[GRASS-SVN] r65353 - grass-addons/grass7/gui/wxpython/wx.mwprecip
svn_grass at osgeo.org
Tue Jun 2 13:58:13 PDT 2015
Author: krejcmat
Date: 2015-06-02 13:58:13 -0700 (Tue, 02 Jun 2015)
New Revision: 65353
grass-addons/grass7/gui/wxpython/wx.mwprecip/g.gui.mwprecip.py
multithreading, color widget
Modified: grass-addons/grass7/gui/wxpython/wx.mwprecip/g.gui.mwprecip.py
--- grass-addons/grass7/gui/wxpython/wx.mwprecip/g.gui.mwprecip.py 2015-06-02 12:23:59 UTC (rev 65352)
+++ grass-addons/grass7/gui/wxpython/wx.mwprecip/g.gui.mwprecip.py 2015-06-02 20:58:13 UTC (rev 65353)
@@ -10,8 +10,11 @@
from core.gcmd import GMessage, GError
from gui_core import gselect
+from core.gthread import gThread
+from gui_core.widgets import ColorTablesComboBox,PictureComboBox
+from core import globalvar
import time
+from core.utils import GetColorTables
class DBconn(wx.ScrolledWindow):
def __init__(self, parent, settings={}):
@@ -425,7 +428,9 @@
wx.Panel.__init__(self, parent=parent, id=wx.ID_ANY)
self.settings = settings
self.colorRules = TextInput(self, label='Color table')
- self.colorsName = BaseInput(self, label='Name of color table')
+ self.colorsName =ColorTablesComboBox(parent=self,
+ size=globalvar.DIALOG_COMBOBOX_SIZE,
+ choices=GetColorTables())
self.layout()
def loadSettings(self, sett=None):
@@ -595,7 +600,7 @@
self.computeBtt = wx.Button(self.mainPanel, label='Compute')
self.computeBtt.Disable()
self.exportDataBtt = wx.Button(self.mainPanel, label='Export data')
- self.computeBtt.Bind(wx.EVT_BUTTON, self.runCompute)
+ self.computeBtt.Bind(wx.EVT_BUTTON, self.startProcess)
self.exportDataBtt.Bind(wx.EVT_BUTTON, self.exportData)
self.findProject()
@@ -826,11 +831,9 @@
path = OnSaveAs(self)
self.OnSaveSettings(toFile=False)
if not self.exportDMgr.chkprecip.GetValue():
- attrTmp1 = []
- attrTmp1.append('link.linkid')
+ attrTmp1 = ['link.linkid']
attrTmp2 = []
attrTmp3 = []
- # attrTmp2.append('public.linkid')
if self.exportDMgr.chkfreq.GetValue():
attrTmp1.append('link.frequency')
if self.exportDMgr.chkpol.GetValue():
@@ -906,7 +909,6 @@
lines += str(r)[1:][:-1] + '\n'
print conn.pathworkSchemaDir
- #path=os.path.join(conn.pathworkSchemaDir, "export")
io0 = open(path, "w+")
io0.writelines(lines)
io0.close()
@@ -915,7 +917,13 @@
self.exportDialog.Destroy()
- def runCompute(self, evt):
+ def startProcess(self,evt=None):
+ self.thread=gThread()
+ self.thread.Run(callable=self.runCom,
+ ondone=self.onFinish)
+ def runComp(self, evt=None):
+ self.computeBtt.Disable()
exportData = {'getData': False, 'dataOnly': False}
self.settings['dataExport'] = exportData
@@ -925,9 +933,9 @@
else:
self.settings['IDtype'] = 'linkid'
self.worker = Gui2Model(self, self.settings,self.workPath)
if self.worker.checkConn():
if not self.worker.initConnection():
return
self.worker.initVectorGrass()
@@ -940,8 +948,12 @@
self.worker.initBaseline()
self.worker.Run()
+ def onFinish(self,evt):
+ #self.computeBtt.SetLabel('Compute')
+ self.computeBtt.Enable()
+ GMessage('Finish')
def layout(self):
self.panelSizer.Add(self.loadScheme, flag=wx.EXPAND)
self.panelSizer.Add(self.profilSelection, flag=wx.EXPAND)
self.panelSizer.Add(self.schema, flag=wx.EXPAND)
@@ -962,7 +974,6 @@
def onQuit(self, e):
self.Close()
class Gui2Model():
def __init__(self, wxParent, settings,path):
@@ -971,7 +982,6 @@
self.conninfo=None
self.workPath=path
def checkConn(self):
try:
self.conninfo = {'name': self.settings['database']}
@@ -1013,7 +1023,6 @@
return self.dbConn
def initVectorGrass(self, type=None, name=None):
convertor = VectorLoader(self.dbConn)
if name is not None:
@@ -1117,7 +1126,8 @@
if state:
self.initGrassLayerMgr()
self.initTemporalMgr()
- GMessage(msg)
+ return
+ #GMessage(msg)
#self.initgrassManagement()
