[GRASS-SVN] r65359 - in grass-addons/grass7/raster: . r.sample.category
svn_grass at osgeo.org
Wed Jun 3 19:54:07 PDT 2015
Author: wenzeslaus
Date: 2015-06-03 19:54:07 -0700 (Wed, 03 Jun 2015)
New Revision: 65359
grass-addons/grass7/raster/Makefile
grass-addons/grass7/raster/r.sample.category/r.sample.category.html
grass-addons/grass7/raster/r.sample.category/r.sample.category.py
r.sample.category: fix bug when Mapset was specified, add example with actual sampling, add to main Makefile
Modified: grass-addons/grass7/raster/Makefile
--- grass-addons/grass7/raster/Makefile 2015-06-04 01:14:52 UTC (rev 65358)
+++ grass-addons/grass7/raster/Makefile 2015-06-04 02:54:07 UTC (rev 65359)
@@ -68,6 +68,7 @@
r.regression.series \
r.rock.stability \
r.roughness.vector \
+ r.sample.category \
r.segment \
r.shaded.pca \
r.shalstab \
Modified: grass-addons/grass7/raster/r.sample.category/r.sample.category.html
--- grass-addons/grass7/raster/r.sample.category/r.sample.category.html 2015-06-04 01:14:52 UTC (rev 65358)
+++ grass-addons/grass7/raster/r.sample.category/r.sample.category.html 2015-06-04 02:54:07 UTC (rev 65359)
@@ -14,10 +14,13 @@
<h2>EXAMPLE</h2>
+<h3>Generate random points</h3>
Generate three points at random location for each category (class)
in the raster map:
<div class="code"><pre>
+g.region raster=landclass96
r.sample.category input=landclass96 output=landclass_points npoints=3
</pre></div>
@@ -46,6 +49,43 @@
Figure: Three random points in each category of landclass raster map
</center>
+<h3>Create a table with values sampled from rasters</h3>
+Create 2 random points per each category (class) in landclass96 raster
+and sample elevation and geology_30m rasters at these points:
+<div class="code"><pre>
+r.sample.category input=landclass96 output=landclass_points sampled=elevation,geology_30m npoints=2
+</pre></div>
+Look at the created data:
+v.db.select landclass_points sep=comma
+</pre></div>
+The result of <em><a href="v.db.select.html">v.db.select</a></em>
+is CSV table which can be used, for example in a spreadsheet application:
+cat,landclass96,elevation,geology_30m
+1,1,102.7855,270
+2,1,105.78,270
+3,2,114.5954,217
+4,2,137.4816,921
+5,3,71.19167,270
+6,3,93.33904,270
+7,4,76.41077,262
+8,4,97.54424,217
+9,5,138.455,405
+10,5,88.8075,270
+11,6,126.5298,217
+12,6,86.73177,217
+13,7,134.5381,217
+14,7,99.6844,270
+</pre></div>
<h2>KNOWN ISSUES</h2>
The module does not respect mask. More precisely it does not allow mask
Modified: grass-addons/grass7/raster/r.sample.category/r.sample.category.py
--- grass-addons/grass7/raster/r.sample.category/r.sample.category.py 2015-06-04 01:14:52 UTC (rev 65358)
+++ grass-addons/grass7/raster/r.sample.category/r.sample.category.py 2015-06-04 02:54:07 UTC (rev 65359)
@@ -70,10 +70,26 @@
def escape_sql_column(name):
+ """Escape string to create a safe name of column for SQL
+ >>> escape_sql_column("elevation.10m")
+ elevation_10m
name = name.replace('.', '_')
return name
+def strip_mapset(name):
+ """Strip Mapset name and '@' from map name
+ >>> strip_mapset('elevation at PERMANENT')
+ elevation
+ if '@' in name:
+ return name.split('@')[0]
+ return name
def main():
options, flags = gscript.parser()
@@ -125,8 +141,8 @@
columns = []
column_names = []
sampled_rasters.insert(0, input_raster)
- for predictor in sampled_rasters:
- column = escape_sql_column(predictor.lower())
+ for raster in sampled_rasters:
+ column = escape_sql_column(strip_mapset(raster).lower())
column_names.append(column)
# TODO: column type according to map type
columns.append("{column} double precision".format(column=column))
