[GRASS-SVN] r65794 - grass/trunk/lib/python/script
Wed Jul 29 07:12:13 PDT 2015
Author: zarch
Date: 2015-07-29 07:12:13 -0700 (Wed, 29 Jul 2015)
New Revision: 65794
   grass/trunk/lib/python/script/array.py
scipt:array add python3 support
Modified: grass/trunk/lib/python/script/array.py
--- grass/trunk/lib/python/script/array.py	2015-07-29 14:11:19 UTC (rev 65793)
+++ grass/trunk/lib/python/script/array.py	2015-07-29 14:12:13 UTC (rev 65794)
@@ -3,12 +3,13 @@
 Usage:
->>> import grass.script as grass
+>>> from __future__ import print_function
+>>> import grass.script as gscript
 >>> from grass.script import array as garray
 >>> # We create a temporary region that is only valid in this python session
-... grass.use_temp_region()
->>> grass.run_command("g.region", n=80, e=120, t=60, s=0, w=0, b=0, res=20, res3=20)
+... gscript.use_temp_region()
+>>> gscript.run_command("g.region", n=80, e=120, t=60, s=0, w=0, b=0, res=20, res3=20)
 0
 >>> # Lets create a raster map numpy array
@@ -21,7 +22,7 @@
 ...         map2d_1[y,x] = y + x
 >>> # Lets have a look at the array
-... print map2d_1
+... print(map2d_1)
 [[ 0.  1.  2.  3.  4.  5.]
  [ 1.  2.  3.  4.  5.  6.]
  [ 2.  3.  4.  5.  6.  7.]
@@ -39,7 +40,7 @@
 0
 >>> map2d_2 %= 3
 >>> # Show the result
-... print map2d_2
+... print(map2d_2)
 [[ 0.  1.  2.  0.  1.  2.]
  [ 1.  2.  0.  1.  2.  0.]
  [ 2.  0.  1.  2.  0.  1.]
@@ -60,7 +61,7 @@
 ...             map3d_1[z,y,x] = z + y + x
 >>> # Lets have a look at the 3D array
-... print map3d_1
+... print(map3d_1)
 [[[  0.   1.   2.   3.   4.   5.]
@@ -87,7 +88,7 @@
 0
 >>> map3d_2 %= 3
 >>> # Show the result
-... print map3d_2
+... print(map3d_2)
 [[[ 0.  1.  2.  0.  1.  2.]
@@ -113,12 +114,12 @@
 .. sectionauthor:: Glynn Clements
+from __future__ import absolute_import
-import os
 import numpy
-from utils import try_remove
-import core as grass
+from .utils import try_remove
+from . import core as gcore
 from grass.exceptions import CalledModuleError
@@ -126,7 +127,7 @@
 class _tempfile(object):
     def __init__(self):
-        self.filename = grass.tempfile()
+        self.filename = gcore.tempfile()
     def __del__(self):
         try_remove(self.filename)
@@ -140,7 +141,7 @@
         :param cls:
         :param dtype: data type (default: numpy.double)
-        reg = grass.region()
+        reg = gcore.region()
         r = reg['rows']
         c = reg['cols']
         shape = (r, c)
@@ -181,7 +182,7 @@
             raise ValueError(_('Invalid size <%d>') % size)
         try:
-            grass.run_command(
+            gcore.run_command(
                 'r.out.bin',
                 flags=flags,
                 input=mapname,
@@ -224,10 +225,10 @@
         else:
             raise ValueError(_('Invalid kind <%s>') % kind)
         try:
                 'r.in.bin',
                 flags=flags,
                 input=self.filename,
@@ -257,7 +258,7 @@
         :param cls:
-        reg = grass.region(True)
+        reg = gcore.region(True)
         r = reg['rows3']
         c = reg['cols3']
         d = reg['depths']
@@ -300,7 +301,7 @@
         try:
                 'r3.out.bin',
                 flags=flags,
                 input=mapname,
@@ -338,10 +339,10 @@
         else:
         try:
                 'r3.in.bin',
                 flags=flags,
