[GRASS-SVN] r65362 - grass/trunk/gui/wxpython/location_wizard
svn_grass at osgeo.org
Thu Jun 4 08:28:50 PDT 2015
Author: martinl
Date: 2015-06-04 08:28:50 -0700 (Thu, 04 Jun 2015)
New Revision: 65362
grass/trunk/gui/wxpython/location_wizard/wizard.py
wxGUI/location wizard: reorder options (EPSG by default)
rename variables
focus location name widget
Modified: grass/trunk/gui/wxpython/location_wizard/wizard.py
--- grass/trunk/gui/wxpython/location_wizard/wizard.py 2015-06-04 13:26:50 UTC (rev 65361)
+++ grass/trunk/gui/wxpython/location_wizard/wizard.py 2015-06-04 15:28:50 UTC (rev 65362)
@@ -107,6 +107,7 @@
# text controls
self.tgisdbase = self.MakeTextCtrl(grassdatabase, size = (300, -1))
self.tlocation = self.MakeTextCtrl("newLocation", size = (300, -1))
+ self.tlocation.SetFocus()
self.tlocation.SetValidator(GenericValidator(grass.legal_name, self._nameValidationFailed))
self.tlocTitle = self.MakeTextCtrl(size = (400, -1))
@@ -219,67 +220,67 @@
global coordsys
# toggles
- self.radio1 = wx.RadioButton(parent = self, id = wx.ID_ANY,
- label = _("Select coordinate system parameters from a list"),
- style = wx.RB_GROUP)
- self.radio2 = wx.RadioButton(parent = self, id = wx.ID_ANY,
- label = _("Select EPSG code of spatial reference system"))
- self.radio3 = wx.RadioButton(parent = self, id = wx.ID_ANY,
- label = _("Read projection and datum terms from a "
- "georeferenced data file"))
- self.radio4 = wx.RadioButton(parent = self, id = wx.ID_ANY,
- "Well Known Text (WKT) .prj file"))
- self.radio5 = wx.RadioButton(parent = self, id = wx.ID_ANY,
- label = _("Specify projection and datum terms using custom "
- "PROJ.4 parameters"))
- self.radio6 = wx.RadioButton(parent = self, id = wx.ID_ANY,
- label = _("Create a generic Cartesian coordinate system (XY)"))
+ self.radioEpsg = wx.RadioButton(parent = self, id = wx.ID_ANY,
+ label = _("Select EPSG code of spatial reference system"),
+ style = wx.RB_GROUP)
+ self.radioFile = wx.RadioButton(parent = self, id = wx.ID_ANY,
+ label = _("Read projection and datum terms from a "
+ "georeferenced data file"))
+ self.radioWkt = wx.RadioButton(parent = self, id = wx.ID_ANY,
+ "Well Known Text (WKT) .prj file"))
+ self.radioSrs = wx.RadioButton(parent = self, id = wx.ID_ANY,
+ label = _("Select coordinate system parameters from a list"))
+ self.radioProj = wx.RadioButton(parent = self, id = wx.ID_ANY,
+ label = _("Specify projection and datum terms using custom "
+ "PROJ.4 parameters"))
+ self.radioXy = wx.RadioButton(parent = self, id = wx.ID_ANY,
+ label = _("Create a generic Cartesian coordinate system (XY)"))
# layout
self.sizer.SetVGap(10)
- self.sizer.Add(item = self.radio1,
+ self.sizer.Add(item = self.radioEpsg,
flag = wx.ALIGN_LEFT, pos = (1, 1))
- self.sizer.Add(item = self.radio2,
+ self.sizer.Add(item = self.radioFile,
flag = wx.ALIGN_LEFT, pos = (2, 1))
- self.sizer.Add(item = self.radio3,
+ self.sizer.Add(item = self.radioWkt,
flag = wx.ALIGN_LEFT, pos = (3, 1))
- self.sizer.Add(item = self.radio4,
+ self.sizer.Add(item = self.radioSrs,
flag = wx.ALIGN_LEFT, pos = (4, 1))
- self.sizer.Add(item = self.radio5,
+ self.sizer.Add(item = self.radioProj,
flag = wx.ALIGN_LEFT, pos = (5, 1))
- self.sizer.Add(item = self.radio6,
+ self.sizer.Add(item = self.radioXy,
flag = wx.ALIGN_LEFT, pos = (6, 1))
self.sizer.AddGrowableCol(1)
# bindings
- self.Bind(wx.EVT_RADIOBUTTON, self.SetVal, id = self.radio1.GetId())
- self.Bind(wx.EVT_RADIOBUTTON, self.SetVal, id = self.radio2.GetId())
- self.Bind(wx.EVT_RADIOBUTTON, self.SetVal, id = self.radio3.GetId())
- self.Bind(wx.EVT_RADIOBUTTON, self.SetVal, id = self.radio4.GetId())
- self.Bind(wx.EVT_RADIOBUTTON, self.SetVal, id = self.radio5.GetId())
- self.Bind(wx.EVT_RADIOBUTTON, self.SetVal, id = self.radio6.GetId())
+ self.Bind(wx.EVT_RADIOBUTTON, self.SetVal, id = self.radioEpsg.GetId())
+ self.Bind(wx.EVT_RADIOBUTTON, self.SetVal, id = self.radioFile.GetId())
+ self.Bind(wx.EVT_RADIOBUTTON, self.SetVal, id = self.radioWkt.GetId())
+ self.Bind(wx.EVT_RADIOBUTTON, self.SetVal, id = self.radioSrs.GetId())
+ self.Bind(wx.EVT_RADIOBUTTON, self.SetVal, id = self.radioProj.GetId())
+ self.Bind(wx.EVT_RADIOBUTTON, self.SetVal, id = self.radioXy.GetId())
self.Bind(wiz.EVT_WIZARD_PAGE_CHANGED, self.OnEnterPage)
def OnEnterPage(self, event):
global coordsys
if not coordsys:
- coordsys = "proj"
- self.radio1.SetValue(True)
+ coordsys = "epsg"
+ self.radioEpsg.SetValue(True)
else:
if coordsys == 'proj':
+ self.radioSrs.SetValue(True)
if coordsys == "epsg":
- self.radio2.SetValue(True)
if coordsys == "file":
- self.radio3.SetValue(True)
+ self.radioFile.SetValue(True)
if coordsys == "wkt":
- self.radio4.SetValue(True)
+ self.radioWkt.SetValue(True)
if coordsys == "custom":
- self.radio5.SetValue(True)
+ self.radioProj.SetValue(True)
if coordsys == "xy":
- self.radio6.SetValue(True)
+ self.radioXy.SetValue(True)
if event.GetDirection():
@@ -307,27 +308,27 @@
def SetVal(self, event):
"""Choose method"""
global coordsys
- if event.GetId() == self.radio1.GetId():
+ if event.GetId() == self.radioSrs.GetId():
coordsys = "proj"
self.SetNext(self.parent.projpage)
self.parent.sumpage.SetPrev(self.parent.datumpage)
- elif event.GetId() == self.radio2.GetId():
+ elif event.GetId() == self.radioEpsg.GetId():
coordsys = "epsg"
self.SetNext(self.parent.epsgpage)
self.parent.sumpage.SetPrev(self.parent.epsgpage)
- elif event.GetId() == self.radio3.GetId():
+ elif event.GetId() == self.radioFile.GetId():
coordsys = "file"
self.SetNext(self.parent.filepage)
self.parent.sumpage.SetPrev(self.parent.filepage)
- elif event.GetId() == self.radio4.GetId():
+ elif event.GetId() == self.radioWkt.GetId():
coordsys = "wkt"
self.SetNext(self.parent.wktpage)
self.parent.sumpage.SetPrev(self.parent.wktpage)
- elif event.GetId() == self.radio5.GetId():
+ elif event.GetId() == self.radioProj.GetId():
coordsys = "custom"
self.SetNext(self.parent.custompage)
self.parent.sumpage.SetPrev(self.parent.custompage)
- elif event.GetId() == self.radio6.GetId():
+ elif event.GetId() == self.radioXy.GetId():
coordsys = "xy"
self.SetNext(self.parent.sumpage)
self.parent.sumpage.SetPrev(self.parent.csystemspage)
@@ -664,23 +665,23 @@
label = _("Datum with associated ellipsoid"),
label = _("Ellipsoid only"))
# default button setting
- if self.radio1.GetValue() == False and self.radio2.GetValue() == False:
+ if self.radio1.GetValue() == False and self.radioEpsg.GetValue() == False:
self.SetNext(self.parent.datumpage)
# self.parent.sumpage.SetPrev(self.parent.datumpage)
radioSBSizer.Add(item = self.radio1,
flag = wx.ALIGN_LEFT | wx.RIGHT, border = 20)
- radioSBSizer.Add(item = self.radio2,
+ radioSBSizer.Add(item = self.radioEpsg,
flag = wx.ALIGN_LEFT)
# bindings
self.Bind(wiz.EVT_WIZARD_PAGE_CHANGING, self.OnPageChange)
@@ -820,7 +821,7 @@
self.SetNext(self.parent.ellipsepage)
self.parent.sumpage.SetPrev(self.parent.ellipsepage)
@@ -1014,7 +1015,7 @@
label = _("Earth based"),
label = _("Planetary bodies"))
# create list control for ellipse list
@@ -1049,7 +1050,7 @@
wx.ALIGN_CENTER_VERTICAL |
wx.ALL, border = 5, pos = (2, 2))
flag = wx.ALIGN_LEFT | wx.ALIGN_CENTER_VERTICAL | wx.LEFT,
border = 25, pos = (2, 3))
@@ -1067,7 +1068,7 @@
self.searchb.Bind(wx.EVT_TEXT_ENTER, self.OnSearch)
self.radio1.Bind(wx.EVT_RADIOBUTTON, self.SetVal, id = self.radio1.GetId())
- self.radio2.Bind(wx.EVT_RADIOBUTTON, self.SetVal, id = self.radio2.GetId())
+ self.radioEpsg.Bind(wx.EVT_RADIOBUTTON, self.SetVal, id = self.radioEpsg.GetId())
self.Bind(wiz.EVT_WIZARD_PAGE_CHANGING, self.OnPageChanging)
@@ -1148,7 +1149,7 @@
self.scope = 'earth'
for key in self.parent.ellipsoids.keys():
data.append([key, self.parent.ellipsoids[key][0]])
+ elif event.GetId() == self.radioEpsgx.GetId():
self.scope = 'planetary'
for key in self.parent.planetary_ellipsoids.keys():
data.append([key, self.parent.planetary_ellipsoids[key][0]])
