[GRASS-SVN] r65348 - in grass/trunk: include/defs lib/gis lib/init lib/raster lib/vector/Vlib
Mon Jun 1 07:57:03 PDT 2015
Author: martinl
Date: 2015-06-01 07:57:03 -0700 (Mon, 01 Jun 2015)
New Revision: 65348
   grass/trunk/include/defs/gis.h
   grass/trunk/lib/gis/file_name.c
   grass/trunk/lib/gis/mapset_msc.c
   grass/trunk/lib/gis/open.c
   grass/trunk/lib/gis/remove.c
   grass/trunk/lib/gis/rename.c
   grass/trunk/lib/gis/tempfile.c
   grass/trunk/lib/init/clean_temp.c
   grass/trunk/lib/init/grass.py
   grass/trunk/lib/init/variables.html
   grass/trunk/lib/raster/close.c
   grass/trunk/lib/vector/Vlib/build.c
   grass/trunk/lib/vector/Vlib/build_ogr.c
   grass/trunk/lib/vector/Vlib/cindex.c
   grass/trunk/lib/vector/Vlib/close.c
   grass/trunk/lib/vector/Vlib/close_nat.c
   grass/trunk/lib/vector/Vlib/close_pg.c
   grass/trunk/lib/vector/Vlib/field.c
   grass/trunk/lib/vector/Vlib/header.c
   grass/trunk/lib/vector/Vlib/local_proto.h
   grass/trunk/lib/vector/Vlib/map.c
   grass/trunk/lib/vector/Vlib/open.c
   grass/trunk/lib/vector/Vlib/open_nat.c
make GRASS data TMPDIR configurable (GRASS_TMPDIR_MAPSET && TMPDIR)
changes in API (new fns): G_file_name_tmp(), G_make_mapset_element_tmp(), G_recursive_remove()
change GRASS_VECTOR_TEMPORARY to support various modes (delete, keep, and move)
update GIS/Raster/Vector API to support this feature
update initialization script to allow defining TMPDIR
Modified: grass/trunk/include/defs/gis.h
--- grass/trunk/include/defs/gis.h	2015-06-01 14:42:58 UTC (rev 65347)
+++ grass/trunk/include/defs/gis.h	2015-06-01 14:57:03 UTC (rev 65348)
@@ -247,6 +247,7 @@
 char *G_file_name(char *, const char *, const char *, const char *);
 char *G_file_name_misc(char *, const char *, const char *, const char *,
 		       const char *);
+char *G_file_name_tmp(char *, const char *, const char *, const char *);
 /* find_file.c */
 const char *G_find_file(const char *, char *, const char *);
@@ -437,6 +438,7 @@
 /* mapset_msc.c */
 int G_make_mapset_element(const char *);
+int G_make_mapset_element_tmp(const char *);
 int G__make_mapset_element_misc(const char *, const char *);
 int G_mapset_permissions(const char *);
 int G_mapset_permissions2(const char *, const char *, const char *);
@@ -596,6 +598,7 @@
 /* remove.c */
 int G_remove(const char *, const char *);
 int G_remove_misc(const char *, const char *, const char *);
+int G_recursive_remove(const char *);
 /* rename.c */
 int G_rename_file(const char *, const char *);
Modified: grass/trunk/lib/gis/file_name.c
--- grass/trunk/lib/gis/file_name.c	2015-06-01 14:42:58 UTC (rev 65347)
+++ grass/trunk/lib/gis/file_name.c	2015-06-01 14:57:03 UTC (rev 65348)
@@ -3,28 +3,32 @@
    \brief GIS library - Determine GRASS data base file name
-   (C) 2001-2008, 2013 by the GRASS Development Team
+   (C) 2001-2015 by the GRASS Development Team
    This program is free software under the GNU General Public License
-   (>=v2).  Read the file COPYING that comes with GRASS for details.
+   (>=v2). Read the file COPYING that comes with GRASS for details.
    \author Original author CERL
 #include <string.h>
+#include <stdlib.h>
 #include <grass/gis.h>
 #include "gis_local_proto.h"
+char *file_name(char *, const char *, const char *,
+                const char *, const char *, const char *);
   \brief Builds full path names to GIS data files
-  If name is of the form "nnn at ppp" then path is set as if name had
-  been nnn and mapset had been ppp (mapset parameter itself is ignored
-  in this case).
+  If <i>name</i> is of the form "nnn at ppp" then path is set as if name
+  had been "nnn" and mapset had been "ppp" (mapset parameter itself is
+  ignored in this case).
   \param[out] path buffer to hold resultant full path to file
-  \param element database element (eg, "cell", "cellhd", etc)
+  \param element database element (eg, "cell", "cellhd", "vector", etc)
   \param name name of file to build path to (fully qualified names allowed)
   \param mapset mapset name
@@ -33,85 +37,116 @@
 char *G_file_name(char *path,
 		   const char *element, const char *name, const char *mapset)
-    char xname[GNAME_MAX];
-    char xmapset[GMAPSET_MAX];
-    const char *pname = name;
-    char *location = G__location_path();
+    return file_name(path, NULL, element, name, mapset, NULL);
-     * if a name is given, build a file name
-     * must split the name into name, mapset if it is
-     * in the name at mapset format
-    if (name && *name && G_name_is_fully_qualified(name, xname, xmapset)) {
-	pname = xname;
-	sprintf(path, "%s/%s", location, xmapset);
-    else if (mapset && *mapset)
-	sprintf(path, "%s/%s", location, mapset);
-    else
-	sprintf(path, "%s/%s", location, G_mapset());
+  \brief Builds full path names to GIS misc data files
-    G_free(location);
+  \param[out] path buffer to hold resultant full path to file
+  \param dir misc directory
+  \param name name of file to build path to (fully qualified names allowed)
+  \param mapset mapset name
-    if (!element && !pname)
-        return path;
-    if (element && *element) {
-	strcat(path, "/");
-	strcat(path, element);
+  \return pointer to <i>path</i> buffer
+char *G_file_name_misc(char *path,
+			const char *dir,
+			const char *element,
+			const char *name, const char *mapset)
+    return file_name(path, dir, element, name, mapset, NULL);
-    if (pname && *pname) {
-	strcat(path, pname);
+  \brief Builds full path names to GIS data files in temporary directory
+  By default temporary directory is located
+  $LOCATION/$MAPSET/.tmp/$HOSTNAME. If GRASS_TMPDIR_MAPSET is set to
+  "0", the temporary directory is located in TMPDIR (environmental
+  variable defined by the user or GRASS initialization script if not
+  given).
+char *G_file_name_tmp(char *path,
+    const char *env, *tmp_path;
+    tmp_path = NULL;
+    env = getenv("GRASS_TMPDIR_MAPSET");
+    if (env && strcmp(env, "0") == 0) {
+        tmp_path = getenv("TMPDIR");
-    G_debug(2, "G_file_name(): path = %s", path);
-    return path;
+    return file_name(path, NULL, element, name, mapset, tmp_path);
-char *G_file_name_misc(char *path,
-			const char *dir,
-			const char *element,
-			const char *name, const char *mapset)
+char *file_name(char *path,
+                const char *dir, const char *element, const char *name,
+                const char *mapset, const char *base)
-	pname = xname;
+    if (base && *base) {
+        sprintf(path, "%s", base);
-    else
+    else {
+        char xname[GNAME_MAX];
+        char xmapset[GMAPSET_MAX];
+        char *location = G__location_path();
+         * if a name is given, build a file name
+         * must split the name into name, mapset if it is
+         * in the name at mapset format
+        if (name && *name && G_name_is_fully_qualified(name, xname, xmapset)) {
+            pname = xname;
+            sprintf(path, "%s/%s", location, xmapset);
+        else if (mapset && *mapset)
+            sprintf(path, "%s/%s", location, mapset);
+        else
+            sprintf(path, "%s/%s", location, G_mapset());
+        G_free(location);
-    G_free(location);
-    if (dir && *dir) {
+    if (dir && *dir) { /* misc element */
 	strcat(path, "/");
 	strcat(path, dir);
+        if (pname && *pname) {
+            strcat(path, "/");
+            strcat(path, pname);
+        if (element && *element) {
+            strcat(path, element);
+    else {
+    G_debug(2, "G_file_name(): path = %s", path);
     return path;
Modified: grass/trunk/lib/gis/mapset_msc.c
--- grass/trunk/lib/gis/mapset_msc.c	2015-06-01 14:42:58 UTC (rev 65347)
+++ grass/trunk/lib/gis/mapset_msc.c	2015-06-01 14:57:03 UTC (rev 65348)
@@ -19,30 +19,59 @@
 #include <grass/glocale.h>
+static int make_mapset_element(const char *, const char *);
    \brief Create element in the current mapset.
-   Make the specified element in the current mapset
-   will check for the existence of the element and
-   do nothing if it is found so this routine
-   can be called even if the element already exists.
+   Make the specified element in the current mapset will check for the
+   existence of the element and do nothing if it is found so this
+   routine can be called even if the element already exists.
+   Calls G_fatal_error() on failure.
+   \param p_element element to be created in mapset
-   \param element element to be created in mapset
-   \return 0 ?
-   \return ?
+   \return 0 no element defined
+   \return 1 on success
 int G_make_mapset_element(const char *p_element)
     char path[GPATH_MAX];
-    char *p;
+    G_file_name(path, NULL, NULL, G_mapset());
+    return make_mapset_element(path, p_element);
+   \brief Create element in the temporary directory.
+   See G_file_name_tmp() for details.
+int G_make_mapset_element_tmp(const char *p_element)
+    char path[GPATH_MAX];
+    G_file_name_tmp(path, NULL, NULL, G_mapset());
+int make_mapset_element(const char *p_path, const char *p_element)
+    char path[GPATH_MAX], *p;
     const char *element;
     element = p_element;
     if (*element == 0)
 	return 0;
-    G_file_name(p = path, NULL, NULL, G_mapset());
+    strncpy(path, p_path, GPATH_MAX);
+    p = path;
     while (*p)
 	p++;
     /* add trailing slash if missing */
@@ -75,10 +104,10 @@
    \brief Create misc element in the current mapset.
    \param dir directory path
-   \param name element name
+   \param name element to be created in mapset
-   \return 0 ?
-   \return ?
 int G__make_mapset_element_misc(const char *dir, const char *name)
Modified: grass/trunk/lib/gis/open.c
--- grass/trunk/lib/gis/open.c	2015-06-01 14:42:58 UTC (rev 65347)
+++ grass/trunk/lib/gis/open.c	2015-06-01 14:57:03 UTC (rev 65348)
@@ -3,7 +3,7 @@
  * \brief GIS Library - Open file functions
- * (C) 1999-2009 by the GRASS Development Team
+ * (C) 1999-2015 by the GRASS Development Team
  * This program is free software under the GNU General Public
  * License (>=v2). Read the file COPYING that comes with GRASS
@@ -53,11 +53,18 @@
 		   const char *name, const char *mapset, int mode)
     int fd;
+    int is_tmp;
     char xname[GNAME_MAX], xmapset[GMAPSET_MAX];
+    G__check_gisinit();
+    is_tmp = (element && strncmp(element, ".tmp", 3) == 0);
-    G__check_gisinit();
+    if (is_tmp)
+        G_file_name_tmp(path, element, name, mapset);
+    else
+        G_file_name(path, element, name, mapset);
     /* READ */
     if (mode == 0) {
@@ -71,13 +78,13 @@
 	    mapset = xmapset;
-	mapset = G_find_file2(element, name, mapset);
-	if (!mapset)
-	    return -1;
-	G_file_name(path, element, name, mapset);
+        if (!is_tmp) {
+            mapset = G_find_file2(element, name, mapset);
+            if (!mapset)
+                return -1;
 	if ((fd = open(path, 0)) < 0)
 	    G_warning(_("G__open(read): Unable to open '%s': %s"),
 	              path, strerror(errno));
@@ -98,10 +105,11 @@
 	if (*name && G_legal_filename(name) == -1)
 	    return -1;
 	if (mode == 1 || access(path, 0) != 0) {
-	    G_make_mapset_element(element);
+            if (is_tmp)
+                G_make_mapset_element_tmp(element);
+            else
+                G_make_mapset_element(element);
 	    close(open(path, O_WRONLY | O_CREAT | O_TRUNC, 0666));
Modified: grass/trunk/lib/gis/remove.c
--- grass/trunk/lib/gis/remove.c	2015-06-01 14:42:58 UTC (rev 65347)
+++ grass/trunk/lib/gis/remove.c	2015-06-01 14:57:03 UTC (rev 65348)
@@ -21,7 +21,6 @@
 #include <dirent.h>
-static int recursive_remove(const char *path);
 static int G__remove(int misc, const char *dir, const char *element,
 		     const char *name);
@@ -95,14 +94,23 @@
     if (access(path, 0) != 0)
 	return 0;
-    if (recursive_remove(path) == 0)
+    if (G_recursive_remove(path) == 0)
 	return 1;
     return -1;
-/* equivalent to rm -rf path */
+  \brief Recursively remove all files in given directory
+  Equivalent to rm -rf path.
+  \param path path to the directory which should be removed
+  \return 0 on success
+  \return -1 on error
+int G_recursive_remove(const char *path)
     DIR *dirp;
     struct dirent *dp;
@@ -110,21 +118,21 @@
     char path2[GPATH_MAX];
     if (G_lstat(path, &sb))
-	return 1;
+	return -1;
     if (!S_ISDIR(sb.st_mode))
-	return remove(path) == 0 ? 0 : 1;
+	return remove(path) == 0 ? 0 : -1;
     if ((dirp = opendir(path)) == NULL)
-	return 1;
+	return -1;
     while ((dp = readdir(dirp)) != NULL) {
 	if (dp->d_name[0] == '.')
 	    continue;
 	if (strlen(path) + strlen(dp->d_name) + 2 > sizeof(path2))
 	    continue;
 	sprintf(path2, "%s/%s", path, dp->d_name);
-	recursive_remove(path2);
+	G_recursive_remove(path2);
     closedir(dirp);
-    return rmdir(path) == 0 ? 0 : 1;
+    return rmdir(path) == 0 ? 0 : -1;
Modified: grass/trunk/lib/gis/rename.c
--- grass/trunk/lib/gis/rename.c	2015-06-01 14:42:58 UTC (rev 65347)
+++ grass/trunk/lib/gis/rename.c	2015-06-01 14:57:03 UTC (rev 65348)
@@ -3,7 +3,7 @@
  * \brief GIS Library - Rename file functions.
- * (C) 2001-2009 by the GRASS Development Team
+ * (C) 2001-2015 by the GRASS Development Team
  * This program is free software under the GNU General Public License
  * (>=v2). Read the file COPYING that comes with GRASS for details.
@@ -19,7 +19,7 @@
-  \brief Rename a file in the filesystem.
+  \brief Rename a file or a directory in the filesystem.
   The file or directory <i>oldname</i> is renamed to <i>newname</i>.
@@ -31,12 +31,23 @@
 int G_rename_file(const char *oldname, const char *newname)
+    int ret;
 #ifdef __MINGW32__
     remove(newname);
 #endif
+    ret = rename(oldname, newname);
-    return rename(oldname, newname);
+    if (ret == -1) {
+	/* if fails, try to copy file and then remove */
+	if (1 == G_copy_file(oldname, newname)) {
+	    if (remove(oldname) != -1)
+		ret = 0;
+    return ret;
Modified: grass/trunk/lib/gis/tempfile.c
--- grass/trunk/lib/gis/tempfile.c	2015-06-01 14:42:58 UTC (rev 65347)
+++ grass/trunk/lib/gis/tempfile.c	2015-06-01 14:57:03 UTC (rev 65348)
@@ -3,7 +3,7 @@
  * \brief GIS Library - Temporary file functions.
@@ -14,6 +14,8 @@
 #include <string.h>
 #include <unistd.h>
 #include <sys/stat.h>
@@ -83,10 +85,12 @@
     do {
 	int uniq = G_counter_next(&unique);
 	sprintf(name, "%d.%d", pid, uniq);
-	G_file_name(path, element, name, G_mapset());
+	G_file_name_tmp(path, element, name, G_mapset());
     while (access(path, F_OK) == 0);
+    G_debug(2, "G_tempfile_pid(): %s", path);
     return G_store(path);
@@ -97,7 +101,7 @@
 void G_temp_element(char *element)
-    const char *machine;
+    const char *machine, *env;
     strcpy(element, ".tmp");
     machine = G__machine_name();
@@ -105,5 +109,13 @@
 	strcat(element, "/");
 	strcat(element, machine);
+    if (!env || strcmp(env, "0") != 0)
+    else
+    G_debug(2, "G_temp_element(): %s (GRASS_TMPDIR_MAPSET=%s)",
+            element, env ? env : "");
Modified: grass/trunk/lib/init/clean_temp.c
--- grass/trunk/lib/init/clean_temp.c	2015-06-01 14:42:58 UTC (rev 65347)
+++ grass/trunk/lib/init/clean_temp.c	2015-06-01 14:57:03 UTC (rev 65348)
@@ -135,7 +135,7 @@
     /* Get the mapset temp directory */
     G_temp_element(element);
-    G_file_name(tmppath, element, "", mapset = G_mapset());
+    G_file_name_tmp(tmppath, element, "", mapset = G_mapset());
     /* get user id and current time in seconds */
 #ifdef __MINGW32__
Modified: grass/trunk/lib/init/grass.py
--- grass/trunk/lib/init/grass.py	2015-06-01 14:42:58 UTC (rev 65347)
+++ grass/trunk/lib/init/grass.py	2015-06-01 14:57:03 UTC (rev 65348)
@@ -985,9 +985,6 @@
         except:
             continue
-        if k in ('TMPDIR', 'TEMP', 'TMP'):
-            continue # don't overwrite TMPDIR set by create_tmp()
         debug("Environmental variable set {}={}".format(k, v))
         os.environ[k] = v
@@ -1700,6 +1697,14 @@
     # thus must be called only after Language has been set.
     set_language(grass_config_dir)
+    # Set shell (needs to be called before load_env())
+    sh, shellname = get_shell()
+    grass_env_file = get_grass_env_file(sh, grass_config_dir)
+    # Load environmental variables from the file (needs to be called
+    # before create_tmp())
+    load_env(grass_env_file)
     # Create the temporary directory and session grassrc file
     tmpdir = create_tmp(user, gis_lock)
@@ -1711,13 +1716,6 @@
     # Create the session grassrc file
     gisrc = create_gisrc(tmpdir, gisrcrc)
-    # Set shell (needs to be called before load_env())
-    sh, shellname = get_shell()
-    grass_env_file = get_grass_env_file(sh, grass_config_dir)
-    # Load environmental variables from the file
-    load_env(grass_env_file)
     ensure_home()
     # Set PATH, PYTHONPATH, ...
     set_paths(grass_config_dir=grass_config_dir)
Modified: grass/trunk/lib/init/variables.html
--- grass/trunk/lib/init/variables.html	2015-06-01 14:42:58 UTC (rev 65347)
+++ grass/trunk/lib/init/variables.html	2015-06-01 14:57:03 UTC (rev 65348)
@@ -276,15 +276,27 @@
   <dt>GRASS_VECTOR_TEMPORARY</dt>
   <dd>[vectorlib]<br> If the environment variable
-    GRASS_VECTOR_TEMPORARY exists, vector library will operate with
-    temporary vector maps. New vector maps will be created
-    in <tt>$MAPSET/.tmp/$HOSTNAME/vector</tt>, existing vector maps
-    will be read also from this directory. Note that temporary vector
-    maps are not visible to the user
-    via <em><a href="g.list.html">g.list</a></em>. They are used
-    internally by the GRASS modules and deleted automatically when the
-    map is closed or GRASS session quited. Note that this variable is
-    dedicated for internal use only.</dd>
+    GRASS_VECTOR_TEMPORARY exists, GRASS vector library will operate
+    on temporary vector maps. New vector maps will be created in
+    temporary directory (see GRASS_TMPDIR_MAPSET variable), existing
+    vector maps will be read (if found) also from this directory. It
+    may be set to either:
+    <ul>
+      <li><tt>keep</tt> - the temporary vector map is not deleted when
+      closing the map.
+      <li><tt>move</tt> - the temporary vector map is moved to the
+      current mapset when closing the map.</li>
+      <li><tt>delete</tt> - the temporary vector map is deleted when
+      closing the map.
+      </li>
+    </ul>
+    Default value is <tt>keep</tt>.
+    Note that temporary vector maps are not visible to the user
+    via <em><a href="g.list.html">g.list</a></em>
+    or <em><a href="wxGUI.html">wxGUI</a></em>. They are used
+    internally by the GRASS modules and deleted automatically when
+    GRASS session is quited.</dd>
   <dt>GRASS_VECTOR_TOPO_DEBUG</dt>
   <dd>[vectorlib, v.generalize]<br> If the environment variable
@@ -334,7 +346,14 @@
     If OpenMP support is enabled this limits the number of threads.
     The default is set to the number of CPUs on the system.
     Setting to '1' effectively disables parallel processing.</dd>
+  <dt>GRASS_TMPDIR_MAPSET</dt>
+  <dd> By default GRASS temporary directory is located in
+  <tt>$LOCATION/$MAPSET/.tmp/$HOSTNAME</tt>. If GRASS_TMPDIR_MAPSET is
+  set to '0', the temporary directory is located in TMPDIR
+  (environmental variable defined by the user or GRASS initialization
+  script if not given).</dd>
   <dt>TMPDIR, TEMP, TMP</dt>
   <dd>[Various GRASS GIS commands and wxGUI]<br>
   <!-- what about Windows %TEMP% and http://trac.osgeo.org/grass/ticket/560#comment:21 ? -->
Modified: grass/trunk/lib/raster/close.c
--- grass/trunk/lib/raster/close.c	2015-06-01 14:42:58 UTC (rev 65347)
+++ grass/trunk/lib/raster/close.c	2015-06-01 14:57:03 UTC (rev 65348)
@@ -375,15 +375,15 @@
 	if (fcb->null_cur_row > 0) {
 	    /* if temporary NULL file exists, write it into cell_misc/name/null */
-	    if (rename(fcb->null_temp_name, path)) {
-		G_warning(_("Unable to rename null file '%s' to '%s': %s"),
+	    if (0 != G_rename_file(fcb->null_temp_name, path)) {
+		G_warning(_("Unable to rename file <%s> to <%s>: %s"),
 			  fcb->null_temp_name, path, strerror(errno));
 		stat = -1;
-	    /* if rename() was successful what is left to remove() ? */
+            /* if rename() was successful what is left to remove() ? */
 	    else {
 		remove(fcb->null_temp_name);
 	else {
@@ -450,8 +450,9 @@
     if (ok && (fcb->temp_name != NULL)) {
 	G_file_name(path, CELL_DIR, fcb->name, fcb->mapset);
 	remove(path);
-	if (rename(fcb->temp_name, path)) {
-	    G_warning(_("Unable to rename cell file '%s' to '%s': %s"),
+	if (G_rename_file(fcb->temp_name, path)) {
 		      fcb->temp_name, path, strerror(errno));
 	    stat = -1;
Modified: grass/trunk/lib/vector/Vlib/build.c
--- grass/trunk/lib/vector/Vlib/build.c	2015-06-01 14:42:58 UTC (rev 65347)
+++ grass/trunk/lib/vector/Vlib/build.c	2015-06-01 14:57:03 UTC (rev 65348)
@@ -998,7 +998,7 @@
 int Vect_save_topo(struct Map_info *Map)
     struct Plus_head *plus;
-    char *path;
     struct gvfile fp;
     G_debug(1, "Vect_save_topo()");
@@ -1007,9 +1007,8 @@
     plus = &(Map->plus);
     dig_file_init(&fp);
-    path = Vect__get_path(Map);
+    Vect__get_path(path, Map);
     fp.file = G_fopen_new(path, GV_TOPO_ELEMENT);
-    G_free(path);
     if (fp.file == NULL) {
 	G_warning(_("Unable to create topo file for vector map <%s>"), Map->name);
 	return 0;
@@ -1247,7 +1246,7 @@
 int Vect_save_sidx(struct Map_info *Map)
-    char *file_path;
+    char file_path[GPATH_MAX];
     G_debug(1, "Vect_save_spatial_index()");
@@ -1261,11 +1260,10 @@
     /* new or update mode ? */
     if (plus->Spidx_new == TRUE) {
 	/*  write out rtrees to sidx file  */
-        file_path = Vect__get_element_path(Map, GV_SIDX_ELEMENT);
+        Vect__get_element_path(file_path, Map, GV_SIDX_ELEMENT);
 	G_debug(1, "Open sidx: %s", file_path);
 	dig_file_init(&(plus->spidx_fp));
 	plus->spidx_fp.file = fopen(file_path, "w+");
-        G_free(file_path);
 	if (plus->spidx_fp.file == NULL) {
 	    G_warning(_("Unable to create spatial index file for vector map <%s>"),
 		      Vect_get_name(Map));
Modified: grass/trunk/lib/vector/Vlib/build_ogr.c
--- grass/trunk/lib/vector/Vlib/build_ogr.c	2015-06-01 14:42:58 UTC (rev 65347)
+++ grass/trunk/lib/vector/Vlib/build_ogr.c	2015-06-01 14:57:03 UTC (rev 65348)
@@ -27,6 +27,8 @@
 #include <ogr_api.h>
 #endif
+#include "local_proto.h"
    \brief Build pseudo-topology (simple features) for OGR layer
@@ -124,7 +126,7 @@
     length = 9;
     sprintf(elem, "%s/%s", GV_DIRECTORY, Map->name);
-    G_file_name(fname, elem, GV_FIDX_ELEMENT, Map->mapset);
+    Vect__get_element_path(fname, Map, GV_FIDX_ELEMENT);
     G_debug(4, "Open fidx: %s", fname);
     dig_file_init(&fp);
     fp.file = fopen(fname, "w");
Modified: grass/trunk/lib/vector/Vlib/cindex.c
--- grass/trunk/lib/vector/Vlib/cindex.c	2015-06-01 14:42:58 UTC (rev 65347)
+++ grass/trunk/lib/vector/Vlib/cindex.c	2015-06-01 14:57:03 UTC (rev 65348)
@@ -472,7 +472,7 @@
 int Vect_cidx_save(struct Map_info *Map)
-    char *path;
     struct gvfile fp;
     G_debug(2, "Vect_cidx_save()");
@@ -482,9 +482,8 @@
     dig_file_init(&fp);
     fp.file = G_fopen_new(path, GV_CIDX_ELEMENT);
-    G_free(path);
 	G_warning(_("Unable to create category index file for vector map <%s>"),
@@ -517,7 +516,7 @@
 int Vect_cidx_open(struct Map_info *Map, int head_only)
     int ret;
-    char file_path[GPATH_MAX], *path;
+    char file_path[GPATH_MAX], path[GPATH_MAX];
     struct gvfile fp;
     struct Plus_head *Plus;
@@ -526,17 +525,15 @@
     Plus = &(Map->plus);
-    G_file_name(file_path, path, GV_CIDX_ELEMENT, Map->mapset);
+    Vect__get_element_path(file_path, Map, GV_CIDX_ELEMENT);
     if (access(file_path, F_OK) != 0) {	/* does not exist */
-        G_free(path);
 	return 1;
     dig_file_init(&fp);
     fp.file = G_fopen_old(path, GV_CIDX_ELEMENT, Map->mapset);
-    G_free(path);
     if (fp.file == NULL) {	/* category index file is not available */
 	G_warning(_("Unable to open category index file for vector map <%s>"),
Modified: grass/trunk/lib/vector/Vlib/close.c
--- grass/trunk/lib/vector/Vlib/close.c	2015-06-01 14:42:58 UTC (rev 65347)
+++ grass/trunk/lib/vector/Vlib/close.c	2015-06-01 14:57:03 UTC (rev 65348)
@@ -323,14 +323,12 @@
 void unlink_file(const struct Map_info *Map, const char *name)
-    char *path;
     /* delete old support files if available */
-    path = Vect__get_element_path(Map, name);
+    Vect__get_element_path(path, Map, name);
     if (access(path, F_OK) == 0) { /* file exists? */
         G_debug(2, "\t%s: unlink", path);
         unlink(path);
-    G_free(path);
Modified: grass/trunk/lib/vector/Vlib/close_nat.c
--- grass/trunk/lib/vector/Vlib/close_nat.c	2015-06-01 14:42:58 UTC (rev 65347)
+++ grass/trunk/lib/vector/Vlib/close_nat.c	2015-06-01 14:57:03 UTC (rev 65348)
@@ -5,7 +5,7 @@
    Higher level functions for reading/writing/manipulating vectors.
-   (C) 2001-2009, 2013 by the GRASS Development Team
@@ -15,8 +15,11 @@
 #include <stdlib.h>
+#include <unistd.h>
+#include <errno.h>
 #include <grass/vector.h>
+#include <grass/glocale.h>
@@ -52,12 +55,115 @@
     /* delete temporary map ? */
     if (Map->temporary) {
-        if (getenv("GRASS_VECTOR_TEMPORARY") == NULL) {
-            G_debug(1, "V1_close_nat(): temporary map <%s> TO BE DELETED", Map->name);
-            Vect__delete(Map->name, TRUE);
+        int delete;
+        char *env = getenv("GRASS_VECTOR_TEMPORARY");
+        delete = TRUE;
+        if (env) {
+            if (G_strcasecmp(env, "move") == 0) {
+                /* copy temporary vector map to the current mapset */
+                char path_tmp[GPATH_MAX], path_map[GPATH_MAX];
+                G_debug(1, "V1_close_nat(): temporary map <%s> TO BE MOVED TO"
+                        " CURRENT MAPSET",
+                        Map->name);
+                Vect__get_element_path(path_tmp, Map, NULL);
+                G_file_name(path_map, GV_DIRECTORY, NULL, Map->mapset);
+                if (access(path_map, 0) != 0 && G_mkdir(path_map) != 0)
+                    G_fatal_error(_("Unable to create '%s': %s"),
+                                  path_map, strerror(errno));
+                G_file_name(path_map, GV_DIRECTORY, Map->name, Map->mapset);
+                G_debug(1, "V1_close_nat(): %s -> %s", path_tmp, path_map);
+                if (0 != G_recursive_copy(path_tmp, path_map))
+                    G_fatal_error(_("Unable to copy '%s': %s"), path_tmp, strerror(errno));
+#ifdef TEMPORARY_MAP_DB
+                int i, ndblinks;
+                struct field_info *fi;
+                dbConnection connection;
+                struct dblinks *dblinks;
+                G_debug(1, "V1_close_nat(): copying attributes");
+                /* copy also attributes */
+                dblinks = Vect_new_dblinks_struct();
+                db_get_connection(&connection);
+                ndblinks = Vect_get_num_dblinks(Map);
+                for (i = 0; i < ndblinks; i++) {
+                    fi = Vect_get_dblink(Map, i);
+                    if (DB_OK != db_copy_table(fi->driver, fi->database, fi->table,
+                                               connection.driverName,
+                                               connection.databaseName,
+                                               fi->table)) {
+                        G_warning(_("Unable to copy table <%s>"), fi->table);
+                        continue;
+                    Vect_add_dblink(dblinks, fi->number, fi->name,
+                                    fi->table, fi->key, connection.databaseName,
+                                    connection.driverName);
+                    G_free(fi);
+                G_free(Map->dblnk);
+                Map->dblnk = dblinks;
+                Map->temporary = FALSE;
+                Vect_write_dblinks(Map);
+                Map->temporary = TRUE;
+#endif
+            else if (G_strcasecmp(env, "delete") == 0) {
+                /* delete temporary vector map */
+                G_debug(1, "V1_close_nat(): temporary map <%s> TO BE DELETED", Map->name);
+            else {
+                /* do not delete temporary vector map */
+                G_debug(1, "V1_close_nat(): temporary map <%s> IS NOT DELETED",
+                        Map->name);
+                delete = FALSE;
-        else {
-            G_debug(1, "V1_close_nat(): temporary map <%s> IS NOT DELETED", Map->name);
+        if (delete) {
+            char path_tmp[GPATH_MAX];
+            /* delete vector directory */
+            G_recursive_remove(path_tmp);
+#ifndef TEMPORARY_MAP_DB
+            if (G_strcasecmp(env, "move") != 0) {
+                int i, ndblinks;
+                dbDriver *driver;
+                dbString table_name;
+                db_init_string(&table_name);
+                /* drop also attribute table */
+                    driver = db_start_driver_open_database(fi->driver, fi->database);
+                    if (driver == NULL) {
+                        G_warning(_("Unable to open database <%s> by driver <%s>"),
+                                  fi->database, fi->driver);
+                        continue;
+                    db_set_string(&table_name, fi->table);
+                    if (DB_OK != db_drop_table(driver, &table_name)) {
+                        G_warning(_("Unable to drop table <%s>"), fi->table);
+                        continue;
+#endif
Modified: grass/trunk/lib/vector/Vlib/close_pg.c
--- grass/trunk/lib/vector/Vlib/close_pg.c	2015-06-01 14:42:58 UTC (rev 65347)
+++ grass/trunk/lib/vector/Vlib/close_pg.c	2015-06-01 14:57:03 UTC (rev 65348)
@@ -127,8 +127,7 @@
         sprintf(buf, "%s/%s", GV_DIRECTORY, Map->name);
-        G_file_name(file_path, buf, GV_TOPO_ELEMENT, G_mapset());
+        Vect__get_element_path(file_path, Map, GV_TOPO_ELEMENT);
         if (access(file_path, F_OK) == 0) /* file exists? */
             unlink(file_path);
Modified: grass/trunk/lib/vector/Vlib/field.c
--- grass/trunk/lib/vector/Vlib/field.c	2015-06-01 14:42:58 UTC (rev 65347)
+++ grass/trunk/lib/vector/Vlib/field.c	2015-06-01 14:57:03 UTC (rev 65348)
@@ -385,9 +385,25 @@
 	fi->name = G_store(buf);
     fi->key = G_store(GV_KEY_COLUMN);	/* Should be: id/fid/gfid/... ? */
+    if (Map->temporary) {
+        Vect__get_element_path(buf, Map, NULL);
+        if (strcmp(DB_DEFAULT_DRIVER, "sqlite") == 0)
+            strcat(buf, "/sqlite.db");
+        else
+            strcat(buf, "/db.dbf");
+        fi->database = G_store(buf);
+        fi->driver = DB_DEFAULT_DRIVER;
+    else {
+        fi->database = G_store(connection.databaseName);
+        fi->driver = G_store(connection.driverName);
+#else
+#endif
     return fi;
@@ -560,7 +576,7 @@
     char file[1024], buf[2001];
     char tab[1024], col[1024], db[1024], drv[1024], fldstr[1024], *fldname;
     int fld;
-    char *c, *path;
+    char *c, path[GPATH_MAX];
     int row, rule;
     struct dblinks *dbl;
     char **tokens;
@@ -569,9 +585,8 @@
     dbl = Map->dblnk;
     /* Read dblink for native format */
     fd = G_fopen_old(path, GV_DBLN_ELEMENT, Map->mapset);
-    G_free(path);
     if (fd == NULL) {		/* This may be correct, no tables defined */
 	G_debug(1, "Cannot open vector database definition file");
 	return -1;
@@ -892,7 +907,7 @@
     int i;
     FILE *fd;
-    char *path, buf[1024];
+    char path[GPATH_MAX], buf[1024];
     if (Map->format != GV_FORMAT_NATIVE)
@@ -904,9 +919,8 @@
     dbl = Map->dblnk;
     fd = G_fopen_new(path, GV_DBLN_ELEMENT);
-    G_free(path);
 	G_warning(_("Unable to create database definition file for vector map <%s>"),
Modified: grass/trunk/lib/vector/Vlib/header.c
--- grass/trunk/lib/vector/Vlib/header.c	2015-06-01 14:42:58 UTC (rev 65347)
+++ grass/trunk/lib/vector/Vlib/header.c	2015-06-01 14:57:03 UTC (rev 65348)
@@ -77,12 +77,11 @@
 int Vect__write_head(const struct Map_info *Map)
-    char *path;
     FILE *head_fp;
     head_fp = G_fopen_new(path, GV_HEAD_ELEMENT);
-    G_free(path);
     if (head_fp == NULL) {
 	G_warning(_("Unable to create header file for vector map <%s>"),
 		  Vect_get_full_name(Map));
@@ -118,15 +117,14 @@
     FILE *head_fp;
     char buff[2000];
-    char *path, *ptr;
+    char path[GPATH_MAX], *ptr;
     /* Reset / init */
     Vect__init_head(Map);
     G_debug(1, "Vect__read_head(): vector = %s@%s", Map->name, Map->mapset);
     head_fp = G_fopen_old(path, GV_HEAD_ELEMENT, Map->mapset);
-    G_free(path);
 	G_warning(_("Unable to open header file of vector <%s>"),
Modified: grass/trunk/lib/vector/Vlib/local_proto.h
--- grass/trunk/lib/vector/Vlib/local_proto.h	2015-06-01 14:42:58 UTC (rev 65347)
+++ grass/trunk/lib/vector/Vlib/local_proto.h	2015-06-01 14:57:03 UTC (rev 65348)
@@ -7,6 +7,9 @@
 #define CACHE_FEATURE 0
 #define CACHE_MAP     1
+/*! Attributes of temporary maps */
+/* #define TEMPORARY_MAP_DB */
 /* Internal vector library subroutines which are not part of public
    API*/
@@ -27,8 +30,8 @@
 /* open.c */
 int Vect__open_old(struct Map_info *, const char *, const char *,
                    const char *, int, int, int);
-char *Vect__get_path(const struct Map_info *);
-char *Vect__get_element_path(const struct Map_info *, const char *);
+char *Vect__get_path(char *, const struct Map_info *);
+char *Vect__get_element_path(char *, const struct Map_info *, const char *);
 /* write_nat.c */
 int V2__add_line_to_topo_nat(struct Map_info *, off_t, int,
Modified: grass/trunk/lib/vector/Vlib/map.c
--- grass/trunk/lib/vector/Vlib/map.c	2015-06-01 14:42:58 UTC (rev 65347)
+++ grass/trunk/lib/vector/Vlib/map.c	2015-06-01 14:57:03 UTC (rev 65348)
@@ -22,6 +22,7 @@
 #include <sys/types.h>
 #include <fcntl.h>
+#include <errno.h>
@@ -347,9 +348,9 @@
 int Vect__delete(const char *map, int is_tmp)
     int ret;
-    char *path, path_buf[GPATH_MAX];
+    char path[GPATH_MAX], path_buf[GPATH_MAX];
-    const char *tmp, *mapset;
+    const char *tmp, *mapset, *env;
     struct Map_info Map;
@@ -384,7 +385,7 @@
-    path = Vect__get_element_path(&Map, GV_DBLN_ELEMENT);
+    Vect__get_element_path(path, &Map, GV_DBLN_ELEMENT);
     G_debug(1, "dbln file: %s", path);
@@ -439,10 +440,9 @@
-    G_free(path);
     /* Delete all files from vector/name directory */
-    path = Vect__get_element_path(&Map, NULL);
+    Vect__get_element_path(path, &Map, NULL);
     Vect_close(&Map);
     G_debug(3, "opendir '%s'", path);
     dir = opendir(path);
@@ -468,23 +468,30 @@
     closedir(dir);
-    /* NFS can create .nfsxxxxxxxx files for those deleted
-     *  -> we have to move the directory to ./tmp before it is deleted */
-    tmp = G_tempfile();
-    G_debug(3, "rename '%s' to '%s'", path, tmp);
-    ret = rename(path, tmp);
-    if (ret == -1) {
-        G_warning(_("Unable to rename directory '%s' to '%s'"), path, tmp);
-        return -1;
+	tmp = path;
-    G_free(path);
+    else {
+	/* NFS can create .nfsxxxxxxxx files for those deleted
+	 *  -> we have to move the directory to ./tmp before it is deleted */
+	tmp = G_tempfile();
+	G_debug(3, "rename '%s' to '%s'", path, tmp);
+	ret = rename(path, tmp);
+	if (ret == -1) {
+	    G_warning(_("Unable to rename directory '%s' to '%s'"), path, tmp);
+	    return -1;
     G_debug(3, "remove directory '%s'", tmp);
     /* Warning: remove() fails on Windows */
     ret = rmdir(tmp);
     if (ret == -1) {
-        G_warning(_("Unable to remove directory '%s'"), tmp);
+        G_warning(_("Unable to remove directory '%s': %s"),
+		  tmp, strerror(errno));
         return -1;
Modified: grass/trunk/lib/vector/Vlib/open.c
--- grass/trunk/lib/vector/Vlib/open.c	2015-06-01 14:42:58 UTC (rev 65347)
+++ grass/trunk/lib/vector/Vlib/open.c	2015-06-01 14:57:03 UTC (rev 65348)
@@ -163,7 +163,7 @@
                    const char *layer, int update, int head_only, int is_tmp)
-    char *path;
     FILE *fp;
     int level, level_request;
     int format, ret;
@@ -174,7 +174,7 @@
             "head_only = %d, is_tmp = %d", name, mapset, layer ? layer : "NULL", update, head_only,
             is_tmp);
-    if (!is_tmp) {
+    if (update && !is_tmp) {
         is_tmp = getenv("GRASS_VECTOR_TEMPORARY") ? TRUE : FALSE;
         G_debug(1, "Vect__open_old(): is_tmp = %d (check GRASS_VECTOR_TEMPORARY)", is_tmp);
@@ -221,7 +221,7 @@
             Map->mapset = G_store("");
     if (!ogr_mapset) {
         /* try to find vector map (not for OGR mapset) */
@@ -253,7 +253,8 @@
                     return -1;
-            G_file_name(file_path, path, GV_HEAD_ELEMENT, Map->mapset);
+            Vect__get_element_path(file_path, Map, GV_HEAD_ELEMENT);
                 return -1;
@@ -521,26 +522,24 @@
     if (update && !head_only) {
-        G_file_name(file_path, path, GV_TOPO_ELEMENT, G_mapset());
         if (access(file_path, F_OK) == 0)       /* topo file exists? */
             unlink(file_path);
-        G_file_name(file_path, path, GV_SIDX_ELEMENT, G_mapset());
         if (access(file_path, F_OK) == 0)       /* sidx file exists? */
             unlink(file_path);
-        G_file_name(file_path, path, GV_CIDX_ELEMENT, G_mapset());
         if (access(file_path, F_OK) == 0)       /* cidx file exists? */
             unlink(file_path);
         if (format == GV_FORMAT_OGR || format == GV_FORMAT_POSTGIS) {
-            G_file_name(file_path, path, GV_FIDX_ELEMENT, G_mapset());
+            Vect__get_element_path(file_path, Map, GV_FIDX_ELEMENT);
             if (access(file_path, F_OK) == 0)   /* fidx file exists? */
                 unlink(file_path);
-    G_free(path);
     return level;
@@ -791,7 +790,8 @@
     if (Map->format != GV_FORMAT_OGR_DIRECT &&
         getenv("GRASS_VECTOR_PGFILE") == NULL) { /* GRASS_VECTOR_PGFILE defined by v.out.postgis */
-        char *path;
+        char *env;
         G_debug(2, " using non-direct format");
@@ -804,7 +804,9 @@
                 return -1;
-        else {
+        env = getenv("GRASS_VECTOR_TEMPORARY");
+        if (!Map->temporary || (env && strcmp(env, "move") == 0)) {
             if (G_find_vector2(name, G_mapset()) != NULL) {
                 G_warning(_("Vector map <%s> already exists and will be overwritten"),
                           name);
@@ -828,9 +830,8 @@
         Vect__write_head(Map);
         /* create history file */
         Map->hist_fp = G_fopen_new(path, GV_HIST_ELEMENT);
-        G_free(path);
         if (Map->hist_fp == NULL) {
             G_warning(_("Unable to open history file of vector map <%s>"),
                       name);
@@ -963,14 +964,12 @@
 int Vect_coor_info(const struct Map_info *Map, struct Coor_info *Info)
-    char *path, file_path[GPATH_MAX];
     struct stat stat_buf;
     switch (Map->format) {
     case GV_FORMAT_NATIVE:
-        G_file_name(file_path, path, GV_COOR_ELEMENT, Map->mapset);
-        G_free(path);
+        Vect__get_element_path(file_path, Map, GV_COOR_ELEMENT);
         G_debug(1, "get coor info: %s", file_path);
         if (0 != stat(file_path, &stat_buf)) {
             G_warning(_("Unable to stat file <%s>"), file_path);
@@ -1087,7 +1086,7 @@
 int Vect_open_topo(struct Map_info *Map, int head_only)
     int err, ret;
     struct gvfile fp;
     struct Coor_info CInfo;
@@ -1097,17 +1096,14 @@
-    G_file_name(file_path, path, GV_TOPO_ELEMENT, Map->mapset);
-        G_free(path);
         return 1;
     dig_file_init(&fp);
     fp.file = G_fopen_old(path, GV_TOPO_ELEMENT, Map->mapset);
-    G_free(path);
     if (fp.file == NULL) {      /* topo file is not available */
         G_debug(1, "Cannot open topo file for vector '%s@%s'.",
@@ -1186,16 +1182,14 @@
     dig_file_init(&(Plus->spidx_fp));
     if (mode < 2) {
+        char path[GPATH_MAX], file_path[GPATH_MAX];
-        G_file_name(file_path, path, GV_SIDX_ELEMENT, Map->mapset);
         if (access(file_path, F_OK) != 0)       /* does not exist */
             return 1;
         Plus->spidx_fp.file = G_fopen_old(path, GV_SIDX_ELEMENT, Map->mapset);
-        G_free(path);
         if (Plus->spidx_fp.file == NULL) {  /* sidx file is not available */
             G_debug(1, "Cannot open spatial index file for vector '%s@%s'.",
@@ -1435,16 +1429,13 @@
   \brief Get map directory name (internal use only)
-  Allocate string should be freed by G_free().
+  \param file_path path string buffer
   \param Map pointer to Map_info struct
-  \return allocated buffer containing path
+  \return buffer containing path
-char *Vect__get_path(const struct Map_info *Map)
+char *Vect__get_path(char *path, const struct Map_info *Map)
-    char path[GPATH_MAX];
         G_temp_element(path_tmp);
@@ -1454,7 +1445,7 @@
         sprintf(path, "%s/%s", GV_DIRECTORY, Map->name);
-    return G_store(path);
+    return path;
@@ -1467,13 +1458,17 @@
-char *Vect__get_element_path(const struct Map_info *Map, const char *element)
+char *Vect__get_element_path(char *file_path,
+                             const struct Map_info *Map, const char *element)
-    G_file_name(file_path, path, element, Map->mapset);
-    G_free(path);
+        G_file_name_tmp(file_path, path, element, Map->mapset);
+    else
+        G_file_name(file_path, path, element, Map->mapset);
-    return G_store(file_path);
+    return file_path;
Modified: grass/trunk/lib/vector/Vlib/open_nat.c
--- grass/trunk/lib/vector/Vlib/open_nat.c	2015-06-01 14:42:58 UTC (rev 65347)
+++ grass/trunk/lib/vector/Vlib/open_nat.c	2015-06-01 14:57:03 UTC (rev 65348)
@@ -38,20 +38,19 @@
 int V1_open_old_nat(struct Map_info *Map, int update)
-    char *path;
     G_debug(1, "V1_open_old_nat(): name = %s mapset = %s", Map->name,
 	    Map->mapset);
     dig_file_init(&(Map->dig_fp));
     if (update)
 	Map->dig_fp.file = G_fopen_modify(path, GV_COOR_ELEMENT);
     else
 	Map->dig_fp.file =
 	    G_fopen_old(path, GV_COOR_ELEMENT, Map->mapset);
-    G_free(path);
     if (Map->dig_fp.file == NULL) {
         G_warning(_("Unable to open coor file for vector map <%s>"),
@@ -95,19 +94,19 @@
 int V1_open_new_nat(struct Map_info *Map, const char *name, int with_z)
     G_debug(1, "V1_open_new_nat(): name = %s with_z = %d is_tmp = %d",
             name, with_z, Map->temporary);
     /* Set the 'coor' file version */
     Map->head.coor_version.major = GV_COOR_VER_MAJOR;
     Map->head.coor_version.minor = GV_COOR_VER_MINOR;
     Map->head.coor_version.back_major = GV_COOR_EARLIEST_MAJOR;
     Map->head.coor_version.back_minor = GV_COOR_EARLIEST_MINOR;
     /* TODO: open better */
     Map->dig_fp.file = G_fopen_new(path, GV_COOR_ELEMENT);
@@ -119,14 +118,13 @@
 	return -1;
     /* if overwrite OK, any existing files have already been deleted by
      * Vect_open_new(): remove this check ? */
     /* check to see if dig_plus file exists and if so, remove it */
-    G_free(path);
-    if (access(file_path, F_OK) == 0)
-        unlink(file_path); /* remove topo file if exists */
+    Vect__get_element_path(path, Map, GV_TOPO_ELEMENT);
+    if (access(path, F_OK) == 0)
+        unlink(path); /* remove topo file if exists */
     /* set conversion matrices */
     dig_init_portable(&(Map->head.port), dig__byte_order_out());
