s)"
+msgstr "Impossible de créer la carte vecteur : <%s> n'est pas dans le jeux de carte courant (%s)"
#: ../lib/vector/Vlib/open.c:777
-#, fuzzy, c-format
+#, c-format
msgid "Unable to create vector map: <%s> is not SQL compliant"
-msgstr "Le nom de la couche vectorielle n'est pas compatible avec le SQL"
+msgstr "Impossible de créer la couche vecteur : <%s> n'est pas compatible SQL"
#: ../lib/vector/Vlib/open.c:803 ../lib/vector/Vlib/open.c:814
#: ../lib/vector/Vlib/map.c:123
@@ -2301,8 +2196,7 @@
#: ../lib/vector/Vlib/open.c:835
#, fuzzy, c-format
msgid "Unable to open history file of vector map <%s>"
-msgstr ""
#: ../lib/vector/Vlib/open.c:876
#, c-format
@@ -2318,9 +2212,8 @@
msgstr ""
#: ../lib/vector/Vlib/open.c:885
-#, fuzzy
msgid "Using native format"
-msgstr "Seul le format natif est pris en charge"
+msgstr "Utilisation du format natif"
#: ../lib/vector/Vlib/open.c:976
#, c-format
@@ -2334,9 +2227,7 @@
#: ../lib/vector/Vlib/open.c:1132
msgid "Size of 'coor' file differs from value saved in topology file"
-msgstr ""
-"La taille du fichier 'coord' est différente de la valeur sauvegardée dans le "
-"fichier de topologie"
+msgstr "La taille du fichier 'coord' est différente de la valeur sauvegardée dans le fichier de topologie"
#: ../lib/vector/Vlib/open.c:1143 ../lib/vector/Vlib/open.c:1244
#, c-format
@@ -2344,16 +2235,12 @@
#: ../lib/vector/Vlib/open.c:1233
-#, fuzzy
msgid "Size of 'coor' file differs from value saved in sidx file"
-msgstr ""
+msgstr "Taille du fichier 'coord' différente de la valeur dans le fichier sidx"
#: ../lib/vector/Vlib/open.c:1313
-#, fuzzy
msgid "Unable to open OGR file"
+msgstr "Impossible d'ouvrir le fichier OGR"
#: ../lib/vector/Vlib/open.c:1339
msgid "OGR output also detected, using OGR"
@@ -2366,15 +2253,12 @@
#: ../lib/vector/Vlib/cats.c:127
#, c-format
msgid "Too many categories (%d), unable to set cat %d (layer %d)"
-msgstr ""
-"Trop de catégories (%d), dans l'impossibilité de mettre en cat %d (couche %d)"
+msgstr "Trop de catégories (%d), dans l'impossibilité de mettre en cat %d (couche %d)"
#: ../lib/vector/Vlib/cats.c:419
#, c-format
msgid "Unable to convert category string '%s' (from '%s') to category range"
-msgstr ""
-"Impossible de convertir les catégories de caractères '%s' (de '%s') en "
-"intervalle de catégorie"
+msgstr "Impossible de convertir les catégories de caractères '%s' (de '%s') en intervalle de catégorie"
#: ../lib/vector/Vlib/cats.c:572 ../lib/vector/Vlib/cats.c:668
#, fuzzy
@@ -2448,29 +2332,22 @@
#: ../lib/vector/Vlib/legal_vname.c:43
#, c-format
msgid "Illegal vector map name <%s>. May not contain '.' or 'NULL'."
-msgstr ""
-"Nom de couche vectorielle illégale <%s>. Ne doit contenir ni '.', ni 'NULL'."
+msgstr "Nom de couche vectorielle illégale <%s>. Ne doit contenir ni '.', ni 'NULL'."
#: ../lib/vector/Vlib/legal_vname.c:50
#, c-format
msgid "Illegal vector map name <%s>. Must start with a letter."
-msgstr ""
-"Nom de couche vectorielle illégale <%s>. Doit commencer par une lettre."
+msgstr "Nom de couche vectorielle illégale <%s>. Doit commencer par une lettre."
#: ../lib/vector/Vlib/legal_vname.c:58
#, c-format
msgid "Illegal vector map name <%s>. Character '%c' not allowed."
-msgstr ""
-"Nom de couche vectorielle illégale <%s>. Le caractère '%c' n'est pas "
-"autorisé."
+msgstr "Nom de couche vectorielle illégale <%s>. Le caractère '%c' n'est pas autorisé."
#: ../lib/vector/Vlib/legal_vname.c:65
#, c-format
-msgid ""
-"Illegal vector map name <%s>. SQL keyword cannot be used as vector map name."
-msgstr ""
-"Nom de couche vectorielle illégale <%s>. Les mot-clefs SQL ne peut pas être "
-"utilisés comme nom de carte vectorielle."
+msgid "Illegal vector map name <%s>. SQL keyword cannot be used as vector map name."
+msgstr "Nom de couche vectorielle illégale <%s>. Les mot-clefs SQL ne peut pas être utilisés comme nom de carte vectorielle."
#: ../lib/vector/Vlib/legal_vname.c:100 ../lib/vector/Vlib/legal_vname.c:104
#, fuzzy, c-format
@@ -2533,9 +2410,7 @@
#: ../lib/vector/Vlib/open_pg.c:549
#, fuzzy
-msgid ""
-"Connection to PostgreSQL database failed. Try to set up username/password by "
-"db.login."
+msgid "Connection to PostgreSQL database failed. Try to set up username/password by db.login."
msgstr "Echec de la connexion."
#: ../lib/vector/Vlib/open_pg.c:556
@@ -2646,9 +2521,9 @@
#: ../lib/vector/Vlib/break_lines.c:563
-#, fuzzy, c-format
+#, c-format
msgid "Intersections: %d"
-msgstr "Autre projection"
+msgstr "Intersections : %d"
#: ../lib/vector/Vlib/write_nat.c:403
#, fuzzy, c-format
@@ -2685,8 +2560,7 @@
#: ../lib/vector/Vlib/net.c:369
#, c-format
msgid "Data type of column <%s> not supported (must be numeric)"
-msgstr ""
-"Type de données de la colonne <%s> non pris en charge (doit être numeric)"
+msgstr "Type de données de la colonne <%s> non pris en charge (doit être numeric)"
#: ../lib/vector/Vlib/net.c:222
msgid "Registering arcs..."
@@ -2694,21 +2568,13 @@
#: ../lib/vector/Vlib/net.c:251
#, c-format
-msgid ""
-"Database record for line %d (cat = %d, forward/both direction(s)) not found "
-"(forward/both direction(s) of line skipped)"
-msgstr ""
-"L'enregistrement de la base de données de la ligne %d (cat = %d, avant/"
-"toutes directions) introuvable (avant/toutes directions de la ligne sautée)"
+msgid "Database record for line %d (cat = %d, forward/both direction(s)) not found (forward/both direction(s) of line skipped)"
+msgstr "L'enregistrement de la base de données de la ligne %d (cat = %d, avant/toutes directions) introuvable (avant/toutes directions de la ligne sautée)"
#: ../lib/vector/Vlib/net.c:270
#, c-format
-msgid ""
-"Database record for line %d (cat = %d, backword direction) not "
-"found(direction of line skipped)"
-msgstr ""
-"L'enregistrement de la base de données de la ligne %d (cat = %d, direction "
-"arrière) introuvable (direction de la ligne sautée)"
+msgid "Database record for line %d (cat = %d, backword direction) not found(direction of line skipped)"
+msgstr "L'enregistrement de la base de données de la ligne %d (cat = %d, direction arrière) introuvable (direction de la ligne sautée)"
#: ../lib/vector/Vlib/net.c:319
msgid "Cannot add network arc"
@@ -2721,9 +2587,7 @@
#: ../lib/vector/Vlib/net.c:412
#, c-format
msgid "Database record for node %d (cat = %d) not found (cost set to 0)"
-msgstr ""
-"L'enregistrement de la base de données pour le noeud %d (cat = %d) n'a pas "
-"été trouvé (coût fixé à 0)"
+msgstr "L'enregistrement de la base de données pour le noeud %d (cat = %d) n'a pas été trouvé (coût fixé à 0)"
#: ../lib/vector/Vlib/net.c:441
msgid "Flattening the graph..."
@@ -2747,13 +2611,11 @@
msgstr ""
#: ../lib/vector/Vlib/buffer2.c:589
-msgid ""
-"Next edge was visited (right) but it is not the first one !!! breaking loop"
+msgid "Next edge was visited (right) but it is not the first one !!! breaking loop"
msgstr ""
#: ../lib/vector/Vlib/buffer2.c:600
-msgid ""
-"Next edge was visited (left) but it is not the first one !!! breaking loop"
+msgid "Next edge was visited (left) but it is not the first one !!! breaking loop"
msgstr ""
#: ../lib/vector/Vlib/buffer2.c:648
@@ -2773,25 +2635,24 @@
msgstr "Vect_get_point_in_poly() a échoué"
#: ../lib/vector/Vlib/read_pg.c:192 ../lib/vector/Vlib/read_sfa.c:117
-#, fuzzy, c-format
+#, c-format
msgid "Unexpected feature type (%d) - should be (%d)"
+msgstr "Type d'objet (%d) inattendu - devrait être (%d)"
#: ../lib/vector/Vlib/read_pg.c:272 ../lib/vector/Vlib/read_pg.c:471
-#, fuzzy, c-format
+#, c-format
msgid "Feature %ld without geometry skipped"
+msgstr "L'objet %ld sans géométrie a été ignoré"
#: ../lib/vector/Vlib/read_pg.c:365
#, c-format
-msgid ""
-"Requesting invalid feature from cache (%d). Number of features in cache: %d"
+msgid "Requesting invalid feature from cache (%d). Number of features in cache: %d"
msgstr ""
#: ../lib/vector/Vlib/read_pg.c:368
-#, fuzzy, c-format
+#, c-format
msgid "Feature %d: unexpected type (%d) - should be %d"
+msgstr "Objet %d : type (%d) inattendu - devrait être %d"
#: ../lib/vector/Vlib/read_pg.c:575
msgid "No geometry or topo geometry column defined"
@@ -2838,18 +2699,22 @@
msgstr ""
#: ../lib/vector/Vlib/read_pg.c:1510 ../lib/vector/Vlib/read_pg.c:1541
-#, fuzzy, c-format
+#, c-format
msgid ""
"Execution failed: %s\n"
"Reason: %s"
-msgstr "Echec de la connexion."
+msgstr ""
+"Échec de l'exécution : %s\n"
+"Raison : %s"
#: ../lib/vector/Vlib/read_pg.c:1670
-#, fuzzy, c-format
+#, c-format
msgid ""
"Unable to read features. Reason:\n"
"%s"
-msgstr "Impossible de lire l'entité d'id %d"
+msgstr ""
+"Impossible de lire l'entité. Raison : \n"
+"%s"
#: ../lib/vector/Vlib/field.c:91
msgid "Layer number must be 1 or greater"
@@ -2858,9 +2723,7 @@
#: ../lib/vector/Vlib/field.c:96
#, fuzzy
msgid "Unable to add attribute link, vector map is not opened in WRITE mode"
-msgstr ""
-"Impossible d'ajouter un lien base de données, la couche n'est pas ouverte en "
-"ECRITURE."
+msgstr "Impossible d'ajouter un lien base de données, la couche n'est pas ouverte en ECRITURE."
#: ../lib/vector/Vlib/field.c:103
#, fuzzy
@@ -2882,9 +2745,7 @@
#: ../lib/vector/Vlib/field.c:185
-msgid ""
-"More DB links defined for input vector map. Using only first DB link for "
-"output."
+msgid "More DB links defined for input vector map. Using only first DB link for output."
msgstr ""
#: ../lib/vector/Vlib/field.c:261
@@ -2931,17 +2792,12 @@
msgstr "Impossible d'ouvrir le pilote OGR DBMI"
#: ../lib/vector/Vlib/field.c:758
-msgid ""
-"All FID tests failed. Neither 'FID' nor 'ogc_fid' nor 'ogr_fid' nor 'gid' "
-"available in OGR DB table"
-msgstr ""
-"Tous les tests FID ont échoués. Ni 'FID' ni 'ogc_fid' ni 'ogr_fid' ni 'gid' "
-"ne sont disponibles dans la table OGR DB"
+msgid "All FID tests failed. Neither 'FID' nor 'ogc_fid' nor 'ogr_fid' nor 'gid' available in OGR DB table"
+msgstr "Tous les tests FID ont échoués. Ni 'FID' ni 'ogc_fid' ni 'ogr_fid' ni 'gid' ne sont disponibles dans la table OGR DB"
#: ../lib/vector/Vlib/field.c:825
#, c-format
-msgid ""
-"Feature table <%s> has no primary key defined. Unable to define DB links."
+msgid "Feature table <%s> has no primary key defined. Unable to define DB links."
msgstr ""
#: ../lib/vector/Vlib/field.c:845
@@ -2956,29 +2812,26 @@
#: ../lib/vector/Vlib/field.c:911
#, fuzzy, c-format
msgid "Unable to create database definition file for vector map <%s>"
-msgstr ""
#: ../lib/vector/Vlib/field.c:1006
msgid "Bug: attempt to update map which is not in current mapset"
-msgstr ""
-"Bug: tentative de mise à jour d'une couche qui n'est pas dans le jeu de "
-"cartes courant"
+msgstr "Bug: tentative de mise à jour d'une couche qui n'est pas dans le jeu de cartes courant"
#: ../lib/vector/Vlib/write_ogr.c:134
#, fuzzy, c-format
msgid "Invalid offset (%d)"
-msgstr "Format invalide\n"
+msgstr "Offset invalide (%d)"
#: ../lib/vector/Vlib/write_ogr.c:239
-#, fuzzy, c-format
+#, c-format
msgid "Creating field <%s> failed"
+msgstr "La création du champ <%s> a échoué"
#: ../lib/vector/Vlib/write_ogr.c:326
-#, fuzzy, c-format
+#, c-format
msgid "Unable to create OGR layer <%s> in '%s'"
+msgstr "Impossible de créer la couche OGR <%s> dans '%s'"
#: ../lib/vector/Vlib/write_ogr.c:424
msgid "Feature is not a point. Skipping."
@@ -2993,18 +2846,17 @@
msgstr ""
#: ../lib/vector/Vlib/write_ogr.c:452
-#, fuzzy, c-format
+#, c-format
msgid "Unsupported feature type (%d)"
+msgstr "Type d'objet (%d) non supporté"
#: ../lib/vector/Vlib/write_ogr.c:471
msgid "Boundary is not closed. Feature skipped."
msgstr ""
#: ../lib/vector/Vlib/write_ogr.c:500
-#, fuzzy
msgid "Unable to writes feature attributes"
-msgstr "Impossible d'ajouter des liens base de données."
+msgstr "Impossible d'écrire les attributs des objets"
#: ../lib/vector/Vlib/write_ogr.c:565
#, fuzzy, c-format
@@ -3012,14 +2864,12 @@
#: ../lib/vector/Vlib/write_ogr.c:624
-#, fuzzy, c-format
+#, c-format
msgid "Unable to create field <%s>"
-msgstr "Impossible de supprimer la table <%s>"
+msgstr "Impossible de créer la champ <%s>"
#: ../lib/vector/Vlib/dgraph.c:432
-msgid ""
-"Trying to add more edges to the planar_graph than the initial allocation "
-"size allows"
+msgid "Trying to add more edges to the planar_graph than the initial allocation size allows"
msgstr ""
#: ../lib/vector/Vlib/box.c:228
@@ -3035,9 +2885,7 @@
#: ../lib/vector/Vlib/box.c:289
#, fuzzy, c-format
msgid "Unable to determine bbox for area %d"
-msgstr ""
-"vectorielle <%s>"
#: ../lib/vector/Vlib/box.c:335
#, fuzzy, c-format
@@ -3045,9 +2893,9 @@
msgstr "Impossible d'écrire la ligne matricielle %i"
#: ../lib/vector/Vlib/write.c:194
-#, fuzzy, c-format
+#, c-format
msgid "Unable to write feature in vector map <%s>"
-msgstr "Impossible de créer la couche vectorielle <%s>"
+msgstr "Impossible d'écrire l'objet dans la carte vecteur <%s>"
#: ../lib/vector/Vlib/write.c:234
#, fuzzy, c-format
@@ -3065,14 +2913,14 @@
msgstr "Impossible de restaurer l'entité %d de la couche vectorielle <%s>"
#: ../lib/vector/Vlib/write.c:308
-#, fuzzy, c-format
+#, c-format
msgid "Vector map <%s> is not opened"
-msgstr "La carte vecteur n'est pas ouverte"
+msgstr "La carte vecteur <%s> n'est pas ouverte"
#: ../lib/vector/Vlib/write.c:313
-#, fuzzy, c-format
+#, c-format
msgid "Vector map <%s> is not opened in write mode"
-msgstr "La carte vectorielle <%s> n'ets pas ouverte au niveau >= 2"
+msgstr "La carte vectorielle <%s> n'est pas ouverte en mode écriture"
#: ../lib/vector/Vlib/dangles.c:148
msgid "Changed"
@@ -3087,9 +2935,9 @@
msgstr ""
#: ../lib/vector/Vlib/dangles.c:262
-#, fuzzy, c-format
+#, c-format
msgid "%s lines: %d"
-msgstr "Nombre de lignes : %d\n"
+msgstr "%s lignes : %d"
#: ../lib/vector/Vlib/dangles.c:263
#, c-format
@@ -3109,7 +2957,7 @@
#: ../lib/vector/Vlib/read_sfa.c:90
#, fuzzy, c-format
msgid "Unable to construct centroid for area %d. Skipped."
-msgstr "Impossible de calculer le centroïde de l'entité surfacique %d"
+msgstr "Impossible de calculer le centroïde pour la surface %d. Ignoré."
#: ../lib/vector/Vlib/read_sfa.c:95
#, c-format
@@ -3122,10 +2970,9 @@
msgstr "Impossible de supprimer l'élément d'id %d de l'index spatial"
#: ../lib/vector/Vlib/header.c:87
-#, fuzzy, c-format
+#, c-format
msgid "Unable to create header file for vector map <%s>"
-msgstr ""
+msgstr "Impossible de créer le fichier d'en-tête pour la couche vectorielle <%s>"
#: ../lib/vector/Vlib/header.c:131
#, c-format
@@ -3602,8 +3449,7 @@
#: ../lib/python/temporal/stds_export.py:110
#, fuzzy, python-format
msgid "Unable to export color rules for raster map <%s> r.out.gdal"
-msgstr ""
#: ../lib/python/temporal/stds_export.py:134
@@ -3643,15 +3489,12 @@
#: ../lib/python/temporal/open_stds.py:122
-msgid ""
-"Space time %(sp)s dataset <%(name)s> is already in the database. Use the "
-"overwrite flag."
+msgid "Space time %(sp)s dataset <%(name)s> is already in the database. Use the overwrite flag."
#: ../lib/python/temporal/open_stds.py:157
-msgid ""
-"Overwriting space time %(sp)s dataset <%(name)s> and unregistering all maps"
+msgid "Overwriting space time %(sp)s dataset <%(name)s> and unregistering all maps"
msgstr "Impossible de créer le fichier d'en-tête pour [%s]"
#: ../lib/python/temporal/open_stds.py:165
@@ -3662,8 +3505,7 @@
#: ../lib/python/temporal/open_stds.py:208
#: ../lib/python/temporal/extract.py:114 ../lib/python/temporal/mapcalc.py:236
-msgid ""
-"Map <%s> is already in temporal database, use overwrite flag to overwrite"
+msgid "Map <%s> is already in temporal database, use overwrite flag to overwrite"
#: ../lib/python/temporal/sampling.py:91 ../lib/python/temporal/sampling.py:96
@@ -3689,9 +3531,7 @@
#: ../lib/python/temporal/abstract_dataset.py:388
#, python-format
-msgid ""
-"Unable to insert dataset <%(ds)s> of type %(type)s in the temporal database. "
-"The mapset of the dataset does not match the current mapset"
+msgid "Unable to insert dataset <%(ds)s> of type %(type)s in the temporal database. The mapset of the dataset does not match the current mapset"
msgstr ""
#: ../lib/python/temporal/abstract_dataset.py:428
@@ -3700,9 +3540,7 @@
#: ../lib/python/temporal/abstract_map_dataset.py:415
#: ../lib/python/temporal/abstract_map_dataset.py:511
#, python-format
-msgid ""
-"Unable to update dataset <%(ds)s> of type %(type)s in the temporal database. "
+msgid "Unable to update dataset <%(ds)s> of type %(type)s in the temporal database. The mapset of the dataset does not match the current mapset"
msgstr ""
#: ../lib/python/temporal/factory.py:47
@@ -3747,9 +3585,7 @@
#: ../lib/python/temporal/space_time_datasets.py:249
msgid "Invalid datetime in timestamp for raster map <%s>"
-msgstr ""
-"Fichier d'étiquette date&heure (timestamp) invalide pour la couche %s %s "
-"dans le jeu de données (mapset) %s"
+msgstr "Fichier d'étiquette date&heure (timestamp) invalide pour la couche %s %s dans le jeu de données (mapset) %s"
#: ../lib/python/temporal/space_time_datasets.py:254
#: ../lib/python/temporal/space_time_datasets.py:588
@@ -3776,9 +3612,7 @@
#: ../lib/python/temporal/space_time_datasets.py:583
msgid "Invalid datetime in timestamp for 3D raster map <%s>"
-msgstr ""
#: ../lib/python/temporal/space_time_datasets.py:847
@@ -3793,9 +3627,7 @@
#: ../lib/python/temporal/space_time_datasets.py:875
msgid "Invalid datetime in timestamp for vector map <%s>"
-msgstr ""
#: ../lib/python/temporal/space_time_datasets.py:891
@@ -3810,8 +3642,7 @@
#: ../lib/python/temporal/stds_import.py:95
msgid "Unable to set the color rules for raster map <%s>."
-msgstr ""
#: ../lib/python/temporal/stds_import.py:119
@@ -3923,9 +3754,7 @@
#: ../lib/python/temporal/stds_import.py:411
-msgid ""
-"Space time %(t)s dataset <%(sp)s> is already in the database. Use the "
-"overwrite flag."
+msgid "Space time %(t)s dataset <%(sp)s> is already in the database. Use the overwrite flag."
#: ../lib/python/temporal/stds_import.py:431
@@ -3949,9 +3778,7 @@
#: ../lib/python/temporal/temporal_vector_algebra.py:372
#, python-format
-msgid ""
-"Error vector maps with basename %s exist. Use --o flag to overwrite existing "
-"file"
+msgid "Error vector maps with basename %s exist. Use --o flag to overwrite existing file"
msgstr ""
#: ../lib/python/temporal/temporal_vector_algebra.py:404
@@ -3969,9 +3796,7 @@
#: ../lib/python/temporal/core.py:576
-msgid ""
-"Unable to initialize the temporal DBMI interface. Please use t.connect to "
-"specify the driver and the database string"
+msgid "Unable to initialize the temporal DBMI interface. Please use t.connect to specify the driver and the database string"
msgstr ""
#: ../lib/python/temporal/core.py:639
@@ -4013,46 +3838,32 @@
#: ../lib/python/temporal/core.py:913
#, python-format
-msgid ""
-"Unable to mogrify sql statement. There is no temporal database connection "
-"defined for mapset <%(mapset)s>"
+msgid "Unable to mogrify sql statement. There is no temporal database connection defined for mapset <%(mapset)s>"
msgstr ""
#: ../lib/python/temporal/core.py:936
-msgid ""
-"Unable to check table. There is no temporal database connection defined for "
-"mapset <%(mapset)s>"
+msgid "Unable to check table. There is no temporal database connection defined for mapset <%(mapset)s>"
msgstr "impossible d'ouvrir le fichier de datums : %s"
#: ../lib/python/temporal/core.py:953
#, python-format
-msgid ""
-"Unable to execute sql statement. There is no temporal database connection "
+msgid "Unable to execute sql statement. There is no temporal database connection defined for mapset <%(mapset)s>"
msgstr ""
#: ../lib/python/temporal/core.py:964
-msgid ""
-"Unable to fetch one. There is no temporal database connection defined for "
-msgstr ""
+msgid "Unable to fetch one. There is no temporal database connection defined for mapset <%(mapset)s>"
#: ../lib/python/temporal/core.py:975
-msgid ""
-"Unable to fetch all. There is no temporal database connection defined for "
-msgstr ""
+msgid "Unable to fetch all. There is no temporal database connection defined for mapset <%(mapset)s>"
#: ../lib/python/temporal/core.py:993
#, python-format
-msgid ""
-"Unable to execute transaction. There is no temporal database connection "
+msgid "Unable to execute transaction. There is no temporal database connection defined for mapset <%(mapset)s>"
msgstr ""
#: ../lib/python/temporal/core.py:1074
@@ -4123,23 +3934,17 @@
#: ../lib/python/temporal/abstract_space_time_dataset.py:1598
#, python-format
-msgid ""
-"Unable to shift dataset <%(ds)s> of type %(type)s in the temporal database. "
+msgid "Unable to shift dataset <%(ds)s> of type %(type)s in the temporal database. The mapset of the dataset does not match the current mapset"
msgstr ""
#: ../lib/python/temporal/abstract_space_time_dataset.py:1767
#, python-format
-msgid ""
-"Unable to snap dataset <%(ds)s> of type %(type)s in the temporal database. "
+msgid "Unable to snap dataset <%(ds)s> of type %(type)s in the temporal database. The mapset of the dataset does not match the current mapset"
msgstr ""
#: ../lib/python/temporal/abstract_space_time_dataset.py:1869
#, python-format
-msgid ""
-"Unable to rename dataset <%(ds)s> of type %(type)s in the temporal database. "
+msgid "Unable to rename dataset <%(ds)s> of type %(type)s in the temporal database. The mapset of the dataset does not match the current mapset"
msgstr ""
#: ../lib/python/temporal/abstract_space_time_dataset.py:1878
@@ -4154,9 +3959,7 @@
#: ../lib/python/temporal/abstract_space_time_dataset.py:1949
#: ../lib/python/temporal/abstract_map_dataset.py:823
#, python-format
-msgid ""
-"Unable to delete dataset <%(ds)s> of type %(type)s from the temporal "
-"database. The mapset of the dataset does not match the current mapset"
+msgid "Unable to delete dataset <%(ds)s> of type %(type)s from the temporal database. The mapset of the dataset does not match the current mapset"
msgstr ""
#: ../lib/python/temporal/abstract_space_time_dataset.py:1962
@@ -4171,15 +3974,11 @@
#: ../lib/python/temporal/abstract_space_time_dataset.py:2046
-msgid ""
-"Unable to register map in dataset <%(ds)s> of type %(type)s. The mapset of "
-"the dataset does not match the current mapset"
+msgid "Unable to register map in dataset <%(ds)s> of type %(type)s. The mapset of the dataset does not match the current mapset"
msgstr "la couche matricielle demandée <%s> n'a pas été trouvée"
#: ../lib/python/temporal/abstract_space_time_dataset.py:2055
-msgid ""
-"Only a map that was inserted in the temporal database can be registered in a "
-"space time dataset"
+msgid "Only a map that was inserted in the temporal database can be registered in a space time dataset"
msgstr ""
#: ../lib/python/temporal/abstract_space_time_dataset.py:2078
@@ -4194,15 +3993,12 @@
#: ../lib/python/temporal/abstract_space_time_dataset.py:2100
-msgid ""
-"Temporal type of space time dataset <%(id)s> and map <%(map)s> with layer "
-"%(l)s are different"
+msgid "Temporal type of space time dataset <%(id)s> and map <%(map)s> with layer %(l)s are different"
#: ../lib/python/temporal/abstract_space_time_dataset.py:2106
-msgid ""
-"Temporal type of space time dataset <%(id)s> and map <%(map)s> are different"
+msgid "Temporal type of space time dataset <%(id)s> and map <%(map)s> are different"
#: ../lib/python/temporal/abstract_space_time_dataset.py:2121
@@ -4212,16 +4008,12 @@
#: ../lib/python/temporal/abstract_space_time_dataset.py:2131
#, python-format
-msgid ""
-"Relative time units of space time dataset <%(id)s> and map <%(map)s> with "
-"layer %(l)s are different"
+msgid "Relative time units of space time dataset <%(id)s> and map <%(map)s> with layer %(l)s are different"
msgstr ""
#: ../lib/python/temporal/abstract_space_time_dataset.py:2137
#, python-format
-msgid ""
-"Relative time units of space time dataset <%(id)s> and map <%(map)s> are "
-"different"
+msgid "Relative time units of space time dataset <%(id)s> and map <%(map)s> are different"
msgstr ""
#: ../lib/python/temporal/abstract_space_time_dataset.py:2143
@@ -4240,17 +4032,12 @@
#: ../lib/python/temporal/abstract_space_time_dataset.py:2200
#, python-format
-msgid ""
-"Unable to unregister map from dataset <%(ds)s> of type %(type)s in the "
-"temporal database. The mapset of the dataset does not match the current "
-"mapset"
+msgid "Unable to unregister map from dataset <%(ds)s> of type %(type)s in the temporal database. The mapset of the dataset does not match the current mapset"
msgstr ""
#: ../lib/python/temporal/abstract_space_time_dataset.py:2213
-msgid ""
-"Map <%(map)s> with layer %(l)s is not registered in space time dataset <"
-"%(base)s>"
+msgid "Map <%(map)s> with layer %(l)s is not registered in space time dataset <%(base)s>"
#: ../lib/python/temporal/abstract_space_time_dataset.py:2219
@@ -4260,8 +4047,7 @@
#: ../lib/python/temporal/abstract_space_time_dataset.py:2280
#, python-format
-msgid ""
-"Update metadata, spatial and temporal extent from all registered maps of <%s>"
+msgid "Update metadata, spatial and temporal extent from all registered maps of <%s>"
msgstr ""
#: ../lib/python/temporal/mapcalc.py:105
@@ -4277,10 +4063,7 @@
msgstr ""
#: ../lib/python/temporal/mapcalc.py:151
-msgid ""
-"Found more than a single map in a sample granule. Only the first map is used "
-"for computation. Use t.rast.aggregate.ds to create synchronous raster "
-"datasets."
+msgid "Found more than a single map in a sample granule. Only the first map is used for computation. Use t.rast.aggregate.ds to create synchronous raster datasets."
msgstr ""
#: ../lib/python/temporal/mapcalc.py:169
@@ -4344,9 +4127,7 @@
#: ../lib/python/temporal/aggregation.py:135
-msgid ""
-"Raster map <%(name)s> is already in temporal database, use overwrite flag to "
-"overwrite"
+msgid "Raster map <%(name)s> is already in temporal database, use overwrite flag to overwrite"
#: ../lib/python/temporal/aggregation.py:140
@@ -4366,9 +4147,7 @@
#: ../lib/python/temporal/aggregation.py:289
#, python-format
-msgid ""
-"Unable to perform aggregation. Output raster map <%(name)s> exists and "
-"overwrite flag was not set"
+msgid "Unable to perform aggregation. Output raster map <%(name)s> exists and overwrite flag was not set"
msgstr ""
#: ../lib/python/temporal/register.py:76 ../lib/python/temporal/register.py:79
@@ -4392,9 +4171,7 @@
#: ../lib/python/temporal/register.py:98
#, python-format
-msgid ""
-"Space time %(sp)s dataset <%(name)s> with relative time found, but no "
-"relative unit set for %(sp)s maps"
+msgid "Space time %(sp)s dataset <%(name)s> with relative time found, but no relative unit set for %(sp)s maps"
msgstr ""
#: ../lib/python/temporal/register.py:163
@@ -4408,16 +4185,12 @@
#: ../lib/python/temporal/register.py:191
-msgid ""
-"Unable to register %(t)s map <%(id)s> with layer %(l)s. The map has "
-"timestamp and the start time is not set."
+msgid "Unable to register %(t)s map <%(id)s> with layer %(l)s. The map has timestamp and the start time is not set."
#: ../lib/python/temporal/register.py:197
-msgid ""
-"Unable to register %(t)s map <%(id)s>. The map has no timestamp and the "
-"start time is not set."
+msgid "Unable to register %(t)s map <%(id)s>. The map has no timestamp and the start time is not set."
#: ../lib/python/temporal/register.py:205
@@ -4432,23 +4205,17 @@
#: ../lib/python/temporal/register.py:221
-msgid ""
-"Map is already registered in temporal database. Unable to update %(t)s map <"
-"%(id)s> with layer %(l)s. Overwrite flag is not set."
+msgid "Map is already registered in temporal database. Unable to update %(t)s map <%(id)s> with layer %(l)s. Overwrite flag is not set."
#: ../lib/python/temporal/register.py:228
-msgid ""
-"%(id)s>. Overwrite flag is not set."
+msgid "Map is already registered in temporal database. Unable to update %(t)s map <%(id)s>. Overwrite flag is not set."
#: ../lib/python/temporal/register.py:252
-msgid ""
-"Unable to update %(t)s map <%(id)s> with layer %(l)s. The temporal types are "
-"different."
+msgid "Unable to update %(t)s map <%(id)s> with layer %(l)s. The temporal types are different."
#: ../lib/python/temporal/register.py:258
@@ -4485,9 +4252,7 @@
#: ../lib/python/temporal/register.py:396
-msgid ""
-"Set absolute valid time for map <%(id)s> with layer %(layer)s to %(start)s - "
-"%(end)s"
+msgid "Set absolute valid time for map <%(id)s> with layer %(layer)s to %(start)s - %(end)s"
#: ../lib/python/temporal/register.py:401
@@ -4497,8 +4262,7 @@
#: ../lib/python/temporal/register.py:418
-msgid ""
-"Set relative valid time for map <%s> with layer %s to %i - %s with unit %s"
+msgid "Set relative valid time for map <%s> with layer %s to %i - %s with unit %s"
#: ../lib/python/temporal/register.py:423
@@ -4518,9 +4282,7 @@
#: ../lib/python/temporal/base.py:620
#, fuzzy
msgid "Wrong identifier, the mapset is missing"
-msgstr ""
-"Impossible d'ouvrir le fichier d'index de catégorie pour la couche "
-"vectorielle <%s@%s>"
+msgstr "Impossible d'ouvrir le fichier d'index de catégorie pour la couche vectorielle <%s@%s>"
#: ../lib/python/temporal/univar_statistics.py:50
#: ../lib/python/temporal/univar_statistics.py:149
@@ -4599,9 +4361,7 @@
#: ../lib/python/temporal/temporal_algebra.py:1133
#: ../lib/python/temporal/temporal_algebra.py:1137
#, python-format
-msgid ""
-"Wrong temporal type of space time dataset <"
-"%s> <%s> time is required"
+msgid "Wrong temporal type of space time dataset <%s> <%s> time is required"
msgstr ""
#: ../lib/python/temporal/temporal_algebra.py:1157
@@ -4611,22 +4371,16 @@
#: ../lib/python/temporal/temporal_algebra.py:2031
#, python-format
-msgid ""
-"The resulting space time dataset type <%(a)s> is different from the "
-"requested type <%(b)s>"
+msgid "The resulting space time dataset type <%(a)s> is different from the requested type <%(b)s>"
msgstr ""
#: ../lib/python/temporal/temporal_algebra.py:2037
-msgid ""
-"Maps that should be registered in the resulting space time dataset have "
-"different types."
+msgid "Maps that should be registered in the resulting space time dataset have different types."
msgstr ""
#: ../lib/python/temporal/temporal_algebra.py:2218
#, python-format
-msgid ""
-"Wrong map type <%s> . TMAP only supports single maps that are registered in "
-"the temporal GRASS database"
+msgid "Wrong map type <%s> . TMAP only supports single maps that are registered in the temporal GRASS database"
msgstr ""
#: ../lib/python/temporal/list_stds.py:191
@@ -4638,25 +4392,19 @@
msgstr ""
#: ../lib/python/temporal/spatial_extent.py:118
-msgid ""
-"Projections are different. Unable to compute overlapping_2d for spatial "
-"extents"
+msgid "Projections are different. Unable to compute overlapping_2d for spatial extents"
msgstr ""
#: ../lib/python/temporal/spatial_extent.py:524
-msgid ""
-"Projections are different. Unable to compute is_in_2d for spatial extents"
+msgid "Projections are different. Unable to compute is_in_2d for spatial extents"
msgstr ""
#: ../lib/python/temporal/spatial_extent.py:656
-msgid ""
-"Projections are different. Unable to compute equivalent_2d for spatial "
-"extents"
+msgid "Projections are different. Unable to compute equivalent_2d for spatial extents"
msgstr ""
#: ../lib/python/temporal/spatial_extent.py:761
-msgid ""
-"Projections are different. Unable to compute cover_2d for spatial extents"
+msgid "Projections are different. Unable to compute cover_2d for spatial extents"
msgstr ""
#: ../lib/python/temporal/spatial_extent.py:833
@@ -4673,40 +4421,27 @@
#: ../lib/python/temporal/abstract_map_dataset.py:341
-msgid ""
-"Start time must be of type datetime for %(type)s map <%(id)s> with layer: "
-"%(l)s"
-msgstr ""
-"Impossible de créer le fichier d'étiquettes date&heure (timestamp) pour la "
-"couche %s %s dans le jeu de données (mapset) %s"
+msgid "Start time must be of type datetime for %(type)s map <%(id)s> with layer: %(l)s"
+msgstr "Impossible de créer le fichier d'étiquettes date&heure (timestamp) pour la couche %s %s dans le jeu de données (mapset) %s"
#: ../lib/python/temporal/abstract_map_dataset.py:348
msgid "Start time must be of type datetime for %(type)s map <%(id)s>"
-msgstr ""
#: ../lib/python/temporal/abstract_map_dataset.py:356
-msgid ""
-"End time must be of type datetime for %(type)s map <%(id)s> with layer: %(l)s"
-msgstr ""
+msgid "End time must be of type datetime for %(type)s map <%(id)s> with layer: %(l)s"
#: ../lib/python/temporal/abstract_map_dataset.py:363
msgid "End time must be of type datetime for %(type)s map <%(id)s>"
-msgstr ""
#: ../lib/python/temporal/abstract_map_dataset.py:372
-msgid ""
-"End time must be greater than start time for %(type)s map <%(id)s> with "
-"layer: %(l)s"
+msgid "End time must be greater than start time for %(type)s map <%(id)s> with layer: %(l)s"
msgstr "L'Est doit être plus grand que l'Ouest"
#: ../lib/python/temporal/abstract_map_dataset.py:380
@@ -4717,12 +4452,8 @@
#: ../lib/python/temporal/abstract_map_dataset.py:451
-msgid ""
-"Unsupported relative time unit type for %(type)s map <%(id)s> with layer "
-"%(l)s: %(u)s"
-msgstr ""
+msgid "Unsupported relative time unit type for %(type)s map <%(id)s> with layer %(l)s: %(u)s"
#: ../lib/python/temporal/abstract_map_dataset.py:458
@@ -4731,22 +4462,17 @@
#: ../lib/python/temporal/abstract_map_dataset.py:467
-msgid ""
-"End time must be greater than start time for %(typ)s map <%(id)s> with layer "
-"%(l)s"
+msgid "End time must be greater than start time for %(typ)s map <%(id)s> with layer %(l)s"
#: ../lib/python/temporal/abstract_map_dataset.py:782
#, python-format
-msgid ""
-"Map <%(id)s> with layer %(layer)s has incorrect time interval, start time is "
-"greater than end time"
+msgid "Map <%(id)s> with layer %(layer)s has incorrect time interval, start time is greater than end time"
msgstr ""
#: ../lib/python/temporal/abstract_map_dataset.py:788
#, python-format
-msgid ""
-"Map <%s> has incorrect time interval, start time is greater than end time"
+msgid "Map <%s> has incorrect time interval, start time is greater than end time"
msgstr ""
#: ../lib/python/temporal/abstract_map_dataset.py:794
@@ -4761,15 +4487,12 @@
#: ../lib/python/temporal/abstract_map_dataset.py:891
#, python-format
-msgid ""
-"Unable to unregister dataset <%(ds)s> of type %(type)s from the temporal "
+msgid "Unable to unregister dataset <%(ds)s> of type %(type)s from the temporal database. The mapset of the dataset does not match the current mapset"
msgstr ""
#: ../lib/python/script/db.py:149
#, python-format
-msgid ""
-"Programmer error: '%(sql)s', '%(filename)s', or '%(table)s' must be provided"
+msgid "Programmer error: '%(sql)s', '%(filename)s', or '%(table)s' must be provided"
msgstr ""
#: ../lib/python/script/db.py:159
@@ -4817,10 +4540,7 @@
#: ../lib/python/script/core.py:287
#, python-format
-msgid ""
-"To run the module <%s> add underscore at the end of the option <%s> to avoid "
-"conflict with Python keywords. Underscore at the beginning is depreciated in "
-"GRASS GIS 7.0 and will be removed in version 7.1."
+msgid "To run the module <%s> add underscore at the end of the option <%s> to avoid conflict with Python keywords. Underscore at the beginning is depreciated in GRASS GIS 7.0 and will be removed in version 7.1."
msgstr ""
#: ../lib/python/script/core.py:909
@@ -4889,12 +4609,8 @@
#: ../lib/python/script/raster.py:46
-msgid ""
-"Unable to write history for <%(map)s>. Raster map <%(map)s> not found in "
-"current mapset."
-msgstr ""
-"Impossible de supprimer la ligne, la couche '%s' n'est pas ouverte en mode "
-"'écriture'"
+msgid "Unable to write history for <%(map)s>. Raster map <%(map)s> not found in current mapset."
+msgstr "Impossible de supprimer la ligne, la couche '%s' n'est pas ouverte en mode 'écriture'"
#: ../lib/python/script/raster.py:105
msgid "An error occurred while running r.mapcalc"
@@ -4925,11 +4641,8 @@
#: ../lib/symbol/read.c:260
#, c-format
-msgid ""
-"Incorrect symbol name: '%s' (should be: group/name or group/name at mapset)"
-msgstr ""
-"Nom du symbole incorrect: '%s' (devrait être group/nom ou groupe/"
-"nom at jeudedonnées)"
+msgid "Incorrect symbol name: '%s' (should be: group/name or group/name at mapset)"
+msgstr "Nom du symbole incorrect: '%s' (devrait être group/nom ou groupe/nom at jeudedonnées)"
#: ../lib/symbol/read.c:284
#, c-format
@@ -4977,9 +4690,7 @@
#: ../lib/ogsf/gp3.c:288
#, c-format
-msgid ""
-"%d points without category. Unable to determine color rules for features "
-"without category."
+msgid "%d points without category. Unable to determine color rules for features without category."
msgstr ""
#: ../lib/ogsf/gp2.c:705
@@ -5027,9 +4738,7 @@
#: ../lib/ogsf/gs3.c:596
#, c-format
msgid "Color table range doesn't match data (mincol=%d, maxcol=%d"
-msgstr ""
-"L'étendue de la table de couleur ne correspond pas aux données (mincol=%d, "
-"maxcol=%d"
+msgstr "L'étendue de la table de couleur ne correspond pas aux données (mincol=%d, maxcol=%d"
#: ../lib/ogsf/gs3.c:658 ../lib/ogsf/gs3.c:730
#, c-format
@@ -5055,18 +4764,13 @@
#: ../lib/ogsf/gsd_prim.c:630
#, c-format
-msgid ""
-"gsd_rot(): %c is an invalid axis specification. Rotation ignored. Please "
-"advise GRASS developers of this error"
-msgstr ""
-"gsd_rot(): %c est une spécification d'axe non valide. Rotation ignorée. "
-"Merci d'avertir les développeurs GRASS de cette erreur"
+msgid "gsd_rot(): %c is an invalid axis specification. Rotation ignored. Please advise GRASS developers of this error"
+msgstr "gsd_rot(): %c est une spécification d'axe non valide. Rotation ignorée. Merci d'avertir les développeurs GRASS de cette erreur"
#: ../lib/ogsf/gv3.c:269
#, c-format
msgid "No features from vector map <%s> fall within current region"
-msgstr ""
-"Aucune entité de la carte vecteur <%s> ne tombe dans la région courante"
+msgstr "Aucune entité de la carte vecteur <%s> ne tombe dans la région courante"
#: ../lib/ogsf/gv3.c:274
#, c-format
@@ -5080,9 +4784,7 @@
#: ../lib/ogsf/gv3.c:414
#, c-format
-msgid ""
-"%d features without category. Unable to determine color rules for features "
+msgid "%d features without category. Unable to determine color rules for features without category."
msgstr ""
#: ../lib/ogsf/gsd_label.c:58
@@ -5102,8 +4804,7 @@
#: ../lib/ogsf/gs2.c:1655
#, c-format
msgid "Raster map <%s> is outside of current region. Load failed."
-msgstr ""
-"La carte raster <%s> est en dehors de la région courante. Chargement échoué."
+msgstr "La carte raster <%s> est en dehors de la région courante. Chargement échoué."
#: ../lib/ogsf/gs2.c:1733 ../lib/ogsf/gs2.c:1739 ../lib/ogsf/gs2.c:1747
#: ../lib/ogsf/gs2.c:1756 ../lib/ogsf/gs2.c:1764 ../lib/ogsf/gs2.c:1774
@@ -5121,8 +4822,7 @@
#: ../lib/ogsf/gsd_surf.c:1742
msgid "Cut-plane points mis-match between surfaces. Check resolution(s)."
-msgstr ""
-"Non concordance des points de surfaces de coupe. Vérifiez les résolutions."
+msgstr "Non concordance des points de surfaces de coupe. Vérifiez les résolutions."
#: ../lib/ogsf/gsd_legend.c:246
#, c-format
@@ -5150,8 +4850,7 @@
#: ../lib/ogsf/gsd_legend.c:385
msgid "Unable to show discrete FP range (use list)"
-msgstr ""
-"Impossible d'afficher une plage flottante discrète (utilisation d'une liste)"
+msgstr "Impossible d'afficher une plage flottante discrète (utilisation d'une liste)"
#: ../lib/ogsf/gsd_legend.c:501
msgid "Too many categories to show as discrete!"
@@ -5226,8 +4925,7 @@
#: ../lib/arraystats/class.c:42
msgid "Discont algorithm currently not available because of bugs"
-msgstr ""
-"L'algorithme discont n'est actuellement pas disponible à cause d'un bug"
+msgstr "L'algorithme discont n'est actuellement pas disponible à cause d'un bug"
#: ../lib/arraystats/class.c:49
#, fuzzy
@@ -5240,12 +4938,8 @@
#: ../lib/arraystats/class.c:242
#, c-format
-msgid ""
-"There are classbreaks outside the range min-max. Number of classes reduced "
-"to %i, but using probabilities for %i classes."
-msgstr ""
-"Il y a des ruptures de classes en dehors de la plage min-max. Nombre de "
-"classes réduites à %i, mais utilisation des probabilités sur %i classes."
+msgid "There are classbreaks outside the range min-max. Number of classes reduced to %i, but using probabilities for %i classes."
+msgstr "Il y a des ruptures de classes en dehors de la plage min-max. Nombre de classes réduites à %i, mais utilisation des probabilités sur %i classes."
#: ../lib/psdriver/graph_set.c:199
#, c-format
@@ -5375,9 +5069,7 @@
#: ../lib/raster3d/open.c:119
#, fuzzy
msgid "Rast3d_open_cell_old: projection does not match window projection"
-msgstr ""
-"Rast3d_openCellOld : la projection ne correspond pas à la projection de la "
-"fenêtre"
+msgstr "Rast3d_openCellOld : la projection ne correspond pas à la projection de la fenêtre"
#: ../lib/raster3d/open.c:123
#, fuzzy
@@ -5437,9 +5129,7 @@
#: ../lib/raster3d/color.c:354
#, fuzzy, c-format
msgid "mapset <%s> is not the current mapset"
-msgstr ""
-"données (mapset) courant."
+msgstr "Bug: tentative de mise à jour d'une couche qui n'est pas dans le jeu de données (mapset) courant."
#: ../lib/raster3d/history.c:43
#, c-format
@@ -5587,17 +5277,12 @@
#: ../lib/gis/view.c:545
#, c-format
msgid " Window saved in \"%s\" is completely outside of current GRASS window."
-msgstr ""
-"La fenêtre sauvegardée dans \"%s\" est complètement en dehors de la fenêtre "
-"GRASS courante."
+msgstr "La fenêtre sauvegardée dans \"%s\" est complètement en dehors de la fenêtre GRASS courante."
#: ../lib/gis/view.c:549
#, c-format
-msgid ""
-" Only %d%% of window saved in \"%s\" overlaps with current GRASS window."
-msgstr ""
-" Seulement %d%% de la fenêtre sauvegardée dans \"%s\" chevauche(nt) la "
-"fenêtre GRASS courante."
+msgid " Only %d%% of window saved in \"%s\" overlaps with current GRASS window."
+msgstr " Seulement %d%% de la fenêtre sauvegardée dans \"%s\" chevauche(nt) la fenêtre GRASS courante."
#: ../lib/gis/parser_interface.c:329 ../lib/gis/parser_html.c:167
#: ../lib/gis/parser_help.c:200 ../lib/gis/parser_rest.c:164
@@ -5679,8 +5364,7 @@
#: ../lib/gis/legal_name.c:77 ../lib/gis/legal_name.c:81
#, c-format
msgid "Output raster map name <%s> is not valid map name"
-msgstr ""
-"Le nom <%s> de la carte raster en sortie n'est pas un nom de carte valide"
+msgstr "Le nom <%s> de la carte raster en sortie n'est pas un nom de carte valide"
#: ../lib/gis/legal_name.c:118 ../lib/gis/legal_name.c:122
#, c-format
@@ -5690,8 +5374,7 @@
#: ../lib/gis/find_file.c:114
#, c-format
msgid "'%s/%s' was found in more mapsets (also found in <%s>)"
-msgstr ""
-"'%s/%s' trouvé dans plusieurs jeux de cartes (également trouvé dans <%s>)"
+msgstr "'%s/%s' trouvé dans plusieurs jeux de cartes (également trouvé dans <%s>)"
#: ../lib/gis/find_file.c:127
#, c-format
@@ -5704,12 +5387,8 @@
#: ../lib/gis/gisinit.c:53 ../lib/gis/gisinit.c:87
#, fuzzy, c-format
-msgid ""
-"Module built against version %s but trying to use version %s. You need to "
-"rebuild GRASS GIS or untangle multiple installations."
-msgstr ""
-"Version de librairie incompatible pour le module. Vous devez recompiler "
-"GRASS ou gérer les versions multiples."
+msgid "Module built against version %s but trying to use version %s. You need to rebuild GRASS GIS or untangle multiple installations."
+msgstr "Version de librairie incompatible pour le module. Vous devez recompiler GRASS ou gérer les versions multiples."
#: ../lib/gis/gisinit.c:65
#, c-format
@@ -5733,37 +5412,27 @@
#: ../lib/gis/timestamp.c:301
#, fuzzy, c-format
msgid "Invalid timestamp specified for %s map <%s@%s>"
-msgstr ""
-"L'étiquette date&heure (timestamp) spécifiée pour la couche %s %s est "
-"invalide dans le jeu de données (mapset) %s"
+msgstr "L'étiquette date&heure (timestamp) spécifiée pour la couche %s %s est invalide dans le jeu de données (mapset) %s"
#: ../lib/gis/timestamp.c:331
#, fuzzy, c-format
msgid "Unable to open timestamp file for %s map <%s@%s>"
-msgstr ""
#: ../lib/gis/timestamp.c:340
#, fuzzy, c-format
msgid "Invalid timestamp file for %s map <%s@%s>"
-msgstr ""
#: ../lib/gis/timestamp.c:479
#, fuzzy, c-format
msgid "Unable to open timestamp file for vector map <%s@%s>"
-msgstr ""
#: ../lib/gis/timestamp.c:488
#, fuzzy, c-format
msgid "Invalid timestamp file for vector map <%s@%s>"
-msgstr ""
#: ../lib/gis/timestamp.c:524
#, fuzzy, c-format
@@ -5773,9 +5442,7 @@
#: ../lib/gis/timestamp.c:533
#, fuzzy, c-format
msgid "Invalid timestamp specified for vector map <%s@%s>"
-msgstr ""
#: ../lib/gis/error.c:361
msgid "WARNING: "
@@ -5948,9 +5615,7 @@
#: ../lib/gis/adj_cellhd.c:74 ../lib/gis/adj_cellhd.c:239
#, c-format
msgid "Fixing subtle input data rounding error of north boundary (%g>%g)"
-msgstr ""
-"Ajustement d'une légère erreur d'arrondi sur la valeur de la limite Nord (%g>"
-"%g)"
+msgstr "Ajustement d'une légère erreur d'arrondi sur la valeur de la limite Nord (%g>%g)"
#: ../lib/gis/adj_cellhd.c:79 ../lib/gis/adj_cellhd.c:244
msgid "Illegal latitude for North"
@@ -5959,9 +5624,7 @@
#: ../lib/gis/adj_cellhd.c:85 ../lib/gis/adj_cellhd.c:250
#, c-format
msgid "Fixing subtle input data rounding error of south boundary (%g>%g)"
-msgstr ""
-"justement d'une légère erreur d'arrondi sur la valeur de la limite Sud (%g>"
-"%g)"
+msgstr "justement d'une légère erreur d'arrondi sur la valeur de la limite Sud (%g>%g)"
#: ../lib/gis/adj_cellhd.c:90 ../lib/gis/adj_cellhd.c:255
msgid "Illegal latitude for South"
@@ -5970,16 +5633,12 @@
#: ../lib/gis/adj_cellhd.c:102 ../lib/gis/adj_cellhd.c:267
#, c-format
msgid "Fixing subtle input data rounding error of west boundary (%g>%g)"
-msgstr ""
-"Erreur dans les méthodes de fixation des données d'entrée à la frontière "
-"Ouest (%g>%g)"
+msgstr "Erreur dans les méthodes de fixation des données d'entrée à la frontière Ouest (%g>%g)"
#: ../lib/gis/adj_cellhd.c:113 ../lib/gis/adj_cellhd.c:278
#, c-format
msgid "Fixing subtle input data rounding error of east boundary (%g>%g)"
-msgstr ""
-"Erreur dans les méthodes de fixation des données d'entrée à la frontière Est "
-"(%g>%g)"
+msgstr "Erreur dans les méthodes de fixation des données d'entrée à la frontière Est (%g>%g)"
#: ../lib/gis/adj_cellhd.c:126 ../lib/gis/adj_cellhd.c:291
msgid "North must be north of South"
@@ -6319,8 +5978,7 @@
msgstr "Nom de la base de données"
#: ../lib/gis/parser_standard_options.c:192
-msgid ""
-"Do not use this option if schemas are not supported by driver/database server"
+msgid "Do not use this option if schemas are not supported by driver/database server"
msgstr ""
#: ../lib/gis/parser_standard_options.c:201
@@ -6453,9 +6111,7 @@
msgstr "Type de données utilisées dans le fichier de sortie"
#: ../lib/gis/parser_standard_options.c:418
-msgid ""
-"Number of digits used as mantissa in the internal map storage, 0 -23 for "
-"float, 0 - 52 for double, max or default"
+msgid "Number of digits used as mantissa in the internal map storage, 0 -23 for float, 0 - 52 for double, max or default"
msgstr ""
#: ../lib/gis/parser_standard_options.c:428
@@ -6465,9 +6121,7 @@
#: ../lib/gis/parser_standard_options.c:438
#, fuzzy
-msgid ""
-"The dimensions of the tiles used in the output raster3d map (XxYxZ or "
-"default: 16x16x8)"
+msgid "The dimensions of the tiles used in the output raster3d map (XxYxZ or default: 16x16x8)"
msgstr "Les dimensions des dalles utilisées dans le fichier de sortie"
#: ../lib/gis/parser_standard_options.c:448
@@ -6514,13 +6168,8 @@
#: ../lib/gis/parser_standard_options.c:512
#, fuzzy
-msgid ""
-"Vector features can have category values in different layers. This number "
-"determines which layer to use. When used with direct OGR access this is the "
-"layer name."
-msgstr ""
-"Une seule carte vectorielle peut être connectée à plusieurs tables de base "
-"de données. Ce nombre détermine la table à utiliser."
+msgid "Vector features can have category values in different layers. This number determines which layer to use. When used with direct OGR access this is the layer name."
+msgstr "Une seule carte vectorielle peut être connectée à plusieurs tables de base de données. Ce nombre détermine la table à utiliser."
#: ../lib/gis/parser_standard_options.c:522
#, fuzzy
@@ -6529,13 +6178,8 @@
#: ../lib/gis/parser_standard_options.c:524
#, fuzzy
-msgid ""
-"A single vector map can be connected to multiple database tables. This "
-"number determines which table to use. When used with direct OGR access this "
-"is the layer name."
-msgstr ""
+msgid "A single vector map can be connected to multiple database tables. This number determines which table to use. When used with direct OGR access this is the layer name."
#: ../lib/gis/parser_standard_options.c:533
msgid "Category value"
@@ -6733,9 +6377,7 @@
#: ../lib/gis/parser_standard_options.c:870
#, fuzzy
-msgid ""
-"WHERE conditions of SQL statement without 'where' keyword used in the "
-"temporal GIS framework"
+msgid "WHERE conditions of SQL statement without 'where' keyword used in the temporal GIS framework"
msgstr "WHERE conditions d'une clause SQL sans le mot-clef 'where'"
#: ../lib/gis/parser_standard_options.c:871
@@ -6881,15 +6523,11 @@
#: ../lib/gis/parser.c:519
msgid "Use either --quiet or --verbose flag, not both. Assuming --verbose."
-msgstr ""
-"Utiliser le drapeau soit --quiet soit --verbose, pas les deux ; --verbose "
-"supposé."
+msgstr "Utiliser le drapeau soit --quiet soit --verbose, pas les deux ; --verbose supposé."
#: ../lib/gis/parser.c:533
msgid "Use either --quiet or --verbose flag, not both. Assuming --quiet."
-msgstr ""
-"Utiliser le drapeau soit --quiet soit --verbose, pas les deux ; --quiet "
-"supposé."
+msgstr "Utiliser le drapeau soit --quiet soit --verbose, pas les deux ; --quiet supposé."
#: ../lib/gis/parser.c:564
#, fuzzy, c-format
@@ -7276,8 +6914,7 @@
#: ../lib/rst/interp_float/vinput2d.c:249
#, c-format
msgid "There are points outside specified 2D/3D region - %d points ignored"
-msgstr ""
-"il y a des points en-dehors de la région 2D/3D spécifiée - %d points ignorés"
+msgstr "il y a des points en-dehors de la région 2D/3D spécifiée - %d points ignorés"
#: ../lib/rst/interp_float/vinput2d.c:252
#, c-format
@@ -7286,12 +6923,8 @@
#: ../lib/rst/interp_float/vinput2d.c:256
#, c-format
-msgid ""
-"%d points given for interpolation (after thinning) is less than given NPMIN="
-"%d"
-msgstr ""
-"%d points donnés pour l'interpolation (après squelettisation) est moins que "
-"le NPMIN=% donnéd"
+msgid "%d points given for interpolation (after thinning) is less than given NPMIN=%d"
+msgstr "%d points donnés pour l'interpolation (après squelettisation) est moins que le NPMIN=% donnéd"
#: ../lib/rst/interp_float/vinput2d.c:261
msgid "Zero points in the given region"
@@ -7299,22 +6932,13 @@
#: ../lib/rst/interp_float/vinput2d.c:266
#, c-format
-msgid ""
-"Segmentation parameters set to invalid values: npmin= %d, segmax= %d for "
-"smooth connection of segments, npmin > segmax (see manual)"
-msgstr ""
-"Paramètres de segmentation invalides: npmin= %d, segmax= %d pour une bonne "
-"connexion des segments, npmin > segmax (voir le manuel)"
+msgid "Segmentation parameters set to invalid values: npmin= %d, segmax= %d for smooth connection of segments, npmin > segmax (see manual)"
+msgstr "Paramètres de segmentation invalides: npmin= %d, segmax= %d pour une bonne connexion des segments, npmin > segmax (voir le manuel)"
#: ../lib/rst/interp_float/vinput2d.c:272
#, c-format
-msgid ""
-"There are less than %d points for interpolation. No segmentation is "
-"necessary, to run the program faster set segmax=%d (see manual)"
-msgstr ""
-"Il y a moins de %d poitns pour l'interpolation. Aucune segmentation n'est "
-"nécessaire, pour faire tourner le programme plus vite, paramétrez segmax=%d "
-"(voir manuel)"
+msgid "There are less than %d points for interpolation. No segmentation is necessary, to run the program faster set segmax=%d (see manual)"
+msgstr "Il y a moins de %d poitns pour l'interpolation. Aucune segmentation n'est nécessaire, pour faire tourner le programme plus vite, paramétrez segmax=%d (voir manuel)"
#: ../lib/rst/interp_float/vinput2d.c:276
#, c-format
@@ -7352,12 +6976,8 @@
msgstr "Impossible de réécrire la ligne"
#: ../lib/rst/interp_float/segmen2d.c:118
-msgid ""
-"Taking too long to find points for interpolation - please change the region "
-"to area where your points are. Continuing calculations..."
-msgstr ""
-"Recherche de points pour l'interpolation trop longue -- merci de changer la "
-"région pour la zone où se trouvent vos points. Poursuite des calculs ..."
+msgid "Taking too long to find points for interpolation - please change the region to area where your points are. Continuing calculations..."
+msgstr "Recherche de points pour l'interpolation trop longue -- merci de changer la région pour la zone où se trouvent vos points. Poursuite des calculs ..."
#: ../lib/rst/interp_float/input2d.c:48
#, c-format
@@ -7380,12 +7000,8 @@
#: ../lib/rst/interp_float/interp2d.c:214
#, c-format
-msgid ""
-"Overshoot - increase in tension suggested. Overshoot occures at (%d,%d) "
-"cell. Z-value %f, zmin %f, zmax %f."
-msgstr ""
-"Dépassement - augmentation de la tension suggérée. Le dépassement se produit "
-"à la cellule (%d,%d), valeur Z %f, zmin %f, zmax %f."
+msgid "Overshoot - increase in tension suggested. Overshoot occures at (%d,%d) cell. Z-value %f, zmin %f, zmax %f."
+msgstr "Dépassement - augmentation de la tension suggérée. Le dépassement se produit à la cellule (%d,%d), valeur Z %f, zmin %f, zmax %f."
#: ../lib/rst/interp_float/resout2d.c:77
msgid "Temporarily changing the region to desired resolution..."
@@ -7541,8 +7157,7 @@
#: ../lib/gmath/la.c:788
msgid "Specified matrix column index is outside range"
-msgstr ""
-"L'index de colonne de la matrice spécifié est en dehors de l'intervalle"
+msgstr "L'index de colonne de la matrice spécifié est en dehors de l'intervalle"
#: ../lib/gmath/la.c:793 ../lib/gmath/la.c:834 ../lib/gmath/la.c:1198
#: ../lib/gmath/la.c:1250 ../lib/gmath/la.c:1325
@@ -7891,11 +7506,8 @@
#: ../lib/proj/convert.c:139
#, c-format
-msgid ""
-"OGR can't parse PROJ.4-style parameter string: %s (OGR Error code was %d)"
-msgstr ""
-"OGR ne peut pas analyser la chaîne de paramètre PROJ.4: %s (Le code erreur "
-"OGR était %d)"
+msgid "OGR can't parse PROJ.4-style parameter string: %s (OGR Error code was %d)"
+msgstr "OGR ne peut pas analyser la chaîne de paramètre PROJ.4: %s (Le code erreur OGR était %d)"
#: ../lib/proj/convert.c:146
#, c-format
@@ -7904,9 +7516,7 @@
#: ../lib/proj/convert.c:406
msgid "No projection name! Projection parameters likely to be meaningless."
-msgstr ""
-"Aucun nom de projection ! Projection de paramètres susceptibles d'être vide "
-"de sens."
+msgstr "Aucun nom de projection ! Projection de paramètres susceptibles d'être vide de sens."
#: ../lib/proj/convert.c:442
#, c-format
@@ -7915,21 +7525,13 @@
#: ../lib/proj/convert.c:458
#, c-format
-msgid ""
-"Datum <%s> apparently recognised by GRASS but no parameters found. You may "
-"want to look into this."
-msgstr ""
-"La date <% s> est apparemment reconnue par GRASS mais aucun paramètre "
-"trouvé. Vous devez examiner."
+msgid "Datum <%s> apparently recognised by GRASS but no parameters found. You may want to look into this."
+msgstr "La date <% s> est apparemment reconnue par GRASS mais aucun paramètre trouvé. Vous devez examiner."
#: ../lib/proj/convert.c:462
#, c-format
-msgid ""
-"Invalid transformation number %d; valid range is 1 to %d. Leaving datum "
-"transform parameters unspecified."
-msgstr ""
-"Numéro de transformation %d invalide ; la plage valide est de 1 à %d. "
-"Paramètres datum de la transformation laissés non spécifiés."
+msgid "Invalid transformation number %d; valid range is 1 to %d. Leaving datum transform parameters unspecified."
+msgstr "Numéro de transformation %d invalide ; la plage valide est de 1 à %d. Paramètres datum de la transformation laissés non spécifiés."
#: ../lib/proj/get_proj.c:148
#, c-format
@@ -7992,13 +7594,11 @@
#: ../lib/proj/ellipse.c:103
msgid "No secondary ellipsoid descriptor (rf, es or b) in file"
-msgstr ""
-"Pas de descripteur secondaire (rf, es or b) d'ellipsoïde dans le fichier"
+msgstr "Pas de descripteur secondaire (rf, es or b) d'ellipsoïde dans le fichier"
#: ../lib/proj/ellipse.c:107
msgid "Invalid ellipsoid descriptors (a, rf, es or b) in file"
-msgstr ""
-"Descripteurs de l'ellipsoïde (a, rf, es ou b) invalides dans le fichier"
+msgstr "Descripteurs de l'ellipsoïde (a, rf, es ou b) invalides dans le fichier"
#: ../lib/proj/ellipse.c:120
msgid "No ellipsoid info given in file"
@@ -8012,9 +7612,7 @@
#: ../lib/raster/init.c:61
#, fuzzy
msgid "Raster library not initialized. Programmer forgot to call Rast_init()."
-msgstr ""
-"\aERREUR : Le système n'est pas initialisé. Le développeur a oublié "
-"d'appeler G_gisinit()\n"
+msgstr "\aERREUR : Le système n'est pas initialisé. Le développeur a oublié d'appeler G_gisinit()\n"
#: ../lib/raster/histogram.c:55
#, c-format
@@ -8039,30 +7637,22 @@
#: ../lib/raster/put_row.c:121
#, fuzzy, c-format
msgid "Error writing uncompressed FP data for row %d of <%s>: %s"
-msgstr ""
-"erreur en lisant la couche compressée [%s] dans le jeu de données [%s], "
-"ligne %d"
+msgstr "erreur en lisant la couche compressée [%s] dans le jeu de données [%s], ligne %d"
#: ../lib/raster/put_row.c:131
#, fuzzy, c-format
msgid "Error writing compressed FP data for row %d of <%s>: %s"
-msgstr ""
-"ligne %d"
#: ../lib/raster/put_row.c:390 ../lib/raster/put_row.c:396
#, fuzzy, c-format
msgid "Error writing compressed data for row %d of <%s>"
-msgstr ""
-"ligne %d"
#: ../lib/raster/put_row.c:406
#, fuzzy, c-format
msgid "Error writing uncompressed data for row %d of <%s>"
-msgstr ""
-"ligne %d"
#: ../lib/raster/put_row.c:465
#, fuzzy, c-format
@@ -8121,16 +7711,12 @@
#: ../lib/raster/quant_io.c:135
#, fuzzy, c-format
msgid "Quantization file for raster map <%s> is missing"
-msgstr ""
#: ../lib/raster/quant_io.c:145
#, fuzzy, c-format
msgid "Quantization file for raster map <%s> is empty"
-msgstr ""
#: ../lib/raster/reclass.c:168
#, fuzzy, c-format
@@ -8140,9 +7726,7 @@
#: ../lib/raster/reclass.c:171
#, fuzzy, c-format
msgid "Illegal reclass format in header file for <%s@%s>"
-msgstr ""
-"Format de reclassification illégal dans l'en-tête de fichier pour [%s dans "
-"%s]"
+msgstr "Format de reclassification illégal dans l'en-tête de fichier pour [%s dans %s]"
#: ../lib/raster/reclass.c:273
msgid "Illegal reclass request"
@@ -8163,21 +7747,15 @@
msgstr "Impossible de créer le fichier de dépendances dans [%s dans %s]"
#: ../lib/raster/window.c:31
-msgid ""
-"Internal error: Rast_get_window() called with split window. Use "
-"Rast_get_input_window() or Rast_get_output_window() instead."
+msgid "Internal error: Rast_get_window() called with split window. Use Rast_get_input_window() or Rast_get_output_window() instead."
msgstr ""
#: ../lib/raster/window.c:90
-msgid ""
-"Internal error: Rast_window_rows() called with split window. Use "
-"Rast_input_window_rows() or Rast_output_window_rows() instead."
+msgid "Internal error: Rast_window_rows() called with split window. Use Rast_input_window_rows() or Rast_output_window_rows() instead."
msgstr ""
#: ../lib/raster/window.c:125
-msgid ""
-"Internal error: Rast_window_cols() called with split window. Use "
-"Rast_input_window_cols() or Rast_output_window_cols() instead."
+msgid "Internal error: Rast_window_cols() called with split window. Use Rast_input_window_cols() or Rast_output_window_cols() instead."
msgstr ""
#: ../lib/raster/raster_metadata.c:109
@@ -8212,8 +7790,7 @@
#: ../lib/raster/close.c:476
msgid "unable to write f_format file for CELL maps"
-msgstr ""
-"pas en mesure d'écrire des fichiers f_format pour des couches de cellules"
+msgstr "pas en mesure d'écrire des fichiers f_format pour des couches de cellules"
#: ../lib/raster/quant_rw.c:88
#, fuzzy, c-format
@@ -8228,8 +7805,7 @@
#: ../lib/raster/quant_rw.c:157
#, fuzzy, c-format
msgid "Unable to write quant rules: raster map <%s> is integer"
-msgstr ""
-"Impossible d'écrire les règles de quantité : la couche %s est un entier"
+msgstr "Impossible d'écrire les règles de quantité : la couche %s est un entier"
#: ../lib/raster/quant_rw.c:166
#, fuzzy, c-format
@@ -8279,12 +7855,8 @@
#: ../lib/raster/open.c:190
#, c-format
-msgid ""
-"Unable to open raster map <%s@%s> since it is a reclass of raster map <%s@"
-"%s> which does not exist"
-msgstr ""
-"Impossible d'ouvrir la carte raster <%s@%s> car il s'agit d'une "
-"reclassification de la carte raster <%s@%s> qui n'existe pas"
+msgid "Unable to open raster map <%s@%s> since it is a reclass of raster map <%s@%s> which does not exist"
+msgstr "Impossible d'ouvrir la carte raster <%s@%s> car il s'agit d'une reclassification de la carte raster <%s@%s> qui n'existe pas"
#: ../lib/raster/open.c:195
#, fuzzy, c-format
@@ -8299,25 +7871,19 @@
#: ../lib/raster/open.c:214
#, c-format
msgid "Raster map <%s@%s>: format field in header file invalid"
-msgstr ""
-"Carte raster <%s@%s>: format de champ invalide dans le fichier d'en-tête"
+msgstr "Carte raster <%s@%s>: format de champ invalide dans le fichier d'en-tête"
#: ../lib/raster/open.c:219
#, fuzzy, c-format
-msgid ""
-"Raster map <%s> is in different projection than current region. Found <%s>, "
-"should be <%s>."
+msgid "Raster map <%s> is in different projection than current region. Found <%s>, should be <%s>."
msgstr ""
-"[%s] dans le jeu de données (mapset) [%s] - est dans une projection "
-"différente par rapport à la région courante :\n"
+"[%s] dans le jeu de données (mapset) [%s] - est dans une projection différente par rapport à la région courante :\n"
" la couche [%s] dans: <%s>, devrait être <%s> "
#: ../lib/raster/open.c:226
#, fuzzy, c-format
msgid "Raster map <%s> is in different zone (%d) than current region (%d)"
-msgstr ""
-"[%s] dans le jeu de données (mapset) [%s] - est dans une zone différente "
-"[%d] de celle de la région courante [%d]"
+msgstr "[%s] dans le jeu de données (mapset) [%s] - est dans une zone différente [%d] de celle de la région courante [%d]"
#: ../lib/raster/open.c:231
#, fuzzy, c-format
@@ -8326,16 +7892,13 @@
#: ../lib/raster/open.c:256
#, c-format
-msgid ""
-"Raster map <%s@%s> is a GDAL link but GRASS is compiled without GDAL support"
+msgid "Raster map <%s@%s> is a GDAL link but GRASS is compiled without GDAL support"
msgstr ""
#: ../lib/raster/open.c:264
#, fuzzy, c-format
msgid "Unable to open %s file for raster map <%s@%s>"
-msgstr ""
#: ../lib/raster/open.c:301
#, fuzzy, c-format
@@ -8397,8 +7960,7 @@
msgstr "La carte raster <%s> n'est pas xdr: byte_order: %s"
#: ../lib/raster/open.c:929
-msgid ""
-"Rast_set_quant_rules() can be called only for raster maps opened for reading"
+msgid "Rast_set_quant_rules() can be called only for raster maps opened for reading"
msgstr ""
#: ../lib/raster/cats.c:109
@@ -8414,16 +7976,12 @@
#: ../lib/raster/cats.c:145
#, fuzzy, c-format
msgid "Category support for vector map <%s@%s> missing"
-msgstr ""
-"support de la catégorie pour le fichier vecteur [%s] dans le jeu de données "
-"(mapset) [%s] %s"
+msgstr "support de la catégorie pour le fichier vecteur [%s] dans le jeu de données (mapset) [%s] %s"
#: ../lib/raster/cats.c:149
#, fuzzy, c-format
msgid "Category support for vector map <%s@%s> invalid"
-msgstr ""
-"(mapset) [%s] %s"
#: ../lib/raster/cats.c:968
#, fuzzy, c-format
@@ -8443,18 +8001,14 @@
#: ../lib/raster/get_row.c:36 ../lib/raster/get_row.c:845
#, c-format
msgid "Reading raster map <%s@%s> request for row %d is outside region"
-msgstr ""
-"La lecture de la carte raster <%s@%s> demande la ligne %d en dehors de la "
-"région"
+msgstr "La lecture de la carte raster <%s@%s> demande la ligne %d en dehors de la région"
#: ../lib/raster/get_row.c:95 ../lib/raster/get_row.c:101
#: ../lib/raster/get_row.c:135 ../lib/raster/get_row.c:142
#: ../lib/raster/get_row.c:177 ../lib/raster/get_row.c:181
#, fuzzy, c-format
msgid "Error reading raster data for row %d of <%s>"
-msgstr ""
-"ligne %d"
#: ../lib/raster/get_row.c:217
#, fuzzy, c-format
@@ -8472,12 +8026,8 @@
#: ../lib/raster/set_window.c:131
#, fuzzy
-msgid ""
-"Rast_set_read_window(): projection/zone differs from that of currently open "
-"raster maps"
-msgstr ""
-"G_set_window() : projection/zone diffèrent de ceux présents dans le fichier "
-"matriciel actuellement ouvert"
+msgid "Rast_set_read_window(): projection/zone differs from that of currently open raster maps"
+msgstr "G_set_window() : projection/zone diffèrent de ceux présents dans le fichier matriciel actuellement ouvert"
#: ../lib/raster/set_window.c:158
#, c-format
@@ -8510,17 +8060,12 @@
#: ../lib/raster/put_title.c:67
#, c-format
msgid "can't write category information for [%s] in [%s]"
-msgstr ""
-"impossible d'écrire les informations de la catégorie pour [%s] dans [%s]"
+msgstr "impossible d'écrire les informations de la catégorie pour [%s] dans [%s]"
#: ../lib/raster/get_cellhd.c:66
#, fuzzy, c-format
-msgid ""
-"Unable to read header file for raster map <%s@%s>. It is a reclass of raster "
-"map <%s@%s> %s"
-msgstr ""
-"impossible d'ouvrir [%s] dans [%s] puisqu'il s'agit d'une reclassification "
-"de [%s] dans [%s] qui n'existe pas"
+msgid "Unable to read header file for raster map <%s@%s>. It is a reclass of raster map <%s@%s> %s"
+msgstr "impossible d'ouvrir [%s] dans [%s] puisqu'il s'agit d'une reclassification de [%s] dans [%s] qui n'existe pas"
#: ../lib/raster/get_cellhd.c:70
msgid "which is missing."
@@ -8558,8 +8103,7 @@
#: ../lib/raster/color_read.c:112
#, fuzzy, c-format
msgid "Color support for <%s@%s> %s"
-msgstr ""
-"support de la couleur pour [%s] dans le jeu de données (mapset) [%s] %s"
+msgstr "support de la couleur pour [%s] dans le jeu de données (mapset) [%s] %s"
#: ../lib/raster/history.c:115 ../lib/raster/history.c:123
#, fuzzy, c-format
@@ -8640,9 +8184,7 @@
#: ../lib/raster/gdal.c:498
#, c-format
-msgid ""
-"Driver <%s> does not support direct writing. Using MEM driver for "
-"intermediate dataset."
+msgid "Driver <%s> does not support direct writing. Using MEM driver for intermediate dataset."
msgstr ""
#: ../lib/raster/gdal.c:504
@@ -8710,9 +8252,7 @@
#: ../lib/display/r_raster.c:147
#, c-format
-msgid ""
-"Neither %s (managed by d.mon command) nor %s (used for direct rendering) "
-"defined"
+msgid "Neither %s (managed by d.mon command) nor %s (used for direct rendering) defined"
msgstr ""
#: ../lib/display/r_raster.c:165
@@ -8798,9 +8338,7 @@
#: ../lib/init/lock.c:42
msgid "Concurrent mapset locking is not supported on Windows"
-msgstr ""
-"Le verrouillage concurrent de jeux de cartes n'est pas pris en charge dans "
-"Windows"
+msgstr "Le verrouillage concurrent de jeux de cartes n'est pas pris en charge dans Windows"
#: ../lib/init/lock.c:60
#, fuzzy, c-format
@@ -8915,8 +8453,7 @@
#: ../lib/init/grass.py:266
-msgid ""
-"Unable to create temporary directory <grass7-%(user)s-%(lock)s>! Exiting."
+msgid "Unable to create temporary directory <grass7-%(user)s-%(lock)s>! Exiting."
msgstr "Allocation mémoire impossible\n"
#: ../lib/init/grass.py:301
@@ -8959,9 +8496,7 @@
#: ../lib/init/grass.py:600
#, python-format
-msgid ""
-"Mapset <%s> doesn't exist in GRASS location <%s>. A new mapset can be "
-"created by '-c' switch."
+msgid "Mapset <%s> doesn't exist in GRASS location <%s>. A new mapset can be created by '-c' switch."
msgstr ""
#: ../lib/init/grass.py:619
@@ -8981,15 +8516,12 @@
#: ../lib/init/grass.py:678
#, python-format
-msgid ""
-"Invalid user interface specified - <%s>. Use the --help option to see valid "
-"interface names."
+msgid "Invalid user interface specified - <%s>. Use the --help option to see valid interface names."
msgstr ""
#: ../lib/init/grass.py:691
msgid ""
-"Error in GUI startup. If necessary, please report this error to the GRASS "
-"developers.\n"
+"Error in GUI startup. If necessary, please report this error to the GRASS developers.\n"
"Switching to text mode now.\n"
"\n"
"Hit RETURN to continue..."
@@ -9029,8 +8561,7 @@
#: ../lib/init/grass.py:809
#, python-format
-msgid ""
-"A language override has been requested. Trying to switch GRASS into '%s'..."
+msgid "A language override has been requested. Trying to switch GRASS into '%s'..."
msgstr ""
#: ../lib/init/grass.py:868
@@ -9040,9 +8571,7 @@
#: ../lib/init/grass.py:876
#, python-format
-msgid ""
-"%(user)s is currently running GRASS in selected mapset (file %(file)s "
-"found). Concurrent use not allowed."
+msgid "%(user)s is currently running GRASS in selected mapset (file %(file)s found). Concurrent use not allowed."
msgstr ""
#: ../lib/init/grass.py:880
@@ -9070,8 +8599,7 @@
#: ../lib/init/grass.py:963
#, python-format
msgid ""
-"Job file '%s' has been defined in the 'GRASS_BATCH_JOB' variable but not "
-"found. Exiting.\n"
+"Job file '%s' has been defined in the 'GRASS_BATCH_JOB' variable but not found. Exiting.\n"
"\n"
"Use 'unset GRASS_BATCH_JOB' to disable batch job processing."
msgstr ""
@@ -9185,8 +8713,7 @@
"Unable to start GRASS. You can:\n"
" - Launch GRASS with '-gui' switch (`grass70 -gui`)\n"
" - Create manually GISRC file (%s)\n"
-" - Launch GRASS with path to the location/mapset as an argument (`grass70 /"
-"path/to/location/mapset`)"
+" - Launch GRASS with path to the location/mapset as an argument (`grass70 /path/to/location/mapset`)"
msgstr ""
#: ../lib/init/grass.py:1409
@@ -9215,8 +8742,7 @@
#: ../lib/imagery/list_subgp.c:85
#, c-format
msgid "subgroup <%s> of group <%s> references the following raster maps\n"
-msgstr ""
-"Le sous-groupe <%s> du groupe <%s>référence les cartes raster suivantes\n"
+msgstr "Le sous-groupe <%s> du groupe <%s>référence les cartes raster suivantes\n"
#: ../lib/imagery/iclass_statistics.c:218
msgid "prepare_signature: outline has odd number of points."
@@ -9287,23 +8813,17 @@
#: ../lib/imagery/points.c:124
#, c-format
msgid "Unable to open control point file for group [%s in %s]"
-msgstr ""
-"Impossible d'ouvrir le fichier de points de contrôle pour le groupe [%s dans "
-"%s]"
+msgstr "Impossible d'ouvrir le fichier de points de contrôle pour le groupe [%s dans %s]"
#: ../lib/imagery/points.c:132
#, c-format
msgid "Bad format in control point file for group [%s in %s]"
-msgstr ""
-"Mauvais format dans le fichier de points de contrôle pour le groupe [%s dans "
-"%s]"
+msgstr "Mauvais format dans le fichier de points de contrôle pour le groupe [%s dans %s]"
#: ../lib/imagery/points.c:159
#, c-format
msgid "Unable to create control point file for group [%s in %s]"
-msgstr ""
-"Impossible de créer le fichier de points de contrôle pour le groupe [%s dans "
-"%s]"
+msgstr "Impossible de créer le fichier de points de contrôle pour le groupe [%s dans %s]"
#: ../lib/imagery/fopen.c:23
#, c-format
@@ -9323,37 +8843,27 @@
#: ../lib/imagery/fopen.c:79
#, c-format
msgid "Unable to create file [%s] for subgroup [%s] of group [%s in %s]"
-msgstr ""
-"Impossible de créer le fichier [%s] du sous-groupe [%s] du groupe [%s de %s]"
+msgstr "Impossible de créer le fichier [%s] du sous-groupe [%s] du groupe [%s de %s]"
#: ../lib/imagery/fopen.c:101 ../lib/imagery/fopen.c:127
#, c-format
msgid "Unable to open file [%s] for subgroup [%s] of group [%s in %s]"
-msgstr ""
-"Impossible d'ouvrir le fichier [%s] du sous-groupe [%s] du groupe [%s de %s]"
+msgstr "Impossible d'ouvrir le fichier [%s] du sous-groupe [%s] du groupe [%s de %s]"
#: ../lib/imagery/fopen.c:116
#, c-format
msgid "Unable to find file [%s] for subgroup [%s] of group [%s in %s]"
-msgstr ""
-"Impossible de trouver le fichier [%s] pour le sous-groupe [%s] du groupe [%s "
-"de %s]"
+msgstr "Impossible de trouver le fichier [%s] pour le sous-groupe [%s] du groupe [%s de %s]"
#: ../lib/imagery/sigsetfile.c:41
#, c-format
-msgid ""
-"Unable to create signature file <%s> for subgroup <%s> of group <%s> - <%s> "
-"is not current mapset"
-msgstr ""
-"Impossible de créer le fichier de signatures <%s> pour le sous-groupe <%s> "
-"du groupe <%s> - <%s> n'est pas le jeux de cartes courant"
+msgid "Unable to create signature file <%s> for subgroup <%s> of group <%s> - <%s> is not current mapset"
+msgstr "Impossible de créer le fichier de signatures <%s> pour le sous-groupe <%s> du groupe <%s> - <%s> n'est pas le jeux de cartes courant"
#: ../lib/imagery/sigsetfile.c:57
#, c-format
msgid "Unable to create signature file <%s> for subgroup <%s> of group <%s>"
-msgstr ""
-"du groupe <%s>"
+msgstr "Impossible de créer le fichier de signatures <%s> pour le sous-groupe <%s> du groupe <%s>"
#: ../lib/imagery/iscatt_core.c:81
#, fuzzy, c-format
@@ -9368,9 +8878,7 @@
#: ../lib/imagery/iscatt_core.c:255
#, fuzzy, c-format
msgid "Unable to open category raster condtions file <%s>."
-msgstr ""
-"impossible d'ouvrir le fichier de définition de base de données pour le "
-"vecteur '%s'"
+msgstr "impossible d'ouvrir le fichier de définition de base de données pour le vecteur '%s'"
#: ../lib/imagery/iscatt_core.c:263
#, fuzzy, c-format
@@ -9402,9 +8910,7 @@
msgstr ""
#: ../lib/imagery/iscatt_core.c:579
-msgid ""
-"Data inconsistent. Value computed for scatter plot is out of initialized "
-"range."
+msgid "Data inconsistent. Value computed for scatter plot is out of initialized range."
msgstr ""
#: ../lib/imagery/iscatt_core.c:745
@@ -9430,9 +8936,7 @@
#: ../lib/imagery/iscatt_core.c:803
#, fuzzy, c-format
msgid "Unable to open category raster condtition file <%s>"
-msgstr ""
-"vecteur '%s'"
#: ../lib/imagery/iscatt_core.c:817
msgid "Corrupted category raster conditions file (fseek failed)"
@@ -9500,12 +9004,8 @@
#~ msgid "Illegal TimeStamp string"
#~ msgstr "Chaîne d'horodatage illégale"
-#~ msgid ""
-#~ "Dev note: Adapted sites library used for vector points. (module should be "
-#~ "updated to GRASS 6 vector library)"
-#~ msgstr ""
-#~ "Note du dev : librairie sites adaptée utilisée pour le vecteur de points. "
-#~ "(le module devrait être mis à jour vers la librairie vecteur GRASS 6)"
+#~ msgid "Dev note: Adapted sites library used for vector points. (module should be updated to GRASS 6 vector library)"
+#~ msgstr "Note du dev : librairie sites adaptée utilisée pour le vecteur de points. (le module devrait être mis à jour vers la librairie vecteur GRASS 6)"
#~ msgid "Cannot fetch row"
#~ msgstr "Impossible de récupérer la ligne"
@@ -9531,3 +9031,43 @@
#, fuzzy
#~ msgid "Removing empty 3D raster maps"
#~ msgstr "Nom de la couche matricielle d'entrée"
+#, fuzzy
+#~ msgid "Error writing uncompressed FP data for row %d of <%s>"
+#~ msgstr "erreur en lisant la couche compressée [%s] dans le jeu de données [%s], ligne %d"
+#, fuzzy
+#~ msgid "Error writing compressed FP data for row %d of <%s>"
+#, fuzzy
+#~ msgid "Both %s and %s are defined. %s will be ignored."
+#~ msgstr "les paramètres 'where' et 'cats' ont été fournis, cat sera ignoré"
+#, fuzzy
+#~ msgid "Turntable field < 1"
+#~ msgstr "Arc < 1"
+#, fuzzy
+#~ msgid "Turntable column <%s> not found in table <%s>"
+#~ msgstr "Colonne <%s> non trouvée dans la table <%s>"
+#, fuzzy
+#~ msgid "Cannot add network arc for virtual node connection."
+#~ msgstr "Impossible d'ajouter un arc de réseau"
+#, fuzzy
+#~ msgid "Database record for turn with cat = %d in not found. (The turn was skipped."
+#~ msgstr "L'enregistrement de la base de données pour le noeud %d (cat = %d) n'a pas été trouvé (coût fixé à 0)"
+#, fuzzy
+#~ msgid "Cannot add network arc representing turn."
+#, fuzzy
+#~ msgid "Database record for line %d (cat = %d, forward/both direction(s)) not found (cost was set to 0)"
+#~ msgstr "L'enregistrement de la base de données de la ligne %d (cat = %d, avant/toutes directions) introuvable (avant/toutes directions de la ligne sautée)"
+#, fuzzy
+#~ msgid "Database record for line %d (cat = %d, backword direction) not found(cost was set to 0)"
+#~ msgstr "L'enregistrement de la base de données de la ligne %d (cat = %d, direction arrière) introuvable (direction de la ligne sautée)"
Modified: grass/branches/releasebranch_7_0/locale/po/grasswxpy_fr.po
--- grass/branches/releasebranch_7_0/locale/po/grasswxpy_fr.po 2015-07-27 12:27:02 UTC (rev 65783)
+++ grass/branches/releasebranch_7_0/locale/po/grasswxpy_fr.po 2015-07-28 14:56:24 UTC (rev 65784)
@@ -10,7 +10,7 @@
"Project-Id-Version: grasswxpy_fr\n"
"Report-Msgid-Bugs-To: \n"
"POT-Creation-Date: 2015-07-20 21:44+0200\n"
-"PO-Revision-Date: 2015-04-19 21:51+0100\n"
+"PO-Revision-Date: 2015-06-07 13:56+0100\n"
"Last-Translator: Sylvain Maillard <sylvain.maillard at gmail.com>\n"
"Language-Team: français <grass-translations at lists.osgeo.org>\n"
"Language: fr\n"
@@ -36,21 +36,12 @@
msgstr "La base de donnée GRASS contient les secteurs."
#: ../gui/wxpython/gis_set.py:133
-msgid ""
-"All data in one Location is in the same coordinate reference system "
-"(projection). One Location can be one project. Location contains Mapsets."
-msgstr ""
-"Toutes les données dans le même Secteur partagent le même système de "
-"coordonnées (projection). Un Secteur peut être un projet. Le Secteur "
-"contient des Jeux de données."
+msgid "All data in one Location is in the same coordinate reference system (projection). One Location can be one project. Location contains Mapsets."
+msgstr "Toutes les données dans le même Secteur partagent le même système de coordonnées (projection). Un Secteur peut être un projet. Le Secteur contient des Jeux de données."
#: ../gui/wxpython/gis_set.py:141
-msgid ""
-"Mapset contains GIS data related to one project, task within one project, "
-"subregion or user."
-msgstr ""
-"Les Jeux de données contiennent les données SIG relatives au projet, tâche "
-"dans un projet, sous-région ou utilisateur."
+msgid "Mapset contains GIS data related to one project, task within one project, subregion or user."
+msgstr "Les Jeux de données contiennent les données SIG relatives au projet, tâche dans un projet, sous-région ou utilisateur."
#: ../gui/wxpython/gis_set.py:156
msgid "Start &GRASS session"
@@ -73,12 +64,8 @@
msgstr "N&ouveau"
#: ../gui/wxpython/gis_set.py:169
-msgid ""
-"Create a new location using location wizard. After location is created "
-"successfully, GRASS session is started."
-msgstr ""
-"Créer un nouveau secteur à l'aide de l'assistant. Une fois qu'un secteur est "
-"créé, la session GRASS sera lancée."
+msgid "Create a new location using location wizard. After location is created successfully, GRASS session is started."
+msgstr "Créer un nouveau secteur à l'aide de l'assistant. Une fois qu'un secteur est créé, la session GRASS sera lancée."
#: ../gui/wxpython/gis_set.py:173
msgid "Ren&ame"
@@ -143,9 +130,7 @@
#: ../gui/wxpython/gis_set.py:252 ../gui/wxpython/gis_set.py:728
msgid "Unable to set GRASS database. Check your locale settings."
-msgstr ""
-"Impossible de définir la base de données GRASS. Vérifiez vos paramètres de "
-"langue."
+msgstr "Impossible de définir la base de données GRASS. Vérifiez vos paramètres de langue."
#: ../gui/wxpython/gis_set.py:270
#, python-format
@@ -192,9 +177,7 @@
#: ../gui/wxpython/gis_set.py:539 ../gui/wxpython/lmgr/frame.py:423
msgid "Do you want to set the default region extents and resolution now?"
-msgstr ""
-"Voulez-vous définir les limites et la résolution la région par défaut "
-"maintenant ?"
+msgstr "Voulez-vous définir les limites et la résolution la région par défaut maintenant ?"
#: ../gui/wxpython/gis_set.py:579
#, python-format
@@ -207,12 +190,8 @@
#: ../gui/wxpython/gis_set.py:582
#, python-format
-msgid ""
-"Data file <%(name)s> imported successfully. The location's default region "
-"was set from this imported map."
-msgstr ""
-"Fichier de données <%(name)s> correctement importé. La région par défaut a "
-"été définie à partir de la carte importée."
+msgid "Data file <%(name)s> imported successfully. The location's default region was set from this imported map."
+msgstr "Fichier de données <%(name)s> correctement importé. La région par défaut a été définie à partir de la carte importée."
#: ../gui/wxpython/gis_set.py:595
msgid ""
@@ -220,8 +199,7 @@
"\n"
"This mapset cannot be renamed."
msgstr ""
-"Le jeu de cartes <PERMANENT> est requis pour qu'un secteur GRASS soit "
-"valide.\n"
+"Le jeu de cartes <PERMANENT> est requis pour qu'un secteur GRASS soit valide.\n"
"\n"
"Ce jeu de cartes ne peut être renommé."
@@ -291,24 +269,20 @@
"\n"
"This mapset cannot be deleted."
msgstr ""
-"valide.\n"
"\n"
"Ce jeu de cartes ne peut être supprimé."
#: ../gui/wxpython/gis_set.py:678
#, python-format
msgid ""
-"Do you want to continue with deleting mapset <%(mapset)s> from location <"
-"%(location)s>?\n"
+"Do you want to continue with deleting mapset <%(mapset)s> from location <%(location)s>?\n"
"\n"
"ALL MAPS included in this mapset will be PERMANENTLY DELETED!"
msgstr ""
-"Voulez-vous vraiment supprimer le jeu de cartes <%(mapset)s> du secteur <"
-"%(location)s>?\n"
+"Voulez-vous vraiment supprimer le jeu de cartes <%(mapset)s> du secteur <%(location)s>?\n"
"\n"
-"TOUTES LES CARTES incluses dans ce jeu de cartes seront DÉFINITIVEMENT "
-"SUPPRIMÉES !"
+"TOUTES LES CARTES incluses dans ce jeu de cartes seront DÉFINITIVEMENT SUPPRIMÉES !"
#: ../gui/wxpython/gis_set.py:692
msgid "Unable to delete mapset"
@@ -331,12 +305,8 @@
#: ../gui/wxpython/gis_set.py:739
#, python-format
-msgid ""
-"No GRASS Location found in '%s'. Create a new Location or choose different "
-"GRASS database directory."
-msgstr ""
-"Pas de Secteur GRASS trouvé dans '%s'. Créez un nouveau Secteur ou "
-"choisissez un autre dossier de base de données GRASS."
+msgid "No GRASS Location found in '%s'. Create a new Location or choose different GRASS database directory."
+msgstr "Pas de Secteur GRASS trouvé dans '%s'. Créez un nouveau Secteur ou choisissez un autre dossier de base de données GRASS."
#: ../gui/wxpython/gis_set.py:857
#, python-format
@@ -359,13 +329,11 @@
#: ../gui/wxpython/gis_set.py:903
#, python-format
msgid ""
-"Mapset <%s> is reserved for direct read access to OGR layers. Please "
-"consider to use another name for your mapset.\n"
+"Mapset <%s> is reserved for direct read access to OGR layers. Please consider to use another name for your mapset.\n"
"\n"
"Are you really sure that you want to create this mapset?"
msgstr ""
-"Le jeu de cartes <%s> est réservé pour un accès en lecture directe des "
-"couches OGR. Merci d'utiliser un autre nom pour votre jeu de cartes.\n"
+"Le jeu de cartes <%s> est réservé pour un accès en lecture directe des couches OGR. Merci d'utiliser un autre nom pour votre jeu de cartes.\n"
"\n"
"Êtes-vous sûr de vouloir créer ce jeu de cartes ?"
@@ -386,16 +354,14 @@
"\n"
"Concurrent use not allowed.\n"
"\n"
-"Do you want to try to remove .gislock (note that you need permission for "
-"this operation) and continue?"
+"Do you want to try to remove .gislock (note that you need permission for this operation) and continue?"
msgstr ""
"GRASS s'exécute déjà dans le jeu de cartes <%(mapset)s> sélectionné\n"
"(fichier %(lock)s détecté).\n"
"\n"
"L'accès concurrent n'est pas autorisé.\n"
"\n"
-"Souhaitez-vous essayer de supprimer .gislock (notez qu'il vous faut disposer "
-"de droits pour cette opération) et continuer ?"
+"Souhaitez-vous essayer de supprimer .gislock (notez qu'il vous faut disposer de droits pour cette opération) et continuer ?"
#: ../gui/wxpython/gis_set.py:949 ../gui/wxpython/gis_set.py:961
msgid "Lock file found"
@@ -405,13 +371,11 @@
msgid ""
"ARE YOU REALLY SURE?\n"
"\n"
-"If you really are running another GRASS session doing this could corrupt "
-"your data. Have another look in the processor manager just to be sure..."
+"If you really are running another GRASS session doing this could corrupt your data. Have another look in the processor manager just to be sure..."
msgstr ""
"ÊTES-VOUS VRAIMENT SÛR ?\n"
"\n"
-"Si vous avez une autre session GRASS en cours, vous risquez de corrompre vos "
-"données. Vérifiez dans votre gestionnaire de tâches pour en être sûr ..."
+"Si vous avez une autre session GRASS en cours, vous risquez de corrompre vos données. Vérifiez dans votre gestionnaire de tâches pour en être sûr ..."
#: ../gui/wxpython/gis_set.py:972
#, python-format
@@ -426,28 +390,16 @@
#: ../gui/wxpython/gis_set.py:1020
#, python-format
-msgid ""
-"Name <%(name)s> is not a valid name for location or mapset. Please use only "
-"ASCII characters excluding %(chars)s and space."
-msgstr ""
-"le nom <%(name)s> n'ets pas un nom valide pour un secteur ou un jeu de "
-"cartes. Merci de n'utiliser que des caractères ASCII sans %(chars)s ni "
-"espaces."
+msgid "Name <%(name)s> is not a valid name for location or mapset. Please use only ASCII characters excluding %(chars)s and space."
+msgstr "le nom <%(name)s> n'ets pas un nom valide pour un secteur ou un jeu de cartes. Merci de n'utiliser que des caractères ASCII sans %(chars)s ni espaces."
#: ../gui/wxpython/gis_set.py:1023 ../gui/wxpython/lmgr/layertree.py:789
msgid "Invalid name"
msgstr "Nom invalide"
#: ../gui/wxpython/gis_set.py:1091
-msgid ""
-"GRASS needs a directory (GRASS database) in which to store its data. Create "
-"one now if you have not already done so. A popular choice is \"grassdata\", "
-"located in your home directory. Press Browse button to select the directory."
-msgstr ""
-"GRASS nécéssite un dossier dans lequel enregistrer ses données. Créez en un "
-"si vous ne l'avez pas déjà fait. Un choix populaire est « grassdata », dans "
-"votre dossier personnel. Cliquez sur le bouton Parcourir pour sélectionner "
-"le dossier."
+msgid "GRASS needs a directory (GRASS database) in which to store its data. Create one now if you have not already done so. A popular choice is \"grassdata\", located in your home directory. Press Browse button to select the directory."
+msgstr "GRASS nécéssite un dossier dans lequel enregistrer ses données. Créez en un si vous ne l'avez pas déjà fait. Un choix populaire est « grassdata », dans votre dossier personnel. Cliquez sur le bouton Parcourir pour sélectionner le dossier."
#: ../gui/wxpython/iclass/statistics.py:29
msgid "Loading imagery lib failed"
@@ -474,7 +426,7 @@
#: ../gui/wxpython/iclass/frame.py:306
msgid "IClass Toolbar"
-msgstr ""
+msgstr "Barre d'outils IClass"
#: ../gui/wxpython/iclass/frame.py:318
msgid "IClass Misc Toolbar"
@@ -528,9 +480,7 @@
#: ../gui/wxpython/iclass/frame.py:554
#, python-format
msgid "Vector map <%s> contains points or lines, these features are ignored."
-msgstr ""
-"La carte vecteur <%s> contient des points ou des lignes, ces entités seront "
-"ignorés."
+msgstr "La carte vecteur <%s> contient des points ou des lignes, ces entités seront ignorés."
#: ../gui/wxpython/iclass/frame.py:579
#, python-format
@@ -553,8 +503,7 @@
#: ../gui/wxpython/iclass/frame.py:698
#, python-format
msgid "%d training areas (%d classes) exported to vector map <%s>."
-msgstr ""
-"%d zones d'entrainement (%d classes) exportées vers la carte vecteur <%s>."
+msgstr "%d zones d'entrainement (%d classes) exportées vers la carte vecteur <%s>."
#: ../gui/wxpython/iclass/frame.py:897
msgid "Failed to create temporary vector map."
@@ -578,12 +527,8 @@
msgstr "Pas de groupe d'images sélectionné."
#: ../gui/wxpython/iclass/frame.py:994
-msgid ""
-"Due to recent changes in classes, signatures can be outdated and should be "
-"recalculated. Do you still want to continue?"
-msgstr ""
-"Suite à un changement récent dans les classes, les signatures peuvent être "
-"obsolètes et doivent être recalculées. Voulez-vous continuer ?"
+msgid "Due to recent changes in classes, signatures can be outdated and should be recalculated. Do you still want to continue?"
+msgstr "Suite à un changement récent dans les classes, les signatures peuvent être obsolètes et doivent être recalculées. Voulez-vous continuer ?"
#: ../gui/wxpython/iclass/frame.py:997
msgid "Outdated signatures"
@@ -608,12 +553,8 @@
#: ../gui/wxpython/iclass/frame.py:1070
#, python-format
-msgid ""
-"Group <%(group)s> does not have enough files (it has %(files)d files). "
-"Operation canceled."
-msgstr ""
-"Le groupe <%(group)s> ne contien pas suffisament de fichiers (il y a "
-"%(files)d fichiers). Opération annulée."
+msgid "Group <%(group)s> does not have enough files (it has %(files)d files). Operation canceled."
+msgstr "Le groupe <%(group)s> ne contien pas suffisament de fichiers (il y a %(files)d fichiers). Opération annulée."
#: ../gui/wxpython/iclass/frame.py:1079
msgid "No areas given. Operation canceled."
@@ -621,9 +562,7 @@
#: ../gui/wxpython/iclass/frame.py:1094
msgid "Vector features are outside raster layers. Operation canceled."
-msgstr ""
-"Les entités vectorielles sont en dehors de la couche raster. Opération "
-"annulée."
+msgstr "Les entités vectorielles sont en dehors de la couche raster. Opération annulée."
#: ../gui/wxpython/iclass/plots.py:66
msgid "Histograms"
@@ -648,18 +587,12 @@
msgstr ""
"La fonction de nuage de points est désactivée.\n"
"\n"
-"Raison : impossible d'importer les paquets nécessaires pour le nuage de "
-"pooints.\n"
+"Raison : impossible d'importer les paquets nécessaires pour le nuage de pooints.\n"
"%s"
#: ../gui/wxpython/iclass/digit.py:57
-msgid ""
-"You are trying to create a training area outside the computational region. "
-"Please, use g.region to set the appropriate region first."
-msgstr ""
-"Vous êtes en train de créer une zone d'entrainement en dehors de la région "
-"de calcul. Merci de commencer par utiliser g.region pour définir la région "
-"appropriée."
+msgid "You are trying to create a training area outside the computational region. Please, use g.region to set the appropriate region first."
+msgstr "Vous êtes en train de créer une zone d'entrainement en dehors de la région de calcul. Merci de commencer par utiliser g.region pour définir la région appropriée."
#: ../gui/wxpython/iclass/digit.py:66
msgid ""
@@ -667,8 +600,7 @@
"\n"
"There is no class yet, do you want to create one?"
msgstr ""
-"Pour créer unne zone d'entrainement, vous devez commencer par sélectionner "
-"une classe.\n"
+"Pour créer unne zone d'entrainement, vous devez commencer par sélectionner une classe.\n"
"\n"
"Il n'y a pas encore de classes, voulez-vous en créer une ?"
@@ -854,8 +786,7 @@
#: ../gui/wxpython/iclass/toolbars.py:39
msgid "Run analysis, update histogram and coincidence plots"
-msgstr ""
-"Lancer l'analyse, mettre à jour l'histogramme et les points de concordance"
+msgstr "Lancer l'analyse, mettre à jour l'histogramme et les points de concordance"
#: ../gui/wxpython/iclass/toolbars.py:41
msgid "Save signature file for i.maxlik"
@@ -879,9 +810,8 @@
msgstr "Ajouter une couche RVB"
#: ../gui/wxpython/iclass/toolbars.py:66
-#, fuzzy
msgid "Training"
-msgstr "Attention"
+msgstr "Training"
#: ../gui/wxpython/modules/colorrules.py:523
@@ -893,7 +823,6 @@
msgstr "Définir la trame de carte pour"
#: ../gui/wxpython/iclass/toolbars.py:72
-#, fuzzy
msgid "/ Zoom to map"
msgstr "/ Zoomer sur la carte"
@@ -941,15 +870,11 @@
#: ../gui/wxpython/gmodeler/frame.py:577 ../gui/wxpython/mapdisp/frame.py:587
#: ../gui/wxpython/modules/histogram.py:423
msgid "Choose a file name to save the image (no need to add extension)"
-msgstr ""
-"Choisissez un nom de fichier pour enregistrer l'image (extension non "
-"nécessaire)"
+msgstr "Choisissez un nom de fichier pour enregistrer l'image (extension non nécessaire)"
#: ../gui/wxpython/mapswipe/frame.py:630 ../gui/wxpython/mapdisp/frame.py:823
msgid "No raster or vector map layer selected for querying."
-msgstr ""
-"Pas de carte rater ou couche de carte vecteur sélectionnée pour "
-"interrogation."
+msgstr "Pas de carte rater ou couche de carte vecteur sélectionnée pour interrogation."
#: ../gui/wxpython/mapswipe/dialogs.py:42
#: ../gui/wxpython/mapswipe/toolbars.py:28
@@ -1002,7 +927,7 @@
#: ../gui/wxpython/mapswipe/dialogs.py:236
#, fuzzy
msgid "Mirrored cursor"
-msgstr "Mode grossier :"
+msgstr "Curseur miroir"
#: ../gui/wxpython/mapswipe/dialogs.py:242 ../gui/wxpython/gcp/manager.py:2473
#: ../gui/wxpython/psmap/dialogs.py:1777 ../gui/wxpython/psmap/dialogs.py:1880
@@ -1182,15 +1107,11 @@
#: ../gui/wxpython/gcp/manager.py:399
msgid "You must select a valid location before selecting a mapset"
-msgstr ""
-"Vous devez sélectionner un secteur valide avant de sélectionner un jeu de "
-"cartes"
+msgstr "Vous devez sélectionner un secteur valide avant de sélectionner un jeu de cartes"
#: ../gui/wxpython/gcp/manager.py:412
msgid "You must select a valid location and mapset in order to continue"
-msgstr ""
-"Vous devez sélectionner un secteur et un jeu de cartes valides pour pouvoir "
-"continuer"
+msgstr "Vous devez sélectionner un secteur et un jeu de cartes valides pour pouvoir continuer"
#: ../gui/wxpython/gcp/manager.py:431
msgid "Select image/map group to georectify"
@@ -1214,9 +1135,7 @@
#: ../gui/wxpython/gcp/manager.py:537
msgid "You must select a valid image/map group in order to continue"
-msgstr ""
-"Vous devez sélectionner un groupe d'images ou de cartes valides pour pouvoir "
-"continuer"
+msgstr "Vous devez sélectionner un groupe d'images ou de cartes valides pour pouvoir continuer"
#: ../gui/wxpython/gcp/manager.py:544
msgid "You must enter an map name extension in order to continue"
@@ -1224,8 +1143,7 @@
#: ../gui/wxpython/gcp/manager.py:610
msgid "Select maps to display for ground control point (GCP) creation"
-msgstr ""
-"Sélectionner les cartes à afficher pour la création des points de contrôle"
+msgstr "Sélectionner les cartes à afficher pour la création des points de contrôle"
#: ../gui/wxpython/gcp/manager.py:618 ../gui/wxpython/gcp/manager.py:2602
msgid "Select source map to display:"
@@ -1310,14 +1228,12 @@
#: ../gui/wxpython/gcp/manager.py:1382
#, python-format
msgid ""
-"Insufficient points defined and active (checked) for selected rectification "
-"method (order: %d).\n"
+"Insufficient points defined and active (checked) for selected rectification method (order: %d).\n"
"3+ points needed for 1st order,\n"
"6+ points for 2nd order, and\n"
"10+ points for 3rd order."
msgstr ""
-"Pas assez de points définis et activés (cochés) pour la méthode de "
-"rectification choisie (ordre : %d).\n"
+"Pas assez de points définis et activés (cochés) pour la méthode de rectification choisie (ordre : %d).\n"
"3 points ou + nécessaires pour le 1er ordre,\n"
"6 points ou + nécessaires pour le 2ème ordre, et\n"
"10 points ou + nécessaires pour le 3ème ordre."
@@ -1454,11 +1370,8 @@
#: ../gui/wxpython/wxplot/dialogs.py:1136
#: ../gui/wxpython/gui_core/preferences.py:93
#: ../gui/wxpython/iscatt/dialogs.py:359
-msgid ""
-"Apply and save changes to user settings file (default for next sessions)"
-msgstr ""
-"Appliquer et enregistrer les modifications des paramètres utilisateur "
-"(valeurs par défaut pour la prochaine session)"
+msgid "Apply and save changes to user settings file (default for next sessions)"
+msgstr "Appliquer et enregistrer les modifications des paramètres utilisateur (valeurs par défaut pour la prochaine session)"
#: ../gui/wxpython/gcp/manager.py:2411 ../gui/wxpython/vnet/dialogs.py:1193
#: ../gui/wxpython/gui_core/dialogs.py:1689
@@ -1561,9 +1474,7 @@
#: ../gui/wxpython/gcp/manager.py:2850
#, python-format
msgid "GCP Manager settings saved to file '%s'."
-msgstr ""
-"Paramètres du gestionnaire de points de contrôle enregistrés dans le fichier "
-"'%s'."
+msgstr "Paramètres du gestionnaire de points de contrôle enregistrés dans le fichier '%s'."
#: ../gui/wxpython/vdigit/g.gui.vdigit.py:63
msgid "GRASS GIS Vector Digitizer"
@@ -1576,12 +1487,8 @@
#: ../gui/wxpython/vdigit/g.gui.vdigit.py:84
#, python-format
-msgid ""
-"Vector map <%s> not found in current mapset. New vector map can be created "
-"by providing '-c' flag."
-msgstr ""
-"Carte vectorielle <%s> non trouvée dans le jeux de données courant. Un "
-"nouvelle carte vectorielle peut être crée en fournissant le paramètre '-c'."
+msgid "Vector map <%s> not found in current mapset. New vector map can be created by providing '-c' flag."
+msgstr "Carte vectorielle <%s> non trouvée dans le jeux de données courant. Un nouvelle carte vectorielle peut être crée en fournissant le paramètre '-c'."
#: ../gui/wxpython/vdigit/g.gui.vdigit.py:87
#, python-format
@@ -1595,14 +1502,8 @@
#: ../gui/wxpython/vdigit/wxdisplay.py:948
#, python-format
-msgid ""
-"Topology for vector map <%s> is not available. Topology is required by "
-"digitizer. Do you want to rebuild topology (takes some time) and open the "
-"vector map for editing?"
-msgstr ""
-"La topologie pour la carte vecteur <%s> n'est pas disponible. La topologie "
-"est requise pour la digitalisation. Voulez-vous reconstruire la topologie "
-"(peut prendre du temps) et ouvrir la carte vecteur pour édition ?"
+msgid "Topology for vector map <%s> is not available. Topology is required by digitizer. Do you want to rebuild topology (takes some time) and open the vector map for editing?"
+msgstr "La topologie pour la carte vecteur <%s> n'est pas disponible. La topologie est requise pour la digitalisation. Voulez-vous reconstruire la topologie (peut prendre du temps) et ouvrir la carte vecteur pour édition ?"
#: ../gui/wxpython/vdigit/wxdisplay.py:952
msgid "Topology missing"
@@ -1619,9 +1520,7 @@
#: ../gui/wxpython/vdigit/mapwindow.py:543
msgid "Nothing to do. Choose appropriate tool from digitizer toolbar."
-msgstr ""
-"Pas d'action. Choisissez l'outil approprié depuis la barre d'outil de "
-"numérisation."
+msgstr "Pas d'action. Choisissez l'outil approprié depuis la barre d'outil de numérisation."
#: ../gui/wxpython/vdigit/mapwindow.py:1041
msgid "Z bulk-labeling dialog"
@@ -1638,9 +1537,7 @@
#: ../gui/wxpython/vdigit/preferences.py:60
msgid "Close dialog and save changes to user settings file"
-msgstr ""
-"Fermer la boîte de dialogue et enregistrer les modifications dans le fichier "
-"de paramètres utilisateur"
+msgstr "Fermer la boîte de dialogue et enregistrer les modifications dans le fichier de paramètres utilisateur"
#: ../gui/wxpython/vdigit/preferences.py:62
#: ../gui/wxpython/gmodeler/preferences.py:539
@@ -1709,11 +1606,8 @@
msgstr "Ne sélectionner que les entités contenues dans la boîte de sélection"
#: ../gui/wxpython/vdigit/preferences.py:226
-msgid ""
-"By default are selected all features overlapping selection bounding box "
-msgstr ""
-"Par défaut sont sélectionnées toutes les entités chevauchent la boîte de "
-"sélection"
+msgid "By default are selected all features overlapping selection bounding box "
+msgstr "Par défaut sont sélectionnées toutes les entités chevauchent la boîte de sélection"
#: ../gui/wxpython/vdigit/preferences.py:229
msgid "Check for duplicates"
@@ -1856,12 +1750,8 @@
msgstr "périmètre"
#: ../gui/wxpython/vdigit/preferences.py:505
-msgid ""
-"Note: These settings are stored in the workspace not in the vector digitizer "
-"preferences."
-msgstr ""
-"Note : ces paramètres sont stockés dans l'espace de travail, et non dans les "
-"préférences du module de numérisation."
+msgid "Note: These settings are stored in the workspace not in the vector digitizer preferences."
+msgstr "Note : ces paramètres sont stockés dans l'espace de travail, et non dans les préférences du module de numérisation."
#: ../gui/wxpython/vdigit/preferences.py:534
msgid "Digitize new line segment"
@@ -1941,9 +1831,7 @@
#: ../gui/wxpython/vdigit/preferences.py:620
#, python-format
msgid "Snapping threshold is %(value).1f %(units)s (based on comp. resolution)"
-msgstr ""
-"Le seuil de magnétisme vaut %(value).1f %(units)s (fondé sur la résolution "
-"calculée)"
+msgstr "Le seuil de magnétisme vaut %(value).1f %(units)s (fondé sur la résolution calculée)"
#: ../gui/wxpython/vdigit/preferences.py:676
#, python-format
@@ -1991,16 +1879,12 @@
#: ../gui/wxpython/vdigit/wxdigit.py:94
#, python-format
msgid "Unable to start database driver <%s>. Operation canceled."
-msgstr ""
-"Impossible de démarrer le pilote de base de données <%s>. Opération annulée."
+msgstr "Impossible de démarrer le pilote de base de données <%s>. Opération annulée."
#: ../gui/wxpython/vdigit/wxdigit.py:102
#, python-format
-msgid ""
-"Unable to open database <%(db)s> by driver <%(driver)s>. Operation canceled."
-msgstr ""
-"Impossible d'ouvrir la base de données <%(db)s> avec le pilote <"
-"%(driver)s> . Opération annulée."
+msgid "Unable to open database <%(db)s> by driver <%(driver)s>. Operation canceled."
+msgstr "Impossible d'ouvrir la base de données <%(db)s> avec le pilote <%(driver)s> . Opération annulée."
#: ../gui/wxpython/vdigit/wxdigit.py:110
#, python-format
@@ -2136,9 +2020,7 @@
#: ../gui/wxpython/vdigit/toolbars.py:130
#: ../gui/wxpython/vdigit/toolbars.py:154
msgid "Left: new point; Ctrl+Left: undo last point; Right: close line"
-msgstr ""
-"Gauche : nouveau point ; Ctrl+gauche : annuler le dernier point ; Droite : "
-"fermer la ligne"
+msgstr "Gauche : nouveau point ; Ctrl+gauche : annuler le dernier point ; Droite : fermer la ligne"
#: ../gui/wxpython/vdigit/toolbars.py:129
msgid "Digitize new boundary"
@@ -2164,13 +2046,11 @@
#: ../gui/wxpython/vdigit/toolbars.py:163
#: ../gui/wxpython/vdigit/toolbars.py:172
msgid "Left: Select; Ctrl+Left: Unselect; Right: Confirm"
-msgstr ""
-"Gauche : Sélectionner ; Ctrl+Gauche : Dé-sélectionner : Droite : Confirmer"
+msgstr "Gauche : Sélectionner ; Ctrl+Gauche : Dé-sélectionner : Droite : Confirmer"
#: ../gui/wxpython/vdigit/toolbars.py:141
msgid "Delete selected point(s), line(s), boundary(ies) or centroid(s)"
-msgstr ""
-"Supprimer le(s) point(s), ligne(s), contour(s) ou centroïde(s) sélectionné(s)"
+msgstr "Supprimer le(s) point(s), ligne(s), contour(s) ou centroïde(s) sélectionné(s)"
#: ../gui/wxpython/vdigit/toolbars.py:144
msgid "Delete selected area(s)"
@@ -2195,8 +2075,7 @@
#: ../gui/wxpython/vdigit/toolbars.py:156
msgid "Move selected point(s), line(s), boundary(ies) or centroid(s)"
-msgstr ""
-"Déplacer le(s) point(s), ligne(s), contour(s) ou centroïde(s) sélectionné(s)"
+msgstr "Déplacer le(s) point(s), ligne(s), contour(s) ou centroïde(s) sélectionné(s)"
#: ../gui/wxpython/vdigit/toolbars.py:159
msgid "Move selected vertex"
@@ -2309,15 +2188,11 @@
#: ../gui/wxpython/vdigit/toolbars.py:848
#, python-format
msgid ""
-"digitizer.\n"
-"Do you want to rebuild topology (takes some time) and open the vector map "
-"for editing?"
+"Topology for vector map <%s> is not available. Topology is required by digitizer.\n"
+"Do you want to rebuild topology (takes some time) and open the vector map for editing?"
msgstr ""
-"La topologie n'est pas disponible pour la carte vecteur <%s> . La topologie "
-"est requise pour la numérisation.\n"
-"Voulez-vous reconstruire la topologie (peut prendre du temps) et ouvrir la "
-"carte vecteur pour édition ?"
+"La topologie n'est pas disponible pour la carte vecteur <%s> . La topologie est requise pour la numérisation.\n"
+"Voulez-vous reconstruire la topologie (peut prendre du temps) et ouvrir la carte vecteur pour édition ?"
#: ../gui/wxpython/vdigit/toolbars.py:852
msgid "Digitizer error"
@@ -2330,11 +2205,8 @@
#: ../gui/wxpython/vdigit/toolbars.py:904
#, python-format
-msgid ""
-"Unsupported feature type '%(type)s'. Unable to edit OGR layer <%(layer)s>."
-msgstr ""
-"Type d'entité '%(type)s' non prise en charge. Impossible de modifier la "
-"couche OGR <%(layer)s>."
+msgid "Unsupported feature type '%(type)s'. Unable to edit OGR layer <%(layer)s>."
+msgstr "Type d'entité '%(type)s' non prise en charge. Impossible de modifier la couche OGR <%(layer)s>."
#: ../gui/wxpython/vdigit/toolbars.py:916
msgid "Vector digitizer"
@@ -2352,9 +2224,7 @@
#: ../gui/wxpython/vdigit/toolbars.py:974
#, python-format
msgid "Please wait, closing and rebuilding topology of vector map <%s>..."
-msgstr ""
-"Merci de patienter, fermeture et reconstruction de la topologie de la carte "
-"vecteur <%s>..."
+msgstr "Merci de patienter, fermeture et reconstruction de la topologie de la carte vecteur <%s>..."
#: ../gui/wxpython/vdigit/toolbars.py:988
#, python-format
@@ -2380,12 +2250,8 @@
#: ../gui/wxpython/mapwin/analysis.py:233
#: ../gui/wxpython/mapwin/analysis.py:342
#, python-format
-msgid ""
-"Click and drag with left mouse button to measure.%sDouble click with left "
-"button to clear."
-msgstr ""
-"Cliquer et glisser avec le bouton gauche de la souris pour mesurer. %s "
-"Double-cliquer avec le bouton gauche pour annuler."
+msgid "Click and drag with left mouse button to measure.%sDouble click with left button to clear."
+msgstr "Cliquer et glisser avec le bouton gauche de la souris pour mesurer. %s Double-cliquer avec le bouton gauche pour annuler."
#: ../gui/wxpython/mapwin/analysis.py:239
msgid "Measuring distance"
@@ -2619,8 +2485,7 @@
#: ../gui/wxpython/gmodeler/frame.py:256
msgid "Do you want to store current model settings to model file?"
-msgstr ""
-"Voulez-vous enregistrer les paramètres du modèle courants dans un fichier ?"
+msgstr "Voulez-vous enregistrer les paramètres du modèle courants dans un fichier ?"
#: ../gui/wxpython/gmodeler/frame.py:262
msgid "Quit Graphical Modeler"
@@ -2645,12 +2510,8 @@
msgstr "%d cartes supprimées du jeu de cartes courant"
#: ../gui/wxpython/gmodeler/frame.py:353 ../gui/wxpython/gmodeler/frame.py:479
-msgid ""
-"Current model is not empty. Do you want to store current settings to model "
-"file?"
-msgstr ""
-"Le modèle courant n'est pas vide. Voulez-vous enregistrer les paramètres "
-"courants dans un fichier ?"
+msgid "Current model is not empty. Do you want to store current settings to model file?"
+msgstr "Le modèle courant n'est pas vide. Voulez-vous enregistrer les paramètres courants dans un fichier ?"
#: ../gui/wxpython/gmodeler/frame.py:356 ../gui/wxpython/gmodeler/frame.py:482
msgid "Create new model?"
@@ -2673,8 +2534,7 @@
#: ../gui/wxpython/gmodeler/frame.py:419 ../gui/wxpython/gmodeler/frame.py:456
#, python-format
msgid "Model file <%s> already exists. Do you want to overwrite this file?"
-msgstr ""
-"Le fichier de modèle <%s> existe déjà. Voulez-vous écraser ce fichier ?"
+msgstr "Le fichier de modèle <%s> existe déjà. Voulez-vous écraser ce fichier ?"
#: ../gui/wxpython/gmodeler/frame.py:422 ../gui/wxpython/menustrings.py:1918
msgid "Save model"
@@ -2953,12 +2813,8 @@
msgstr "Enegistrer le fichier"
#: ../gui/wxpython/gmodeler/frame.py:1797
-msgid ""
-"Python script is locally modificated. Refresh will discard all changes. Do "
-"you really want to continue?"
-msgstr ""
-"Le script Python a été modifié manuellement. La mise à jour écrasera toutes "
-"les modifications. Voulez-vous vraiment continuer ?"
+msgid "Python script is locally modificated. Refresh will discard all changes. Do you really want to continue?"
+msgstr "Le script Python a été modifié manuellement. La mise à jour écrasera toutes les modifications. Voulez-vous vraiment continuer ?"
#: ../gui/wxpython/gmodeler/frame.py:1800
msgid "Update"
@@ -3422,27 +3278,18 @@
#: ../gui/wxpython/psmap/instructions.py:818
#: ../gui/wxpython/psmap/instructions.py:1700
#, python-format
-msgid ""
-"Characters on position %s are not supported by ISO-8859-1 (Latin 1) encoding "
-"which is required by module ps.map."
-msgstr ""
-"Les caractères en position %s ne sont pas pris en charge par l'encodage "
-"ISO-8859-1 (Latin 1) requis pour le module ps.map."
+msgid "Characters on position %s are not supported by ISO-8859-1 (Latin 1) encoding which is required by module ps.map."
+msgstr "Les caractères en position %s ne sont pas pris en charge par l'encodage ISO-8859-1 (Latin 1) requis pour le module ps.map."
#: ../gui/wxpython/psmap/instructions.py:822
#: ../gui/wxpython/psmap/instructions.py:1704
-msgid ""
-"Not all characters are supported by ISO-8859-1 (Latin 1) encoding which is "
-"required by module ps.map."
-msgstr ""
-"Tous les caractères ne sont pas supportés par l'encodage ISO-8859-1 (Latin "
-"1) requis pour le module ps.map."
+msgid "Not all characters are supported by ISO-8859-1 (Latin 1) encoding which is required by module ps.map."
+msgstr "Tous les caractères ne sont pas supportés par l'encodage ISO-8859-1 (Latin 1) requis pour le module ps.map."
#: ../gui/wxpython/psmap/instructions.py:938
#, python-format
msgid "Failed to read instruction %(inst)s: file %(file)s not found."
-msgstr ""
-"Échec à la lecture de l'instruction %(inst)s : fichier %(file)s non trouvé."
+msgstr "Échec à la lecture de l'instruction %(inst)s : fichier %(file)s non trouvé."
#: ../gui/wxpython/psmap/frame.py:51
msgid "GRASS GIS Cartographic Composer"
@@ -3458,9 +3305,7 @@
#: ../gui/wxpython/psmap/frame.py:238
msgid "Program ps2pdf is not available. Please install it first to create PDF."
-msgstr ""
-"Le programme ps2pdf n'est pas disponible. Merci de l'installer pour "
-"permettre la création de fichiers PDF."
+msgstr "Le programme ps2pdf n'est pas disponible. Merci de l'installer pour permettre la création de fichiers PDF."
#: ../gui/wxpython/psmap/frame.py:282
msgid "Generating PDF..."
@@ -3495,8 +3340,7 @@
"\n"
" %s"
msgstr ""
-"permettre la création de fichiers PDF.\n"
+"Le programme ps2pdf n'est pas disponible. Merci de l'installer pour permettre la création de fichiers PDF.\n"
"\n"
" %s"
@@ -3514,11 +3358,8 @@
#: ../gui/wxpython/psmap/frame.py:356
#, fuzzy
-msgid ""
-"Preview is not available probably because Ghostscript is not installed or "
-"not on PATH."
-msgstr ""
-"L'aperçu n'est pas disponible, probablement parce qu'il manque Ghostscript."
+msgid "Preview is not available probably because Ghostscript is not installed or not on PATH."
+msgstr "L'aperçu n'est pas disponible, probablement parce qu'il manque Ghostscript."
#: ../gui/wxpython/psmap/frame.py:358
msgid "Please follow instructions on GRASS Trac Wiki."
@@ -3993,8 +3834,7 @@
#: ../gui/wxpython/psmap/dialogs.py:1676
msgid "Database connection is not defined in DB file."
-msgstr ""
-"La connexion à la base de données n'est pas définie dans le fichier DB."
+msgstr "La connexion à la base de données n'est pas définie dans le fichier DB."
#: ../gui/wxpython/psmap/dialogs.py:1677
msgid "Select layer:"
@@ -4095,8 +3935,7 @@
#: ../gui/wxpython/psmap/dialogs.py:1971 ../gui/wxpython/psmap/dialogs.py:2160
msgid "Type filename or click browse to choose file"
-msgstr ""
-"Taper un nom de fichier ou cliquer sur Parcourir pour choisir un fichier"
+msgstr "Taper un nom de fichier ou cliquer sur Parcourir pour choisir un fichier"
#: ../gui/wxpython/psmap/dialogs.py:1972 ../gui/wxpython/psmap/dialogs.py:2161
msgid "Choose a file"
@@ -4278,8 +4117,7 @@
#: ../gui/wxpython/psmap/dialogs.py:2729
msgid "Leave the edit field empty, to use default values."
-msgstr ""
-"Laisser vide le champ d'édition afin d'utiliser les valeurs par défaut."
+msgstr "Laisser vide le champ d'édition afin d'utiliser les valeurs par défaut."
#: ../gui/wxpython/psmap/dialogs.py:2751
msgid ""
@@ -4684,13 +4522,8 @@
#: ../gui/wxpython/dbmgr/manager.py:85
#, python-format
-msgid ""
-"Database connection for vector map <%s> is not defined in DB file. You can "
-"define new connection in 'Manage layers' tab."
-msgstr ""
-"La connexion à une base de données n'est pas définie dans le fichier DB pour "
-"la carte vecteur <%s>. Vous pouvez définir une nouvelle connexion dans "
-"l'onglet 'Gérer les couches'."
+msgid "Database connection for vector map <%s> is not defined in DB file. You can define new connection in 'Manage layers' tab."
+msgstr "La connexion à une base de données n'est pas définie dans le fichier DB pour la carte vecteur <%s>. Vous pouvez définir une nouvelle connexion dans l'onglet 'Gérer les couches'."
#: ../gui/wxpython/dbmgr/manager.py:90
msgid "Please wait, loading attribute data..."
@@ -4731,11 +4564,8 @@
#: ../gui/wxpython/dbmgr/vinfo.py:101
#, python-brace-format
-msgid ""
-"Failed to query vector map <{map}>. Check database settings and topology."
-msgstr ""
-"Échec de requête de la carte vecteur <{map}>. Vérifiez les paramètres de la "
-"base de données et la topologie."
+msgid "Failed to query vector map <{map}>. Check database settings and topology."
+msgstr "Échec de requête de la carte vecteur <{map}>. Vérifiez les paramètres de la base de données et la topologie."
#: ../gui/wxpython/dbmgr/sqlbuilder.py:93 ../gui/wxpython/dbmgr/base.py:2065
msgid "Database connection"
@@ -4752,8 +4582,7 @@
#: ../gui/wxpython/dbmgr/sqlbuilder.py:123
msgid "Apply SQL statement in Attribute Table Manager"
-msgstr ""
-"Appliquer l'expression SQL dans le gestionnaire des tables attributaires"
+msgstr "Appliquer l'expression SQL dans le gestionnaire des tables attributaires"
#: ../gui/wxpython/dbmgr/sqlbuilder.py:125
msgid "Close the dialog"
@@ -4873,12 +4702,8 @@
#: ../gui/wxpython/dbmgr/base.py:154
#, python-format
-msgid ""
-"Attribute table <%s> not found. For creating the table switch to 'Manage "
-"layers' tab."
-msgstr ""
-"Table d'attributs <%s> non trouvée. Pour créer la table passer à l'onglet "
-"'Gérer les couches'."
+msgid "Attribute table <%s> not found. For creating the table switch to 'Manage layers' tab."
+msgstr "Table d'attributs <%s> non trouvée. Pour créer la table passer à l'onglet 'Gérer les couches'."
#: ../gui/wxpython/dbmgr/base.py:165
#, python-format
@@ -4905,21 +4730,16 @@
# Conserver le sigle GUI me semble plus clair pour l'utilisateur que sa traduction française (IGU) peu voire pas usitée.
#: ../gui/wxpython/dbmgr/base.py:321
msgid "Unable to decode value. Set encoding in GUI preferences ('Attributes')."
-msgstr ""
-"Valeur impossible à décoder. Fixer l'encodage dans les préférences du GUI "
-"('Attributs')"
+msgstr "Valeur impossible à décoder. Fixer l'encodage dans les préférences du GUI ('Attributs')"
#: ../gui/wxpython/dbmgr/base.py:330
#, python-format
msgid ""
-"Error loading attribute data. Record number: %(rec)d. Unable to convert "
-"value '%(val)s' in key column (%(key)s) to integer.\n"
+"Error loading attribute data. Record number: %(rec)d. Unable to convert value '%(val)s' in key column (%(key)s) to integer.\n"
"\n"
"Details: %(detail)s"
msgstr ""
-"Erreur au chargement des données attributaires. Numéro d'enregistrement "
-"%(rec)d. Impossible de convertir la valeur '%(val)s' dans la colonne clé "
-"(%(key)s) en nombre entier.\n"
+"Erreur au chargement des données attributaires. Numéro d'enregistrement %(rec)d. Impossible de convertir la valeur '%(val)s' dans la colonne clé (%(key)s) en nombre entier.\n"
"\n"
"Détails: %(detail)s"
@@ -5000,8 +4820,7 @@
#: ../gui/wxpython/dbmgr/base.py:1026
msgid "Attribute data - right-click to edit/manage records"
-msgstr ""
-"Données attributaires - clic droit pour éditer/gérer les enregistrements"
+msgstr "Données attributaires - clic droit pour éditer/gérer les enregistrements"
#: ../gui/wxpython/dbmgr/base.py:1041 ../gui/wxpython/dbmgr/base.py:2049
#: ../gui/wxpython/dbmgr/base.py:2642 ../gui/wxpython/dbmgr/base.py:2773
@@ -5099,8 +4918,7 @@
#: ../gui/wxpython/dbmgr/base.py:1455
#, python-format
msgid "Record with category number %d already exists in the table."
-msgstr ""
-"L'enregistrement portant la catégorie numéro %d existe déjà dans la table."
+msgstr "L'enregistrement portant la catégorie numéro %d existe déjà dans la table."
#: ../gui/wxpython/dbmgr/base.py:1465
#, python-format
@@ -5118,12 +4936,8 @@
#: ../gui/wxpython/dbmgr/base.py:1540
#, python-format
-msgid ""
-"Selected data records (%d) will be permanently deleted from table. Do you "
-"want to delete them?"
-msgstr ""
-"Les enregistrements sélectionnés (%d) vont être définitivement supprimés de "
-"la table. Souhaitez-vous les supprimer ?"
+msgid "Selected data records (%d) will be permanently deleted from table. Do you want to delete them?"
+msgstr "Les enregistrements sélectionnés (%d) vont être définitivement supprimés de la table. Souhaitez-vous les supprimer ?"
#: ../gui/wxpython/dbmgr/base.py:1543 ../gui/wxpython/dbmgr/base.py:1589
msgid "Delete records"
@@ -5131,12 +4945,8 @@
#: ../gui/wxpython/dbmgr/base.py:1586
#, python-format
-msgid ""
-"All data records (%d) will be permanently deleted from table. Do you want to "
-"delete them?"
-msgstr ""
-"Tous les enregistrements (%d) seront définitivement supprimés de la table. "
-"Souhaitez-vous les supprimer ?"
+msgid "All data records (%d) will be permanently deleted from table. Do you want to delete them?"
+msgstr "Tous les enregistrements (%d) seront définitivement supprimés de la table. Souhaitez-vous les supprimer ?"
#: ../gui/wxpython/dbmgr/base.py:1761
msgid "Nothing to extract."
@@ -5195,21 +5005,13 @@
#: ../gui/wxpython/dbmgr/base.py:2267
#, python-format
-msgid ""
-"Unable to rename column <%(column)s> to <%(columnTo)s>. Column already "
-"exists in the table <%(table)s>."
-msgstr ""
-"Impossible de renommer la colonne <%(column)s> en <%(columnTo)s>. La colonne "
-"existe déjà dans la table <%(table)s>."
+msgid "Unable to rename column <%(column)s> to <%(columnTo)s>. Column already exists in the table <%(table)s>."
+msgstr "Impossible de renommer la colonne <%(column)s> en <%(columnTo)s>. La colonne existe déjà dans la table <%(table)s>."
#: ../gui/wxpython/dbmgr/base.py:2283
#, python-format
-msgid ""
-"Unable to rename column. Column <%(column)s> doesn't exist in the table <"
-"%(table)s>."
-msgstr ""
-"Impossible de renommer la colonne. La colonnes<%(column)s> n'existe pas dans "
-"la table <%(table)s>."
+msgid "Unable to rename column. Column <%(column)s> doesn't exist in the table <%(table)s>."
+msgstr "Impossible de renommer la colonne. La colonnes<%(column)s> n'existe pas dans la table <%(table)s>."
#: ../gui/wxpython/dbmgr/base.py:2310
msgid "Drop selected column"
@@ -5221,12 +5023,8 @@
#: ../gui/wxpython/dbmgr/base.py:2342
#, python-format
-msgid ""
-"Selected %s will PERMANENTLY removed from table. Do you want to drop the "
-"column?"
-msgstr ""
-"La colonne sélectionnée %s sera DÉFINITIVEMENT supprimée de la table. "
-"Souhaitez-vous supprimer cette colonne ?"
+msgid "Selected %s will PERMANENTLY removed from table. Do you want to drop the column?"
+msgstr "La colonne sélectionnée %s sera DÉFINITIVEMENT supprimée de la table. Souhaitez-vous supprimer cette colonne ?"
#: ../gui/wxpython/dbmgr/base.py:2345 ../gui/wxpython/dbmgr/base.py:2382
msgid "Drop column(s)"
@@ -5241,8 +5039,7 @@
msgstr ""
"Les colonnes sélectionnées\n"
"%s\n"
-"seront DÉFINITIVEMENT supprimées de la table. Souhaitez-vous supprimer ces "
-"colonnes ?"
+"seront DÉFINITIVEMENT supprimées de la table. Souhaitez-vous supprimer ces colonnes ?"
#: ../gui/wxpython/dbmgr/base.py:2467
msgid "List of layers"
@@ -5348,25 +5145,17 @@
#: ../gui/wxpython/dbmgr/base.py:3220
msgid "Unable to create new table. Table name or key column name is missing."
-msgstr ""
-"Impossible de créer la nouvelle table. Il manque le nom de la table ou de la "
-"colonne clé."
+msgstr "Impossible de créer la nouvelle table. Il manque le nom de la table ou de la colonne clé."
#: ../gui/wxpython/dbmgr/base.py:3226
#, python-format
msgid "Unable to create new table. Table <%s> already exists in the database."
-msgstr ""
-"Impossible de créer la nouvelle table. La table <%s> existe déjà dans la "
-"base."
+msgstr "Impossible de créer la nouvelle table. La table <%s> existe déjà dans la base."
#: ../gui/wxpython/dbmgr/base.py:3264
#, python-format
-msgid ""
-"Unable to add new layer to vector map <%(vector)s>. Layer %(layer)d already "
-"exists."
-msgstr ""
-"Impossible d'ajouter la nouvelle couche à la carte vecteur <%(vector)s>. La "
-"couche %(layer)d existe déjà."
+msgid "Unable to add new layer to vector map <%(vector)s>. Layer %(layer)d already exists."
+msgstr "Impossible d'ajouter la nouvelle couche à la carte vecteur <%(vector)s>. La couche %(layer)d existe déjà."
#: ../gui/wxpython/dbmgr/base.py:3428
msgid "Field statistics"
@@ -5386,11 +5175,8 @@
#: ../gui/wxpython/dbmgr/base.py:3533
#, python-format
-msgid ""
-"Unable to calculte statistics. Invalid number of lines %d (should be %d)."
-msgstr ""
-"Impossible de calculer les statistiques. Nombre de lignes %d invalides "
-"(devrait être %d)."
+msgid "Unable to calculte statistics. Invalid number of lines %d (should be %d)."
+msgstr "Impossible de calculer les statistiques. Nombre de lignes %d invalides (devrait être %d)."
#: ../gui/wxpython/dbmgr/base.py:3551
msgid "Unable to calculte standard deviation."
@@ -5415,13 +5201,11 @@
msgid ""
"No attribute table found.\n"
"\n"
-"Do you want to create a new attribute table and defined a link to vector map "
-"<%s>?"
+"Do you want to create a new attribute table and defined a link to vector map <%s>?"
msgstr ""
"Pas de table attributaire trouvée.\n"
"\n"
-"Voulez-vous créer une nouvelle table attributaire et la lier au vecteur <"
-"%s> ?"
+"Voulez-vous créer une nouvelle table attributaire et la lier au vecteur <%s> ?"
#: ../gui/wxpython/dbmgr/dialogs.py:77
msgid "Create table?"
@@ -5459,8 +5243,7 @@
#: ../gui/wxpython/dbmgr/dialogs.py:226
#, python-format
msgid "Column <%(col)s>: Value '%(value)s' needs to be entered as %(type)s."
-msgstr ""
-"Colonne<%(col)s> : La valeur '%(value)s' doit être entrée comme %(type)s."
+msgstr "Colonne<%(col)s> : La valeur '%(value)s' doit être entrée comme %(type)s."
#: ../gui/wxpython/dbmgr/dialogs.py:436
msgid "Unknown"
@@ -5469,14 +5252,12 @@
#: ../gui/wxpython/icons/icon.py:34
#, python-format
msgid "Unknown iconset '%s', using default 'grass'...\n"
-msgstr ""
-"Jeu d'icônes '%s' inconnu, utilisation du jeu par defaut 'grass\" ...\n"
+msgstr "Jeu d'icônes '%s' inconnu, utilisation du jeu par defaut 'grass\" ...\n"
#: ../gui/wxpython/icons/icon.py:51
#, python-format
msgid "Unable to load icon theme. Reason: %s. Quiting wxGUI..."
-msgstr ""
-"Impossible de charger les icône du thème. Raison : %s. Arrêt de wxGUI ..."
+msgstr "Impossible de charger les icône du thème. Raison : %s. Arrêt de wxGUI ..."
#: ../gui/wxpython/animation/data.py:44 ../gui/wxpython/mapdisp/frame.py:270
#: ../gui/wxpython/mapdisp/frame.py:329 ../gui/wxpython/mapdisp/frame.py:510
@@ -5516,12 +5297,8 @@
#: ../gui/wxpython/animation/controller.py:245
#: ../gui/wxpython/animation/dialogs.py:727
-msgid ""
-"More animations are using one window. Please select different window for "
-"each animation."
-msgstr ""
-"Plusieurs animations utilisent la même fenêtre. Merci de sélectionner une "
-"fenêtre différente pour chaque animation."
+msgid "More animations are using one window. Please select different window for each animation."
+msgstr "Plusieurs animations utilisent la même fenêtre. Merci de sélectionner une fenêtre différente pour chaque animation."
#: ../gui/wxpython/animation/controller.py:404
msgid "Failed to display legend."
@@ -5588,39 +5365,24 @@
msgstr "Le nombre de cartes des jeux de données temporels doiit être le même."
#: ../gui/wxpython/animation/utils.py:182
-msgid ""
-"The temporal type (absolute/relative) of space-time datasets has to be the "
-"same."
-msgstr ""
-"Le type temporel (absolut/relatif) des jeux de données temporels doit être "
-"le même."
+msgid "The temporal type (absolute/relative) of space-time datasets has to be the same."
+msgstr "Le type temporel (absolut/relatif) des jeux de données temporels doit être le même."
#: ../gui/wxpython/animation/utils.py:186
-msgid ""
-"The map type (point/interval) of space-time datasets has to be the same."
-msgstr ""
-"Le type de carte (ponctuel/intervalle) des jeux de donénes temporels doit "
-"être le même."
+msgid "The map type (point/interval) of space-time datasets has to be the same."
+msgstr "Le type de carte (ponctuel/intervalle) des jeux de donénes temporels doit être le même."
#: ../gui/wxpython/animation/utils.py:190
-msgid ""
-"The temporal extents of maps in space-time datasets have to be the same."
-msgstr ""
-"L'étendue temporelle des cartes des jeux de données temporels doit être la "
-"même."
+msgid "The temporal extents of maps in space-time datasets have to be the same."
+msgstr "L'étendue temporelle des cartes des jeux de données temporels doit être la même."
#: ../gui/wxpython/animation/utils.py:198
msgid "The number of maps to animate has to be the same for each map series."
-msgstr ""
-"Le nombre de cartes à animer doit être le même pour chaque série de cartes."
+msgstr "Le nombre de cartes à animer doit être le même pour chaque série de cartes."
#: ../gui/wxpython/animation/utils.py:202
-msgid ""
-"The number of maps to animate has to be the same as the number of maps in "
-"temporal dataset."
-msgstr ""
-"Le nombre de cartes à animer doit être le même que le nombre de cartes dans "
-"le jeu de données temporel."
+msgid "The number of maps to animate has to be the same as the number of maps in temporal dataset."
+msgstr "Le nombre de cartes à animer doit être le même que le nombre de cartes dans le jeu de données temporel."
#: ../gui/wxpython/animation/nviztask.py:42 ../gui/wxpython/lmgr/frame.py:1224
#, python-format
@@ -5661,28 +5423,17 @@
msgstr "Répertoire {t} non supprimé."
#: ../gui/wxpython/animation/temporal_manager.py:105
-msgid ""
-"It is not allowed to display data with different temporal types (absolute "
-"and relative)."
-msgstr ""
-"Il n'est pas permis d'afficher des données avec des types temporels "
-"différents (absolu et reatif)."
+msgid "It is not allowed to display data with different temporal types (absolute and relative)."
+msgstr "Il n'est pas permis d'afficher des données avec des types temporels différents (absolu et reatif)."
#: ../gui/wxpython/animation/temporal_manager.py:119
#, python-format
msgid "It is not allowed to display data with different units (%s)."
-msgstr ""
-"Il n'est pas permis d'afficher des donénes avec des unités différentes (%s)."
+msgstr "Il n'est pas permis d'afficher des donénes avec des unités différentes (%s)."
#: ../gui/wxpython/animation/temporal_manager.py:130
-msgid ""
-"You are going to display data with different temporal types of maps "
-"(interval and point). It is recommended to use data of one temporal type to "
-"avoid confusion."
-msgstr ""
-"Vous êtes sur le point d'afficher des données avec des types de cartes "
-"temporelles différents (intervalle et ponctuel). Il est recommandé "
-"d'utiliser un seul tye temporel pour éviter la confusion."
+msgid "You are going to display data with different temporal types of maps (interval and point). It is recommended to use data of one temporal type to avoid confusion."
+msgstr "Vous êtes sur le point d'afficher des données avec des types de cartes temporelles différents (intervalle et ponctuel). Il est recommandé d'utiliser un seul tye temporel pour éviter la confusion."
#: ../gui/wxpython/animation/temporal_manager.py:330
#, python-format
@@ -5800,8 +5551,7 @@
"For 3D animation, please select only one space-time dataset\n"
"or one series of map layers."
msgstr ""
-"Pour une animation 3D, merci de ne sélectionner qu'un seul jeu de données "
-"temporel\n"
+"Pour une animation 3D, merci de ne sélectionner qu'un seul jeu de données temporel\n"
"ou une série de cartes."
#: ../gui/wxpython/animation/dialogs.py:371
@@ -5819,8 +5569,7 @@
#: ../gui/wxpython/animation/dialogs.py:396
msgid "Choose workspace file to import 3D view parameters"
-msgstr ""
-"Choisir le fichier d'espace de travail pour l'import des paramètres de vue 3D"
+msgstr "Choisir le fichier d'espace de travail pour l'import des paramètres de vue 3D"
#: ../gui/wxpython/animation/dialogs.py:403
msgid "Parameter for animation:"
@@ -5844,8 +5593,7 @@
#: ../gui/wxpython/animation/dialogs.py:441
msgid "N-S/E-W distances in map units used to gradually reduce region."
-msgstr ""
-"Distances N-S/E-O en unité de carte pour réduire graduellement la région."
+msgstr "Distances N-S/E-O en unité de carte pour réduire graduellement la région."
#: ../gui/wxpython/animation/dialogs.py:448
msgid "N-S:"
@@ -5857,8 +5605,7 @@
#: ../gui/wxpython/animation/dialogs.py:543
msgid "Only one series or space-time dataset is accepted for 3D mode."
-msgstr ""
-"Seulement une série ou jeu de données temporel est accepté dans le mode 3D."
+msgstr "Seulement une série ou jeu de données temporel est accepté dans le mode 3D."
#: ../gui/wxpython/animation/dialogs.py:551
#, fuzzy
@@ -5943,9 +5690,7 @@
#: ../gui/wxpython/animation/dialogs.py:878
msgid "Placement as percentage of screen coordinates (X: 0, Y: 0 is top left):"
-msgstr ""
-"Positionnement en pourcentage des coordonnées de l'écran (X : 0, Y : 0 est "
-"en haut à gauche) :"
+msgstr "Positionnement en pourcentage des coordonnées de l'écran (X : 0, Y : 0 est en haut à gauche) :"
#: ../gui/wxpython/animation/dialogs.py:901
msgid "image sequence"
@@ -6009,8 +5754,7 @@
"Please install it first and make sure\n"
"it's in the PATH variable."
msgstr ""
-"Le programme 'ffmpeg' n'a pas été trouvé.Merci de l'installer et de "
-"vérifier\n"
+"Le programme 'ffmpeg' n'a pas été trouvé.Merci de l'installer et de vérifier\n"
"qu'il ets dans le PATH."
#: ../gui/wxpython/animation/dialogs.py:990
@@ -6026,12 +5770,8 @@
msgstr "Options supplémentaires :"
#: ../gui/wxpython/animation/dialogs.py:998
-msgid ""
-"Consider adding '-sameq' or '-qscale 1' if not satisfied with video quality. "
-"Options depend on ffmpeg version."
-msgstr ""
-"Ajouter '-sameq' ou '-qscale 1' si vous n'êtes pas satisfaits de la qualité "
-"de la vidéo. Les options dépendent de la version de ffmpeg."
+msgid "Consider adding '-sameq' or '-qscale 1' if not satisfied with video quality. Options depend on ffmpeg version."
+msgstr "Ajouter '-sameq' ou '-qscale 1' si vous n'êtes pas satisfaits de la qualité de la vidéo. Les options dépendent de la version de ffmpeg."
#: ../gui/wxpython/animation/dialogs.py:1020
#, python-format
@@ -6137,12 +5877,8 @@
#: ../gui/wxpython/animation/dialogs.py:1537
#, fuzzy
-msgid ""
-"Click and then press key up or down to preview different date and time "
-"formats. Type custom format string."
-msgstr ""
-"Cliquez et appuyer sur les touches haut et bas pour voir différents formats "
-"de date et heure."
+msgid "Click and then press key up or down to preview different date and time formats. Type custom format string."
+msgstr "Cliquez et appuyer sur les touches haut et bas pour voir différents formats de date et heure."
#: ../gui/wxpython/animation/dialogs.py:1546
msgid "Learn more about formatting options"
@@ -6155,13 +5891,8 @@
#: ../gui/wxpython/animation/dialogs.py:1556
#, fuzzy
-msgid ""
-"When animating instant-based data which have irregular timestamps you can "
-"display 'no data frame' (checked option) or keep last frame."
-msgstr ""
-"Lorsque l'animation contient des données avec un pas de temps irrégulier, "
-"vous pouvez afficher 'pas d'image' (option cochée) ou garder la dernière "
-"image."
+msgid "When animating instant-based data which have irregular timestamps you can display 'no data frame' (checked option) or keep last frame."
+msgstr "Lorsque l'animation contient des données avec un pas de temps irrégulier, vous pouvez afficher 'pas d'image' (option cochée) ou garder la dernière image."
#: ../gui/wxpython/animation/dialogs.py:1578
msgid "Invalid"
@@ -6208,8 +5939,7 @@
#: ../gui/wxpython/animation/toolbars.py:50
msgid "Add space-time dataset or series of map layers for animation"
-msgstr ""
-"Ajouter un jeu de données temporel ou une série de cartes pour l'animation"
+msgstr "Ajouter un jeu de données temporel ou une série de cartes pour l'animation"
#: ../gui/wxpython/vnet/widgets.py:377
msgid "Invalid value inserted. Operation canceled."
@@ -6226,12 +5956,10 @@
#: ../gui/wxpython/vnet/vnet_core.py:211
#, python-format
msgid ""
-"Temporary map '%s' with result was changed outside vector network analysis "
-"tool.\n"
+"Temporary map '%s' with result was changed outside vector network analysis tool.\n"
"Showed result may not correspond original analysis result."
msgstr ""
-"La carte temporaire '%s' avec les résultats a été modifiée en dehors de "
-"l'outil d'analyse de réseau vectoriel.\n"
+"La carte temporaire '%s' avec les résultats a été modifiée en dehors de l'outil d'analyse de réseau vectoriel.\n"
"Les résultats affichés peuvent ne pas correspondre aux résultats d'origine."
#: ../gui/wxpython/vnet/vnet_core.py:216
@@ -6275,12 +6003,10 @@
#: ../gui/wxpython/vnet/vnet_core.py:895
#, python-format
msgid ""
-"Input map '%s' for analysis was changed outside vector network analysis "
-"tool.\n"
+"Input map '%s' for analysis was changed outside vector network analysis tool.\n"
"Topology column may not correspond to changed situation."
msgstr ""
-"La carte d'entrée '%s' pour l'analyse a été modifiée en dehors de l'outil "
-"d'analyse de réseau vectoriel.\n"
+"La carte d'entrée '%s' pour l'analyse a été modifiée en dehors de l'outil d'analyse de réseau vectoriel.\n"
"La colonne de topologie peut ne pas correspondre à la situation modifiée."
#: ../gui/wxpython/vnet/vnet_core.py:900
@@ -6315,8 +6041,7 @@
"Temporary map '%s' was changed outside vector analysis tool.\n"
"Do you really want to activate snapping and overwrite it? "
msgstr ""
-"La carte temporaire '%s' a été modifiée en dehors de l'outil d'analyse "
-"vectorielle.\n"
+"La carte temporaire '%s' a été modifiée en dehors de l'outil d'analyse vectorielle.\n"
"Voulez-vous vraiment activer le magnétisme et l'écraser ?"
#: ../gui/wxpython/vnet/vnet_core.py:1045
@@ -6365,12 +6090,8 @@
#: ../gui/wxpython/vnet/vnet_data.py:184
#, python-format
-msgid ""
-"Chosen column '%s' does not exist in attribute table of layer '%s' of vector "
-"map '%s'.\n"
-msgstr ""
-"La colonne choisie '%s' n'existe pas dans la table d'attributs de la couche "
-"'%s' de la carte vectorielle '%s'.\n"
+msgid "Chosen column '%s' does not exist in attribute table of layer '%s' of vector map '%s'.\n"
+msgstr "La colonne choisie '%s' n'existe pas dans la table d'attributs de la couche '%s' de la carte vectorielle '%s'.\n"
#: ../gui/wxpython/vnet/vnet_data.py:238
msgid "type"
@@ -6711,15 +6432,8 @@
msgstr "Afficher les limites de calculs"
#: ../gui/wxpython/mapdisp/statusbar.py:443
-msgid ""
-"Show/hide computational region extent (set with g.region). Display region "
-"drawn as a blue box inside the computational region, computational region "
-"inside a display region as a red box)."
-msgstr ""
-"Afficher/cacher les limites de la région de calcul (définie avec g.region). "
-"Région de l'affichage dessinée comme rectangle bleu à l'intérieur de la "
-"région de calcul, région de calcul comme rectangle rouge à l'intérieur de la "
-"région de l'affichage."
+msgid "Show/hide computational region extent (set with g.region). Display region drawn as a blue box inside the computational region, computational region inside a display region as a red box)."
+msgstr "Afficher/cacher les limites de la région de calcul (définie avec g.region). Région de l'affichage dessinée comme rectangle bleu à l'intérieur de la région de calcul, région de calcul comme rectangle rouge à l'intérieur de la région de l'affichage."
#: ../gui/wxpython/mapdisp/statusbar.py:492
msgid "Display mode"
@@ -6731,13 +6445,8 @@
msgstr "Aligner l'étendue de la région sur la taille de l'affichage"
#: ../gui/wxpython/mapdisp/statusbar.py:499
-msgid ""
-"Align region extent based on display size from center point. Default value "
-"for new map displays can be set up in 'User GUI settings' dialog."
-msgstr ""
-"Aligner l'emprise de la région sur la taille de l'affichage depuis le point "
-"central. La valeur par défaut pour les nouveaux affichages peut être définie "
-"dans la boîte de dialogue 'Paramètres de l'interface utilisateur'"
+msgid "Align region extent based on display size from center point. Default value for new map displays can be set up in 'User GUI settings' dialog."
+msgstr "Aligner l'emprise de la région sur la taille de l'affichage depuis le point central. La valeur par défaut pour les nouveaux affichages peut être définie dans la boîte de dialogue 'Paramètres de l'interface utilisateur'"
#: ../gui/wxpython/mapdisp/statusbar.py:532
msgid "Display resolution"
@@ -6749,26 +6458,16 @@
msgstr "Contraindre la résolution d'affichage aux paramètres de calculs"
#: ../gui/wxpython/mapdisp/statusbar.py:538
-msgid ""
-"Constrain display resolution to computational region settings. Default value "
-msgstr ""
-"Contraindre la résolution d'affichage aux paramètres de la région calculée. "
-"La valeur par défaut pour les nouveaux affichages de cartes peut être "
-"définie dans la boîte de dialogue 'Paramètres de l'interface utilisateur'"
+msgid "Constrain display resolution to computational region settings. Default value for new map displays can be set up in 'User GUI settings' dialog."
+msgstr "Contraindre la résolution d'affichage aux paramètres de la région calculée. La valeur par défaut pour les nouveaux affichages de cartes peut être définie dans la boîte de dialogue 'Paramètres de l'interface utilisateur'"
#: ../gui/wxpython/mapdisp/statusbar.py:575
msgid "Map scale"
msgstr "Échelle de la carte"
#: ../gui/wxpython/mapdisp/statusbar.py:589
-msgid ""
-"As everyone's monitors and resolutions are set differently these values are "
-"not true map scales, but should get you into the right neighborhood."
-msgstr ""
-"Étant donné que tous les moniteurs et les résolutions sont réglés "
-"différemment, ces valeurs ne sont pas des échelles réelles mais restent "
-"proches de la réalité."
+msgid "As everyone's monitors and resolutions are set differently these values are not true map scales, but should get you into the right neighborhood."
+msgstr "Étant donné que tous les moniteurs et les résolutions sont réglés différemment, ces valeurs ne sont pas des échelles réelles mais restent proches de la réalité."
#: ../gui/wxpython/mapdisp/statusbar.py:642
msgid "Go to"
@@ -6797,13 +6496,8 @@
msgstr "Utiliser une projection définie"
#: ../gui/wxpython/mapdisp/statusbar.py:787
-msgid ""
-"Reproject coordinates displayed in the statusbar. Projection can be defined "
-"in GUI preferences dialog (tab 'Projection')"
-msgstr ""
-"Re-projeter les coordonnées affichées dans la barre d'état. La projection "
-"peut être définie dans les préférences de l'interface utilisateur (onglet "
-"'Affichage de la carte')"
+msgid "Reproject coordinates displayed in the statusbar. Projection can be defined in GUI preferences dialog (tab 'Projection')"
+msgstr "Re-projeter les coordonnées affichées dans la barre d'état. La projection peut être définie dans les préférences de l'interface utilisateur (onglet 'Affichage de la carte')"
#: ../gui/wxpython/mapdisp/statusbar.py:812
msgid "MASK"
@@ -6838,11 +6532,8 @@
#: ../gui/wxpython/mapdisp/frame.py:254
#, python-format
-msgid ""
-"GRASS GIS %(version)s Map Display: %(id)s - Location: %(loc)s@%(mapset)s"
-msgstr ""
-"SIG GRASS %(version)s - Fenêtre de cartes : %(id)s - Secteur : %(loc)s@"
-"%(mapset)s"
+msgid "GRASS GIS %(version)s Map Display: %(id)s - Location: %(loc)s@%(mapset)s"
+msgstr "SIG GRASS %(version)s - Fenêtre de cartes : %(id)s - Secteur : %(loc)s@%(mapset)s"
#: ../gui/wxpython/mapdisp/frame.py:272 ../gui/wxpython/lmgr/layertree.py:908
#, python-format
@@ -6908,11 +6599,8 @@
#: ../gui/wxpython/mapdisp/frame.py:878
-msgid ""
-"Failed to query vector map(s) <{maps}>. Check database settings and topology."
-msgstr ""
-"L'interrogation de la carte vecteur <{maps}> a échoué. Vérifier les "
-"paramètres de base de données et de topologie."
+msgid "Failed to query vector map(s) <{maps}>. Check database settings and topology."
+msgstr "L'interrogation de la carte vecteur <{maps}> a échoué. Vérifier les paramètres de base de données et de topologie."
#: ../gui/wxpython/mapdisp/frame.py:1253
#: ../gui/wxpython/mapdisp/toolbars.py:49
@@ -6939,9 +6627,7 @@
#: ../gui/wxpython/gui_core/mapdisp.py:114 ../gui/wxpython/core/render.py:449
#, python-format
msgid "GRASS module '%s' not found. Unable to start map display window."
-msgstr ""
-"Module GRASS '%s' introuvable. Impossible de démarrer la fenêtre d'affichage "
-"des cartes."
+msgstr "Module GRASS '%s' introuvable. Impossible de démarrer la fenêtre d'affichage des cartes."
#: ../gui/wxpython/mapdisp/test_mapdisp.py:129
msgid "Map window test frame"
@@ -7059,11 +6745,8 @@
msgstr "Mode survol"
#: ../gui/wxpython/mapdisp/toolbars.py:62
-msgid ""
-"Drag with mouse, hold Ctrl down for different mode or Shift to accelerate"
-msgstr ""
-"Déplacer avec la souris, appuyer sur Ctrl pour les différents modes, ou Maj "
-"pour accélérer"
+msgid "Drag with mouse, hold Ctrl down for different mode or Shift to accelerate"
+msgstr "Déplacer avec la souris, appuyer sur Ctrl pour les différents modes, ou Maj pour accélérer"
#: ../gui/wxpython/mapdisp/toolbars.py:64
msgid "Click mouse to zoom"
@@ -7088,15 +6771,8 @@
msgstr "La numérisation de vector n'est pas disponible"
#: ../gui/wxpython/mapdisp/toolbars.py:109
-msgid ""
-"Note that the wxGUI's vector digitizer is currently disabled (hopefully this "
-"will be fixed soon). Please keep an eye out for updated versions of GRASS. "
-"In the meantime you can use \"v.digit\" from the Develop Vector menu."
-msgstr ""
-"Notez que le module de digitalisation de wxGUI est actuellement indisponible "
-"(en espérant que cela soit prochainement résolu). Merci de garder un œil sur "
-"les mises à jour de GRASS. En attendant, vous pouvez utiliser le module \"v."
-"digit\", accessible depuis le menu Vecteur."
+msgid "Note that the wxGUI's vector digitizer is currently disabled (hopefully this will be fixed soon). Please keep an eye out for updated versions of GRASS. In the meantime you can use \"v.digit\" from the Develop Vector menu."
+msgstr "Notez que le module de digitalisation de wxGUI est actuellement indisponible (en espérant que cela soit prochainement résolu). Merci de garder un œil sur les mises à jour de GRASS. En attendant, vous pouvez utiliser le module \"v.digit\", accessible depuis le menu Vecteur."
#: ../gui/wxpython/rlisetup/sampling_frame.py:205
#: ../gui/wxpython/rlisetup/sampling_frame.py:308
@@ -7145,9 +6821,7 @@
#: ../gui/wxpython/rlisetup/sampling_frame.py:392
msgid "Draw sampling region by polygon. Right Double click to end drawing"
-msgstr ""
-"Dessiner la région d'échantillonage avec un polygone. Double-clic droit pour "
-"terminer"
+msgstr "Dessiner la région d'échantillonage avec un polygone. Double-clic droit pour terminer"
#: ../gui/wxpython/rlisetup/frame.py:22
msgid "Modify the configuration file"
@@ -7164,8 +6838,7 @@
"Are you sure that you want modify r.li configuration file {name}?\n"
"You could broke the configuration file..."
msgstr ""
-"Êtes-vous sûr de vouloir modifier le fichier de configuration de r.li "
-"{name} ?\n"
+"Êtes-vous sûr de vouloir modifier le fichier de configuration de r.li {name} ?\n"
"Vous risquez de casser la configuration ..."
#: ../gui/wxpython/rlisetup/frame.py:88
@@ -7226,12 +6899,8 @@
#: ../gui/wxpython/rlisetup/frame.py:241
#, python-format
-msgid ""
-"Set the new name for %s \" "
-"\"configuration file"
-msgstr ""
-"Définir le nouveau nom pour le fichier de configuration %s "
+msgid "Set the new name for %s \" \"configuration file"
+msgstr "Définir le nouveau nom pour le fichier de configuration %s \" \""
#: ../gui/wxpython/rlisetup/frame.py:243
msgid "Rename configuration file"
@@ -7252,8 +6921,7 @@
#: ../gui/wxpython/rlisetup/wizard.py:130
msgid "r.li.setup wizard canceled. Configuration file not created."
-msgstr ""
-"Assistant de r.li interrompu. Le fichier de configuration n'a pas été créé."
+msgstr "Assistant de r.li interrompu. Le fichier de configuration n'a pas été créé."
#: ../gui/wxpython/rlisetup/wizard.py:429
msgid "Select maps and define name"
@@ -7300,21 +6968,17 @@
#: ../gui/wxpython/rlisetup/wizard.py:588
#, python-format
msgid "Vector %s was not found, please select another vector"
-msgstr ""
-"Le vecteur %s n'a pas été trouvé, merci de sélectionner un autre vecteur"
+msgstr "Le vecteur %s n'a pas été trouvé, merci de sélectionner un autre vecteur"
#: ../gui/wxpython/rlisetup/wizard.py:592
#, python-format
msgid "Vector %s has no areas, please select another vector"
-msgstr ""
-"L vecteur %s n'a pas de polygones, merci de sélectionner un autre vecteur"
+msgstr "L vecteur %s n'a pas de polygones, merci de sélectionner un autre vecteur"
#: ../gui/wxpython/rlisetup/wizard.py:597
#, python-format
msgid "Vector %s has no table connected, please select another vector"
-msgstr ""
-"Le vecteur %s n'a pas de table connectée, merci de sélectionner un autre "
-"vecteur"
+msgstr "Le vecteur %s n'a pas de table connectée, merci de sélectionner un autre vecteur"
#: ../gui/wxpython/rlisetup/wizard.py:639
msgid "Insert sampling frame parameter"
@@ -7538,13 +7202,8 @@
#: ../gui/wxpython/rlisetup/wizard.py:1578
#: ../gui/wxpython/rlisetup/functions.py:138
#, python-format
-msgid ""
-"The raster map <%s> already exists. Please remove or rename the maps with "
-"the prefix '%s' or select the option to overwrite existing maps"
-msgstr ""
-"la carte raster <%s> existe déjà. Merci de supprimer ou de renommer les "
-"cartes avec le préfix '%s' ou de sélectionner l'option pour écraser les "
-"cartes existantes."
+msgid "The raster map <%s> already exists. Please remove or rename the maps with the prefix '%s' or select the option to overwrite existing maps"
+msgstr "la carte raster <%s> existe déjà. Merci de supprimer ou de renommer les cartes avec le préfix '%s' ou de sélectionner l'option pour écraser les cartes existantes."
#: ../gui/wxpython/rlisetup/wizard.py:1618
#: ../gui/wxpython/rlisetup/functions.py:127
@@ -7702,7 +7361,6 @@
msgstr "Console de commande"
#: ../gui/wxpython/lmgr/frame.py:318
-#, fuzzy
msgid "Search modules"
msgstr "Rechercher un module"
@@ -7754,12 +7412,8 @@
#: ../gui/wxpython/lmgr/frame.py:646
#, python-format
-msgid ""
-"Command '%s' not yet implemented in the WxGUI. Try adding it as a command "
-"layer instead."
-msgstr ""
-"La commande '%s' n'est pas encore implantée dans wxGUI. Essayez plutôt de "
-"l'ajouter en tant que couche de commande."
+msgid "Command '%s' not yet implemented in the WxGUI. Try adding it as a command layer instead."
+msgstr "La commande '%s' n'est pas encore implantée dans wxGUI. Essayez plutôt de l'ajouter en tant que couche de commande."
#: ../gui/wxpython/lmgr/frame.py:807 ../gui/wxpython/lmgr/frame.py:1732
msgid "Selected map layer is not vector."
@@ -7767,9 +7421,7 @@
#: ../gui/wxpython/lmgr/frame.py:812
msgid "Editing is allowed only for vector maps from the current mapset."
-msgstr ""
-"L'édition n'est permise que pour des cartes vectorielles du jeux de cartes "
-"actuel."
+msgstr "L'édition n'est permise que pour des cartes vectorielles du jeux de cartes actuel."
#: ../gui/wxpython/lmgr/frame.py:836
msgid "Choose script file to run"
@@ -7780,14 +7432,8 @@
msgstr "Script Python (*.py)|*.py|Bash script (*.sh)|*.sh"
#: ../gui/wxpython/lmgr/frame.py:850
-msgid ""
-"Due to the limitations of your operating system, the script path cannot "
-"contain certain non-ascii characters. Please rename the script or move it to "
-"a different location."
-msgstr ""
-"À cause de limitations de votre système, the chemin du script ne peut pas "
-"contenir certains caractères non-ascii. Merci de renommer le script ou de le "
-"déplacer dans un endroit différent."
+msgid "Due to the limitations of your operating system, the script path cannot contain certain non-ascii characters. Please rename the script or move it to a different location."
+msgstr "À cause de limitations de votre système, the chemin du script ne peut pas contenir certains caractères non-ascii. Merci de renommer le script ou de le déplacer dans un endroit différent."
#: ../gui/wxpython/lmgr/frame.py:857
#, python-format
@@ -7796,12 +7442,8 @@
#: ../gui/wxpython/lmgr/frame.py:864
#, python-format
-msgid ""
-"Script <%s> is not executable. Do you want to set the permissions that "
-"allows you to run this script (note that you must be the owner of the file)?"
-msgstr ""
-"Le script <%s> n'est pas exécutable. Voulez-vous définir les permissions "
-"d'exécution du script (vous devez être l'utilisateur propriétaire) ?"
+msgid "Script <%s> is not executable. Do you want to set the permissions that allows you to run this script (note that you must be the owner of the file)?"
+msgstr "Le script <%s> n'est pas exécutable. Voulez-vous définir les permissions d'exécution du script (vous devez être l'utilisateur propriétaire) ?"
#: ../gui/wxpython/lmgr/frame.py:869
msgid "Set permission?"
@@ -7813,12 +7455,8 @@
#: ../gui/wxpython/lmgr/frame.py:889
#, python-format
-msgid ""
-"Directory '%s' is not defined in GRASS_ADDON_PATH. Do you want add this "
-"directory to GRASS_ADDON_PATH?"
-msgstr ""
-"Le dossier '%s' n'est pas définit dans GRASS_ADDON_PATH. Voulez-vous ajouter "
-"ce dossier à GRASS_ADDON_PATH ?"
+msgid "Directory '%s' is not defined in GRASS_ADDON_PATH. Do you want add this directory to GRASS_ADDON_PATH?"
+msgstr "Le dossier '%s' n'est pas définit dans GRASS_ADDON_PATH. Voulez-vous ajouter ce dossier à GRASS_ADDON_PATH ?"
#: ../gui/wxpython/lmgr/frame.py:892
msgid "Update Addons path?"
@@ -7854,7 +7492,7 @@
#: ../gui/wxpython/lmgr/frame.py:993
#, fuzzy
msgid "Changes current working directory for this GUI."
-msgstr "Modifier l'environnement de travail"
+msgstr "Modifier le dossier de travail pour cette Interface Graphique"
#: ../gui/wxpython/lmgr/frame.py:995
msgid "Usage: cd [directory]"
@@ -7865,12 +7503,8 @@
msgstr "Sans paramètre, ouvre une boiite de dialogue."
#: ../gui/wxpython/lmgr/frame.py:1000
-msgid ""
-"If ~ (tilde) is present as the first directory on the path, it is replaced "
-"by user's home directory."
-msgstr ""
-"Si ~ (tilde) est présent comme premier dossier du chemin, il sera remplacé "
-"par le dossier utilisateur."
+msgid "If ~ (tilde) is present as the first directory on the path, it is replaced by user's home directory."
+msgstr "Si ~ (tilde) est présent comme premier dossier du chemin, il sera remplacé par le dossier utilisateur."
#: ../gui/wxpython/lmgr/frame.py:1014
msgid "More than one parameter provided."
@@ -7910,12 +7544,8 @@
msgstr "Plateforme"
#: ../gui/wxpython/lmgr/frame.py:1160
-msgid ""
-"Current workspace is not empty. Do you want to store current settings to "
-"workspace file?"
-msgstr ""
-"L'espace de travail n'est pas vide. Voulez-vous enregistrer les paramètres "
-"actuels dans un fichier ?"
+msgid "Current workspace is not empty. Do you want to store current settings to workspace file?"
+msgstr "L'espace de travail n'est pas vide. Voulez-vous enregistrer les paramètres actuels dans un fichier ?"
#: ../gui/wxpython/lmgr/frame.py:1163
msgid "Create new workspace?"
@@ -7948,8 +7578,7 @@
#: ../gui/wxpython/lmgr/frame.py:1401 ../gui/wxpython/lmgr/frame.py:1417
#, python-format
msgid "Workspace file <%s> already exists. Do you want to overwrite this file?"
-msgstr ""
-"Le fichier d'environnement <%s> existe déjà. Voulez-vous écraser ce fichier ?"
+msgstr "Le fichier d'environnement <%s> existe déjà. Voulez-vous écraser ce fichier ?"
#: ../gui/wxpython/lmgr/frame.py:1403 ../gui/wxpython/lmgr/frame.py:1420
#: ../gui/wxpython/menustrings.py:10
@@ -7975,7 +7604,10 @@
"Unable to launch \"Supervised Classification Tool\".\n"
"\n"
"Reason: %s"
-msgstr "Impossible de charger les icônes d'un thème. Raison : %s"
+msgstr ""
+"Impossible de lancer l' « Outil de classification supervisée ».\n"
+"\n"
+"Raison: %s"
#: ../gui/wxpython/lmgr/frame.py:1614
#, fuzzy
@@ -7994,12 +7626,8 @@
msgstr "Type de couche <%s> non pris en charge"
#: ../gui/wxpython/lmgr/frame.py:2052
-msgid ""
-"Note that cell values can only be displayed for regions of less than 10,000 "
-"cells."
-msgstr ""
-"A noter que les valeurs des cellules ne peuvent être affichées que pour les "
-"régions de moins de 10 000 cellules."
+msgid "Note that cell values can only be displayed for regions of less than 10,000 cells."
+msgstr "A noter que les valeurs des cellules ne peuvent être affichées que pour les régions de moins de 10 000 cellules."
#: ../gui/wxpython/lmgr/frame.py:2126 ../gui/wxpython/lmgr/layertree.py:1643
msgid "opacity:"
@@ -8018,9 +7646,7 @@
#: ../gui/wxpython/lmgr/frame.py:2137
msgid "Do you want to remove selected map layer(s) from layer tree?"
-msgstr ""
-"Voulez-vous retirer la(les) carte(s) sélectionnée(s) de l'arborescence des "
-"couches ?"
+msgstr "Voulez-vous retirer la(les) carte(s) sélectionnée(s) de l'arborescence des couches ?"
#: ../gui/wxpython/lmgr/frame.py:2141
msgid "Remove map layer"
@@ -8035,32 +7661,20 @@
msgstr "Aucune ccouche sélectionnée. Opération annulée."
#: ../gui/wxpython/lmgr/frame.py:2247
-msgid ""
-"Display resolution is currently not constrained to computational settings. "
-"It's suggested to constrain map to region geometry. Do you want to constrain "
-"the resolution?"
-msgstr ""
-"La résolution de l'affichage n'est actuellement pas contrainte aux limite de "
-"la région de calculs. Il est suggéré de contraindre les cartes aux limites "
-"de la région. Voulez-vous contraindre la résolution ?"
+msgid "Display resolution is currently not constrained to computational settings. It's suggested to constrain map to region geometry. Do you want to constrain the resolution?"
+msgstr "La résolution de l'affichage n'est actuellement pas contrainte aux limite de la région de calculs. Il est suggéré de contraindre les cartes aux limites de la région. Voulez-vous contraindre la résolution ?"
#: ../gui/wxpython/lmgr/frame.py:2256
msgid "Constrain map to region geometry?"
msgstr "Restreindre la carte aux limites de la région ?"
#: ../gui/wxpython/lmgr/menudata.py:42
-msgid ""
-"Unable to parse user toolboxes XML files. Default main menu will be loaded."
-msgstr ""
-"Impossible d'analyser le fichier XML des outils utilisateur. Chargement du "
-"menu principal par défaut."
+msgid "Unable to parse user toolboxes XML files. Default main menu will be loaded."
+msgstr "Impossible d'analyser le fichier XML des outils utilisateur. Chargement du menu principal par défaut."
#: ../gui/wxpython/lmgr/menudata.py:64
-msgid ""
-"Unable to parse user toolboxes XML files. Default module tree will be loaded."
-msgstr ""
-"Impossible d'analyser le fichier XML des outils utilisateur. Chargement de "
-"l'arbre des modules par défaut."
+msgid "Unable to parse user toolboxes XML files. Default module tree will be loaded."
+msgstr "Impossible d'analyser le fichier XML des outils utilisateur. Chargement de l'arbre des modules par défaut."
#: ../gui/wxpython/lmgr/layertree.py:56 ../gui/wxpython/menustrings.py:32
#: ../gui/wxpython/menustrings.py:1009
@@ -8178,7 +7792,6 @@
msgstr "Ajouter une couche WMS."
#: ../gui/wxpython/lmgr/layertree.py:111
-#, fuzzy
msgid "Editing mode"
msgstr "Mode édition"
@@ -8205,8 +7818,7 @@
#: ../gui/wxpython/lmgr/layertree.py:463
msgid "Set computational region from selected map(s)"
-msgstr ""
-"Définir la région calculée à partir de la(des) carte(s) sélectionnée(s)"
+msgstr "Définir la région calculée à partir de la(des) carte(s) sélectionnée(s)"
#: ../gui/wxpython/lmgr/layertree.py:477
msgid "Export common formats"
@@ -8278,13 +7890,8 @@
#: ../gui/wxpython/lmgr/layertree.py:786
#, python-format
-msgid ""
-"Name <%(name)s> is not a valid name for GRASS map. Please use only ASCII "
-"characters excluding %(chars)s and space."
-msgstr ""
-"Le nom <%(name)s> n'est pas un nom valide pour une carte GRASS. Merci de "
-"n'utiliser que des caractères ASCII à l'exclusion de %(chars)s et des "
-"espaces."
+msgid "Name <%(name)s> is not a valid name for GRASS map. Please use only ASCII characters excluding %(chars)s and space."
+msgstr "Le nom <%(name)s> n'est pas un nom valide pour une carte GRASS. Merci de n'utiliser que des caractères ASCII à l'exclusion de %(chars)s et des espaces."
#: ../gui/wxpython/lmgr/layertree.py:808 ../gui/wxpython/nviz/tools.py:1532
msgid "3D raster map"
@@ -8296,9 +7903,9 @@
#: ../gui/wxpython/lmgr/layertree.py:815
-#, fuzzy, python-format
+#, python-format
msgid "Enter name for the new %s in the current mapset:"
-msgstr "Entrer le nom du nouveau jeu de cartes :"
+msgstr "Entrer le nom pour le nouveau %s dans le jeux de cartes courant :"
#: ../gui/wxpython/lmgr/layertree.py:816
#, python-format
@@ -8307,10 +7914,8 @@
#: ../gui/wxpython/lmgr/layertree.py:830
#, python-format
-msgid ""
-"%s <%s> already exists in the current mapset. Do you want to overwrite it?"
-msgstr ""
-"%s <%s> existe déjà dans le jeu de cartes courant. Voulez-vous l'écraser ?"
+msgid "%s <%s> already exists in the current mapset. Do you want to overwrite it?"
+msgstr "%s <%s> existe déjà dans le jeu de cartes courant. Voulez-vous l'écraser ?"
#: ../gui/wxpython/lmgr/layertree.py:833
#: ../gui/wxpython/gui_core/dialogs.py:423
@@ -8325,15 +7930,11 @@
#: ../gui/wxpython/lmgr/layertree.py:847
#, python-format
msgid "Unable to make copy of <%s>. Mapset <%s> is not current mapset."
-msgstr ""
-"Impossible de faire une copie de <%s>. Le jeu de cartes <%s> n'est pas le "
-"jeu de cartes courant."
+msgstr "Impossible de faire une copie de <%s>. Le jeu de cartes <%s> n'est pas le jeu de cartes courant."
#: ../gui/wxpython/lmgr/layertree.py:864
msgid "Unable to display histogram of raster map. No map name defined."
-msgstr ""
-"Impossible d'afficher l'histogramme de carte raster. Pas de nom de carte "
-"définit."
+msgstr "Impossible d'afficher l'histogramme de carte raster. Pas de nom de carte définit."
#: ../gui/wxpython/lmgr/layertree.py:965
#: ../gui/wxpython/gui_core/simplelmgr.py:270
@@ -8409,8 +8010,7 @@
#: ../gui/wxpython/lmgr/toolbars.py:95
msgid "Remove selected map layer(s) from layer tree"
-msgstr ""
-"Supprimer la(les) carte(s) sélectionnée(s) de l'arborescence des couches"
+msgstr "Supprimer la(les) carte(s) sélectionnée(s) de l'arborescence des couches"
#: ../gui/wxpython/lmgr/toolbars.py:136
msgid "Import/link raster or vector data"
@@ -8434,7 +8034,6 @@
msgstr "Composeur de cartes"
#: ../gui/wxpython/lmgr/toolbars.py:146
-#, fuzzy
msgid "Launch user-defined script"
msgstr "Lancer un script"
@@ -8452,8 +8051,7 @@
#: ../gui/wxpython/lmgr/toolbars.py:208
msgid "Show attribute data for selected vector map"
-msgstr ""
-"Montrer les données attributaires pour la carte vectorielle sélectionnée"
+msgstr "Montrer les données attributaires pour la carte vectorielle sélectionnée"
#: ../gui/wxpython/lmgr/toolbars.py:237
msgid "Generate command for m.nviz.image"
@@ -8476,16 +8074,8 @@
msgstr "Afficher le manuel de la vue 3D"
#: ../gui/wxpython/wxplot/profile.py:34 ../gui/wxpython/nviz/wxnviz.py:32
-msgid ""
-"This module requires the NumPy module, which could not be imported. It "
-"probably is not installed (it's not part of the standard Python "
-"distribution). See the Numeric Python site (http://numpy.scipy.org) for "
-"information on downloading source or binaries."
-msgstr ""
-"Ce module requiert le module NumPy, qui n'a pas pu être importé. Il n'est "
-"probablement pas installé (ne fait pas partie de la distribution standard "
-"Python). Voir le site Numeric Python (http://numpy.scipy.org) pour "
-"télécharger les binaires ou le code source."
+msgid "This module requires the NumPy module, which could not be imported. It probably is not installed (it's not part of the standard Python distribution). See the Numeric Python site (http://numpy.scipy.org) for information on downloading source or binaries."
+msgstr "Ce module requiert le module NumPy, qui n'a pas pu être importé. Il n'est probablement pas installé (ne fait pas partie de la distribution standard Python). Voir le site Numeric Python (http://numpy.scipy.org) pour télécharger les binaires ou le code source."
#: ../gui/wxpython/wxplot/profile.py:61
msgid "GRASS Profile Analysis Tool"
@@ -8526,8 +8116,7 @@
#: ../gui/wxpython/wxplot/profile.py:342
msgid "Choose prefix for file(s) where to save profile values..."
-msgstr ""
-"Choisir le préfixe des fichiers où enregistrer les valeurs du profil ..."
+msgstr "Choisir le préfixe des fichiers où enregistrer les valeurs du profil ..."
#: ../gui/wxpython/wxplot/profile.py:344
msgid "Comma separated value (*.csv)|*.csv"
@@ -8804,9 +8393,7 @@
#: ../gui/wxpython/wxplot/dialogs.py:687
#: ../gui/wxpython/wxplot/dialogs.py:1135
msgid "Apply changes for the current session and close dialog"
-msgstr ""
-"Appliquer les changements pour la session courante et fermer la boite de "
-"dialogue"
+msgstr "Appliquer les changements pour la session courante et fermer la boite de dialogue"
#: ../gui/wxpython/wxplot/dialogs.py:743
#, python-format
@@ -8854,11 +8441,8 @@
msgstr "Échelle"
#: ../gui/wxpython/wxplot/dialogs.py:1033
-msgid ""
-"Automatic axis scaling, custom max and min, or scale matches data range (min)"
-msgstr ""
-"Échelle de l'axe automatique, min et max personnalisés, ou échelle "
-"correspondant à la plage de données (min)"
+msgid "Automatic axis scaling, custom max and min, or scale matches data range (min)"
+msgstr "Échelle de l'axe automatique, min et max personnalisés, ou échelle correspondant à la plage de données (min)"
#: ../gui/wxpython/wxplot/dialogs.py:1038
msgid "Custom min"
@@ -9011,12 +8595,8 @@
msgstr "Importation et maillage de points ASCII x,y,z"
#: ../gui/wxpython/menustrings.py:36 ../gui/wxpython/menustrings.py:1013
-msgid ""
-"Creates a raster map from an assemblage of many coordinates using univariate "
-"statistics."
-msgstr ""
-"Créer une carte raster à partir de l'assemblage d'un lot de coordonnées en "
-"utilisant des statistiques univariées."
+msgid "Creates a raster map from an assemblage of many coordinates using univariate statistics."
+msgstr "Créer une carte raster à partir de l'assemblage d'un lot de coordonnées en utilisant des statistiques univariées."
#: ../gui/wxpython/menustrings.py:37 ../gui/wxpython/menustrings.py:1014
msgid "ASCII grid import"
@@ -9048,8 +8628,7 @@
#: ../gui/wxpython/menustrings.py:44 ../gui/wxpython/menustrings.py:1021
msgid "Imports GRIDATB.FOR map file (TOPMODEL) into a GRASS raster map."
-msgstr ""
-"Importer un fichier carte GRIDATB.FOR (TOPMODEL) vers une carte raster GRASS."
+msgstr "Importer un fichier carte GRIDATB.FOR (TOPMODEL) vers une carte raster GRASS."
#: ../gui/wxpython/menustrings.py:45 ../gui/wxpython/menustrings.py:1022
msgid "Matlab 2D array import"
@@ -9088,12 +8667,8 @@
msgstr "Importer un Terra ASTER HDF"
#: ../gui/wxpython/menustrings.py:54 ../gui/wxpython/menustrings.py:1031
-msgid ""
-"Georeference, rectify, and import Terra-ASTER imagery and relative DEMs "
-"using gdalwarp."
-msgstr ""
-"Géoréférencer, rectifier et importer une image Terra-ASTER et ses MNT "
-"associés avec gdalwarp."
+msgid "Georeference, rectify, and import Terra-ASTER imagery and relative DEMs using gdalwarp."
+msgstr "Géoréférencer, rectifier et importer une image Terra-ASTER et ses MNT associés avec gdalwarp."
#: ../gui/wxpython/menustrings.py:55 ../gui/wxpython/menustrings.py:77
#: ../gui/wxpython/menustrings.py:1032 ../gui/wxpython/menustrings.py:1054
@@ -9102,8 +8677,7 @@
#: ../gui/wxpython/menustrings.py:57 ../gui/wxpython/menustrings.py:1034
#, fuzzy
-msgid ""
-"Imports a raster map as GRASS GIS specific archive file (packed with r.pack)"
+msgid "Imports a raster map as GRASS GIS specific archive file (packed with r.pack)"
msgstr "Importer des données vectorielles"
#: ../gui/wxpython/menustrings.py:58 ../gui/wxpython/menustrings.py:274
@@ -9114,8 +8688,7 @@
#: ../gui/wxpython/menustrings.py:59 ../gui/wxpython/menustrings.py:275
#: ../gui/wxpython/menustrings.py:1036 ../gui/wxpython/menustrings.py:1174
msgid "Re-projects a raster map from given location to the current location."
-msgstr ""
-"Reprojeter une carte raster depuis un secteur donné vers le secteur courant."
+msgstr "Reprojeter une carte raster depuis un secteur donné vers le secteur courant."
#: ../gui/wxpython/menustrings.py:61 ../gui/wxpython/menustrings.py:90
#: ../gui/wxpython/menustrings.py:1038 ../gui/wxpython/menustrings.py:1067
@@ -9132,9 +8705,7 @@
#: ../gui/wxpython/menustrings.py:64 ../gui/wxpython/menustrings.py:1041
msgid "Creates a vector map from an ASCII points file or ASCII vector file."
-msgstr ""
-"Créer une carte vecteur depuis un fichier de points ASCII ou un fichier "
-"vecteur ASCII."
+msgstr "Créer une carte vecteur depuis un fichier de points ASCII ou un fichier vecteur ASCII."
#: ../gui/wxpython/menustrings.py:65 ../gui/wxpython/menustrings.py:1042
msgid "ASCII points as a vector lines"
@@ -9186,8 +8757,7 @@
#: ../gui/wxpython/menustrings.py:79 ../gui/wxpython/menustrings.py:1056
#, fuzzy
-msgid ""
-"Imports a vector map as GRASS GIS specific archive file (packed with v.pack)"
+msgid "Imports a vector map as GRASS GIS specific archive file (packed with v.pack)"
#: ../gui/wxpython/menustrings.py:80 ../gui/wxpython/menustrings.py:554
@@ -9198,8 +8768,7 @@
#: ../gui/wxpython/menustrings.py:81 ../gui/wxpython/menustrings.py:555
#: ../gui/wxpython/menustrings.py:1058 ../gui/wxpython/menustrings.py:1454
msgid "Re-projects a vector map from one location to the current location."
-msgstr ""
-"Re-projette une carte vecteur depuis un secteur dans le secteur courant."
+msgstr "Re-projette une carte vecteur depuis un secteur dans le secteur courant."
#: ../gui/wxpython/menustrings.py:82 ../gui/wxpython/menustrings.py:1059
msgid "Import 3D raster data"
@@ -9264,11 +8833,8 @@
msgstr "Export en points ASCII x,y,z"
#: ../gui/wxpython/menustrings.py:98 ../gui/wxpython/menustrings.py:1075
-msgid ""
-"Exports a raster map to a text file as x,y,z values based on cell centers."
-msgstr ""
-"Exporter une carte raster vers un fichier texte de valeurs x,y,z basées sur "
-"le centre des cellules."
+msgid "Exports a raster map to a text file as x,y,z values based on cell centers."
+msgstr "Exporter une carte raster vers un fichier texte de valeurs x,y,z basées sur le centre des cellules."
#: ../gui/wxpython/menustrings.py:99 ../gui/wxpython/menustrings.py:1076
msgid "GRIDATB.FOR export"
@@ -9341,9 +8907,7 @@
#: ../gui/wxpython/menustrings.py:116 ../gui/wxpython/menustrings.py:1093
msgid "Exports a raster map to the Virtual Reality Modeling Language (VRML)."
-msgstr ""
-"Exporter une carte raster vers le Langage de Modélisaiton de Réalité "
-"Virtuelle (VRML)."
+msgstr "Exporter une carte raster vers le Langage de Modélisaiton de Réalité Virtuelle (VRML)."
#: ../gui/wxpython/menustrings.py:117 ../gui/wxpython/menustrings.py:134
#: ../gui/wxpython/menustrings.py:145 ../gui/wxpython/menustrings.py:1094
@@ -9369,26 +8933,16 @@
msgstr "Exporter une carte vecteur"
#: ../gui/wxpython/menustrings.py:123 ../gui/wxpython/menustrings.py:1100
-msgid ""
-"Exports a vector map layer to any of the supported OGR vector formats. By "
-"default a vector map layer is exported to Esri Shapefile format."
-msgstr ""
-"Exporter une couche vecteur vers n'importe lequel des formats vecteurs "
-"supportés par OGR. Par défaut une couche vecteur est exportée vers le format "
-"ESRI Shape."
+msgid "Exports a vector map layer to any of the supported OGR vector formats. By default a vector map layer is exported to Esri Shapefile format."
+msgstr "Exporter une couche vecteur vers n'importe lequel des formats vecteurs supportés par OGR. Par défaut une couche vecteur est exportée vers le format ESRI Shape."
#: ../gui/wxpython/menustrings.py:124 ../gui/wxpython/menustrings.py:1101
msgid "ASCII points or GRASS ASCII vector export"
msgstr "Exporter des points ASCII ou vecteurs ASCII GRASS"
#: ../gui/wxpython/menustrings.py:125 ../gui/wxpython/menustrings.py:1102
-msgid ""
-"Exports a vector map to a GRASS ASCII vector representation. By default only "
-"features with category are exported. To export all features use 'layer=-1'."
-msgstr ""
-"Exporter une carte vecteur vers un vecteur ASCII GRASS. Par défaut seules "
-"les entités avec une catégorie sont exportés. Utiliser 'layer=-1' pour "
-"exporter toutes les entités."
+msgid "Exports a vector map to a GRASS ASCII vector representation. By default only features with category are exported. To export all features use 'layer=-1'."
+msgstr "Exporter une carte vecteur vers un vecteur ASCII GRASS. Par défaut seules les entités avec une catégorie sont exportés. Utiliser 'layer=-1' pour exporter toutes les entités."
#: ../gui/wxpython/menustrings.py:126 ../gui/wxpython/menustrings.py:1103
msgid "DXF export"
@@ -9477,14 +9031,11 @@
#: ../gui/wxpython/menustrings.py:152 ../gui/wxpython/menustrings.py:1129
msgid "Link GDAL supported raster data as a pseudo GRASS raster map layer."
-msgstr ""
-"Lier des données prises en charge par GDAL en tant que pseudocarte raster."
+msgstr "Lier des données prises en charge par GDAL en tant que pseudocarte raster."
#: ../gui/wxpython/menustrings.py:154 ../gui/wxpython/menustrings.py:1131
msgid "Creates a new pseudo-vector map as a link to an OGR-supported layer."
-msgstr ""
-"Crée une nouvelle pseudo carte vecteur comme lien vers une couche prise en "
-"charge par OGR."
+msgstr "Crée une nouvelle pseudo carte vecteur comme lien vers une couche prise en charge par OGR."
#: ../gui/wxpython/menustrings.py:155 ../gui/wxpython/menustrings.py:1132
msgid "Output format for raster data"
@@ -9511,12 +9062,8 @@
msgstr "Copier"
#: ../gui/wxpython/menustrings.py:161 ../gui/wxpython/menustrings.py:1138
-msgid ""
-"Copies available data files in the current mapset search path to the user's "
-"current mapset."
-msgstr ""
-"Copier les fichiers de données disponibles dans le chemin de recherche du "
-"jeu de cartes courant vers le jeu de cartes de l'utilisateur courant."
+msgid "Copies available data files in the current mapset search path to the user's current mapset."
+msgstr "Copier les fichiers de données disponibles dans le chemin de recherche du jeu de cartes courant vers le jeu de cartes de l'utilisateur courant."
#: ../gui/wxpython/menustrings.py:162 ../gui/wxpython/menustrings.py:921
#: ../gui/wxpython/menustrings.py:1139 ../gui/wxpython/menustrings.py:1820
@@ -9524,27 +9071,17 @@
msgstr "Liste"
#: ../gui/wxpython/menustrings.py:163 ../gui/wxpython/menustrings.py:1140
-msgid ""
-"Lists available GRASS data base files of the user-specified data type "
-"optionally using the search pattern."
-msgstr ""
-"Lister les fichiers de base de données GRASS disponibles du type spécifié "
-"par l'utilisateur en utilisant un modèle de recherche."
+msgid "Lists available GRASS data base files of the user-specified data type optionally using the search pattern."
+msgstr "Lister les fichiers de base de données GRASS disponibles du type spécifié par l'utilisateur en utilisant un modèle de recherche."
#: ../gui/wxpython/menustrings.py:165 ../gui/wxpython/menustrings.py:1142
msgid "Renames data base element files in the user's current mapset."
-msgstr ""
-"Renommer les fichiers éléments de la base de données dans le jeu de données "
-"courant de l'utilisateur"
+msgstr "Renommer les fichiers éléments de la base de données dans le jeu de données courant de l'utilisateur"
#: ../gui/wxpython/menustrings.py:167 ../gui/wxpython/menustrings.py:1144
#, fuzzy
-msgid ""
-"Removes data base element files from the user's current mapset using the "
-"search pattern."
-msgstr ""
-"Supprimer les fichiers éléments de base de données du jeu de données courant "
-"de l'utilisateur"
+msgid "Removes data base element files from the user's current mapset using the search pattern."
+msgstr "Supprimer les fichiers éléments de base de données du jeu de données courant de l'utilisateur"
#: ../gui/wxpython/menustrings.py:168 ../gui/wxpython/menustrings.py:298
#: ../gui/wxpython/menustrings.py:592 ../gui/wxpython/menustrings.py:824
@@ -9571,8 +9108,7 @@
#: ../gui/wxpython/menustrings.py:172 ../gui/wxpython/menustrings.py:302
#: ../gui/wxpython/menustrings.py:1201
msgid "Converts 2D raster map slices to one 3D raster volume map."
-msgstr ""
-"Convertir des tranches de cartes raster 2D en une carte volumique raster 3D. "
+msgstr "Convertir des tranches de cartes raster 2D en une carte volumique raster 3D. "
#: ../gui/wxpython/menustrings.py:173 ../gui/wxpython/menustrings.py:303
#: ../gui/wxpython/menustrings.py:1202
@@ -9582,8 +9118,7 @@
#: ../gui/wxpython/menustrings.py:174 ../gui/wxpython/menustrings.py:304
#: ../gui/wxpython/menustrings.py:1203
msgid "Creates a 3D volume map based on 2D elevation and value raster maps."
-msgstr ""
-"Crée un volume 3D à partir de cartes raster 2D d'altitude et de valeurs."
+msgstr "Crée un volume 3D à partir de cartes raster 2D d'altitude et de valeurs."
#: ../gui/wxpython/menustrings.py:175 ../gui/wxpython/menustrings.py:593
#: ../gui/wxpython/menustrings.py:1492
@@ -9653,12 +9188,8 @@
msgstr "Rendu d'image 3D"
#: ../gui/wxpython/menustrings.py:190
-msgid ""
-"Creates a 3D rendering of GIS data. Renders surfaces (raster data), 2D/3D "
-"vector data, and volumes (3D raster data) in 3D."
-msgstr ""
-"Créer un rendu 3D. Rendu des surfaces (raster), des vecteurs 2D/3D, et des "
-"volumes (raster 3D) en 3D."
+msgid "Creates a 3D rendering of GIS data. Renders surfaces (raster data), 2D/3D vector data, and volumes (3D raster data) in 3D."
+msgstr "Créer un rendu 3D. Rendu des surfaces (raster), des vecteurs 2D/3D, et des volumes (raster 3D) en 3D."
#: ../gui/wxpython/menustrings.py:191 ../gui/wxpython/menustrings.py:993
#: ../gui/wxpython/menustrings.py:1892 ../gui/wxpython/menustrings.py:1897
@@ -9675,13 +9206,8 @@
msgstr "Gisement/distance vers coordonnées"
#: ../gui/wxpython/menustrings.py:194
-msgid ""
-"A simple utility for converting bearing and distance measurements to "
-"coordinates and vice versa. It assumes a cartesian coordinate system"
-msgstr ""
-"Un utilitaire simple pour convertir des mesures de gisements et distances "
-"vers des coordonnées et vice-versa. Présume un système de coordonnées "
-"cartésien"
+msgid "A simple utility for converting bearing and distance measurements to coordinates and vice versa. It assumes a cartesian coordinate system"
+msgstr "Un utilitaire simple pour convertir des mesures de gisements et distances vers des coordonnées et vice-versa. Présume un système de coordonnées cartésien"
#: ../gui/wxpython/menustrings.py:196 ../gui/wxpython/menustrings.py:1909
msgid "Launch Cartographic Composer"
@@ -9743,32 +9269,23 @@
#: ../gui/wxpython/menustrings.py:211
msgid "Set/unset access to other mapsets in current location"
-msgstr ""
-"Active/désactive l'accès aux autres jeux de données dans le secteur courant"
+msgstr "Active/désactive l'accès aux autres jeux de données dans le secteur courant"
#: ../gui/wxpython/menustrings.py:212
msgid "User access"
msgstr "Permissions utilisateur"
#: ../gui/wxpython/menustrings.py:213
-msgid ""
-"Controls access to the current mapset for other users on the system. If no "
-"option given, prints current status."
-msgstr ""
-"Contrôle l'accès au jeu de cartes courant pour les autres utilisateurs du "
-"système. Si aucune option n'ets données, affiche l'état actuel."
+msgid "Controls access to the current mapset for other users on the system. If no option given, prints current status."
+msgstr "Contrôle l'accès au jeu de cartes courant pour les autres utilisateurs du système. Si aucune option n'ets données, affiche l'état actuel."
#: ../gui/wxpython/menustrings.py:214
msgid "Change working environment"
#: ../gui/wxpython/menustrings.py:215
-msgid ""
-"Changes/reports current mapset. Optionally create new mapset or list "
-"available mapsets in given location."
-msgstr ""
-"Modifie/affiche le jeu de cartes courant. En option, créé un nouveau jeu de "
-"cartes ou list les jeux de cartes disponibles dans le secteur choisi."
+msgid "Changes/reports current mapset. Optionally create new mapset or list available mapsets in given location."
+msgstr "Modifie/affiche le jeu de cartes courant. En option, créé un nouveau jeu de cartes ou list les jeux de cartes disponibles dans le secteur choisi."
#: ../gui/wxpython/menustrings.py:216
msgid "Change location and mapset"
@@ -9796,22 +9313,15 @@
#: ../gui/wxpython/menustrings.py:223
msgid "Outputs and modifies the user's current GRASS variable settings."
-msgstr ""
-"Affiche et modifie les paramètres de variables GRASS de l'utilisateur "
-"courant."
+msgstr "Affiche et modifie les paramètres de variables GRASS de l'utilisateur courant."
#: ../gui/wxpython/menustrings.py:224
msgid "Change settings"
msgstr "Modifier les paramètres"
#: ../gui/wxpython/menustrings.py:225
-msgid ""
-"Outputs and modifies the user's current GRASS variable settings. Prints all "
-"defined GRASS variables if no option is given."
-msgstr ""
-"Affiche et modifie les paramètres des variables GRASS de l'utilisateur "
-"courant. Affiche toutes les variables GRASS définies si aucune option n'est "
-"définie."
+msgid "Outputs and modifies the user's current GRASS variable settings. Prints all defined GRASS variables if no option is given."
+msgstr "Affiche et modifie les paramètres des variables GRASS de l'utilisateur courant. Affiche toutes les variables GRASS définies si aucune option n'est définie."
#: ../gui/wxpython/menustrings.py:226
msgid "Create new location"
@@ -9823,9 +9333,7 @@
#: ../gui/wxpython/menustrings.py:229
msgid "Creates new mapset in the current location, changes current mapset."
-msgstr ""
-"Crée un nouveau jeux de cartes dans le secteur de travail courant, et change "
-"le jeux de cartes courant."
+msgstr "Crée un nouveau jeux de cartes dans le secteur de travail courant, et change le jeux de cartes courant."
#: ../gui/wxpython/menustrings.py:230
msgid "Version and copyright"
@@ -9844,26 +9352,16 @@
msgstr "Affiche la projection de la carte"
#: ../gui/wxpython/menustrings.py:234
-msgid ""
-"Converts co-ordinate system descriptions (i.e. projection information) "
-"between various formats (including GRASS format)."
-msgstr ""
-"Convertit les descriptions de systèmes de coordonnées (c.-à-d. les "
-"informations de projection) entre divers formats (dont le format GRASS)."
+msgid "Converts co-ordinate system descriptions (i.e. projection information) between various formats (including GRASS format)."
+msgstr "Convertit les descriptions de systèmes de coordonnées (c.-à-d. les informations de projection) entre divers formats (dont le format GRASS)."
#: ../gui/wxpython/menustrings.py:235
msgid "Manage projections"
msgstr "Gérer les projections"
#: ../gui/wxpython/menustrings.py:236
-msgid ""
-"Prints or modifies GRASS projection information files (in various co-"
-"ordinate system descriptions). Can also be used to create new GRASS "
-"locations."
-msgstr ""
-"Affiche ou modifie les fichiers de projection de GRASS (dans divers systèmes "
-"de coordonnées). Peut aussi être utilisé pour créer de nouveaux secteurs "
-"GRASS."
+msgid "Prints or modifies GRASS projection information files (in various co-ordinate system descriptions). Can also be used to create new GRASS locations."
+msgstr "Affiche ou modifie les fichiers de projection de GRASS (dans divers systèmes de coordonnées). Peut aussi être utilisé pour créer de nouveaux secteurs GRASS."
#: ../gui/wxpython/menustrings.py:237
msgid "Convert coordinates"
@@ -9872,8 +9370,7 @@
# L'usage en traduction française semble être de conserver les anglicismes frontend et backend
#: ../gui/wxpython/menustrings.py:238
msgid "Converts coordinates from one projection to another (cs2cs frontend)."
-msgstr ""
-"Convertir les coordonnées d'une projection à une autre (frontend cs2cs)."
+msgstr "Convertir les coordonnées d'une projection à une autre (frontend cs2cs)."
#: ../gui/wxpython/menustrings.py:239
msgid "Addons extensions"
@@ -9901,8 +9398,7 @@
#: ../gui/wxpython/menustrings.py:245
msgid "User GUI preferences (display font, commands, digitizer, etc.)"
-msgstr ""
-"Préférences utilisateur GUI (police d'affichage, commandes, numériseur, etc.)"
+msgstr "Préférences utilisateur GUI (police d'affichage, commandes, numériseur, etc.)"
#: ../gui/wxpython/menustrings.py:246 ../gui/wxpython/menustrings.py:1145
msgid "&Raster"
@@ -9942,8 +9438,7 @@
#: ../gui/wxpython/menustrings.py:255 ../gui/wxpython/menustrings.py:1154
msgid "Produces the quantization file for a floating-point map."
-msgstr ""
-"Produit le fichier de quantification pour une carte en virgule flottante."
+msgstr "Produit le fichier de quantification pour une carte en virgule flottante."
#: ../gui/wxpython/menustrings.py:256 ../gui/wxpython/menustrings.py:1155
msgid "Timestamp"
@@ -9951,9 +9446,7 @@
#: ../gui/wxpython/menustrings.py:257 ../gui/wxpython/menustrings.py:1156
#, fuzzy
-msgid ""
-"Modifies a timestamp for a raster map. Print/add/remove a timestamp for a "
-"raster map."
+msgid "Modifies a timestamp for a raster map. Print/add/remove a timestamp for a raster map."
msgstr "Afficher/ajouter/supprimer une date/heure d'une carte raster 3D"
#: ../gui/wxpython/menustrings.py:258 ../gui/wxpython/menustrings.py:1157
@@ -9962,9 +9455,7 @@
#: ../gui/wxpython/menustrings.py:259 ../gui/wxpython/menustrings.py:1158
msgid "Resamples raster map layers to a coarser grid using aggregation."
-msgstr ""
-"Ré-échantillonner une carte raster avec un maillage plus grossier en "
-"procédant par agrégation."
+msgstr "Ré-échantillonner une carte raster avec un maillage plus grossier en procédant par agrégation."
#: ../gui/wxpython/menustrings.py:260 ../gui/wxpython/menustrings.py:1159
msgid "Resample using multiple methods"
@@ -9972,9 +9463,7 @@
#: ../gui/wxpython/menustrings.py:261 ../gui/wxpython/menustrings.py:1160
msgid "Resamples raster map to a finer grid using interpolation."
-msgstr ""
-"Ré-échantillonner une carte raster vers un maillage plus fin par "
-"interpolation."
+msgstr "Ré-échantillonner une carte raster vers un maillage plus fin par interpolation."
#: ../gui/wxpython/menustrings.py:262 ../gui/wxpython/menustrings.py:1161
msgid "Resample using nearest neighbor"
@@ -9989,25 +9478,16 @@
msgstr "Ré-échantillonner par les splines avec tension"
#: ../gui/wxpython/menustrings.py:265 ../gui/wxpython/menustrings.py:1164
-msgid ""
-"Reinterpolates and optionally computes topographic analysis from input "
-"raster map to a new raster map (possibly with different resolution) using "
-"regularized spline with tension and smoothing."
-msgstr ""
-"Ré-interpole et en option calcule une analyse topographique d'une carte "
-"raster (éventuellement à une résolution différente) en utilisant les splines "
-"régulées avec tension et lissage."
+msgid "Reinterpolates and optionally computes topographic analysis from input raster map to a new raster map (possibly with different resolution) using regularized spline with tension and smoothing."
+msgstr "Ré-interpole et en option calcule une analyse topographique d'une carte raster (éventuellement à une résolution différente) en utilisant les splines régulées avec tension et lissage."
#: ../gui/wxpython/menustrings.py:266 ../gui/wxpython/menustrings.py:1165
msgid "Resample using bspline"
msgstr "Rééchantillonner par les bsplines"
#: ../gui/wxpython/menustrings.py:267 ../gui/wxpython/menustrings.py:1166
-msgid ""
-"Performs bilinear or bicubic spline interpolation with Tykhonov "
-"regularization."
-msgstr ""
-"Interpolation spline bilinéaire ou bicubique avec régularisation de Tykhonov."
+msgid "Performs bilinear or bicubic spline interpolation with Tykhonov regularization."
+msgstr "Interpolation spline bilinéaire ou bicubique avec régularisation de Tykhonov."
#: ../gui/wxpython/menustrings.py:268 ../gui/wxpython/menustrings.py:1167
#, fuzzy
@@ -10028,9 +9508,7 @@
# Pour désigner les support files, je propose la traduction fichiers de maintenance. Guère d'autre idée pour englober à la fois la dimension historique du fichier, méta-infos, lien vers un éventuel autre raster...
#: ../gui/wxpython/menustrings.py:271 ../gui/wxpython/menustrings.py:1170
msgid "Allows creation and/or modification of raster map layer support files."
-msgstr ""
-"Permet la création et/ou la modification de fichiers de maintenance de "
-"cartes raster."
+msgstr "Permet la création et/ou la modification de fichiers de maintenance de cartes raster."
#: ../gui/wxpython/menustrings.py:272 ../gui/wxpython/menustrings.py:1171
msgid "Update map statistics"
@@ -10045,12 +9523,8 @@
msgstr "Mosaïquer"
#: ../gui/wxpython/menustrings.py:277 ../gui/wxpython/menustrings.py:1176
-msgid ""
-"Produces tilings of the source projection for use in the destination region "
-"and projection."
-msgstr ""
-"Produit une mosaïque de la projection source pour utilisation dans la région "
-"et projection de destination."
+msgid "Produces tilings of the source projection for use in the destination region and projection."
+msgstr "Produit une mosaïque de la projection source pour utilisation dans la région et projection de destination."
#: ../gui/wxpython/menustrings.py:278 ../gui/wxpython/menustrings.py:575
#: ../gui/wxpython/menustrings.py:1177 ../gui/wxpython/menustrings.py:1474
@@ -10072,9 +9546,7 @@
#: ../gui/wxpython/menustrings.py:282 ../gui/wxpython/menustrings.py:1181
msgid "Sets color rules based on stddev from a raster map's mean value."
-msgstr ""
-"Définir les règles de couleurs basées sur l'écart-type depuis la moyenne des "
-"valeurs d'une carte raster."
+msgstr "Définir les règles de couleurs basées sur l'écart-type depuis la moyenne des valeurs d'une carte raster."
#: ../gui/wxpython/menustrings.py:283 ../gui/wxpython/menustrings.py:578
#: ../gui/wxpython/menustrings.py:1182 ../gui/wxpython/menustrings.py:1477
@@ -10100,19 +9572,15 @@
#: ../gui/wxpython/menustrings.py:288 ../gui/wxpython/menustrings.py:1187
msgid "Blends color components of two raster maps by a given ratio."
-msgstr ""
-"Mélange les composantes de couleur de deux cartes raster d'un ratio donné."
+msgstr "Mélange les composantes de couleur de deux cartes raster d'un ratio donné."
#: ../gui/wxpython/menustrings.py:289 ../gui/wxpython/menustrings.py:1188
msgid "Create RGB"
msgstr "Créer RVB"
#: ../gui/wxpython/menustrings.py:290 ../gui/wxpython/menustrings.py:1189
-msgid ""
-"Combines red, green and blue raster maps into a single composite raster map."
-msgstr ""
-"Combine des cartes raster rouge, vert et bleu en une unique carte raster "
-"composite."
+msgid "Combines red, green and blue raster maps into a single composite raster map."
+msgstr "Combine des cartes raster rouge, vert et bleu en une unique carte raster composite."
#: ../gui/wxpython/menustrings.py:291 ../gui/wxpython/menustrings.py:731
#: ../gui/wxpython/menustrings.py:1190 ../gui/wxpython/menustrings.py:1630
@@ -10120,14 +9588,8 @@
msgstr "RVB vers TSV"
#: ../gui/wxpython/menustrings.py:292 ../gui/wxpython/menustrings.py:1191
-msgid ""
-"Generates red, green and blue (RGB) raster map layers combining hue, "
-"intensity and saturation (HIS) values from user-specified input raster map "
-"layers."
-msgstr ""
-"Génère des couches raster rouge, vert et bleu (RVB) en combinant des valeurs "
-"de teinte, saturation, valeur (TSV) depuis des cartes raster indiquées par "
-"l'utilisateur."
+msgid "Generates red, green and blue (RGB) raster map layers combining hue, intensity and saturation (HIS) values from user-specified input raster map layers."
+msgstr "Génère des couches raster rouge, vert et bleu (RVB) en combinant des valeurs de teinte, saturation, valeur (TSV) depuis des cartes raster indiquées par l'utilisateur."
#: ../gui/wxpython/menustrings.py:293 ../gui/wxpython/menustrings.py:1192
msgid "Query raster maps"
@@ -10139,8 +9601,7 @@
#: ../gui/wxpython/menustrings.py:295 ../gui/wxpython/menustrings.py:1194
msgid "Queries raster maps on their category values and category labels."
-msgstr ""
-"Interroger des cartes raster sur les valeurs et étiquettes de catégories."
+msgstr "Interroger des cartes raster sur les valeurs et étiquettes de catégories."
#: ../gui/wxpython/menustrings.py:296 ../gui/wxpython/menustrings.py:1195
msgid "Query colors by value"
@@ -10159,12 +9620,8 @@
msgstr "Zone tampon raster"
#: ../gui/wxpython/menustrings.py:307 ../gui/wxpython/menustrings.py:1206
-msgid ""
-"Creates a raster map showing buffer zones surrounding cells that contain non-"
-"NULL category values."
-msgstr ""
-"Créer une carte raster qui affiche des zones tampon autour des cellules qui "
-"contiennent des valeurs de catégorie non-NULL."
+msgid "Creates a raster map showing buffer zones surrounding cells that contain non-NULL category values."
+msgstr "Créer une carte raster qui affiche des zones tampon autour des cellules qui contiennent des valeurs de catégorie non-NULL."
#: ../gui/wxpython/menustrings.py:308 ../gui/wxpython/menustrings.py:1207
msgid "Concentric circles"
@@ -10172,9 +9629,7 @@
#: ../gui/wxpython/menustrings.py:309 ../gui/wxpython/menustrings.py:1208
msgid "Creates a raster map containing concentric rings around a given point."
-msgstr ""
-"Crée une carte raster contenant des cercles concentriques autour d'un point "
-"donné."
+msgstr "Crée une carte raster contenant des cercles concentriques autour d'un point donné."
#: ../gui/wxpython/menustrings.py:310 ../gui/wxpython/menustrings.py:1209
msgid "Closest points"
@@ -10182,9 +9637,7 @@
#: ../gui/wxpython/menustrings.py:311 ../gui/wxpython/menustrings.py:1210
msgid "Locates the closest points between objects in two raster maps."
-msgstr ""
-"Localise les points de plus grande proximité entre objets de deux cartes "
-"raster."
+msgstr "Localise les points de plus grande proximité entre objets de deux cartes raster."
#: ../gui/wxpython/menustrings.py:312 ../gui/wxpython/menustrings.py:1211
msgid "Grow by one cell"
@@ -10193,9 +9646,7 @@
#: ../gui/wxpython/menustrings.py:313 ../gui/wxpython/menustrings.py:376
#: ../gui/wxpython/menustrings.py:1212 ../gui/wxpython/menustrings.py:1275
msgid "Generates a raster map layer with contiguous areas grown by one cell."
-msgstr ""
-"Produit une couche raster où les surfaces contiguës ont été agrandies d'une "
-"cellule."
+msgstr "Produit une couche raster où les surfaces contiguës ont été agrandies d'une cellule."
#: ../gui/wxpython/menustrings.py:314 ../gui/wxpython/menustrings.py:368
#: ../gui/wxpython/menustrings.py:1213 ../gui/wxpython/menustrings.py:1267
@@ -10205,9 +9656,7 @@
#: ../gui/wxpython/menustrings.py:315 ../gui/wxpython/menustrings.py:369
#: ../gui/wxpython/menustrings.py:1214 ../gui/wxpython/menustrings.py:1268
msgid "Generates a raster map containing distances to nearest raster features."
-msgstr ""
-"Générer une carte raster contenant les distances vers les entités raster les "
-"plus proches."
+msgstr "Générer une carte raster contenant les distances vers les entités raster les plus proches."
#: ../gui/wxpython/menustrings.py:317 ../gui/wxpython/menustrings.py:1216
msgid "Creates a MASK for limiting raster operation."
@@ -10223,29 +9672,16 @@
msgstr "Analyse de voisinage"
#: ../gui/wxpython/menustrings.py:322 ../gui/wxpython/menustrings.py:1221
-msgid ""
-"Makes each cell category value a function of the category values assigned to "
-"the cells around it, and stores new cell values in an output raster map "
-"layer."
-msgstr ""
-"Rend la catégorie de chaque cellule une fontion des valeurs de catégorie des "
-"cellules voisines, et enregistre la nouvelle valeur dans une carte raster de "
-"sortie."
+msgid "Makes each cell category value a function of the category values assigned to the cells around it, and stores new cell values in an output raster map layer."
+msgstr "Rend la catégorie de chaque cellule une fontion des valeurs de catégorie des cellules voisines, et enregistre la nouvelle valeur dans une carte raster de sortie."
#: ../gui/wxpython/menustrings.py:323 ../gui/wxpython/menustrings.py:1222
msgid "Neighborhood points"
msgstr "Points voisins"
#: ../gui/wxpython/menustrings.py:324 ../gui/wxpython/menustrings.py:1223
-msgid ""
-"Neighborhood analysis tool for vector point maps. Makes each cell value a "
-"function of the attribute values assigned to the vector points or centroids "
-"around it, and stores new cell values in an output raster map."
-msgstr ""
-"OUtil d'analyse de voisinnage pour des cartes vecteurs de points. Défini la "
-"valeur de chaque cellule en fonction des valeurs d'attributs des points ou "
-"centroids voisins, et enregistre les nouvelles valeurs de cellule dans une "
-"carte raster."
+msgid "Neighborhood analysis tool for vector point maps. Makes each cell value a function of the attribute values assigned to the vector points or centroids around it, and stores new cell values in an output raster map."
+msgstr "OUtil d'analyse de voisinnage pour des cartes vecteurs de points. Défini la valeur de chaque cellule en fonction des valeurs d'attributs des points ou centroids voisins, et enregistre les nouvelles valeurs de cellule dans une carte raster."
#: ../gui/wxpython/menustrings.py:325 ../gui/wxpython/menustrings.py:1224
msgid "Overlay rasters"
@@ -10256,59 +9692,40 @@
msgstr "Produit en croix"
#: ../gui/wxpython/menustrings.py:327 ../gui/wxpython/menustrings.py:1226
-msgid ""
-"Creates a cross product of the category values from multiple raster map "
-"layers."
-msgstr ""
-"Crée un produit croisé des valeurs de catégories de multiples cartes raster."
+msgid "Creates a cross product of the category values from multiple raster map layers."
+msgstr "Crée un produit croisé des valeurs de catégories de multiples cartes raster."
#: ../gui/wxpython/menustrings.py:328 ../gui/wxpython/menustrings.py:1227
msgid "Patch raster maps"
msgstr "Combiner des cartes raster"
#: ../gui/wxpython/menustrings.py:329 ../gui/wxpython/menustrings.py:1228
-msgid ""
-"Creates a composite raster map layer by using known category values from one "
-"(or more) map layer(s) to fill in areas of \"no data\" in another map layer."
-msgstr ""
-"Crée une carte raster composite en utilisant les valeurs connues d'une (ou "
-"plusieurs) carte pour remplir les zones de \"no data\" d'une autre carte."
+msgid "Creates a composite raster map layer by using known category values from one (or more) map layer(s) to fill in areas of \"no data\" in another map layer."
+msgstr "Crée une carte raster composite en utilisant les valeurs connues d'une (ou plusieurs) carte pour remplir les zones de \"no data\" d'une autre carte."
#: ../gui/wxpython/menustrings.py:330 ../gui/wxpython/menustrings.py:1229
msgid "Raster series aggregation"
msgstr "Aggrégation de séries raster"
#: ../gui/wxpython/menustrings.py:331 ../gui/wxpython/menustrings.py:1230
-msgid ""
-"Makes each output cell value a function of the values assigned to the "
-"corresponding cells in the input raster map layers."
-msgstr ""
-"Rend la valeur de sortie des cellules une foncton des valeurs des cellules "
-"correspondantes dans les cartes raster d'entrée."
+msgid "Makes each output cell value a function of the values assigned to the corresponding cells in the input raster map layers."
+msgstr "Rend la valeur de sortie des cellules une foncton des valeurs des cellules correspondantes dans les cartes raster d'entrée."
#: ../gui/wxpython/menustrings.py:332 ../gui/wxpython/menustrings.py:1231
msgid "Raster series accumulation"
msgstr "Accumulation de séries raster"
#: ../gui/wxpython/menustrings.py:333 ../gui/wxpython/menustrings.py:1232
-msgid ""
-"Makes each output cell value a accumulationfunction of the values assigned "
-"to the corresponding cells in the input raster map layers."
-msgstr ""
-"Définie la valeur de sortie des cellules comme une foncton d'accumulation "
-"des valeurs des cellules correspondantes dans les cartes raster d'entrée."
+msgid "Makes each output cell value a accumulationfunction of the values assigned to the corresponding cells in the input raster map layers."
+msgstr "Définie la valeur de sortie des cellules comme une foncton d'accumulation des valeurs des cellules correspondantes dans les cartes raster d'entrée."
#: ../gui/wxpython/menustrings.py:334 ../gui/wxpython/menustrings.py:1233
msgid "Statistical overlay"
msgstr "Recouvrement statistique"
#: ../gui/wxpython/menustrings.py:335 ../gui/wxpython/menustrings.py:1234
-msgid ""
-"Calculates category or object oriented statistics (accumulator-based "
-"statistics)."
-msgstr ""
-"Calculer des statistiques par catégories ou orientées objets (statistiques "
-"d'accumulation)."
+msgid "Calculates category or object oriented statistics (accumulator-based statistics)."
+msgstr "Calculer des statistiques par catégories ou orientées objets (statistiques d'accumulation)."
#: ../gui/wxpython/menustrings.py:336 ../gui/wxpython/menustrings.py:1235
#, fuzzy
@@ -10336,53 +9753,24 @@
msgstr "Rayonnement solaire et irradiation"
#: ../gui/wxpython/menustrings.py:342 ../gui/wxpython/menustrings.py:1241
-msgid ""
-"Solar irradiance and irradiation model. Computes direct (beam), diffuse and "
-"reflected solar irradiation raster maps for given day, latitude, surface and "
-"atmospheric conditions. Solar parameters (e.g. sunrise, sunset times, "
-"declination, extraterrestrial irradiance, daylight length) are saved in the "
-"map history file. Alternatively, a local time can be specified to compute "
-"solar incidence angle and/or irradiance raster maps. The shadowing effect of "
-"the topography is optionally incorporated."
-msgstr ""
-"Irradiance solaire et modèle d'irradiation. Calcule las cartes d'irradiation "
-"solaire directe (beam), diffuse et réfléchie pour un jour, latitude, "
-"conditions de surface et atmosphérique donnés. Les paramètres olaire (ex: "
-"heures de lever et de coucher, déclinaison, irradiance extra-terrestre, "
-"durée du jour) sont enregistrés dans l'historique du fichier. "
-"Alternativement, un fichier local peut être spécifié pour calculer les "
-"cartes raster d'angle d'incidence et/ou d'irradiance solaire. La prise en "
-"compte de l'effet d'ombrage de la topographie est optionnelle."
+msgid "Solar irradiance and irradiation model. Computes direct (beam), diffuse and reflected solar irradiation raster maps for given day, latitude, surface and atmospheric conditions. Solar parameters (e.g. sunrise, sunset times, declination, extraterrestrial irradiance, daylight length) are saved in the map history file. Alternatively, a local time can be specified to compute solar incidence angle and/or irradiance raster maps. The shadowing effect of the topography is optionally incorporated."
+msgstr "Irradiance solaire et modèle d'irradiation. Calcule las cartes d'irradiation solaire directe (beam), diffuse et réfléchie pour un jour, latitude, conditions de surface et atmosphérique donnés. Les paramètres olaire (ex: heures de lever et de coucher, déclinaison, irradiance extra-terrestre, durée du jour) sont enregistrés dans l'historique du fichier. Alternativement, un fichier local peut être spécifié pour calculer les cartes raster d'angle d'incidence et/ou d'irradiance solaire. La prise en compte de l'effet d'ombrage de la topographie est optionnelle."
#: ../gui/wxpython/menustrings.py:343 ../gui/wxpython/menustrings.py:1242
msgid "Shadows map"
msgstr "Carte des ombres"
#: ../gui/wxpython/menustrings.py:344 ../gui/wxpython/menustrings.py:1243
-msgid ""
-"Calculates cast shadow areas from sun position and elevation raster map. "
-"Either exact sun position (A) is specified, or date/time to calculate the "
-"sun position (B) by r.sunmask itself."
-msgstr ""
-"Calcule les zones d'ombre depuis la position du soleil et une carte raster "
-"d'altitudes. Soit la position exacte du soleil (A) est spécifiée, soit la "
-"date/heure (B) pour que r.sunmask calcule tout seul la position du soleil."
+msgid "Calculates cast shadow areas from sun position and elevation raster map. Either exact sun position (A) is specified, or date/time to calculate the sun position (B) by r.sunmask itself."
+msgstr "Calcule les zones d'ombre depuis la position du soleil et une carte raster d'altitudes. Soit la position exacte du soleil (A) est spécifiée, soit la date/heure (B) pour que r.sunmask calcule tout seul la position du soleil."
#: ../gui/wxpython/menustrings.py:345 ../gui/wxpython/menustrings.py:1244
msgid "Sunshine hours and solar angles"
msgstr "Heure et angle solaire"
#: ../gui/wxpython/menustrings.py:346 ../gui/wxpython/menustrings.py:1245
-msgid ""
-"Calculates solar elevation, solar azimuth, and sun hours. Solar elevation: "
-"the angle between the direction of the geometric center of the sun's "
-"apparent disk and the (idealized) horizon. Solar azimuth: the angle from due "
-"north in clockwise direction."
-msgstr ""
-"Calcules l'élévation du soleil, son azimuth, et l'heure solaire. Élévation "
-"du soleil : l'angle entre la direction du centre géométrique du disque "
-"solaire apparent et l'horizon (idéal). Azimuth solaire : l'angle dans le "
-"sens horaire à partir du nord."
+msgid "Calculates solar elevation, solar azimuth, and sun hours. Solar elevation: the angle between the direction of the geometric center of the sun's apparent disk and the (idealized) horizon. Solar azimuth: the angle from due north in clockwise direction."
+msgstr "Calcules l'élévation du soleil, son azimuth, et l'heure solaire. Élévation du soleil : l'angle entre la direction du centre géométrique du disque solaire apparent et l'horizon (idéal). Azimuth solaire : l'angle dans le sens horaire à partir du nord."
#: ../gui/wxpython/menustrings.py:347 ../gui/wxpython/menustrings.py:1246
msgid "Terrain analysis"
@@ -10394,22 +9782,15 @@
#: ../gui/wxpython/menustrings.py:349 ../gui/wxpython/menustrings.py:1248
msgid "Produces a vector map of specified contours from a raster map."
-msgstr ""
-"Créer une couche vecteur GRASS avec les contours d'une couche raster GRASS."
+msgstr "Créer une couche vecteur GRASS avec les contours d'une couche raster GRASS."
#: ../gui/wxpython/menustrings.py:350 ../gui/wxpython/menustrings.py:1249
msgid "Cost surface"
msgstr "Surface de coût"
#: ../gui/wxpython/menustrings.py:351 ../gui/wxpython/menustrings.py:1250
-msgid ""
-"Creates a raster map showing the cumulative cost of moving between different "
-"geographic locations on an input raster map whose cell category values "
-"represent cost."
-msgstr ""
-"Crée une carte raster montrant le coût cumulé d'un déplacement entre "
-"différents points sur une carte raster d'altitude dont les valeurs de "
-"catégories représentent un coût."
+msgid "Creates a raster map showing the cumulative cost of moving between different geographic locations on an input raster map whose cell category values represent cost."
+msgstr "Crée une carte raster montrant le coût cumulé d'un déplacement entre différents points sur une carte raster d'altitude dont les valeurs de catégories représentent un coût."
#: ../gui/wxpython/menustrings.py:352 ../gui/wxpython/menustrings.py:1251
msgid "Cumulative movement costs"
@@ -10417,25 +9798,16 @@
#: ../gui/wxpython/menustrings.py:353 ../gui/wxpython/menustrings.py:1252
#, fuzzy
-msgid ""
-"Creates a raster map showing the anisotropic cumulative cost of moving "
-"between different geographic locations on an input raster map whose cell "
-"category values represent cost."
-msgstr ""
+msgid "Creates a raster map showing the anisotropic cumulative cost of moving between different geographic locations on an input raster map whose cell category values represent cost."
#: ../gui/wxpython/menustrings.py:354 ../gui/wxpython/menustrings.py:1253
msgid "Least cost route or flow"
msgstr "Plus court chemin ou flux"
#: ../gui/wxpython/menustrings.py:355 ../gui/wxpython/menustrings.py:1254
-msgid ""
-"Traces a flow through an elevation model or cost surface on a raster map."
-msgstr ""
-"Trace un écoulement à travers un modèle d'altitude ou une surface de coûts "
-"sur une carte raster."
+msgid "Traces a flow through an elevation model or cost surface on a raster map."
+msgstr "Trace un écoulement à travers un modèle d'altitude ou une surface de coûts sur une carte raster."
#: ../gui/wxpython/menustrings.py:356 ../gui/wxpython/menustrings.py:1255
msgid "Compute shaded relief"
@@ -10451,35 +9823,23 @@
#: ../gui/wxpython/menustrings.py:359 ../gui/wxpython/menustrings.py:1258
msgid "Drapes a color raster over an shaded relief or aspect map."
-msgstr ""
-"Drape un raster de couleur sur le relief ombré ou une carte d'exposition."
+msgstr "Drape un raster de couleur sur le relief ombré ou une carte d'exposition."
#: ../gui/wxpython/menustrings.py:360 ../gui/wxpython/menustrings.py:1259
msgid "Slope and aspect"
msgstr "Pente et exposition"
#: ../gui/wxpython/menustrings.py:361 ../gui/wxpython/menustrings.py:1260
-msgid ""
-"Generates raster maps of slope, aspect, curvatures and partial derivatives "
-"from an elevation raster map. Aspect is calculated counterclockwise from "
-"east."
-msgstr ""
-"Générer des cartes raster de pente, exposition, courbure et dérivées "
-"partielles à partir d'une carte raster d'altitude. L'exposition est calculée "
-"dans le sens anti-horaire depuis l'est."
+msgid "Generates raster maps of slope, aspect, curvatures and partial derivatives from an elevation raster map. Aspect is calculated counterclockwise from east."
+msgstr "Générer des cartes raster de pente, exposition, courbure et dérivées partielles à partir d'une carte raster d'altitude. L'exposition est calculée dans le sens anti-horaire depuis l'est."
#: ../gui/wxpython/menustrings.py:362 ../gui/wxpython/menustrings.py:1261
msgid "Terrain parameters"
msgstr "Paramètres de terrain"
#: ../gui/wxpython/menustrings.py:363 ../gui/wxpython/menustrings.py:1262
-msgid ""
-"Extracts terrain parameters from a DEM. Uses a multi-scale approach by "
-"taking fitting quadratic parameters to any size window (via least squares)."
-msgstr ""
-"Extrait les paramètres du terrain depuis un MNA. Utilise une approche multi-"
-"échelle en prenant le paramètres quadratiques englobants pour n'import "
-"quelle taille de fenêtre (par les moindre carrés)."
+msgid "Extracts terrain parameters from a DEM. Uses a multi-scale approach by taking fitting quadratic parameters to any size window (via least squares)."
+msgstr "Extrait les paramètres du terrain depuis un MNA. Utilise une approche multi-échelle en prenant le paramètres quadratiques englobants pour n'import quelle taille de fenêtre (par les moindre carrés)."
#: ../gui/wxpython/menustrings.py:364 ../gui/wxpython/menustrings.py:1263
msgid "Textural features"
@@ -10487,8 +9847,7 @@
#: ../gui/wxpython/menustrings.py:365 ../gui/wxpython/menustrings.py:1264
msgid "Generate images with textural features from a raster map."
-msgstr ""
-"Génère des images avec des entités de textures à partir d'une couche raster."
+msgstr "Génère des images avec des entités de textures à partir d'une couche raster."
#: ../gui/wxpython/menustrings.py:366 ../gui/wxpython/menustrings.py:1265
msgid "Visibility"
@@ -10496,34 +9855,16 @@
#: ../gui/wxpython/menustrings.py:367 ../gui/wxpython/menustrings.py:1266
#, fuzzy
-msgid ""
-"Computes the viewshed of a point on an elevation raster map. Default format: "
-"NULL (invisible), vertical angle wrt viewpoint (visible)."
-msgstr ""
-"Calculer la visibilité d'un point sur une carte raster d'altitudes. Format "
-"par défaut : NULL (invisible), angle vertical vers le point de vue (visible)."
+msgid "Computes the viewshed of a point on an elevation raster map. Default format: NULL (invisible), vertical angle wrt viewpoint (visible)."
+msgstr "Calculer la visibilité d'un point sur une carte raster d'altitudes. Format par défaut : NULL (invisible), angle vertical vers le point de vue (visible)."
#: ../gui/wxpython/menustrings.py:370 ../gui/wxpython/menustrings.py:1269
msgid "Horizon angle"
msgstr "Angle d'horizon"
#: ../gui/wxpython/menustrings.py:371 ../gui/wxpython/menustrings.py:1270
-msgid ""
-"Computes horizon angle height from a digital elevation model. The module has "
-"two different modes of operation: 1. Computes the entire horizon around a "
-"single point whose coordinates are given with the 'coord' option. The "
-"horizon height (in radians). 2. Computes one or more raster maps of the "
-"horizon height in a single direction. The input for this is the angle (in "
-"degrees), which is measured counterclockwise with east=0, north=90 etc. The "
-"output is the horizon height in radians."
-msgstr ""
-"Calculer la hauteur d'angle de l'horizon depuis un modèle numérique "
-"d'altitude. Le module a deux modes opératoiires différents : 1. Calculer "
-"l'horizon entier autour d'un simple point dont on a donné les coordonnées en "
-"option. La hauteur d'orizon (en radians). 2. Calculer une ou plusieurs "
-"cartes raster de la hauteur d'horizon dans une seule direction. Le paramètre "
-"d'entrée est l'angle (en degrés), qui est mesuré dans le sens anti-horaire "
-"avec est=0, nord=90 etc. La sortie est la hauteur de l'horizon en radians."
+msgid "Computes horizon angle height from a digital elevation model. The module has two different modes of operation: 1. Computes the entire horizon around a single point whose coordinates are given with the 'coord' option. The horizon height (in radians). 2. Computes one or more raster maps of the horizon height in a single direction. The input for this is the angle (in degrees), which is measured counterclockwise with east=0, north=90 etc. The output is the horizon height in radians."
+msgstr "Calculer la hauteur d'angle de l'horizon depuis un modèle numérique d'altitude. Le module a deux modes opératoiires différents : 1. Calculer l'horizon entier autour d'un simple point dont on a donné les coordonnées en option. La hauteur d'orizon (en radians). 2. Calculer une ou plusieurs cartes raster de la hauteur d'horizon dans une seule direction. Le paramètre d'entrée est l'angle (en degrés), qui est mesuré dans le sens anti-horaire avec est=0, nord=90 etc. La sortie est la hauteur de l'horizon en radians."
#: ../gui/wxpython/menustrings.py:372 ../gui/wxpython/menustrings.py:1271
msgid "Transform features"
@@ -10534,12 +9875,8 @@
msgstr "Agglomérer"
#: ../gui/wxpython/menustrings.py:374 ../gui/wxpython/menustrings.py:1273
-msgid ""
-"Recategorizes data in a raster map by grouping cells that form physically "
-"discrete areas into unique categories."
-msgstr ""
-"Reclasser les données dans une couche raster en regroupant les cellules qui "
-"forment des zones physiques discrètes."
+msgid "Recategorizes data in a raster map by grouping cells that form physically discrete areas into unique categories."
+msgstr "Reclasser les données dans une couche raster en regroupant les cellules qui forment des zones physiques discrètes."
#: ../gui/wxpython/menustrings.py:375 ../gui/wxpython/menustrings.py:1274
msgid "Grow"
@@ -10552,9 +9889,7 @@
#: ../gui/wxpython/menustrings.py:378 ../gui/wxpython/menustrings.py:1277
#, fuzzy
msgid "Thins non-null cells that denote linear features in a raster map layer."
-msgstr ""
-"Réduit les cellules non vides qui définissent une entité linéaire dans une "
-"couche raster."
+msgstr "Réduit les cellules non vides qui définissent une entité linéaire dans une couche raster."
#: ../gui/wxpython/menustrings.py:379 ../gui/wxpython/menustrings.py:1278
msgid "Hydrologic modeling"
@@ -10565,13 +9900,8 @@
msgstr "Creuser des chenaux d'écoulement"
#: ../gui/wxpython/menustrings.py:381 ../gui/wxpython/menustrings.py:1280
-msgid ""
-"Generates stream channels. Takes vector stream data, transforms it to raster "
-"and subtracts depth from the output DEM."
-msgstr ""
-"Générer les chenaux d'écoulement. Prends les données vectorielles "
-"d'écoulement, les transforme en raster, et soustrait la profondeur au modèle "
-"de terrain en sortie."
+msgid "Generates stream channels. Takes vector stream data, transforms it to raster and subtracts depth from the output DEM."
+msgstr "Générer les chenaux d'écoulement. Prends les données vectorielles d'écoulement, les transforme en raster, et soustrait la profondeur au modèle de terrain en sortie."
#: ../gui/wxpython/menustrings.py:382 ../gui/wxpython/menustrings.py:1281
msgid "Fill lake"
@@ -10586,12 +9916,8 @@
msgstr "Carte sans dépressions ni lignes de flux"
#: ../gui/wxpython/menustrings.py:385 ../gui/wxpython/menustrings.py:1284
-msgid ""
-"Filters and generates a depressionless elevation map and a flow direction "
-"map from a given elevation raster map."
-msgstr ""
-"Filtrer et générer une couche d'altitude sans dépressions et une couche de "
-"direction d'écoulement depuis une couche d'altitude donnée."
+msgid "Filters and generates a depressionless elevation map and a flow direction map from a given elevation raster map."
+msgstr "Filtrer et générer une couche d'altitude sans dépressions et une couche de direction d'écoulement depuis une couche d'altitude donnée."
#: ../gui/wxpython/menustrings.py:386 ../gui/wxpython/menustrings.py:1285
msgid "Flow accumulation"
@@ -10607,13 +9933,8 @@
msgstr "Lignes de flux"
#: ../gui/wxpython/menustrings.py:389 ../gui/wxpython/menustrings.py:1288
-msgid ""
-"Constructs flowlines. Computes flowlines, flowpath lengths, and "
-"flowaccumulation (contributing areas) from a elevation raster map."
-msgstr ""
-"Construit les lignes de flux. Calcule les lignes de flux, longueur des "
-"chemins, et accumulations (surfaces amont) depuis une carte raster "
-"d'altitudes."
+msgid "Constructs flowlines. Computes flowlines, flowpath lengths, and flowaccumulation (contributing areas) from a elevation raster map."
+msgstr "Construit les lignes de flux. Calcule les lignes de flux, longueur des chemins, et accumulations (surfaces amont) depuis une carte raster d'altitudes."
#: ../gui/wxpython/menustrings.py:390 ../gui/wxpython/menustrings.py:1289
msgid "Watershed analysis"
@@ -10637,9 +9958,7 @@
#: ../gui/wxpython/menustrings.py:395 ../gui/wxpython/menustrings.py:1294
msgid "Creates watershed basins from a drainage direction map."
-msgstr ""
-"Générer les bassins versants à partir d'une carte de direction des "
-"écoulements."
+msgstr "Générer les bassins versants à partir d'une carte de direction des écoulements."
#: ../gui/wxpython/menustrings.py:396 ../gui/wxpython/menustrings.py:1295
msgid "Extraction of stream networks"
@@ -10662,12 +9981,8 @@
msgstr "Modélisation SIMWE des flux de sédiments"
#: ../gui/wxpython/menustrings.py:401 ../gui/wxpython/menustrings.py:1300
-msgid ""
-"Sediment transport and erosion/deposition simulation using path sampling "
-"method (SIMWE)."
-msgstr ""
-"Simulation de transport de sédiments et d'érosion/sédimentation avec la "
-"méthode SIMWE."
+msgid "Sediment transport and erosion/deposition simulation using path sampling method (SIMWE)."
+msgstr "Simulation de transport de sédiments et d'érosion/sédimentation avec la méthode SIMWE."
#: ../gui/wxpython/menustrings.py:402 ../gui/wxpython/menustrings.py:1301
msgid "Topographic index map"
@@ -10675,9 +9990,7 @@
#: ../gui/wxpython/menustrings.py:403 ../gui/wxpython/menustrings.py:1302
msgid "Creates a topographic index raster map from an elevation raster map."
-msgstr ""
-"Créer une carte d'index topographique à partir d'une carte raster "
-"d'altitudes."
+msgstr "Créer une carte d'index topographique à partir d'une carte raster d'altitudes."
#: ../gui/wxpython/menustrings.py:404 ../gui/wxpython/menustrings.py:1303
msgid "TOPMODEL simulation"
@@ -10713,24 +10026,16 @@
msgstr "Flux souterrain"
#: ../gui/wxpython/menustrings.py:412 ../gui/wxpython/menustrings.py:1311
-msgid ""
-"Numerical calculation program for transient, confined and unconfined "
-"groundwater flow in two dimensions."
-msgstr ""
-"Calcul numérique pour les eaux souterraines transitoires, confinées et non "
-"confinées, en deux dimensions."
+msgid "Numerical calculation program for transient, confined and unconfined groundwater flow in two dimensions."
+msgstr "Calcul numérique pour les eaux souterraines transitoires, confinées et non confinées, en deux dimensions."
#: ../gui/wxpython/menustrings.py:413 ../gui/wxpython/menustrings.py:1312
msgid "Groundwater solute transport"
msgstr "Transport de soluté souterrain"
#: ../gui/wxpython/menustrings.py:414 ../gui/wxpython/menustrings.py:1313
-msgid ""
-"Numerical calculation program for transient, confined and unconfined solute "
-"transport in two dimensions"
-msgstr ""
-"Calcul numérique pour le transport soluble transitoire, confiné et non "
-"confiné, en deux dimensions"
+msgid "Numerical calculation program for transient, confined and unconfined solute transport in two dimensions"
+msgstr "Calcul numérique pour le transport soluble transitoire, confiné et non confiné, en deux dimensions"
#: ../gui/wxpython/menustrings.py:415 ../gui/wxpython/menustrings.py:1314
msgid "Landscape patch analysis"
@@ -10749,11 +10054,8 @@
msgstr "Densité du bord"
#: ../gui/wxpython/menustrings.py:419 ../gui/wxpython/menustrings.py:1318
-msgid ""
-"Calculates edge density index on a raster map, using a 4 neighbour algorithm"
-msgstr ""
-"Calcule l'index de densité de bords d'une carte raster, à l'aide d'un "
-"algorithme des 4 voisins les plus proches."
+msgid "Calculates edge density index on a raster map, using a 4 neighbour algorithm"
+msgstr "Calcule l'index de densité de bords d'une carte raster, à l'aide d'un algorithme des 4 voisins les plus proches."
#: ../gui/wxpython/menustrings.py:420 ../gui/wxpython/menustrings.py:1319
msgid "Contrast weighted edge density"
@@ -10761,21 +10063,15 @@
#: ../gui/wxpython/menustrings.py:421 ../gui/wxpython/menustrings.py:1320
msgid "Calculates contrast weighted edge density index on a raster map"
-msgstr ""
-"Calculer l'index de densité de bords pondérée par le contraste sur une carte "
-"raster"
+msgstr "Calculer l'index de densité de bords pondérée par le contraste sur une carte raster"
#: ../gui/wxpython/menustrings.py:422 ../gui/wxpython/menustrings.py:1321
msgid "Patch area mean"
msgstr "Surface moyenne des patch"
#: ../gui/wxpython/menustrings.py:423 ../gui/wxpython/menustrings.py:1322
-msgid ""
-"Calculates mean patch size index on a raster map, using a 4 neighbour "
-"algorithm"
-msgstr ""
-"Calculer l'index de taille moyenne de patch d'une carte raster, à l'aide "
-"d'un algorithme des 4 voisins les plus proches."
+msgid "Calculates mean patch size index on a raster map, using a 4 neighbour algorithm"
+msgstr "Calculer l'index de taille moyenne de patch d'une carte raster, à l'aide d'un algorithme des 4 voisins les plus proches."
#: ../gui/wxpython/menustrings.py:424 ../gui/wxpython/menustrings.py:1323
msgid "Patch area range"
@@ -10799,30 +10095,23 @@
#: ../gui/wxpython/menustrings.py:429 ../gui/wxpython/menustrings.py:1328
msgid "Calculates coefficient of variation of patch area on a raster map"
-msgstr ""
-"Calculer le coefficient de variation des taille de patch d'une carte raster."
+msgstr "Calculer le coefficient de variation des taille de patch d'une carte raster."
#: ../gui/wxpython/menustrings.py:430 ../gui/wxpython/menustrings.py:1329
msgid "Patch density"
msgstr "Module de densité"
#: ../gui/wxpython/menustrings.py:431 ../gui/wxpython/menustrings.py:1330
-msgid ""
-"Calculates patch density index on a raster map, using a 4 neighbour algorithm"
-msgstr ""
-"Calculer l'index de densité de patch d'une carte raster, à l'aide d'un "
+msgid "Calculates patch density index on a raster map, using a 4 neighbour algorithm"
+msgstr "Calculer l'index de densité de patch d'une carte raster, à l'aide d'un algorithme des 4 voisins les plus proches."
#: ../gui/wxpython/menustrings.py:432 ../gui/wxpython/menustrings.py:1331
msgid "Patch number"
msgstr "Module nombre"
#: ../gui/wxpython/menustrings.py:433 ../gui/wxpython/menustrings.py:1332
-msgid ""
-"Calculates patch number index on a raster map, using a 4 neighbour algorithm."
-msgstr ""
-"Calculer l'index du nombre de patch d'une carte raster, à l'aide d'un "
+msgid "Calculates patch number index on a raster map, using a 4 neighbour algorithm."
+msgstr "Calculer l'index du nombre de patch d'une carte raster, à l'aide d'un algorithme des 4 voisins les plus proches."
#: ../gui/wxpython/menustrings.py:434 ../gui/wxpython/menustrings.py:1333
msgid "Dominance's diversity"
@@ -10873,28 +10162,16 @@
msgstr "Taux de propagation"
#: ../gui/wxpython/menustrings.py:446 ../gui/wxpython/menustrings.py:1345
-msgid ""
-"Generates rate of spread raster maps. Generates three, or four raster map "
-"layers showing the base (perpendicular) rate of spread (ROS), the maximum "
-"(forward) ROS, the direction of the maximum ROS, and optionally the maximum "
-"potential spotting distance for fire spread simulation."
-msgstr ""
-"Génère trois ou quatre couches raster montrant 1) la la vitesse de "
-"propagation de base (ROS), 2) la propagation maximale, 3) la direction de la "
-"propagation maximale, et en option 4) la distance potentielle maximale de "
-"propagation."
+msgid "Generates rate of spread raster maps. Generates three, or four raster map layers showing the base (perpendicular) rate of spread (ROS), the maximum (forward) ROS, the direction of the maximum ROS, and optionally the maximum potential spotting distance for fire spread simulation."
+msgstr "Génère trois ou quatre couches raster montrant 1) la la vitesse de propagation de base (ROS), 2) la propagation maximale, 3) la direction de la propagation maximale, et en option 4) la distance potentielle maximale de propagation."
#: ../gui/wxpython/menustrings.py:447 ../gui/wxpython/menustrings.py:1346
msgid "Least-cost spread paths"
msgstr "Propagation par chemins de moindre coût "
#: ../gui/wxpython/menustrings.py:448 ../gui/wxpython/menustrings.py:1347
-msgid ""
-"Recursively traces the least cost path backwards to cells from which the "
-"cumulative cost was determined."
-msgstr ""
-"Trace de façon récursive le plus court chemin vers les cellules pour "
-"lequelles le coût cumulé est déterminé."
+msgid "Recursively traces the least cost path backwards to cells from which the cumulative cost was determined."
+msgstr "Trace de façon récursive le plus court chemin vers les cellules pour lequelles le coût cumulé est déterminé."
#: ../gui/wxpython/menustrings.py:449 ../gui/wxpython/menustrings.py:1348
msgid "Anisotropic spread simulation"
@@ -10902,16 +10179,8 @@
#: ../gui/wxpython/menustrings.py:450 ../gui/wxpython/menustrings.py:1349
#, fuzzy
-msgid ""
-"Simulates elliptically anisotropic spread. Generates a raster map of the "
-"cumulative time of spread, given raster maps containing the rates of spread "
-"(ROS), the ROS directions and the spread origins. It optionally produces "
-"raster maps to contain backlink UTM coordinates for tracing spread paths. "
-"Usable for fire spread simulations."
-msgstr ""
-"Simule une propagation elliptique anisotropique sur une fenêtre graphique et "
-"génère une couche raster du temps cumulé de propagation, à partir de couches "
-"raster contenant des taux (ROS), directions, et origine des propagations."
+msgid "Simulates elliptically anisotropic spread. Generates a raster map of the cumulative time of spread, given raster maps containing the rates of spread (ROS), the ROS directions and the spread origins. It optionally produces raster maps to contain backlink UTM coordinates for tracing spread paths. Usable for fire spread simulations."
+msgstr "Simule une propagation elliptique anisotropique sur une fenêtre graphique et génère une couche raster du temps cumulé de propagation, à partir de couches raster contenant des taux (ROS), directions, et origine des propagations."
#: ../gui/wxpython/menustrings.py:451 ../gui/wxpython/menustrings.py:1350
msgid "Change category values and labels"
@@ -10924,12 +10193,8 @@
#: ../gui/wxpython/menustrings.py:453 ../gui/wxpython/menustrings.py:505
#: ../gui/wxpython/menustrings.py:1352 ../gui/wxpython/menustrings.py:1404
-msgid ""
-"Manages category values and labels associated with user-specified raster map "
-"layers."
-msgstr ""
-"Gérer les valeurs de catégories et les étiquettes associées aux cartes "
-"raster spécifiées."
+msgid "Manages category values and labels associated with user-specified raster map layers."
+msgstr "Gérer les valeurs de catégories et les étiquettes associées aux cartes raster spécifiées."
#: ../gui/wxpython/menustrings.py:454 ../gui/wxpython/menustrings.py:1353
msgid "Interactively edit category values"
@@ -10944,12 +10209,8 @@
msgstr "Reclasser en fonction de la taille"
#: ../gui/wxpython/menustrings.py:457 ../gui/wxpython/menustrings.py:1356
-msgid ""
-"Reclasses a raster map greater or less than user specified area size (in "
-"hectares)."
-msgstr ""
-"Reclasser une carte raster pour une taille supérieure ou égale à la taille "
-"spécifiée par l'utilisateur (en hectares)."
+msgid "Reclasses a raster map greater or less than user specified area size (in hectares)."
+msgstr "Reclasser une carte raster pour une taille supérieure ou égale à la taille spécifiée par l'utilisateur (en hectares)."
#: ../gui/wxpython/menustrings.py:458 ../gui/wxpython/menustrings.py:664
#: ../gui/wxpython/menustrings.py:1357 ../gui/wxpython/menustrings.py:1563
@@ -10957,14 +10218,8 @@
msgstr "Reclasser"
#: ../gui/wxpython/menustrings.py:459 ../gui/wxpython/menustrings.py:1358
-msgid ""
-"Reclassify raster map based on category values. Creates a new raster map "
-"whose category values are based upon a reclassification of the categories in "
-"an existing raster map."
-msgstr ""
-"Reclasser une carte raster en se basant sur les valeurs de catégories. Créer "
-"une nouvelle carte dont les valeurs de catégories sont basées sur une "
-"reclassification des catégories d'une carte raster existante."
+msgid "Reclassify raster map based on category values. Creates a new raster map whose category values are based upon a reclassification of the categories in an existing raster map."
+msgstr "Reclasser une carte raster en se basant sur les valeurs de catégories. Créer une nouvelle carte dont les valeurs de catégories sont basées sur une reclassification des catégories d'une carte raster existante."
#: ../gui/wxpython/menustrings.py:460 ../gui/wxpython/menustrings.py:1359
msgid "Recode"
@@ -10987,12 +10242,8 @@
msgstr "Recalculer l'échelle des valeurs par histogramme"
#: ../gui/wxpython/menustrings.py:465 ../gui/wxpython/menustrings.py:1364
-msgid ""
-"Rescales histogram equalized the range of category values in a raster map "
-"layer."
-msgstr ""
-"Rééchelonne l'histogramme sur la plage des valeurs de catégories de la "
-"couche raster."
+msgid "Rescales histogram equalized the range of category values in a raster map layer."
+msgstr "Rééchelonne l'histogramme sur la plage des valeurs de catégories de la couche raster."
#: ../gui/wxpython/menustrings.py:466 ../gui/wxpython/menustrings.py:1365
msgid "Generate random cells"
@@ -11004,20 +10255,15 @@
#: ../gui/wxpython/menustrings.py:468 ../gui/wxpython/menustrings.py:1367
msgid "Generates random cell values with spatial dependence."
-msgstr ""
-"Génère des valeurs de cellules aléatoires avec une dépendance spatiale."
+msgstr "Génère des valeurs de cellules aléatoires avec une dépendance spatiale."
#: ../gui/wxpython/menustrings.py:469 ../gui/wxpython/menustrings.py:1368
msgid "Random cells and vector points"
msgstr "Cellules aléatoires et points vectoriels"
#: ../gui/wxpython/menustrings.py:470 ../gui/wxpython/menustrings.py:1369
-msgid ""
-"Creates a raster map layer and vector point map containing randomly located "
-"points."
-msgstr ""
-"Créer une carte raster ou une carte vectorielle de points contenant des "
-"points dispersés de manière aléatoire."
+msgid "Creates a raster map layer and vector point map containing randomly located points."
+msgstr "Créer une carte raster ou une carte vectorielle de points contenant des points dispersés de manière aléatoire."
#: ../gui/wxpython/menustrings.py:471 ../gui/wxpython/menustrings.py:1370
msgid "Generate surfaces"
@@ -11036,27 +10282,16 @@
msgstr "Surface avec un noyau de densité gaussienne"
#: ../gui/wxpython/menustrings.py:475 ../gui/wxpython/menustrings.py:1374
-msgid ""
-"Generates a raster density map from vector points map. Density is computed "
-"using a moving kernel. Optionally generates a vector density map on a vector "
-"network."
-msgstr ""
-"Génère une carte raster de densité à partir de données vecteurs points en "
-"utilisant un noyau mouvant et en option génère une carte de densité sur un "
-"réseau vectoriel."
+msgid "Generates a raster density map from vector points map. Density is computed using a moving kernel. Optionally generates a vector density map on a vector network."
+msgstr "Génère une carte raster de densité à partir de données vecteurs points en utilisant un noyau mouvant et en option génère une carte de densité sur un réseau vectoriel."
#: ../gui/wxpython/menustrings.py:476 ../gui/wxpython/menustrings.py:1375
msgid "Gaussian deviates surface"
msgstr "Déviance gaussienne de surface"
#: ../gui/wxpython/menustrings.py:477 ../gui/wxpython/menustrings.py:1376
-msgid ""
-"Generates a raster map using gaussian random number generator. Mean and "
-"standard deviation of gaussian deviates can be expressed by the user."
-msgstr ""
-"Générer une carte raster en utilisant un générateur de nombres aléatoire "
-"gaussien. La moyenne et l'écart-type de la déviation gaussienne peut être "
-"indiqués par l'utilisateur."
+msgid "Generates a raster map using gaussian random number generator. Mean and standard deviation of gaussian deviates can be expressed by the user."
+msgstr "Générer une carte raster en utilisant un générateur de nombres aléatoire gaussien. La moyenne et l'écart-type de la déviation gaussienne peut être indiqués par l'utilisateur."
#: ../gui/wxpython/menustrings.py:478 ../gui/wxpython/menustrings.py:1377
#: ../gui/wxpython/nviz/tools.py:4593
@@ -11065,23 +10300,16 @@
# Dip traduit ici pendage, en référence à la terminologie des géologues.
#: ../gui/wxpython/menustrings.py:479 ../gui/wxpython/menustrings.py:1378
-msgid ""
-"Creates raster plane map given dip (inclination), aspect (azimuth) and one "
-"point."
-msgstr ""
-"Crée une carte raster plane définie par un pendage (inclinaison), une "
-"orientation (azimuth) et un point."
+msgid "Creates raster plane map given dip (inclination), aspect (azimuth) and one point."
+msgstr "Crée une carte raster plane définie par un pendage (inclinaison), une orientation (azimuth) et un point."
#: ../gui/wxpython/menustrings.py:480 ../gui/wxpython/menustrings.py:1379
msgid "Random deviates surface"
msgstr "Déviance aléatoire de surface"
#: ../gui/wxpython/menustrings.py:481 ../gui/wxpython/menustrings.py:1380
-msgid ""
-"Produces a raster surface map of uniform random deviates with defined range."
-msgstr ""
-"Produit une couche raster de données aléatoires uniformément réparties dans "
-"une plage donnée par l'utilisateur."
+msgid "Produces a raster surface map of uniform random deviates with defined range."
+msgstr "Produit une couche raster de données aléatoires uniformément réparties dans une plage donnée par l'utilisateur."
#: ../gui/wxpython/menustrings.py:482 ../gui/wxpython/menustrings.py:1381
msgid "Random surface with spatial dependence"
@@ -11100,36 +10328,24 @@
msgstr "Bilinéaire et bicubique de points vecteur"
#: ../gui/wxpython/menustrings.py:486 ../gui/wxpython/menustrings.py:1385
-msgid ""
-"Performs bicubic or bilinear spline interpolation with Tykhonov "
-"regularization."
-msgstr ""
-"Effectue une interpolation spline bicubique ou bilinéaire avec "
-"régularisation de Tykhonov."
+msgid "Performs bicubic or bilinear spline interpolation with Tykhonov regularization."
+msgstr "Effectue une interpolation spline bicubique ou bilinéaire avec régularisation de Tykhonov."
#: ../gui/wxpython/menustrings.py:487 ../gui/wxpython/menustrings.py:1386
msgid "IDW from raster points"
msgstr "IDW de points matriciels"
#: ../gui/wxpython/menustrings.py:488 ../gui/wxpython/menustrings.py:1387
-msgid ""
-"Provides surface interpolation from raster point data by Inverse Distance "
-"Squared Weighting."
-msgstr ""
-"Interpolation de surface à partir de points raster par pondération de la "
-"distance inverse au carré (IDSW)."
+msgid "Provides surface interpolation from raster point data by Inverse Distance Squared Weighting."
+msgstr "Interpolation de surface à partir de points raster par pondération de la distance inverse au carré (IDSW)."
#: ../gui/wxpython/menustrings.py:489 ../gui/wxpython/menustrings.py:1388
msgid "IDW from vector points"
msgstr "IDW de points vecteur"
#: ../gui/wxpython/menustrings.py:490 ../gui/wxpython/menustrings.py:1389
-msgid ""
-"Provides surface interpolation from vector point data by Inverse Distance "
-msgstr ""
-"Interpolation de surface à partir de points vecteur par pondération de la "
+msgid "Provides surface interpolation from vector point data by Inverse Distance Squared Weighting."
+msgstr "Interpolation de surface à partir de points vecteur par pondération de la distance inverse au carré (IDSW)."
#: ../gui/wxpython/menustrings.py:491 ../gui/wxpython/menustrings.py:1390
msgid "Raster contours"
@@ -11144,28 +10360,16 @@
msgstr "Splines régulées avec tension"
#: ../gui/wxpython/menustrings.py:494 ../gui/wxpython/menustrings.py:1393
-msgid ""
-"Performs surface interpolation from vector points map by splines. Spatial "
-"approximation and topographic analysis from given point or isoline data in "
-"vector format to floating point raster format using regularized spline with "
-"tension."
-msgstr ""
-"Effectue une interpolation de surfaces depuis des points vecteurs avec les "
-"splines. Approximation spatiale et analyse topographique depuis des points "
-"ou isolines au format vecteur vers un raster en nombre flottants, en "
-"utilisant des splines régulées avec tension."
+msgid "Performs surface interpolation from vector points map by splines. Spatial approximation and topographic analysis from given point or isoline data in vector format to floating point raster format using regularized spline with tension."
+msgstr "Effectue une interpolation de surfaces depuis des points vecteurs avec les splines. Approximation spatiale et analyse topographique depuis des points ou isolines au format vecteur vers un raster en nombre flottants, en utilisant des splines régulées avec tension."
#: ../gui/wxpython/menustrings.py:495 ../gui/wxpython/menustrings.py:1394
msgid "Raster series interpolation"
msgstr "Interpolation de série raster"
#: ../gui/wxpython/menustrings.py:496 ../gui/wxpython/menustrings.py:1395
-msgid ""
-"Interpolates raster maps located (temporal or spatial) in between input "
-"raster maps at specific sampling positions."
-msgstr ""
-"Interpoler des cartes raster situées (temporel ou spatial) entre des cartes "
-"rasters d'entrée à des points d'échantillonages spécifiques."
+msgid "Interpolates raster maps located (temporal or spatial) in between input raster maps at specific sampling positions."
+msgstr "Interpoler des cartes raster situées (temporel ou spatial) entre des cartes rasters d'entrée à des points d'échantillonages spécifiques."
#: ../gui/wxpython/menustrings.py:497 ../gui/wxpython/menustrings.py:1396
msgid "Ordinary or block kriging"
@@ -11181,8 +10385,7 @@
#: ../gui/wxpython/menustrings.py:500 ../gui/wxpython/menustrings.py:1399
msgid "Fills no-data areas in raster maps using spline interpolation."
-msgstr ""
-"Remplir les zones sans données de la carte raster par interpolation spline."
+msgstr "Remplir les zones sans données de la carte raster par interpolation spline."
#: ../gui/wxpython/menustrings.py:501 ../gui/wxpython/menustrings.py:703
#: ../gui/wxpython/menustrings.py:813 ../gui/wxpython/menustrings.py:981
@@ -11221,8 +10424,7 @@
#: ../gui/wxpython/menustrings.py:511 ../gui/wxpython/menustrings.py:1410
msgid "Prints terse list of category values found in a raster map layer."
-msgstr ""
-"Afficher la liste des valeurs de catégories trouvées dans une carte raster."
+msgstr "Afficher la liste des valeurs de catégories trouvées dans une carte raster."
#: ../gui/wxpython/menustrings.py:512 ../gui/wxpython/menustrings.py:1411
msgid "Sum area by raster map and category"
@@ -11237,12 +10439,8 @@
msgstr "Statistiques pour des amas de cellules"
#: ../gui/wxpython/menustrings.py:515 ../gui/wxpython/menustrings.py:1414
-msgid ""
-"Calculates the volume of data \"clumps\". Optionally produces a GRASS vector "
-"points map containing the calculated centroids of these clumps."
-msgstr ""
-"Calcul le volume de données en amas. En option, produit une couche de points "
-"contenant les centroïdes de ces amas."
+msgid "Calculates the volume of data \"clumps\". Optionally produces a GRASS vector points map containing the calculated centroids of these clumps."
+msgstr "Calcul le volume de données en amas. En option, produit une couche de points contenant les centroïdes de ces amas."
#: ../gui/wxpython/menustrings.py:516 ../gui/wxpython/menustrings.py:1415
msgid "Total corrected area"
@@ -11253,16 +10451,8 @@
msgstr "Afficher les estimations de superficies d'une carte raster."
#: ../gui/wxpython/menustrings.py:519 ../gui/wxpython/menustrings.py:1418
-msgid ""
-"Calculates univariate statistics from the non-null cells of a raster map. "
-"Statistics include number of cells counted, minimum and maximum cell values, "
-"range, arithmetic mean, population variance, standard deviation, coefficient "
-"of variation, and sum."
-msgstr ""
-"Calcule les statistiques univariées pour les cellules non nulles d'une carte "
-"raster. Les statistiques incluent le nombe de cellules, les valeurs "
-"minimales et maximales, la plage, la moyenne arithmétique, la variance, "
-"l'écart-type, le coefficient de variation, et la somme."
+msgid "Calculates univariate statistics from the non-null cells of a raster map. Statistics include number of cells counted, minimum and maximum cell values, range, arithmetic mean, population variance, standard deviation, coefficient of variation, and sum."
+msgstr "Calcule les statistiques univariées pour les cellules non nulles d'une carte raster. Les statistiques incluent le nombe de cellules, les valeurs minimales et maximales, la plage, la moyenne arithmétique, la variance, l'écart-type, le coefficient de variation, et la somme."
#: ../gui/wxpython/menustrings.py:520 ../gui/wxpython/menustrings.py:1419
msgid "Sample transects"
@@ -11270,29 +10460,22 @@
#: ../gui/wxpython/menustrings.py:521 ../gui/wxpython/menustrings.py:1420
msgid "Outputs the raster map layer values lying on user-defined line(s)."
-msgstr ""
-"Affiche en sortie les valeurs de carte raster suivant une(des) ligne(s) "
-"définie(s) par l'utilisateur."
+msgstr "Affiche en sortie les valeurs de carte raster suivant une(des) ligne(s) définie(s) par l'utilisateur."
#: ../gui/wxpython/menustrings.py:522 ../gui/wxpython/menustrings.py:1421
msgid "Sample transects (bearing/distance)"
msgstr "Exemple de transects (parcours/distance)"
#: ../gui/wxpython/menustrings.py:523 ../gui/wxpython/menustrings.py:1422
-msgid ""
-"Outputs raster map layer values lying along user defined transect line(s)."
-msgstr ""
-"Affiche en sortie les valeurs de carte raster suivant un(des) transect(s) "
-"défini(s) par l'utilisateur."
+msgid "Outputs raster map layer values lying along user defined transect line(s)."
+msgstr "Affiche en sortie les valeurs de carte raster suivant un(des) transect(s) défini(s) par l'utilisateur."
#: ../gui/wxpython/menustrings.py:524 ../gui/wxpython/menustrings.py:1423
msgid "Covariance/correlation"
msgstr "Covariance/corrélation"
#: ../gui/wxpython/menustrings.py:525 ../gui/wxpython/menustrings.py:1424
-msgid ""
-"Outputs a covariance/correlation matrix for user-specified raster map "
-"layer(s)."
+msgid "Outputs a covariance/correlation matrix for user-specified raster map layer(s)."
msgstr "Sortir la matrice de covariance/corrélation pour des"
#: ../gui/wxpython/menustrings.py:526 ../gui/wxpython/menustrings.py:1425
@@ -11301,8 +10484,7 @@
#: ../gui/wxpython/menustrings.py:527 ../gui/wxpython/menustrings.py:1426
msgid "Calculates linear regression from two raster maps: y = a + b*x."
-msgstr ""
-"Calcule une régression linéaire depuis deux cartes raster : y = a + b*x."
+msgstr "Calcule une régression linéaire depuis deux cartes raster : y = a + b*x."
#: ../gui/wxpython/menustrings.py:528 ../gui/wxpython/menustrings.py:1427
msgid "Multiple regression"
@@ -11317,11 +10499,8 @@
msgstr "Occurences mutelles de catégories"
#: ../gui/wxpython/menustrings.py:531 ../gui/wxpython/menustrings.py:1430
-msgid ""
-"Tabulates the mutual occurrence (coincidence) of categories for two raster "
-"map layers."
-msgstr ""
-"Tabuler les occurences mutuelles (coincidence) des catégories de deux rasters"
+msgid "Tabulates the mutual occurrence (coincidence) of categories for two raster map layers."
+msgstr "Tabuler les occurences mutuelles (coincidence) des catégories de deux rasters"
#: ../gui/wxpython/menustrings.py:532 ../gui/wxpython/menustrings.py:1431
msgid "&Vector"
@@ -11346,12 +10525,8 @@
msgstr "Éditer une carte vecteur (de façon non interactive)"
#: ../gui/wxpython/menustrings.py:537 ../gui/wxpython/menustrings.py:1436
-msgid ""
-"Edits a vector map, allows adding, deleting and modifying selected vector "
-"features."
-msgstr ""
-"Édite une carte vecteur, permet d'ajouter, supprimer et modifier les objets "
-"vectoriels sélectionnés."
+msgid "Edits a vector map, allows adding, deleting and modifying selected vector features."
+msgstr "Édite une carte vecteur, permet d'ajouter, supprimer et modifier les objets vectoriels sélectionnés."
#: ../gui/wxpython/menustrings.py:538 ../gui/wxpython/menustrings.py:1437
msgid "Convert object types"
@@ -11374,12 +10549,8 @@
msgstr "Fusionner des contours"
#: ../gui/wxpython/menustrings.py:543 ../gui/wxpython/menustrings.py:1442
-msgid ""
-"Dissolves boundaries between adjacent areas sharing a common category number "
-"or attribute."
-msgstr ""
-"Fusionne des contours entre surfaces adjacentes partageant un attribut ou "
-"une catégorie commun(e)."
+msgid "Dissolves boundaries between adjacent areas sharing a common category number or attribute."
+msgstr "Fusionne des contours entre surfaces adjacentes partageant un attribut ou une catégorie commun(e)."
#: ../gui/wxpython/menustrings.py:544 ../gui/wxpython/menustrings.py:1443
msgid "Create 3D vector over raster"
@@ -11387,22 +10558,15 @@
#: ../gui/wxpython/menustrings.py:545 ../gui/wxpython/menustrings.py:1444
msgid "Converts 2D vector features to 3D by sampling of elevation raster map."
-msgstr ""
-"Convertit des entités vecteurs de 2D vers 3D par échantillonage d'une carte "
-"raster d'altitudes."
+msgstr "Convertit des entités vecteurs de 2D vers 3D par échantillonage d'une carte raster d'altitudes."
#: ../gui/wxpython/menustrings.py:546 ../gui/wxpython/menustrings.py:1445
msgid "Extrude 3D vector map"
msgstr "Extruder une carte vecteur 3D"
#: ../gui/wxpython/menustrings.py:547 ../gui/wxpython/menustrings.py:1446
-msgid ""
-"Extrudes flat vector features to 3D vector features with defined height. "
-"Optionally the height can be derived from sampling of elevation raster map."
-msgstr ""
-"Extruder un vecteur plat vers des entités vectorielles 3D avec une hauteur "
-"définie. En Option, la hauteur peut être dérivée de l'échantillonage d'une "
-"carte raster d'altitudes."
+msgid "Extrudes flat vector features to 3D vector features with defined height. Optionally the height can be derived from sampling of elevation raster map."
+msgstr "Extruder un vecteur plat vers des entités vectorielles 3D avec une hauteur définie. En Option, la hauteur peut être dérivée de l'échantillonage d'une carte raster d'altitudes."
#: ../gui/wxpython/menustrings.py:548 ../gui/wxpython/menustrings.py:1447
msgid "Create labels"
@@ -11417,23 +10581,16 @@
msgstr "Repositionner une carte vecteur"
#: ../gui/wxpython/menustrings.py:551 ../gui/wxpython/menustrings.py:1450
-msgid ""
-"Performs an affine transformation (shift, scale and rotate) on vector map."
-msgstr ""
-"Effectue la transformation affine (translation, échelle et rotation) d'une "
-"carte vecteur."
+msgid "Performs an affine transformation (shift, scale and rotate) on vector map."
+msgstr "Effectue la transformation affine (translation, échelle et rotation) d'une carte vecteur."
#: ../gui/wxpython/menustrings.py:552 ../gui/wxpython/menustrings.py:1451
msgid "Rectify vector map"
msgstr "Rectifier une carte vecteur"
#: ../gui/wxpython/menustrings.py:553 ../gui/wxpython/menustrings.py:1452
-msgid ""
-"Rectifies a vector by computing a coordinate transformation for each object "
-"in the vector based on the control points."
-msgstr ""
-"Rectifie un vecteur en calculant une transformation de coordonnées pour "
-"chaque objet du vecteur en se basant sur des points de contrôle."
+msgid "Rectifies a vector by computing a coordinate transformation for each object in the vector based on the control points."
+msgstr "Rectifie un vecteur en calculant une transformation de coordonnées pour chaque objet du vecteur en se basant sur des points de contrôle."
#: ../gui/wxpython/menustrings.py:557 ../gui/wxpython/menustrings.py:1456
msgid "Updates vector map metadata."
@@ -11448,12 +10605,8 @@
msgstr "Créer ou reconstruire la topologie"
#: ../gui/wxpython/menustrings.py:560 ../gui/wxpython/menustrings.py:1459
-msgid ""
-"Creates topology for vector map. Optionaly also checks for topological "
-"errors."
-msgstr ""
-"Créer la topologie pour la carte vecteur. En option, vérifie les erreurs de "
-"topologie."
+msgid "Creates topology for vector map. Optionaly also checks for topological errors."
+msgstr "Créer la topologie pour la carte vecteur. En option, vérifie les erreurs de topologie."
#: ../gui/wxpython/menustrings.py:561 ../gui/wxpython/menustrings.py:1460
msgid "Rebuild topology on all vector maps"
@@ -11461,9 +10614,7 @@
#: ../gui/wxpython/menustrings.py:562 ../gui/wxpython/menustrings.py:1461
msgid "Rebuilds topology on all vector maps in the current mapset."
-msgstr ""
-"Reconstruire la topologie de toutes les cartes vectorielles dans le jeux de "
-"cartes courant."
+msgstr "Reconstruire la topologie de toutes les cartes vectorielles dans le jeux de cartes courant."
#: ../gui/wxpython/menustrings.py:563 ../gui/wxpython/menustrings.py:1462
msgid "Build polylines"
@@ -11487,9 +10638,7 @@
#: ../gui/wxpython/menustrings.py:568 ../gui/wxpython/menustrings.py:1467
msgid "Creates points/segments from input vector lines and positions."
-msgstr ""
-"Crée des points/segments à partir de lignes vectorielles et positions en "
-"entrée."
+msgstr "Crée des points/segments à partir de lignes vectorielles et positions en entrée."
#: ../gui/wxpython/menustrings.py:569 ../gui/wxpython/menustrings.py:1468
msgid "Clean vector map"
@@ -11558,23 +10707,16 @@
msgstr "Sélectionner par attributs"
#: ../gui/wxpython/menustrings.py:589 ../gui/wxpython/menustrings.py:1488
-msgid ""
-"Selects vector features from an existing vector map and creates a new vector "
-"map containing only the selected features."
-msgstr ""
-"Sélectionne les entités vectorielles depuis une carte vecteur existante et "
-"créé une nouvelle carte vecteur contenant les entités sélectionnées."
+msgid "Selects vector features from an existing vector map and creates a new vector map containing only the selected features."
+msgstr "Sélectionne les entités vectorielles depuis une carte vecteur existante et créé une nouvelle carte vecteur contenant les entités sélectionnées."
#: ../gui/wxpython/menustrings.py:590 ../gui/wxpython/menustrings.py:1489
msgid "Select by another map"
msgstr "Sélectionner par une autre carte"
#: ../gui/wxpython/menustrings.py:591 ../gui/wxpython/menustrings.py:1490
-msgid ""
-"Selects features from vector map (A) by features from other vector map (B)."
-msgstr ""
-"Sélectionne des entités d'une carte vecteur (A) par des entités d'une autre "
-"carte vecteur (B)."
+msgid "Selects features from vector map (A) by features from other vector map (B)."
+msgstr "Sélectionne des entités d'une carte vecteur (A) par des entités d'une autre carte vecteur (B)."
#: ../gui/wxpython/menustrings.py:599 ../gui/wxpython/menustrings.py:1498
msgid "Buffer vectors"
@@ -11610,24 +10752,16 @@
msgstr "Détecter intérieurs"
#: ../gui/wxpython/menustrings.py:607 ../gui/wxpython/menustrings.py:1506
-msgid ""
-"Building contour determination and Region Growing algorithm for determining "
-"the building inside"
-msgstr ""
-"Détermination des contours de bâtiments et algorithme d'agrandissement de la "
-"région pour déterminer les bâtiments à l'intérieur"
+msgid "Building contour determination and Region Growing algorithm for determining the building inside"
+msgstr "Détermination des contours de bâtiments et algorithme d'agrandissement de la région pour déterminer les bâtiments à l'intérieur"
#: ../gui/wxpython/menustrings.py:608 ../gui/wxpython/menustrings.py:1507
msgid "Correct and reclassify objects"
msgstr "Corriger et classifier les objets"
#: ../gui/wxpython/menustrings.py:609 ../gui/wxpython/menustrings.py:1508
-msgid ""
-"Corrects the v.lidar.growing output. It is the last of the three algorithms "
-"for LIDAR filtering."
-msgstr ""
-"Correction de la sortie de v.lidar.growing. Il s'agit du dernier des trois "
-"algorithms pour le filtrage LIDAR."
+msgid "Corrects the v.lidar.growing output. It is the last of the three algorithms for LIDAR filtering."
+msgstr "Correction de la sortie de v.lidar.growing. Il s'agit du dernier des trois algorithms pour le filtrage LIDAR."
#: ../gui/wxpython/menustrings.py:610 ../gui/wxpython/menustrings.py:1509
msgid "Linear referencing"
@@ -11647,45 +10781,31 @@
#: ../gui/wxpython/menustrings.py:614 ../gui/wxpython/menustrings.py:1513
msgid "Creates stationing from input lines, and linear reference system."
-msgstr ""
-"Créer des placement à partir de lignes, et d'un système de référence linéaire"
+msgstr "Créer des placement à partir de lignes, et d'un système de référence linéaire"
#: ../gui/wxpython/menustrings.py:615 ../gui/wxpython/menustrings.py:1514
msgid "Create points/segments"
msgstr "Créer points/segments"
#: ../gui/wxpython/menustrings.py:616 ../gui/wxpython/menustrings.py:1515
-msgid ""
-"Creates points/segments from input lines, linear reference system and "
-"positions read from stdin or a file."
-msgstr ""
-"Créer des points/segments à partir des lignes en entrée, un système de "
-"référence linéaire et des positions lues depuis l'entrée standard ou un "
-"fichier."
+msgid "Creates points/segments from input lines, linear reference system and positions read from stdin or a file."
+msgstr "Créer des points/segments à partir des lignes en entrée, un système de référence linéaire et des positions lues depuis l'entrée standard ou un fichier."
#: ../gui/wxpython/menustrings.py:617 ../gui/wxpython/menustrings.py:1516
msgid "Find line id and offset"
msgstr "Trouver l'id de ligne et le décalage"
#: ../gui/wxpython/menustrings.py:618 ../gui/wxpython/menustrings.py:1517
-msgid ""
-"Finds line id and real km+offset for given points in vector map using linear "
-"reference system."
-msgstr ""
-"Trouvez l'id de ligne et le km réel pour les points donnés de la carte "
-"vectorielle en utilisant un système de référence linéaire"
+msgid "Finds line id and real km+offset for given points in vector map using linear reference system."
+msgstr "Trouvez l'id de ligne et le km réel pour les points donnés de la carte vectorielle en utilisant un système de référence linéaire"
#: ../gui/wxpython/menustrings.py:619 ../gui/wxpython/menustrings.py:1518
msgid "Nearest features"
msgstr "Entités les plus proches"
#: ../gui/wxpython/menustrings.py:620 ../gui/wxpython/menustrings.py:1519
-msgid ""
-"Finds the nearest element in vector map 'to' for elements in vector map "
-"'from'."
-msgstr ""
-"Trouve l'élément de la carte \"vers\" le plus proche des éléments de la "
-"carte \"depuis\"."
+msgid "Finds the nearest element in vector map 'to' for elements in vector map 'from'."
+msgstr "Trouve l'élément de la carte \"vers\" le plus proche des éléments de la carte \"depuis\"."
#: ../gui/wxpython/menustrings.py:621 ../gui/wxpython/menustrings.py:1520
msgid "Network analysis"
@@ -11708,28 +10828,16 @@
msgstr "Allouer des sous-réseaux"
#: ../gui/wxpython/menustrings.py:627 ../gui/wxpython/menustrings.py:1526
-msgid ""
-"Allocates subnets for nearest centers (direction from center). center node "
-"must be opened (costs >= 0). Costs of center node are used in calculation"
-msgstr ""
-"Allouer les sous-réseaux pour le centre le plus proche (direction depuis le "
-"centre). Le noeud central doit être ouvert (coût >= 0). Le coût du noeud "
-"central est pris en compte dans le calcul."
+msgid "Allocates subnets for nearest centers (direction from center). center node must be opened (costs >= 0). Costs of center node are used in calculation"
+msgstr "Allouer les sous-réseaux pour le centre le plus proche (direction depuis le centre). Le noeud central doit être ouvert (coût >= 0). Le coût du noeud central est pris en compte dans le calcul."
#: ../gui/wxpython/menustrings.py:628 ../gui/wxpython/menustrings.py:1527
msgid "Split net"
msgstr "Diviser le réseau"
#: ../gui/wxpython/menustrings.py:629 ../gui/wxpython/menustrings.py:1528
-msgid ""
-"Splits net by cost isolines. Splits net to bands between cost isolines "
-"(direction from center). Center node must be opened (costs >= 0). Costs of "
-"center node are used in calculation."
-msgstr ""
-"Couper le réseau selon les isolignes de coût. Coupe le réseau en bandes "
-"entre les isolignes de coût (direction depuis le centre). Le noeud central "
-"doit être ouvert (coût >= 0). Le coût du noeud central est pris en compte "
-"dans le calcul."
+msgid "Splits net by cost isolines. Splits net to bands between cost isolines (direction from center). Center node must be opened (costs >= 0). Costs of center node are used in calculation."
+msgstr "Couper le réseau selon les isolignes de coût. Coupe le réseau en bandes entre les isolignes de coût (direction depuis le centre). Le noeud central doit être ouvert (coût >= 0). Le coût du noeud central est pris en compte dans le calcul."
#: ../gui/wxpython/menustrings.py:630 ../gui/wxpython/menustrings.py:1529
msgid "Shortest path"
@@ -11744,16 +10852,8 @@
msgstr "Plus court chemin pour des jeux d'entités"
#: ../gui/wxpython/menustrings.py:633 ../gui/wxpython/menustrings.py:1532
-msgid ""
-"Computes shortest distance via the network between the given sets of "
-"features. Finds the shortest paths from each 'from' point to the nearest "
-"'to' feature and various information about this relation are uploaded to the "
-"attribute table."
-msgstr ""
-"Calcule la distance la plus proche à travers le réseau entre les jeux "
-"d'entités donnés. Trouve le chemin le plus proche depuis tous les points "
-"'depuis' vers l'entité 'vers' la plus proche et enregistre les informations "
-"sur cette relation dans la table d'attributs."
+msgid "Computes shortest distance via the network between the given sets of features. Finds the shortest paths from each 'from' point to the nearest 'to' feature and various information about this relation are uploaded to the attribute table."
+msgstr "Calcule la distance la plus proche à travers le réseau entre les jeux d'entités donnés. Trouve le chemin le plus proche depuis tous les points 'depuis' vers l'entité 'vers' la plus proche et enregistre les informations sur cette relation dans la table d'attributs."
#: ../gui/wxpython/menustrings.py:634 ../gui/wxpython/menustrings.py:1533
msgid "Shortest path using timetables"
@@ -11769,8 +10869,7 @@
#: ../gui/wxpython/menustrings.py:637 ../gui/wxpython/menustrings.py:1536
msgid "Computes the shortest path between all pairs of nodes in the network."
-msgstr ""
-"Calcule le plus court chemin entre toutes les paires de nœuds du réseau."
+msgstr "Calcule le plus court chemin entre toutes les paires de nœuds du réseau."
#: ../gui/wxpython/menustrings.py:638 ../gui/wxpython/menustrings.py:1537
msgid "Visibility network"
@@ -11802,8 +10901,7 @@
#: ../gui/wxpython/menustrings.py:645 ../gui/wxpython/menustrings.py:1544
msgid "Computes vertex connectivity between two sets of nodes in the network."
-msgstr ""
-"Calcule la connectivité des sommets entre deux jeux de noeuds d'un réseau."
+msgstr "Calcule la connectivité des sommets entre deux jeux de noeuds d'un réseau."
#: ../gui/wxpython/menustrings.py:646 ../gui/wxpython/menustrings.py:1545
msgid "Components"
@@ -11818,27 +10916,16 @@
msgstr "Centralité"
#: ../gui/wxpython/menustrings.py:649 ../gui/wxpython/menustrings.py:1548
-msgid ""
-"Computes degree, centrality, betweeness, closeness and eigenvector "
-"centrality measures in the network."
-msgstr ""
-"Calcule les degré, centralité, intermédiarité, proximité et vecteur propre "
-"des mesures de centralité d'un réseau."
+msgid "Computes degree, centrality, betweeness, closeness and eigenvector centrality measures in the network."
+msgstr "Calcule les degré, centralité, intermédiarité, proximité et vecteur propre des mesures de centralité d'un réseau."
#: ../gui/wxpython/menustrings.py:650 ../gui/wxpython/menustrings.py:1549
msgid "Steiner tree"
msgstr "Arbre de Steiner"
#: ../gui/wxpython/menustrings.py:651 ../gui/wxpython/menustrings.py:1550
-msgid ""
-"Creates Steiner tree for the network and given terminals. Note that 'Minimum "
-"Steiner Tree' problem is NP-hard and heuristic algorithm is used in this "
-"module so the result may be sub optimal."
-msgstr ""
-"Créer l'arbre de Steiner pour le réseau et les points terminaux donnés. Il "
-"est à noter que 'l'arbre de Steiner minimal' est un problème NP complexe et "
-"qu'un algorithme heuristique est utilisé par ce module, le résultat peut "
-"être sous-optimal."
+msgid "Creates Steiner tree for the network and given terminals. Note that 'Minimum Steiner Tree' problem is NP-hard and heuristic algorithm is used in this module so the result may be sub optimal."
+msgstr "Créer l'arbre de Steiner pour le réseau et les points terminaux donnés. Il est à noter que 'l'arbre de Steiner minimal' est un problème NP complexe et qu'un algorithme heuristique est utilisé par ce module, le résultat peut être sous-optimal."
#: ../gui/wxpython/menustrings.py:652 ../gui/wxpython/menustrings.py:1551
msgid "Minimum spanning tree"
@@ -11853,15 +10940,8 @@
msgstr "Analyse de type 'représentant commercial'"
#: ../gui/wxpython/menustrings.py:655 ../gui/wxpython/menustrings.py:1554
-msgid ""
-"Creates a cycle connecting given nodes (Traveling salesman problem). Note "
-"that TSP is NP-hard, heuristic algorithm is used by this module and created "
-"cycle may be sub optimal"
-msgstr ""
-"Créer un cycle connectant les noeuds donnés (problème du représentant "
-"commercial). Il est à noter qu'il s'agit d'une problème NP complexe, un "
-"algorithme heuristique est utilisé par ce module et le résultat peut être "
-"sous optimal."
+msgid "Creates a cycle connecting given nodes (Traveling salesman problem). Note that TSP is NP-hard, heuristic algorithm is used by this module and created cycle may be sub optimal"
+msgstr "Créer un cycle connectant les noeuds donnés (problème du représentant commercial). Il est à noter qu'il s'agit d'une problème NP complexe, un algorithme heuristique est utilisé par ce module et le résultat peut être sous optimal."
#: ../gui/wxpython/menustrings.py:656 ../gui/wxpython/menustrings.py:657
#: ../gui/wxpython/menustrings.py:1555 ../gui/wxpython/menustrings.py:1556
@@ -11890,31 +10970,19 @@
#: ../gui/wxpython/menustrings.py:663 ../gui/wxpython/menustrings.py:1562
msgid "Attaches, deletes or reports vector categories to map geometry."
-msgstr ""
-"Attacher, supprimer ou rendre compte des catégories de vecteur vers la carte "
-"de géométries."
+msgstr "Attacher, supprimer ou rendre compte des catégories de vecteur vers la carte de géométries."
#: ../gui/wxpython/menustrings.py:665 ../gui/wxpython/menustrings.py:1564
-msgid ""
-"Changes vector category values for an existing vector map according to "
-"results of SQL queries or a value in attribute table column."
-msgstr ""
-"Change les valeurs de catégorie pour une carte vecteur existante en fonction "
-"des résultats de requêtes SQL ou d'un valeur dans une colonne de table "
-"attributaire."
+msgid "Changes vector category values for an existing vector map according to results of SQL queries or a value in attribute table column."
+msgstr "Change les valeurs de catégorie pour une carte vecteur existante en fonction des résultats de requêtes SQL ou d'un valeur dans une colonne de table attributaire."
#: ../gui/wxpython/menustrings.py:667 ../gui/wxpython/menustrings.py:1566
msgid "Update area attributes from raster"
msgstr "Mise à jour des attributs surfaciques à partir d'une carte raster"
#: ../gui/wxpython/menustrings.py:668 ../gui/wxpython/menustrings.py:1567
-msgid ""
-"Calculates univariate statistics from a raster map based on a vector map and "
-"uploads statistics to new attribute columns."
-msgstr ""
-"Calculer les statistiques univariées d'une carte raster basées sur une carte "
-"vecteur et ajouter les statistiques dans des nouvelles colonnes "
-"attributaires."
+msgid "Calculates univariate statistics from a raster map based on a vector map and uploads statistics to new attribute columns."
+msgstr "Calculer les statistiques univariées d'une carte raster basées sur une carte vecteur et ajouter les statistiques dans des nouvelles colonnes attributaires."
#: ../gui/wxpython/menustrings.py:669 ../gui/wxpython/menustrings.py:1568
msgid "Update area attributes from vector"
@@ -11922,9 +10990,7 @@
#: ../gui/wxpython/menustrings.py:670 ../gui/wxpython/menustrings.py:1569
msgid "Count points in areas, calculate statistics from point attributes."
-msgstr ""
-"Compter les points dans une surface, calculer les statistiques des attributs "
-"des points."
+msgstr "Compter les points dans une surface, calculer les statistiques des attributs des points."
#: ../gui/wxpython/menustrings.py:671 ../gui/wxpython/menustrings.py:1570
msgid "Update point attributes from areas"
@@ -11932,9 +10998,7 @@
#: ../gui/wxpython/menustrings.py:672 ../gui/wxpython/menustrings.py:1571
msgid "Uploads vector values at positions of vector points to the table."
-msgstr ""
-"Ajouter dans la table les valeurs de vecteur à la position des points du "
-"vecteur."
+msgstr "Ajouter dans la table les valeurs de vecteur à la position des points du vecteur."
#: ../gui/wxpython/menustrings.py:673 ../gui/wxpython/menustrings.py:1572
msgid "Update database values from vector"
@@ -11950,9 +11014,7 @@
#: ../gui/wxpython/menustrings.py:676 ../gui/wxpython/menustrings.py:1575
msgid "Uploads raster values at positions of vector points to the table."
-msgstr ""
-"Ajouter dans la table les valeurs de raster à la position des points du "
-"vecteur."
+msgstr "Ajouter dans la table les valeurs de raster à la position des points du vecteur."
#: ../gui/wxpython/menustrings.py:677 ../gui/wxpython/menustrings.py:1576
msgid "Sample raster neighborhood around points"
@@ -11960,8 +11022,7 @@
#: ../gui/wxpython/menustrings.py:678 ../gui/wxpython/menustrings.py:1577
msgid "Samples a raster map at vector point locations."
-msgstr ""
-"Échantillonne une carte raster au droit des points d'une carte vecteur."
+msgstr "Échantillonne une carte raster au droit des points d'une carte vecteur."
#: ../gui/wxpython/menustrings.py:679 ../gui/wxpython/menustrings.py:1578
msgid "Generate area for current region"
@@ -11988,24 +11049,16 @@
msgstr "Triangles de Delaunay"
#: ../gui/wxpython/menustrings.py:685 ../gui/wxpython/menustrings.py:1584
-msgid ""
-"Creates a Delaunay triangulation from an input vector map containing points "
-"or centroids."
-msgstr ""
-"Crée une triangulation de Delaunay à partir d'une carte vecteur contenant "
-"des points ou centroïdes."
+msgid "Creates a Delaunay triangulation from an input vector map containing points or centroids."
+msgstr "Crée une triangulation de Delaunay à partir d'une carte vecteur contenant des points ou centroïdes."
#: ../gui/wxpython/menustrings.py:686 ../gui/wxpython/menustrings.py:1585
msgid "Voronoi diagram/Thiessen polygons"
msgstr "Diagramme de Voronoï/polygones de Thiessen"
#: ../gui/wxpython/menustrings.py:687 ../gui/wxpython/menustrings.py:1586
-msgid ""
-"Creates a Voronoi diagram in current region from an input vector map "
-"containing points or centroids."
-msgstr ""
-"Crée un diagramme de Voronoï dans la région courante depuis une carte "
-"vecteur contenant des points ou centroïdes."
+msgid "Creates a Voronoi diagram in current region from an input vector map containing points or centroids."
+msgstr "Crée un diagramme de Voronoï dans la région courante depuis une carte vecteur contenant des points ou centroïdes."
#: ../gui/wxpython/menustrings.py:688 ../gui/wxpython/menustrings.py:1587
msgid "Generate grid"
@@ -12024,11 +11077,8 @@
msgstr "Générer à partir d'une base de données"
#: ../gui/wxpython/menustrings.py:692 ../gui/wxpython/menustrings.py:1591
-msgid ""
-"Creates new vector (points) map from database table containing coordinates."
-msgstr ""
-"Crée une nouvelle carte vecteur (points) à partir d'une table de base de "
-"données contenant des coordonnées."
+msgid "Creates new vector (points) map from database table containing coordinates."
+msgstr "Crée une nouvelle carte vecteur (points) à partir d'une table de base de données contenant des coordonnées."
#: ../gui/wxpython/menustrings.py:693 ../gui/wxpython/menustrings.py:1592
msgid "Generate points along lines"
@@ -12036,9 +11086,7 @@
#: ../gui/wxpython/menustrings.py:694 ../gui/wxpython/menustrings.py:1593
msgid "Creates points along input lines in new vector map with 2 layers."
-msgstr ""
-"Créer des points le long d'une ligne d'entrée dans une nouvelle carte "
-"vecteur avec 2 couches."
+msgstr "Créer des points le long d'une ligne d'entrée dans une nouvelle carte vecteur avec 2 couches."
#: ../gui/wxpython/menustrings.py:695 ../gui/wxpython/menustrings.py:1594
msgid "Generate random points"
@@ -12083,9 +11131,7 @@
#: ../gui/wxpython/menustrings.py:707 ../gui/wxpython/menustrings.py:1606
msgid "Classifies attribute data, e.g. for thematic mapping"
-msgstr ""
-"Classifier les données attributaires, par exemple pour une cartographie "
-"thématique"
+msgstr "Classifier les données attributaires, par exemple pour une cartographie thématique"
#: ../gui/wxpython/menustrings.py:708 ../gui/wxpython/menustrings.py:1607
msgid "Report topology by category"
@@ -12101,21 +11147,15 @@
msgstr "Statistiques univariées pour des points"
#: ../gui/wxpython/menustrings.py:711 ../gui/wxpython/menustrings.py:1610
-msgid ""
-"Calculates univariate statistics of vector map features. Variance and "
-"standard deviation is calculated only for points if specified."
-msgstr ""
-"Calcule les statistiques univariées pour les entités. La variance et l'écart-"
-"type sont calculés uniquement pour les points."
+msgid "Calculates univariate statistics of vector map features. Variance and standard deviation is calculated only for points if specified."
+msgstr "Calcule les statistiques univariées pour les entités. La variance et l'écart-type sont calculés uniquement pour les points."
#: ../gui/wxpython/menustrings.py:712 ../gui/wxpython/menustrings.py:1611
msgid "Univariate statistics for attribute columns"
msgstr "Statistiques univariées pour les colonnes d'attributs"
#: ../gui/wxpython/menustrings.py:713 ../gui/wxpython/menustrings.py:1612
-msgid ""
-"Calculates univariate statistics on selected table column for a GRASS vector "
-"map."
+msgid "Calculates univariate statistics on selected table column for a GRASS vector map."
msgstr "Calcule les statistiques univariées sur la colonne sélectionnée."
#: ../gui/wxpython/menustrings.py:714 ../gui/wxpython/menustrings.py:1613
@@ -12168,9 +11208,7 @@
#: ../gui/wxpython/menustrings.py:725 ../gui/wxpython/menustrings.py:1624
#, fuzzy
msgid "Mosaics several images and extends colormap."
-msgstr ""
-"Créer une mosaïque jusqu'à 4 images et étend la table de couleurs; créer une "
-"carte *.mosaic"
+msgstr "Créer une mosaïque jusqu'à 4 images et étend la table de couleurs; créer une carte *.mosaic"
#: ../gui/wxpython/menustrings.py:726 ../gui/wxpython/menustrings.py:1625
msgid "Manage image colors"
@@ -12190,32 +11228,20 @@
msgstr "TSV vers RVB"
#: ../gui/wxpython/menustrings.py:730 ../gui/wxpython/menustrings.py:1629
-msgid ""
-"Transforms raster maps from HIS (Hue-Intensity-Saturation) color space to "
-"RGB (Red-Green-Blue) color space."
-msgstr ""
-"Transforme une carte raster de l'espace colorimétrique TSV (Teinte-"
-"Saturation-Valeur) vers l'espace colorimétrique RVB (Rouge-Vert-Bleu)."
+msgid "Transforms raster maps from HIS (Hue-Intensity-Saturation) color space to RGB (Red-Green-Blue) color space."
+msgstr "Transforme une carte raster de l'espace colorimétrique TSV (Teinte-Saturation-Valeur) vers l'espace colorimétrique RVB (Rouge-Vert-Bleu)."
#: ../gui/wxpython/menustrings.py:732 ../gui/wxpython/menustrings.py:1631
-msgid ""
-"Transforms raster maps from RGB (Red-Green-Blue) color space to HIS (Hue-"
-"Intensity-Saturation) color space."
-msgstr ""
-"Transforme une carte raster de l'espace colorimétrique RVB (Rouge-Vert-Bleu) "
-"vers l'espace colorimétrique TSV (Teinte-Saturation-Valeur)."
+msgid "Transforms raster maps from RGB (Red-Green-Blue) color space to HIS (Hue-Intensity-Saturation) color space."
+msgstr "Transforme une carte raster de l'espace colorimétrique RVB (Rouge-Vert-Bleu) vers l'espace colorimétrique TSV (Teinte-Saturation-Valeur)."
#: ../gui/wxpython/menustrings.py:733 ../gui/wxpython/menustrings.py:1632
msgid "Rectify image or raster"
msgstr "Rectifier une image ou une carte raster"
#: ../gui/wxpython/menustrings.py:734 ../gui/wxpython/menustrings.py:1633
-msgid ""
-"Rectifies an image by computing a coordinate transformation for each pixel "
-"in the image based on the control points."
-msgstr ""
-"Redresse une image en calculant une transformation de coordonnées pour "
-"chaque pixel de l'image basée sur des points de contrôle."
+msgid "Rectifies an image by computing a coordinate transformation for each pixel in the image based on the control points."
+msgstr "Redresse une image en calculant une transformation de coordonnées pour chaque pixel de l'image basée sur des points de contrôle."
#: ../gui/wxpython/menustrings.py:736 ../gui/wxpython/menustrings.py:1635
msgid "Generate histogram of image"
@@ -12226,11 +11252,8 @@
msgstr "Réponse spectrale"
#: ../gui/wxpython/menustrings.py:738 ../gui/wxpython/menustrings.py:1637
-msgid ""
-"Displays spectral response at user specified locations in group or images."
-msgstr ""
-"Affiche la réponse spectrale d'une position données pour un groupe ou une "
-"image."
+msgid "Displays spectral response at user specified locations in group or images."
+msgstr "Affiche la réponse spectrale d'une position données pour un groupe ou une image."
#: ../gui/wxpython/menustrings.py:739 ../gui/wxpython/menustrings.py:1638
#, fuzzy
@@ -12239,12 +11262,8 @@
#: ../gui/wxpython/menustrings.py:740 ../gui/wxpython/menustrings.py:1639
#, fuzzy
-msgid ""
-"Image fusion algorithms to sharpen multispectral with high-res panchromatic "
-"channels"
-msgstr ""
-"Transformation de Brovey pour fusionner des canaux multispectraux et "
-"panchromatique haute résolution."
+msgid "Image fusion algorithms to sharpen multispectral with high-res panchromatic channels"
+msgstr "Transformation de Brovey pour fusionner des canaux multispectraux et panchromatique haute résolution."
#: ../gui/wxpython/menustrings.py:741 ../gui/wxpython/menustrings.py:1640
msgid "Classify image"
@@ -12256,13 +11275,8 @@
#: ../gui/wxpython/menustrings.py:743 ../gui/wxpython/menustrings.py:1642
#, fuzzy
-msgid ""
-"Generates spectral signatures for land cover types in an image using a "
-"clustering algorithm. The resulting signature file is used as input for i."
-"maxlik, to generate an unsupervised image classification."
-msgstr ""
-"Générer les signatures spectrales pour l'occupation des sols dans une image, "
-"à l'aide d'un algorithme de regroupement."
+msgid "Generates spectral signatures for land cover types in an image using a clustering algorithm. The resulting signature file is used as input for i.maxlik, to generate an unsupervised image classification."
+msgstr "Générer les signatures spectrales pour l'occupation des sols dans une image, à l'aide d'un algorithme de regroupement."
#: ../gui/wxpython/menustrings.py:744 ../gui/wxpython/menustrings.py:1643
msgid "Input for supervised MLC"
@@ -12277,14 +11291,8 @@
msgstr "Classification par le maximum de vraissemblance (MLC)"
#: ../gui/wxpython/menustrings.py:747 ../gui/wxpython/menustrings.py:1646
-msgid ""
-"Classifies the cell spectral reflectances in imagery data. Classification is "
-"based on the spectral signature information generated by either i.cluster, g."
-"gui.iclass, or i.gensig."
-msgstr ""
-"Classifie les réflectances spectrales des cellules de donénes d'imagerie. La "
-"classification est basée sur les informations de signatures spectrales "
-"générées soit par i.cluster, g.gui.iclass, ou i.gensig."
+msgid "Classifies the cell spectral reflectances in imagery data. Classification is based on the spectral signature information generated by either i.cluster, g.gui.iclass, or i.gensig."
+msgstr "Classifie les réflectances spectrales des cellules de donénes d'imagerie. La classification est basée sur les informations de signatures spectrales générées soit par i.cluster, g.gui.iclass, ou i.gensig."
#: ../gui/wxpython/menustrings.py:748 ../gui/wxpython/menustrings.py:1647
#: ../gui/wxpython/menustrings.py:1904
@@ -12295,11 +11303,8 @@
#: ../gui/wxpython/menustrings.py:749 ../gui/wxpython/menustrings.py:1648
#: ../gui/wxpython/menustrings.py:1905
#, fuzzy
-msgid ""
-"Generates spectral signatures by allowing the user to outline training areas."
-msgstr ""
-"Générer les signatures spectrales en autorisant l'utilisateur à définir les "
-"zones d'entrainement."
+msgid "Generates spectral signatures by allowing the user to outline training areas."
+msgstr "Générer les signatures spectrales en autorisant l'utilisateur à définir les zones d'entrainement."
#: ../gui/wxpython/menustrings.py:750 ../gui/wxpython/menustrings.py:1649
msgid "Input for supervised SMAP"
@@ -12314,12 +11319,8 @@
msgstr "Classification par le maximum séquentiel à postériori (SMAP)"
#: ../gui/wxpython/menustrings.py:753 ../gui/wxpython/menustrings.py:1652
-msgid ""
-"Performs contextual image classification using sequential maximum a "
-"posteriori (SMAP) estimation."
-msgstr ""
-"Effectue une classification d'image contextuelle, en utilisant l'estimation "
-"du maximum séquentiel à postériori (SMAP)."
+msgid "Performs contextual image classification using sequential maximum a posteriori (SMAP) estimation."
+msgstr "Effectue une classification d'image contextuelle, en utilisant l'estimation du maximum séquentiel à postériori (SMAP)."
#: ../gui/wxpython/menustrings.py:754 ../gui/wxpython/menustrings.py:1653
#, fuzzy
@@ -12340,9 +11341,7 @@
#: ../gui/wxpython/menustrings.py:758 ../gui/wxpython/menustrings.py:1657
msgid "Zero-crossing \"edge detection\" raster function for image processing."
-msgstr ""
-"Fonction raster de \"détection des bords\" sans croisement pour l'analyse "
-"d'images."
+msgstr "Fonction raster de \"détection des bords\" sans croisement pour l'analyse d'images."
#: ../gui/wxpython/menustrings.py:759 ../gui/wxpython/menustrings.py:1658
msgid "Matrix/convolving filter"
@@ -12399,12 +11398,8 @@
#: ../gui/wxpython/menustrings.py:772 ../gui/wxpython/menustrings.py:1671
#, fuzzy
-msgid ""
-"Calculates Top of Atmosphere Radiance/Reflectance/Brightness Temperature "
-"from ASTER DN."
-msgstr ""
-"Calcules les radiance/réflectance/température de luminosité au dessus de "
-"l'atmosphère pour les DN Aster."
+msgid "Calculates Top of Atmosphere Radiance/Reflectance/Brightness Temperature from ASTER DN."
+msgstr "Calcules les radiance/réflectance/température de luminosité au dessus de l'atmosphère pour les DN Aster."
#: ../gui/wxpython/menustrings.py:773 ../gui/wxpython/menustrings.py:1672
msgid "Landsat DN to radiance/reflectance"
@@ -12412,12 +11407,8 @@
#: ../gui/wxpython/menustrings.py:774 ../gui/wxpython/menustrings.py:1673
#, fuzzy
-msgid ""
-"Calculates top-of-atmosphere radiance or reflectance and temperature for "
-"Landsat MSS/TM/ETM+/OLI"
-msgstr ""
-"Calculer la radiance ou la réflectance \"top-of-atmosphere\" et la "
-"température pour les images Landsat MSS/TM/ETM+."
+msgid "Calculates top-of-atmosphere radiance or reflectance and temperature for Landsat MSS/TM/ETM+/OLI"
+msgstr "Calculer la radiance ou la réflectance \"top-of-atmosphere\" et la température pour les images Landsat MSS/TM/ETM+."
#: ../gui/wxpython/menustrings.py:775 ../gui/wxpython/menustrings.py:1674
msgid "Landsat cloud cover assessment"
@@ -12425,9 +11416,7 @@
#: ../gui/wxpython/menustrings.py:776 ../gui/wxpython/menustrings.py:1675
msgid "Performs Landsat TM/ETM+ Automatic Cloud Cover Assessment (ACCA)."
-msgstr ""
-"Effecture une évaluation automatique de la couverture nuageuse (ACCA) pour "
-"Landsat TM/ETM+."
+msgstr "Effecture une évaluation automatique de la couverture nuageuse (ACCA) pour Landsat TM/ETM+."
#: ../gui/wxpython/menustrings.py:777 ../gui/wxpython/menustrings.py:1676
msgid "Modis quality control"
@@ -12444,9 +11433,7 @@
#: ../gui/wxpython/menustrings.py:780 ../gui/wxpython/menustrings.py:1679
#, fuzzy
-msgid ""
-"Performs atmospheric correction using the 6S algorithm. 6S - Second "
-"Simulation of Satellite Signal in the Solar Spectrum."
+msgid "Performs atmospheric correction using the 6S algorithm. 6S - Second Simulation of Satellite Signal in the Solar Spectrum."
msgstr "Effectue une correction atmosphérique par l'algorithme 6S."
#: ../gui/wxpython/menustrings.py:781 ../gui/wxpython/menustrings.py:1680
@@ -12468,13 +11455,8 @@
msgstr "Indices des quadrats"
#: ../gui/wxpython/menustrings.py:785 ../gui/wxpython/menustrings.py:1684
-msgid ""
-"Calculates different types of vegetation indices. Uses red and nir bands "
-"mostly, and some indices require additional bands."
-msgstr ""
-"Calcule différents types d'indices de végétation. Utilise principalement les "
-"bandes rouge et proche infra-rouge, certains indices nécessitent des bandes "
-"supplémentaires."
+msgid "Calculates different types of vegetation indices. Uses red and nir bands mostly, and some indices require additional bands."
+msgstr "Calcule différents types d'indices de végétation. Utilise principalement les bandes rouge et proche infra-rouge, certains indices nécessitent des bandes supplémentaires."
#: ../gui/wxpython/menustrings.py:786 ../gui/wxpython/menustrings.py:1685
msgid "Tasseled cap vegetation index"
@@ -12483,8 +11465,7 @@
#: ../gui/wxpython/menustrings.py:787 ../gui/wxpython/menustrings.py:1686
#, fuzzy
msgid "Performs Tasseled Cap (Kauth Thomas) transformation."
-msgstr ""
-"Transformation de Tasseled cap (Kauth Thomas) pour les données LANDSAT-TM"
+msgstr "Transformation de Tasseled cap (Kauth Thomas) pour les données LANDSAT-TM"
#: ../gui/wxpython/menustrings.py:788 ../gui/wxpython/menustrings.py:1687
msgid "Albedo"
@@ -12502,9 +11483,7 @@
#: ../gui/wxpython/menustrings.py:791 ../gui/wxpython/menustrings.py:1690
msgid "Computes emissivity from NDVI, generic method for sparse land."
-msgstr ""
-"Calcule l'émissivité depuis le NDVI, méthode générique pour les terres "
-"clairsemées."
+msgstr "Calcule l'émissivité depuis le NDVI, méthode générique pour les terres clairsemées."
#: ../gui/wxpython/menustrings.py:792 ../gui/wxpython/menustrings.py:1691
msgid "Biomass growth"
@@ -12512,9 +11491,7 @@
#: ../gui/wxpython/menustrings.py:793 ../gui/wxpython/menustrings.py:1692
msgid "Computes biomass growth, precursor of crop yield calculation."
-msgstr ""
-"Calcule la croissance de la biomasse, un des précurseur du calcul du "
-"rendement d'un champ."
+msgstr "Calcule la croissance de la biomasse, un des précurseur du calcul du rendement d'un champ."
#: ../gui/wxpython/menustrings.py:794 ../gui/wxpython/menustrings.py:1693
msgid "Evapotranspiration calculation"
@@ -12553,12 +11530,8 @@
#: ../gui/wxpython/menustrings.py:802 ../gui/wxpython/menustrings.py:1701
#, fuzzy
-msgid ""
-"Computes evaporative fraction (Bastiaanssen, 1995) and root zone soil "
-"moisture (Makin, Molden and Bastiaanssen, 2001)."
-msgstr ""
-"Calcule la fraction évaporée (Bastiaanssen, 1995) et l'humidité racinaire du "
-"sol (Makin, Molden and Bastiaanssen, 2001)."
+msgid "Computes evaporative fraction (Bastiaanssen, 1995) and root zone soil moisture (Makin, Molden and Bastiaanssen, 2001)."
+msgstr "Calcule la fraction évaporée (Bastiaanssen, 1995) et l'humidité racinaire du sol (Makin, Molden and Bastiaanssen, 2001)."
#: ../gui/wxpython/menustrings.py:803 ../gui/wxpython/menustrings.py:1702
msgid "Actual Evapotranspiration"
@@ -12569,13 +11542,12 @@
msgstr "Évapotranspiration réelle pour la période diurne (Bastiaanssen, 1995)."
#: ../gui/wxpython/menustrings.py:805 ../gui/wxpython/menustrings.py:1704
+#, fuzzy
msgid "Temporal integration of ETa"
-msgstr ""
+msgstr "Intégration temporelle de ETa"
#: ../gui/wxpython/menustrings.py:806 ../gui/wxpython/menustrings.py:1705
-msgid ""
-"Computes temporal integration of satellite ET actual (ETa) following the "
-"daily ET reference (ETo) from meteorological station(s)."
+msgid "Computes temporal integration of satellite ET actual (ETa) following the daily ET reference (ETo) from meteorological station(s)."
msgstr ""
#: ../gui/wxpython/menustrings.py:807 ../gui/wxpython/menustrings.py:1706
@@ -12584,12 +11556,8 @@
#: ../gui/wxpython/menustrings.py:808 ../gui/wxpython/menustrings.py:1707
#, fuzzy
-msgid ""
-"Computes evapotranspiration calculation modified or original Hargreaves "
-"formulation, 2001."
-msgstr ""
-"Calcule l'évapotranspiration selon la formule de Hargreaves originale ou "
-"modifiée, 2001."
+msgid "Computes evapotranspiration calculation modified or original Hargreaves formulation, 2001."
+msgstr "Calcule l'évapotranspiration selon la formule de Hargreaves originale ou modifiée, 2001."
#: ../gui/wxpython/menustrings.py:809 ../gui/wxpython/menustrings.py:1708
msgid "Penman-Monteith Evapotranspiration"
@@ -12597,12 +11565,8 @@
#: ../gui/wxpython/menustrings.py:810 ../gui/wxpython/menustrings.py:1709
#, fuzzy
-msgid ""
-"Computes potential evapotranspiration calculation with hourly Penman-"
-"Monteith."
-msgstr ""
-"Calcule le potentiel d'évapotranspiration avec la méthode horaire Penman-"
-"Monteith."
+msgid "Computes potential evapotranspiration calculation with hourly Penman-Monteith."
+msgstr "Calcule le potentiel d'évapotranspiration avec la méthode horaire Penman-Monteith."
#: ../gui/wxpython/menustrings.py:811 ../gui/wxpython/menustrings.py:1710
msgid "Priestley-Taylor Evapotranspiration"
@@ -12610,23 +11574,16 @@
#: ../gui/wxpython/menustrings.py:812 ../gui/wxpython/menustrings.py:1711
#, fuzzy
-msgid ""
-"Computes evapotranspiration calculation Priestley and Taylor formulation, "
-"1972."
-msgstr ""
-"Calcule l'évapotranspiration selon la formule de Priestley et Taylor, 1972."
+msgid "Computes evapotranspiration calculation Priestley and Taylor formulation, 1972."
+msgstr "Calcule l'évapotranspiration selon la formule de Priestley et Taylor, 1972."
#: ../gui/wxpython/menustrings.py:814 ../gui/wxpython/menustrings.py:1713
msgid "Kappa analysis"
msgstr "Analyse Kappa"
#: ../gui/wxpython/menustrings.py:815 ../gui/wxpython/menustrings.py:1714
-msgid ""
-"Calculates error matrix and kappa parameter for accuracy assessment of "
-"classification result."
-msgstr ""
-"Calcule la matrice de confusion et le paramètre kappa pour l'évaluation de "
-"l'exactitude des résultats de classification."
+msgid "Calculates error matrix and kappa parameter for accuracy assessment of classification result."
+msgstr "Calcule la matrice de confusion et le paramètre kappa pour l'évaluation de l'exactitude des résultats de classification."
#: ../gui/wxpython/menustrings.py:816 ../gui/wxpython/menustrings.py:1715
msgid "OIF for LandSat TM"
@@ -12635,9 +11592,7 @@
#: ../gui/wxpython/menustrings.py:817 ../gui/wxpython/menustrings.py:1716
#, fuzzy
msgid "Calculates Optimum-Index-Factor table for spectral bands"
-msgstr ""
-"Calcule la table de facteur d'index optimal pour les bandes 1-5 et 7 de "
-"Landsat TM."
+msgstr "Calcule la table de facteur d'index optimal pour les bandes 1-5 et 7 de Landsat TM."
#: ../gui/wxpython/menustrings.py:818 ../gui/wxpython/menustrings.py:1717
#, fuzzy
@@ -12710,33 +11665,21 @@
#: ../gui/wxpython/menustrings.py:836 ../gui/wxpython/menustrings.py:1735
#, fuzzy
-msgid ""
-"Creates cross section 2D raster map from 3D raster map based on 2D elevation "
-"map"
-msgstr ""
-"Créer une section de coupe 2D depuis une carte raster 3D et une carte "
-"d'altitude 2D"
+msgid "Creates cross section 2D raster map from 3D raster map based on 2D elevation map"
+msgstr "Créer une section de coupe 2D depuis une carte raster 3D et une carte d'altitude 2D"
#: ../gui/wxpython/menustrings.py:838 ../gui/wxpython/menustrings.py:1737
#, fuzzy
-msgid ""
-"Numerical calculation program for transient, confined groundwater flow in "
-"three dimensions."
-msgstr ""
-"Calcul numérique pour les eaux souterraines transitoires, confinées et non "
-"confinées, en deux dimensions."
+msgid "Numerical calculation program for transient, confined groundwater flow in three dimensions."
+msgstr "Calcul numérique pour les eaux souterraines transitoires, confinées et non confinées, en deux dimensions."
#: ../gui/wxpython/menustrings.py:839 ../gui/wxpython/menustrings.py:1738
msgid "Interpolate 3D raster from points"
msgstr "Interpoler un raster 3D depuis des points"
#: ../gui/wxpython/menustrings.py:840 ../gui/wxpython/menustrings.py:1739
-msgid ""
-"Interpolates point data to a 3D raster map using regularized spline with "
-"tension (RST) algorithm."
-msgstr ""
-"Interpoler des données points vers une carte raster 3D, en utilisant "
-"l'algorithme des splines régulées avec tension (RST)."
+msgid "Interpolates point data to a 3D raster map using regularized spline with tension (RST) algorithm."
+msgstr "Interpoler des données points vers une carte raster 3D, en utilisant l'algorithme des splines régulées avec tension (RST)."
#: ../gui/wxpython/menustrings.py:841 ../gui/wxpython/menustrings.py:1740
msgid "Reports and Statistics"
@@ -12763,16 +11706,8 @@
msgstr "Statistiques univariées pour les raster 3D"
#: ../gui/wxpython/menustrings.py:847 ../gui/wxpython/menustrings.py:1746
-msgid ""
-"Calculates univariate statistics from the non-null cells of a 3D raster map. "
-msgstr ""
-"raster 3D. Les statiqtiques incluent le nombre de cellules, les valeurs "
-"l'écart type, le coefficient de variation, et la somme."
+msgid "Calculates univariate statistics from the non-null cells of a 3D raster map. Statistics include number of cells counted, minimum and maximum cell values, range, arithmetic mean, population variance, standard deviation, coefficient of variation, and sum."
+msgstr "Calcule les statistiques univariées pour les cellules non nulles d'une carte raster 3D. Les statiqtiques incluent le nombre de cellules, les valeurs minimales et maximales, la plage, la moyenne arithmétique, la variance, l'écart type, le coefficient de variation, et la somme."
#: ../gui/wxpython/menustrings.py:848 ../gui/wxpython/menustrings.py:1747
msgid "&Database"
@@ -12788,8 +11723,7 @@
#: ../gui/wxpython/menustrings.py:851 ../gui/wxpython/menustrings.py:1750
msgid "Lists all databases for a given driver and location."
-msgstr ""
-"Lister toutes les bases de données pour un pilote et un secteur donnés."
+msgstr "Lister toutes les bases de données pour un pilote et un secteur donnés."
#: ../gui/wxpython/menustrings.py:852 ../gui/wxpython/menustrings.py:1751
msgid "List drivers"
@@ -12833,8 +11767,7 @@
#: ../gui/wxpython/menustrings.py:862 ../gui/wxpython/menustrings.py:1761
msgid "Prints/sets general DB connection for current mapset."
-msgstr ""
-"Afficher/définir la connecion DB générale pour le jeu de cartes courant."
+msgstr "Afficher/définir la connecion DB générale pour le jeu de cartes courant."
#: ../gui/wxpython/menustrings.py:863 ../gui/wxpython/menustrings.py:1762
msgid "Login"
@@ -12873,13 +11806,8 @@
msgstr "Copier la table"
#: ../gui/wxpython/menustrings.py:872 ../gui/wxpython/menustrings.py:1771
-msgid ""
-"Copy a table. Either 'from_table' (optionally with 'where') can be used or "
-"'select' option, but not 'from_table' and 'select' at the same time."
-msgstr ""
-"Copier une table. Soit 'depuis_table' (en option avec 'where') peut être "
-"utilisé ou l'option 'select', mais pas 'depuis_table' et 'select' en même "
-"temps."
+msgid "Copy a table. Either 'from_table' (optionally with 'where') can be used or 'select' option, but not 'from_table' and 'select' at the same time."
+msgstr "Copier une table. Soit 'depuis_table' (en option avec 'where') peut être utilisé ou l'option 'select', mais pas 'depuis_table' et 'select' en même temps."
#: ../gui/wxpython/menustrings.py:873 ../gui/wxpython/menustrings.py:893
#: ../gui/wxpython/menustrings.py:1772 ../gui/wxpython/menustrings.py:1792
@@ -12896,9 +11824,7 @@
#: ../gui/wxpython/menustrings.py:876 ../gui/wxpython/menustrings.py:1775
msgid "Test database driver, database must exist and set by db.connect."
-msgstr ""
-"Tester un pilote de base de données ; la base doit exister et être connectée "
-"via db.connect"
+msgstr "Tester un pilote de base de données ; la base doit exister et être connectée via db.connect"
#: ../gui/wxpython/menustrings.py:878 ../gui/wxpython/menustrings.py:1777
msgid "Query any table"
@@ -12906,8 +11832,7 @@
#: ../gui/wxpython/menustrings.py:879 ../gui/wxpython/menustrings.py:1778
msgid "Selects data from attribute table. Performs SQL query statement(s)."
-msgstr ""
-"Sélectionne des données d'une table attributaire. Exécute des requêtes SQL."
+msgstr "Sélectionne des données d'une table attributaire. Exécute des requêtes SQL."
#: ../gui/wxpython/menustrings.py:882 ../gui/wxpython/menustrings.py:1781
msgid "SQL statement"
@@ -12915,9 +11840,7 @@
#: ../gui/wxpython/menustrings.py:883 ../gui/wxpython/menustrings.py:1782
msgid "Executes any SQL statement. For SELECT statements use 'db.select'."
-msgstr ""
-"Exécute n'importe qu'elle requête SQL. Pour une requête SELECT utiliser 'db."
-"select'."
+msgstr "Exécute n'importe qu'elle requête SQL. Pour une requête SELECT utiliser 'db.select'."
#: ../gui/wxpython/menustrings.py:884 ../gui/wxpython/menustrings.py:1783
msgid "Vector database connections"
@@ -12928,12 +11851,8 @@
msgstr "Nouvelle table"
#: ../gui/wxpython/menustrings.py:886 ../gui/wxpython/menustrings.py:1785
-msgid ""
-"Creates and connects a new attribute table to a given layer of an existing "
-"vector map."
-msgstr ""
-"Créée et connecte une table attributaire à une couche donnée d'une carte "
-"vecteur existante."
+msgid "Creates and connects a new attribute table to a given layer of an existing vector map."
+msgstr "Créée et connecte une table attributaire à une couche donnée d'une carte vecteur existante."
#: ../gui/wxpython/menustrings.py:887 ../gui/wxpython/menustrings.py:1786
msgid "Remove table"
@@ -12956,26 +11875,16 @@
msgstr "Ajouter des colonnes"
#: ../gui/wxpython/menustrings.py:892 ../gui/wxpython/menustrings.py:1791
-msgid ""
-"Adds one or more columns to the attribute table connected to a given vector "
-"map."
-msgstr ""
-"Ajoute une ou des colonnes à la table attributaire connectée à une carte "
-"vecteur donnée."
+msgid "Adds one or more columns to the attribute table connected to a given vector map."
+msgstr "Ajoute une ou des colonnes à la table attributaire connectée à une carte vecteur donnée."
#: ../gui/wxpython/menustrings.py:894 ../gui/wxpython/menustrings.py:1793
-msgid ""
-"Drops a column from the attribute table connected to a given vector map."
-msgstr ""
-"Supprime une colonne d'une table attributaire connectée à une carte vecteur "
-"donnée."
+msgid "Drops a column from the attribute table connected to a given vector map."
+msgstr "Supprime une colonne d'une table attributaire connectée à une carte vecteur donnée."
#: ../gui/wxpython/menustrings.py:896 ../gui/wxpython/menustrings.py:1795
-msgid ""
-"Renames a column in the attribute table connected to a given vector map."
-msgstr ""
-"Renomme une colonne dans une table attributaire connectée à une carte "
-"vecteur donnée."
+msgid "Renames a column in the attribute table connected to a given vector map."
+msgstr "Renomme une colonne dans une table attributaire connectée à une carte vecteur donnée."
#: ../gui/wxpython/menustrings.py:897 ../gui/wxpython/menustrings.py:1796
msgid "Change values"
@@ -12983,9 +11892,7 @@
#: ../gui/wxpython/menustrings.py:898 ../gui/wxpython/menustrings.py:1797
msgid "Updates a column in the attribute table connected to a vector map."
-msgstr ""
-"Met à jour une colonne dans la table attributaire connectée à une carte "
-"vecteur."
+msgstr "Met à jour une colonne dans la table attributaire connectée à une carte vecteur."
#: ../gui/wxpython/menustrings.py:899 ../gui/wxpython/menustrings.py:1798
msgid "Drop row"
@@ -12993,20 +11900,15 @@
#: ../gui/wxpython/menustrings.py:900 ../gui/wxpython/menustrings.py:1799
msgid "Removes a vector feature from a vector map through attribute selection."
-msgstr ""
-"Supprime une entité d'une carte vecteur par sélection de ses attributs."
+msgstr "Supprime une entité d'une carte vecteur par sélection de ses attributs."
#: ../gui/wxpython/menustrings.py:901 ../gui/wxpython/menustrings.py:1800
msgid "Reconnect vectors to database"
msgstr "Reconnecter des cartes vecteur à une base de données"
#: ../gui/wxpython/menustrings.py:902 ../gui/wxpython/menustrings.py:1801
-msgid ""
-"Reconnects attribute tables for all vector maps from the current mapset to a "
-"new database."
-msgstr ""
-"Reconnecter les tables attributaires pour toutes les cartes vecteur du jeu "
-"de données actuel vers une nouvelle base de données."
+msgid "Reconnects attribute tables for all vector maps from the current mapset to a new database."
+msgstr "Reconnecter les tables attributaires pour toutes les cartes vecteur du jeu de données actuel vers une nouvelle base de données."
#: ../gui/wxpython/menustrings.py:903 ../gui/wxpython/menustrings.py:1802
msgid "Set vector map - database connection"
@@ -13014,9 +11916,7 @@
#: ../gui/wxpython/menustrings.py:904 ../gui/wxpython/menustrings.py:1803
msgid "Prints/sets DB connection for a vector map to attribute table."
-msgstr ""
-"Afficher/définir les connexions base de données pour la table d'attributs de "
-"la carte vecteur."
+msgstr "Afficher/définir les connexions base de données pour la table d'attributs de la carte vecteur."
#: ../gui/wxpython/menustrings.py:905 ../gui/wxpython/menustrings.py:1804
msgid "&Temporal"
@@ -13036,8 +11936,7 @@
#: ../gui/wxpython/menustrings.py:912 ../gui/wxpython/menustrings.py:1811
msgid "Removes space time datasets from temporal database."
-msgstr ""
-"Supprimer des jeux de données temporels de la base de donénes temporelle."
+msgstr "Supprimer des jeux de données temporels de la base de donénes temporelle."
#: ../gui/wxpython/menustrings.py:913 ../gui/wxpython/menustrings.py:1812
msgid "Update metadata"
@@ -13053,17 +11952,17 @@
#: ../gui/wxpython/menustrings.py:916 ../gui/wxpython/menustrings.py:1815
msgid "Merges several space time datasets into a single space time dataset."
-msgstr ""
-"Fusionner plusieurs jeux de données temporels vers un seul jeu de données "
-"temporel."
+msgstr "Fusionner plusieurs jeux de données temporels vers un seul jeu de données temporel."
#: ../gui/wxpython/menustrings.py:917 ../gui/wxpython/menustrings.py:1816
+#, fuzzy
msgid "Temporally shift"
-msgstr ""
+msgstr "Déplacement temporel"
#: ../gui/wxpython/menustrings.py:918 ../gui/wxpython/menustrings.py:1817
+#, fuzzy
msgid "Shifts temporally the maps of a space time dataset."
-msgstr ""
+msgstr "Déplacer temporellement les cartes d'un jeu de données temporel."
#: ../gui/wxpython/menustrings.py:919 ../gui/wxpython/menustrings.py:1818
msgid "Snap maps of dataset"
@@ -13074,48 +11973,51 @@
msgstr ""
#: ../gui/wxpython/menustrings.py:922 ../gui/wxpython/menustrings.py:1821
+#, fuzzy
msgid "Lists space time datasets and maps registered in the temporal database."
-msgstr ""
+msgstr "Lister les jeux de données temporels et cartes enregistrées dans la base de données temporelle."
#: ../gui/wxpython/menustrings.py:923 ../gui/wxpython/menustrings.py:1822
+#, fuzzy
msgid "Manage maps in datasets"
-msgstr ""
+msgstr "Gérer les cartes dans le jeu de données"
#: ../gui/wxpython/menustrings.py:924 ../gui/wxpython/menustrings.py:1823
+#, fuzzy
msgid "Register maps in datasets"
-msgstr ""
+msgstr "Enregistrer des cartes dans les jeux de données"
#: ../gui/wxpython/menustrings.py:925 ../gui/wxpython/menustrings.py:1824
msgid "Registers raster, vector and raster3d maps in a space time datasets."
-msgstr ""
-"Enregistrer des cartes raster, vecteur et raster3D dans un jeu de données "
-"temporel."
+msgstr "Enregistrer des cartes raster, vecteur et raster3D dans un jeu de données temporel."
#: ../gui/wxpython/menustrings.py:926 ../gui/wxpython/menustrings.py:1825
msgid "Unregister maps from datasets"
msgstr ""
#: ../gui/wxpython/menustrings.py:927 ../gui/wxpython/menustrings.py:1826
-msgid ""
-"Unregisters raster, vector and raster3d maps from the temporal database or a "
-"specific space time dataset."
+msgid "Unregisters raster, vector and raster3d maps from the temporal database or a specific space time dataset."
msgstr ""
#: ../gui/wxpython/menustrings.py:928 ../gui/wxpython/menustrings.py:1827
+#, fuzzy
msgid "List raster dataset maps"
-msgstr ""
+msgstr "Lister les rasters du jeu de données"
#: ../gui/wxpython/menustrings.py:929 ../gui/wxpython/menustrings.py:1828
+#, fuzzy
msgid "Lists registered maps of a space time raster dataset."
-msgstr ""
+msgstr "Lister les cartes enregistrées dans le jeu de données raster temporel."
#: ../gui/wxpython/menustrings.py:930 ../gui/wxpython/menustrings.py:1829
+#, fuzzy
msgid "List vector dataset maps"
-msgstr ""
+msgstr "Lister les vecteurs du jeu de données"
#: ../gui/wxpython/menustrings.py:931 ../gui/wxpython/menustrings.py:1830
+#, fuzzy
msgid "Lists registered maps of a space time vector dataset."
-msgstr ""
+msgstr "Lister les cartes enregistrées dans le jeux de données vecteur temporel."
#: ../gui/wxpython/menustrings.py:932 ../gui/wxpython/menustrings.py:1831
msgid "List raster3D dataset maps"
@@ -13143,8 +12045,7 @@
#: ../gui/wxpython/menustrings.py:938 ../gui/wxpython/menustrings.py:1837
#, fuzzy
-msgid ""
-"Imports a space time vector dataset from a GRASS GIS specific archive file."
+msgid "Imports a space time vector dataset from a GRASS GIS specific archive file."
msgstr "Importer des données vectorielles"
#: ../gui/wxpython/menustrings.py:940 ../gui/wxpython/menustrings.py:1839
@@ -13200,12 +12101,14 @@
msgstr ""
#: ../gui/wxpython/menustrings.py:953 ../gui/wxpython/menustrings.py:1852
+#, fuzzy
msgid "Extract subset of raster3D dataset"
-msgstr ""
+msgstr "Extraire une sous-partie du jeu de données raster3D"
#: ../gui/wxpython/menustrings.py:954 ../gui/wxpython/menustrings.py:1853
+#, fuzzy
msgid "Extracts a subset of a space time 3D raster dataset."
-msgstr ""
+msgstr "Extraire une sous-partie du jeu de données raster 3D temporel."
#: ../gui/wxpython/menustrings.py:955 ../gui/wxpython/menustrings.py:1854
#, fuzzy
@@ -13213,8 +12116,7 @@
msgstr "Interroger la carte vecteur depuis la table d'attributs"
#: ../gui/wxpython/menustrings.py:956 ../gui/wxpython/menustrings.py:1855
-msgid ""
-"Prints attributes of vector maps registered in a space time vector dataset."
+msgid "Prints attributes of vector maps registered in a space time vector dataset."
msgstr ""
#: ../gui/wxpython/menustrings.py:957 ../gui/wxpython/menustrings.py:1856
@@ -13224,9 +12126,7 @@
#: ../gui/wxpython/menustrings.py:958 ../gui/wxpython/menustrings.py:1857
#, fuzzy
-msgid ""
-"Creates/modifies the color table associated with each raster map of the "
-"space time raster dataset."
+msgid "Creates/modifies the color table associated with each raster map of the space time raster dataset."
msgstr "Crée/modifie la table de couleur associée à une carte raster."
#: ../gui/wxpython/menustrings.py:959 ../gui/wxpython/menustrings.py:1858
@@ -13235,9 +12135,7 @@
#: ../gui/wxpython/menustrings.py:960 ../gui/wxpython/menustrings.py:1859
#, fuzzy
-msgid ""
-"Performs spatio-temporal mapcalc expressions on temporally sampled maps of "
-"space time raster datasets."
+msgid "Performs spatio-temporal mapcalc expressions on temporally sampled maps of space time raster datasets."
msgstr "Importer une carte raster"
#: ../gui/wxpython/menustrings.py:961 ../gui/wxpython/menustrings.py:1860
@@ -13246,9 +12144,7 @@
#: ../gui/wxpython/menustrings.py:962 ../gui/wxpython/menustrings.py:1861
#, fuzzy
-msgid ""
-"Performs r3.mapcalc expressions on maps of sampled space time 3D raster "
-"datasets."
+msgid "Performs r3.mapcalc expressions on maps of sampled space time 3D raster datasets."
#: ../gui/wxpython/menustrings.py:963 ../gui/wxpython/menustrings.py:1862
@@ -13258,8 +12154,7 @@
#: ../gui/wxpython/menustrings.py:964 ../gui/wxpython/menustrings.py:1863
#, fuzzy
-msgid ""
-"Replaces gaps in a space time raster dataset with interpolated raster maps."
+msgid "Replaces gaps in a space time raster dataset with interpolated raster maps."
msgstr "Convertir une carte vecteur en carte raster."
#: ../gui/wxpython/menustrings.py:965 ../gui/wxpython/menustrings.py:1864
@@ -13273,11 +12168,8 @@
msgstr "Analyse de voisinage"
#: ../gui/wxpython/menustrings.py:967 ../gui/wxpython/menustrings.py:1866
-msgid ""
-"Performs a neighborhood analysis for each map in a space time raster dataset."
-msgstr ""
-"Effectuer une analyse de voisinage pour chaque carte d'un jeu de données "
-"temporel."
+msgid "Performs a neighborhood analysis for each map in a space time raster dataset."
+msgstr "Effectuer une analyse de voisinage pour chaque carte d'un jeu de données temporel."
#: ../gui/wxpython/menustrings.py:968 ../gui/wxpython/menustrings.py:1867
#, fuzzy
@@ -13286,12 +12178,8 @@
#: ../gui/wxpython/menustrings.py:969 ../gui/wxpython/menustrings.py:1868
#, fuzzy
-msgid ""
-"Performs different aggregation algorithms from r.series on all or a subset "
-"of raster maps in a space time raster dataset."
-msgstr ""
-"Effectue différents algorithmes d'aggrégation depuis r.series ou a sous-jeu "
-"de cartes raster dans un jeu de données raster temporels."
+msgid "Performs different aggregation algorithms from r.series on all or a subset of raster maps in a space time raster dataset."
+msgstr "Effectue différents algorithmes d'aggrégation depuis r.series ou a sous-jeu de cartes raster dans un jeu de données raster temporels."
#: ../gui/wxpython/menustrings.py:970 ../gui/wxpython/menustrings.py:1869
#, fuzzy
@@ -13300,9 +12188,7 @@
#: ../gui/wxpython/menustrings.py:971 ../gui/wxpython/menustrings.py:1870
#, fuzzy
-msgid ""
-"Aggregates temporally the maps of a space time raster dataset by a user "
-"defined granularity."
+msgid "Aggregates temporally the maps of a space time raster dataset by a user defined granularity."
#: ../gui/wxpython/menustrings.py:972 ../gui/wxpython/menustrings.py:1871
@@ -13312,12 +12198,8 @@
#: ../gui/wxpython/menustrings.py:973 ../gui/wxpython/menustrings.py:1872
#, fuzzy
-msgid ""
-"Aggregates data of an existing space time raster dataset using the time "
-"intervals of a second space time dataset."
-msgstr ""
-"Aggrégation de données d'un jeu de données raster temporel en utilisant le "
-"temps d'intervale d'un second jeu de données temporel."
+msgid "Aggregates data of an existing space time raster dataset using the time intervals of a second space time dataset."
+msgstr "Aggrégation de données d'un jeu de données raster temporel en utilisant le temps d'intervale d'un second jeu de données temporel."
#: ../gui/wxpython/menustrings.py:974 ../gui/wxpython/menustrings.py:1873
#, fuzzy
@@ -13331,39 +12213,26 @@
#: ../gui/wxpython/menustrings.py:976 ../gui/wxpython/menustrings.py:1875
#, fuzzy
-msgid ""
-"Samples the input space time dataset(s) with a sample space time dataset and "
-"print the result to stdout."
-msgstr ""
-"Échantillone un jeu de données temporel d'entrée avec un échantillon de jeu "
-"de données temporel et affiche le résultat dans la sortie standard."
+msgid "Samples the input space time dataset(s) with a sample space time dataset and print the result to stdout."
+msgstr "Échantillone un jeu de données temporel d'entrée avec un échantillon de jeu de données temporel et affiche le résultat dans la sortie standard."
#: ../gui/wxpython/menustrings.py:977 ../gui/wxpython/menustrings.py:1876
#, fuzzy
msgid "Query raster dataset by vector points dataset"
-msgstr ""
#: ../gui/wxpython/menustrings.py:978 ../gui/wxpython/menustrings.py:1877
#, fuzzy
-msgid ""
-"Stores raster map values at spatial and temporal positions of vector points "
-"as vector attributes."
-msgstr ""
-"vecteur."
+msgid "Stores raster map values at spatial and temporal positions of vector points as vector attributes."
#: ../gui/wxpython/menustrings.py:979 ../gui/wxpython/menustrings.py:1878
msgid "Observe specific locations in raster dataset"
msgstr "Observer un secteur spécifique dans le jeu de données raster"
#: ../gui/wxpython/menustrings.py:980 ../gui/wxpython/menustrings.py:1879
-msgid ""
-"Observes specific locations in a space time raster dataset over a period of "
-"time using vector points."
-msgstr ""
-"Observer un jeu de données spécifique dans un jeu de données raster temporel "
-"sur une période de temps en utilisant un vecteur de points."
+msgid "Observes specific locations in a space time raster dataset over a period of time using vector points."
+msgstr "Observer un jeu de données spécifique dans un jeu de données raster temporel sur une période de temps en utilisant un vecteur de points."
#: ../gui/wxpython/menustrings.py:982 ../gui/wxpython/menustrings.py:1881
#, fuzzy
@@ -13382,12 +12251,8 @@
#: ../gui/wxpython/menustrings.py:985 ../gui/wxpython/menustrings.py:1884
#, fuzzy
-msgid ""
-"Calculates univariate statistics from the non-null cells for each registered "
-"raster map of a space time raster dataset."
-msgstr ""
-"Calculer les statistiques univariées pour les cellules non nulles de la "
-"carte raster."
+msgid "Calculates univariate statistics from the non-null cells for each registered raster map of a space time raster dataset."
+msgstr "Calculer les statistiques univariées pour les cellules non nulles de la carte raster."
#: ../gui/wxpython/menustrings.py:986 ../gui/wxpython/menustrings.py:1885
#, fuzzy
@@ -13396,9 +12261,7 @@
#: ../gui/wxpython/menustrings.py:987 ../gui/wxpython/menustrings.py:1886
#, fuzzy
-msgid ""
-"Calculates univariate statistics of attributes for each registered vector "
-"map of a space time vector dataset"
+msgid "Calculates univariate statistics of attributes for each registered vector map of a space time vector dataset"
#: ../gui/wxpython/menustrings.py:988 ../gui/wxpython/menustrings.py:1887
@@ -13408,12 +12271,8 @@
#: ../gui/wxpython/menustrings.py:989 ../gui/wxpython/menustrings.py:1888
#, fuzzy
-msgid ""
-"3D raster map of a space time 3D raster dataset."
-msgstr ""
-"carte raster."
+msgid "Calculates univariate statistics from the non-null cells for each registered 3D raster map of a space time 3D raster dataset."
#: ../gui/wxpython/menustrings.py:990 ../gui/wxpython/menustrings.py:1889
#, fuzzy
@@ -13734,12 +12593,8 @@
msgstr "Fichier &Log"
#: ../gui/wxpython/gui_core/goutput.py:149
-msgid ""
-"Toggle to save list of executed commands into a file; content saved when "
-"switching off."
-msgstr ""
-"Basculer l'enregistrement de la liste des commandes exécutées dans le "
-"fichier; le contenu est enregistré lorsque désactivé."
+msgid "Toggle to save list of executed commands into a file; content saved when switching off."
+msgstr "Basculer l'enregistrement de la liste des commandes exécutées dans le fichier; le contenu est enregistré lorsque désactivé."
#: ../gui/wxpython/gui_core/goutput.py:374
#: ../gui/wxpython/gui_core/goutput.py:461
@@ -13860,9 +12715,7 @@
#: ../gui/wxpython/gui_core/preferences.py:305
msgid "Automatically copy selected text to clipboard (in Command console)"
-msgstr ""
-"Copier automatiquement le texte dans le bloc-notes (dans la console de "
-"commande)"
+msgstr "Copier automatiquement le texte dans le bloc-notes (dans la console de commande)"
#: ../gui/wxpython/gui_core/preferences.py:320
msgid "Workspace settings"
@@ -13881,13 +12734,8 @@
msgstr "Enregistrer la configuration de fenêtre actuelle comme défaut"
#: ../gui/wxpython/gui_core/preferences.py:353
-msgid ""
-"Save current position and size of Layer Manager window and opened Map "
-"Display window(s) and use as default for next sessions."
-msgstr ""
-"Enregistrer les positions et tailles actuelles de la fenêtre de gestionnaire "
-"de couches et de la (des) fenêtre(s) d'affichage de carte ; utiliser par "
-"défaut pour les sessions suivantes."
+msgid "Save current position and size of Layer Manager window and opened Map Display window(s) and use as default for next sessions."
+msgstr "Enregistrer les positions et tailles actuelles de la fenêtre de gestionnaire de couches et de la (des) fenêtre(s) d'affichage de carte ; utiliser par défaut pour les sessions suivantes."
#: ../gui/wxpython/gui_core/preferences.py:372
#: ../gui/wxpython/nviz/tools.py:96
@@ -14049,8 +12897,7 @@
#: ../gui/wxpython/gui_core/preferences.py:1089
msgid "Automatically hightlight selected features in map display"
-msgstr ""
-"Surligner automatiquement les entités sélectionnées dans la fenêtre de cartes"
+msgstr "Surligner automatiquement les entités sélectionnées dans la fenêtre de cartes"
#: ../gui/wxpython/gui_core/preferences.py:1109
msgid "Data browser"
@@ -14084,21 +12931,15 @@
#: ../gui/wxpython/gui_core/preferences.py:1207
msgid ""
"\n"
-"Note: This only controls the coordinates displayed in the lower-left of the "
-"Map Display\n"
-"window's status bar. It is purely cosmetic and does not affect the working "
-"location's\n"
-"projection in any way. You will need to enable the Projection check box in "
-"the drop-down\n"
+"Note: This only controls the coordinates displayed in the lower-left of the Map Display\n"
+"window's status bar. It is purely cosmetic and does not affect the working location's\n"
+"projection in any way. You will need to enable the Projection check box in the drop-down\n"
"menu located at the bottom of the Map Display window.\n"
msgstr ""
"\n"
-"Note : Ceci contrôle uniquement les coordonnées affichées dans le coin "
-"inférieur gauche\n"
-" de la fenêtre de Carte. L'effet est purement cosméthique et n'affecte pas "
-"la projection\n"
-" du secteur d'aucune manière. Vous devrez cocher la case Projection dans le "
-"menu déroulant\n"
+"Note : Ceci contrôle uniquement les coordonnées affichées dans le coin inférieur gauche\n"
+" de la fenêtre de Carte. L'effet est purement cosméthique et n'affecte pas la projection\n"
+" du secteur d'aucune manière. Vous devrez cocher la case Projection dans le menu déroulant\n"
" en bas de la fenêtre de carte.\n"
#: ../gui/wxpython/gui_core/preferences.py:1222
@@ -14115,12 +12956,8 @@
msgstr "Fichier EPSG :"
#: ../gui/wxpython/gui_core/preferences.py:1270
-msgid ""
-"Load EPSG codes (be patient), enter EPSG code or insert Proj.4 string "
-"directly."
-msgstr ""
-"Charger les codes EPSG (patience), entrer le code EPSG ou insérer la chaîne "
-"Proj.4 directement."
+msgid "Load EPSG codes (be patient), enter EPSG code or insert Proj.4 string directly."
+msgstr "Charger les codes EPSG (patience), entrer le code EPSG ou insérer la chaîne Proj.4 directement."
#: ../gui/wxpython/gui_core/preferences.py:1278
msgid "&Load EPSG codes"
@@ -14156,9 +12993,7 @@
#: ../gui/wxpython/gui_core/preferences.py:1449
msgid "Failed to set default display font. Try different font."
-msgstr ""
-"Impossible de définir la police de caractères par défaut. Essayez une police "
-"de caractère différente."
+msgstr "Impossible de définir la police de caractères par défaut. Essayez une police de caractère différente."
#: ../gui/wxpython/gui_core/preferences.py:1549
msgid "Select font:"
@@ -14201,8 +13036,7 @@
#: ../gui/wxpython/gui_core/query.py:40
msgid "Right click to copy selected values to clipboard."
-msgstr ""
-"Clic droit pour copier les valeurs sélectionnées vers le presse-papier."
+msgstr "Clic droit pour copier les valeurs sélectionnées vers le presse-papier."
#: ../gui/wxpython/gui_core/query.py:44
msgid "Feature"
@@ -14264,9 +13098,7 @@
#: ../gui/wxpython/gui_core/widgets.py:882
msgid "Type to search in all modules. Press Enter for next match."
-msgstr ""
-"Taper pour rechercher dans tous les modules. Appuyer sur Entrer pour la "
-"prochaine concordance."
+msgstr "Taper pour rechercher dans tous les modules. Appuyer sur Entrer pour la prochaine concordance."
#: ../gui/wxpython/gui_core/widgets.py:946
msgid "Searching, please type more characters."
@@ -14347,12 +13179,8 @@
msgstr "Fermer la boîte de dialogue après exécution"
#: ../gui/wxpython/gui_core/forms.py:586
-msgid ""
-"Close dialog when command is successfully finished. Change this settings in "
-"Preferences dialog ('Command' tab)."
-msgstr ""
-"Fermer la fenêtre de dialogue quand la commande se termine avec succès. "
-"Modifier ce paramètre dans les Préférences (onglet 'Commande')."
+msgid "Close dialog when command is successfully finished. Change this settings in Preferences dialog ('Command' tab)."
+msgstr "Fermer la fenêtre de dialogue quand la commande se termine avec succès. Modifier ce paramètre dans les Préférences (onglet 'Commande')."
#: ../gui/wxpython/gui_core/forms.py:753
#, python-format
@@ -14386,9 +13214,7 @@
#: ../gui/wxpython/gui_core/forms.py:1301
msgid "Show graphical representation of temporal extent of dataset(s) ."
-msgstr ""
-"Afficher une représentation graphique de l'emprise temporelle du jeu de "
-"données."
+msgstr "Afficher une représentation graphique de l'emprise temporelle du jeu de données."
#: ../gui/wxpython/gui_core/forms.py:1461 ../gui/wxpython/core/utils.py:998
msgid "Select Color"
@@ -14422,12 +13248,8 @@
msgstr "ou entrer les valeurs manuellement :"
#: ../gui/wxpython/gui_core/forms.py:1563
-msgid ""
-"Enter file content directly instead of specifying a file. Temporary file "
-"will be automatically created."
-msgstr ""
-"Entrez le contenu directement au lieu de spécifier un fichier. Un fichier "
-"temporaire sera créé automatiquement."
+msgid "Enter file content directly instead of specifying a file. Temporary file will be automatically created."
+msgstr "Entrez le contenu directement au lieu de spécifier un fichier. Un fichier temporaire sera créé automatiquement."
#: ../gui/wxpython/gui_core/forms.py:1588
#: ../gui/wxpython/gui_core/gselect.py:1320
@@ -14546,12 +13368,8 @@
#: ../gui/wxpython/gui_core/dialogs.py:420
#, python-format
-msgid ""
-"Vector map <%s> already exists in the current mapset. Do you want to "
-"overwrite it?"
-msgstr ""
-"La carte vecteur <%s> existe déjà dans le jeu de cartes courant. Voulez-vous "
-"l'écraser ?"
+msgid "Vector map <%s> already exists in the current mapset. Do you want to overwrite it?"
+msgstr "La carte vecteur <%s> existe déjà dans le jeu de cartes courant. Voulez-vous l'écraser ?"
#: ../gui/wxpython/gui_core/dialogs.py:503
msgid "Load region:"
@@ -14562,13 +13380,8 @@
msgstr "Enregistrer une région :"
#: ../gui/wxpython/gui_core/dialogs.py:544
-msgid ""
-"Name cannot begin with '.' and must not contain space, quotes, '/', ''', "
-"'@', ',', '=', '*', and all other non-alphanumeric characters."
-msgstr ""
-"Un nom ne peut aps commencer par '.' et ne doit pas contenir d'espaces, "
-"guillemets, '/', ''', '@', ',', '=', '*', ou tout autre caractère non alpha-"
-"numérique."
+msgid "Name cannot begin with '.' and must not contain space, quotes, '/', ''', '@', ',', '=', '*', and all other non-alphanumeric characters."
+msgstr "Un nom ne peut aps commencer par '.' et ne doit pas contenir d'espaces, guillemets, '/', ''', '@', ',', '=', '*', ou tout autre caractère non alpha-numérique."
#: ../gui/wxpython/gui_core/dialogs.py:559
msgid "Create or edit imagery groups"
@@ -14584,17 +13397,12 @@
#: ../gui/wxpython/gui_core/dialogs.py:594
msgid "Close dialog, changes are not applied"
-msgstr ""
-"Fermer la boîte de dialogue, les modifications ne seront pas appliquées"
+msgstr "Fermer la boîte de dialogue, les modifications ne seront pas appliquées"
#: ../gui/wxpython/gui_core/dialogs.py:635
#: ../gui/wxpython/gui_core/dialogs.py:1382
-msgid ""
-"Put here a regular expression. Characters '.*' stand for anything, character "
-"'^' stands for the beginning and '$' for the end."
-msgstr ""
-"Mettez ici une expression régulière. Le caratère '.*' correspond à n'importe "
-"quoi, le caractère '^' correspond au début et '$' à la fin."
+msgid "Put here a regular expression. Characters '.*' stand for anything, character '^' stands for the beginning and '$' for the end."
+msgstr "Mettez ici une expression régulière. Le caratère '.*' correspond à n'importe quoi, le caractère '^' correspond au début et '$' à la fin."
#: ../gui/wxpython/gui_core/dialogs.py:642
msgid "Select existing group or enter name of new group:"
@@ -14606,9 +13414,7 @@
#: ../gui/wxpython/gui_core/dialogs.py:662
msgid "Select existing subgroup or enter name of new subgroup:"
-msgstr ""
-"Sélectionner un sous-groupe existant ou entrez le nom d'un nouveau sous-"
-"groupe :"
+msgstr "Sélectionner un sous-groupe existant ou entrez le nom d'un nouveau sous-groupe :"
#: ../gui/wxpython/gui_core/dialogs.py:690
#: ../gui/wxpython/gui_core/dialogs.py:743
@@ -14641,8 +13447,7 @@
#: ../gui/wxpython/gui_core/dialogs.py:1057
#, python-format
msgid "Group <%s> was changed, do you want to apply changes?"
-msgstr ""
-"Le groupe <%s> a été modifié, voulez-vous enregistrer les modifications ?"
+msgstr "Le groupe <%s> a été modifié, voulez-vous enregistrer les modifications ?"
#: ../gui/wxpython/gui_core/dialogs.py:1059
#: ../gui/wxpython/gui_core/dialogs.py:1071
@@ -14652,9 +13457,7 @@
#: ../gui/wxpython/gui_core/dialogs.py:1069
#, python-format
msgid "Subgroup <%s> was changed, do you want to apply changes?"
-msgstr ""
-"Le sous-groupe <%s> a été modifié, voulez-vous enregistrer les "
-"modifications ?"
+msgstr "Le sous-groupe <%s> a été modifié, voulez-vous enregistrer les modifications ?"
#: ../gui/wxpython/gui_core/dialogs.py:1125
msgid "No raster maps selected."
@@ -14786,15 +13589,12 @@
#: ../gui/wxpython/gui_core/dialogs.py:1874
#, python-brace-format
msgid "Add linked layers into layer tree ({mightNotWork})"
-msgstr ""
-"Ajouter les couches liées dans l'arborescence des couches ({mightNotWork})"
+msgstr "Ajouter les couches liées dans l'arborescence des couches ({mightNotWork})"
#: ../gui/wxpython/gui_core/dialogs.py:1877
msgid "Add imported layers into layer tree ({mightNotWork})"
-msgstr ""
-"Ajouter les couches importées dans l'arborescence des couches "
-"({mightNotWork})"
+msgstr "Ajouter les couches importées dans l'arborescence des couches ({mightNotWork})"
#: ../gui/wxpython/gui_core/dialogs.py:1883
msgid "&Link"
@@ -15089,9 +13889,7 @@
#: ../gui/wxpython/gui_core/toolbars.py:56
msgid "Zoom to default or saved region, save to named region, ..."
-msgstr ""
-"Zoomer sur la région de calculs par défaut ou enregistrée, enregistre vers "
-"un nom de région, ..."
+msgstr "Zoomer sur la région de calculs par défaut ou enregistrée, enregistre vers un nom de région, ..."
#: ../gui/wxpython/gui_core/toolbars.py:58
msgid "Zoom to selected map layer(s)"
@@ -15261,8 +14059,7 @@
#: ../gui/wxpython/gui_core/gselect.py:1796
#: ../gui/wxpython/web_services/dialogs.py:281
msgid "No data source defined, settings are not saved."
-msgstr ""
-"Pas de source de données définie, les paramètres ne sont pas enregistrés."
+msgstr "Pas de source de données définie, les paramètres ne sont pas enregistrés."
#: ../gui/wxpython/gui_core/gselect.py:2113
#, fuzzy
@@ -15274,12 +14071,8 @@
msgstr "Polygone"
#: ../gui/wxpython/timeline/frame.py:38
-msgid ""
-"The Timeline Tool needs the \"matplotlib\" (python-matplotlib) package to be "
-"installed."
-msgstr ""
-"L'outil temporel nécessite que le paquet \"matplotlib\" (python-matplotlib) "
-"soit installé."
+msgid "The Timeline Tool needs the \"matplotlib\" (python-matplotlib) package to be installed."
+msgstr "L'outil temporel nécessite que le paquet \"matplotlib\" (python-matplotlib) soit installé."
#: ../gui/wxpython/timeline/frame.py:70
#, fuzzy
@@ -15308,21 +14101,15 @@
#: ../gui/wxpython/timeline/frame.py:162
#, fuzzy, python-format
msgid "Dataset <%s> not found in temporal database"
-msgstr "Carte vectorielle <%s> non trouvée"
+msgstr "Jeux de données <%s> non trouvé dans la base temporelle"
#: ../gui/wxpython/timeline/frame.py:174
-msgid ""
-"Datasets have different temporal type (absolute x relative), which is not "
-"allowed."
-msgstr ""
-"Les jeux de données ont des types temporels (absolut x relatif) différents, "
-"ce qui n'ets pas permis. "
+msgid "Datasets have different temporal type (absolute x relative), which is not allowed."
+msgstr "Les jeux de données ont des types temporels (absolut x relatif) différents, ce qui n'ets pas permis. "
#: ../gui/wxpython/timeline/frame.py:189
msgid "Datasets have different time unit which is not allowed."
-msgstr ""
-"Les jeux de données ont des unités de temps différentes, ce qui n'est pas "
-"permis."
+msgstr "Les jeux de données ont des unités de temps différentes, ce qui n'est pas permis."
#: ../gui/wxpython/timeline/frame.py:264
#, python-format
@@ -15482,8 +14269,7 @@
"%s web service was not found in fetched capabilities file from <%s>:\n"
"%s\n"
msgstr ""
-"Le service web %s n'a pas été trouvé dans le fichier de capacités récupérer "
-"depuis <%s> :\n"
+"Le service web %s n'a pas été trouvé dans le fichier de capacités récupérer depuis <%s> :\n"
"%s\n"
#: ../gui/wxpython/web_services/widgets.py:769
@@ -15524,8 +14310,7 @@
"User defined server with same name as default server <%s> already exists.\n"
"Keeping user defined server"
msgstr ""
-"Un serveur défini par l'utilisateur existe déjà avec le même nom que le "
-"serveur par défaut <%s>.\n"
+"Un serveur défini par l'utilisateur existe déjà avec le même nom que le serveur par défaut <%s>.\n"
"On garde le serveur défini par l'utilisateur."
#: ../gui/wxpython/web_services/dialogs.py:90
@@ -15589,8 +14374,7 @@
#: ../gui/wxpython/web_services/dialogs.py:488
msgid "Add selected web service layers as map layer into layer tree"
-msgstr ""
-"Ajouter les couches web service sélectionnées dans l'arborescence des couches"
+msgstr "Ajouter les couches web service sélectionnées dans l'arborescence des couches"
#: ../gui/wxpython/web_services/dialogs.py:581
msgid "Web service layer properties"
@@ -15618,9 +14402,7 @@
#: ../gui/wxpython/web_services/dialogs.py:807
msgid "Extent and resolution are based on Map Display geometry."
-msgstr ""
-"L'étendue et la résolution sont basés sur la géométrie de l'écran "
-"d'affichage."
+msgstr "L'étendue et la résolution sont basés sur la géométrie de l'écran d'affichage."
#: ../gui/wxpython/web_services/dialogs.py:809
msgid "Extent and resolution are based on computational region."
@@ -15706,9 +14488,7 @@
#: ../gui/wxpython/modules/colorrules.py:409
msgid "Type filename or click to choose file and load color table"
-msgstr ""
-"Entrer un nom de fichier ou cliquer sur Parcourir pour charger une table de "
-"couleur"
+msgstr "Entrer un nom de fichier ou cliquer sur Parcourir pour charger une table de couleur"
#: ../gui/wxpython/modules/colorrules.py:415
msgid "Choose file to save color table"
@@ -15716,9 +14496,7 @@
#: ../gui/wxpython/modules/colorrules.py:416
msgid "Type filename or click to choose file and save color table"
-msgstr ""
-"Entrer un nom de fichier ou cliquer sur Parcourir pour enregistrer une table "
-"de couleur"
+msgstr "Entrer un nom de fichier ou cliquer sur Parcourir pour enregistrer une table de couleur"
#: ../gui/wxpython/modules/colorrules.py:424
#, fuzzy
@@ -15743,9 +14521,7 @@
#: ../gui/wxpython/modules/colorrules.py:527
msgid "Show preview of map (current Map Display extent is used)."
-msgstr ""
-"Affiche un aperçu de la carte (l'étendue de la fenêtre de cartes actuelle "
-"sera utilisée)."
+msgstr "Affiche un aperçu de la carte (l'étendue de la fenêtre de cartes actuelle sera utilisée)."
#: ../gui/wxpython/modules/colorrules.py:560
#: ../gui/wxpython/modules/colorrules.py:1717
@@ -15759,8 +14535,7 @@
#: ../gui/wxpython/modules/colorrules.py:720
#, python-format
msgid "Invalid rule value '%s'. Unable to apply color table."
-msgstr ""
-"Valeur '%s' de règle non valide. Impossible d'appliquer la table de couleur."
+msgstr "Valeur '%s' de règle non valide. Impossible d'appliquer la table de couleur."
#: ../gui/wxpython/modules/colorrules.py:798
msgid "Create new color table for raster map"
@@ -15777,9 +14552,7 @@
#: ../gui/wxpython/modules/colorrules.py:881
#, python-format
msgid "Enter raster category values or percents (%(range)s = %(min)d-%(max)d)"
-msgstr ""
-"Saisir les valeurs de catégorie ou le pourcentage (%(range)s = %(min)d-"
-"%(max)d)"
+msgstr "Saisir les valeurs de catégorie ou le pourcentage (%(range)s = %(min)d-%(max)d)"
#: ../gui/wxpython/modules/colorrules.py:969
msgid "Create new color rules for vector map"
@@ -15846,13 +14619,8 @@
#: ../gui/wxpython/modules/colorrules.py:1140
#, python-format
-msgid ""
-"Database connection for vector map <%s> is not defined in DB file. Do you "
-"want to create and connect new attribute table?"
-msgstr ""
-"La connexion à une base de données pour la carte vecteur <%s> n'est pas "
-"définie dans le fichier DB. Voulez-vous créer et connecter une nouvelle "
-"table d'attributs ?"
+msgid "Database connection for vector map <%s> is not defined in DB file. Do you want to create and connect new attribute table?"
+msgstr "La connexion à une base de données pour la carte vecteur <%s> n'est pas définie dans le fichier DB. Voulez-vous créer et connecter une nouvelle table d'attributs ?"
#: ../gui/wxpython/modules/colorrules.py:1143
msgid "No database connection defined"
@@ -15860,12 +14628,8 @@
#: ../gui/wxpython/modules/colorrules.py:1215
#, python-format
-msgid ""
-"Selected map <%(map)s> is not in current mapset <%(mapset)s>. Attribute "
-"table cannot be edited."
-msgstr ""
-"La carte sélectionnée <%(map)s> n'est pas dans le jeux de cartes courant <"
-"%(mapset)s>. La table d'attributs ne peut pas être modifiée."
+msgid "Selected map <%(map)s> is not in current mapset <%(mapset)s>. Attribute table cannot be edited."
+msgstr "La carte sélectionnée <%(map)s> n'est pas dans le jeux de cartes courant <%(mapset)s>. La table d'attributs ne peut pas être modifiée."
#: ../gui/wxpython/modules/colorrules.py:1368
#, python-format
@@ -15878,13 +14642,8 @@
#: ../gui/wxpython/modules/colorrules.py:1461
#, python-format
-msgid ""
-"Number of loaded records reached %d, displaying all the records will be time-"
-"consuming and may lead to computer freezing, do you still want to continue?"
-msgstr ""
-"Le nombre d'enregistrements est de %d, afficher tous les enregistrements "
-"serait très long et peut provoquer un gel de l'ordinateur. Voulez-vous "
-"continuer ?"
+msgid "Number of loaded records reached %d, displaying all the records will be time-consuming and may lead to computer freezing, do you still want to continue?"
+msgstr "Le nombre d'enregistrements est de %d, afficher tous les enregistrements serait très long et peut provoquer un gel de l'ordinateur. Voulez-vous continuer ?"
#: ../gui/wxpython/modules/colorrules.py:1465
msgid "Too many records"
@@ -16120,9 +14879,7 @@
#: ../gui/wxpython/modules/extensions.py:96
msgid "Fetch list of available modules from GRASS Addons SVN repository"
-msgstr ""
-"Récupérer la liste des modules disponibles depuis le dépôt svn des GRASS "
-"AddOns"
+msgstr "Récupérer la liste des modules disponibles depuis le dépôt svn des GRASS AddOns"
#: ../gui/wxpython/modules/extensions.py:100
msgid "&Install"
@@ -16142,9 +14899,7 @@
#: ../gui/wxpython/modules/extensions.py:191
msgid "Fetching list of modules from GRASS-Addons SVN (be patient)..."
-msgstr ""
-"Récupération de la liste des modules à partir du svn GRASS AddOns (soyez "
-"patient)..."
+msgstr "Récupération de la liste des modules à partir du svn GRASS AddOns (soyez patient)..."
#: ../gui/wxpython/modules/extensions.py:213
msgid "Install"
@@ -16471,8 +15226,7 @@
"\n"
"Number of skipped lines: %(line)d"
msgstr ""
-"Certaines lignes ont été sautées à la lecture des paramètres depuis le "
-"fichier <%(file)s>.\n"
+"Certaines lignes ont été sautées à la lecture des paramètres depuis le fichier <%(file)s>.\n"
"Voir la fenêtre 'Sortie de commande' pour des détails.\n"
"\n"
"Nombre de lignes sautées : %(line)d"
@@ -16509,8 +15263,7 @@
#: ../gui/wxpython/core/render.py:483
#, python-format
msgid "Error: Unable to open '%(file)s'. Reason: %(ret)s. wxGUI exited.\n"
-msgstr ""
-"Erreur : impossible d'ouvrir '%(file)s'. Raison : %(ret)s. Sortie de wxGUI.\n"
+msgstr "Erreur : impossible d'ouvrir '%(file)s'. Raison : %(ret)s. Sortie de wxGUI.\n"
#: ../gui/wxpython/core/render.py:491
#, python-format
@@ -16547,12 +15300,8 @@
msgstr "Impossible de zoomer sur la carte raster 3d <%s>."
#: ../gui/wxpython/core/render.py:676
-msgid ""
-"Unable to get current geographic extent. Force quiting wxGUI. Please "
-"manually run g.region to fix the problem."
-msgstr ""
-"Impossible d'obtenir l’extension géographique courante. Sortie forcée de "
-"wxGUI. Merci d'exécuter manuellement g.region pour résoudre ce problème."
+msgid "Unable to get current geographic extent. Force quiting wxGUI. Please manually run g.region to fix the problem."
+msgstr "Impossible d'obtenir l’extension géographique courante. Sortie forcée de wxGUI. Merci d'exécuter manuellement g.region pour résoudre ce problème."
#: ../gui/wxpython/core/render.py:987
#, python-format
@@ -16590,9 +15339,7 @@
#: ../gui/wxpython/core/toolboxes.py:195
msgid "Unable to parse user toolboxes XML files. Default files will be loaded."
-msgstr ""
-"Impossible d'analyser le fichier XML des barres d'outils utilisateur. "
-"Chargement du fichier par défaut."
+msgstr "Impossible d'analyser le fichier XML des barres d'outils utilisateur. Chargement du fichier par défaut."
#: ../gui/wxpython/core/toolboxes.py:235
msgid "Unable to create toolboxes directory."
@@ -16611,12 +15358,8 @@
msgstr "Extensions"
#: ../gui/wxpython/core/toolboxes.py:607
-msgid ""
-"WARNING: Some addons failed when loading. Please consider to update your "
-"addons by running 'g.extension.all -f'.\n"
-msgstr ""
-"ATTENTION : le chargement de certaines extensions à échoué. Merci de mettre "
-"à jour vos extensions en lançant 'g.extension.all -f'.\n"
+msgid "WARNING: Some addons failed when loading. Please consider to update your addons by running 'g.extension.all -f'.\n"
+msgstr "ATTENTION : le chargement de certaines extensions à échoué. Merci de mettre à jour vos extensions en lançant 'g.extension.all -f'.\n"
#: ../gui/wxpython/core/utils.py:53
#, python-format
@@ -16673,8 +15416,7 @@
"impossible de lancer la commande :\n"
"%(cmd)s\n"
"\n"
-"Option <%(opt)s> : la lecture depuis l'entrée standard n'est pas prise en "
-"charge par wxGUI"
+"Option <%(opt)s> : la lecture depuis l'entrée standard n'est pas prise en charge par wxGUI"
#: ../gui/wxpython/core/gconsole.py:610
#, python-format
@@ -16687,11 +15429,8 @@
msgstr "%(min)d min %(sec)d sec"
#: ../gui/wxpython/core/gconsole.py:621
-msgid ""
-"Please note that the data are left in inconsistent state and may be corrupted"
-msgstr ""
-"Veuillez noter que les données sont laissées dans un état inconsitant et "
-"peuvent être corrompues"
+msgid "Please note that the data are left in inconsistent state and may be corrupted"
+msgstr "Veuillez noter que les données sont laissées dans un état inconsitant et peuvent être corrompues"
#: ../gui/wxpython/core/gconsole.py:623
msgid "Command aborted"
@@ -16914,13 +15653,8 @@
#: ../gui/wxpython/location_wizard/wizard.py:162
#, python-format
-msgid ""
-"Name <%(name)s> is not a valid name for location. Please use only ASCII "
-"characters excluding %(chars)s and space."
-msgstr ""
-"Le nom <%(name)s> n'est pas un nom valide pour un secteur. Merci de "
-"n'utiliser que des caractères ASCII à l'exclusion de %(chars)s et des "
-"espaces."
+msgid "Name <%(name)s> is not a valid name for location. Please use only ASCII characters excluding %(chars)s and space."
+msgstr "Le nom <%(name)s> n'est pas un nom valide pour un secteur. Merci de n'utiliser que des caractères ASCII à l'exclusion de %(chars)s et des espaces."
#: ../gui/wxpython/location_wizard/wizard.py:165
msgid "Invalid location name"
@@ -16940,12 +15674,8 @@
msgstr "Impossible de créer le secteur"
#: ../gui/wxpython/location_wizard/wizard.py:208
-msgid ""
-"Title of the location is limited only to one line and 256 characters. The "
-"rest of the text will be ignored."
-msgstr ""
-"Le titre du secteur est limité à une ligne et 256 caractères. Le reste du "
-"texte sera ignoré."
+msgid "Title of the location is limited only to one line and 256 characters. The rest of the text will be ignored."
+msgstr "Le titre du secteur est limité à une ligne et 256 caractères. Le reste du texte sera ignoré."
#: ../gui/wxpython/location_wizard/wizard.py:215
msgid "Choose method for creating a new location"
@@ -17162,13 +15892,8 @@
#: ../gui/wxpython/location_wizard/wizard.py:2078
#, python-format
-msgid ""
-"Location <%(loc)s> will be created in GIS data directory <%(dir)s>. You will "
-"need to change the default GIS data directory in the GRASS startup screen."
-msgstr ""
-"Le secteur <%(loc)s> va être créé dans le répertoire SIG <%(dir)s>. Il vous "
-"faudra changer le répertoire SIG par défaut dans l'écran de démarrage de "
-"GRASS."
+msgid "Location <%(loc)s> will be created in GIS data directory <%(dir)s>. You will need to change the default GIS data directory in the GRASS startup screen."
+msgstr "Le secteur <%(loc)s> va être créé dans le répertoire SIG <%(dir)s>. Il vous faudra changer le répertoire SIG par défaut dans l'écran de démarrage de GRASS."
#: ../gui/wxpython/location_wizard/wizard.py:2083
msgid "New GIS data directory"
@@ -17280,22 +16005,13 @@
msgstr "Sélectionner parmi une liste de datums de transformation"
#: ../gui/wxpython/nviz/mapwindow.py:224
-msgid ""
-"Opening 3D view was not successful. Please try to change the value of depth "
-"buffer in GUI Settings dialog > tab Map Display > Advanced and restart GUI."
-msgstr ""
-"Le lancement de la vue 3D a échoué. Essayez de modifier la taille du tampon "
-"d'affichage dans Paramètres > Préférences > onglet Fenêtre de carte > "
-"Paramètres d'affichage avancés puis redémarrer l'interface."
+msgid "Opening 3D view was not successful. Please try to change the value of depth buffer in GUI Settings dialog > tab Map Display > Advanced and restart GUI."
+msgstr "Le lancement de la vue 3D a échoué. Essayez de modifier la taille du tampon d'affichage dans Paramètres > Préférences > onglet Fenêtre de carte > Paramètres d'affichage avancés puis redémarrer l'interface."
#: ../gui/wxpython/nviz/mapwindow.py:559
#, python-format
-msgid ""
-"Image is too large, your OpenGL implementation supports maximum texture size "
-"%d px."
-msgstr ""
-"L'image est trop grande, votre installation OpenGL supporte une taille de "
-"texture d'un maximum de %d pixels."
+msgid "Image is too large, your OpenGL implementation supports maximum texture size %d px."
+msgstr "L'image est trop grande, votre installation OpenGL supporte une taille de texture d'un maximum de %d pixels."
# Easting et Northing sont ici traduits resp. Abscisse et Ordonnée, désignant plutôt des valeurs numériques que des directions cardinales.
#: ../gui/wxpython/nviz/mapwindow.py:1057
@@ -17437,8 +16153,7 @@
#: ../gui/wxpython/nviz/tools.py:247
msgid "Adjusts the distance and angular perspective of the image viewpoint"
-msgstr ""
-"Ajuster la distance et l'angle de perspective de l'image au point de vue"
+msgstr "Ajuster la distance et l'angle de perspective de l'image au point de vue"
#: ../gui/wxpython/nviz/tools.py:252 ../gui/wxpython/nviz/preferences.py:69
msgid "Perspective:"
@@ -17453,12 +16168,8 @@
msgstr "Inclinaison :"
#: ../gui/wxpython/nviz/tools.py:271
-msgid ""
-"Adjusts the viewing height above the surface (angle of view automatically "
-"adjusts to maintain the same center of view)"
-msgstr ""
-"Ajuster la hauteur de vue (l'angle de vue s'ajuste automatiquement pour "
-"garder le même centre de la vue)"
+msgid "Adjusts the viewing height above the surface (angle of view automatically adjusts to maintain the same center of view)"
+msgstr "Ajuster la hauteur de vue (l'angle de vue s'ajuste automatiquement pour garder le même centre de la vue)"
#: ../gui/wxpython/nviz/tools.py:276
msgid "Adjusts the relative height of features above the plane of the surface"
@@ -17477,12 +16188,8 @@
msgstr "curseur"
#: ../gui/wxpython/nviz/tools.py:309
-msgid ""
-"Allows you to select a point on the surface that becomes the new center of "
-"view. Click on the button and then on the surface."
-msgstr ""
-"Permet de sélectionner un point sur la surface qui deviendra le nouveau "
-"centre de la vue. Cliquer sur le bouton puis sur la surface."
+msgid "Allows you to select a point on the surface that becomes the new center of view. Click on the button and then on the surface."
+msgstr "Permet de sélectionner un point sur la surface qui deviendra le nouveau centre de la vue. Cliquer sur le bouton puis sur la surface."
#: ../gui/wxpython/nviz/tools.py:315
msgid "center"
@@ -17497,12 +16204,8 @@
msgstr "nord"
#: ../gui/wxpython/nviz/tools.py:325
-msgid ""
-"Sets the viewer directly over the scene's center position. This top view "
-"orients approximately north south."
-msgstr ""
-"Définir la vue directement au dessus du centre de la scène. Cette vue du "
-"haut est orientée approximativement nord-sud."
+msgid "Sets the viewer directly over the scene's center position. This top view orients approximately north south."
+msgstr "Définir la vue directement au dessus du centre de la scène. Cette vue du haut est orientée approximativement nord-sud."
#: ../gui/wxpython/nviz/tools.py:329
msgid "reset"
@@ -17517,13 +16220,8 @@
msgstr "Apparence de l'image"
#: ../gui/wxpython/nviz/tools.py:392
-msgid ""
-"Press 'Record' button and start changing the view. It is recommended to use "
-"fly-through mode (Map Display toolbar) to achieve smooth motion."
-msgstr ""
-"Appuyez sur le bouton 'Enregistrer' et commencez à changer la vue. Il est "
-"recommandé d'utiliser le mode survol (barre d'outils d'affichage) pour "
-"obtenir un déplacement fluide."
+msgid "Press 'Record' button and start changing the view. It is recommended to use fly-through mode (Map Display toolbar) to achieve smooth motion."
+msgstr "Appuyez sur le bouton 'Enregistrer' et commencez à changer la vue. Il est recommandé d'utiliser le mode survol (barre d'outils d'affichage) pour obtenir un déplacement fluide."
#: ../gui/wxpython/nviz/tools.py:403
msgid "Record"
@@ -17554,11 +16252,8 @@
msgstr "Choisir un répertoire pour les images"
#: ../gui/wxpython/nviz/tools.py:490
-msgid ""
-"Generated files names will look like this: prefix_1.ppm, prefix_2.ppm, ..."
-msgstr ""
-"Les noms de fichiers générés ressembleront à ceci : prefix_1.ppm, prefix_2."
-"ppm, ..."
+msgid "Generated files names will look like this: prefix_1.ppm, prefix_2.ppm, ..."
+msgstr "Les noms de fichiers générés ressembleront à ceci : prefix_1.ppm, prefix_2.ppm, ..."
#: ../gui/wxpython/nviz/tools.py:546 ../gui/wxpython/nviz/tools.py:1862
#: ../gui/wxpython/nviz/preferences.py:361
@@ -17739,12 +16434,8 @@
msgstr "Effectue une rotation sur l'axe horizontal du plan de coupe"
#: ../gui/wxpython/nviz/tools.py:1045
-msgid ""
-"Sets the Z coordinate of the current cutting plane (only meaningful when "
-"tilt is not 0)"
-msgstr ""
-"Définit la coordonnée Z du plan de coupe actuel (n'a de sens que si "
-"l'inclinaison n'est pas à 0)"
+msgid "Sets the Z coordinate of the current cutting plane (only meaningful when tilt is not 0)"
+msgstr "Définit la coordonnée Z du plan de coupe actuel (n'a de sens que si l'inclinaison n'est pas à 0)"
#: ../gui/wxpython/nviz/tools.py:1114
msgid "Fine resolution:"
@@ -17924,9 +16615,7 @@
#: ../gui/wxpython/nviz/tools.py:2090
msgid "Do you want to record new animation without saving the previous one?"
-msgstr ""
-"Voulez-vous enregistrer une nouvelle animation sans enregistrer la "
-"précédente ?"
+msgstr "Voulez-vous enregistrer une nouvelle animation sans enregistrer la précédente ?"
#: ../gui/wxpython/nviz/tools.py:2093
msgid "Animation already axists"
@@ -18094,12 +16783,8 @@
msgstr "Ajuster la distance et la direction au point de vue"
#: ../gui/wxpython/nviz/tools.py:5175
-msgid ""
-"Adjusts the light direction. Click and drag the puck to change the light "
-"direction."
-msgstr ""
-"Ajuster la direction de la lumière. Cliquez et déplacez le point pour "
-"changer l'origine de la lumière."
+msgid "Adjusts the light direction. Click and drag the puck to change the light direction."
+msgstr "Ajuster la direction de la lumière. Cliquez et déplacez le point pour changer l'origine de la lumière."
#: ../gui/wxpython/nviz/wxnviz.py:482 ../gui/wxpython/nviz/wxnviz.py:494
#, python-format
@@ -18112,8 +16797,7 @@
#: ../gui/wxpython/nviz/preferences.py:49
msgid "Revert settings to default, changes are not applied"
-msgstr ""
-"Revenir aux paramètres par défaut, les changements ne seront pas appliqués"
+msgstr "Revenir aux paramètres par défaut, les changements ne seront pas appliqués"
#: ../gui/wxpython/nviz/preferences.py:72
#: ../gui/wxpython/nviz/preferences.py:135
@@ -18180,45 +16864,33 @@
#, python-format
msgid ""
"Interactive Scatter Plot Tool can not be used.\n"
-"Number of cells (rows*cols) <%d> in current regionis higher than maximum "
-"limit <%d>.\n"
+"Number of cells (rows*cols) <%d> in current regionis higher than maximum limit <%d>.\n"
"\n"
"You can reduce number of cells in current region using <g.region> command."
msgstr ""
"L'outil interactif de nuage de points ne peut pas être utilisé.\n"
-"Le nombre de cellules (lignes*colonnes) <%d> de la région courante ets plus "
-"grand que la limite maximale <%d>.\n"
+"Le nombre de cellules (lignes*colonnes) <%d> de la région courante ets plus grand que la limite maximale <%d>.\n"
"\n"
-"Vous pouvez diminuer le nombre de cellules de la région avec la commande <g."
-"region>."
+"Vous pouvez diminuer le nombre de cellules de la région avec la commande <g.region>."
#: ../gui/wxpython/iscatt/controllers.py:228
#, python-format
msgid ""
-"Number of cells (rows*cols) <%d> in current region is higher than "
-"recommended threshold <%d>.\n"
-"It is strongly advised to reduce number of cells in current region bellow "
-"recommend threshold.\n"
+"Number of cells (rows*cols) <%d> in current region is higher than recommended threshold <%d>.\n"
+"It is strongly advised to reduce number of cells in current region bellow recommend threshold.\n"
" It can be done by <g.region> command.\n"
"\n"
"Do you want to continue using Interactive Scatter Plot Tool with this region?"
msgstr ""
-"Le nombre de cellules (lignes*colonnes) <%d> de la région courante est plus "
-"grand que le seuil recommandé <%d>.\n"
-"Il est fortement conseillé de réduire le nombre de cellules de la région "
-"courante en dessous du seuil recommandé.\n"
+"Le nombre de cellules (lignes*colonnes) <%d> de la région courante est plus grand que le seuil recommandé <%d>.\n"
+"Il est fortement conseillé de réduire le nombre de cellules de la région courante en dessous du seuil recommandé.\n"
" Ceci peut être fait par la commande <g.region>.\n"
"\n"
-"Voulez-vous continuer à utiliser l'outil interactif de nuages de points avec "
-"cette région ?"
+"Voulez-vous continuer à utiliser l'outil interactif de nuages de points avec cette région ?"
#: ../gui/wxpython/iscatt/controllers.py:284
-msgid ""
-"Scatter plot with same band combination (regardless x y order) is already "
-"displayed."
-msgstr ""
-"Un nuage de points avec la même combinaison de bandes (indépendament de "
-"l'ordre x y) est déjà affiché."
+msgid "Scatter plot with same band combination (regardless x y order) is already displayed."
+msgstr "Un nuage de points avec la même combinaison de bandes (indépendament de l'ordre x y) est déjà affiché."
#: ../gui/wxpython/iscatt/controllers.py:297
#, python-format
@@ -18233,27 +16905,21 @@
#, python-format
msgid ""
"Scatter plot cannot be added.\n"
-"Multiple of bands ranges <%s:%d * %s:%d = %d> is higher than maximum limit <"
-"%d>.\n"
+"Multiple of bands ranges <%s:%d * %s:%d = %d> is higher than maximum limit <%d>.\n"
msgstr ""
"Le nuage de point ne peut pas être ajouté.\n"
-"La multiplication des plages de bandes <%s:%d * %s:%d = %d> est supérieure à "
-"la limite maximale <%d>.\n"
+"La multiplication des plages de bandes <%s:%d * %s:%d = %d> est supérieure à la limite maximale <%d>.\n"
#: ../gui/wxpython/iscatt/controllers.py:314
#, python-format
msgid ""
-"Multiple of bands ranges <%s:%d * %s:%d = %d> is higher than recommended "
-"limit <%d>.\n"
-"It is strongly advised to reduce range extend of bands(e. g. using r."
-"rescale) bellow recommended threshold.\n"
+"Multiple of bands ranges <%s:%d * %s:%d = %d> is higher than recommended limit <%d>.\n"
+"It is strongly advised to reduce range extend of bands(e. g. using r.rescale) bellow recommended threshold.\n"
"\n"
"Do you really want to add this scatter plot?"
msgstr ""
-"La multiplication des étendues de bandes <%s:%d * %s:%d = %d> est supérieure "
-"à la limite recommandée <%d>.\n"
-"Il est fortement conseillé de réduire la plage des bandes (ex : en utilisant "
-"r.rescale) en dessous du seuil recommandé.\n"
+"La multiplication des étendues de bandes <%s:%d * %s:%d = %d> est supérieure à la limite recommandée <%d>.\n"
+"Il est fortement conseillé de réduire la plage des bandes (ex : en utilisant r.rescale) en dessous du seuil recommandé.\n"
"\n"
"Voulez-vous vraiment ajouter ce nuage de poitns ?"
@@ -18263,8 +16929,7 @@
"\n"
"There is no class yet, do you want to create one?"
msgstr ""
-"Pour sélectionner une zone dans le nuage de points, vous devez d'abord "
-"sélectionner une classe.\n"
+"Pour sélectionner une zone dans le nuage de points, vous devez d'abord sélectionner une classe.\n"
"\n"
"Il n'y a pas encore de classe, voulez-vous en créer une ?"
@@ -18301,14 +16966,13 @@
msgstr "Échec du chargement de la librairie ctypes"
#: ../gui/wxpython/iscatt/frame.py:146
-#, fuzzy
msgid "GRASS GIS Interactive Scatter Plot Tool"
-msgstr "Barre d'outils de nuages de points"
+msgstr "Barre d'outils interactive de nuages de points"
#: ../gui/wxpython/iscatt/frame.py:361
#, fuzzy
msgid "scatter plot"
-msgstr "Points vectoriels"
+msgstr "nuage de points"
#: ../gui/wxpython/iscatt/frame.py:437
msgid "Maximum limit of categories number was reached."
@@ -18402,12 +17066,8 @@
msgstr "Les bandes sélectionnées doivent être différentes."
#: ../gui/wxpython/iscatt/dialogs.py:191
-msgid ""
-"Scatter plot with same bands combination (regardless x y order) has been "
-"already added into the list."
-msgstr ""
-"l'ordre x y) a déjà été ajouté à la liste."
+msgid "Scatter plot with same bands combination (regardless x y order) has been already added into the list."
+msgstr "Un nuage de points avec la même combinaison de bandes (indépendament de l'ordre x y) a déjà été ajouté à la liste."
#: ../gui/wxpython/iscatt/dialogs.py:292
#, python-format
@@ -18496,12 +17156,8 @@
msgstr "Mode zoom pour les nuages de points (bouton de souris gauche, molette)"
#: ../gui/wxpython/iscatt/toolbars.py:56
-msgid ""
-"Zoom to scatter plot data extend mode (click on scatter plot for zooming to "
-"extend)"
-msgstr ""
-"Mode de zoom sur l'emprise des données du nuage de points (cliquer sur le "
-"nuage de points pour zoomer sur l'emprise)"
+msgid "Zoom to scatter plot data extend mode (click on scatter plot for zooming to extend)"
+msgstr "Mode de zoom sur l'emprise des données du nuage de points (cliquer sur le nuage de points pour zoomer sur l'emprise)"
#: ../gui/wxpython/iscatt/toolbars.py:58
msgid "Show/hide class manager"
@@ -18531,8 +17187,7 @@
#: ../gui/wxpython/iscatt/toolbars.py:172
msgid "Add new vertex between last and first points of the boundary"
-msgstr ""
-"Ajouter un nouveau sommet entre le dernier et le premier point du contour"
+msgstr "Ajouter un nouveau sommet entre le dernier et le premier point du contour"
#: ../gui/wxpython/iscatt/toolbars.py:174
msgid "Move vertex"
@@ -18552,9 +17207,7 @@
#: ../gui/wxpython/iscatt/toolbars.py:180
msgid "Remove polygon (click on scatter plot for removing it's polygon)"
-msgstr ""
-"Supprimer le polygone (cliquer sur le nuage de points pour supprimer son "
-"polygone)"
+msgstr "Supprimer le polygone (cliquer sur le nuage de points pour supprimer son polygone)"
#: ../gui/wxpython/iscatt/toolbars.py:257
msgid "Add class"
@@ -18579,38 +17232,26 @@
#~ msgid "Multiple GPS export formats using GPSBabel"
#~ msgstr "Exporter vers des formats GPS avec GPSBABEL"
-#~ msgid ""
-#~ "Exports a vector map to a GPS receiver or file format supported by "
-#~ "GPSBabel."
-#~ msgstr ""
-#~ "Exporter une carte vecteur vers un récepteur GPS ou un fichier pris en "
-#~ "charge par GPSBabel."
+#~ msgid "Exports a vector map to a GPS receiver or file format supported by GPSBabel."
+#~ msgstr "Exporter une carte vecteur vers un récepteur GPS ou un fichier pris en charge par GPSBabel."
#~ msgid "Packs up a vector map and support files for copying."
-#~ msgstr ""
-#~ "Empaqueter une carte vecteur et ses fichiers associée pour la copie."
+#~ msgstr "Empaqueter une carte vecteur et ses fichiers associée pour la copie."
#~ msgid "Common export formats using OGR"
#~ msgstr "Exporter vers des formats communs avec OGR"
#~ msgid "Set computational region from selected map(s) (ignore NULLs)"
-#~ msgstr ""
-#~ "Définir la région de calcul à partir de la(des) carte(s) sélectionnée(s) "
-#~ "(ignore les NULLs)"
+#~ msgstr "Définir la région de calcul à partir de la(des) carte(s) sélectionnée(s) (ignore les NULLs)"
#~ msgid "Historical GRASS vector import"
#~ msgstr "Importer une carte vecteur d'une ancienne version de GRASS"
#~ msgid "Historical GRASS vector import (all maps)"
-#~ msgstr ""
-#~ "Import de cartes vecteurs ancienne version de GRASS (toutes les cartes)"
+#~ msgstr "Import de cartes vecteurs ancienne version de GRASS (toutes les cartes)"
-#~ msgid ""
-#~ "Converts all older versions of GRASS vector maps in current mapset to "
-#~ "current format."
-#~ msgstr ""
-#~ "Convertir toutes les cartes vectorielles en ancien format GRASS du jeux "
-#~ "de cartes courant vers le nouveau format."
+#~ msgid "Converts all older versions of GRASS vector maps in current mapset to current format."
+#~ msgstr "Convertir toutes les cartes vectorielles en ancien format GRASS du jeux de cartes courant vers le nouveau format."
#~ msgid "GPS data import"
#~ msgstr "Importer des données GPS"
@@ -18619,8 +17260,7 @@
#~ msgstr "Importer depuis GEOnet"
#~ msgid "IDW from raster points (alternate method for sparse points)"
-#~ msgstr ""
-#~ "IDW depuis des points raster (méthode alternative pour points clairsemés)"
+#~ msgstr "IDW depuis des points raster (méthode alternative pour points clairsemés)"
#~ msgid "Create optimally placed labels"
#~ msgstr "Créer des étiquettes placées de manière optimale"
@@ -18628,67 +17268,54 @@
#~ msgid "Bit pattern comparison "
#~ msgstr "Comparaison bit à bit"
-#, fuzzy
#~ msgid "Data file <%(name)s> imported successfully."
-#~ msgstr "Déchargement de la carte vecteur <%(name)s> réussit."
+#~ msgstr "L'import du fichier <%(name)s> a réussit."
-#, fuzzy
#~ msgid "category"
-#~ msgstr "Catégorie"
+#~ msgstr "catégorie"
-#, fuzzy
#~ msgid "Select features"
-#~ msgstr "Sélectionner des objets vectoriels"
+#~ msgstr "Sélectionner des objets"
-#, fuzzy
#~ msgid "Create a new map"
-#~ msgstr "Créer un nouveau jeu de cartes"
+#~ msgstr "Créer une nouvelle carte"
-#, fuzzy
-#~ msgid ""
-#~ "Selected map <%s> has been disabled for rendering. Operation canceled."
-#~ msgstr "La carte vecteur n'est pas 3D. Opération annulée."
+#~ msgid "Selected map <%s> has been disabled for rendering. Operation canceled."
+#~ msgstr "L'affichage de la carte sélectionnée <%s> a été désactivé. Opération annulée."
#, fuzzy
#~ msgid "Failed to query vector map(s) <%s>."
-#~ msgstr "Impossible d'ouvrir la carte vecteur <%s>."
+#~ msgstr "Échec d'interrogation de la carte vecteur <%s>."
-#, fuzzy
#~ msgid "No features selected"
-#~ msgstr "Pas de source de données sélectionnée."
+#~ msgstr "Pas d'objets sélectionnée."
-#, fuzzy
#~ msgid "Vector map <%s> was created"
-#~ msgstr "Nouvelle carte vecteur <%s> créée"
+#~ msgstr "La carte vecteur <%s> a créée"
-#, fuzzy
#~ msgid ""
#~ "Unable to create a new vector map.\n"
#~ "\n"
#~ "Reason: %s"
-#~ msgstr "Impossible de créer la carte vecteur <%s>."
+#~ msgstr ""
+#~ "Impossible de créer la nouvelle carte vecteur.\n"
+#~ "\n"
+#~ "Raison: %s"
-#, fuzzy
#~ msgid "Add linked layers into layer tree"
-#~ msgstr "Ajouter les couches importées dans l'arborescence des couches"
+#~ msgstr "Ajouter les couches liées dans l'arborescence des couches"
-#, fuzzy
#~ msgid "Unable to determine number of raster bands"
-#~ msgstr "Impossible de créer le profil de carte raster."
+#~ msgstr "Impossible de déterminer le nombre de bandes du raster"
#~ msgid "1:"
#~ msgstr "1:"
-#, fuzzy
-#~ msgid ""
-#~ "Creates a raster map from LAS LiDAR points using univariate statistics."
-#~ msgstr ""
-#~ "Créer une carte raster à partir d'un assemblage d'un lot de coordonnées "
-#~ "en utilisant des statistiques univariées."
+#~ msgid "Creates a raster map from LAS LiDAR points using univariate statistics."
+#~ msgstr "Créer une carte raster à partir de points LiDAR LAS en utilisant des statistiques univariées."
-#, fuzzy
#~ msgid "Converts LAS LiDAR point clouds to a GRASS vector map with libLAS."
-#~ msgstr "Convertir des couches vectorielles OGR en carte vectorielle GRASS."
+#~ msgstr "Convertir un nuage de points LiDAR LAS vers une carte vecteur GRASS avec libLAS."
#, fuzzy
#~ msgid "Temporal plot tool"
@@ -18820,24 +17447,18 @@
#~ msgstr "Calcule l'indice de forme sur une carte raster"
#, fuzzy
-#~ msgid ""
-#~ "Raster map <%s> already exists in the current mapset. Do you want to "
-#~ "overwrite it?"
-#~ msgstr ""
-#~ "La carte vecteur <%s> existe déjà dans le jeu de cartes courant. Voulez-"
-#~ "vous l'écraser ?"
+#~ msgid "Raster map <%s> already exists in the current mapset. Do you want to overwrite it?"
+#~ msgstr "La carte vecteur <%s> existe déjà dans le jeu de cartes courant. Voulez-vous l'écraser ?"
-#, fuzzy
#~ msgid "GRASS GIS Temporal Plot Tool"
-#~ msgstr "Histogramme GRASS"
+#~ msgstr "Outil d'affichage "
#, fuzzy
#~ msgid "Select space time raster dataset(s):"
#~ msgstr "Choisir le jeu de cartes source:"
-#, fuzzy
#~ msgid "Temporal resolution: %s"
-#~ msgstr "Mode catégorie"
+#~ msgstr "Résolution temporelle : %s"
#, fuzzy
#~ msgid "Invalid input coordinates"
@@ -18847,21 +17468,17 @@
#~ msgid "Invalid input temporal dataset"
#~ msgstr "Entrée non valide"
-#, fuzzy
#~ msgid "Data catalog"
-#~ msgstr "Sélection des données"
+#~ msgstr "Catalogue de données"
-#, fuzzy
#~ msgid "GRASS SVN revision"
#~ msgstr "Version SVN:"
-#, fuzzy
#~ msgid "Build date"
#~ msgstr "Date de compilation"
-#, fuzzy
#~ msgid "Build platform"
-#~ msgstr "Plateforme"
+#~ msgstr "Plateforme de compilation"
#, fuzzy
#~ msgid "Unable to start Temporal Plot Tool."
@@ -18871,15 +17488,13 @@
#, fuzzy
#~ msgid "No mapsets readable"
-#~ msgstr "Pas de paramètres disponibles"
+#~ msgstr "Pas de jeux de cartes accessible"
-#, fuzzy
#~ msgid "New name"
-#~ msgstr "Renommer"
+#~ msgstr "Nouveau nom"
-#, fuzzy
#~ msgid "Rename map"
-#~ msgstr "Renommer le jeu de cartes"
+#~ msgstr "Renommer la carte"
#, fuzzy
#~ msgid "Editing"
@@ -18889,25 +17504,21 @@
#~ msgid "Renaming"
-#, fuzzy
#~ msgid "Failed to copy layer: invalid type."
-#~ msgstr "Impossible de lire le fichier %s."
+#~ msgstr "Échec de copie de la couche : type invalide."
-#, fuzzy
#~ msgid "Copy map"
-#~ msgstr "Copier la table"
+#~ msgstr "Copier la carte"
#, fuzzy
#~ msgid "Copying"
-#~ msgstr "Copier la ligne"
+#~ msgstr "Copie"
-#, fuzzy
#~ msgid "Do you really want to delete map <{m}>?"
-#~ msgstr "Voulez-vous créer un nouveau jeux de données ?"
+#~ msgstr "Voulez-vous vraiment supprimer la carte <{m}> ?"
-#, fuzzy
#~ msgid "Delete map"
-#~ msgstr "Supprimer le jeu de cartes"
+#~ msgstr "Supprimer la carte"
#~ msgid "Deleting"
#~ msgstr "Supprimer"
@@ -18916,22 +17527,70 @@
#~ msgid "Displaying"
#~ msgstr "Affichage"
-#, fuzzy
#~ msgid "&Copy"
-#~ msgstr "Copier"
+#~ msgstr "&Copier"
#, fuzzy
#~ msgid "&Paste"
-#~ msgstr "&Raster"
+#~ msgstr "&Coller"
#, fuzzy
#~ msgid "&Display layer"
#~ msgstr "Afficher la carte"
-#, fuzzy
-#~ msgid ""
-#~ "Do you want to import <%(name)s> to the newly created location? The "
-#~ "location's default region will be set from this imported map."
-#~ msgstr ""
-#~ "Voulez-vous importer la source de données <%(name)s> pour créer le "
-#~ "secteur ? la région par défaut sera alignée sur la carte importée."
+#~ msgid "Do you want to import <%(name)s> to the newly created location? The location's default region will be set from this imported map."
+#~ msgstr "Voulez-vous importer <%(name)s> dans le nouveau secteur ? La région par défaut sera alignée sur la carte importée."
+#~ msgid "Reload attribute data (selected layer only)"
+#~ msgstr "Recharger les données attributaires (couche sélectionnée seulement) "
+#~ msgid "Row lenght of sampling frame"
+#~ msgstr "Nombre de lignes du cadre d'échantillonage"
+#~ msgid "Preview is not available probably due to missing Ghostscript."
+#~ msgstr "L'aperçu n'est pas disponible, probablement parce qu'il manque Ghostscript."
+#~ msgid "Thins non-zero cells that denote linear features in a raster map layer."
+#~ msgstr "Réduit les cellules non vides qui définissent une entité linéaire dans une couche raster."
+#~ msgid "Flow computation for massive grids (float version)."
+#~ msgstr "Calcul des flux pour une grille massive (version nombre flottants)."
+#~ msgid "Hide statusbar"
+#~ msgstr "Cacher la barre de status"
+#~ msgid "Right click to finish area"
+#~ msgstr "Clic droit pour terminer la surface"
+#~ msgid "Right click to finish line"
+#~ msgstr "Clic droit pour terminer la ligne"
+#~ msgid "Set drawing color (not raster cell color)"
+#~ msgstr "Définir la couleur de dessin (pas la couleur des cellules du raster)"
+#~ msgid "X and Y coordinates separated by comma:"
+#~ msgstr "coordonnées X et Y séparées par des virgules :"
+#~ msgid "Coordinates can be obtained for example by right-clicking on Map Display."
+#~ msgstr "Les coordonnées peuvent être obtenues par exemple par un clic-droit dans la fenêtre de cartes."
+#~ msgid "Incorrect format of coordinates, should be: x,y"
+#~ msgstr "Format de coordonnées incorrect , devrait être : x,y"
+#~ msgid "Datasets have different number ofvalues"
+#~ msgstr "Les jeux de données ont des nombres de valeurs différents"
+#~ msgid "Value for {date} is {val}"
+#~ msgstr "La valeur pour {date} est {val}"
+#~ msgid "Press Del to dismiss."
+#~ msgstr "Appuyer sur Suppr pour annuler."
+#~ msgid "Layer was not copied: new layer has the same name"
+#~ msgstr "Couche non copiée : la nouvelle couche a le même nom"
+#~ msgid "Failed to copy layer: action is allowed only within the same location."
+#~ msgstr "Échec de copie de la couche : cette action est autorisée uniquement dans le même secteur."
+#~ msgid "Failed to display layer: not in current mapset or invalid layer"
+#~ msgstr "Échec d'affichage de la couche : pas dans le jeu de données courant ou couche invalide"
