[GRASS-SVN] r65789 - grass/trunk/lib/python/script
Wed Jul 29 07:07:15 PDT 2015
Author: zarch
Date: 2015-07-29 07:07:15 -0700 (Wed, 29 Jul 2015)
New Revision: 65789
   grass/trunk/lib/python/script/db.py
scipt:db add python3 support
Modified: grass/trunk/lib/python/script/db.py
--- grass/trunk/lib/python/script/db.py	2015-07-29 14:06:41 UTC (rev 65788)
+++ grass/trunk/lib/python/script/db.py	2015-07-29 14:07:15 UTC (rev 65789)
@@ -18,9 +18,9 @@
 .. sectionauthor:: Glynn Clements
 .. sectionauthor:: Martin Landa <landa.martin gmail.com>
-from core import *
-from utils import try_remove
+from __future__ import absolute_import
+from .core import *
+from .utils import try_remove
 from grass.exceptions import CalledModuleError
@@ -110,7 +110,7 @@
     if not conn and force:
         run_command('db.connect', flags='c')
         conn = parse_command('db.connect', flags='g')
     return conn
 def db_select(sql=None, filename=None, table=None, **args):
