[GRASS-SVN] r65370 - grass/branches/releasebranch_7_0/lib/python/pygrass/modules/interface
svn_grass at osgeo.org
Thu Jun 4 22:24:38 PDT 2015
Author: zarch
Date: 2015-06-04 22:24:38 -0700 (Thu, 04 Jun 2015)
New Revision: 65370
Added:
grass/branches/releasebranch_7_0/lib/python/pygrass/modules/interface/docstring.py
grass/branches/releasebranch_7_0/lib/python/pygrass/modules/interface/Makefile
grass/branches/releasebranch_7_0/lib/python/pygrass/modules/interface/flag.py
grass/branches/releasebranch_7_0/lib/python/pygrass/modules/interface/module.py
grass/branches/releasebranch_7_0/lib/python/pygrass/modules/interface/parameter.py
grass/branches/releasebranch_7_0/lib/python/pygrass/modules/interface/typedict.py
pygrass: backport 65190, Remove import from utils, because utils require ctypes
Modified: grass/branches/releasebranch_7_0/lib/python/pygrass/modules/interface/Makefile
--- grass/branches/releasebranch_7_0/lib/python/pygrass/modules/interface/Makefile 2015-06-05 05:20:34 UTC (rev 65369)
+++ grass/branches/releasebranch_7_0/lib/python/pygrass/modules/interface/Makefile 2015-06-05 05:24:38 UTC (rev 65370)
@@ -9,7 +9,7 @@
PGDIR = $(GDIR)/pygrass
DSTDIR= $(PGDIR)/modules/interface
-MODULES = read typedict flag parameter module
+MODULES = docstring read typedict flag parameter module
PYFILES := $(patsubst %,$(DSTDIR)/%.py,$(MODULES) __init__)
PYCFILES := $(patsubst %,$(DSTDIR)/%.pyc,$(MODULES) __init__)
@@ -29,4 +29,4 @@
$(INSTALL_DATA) $< $@
#doxygen:
-DOXNAME = pythonpygrass
\ No newline at end of file
+DOXNAME = pythonpygrass
Copied: grass/branches/releasebranch_7_0/lib/python/pygrass/modules/interface/docstring.py (from rev 65190, grass/trunk/lib/python/pygrass/modules/interface/docstring.py)
--- grass/branches/releasebranch_7_0/lib/python/pygrass/modules/interface/docstring.py (rev 0)
+++ grass/branches/releasebranch_7_0/lib/python/pygrass/modules/interface/docstring.py 2015-06-05 05:24:38 UTC (rev 65370)
@@ -0,0 +1,55 @@
+# -*- coding: utf-8 -*-
+def docstring_property(class_doc):
+ """Property attribute for docstrings.
+ Took from: https://gist.github.com/bfroehle/4041015
+ >>> class A(object):
+ ... '''Main docstring'''
+ ... def __init__(self, x):
+ ... self.x = x
+ ... @docstring_property(__doc__)
+ ... def __doc__(self):
+ ... return "My value of x is %s." % self.x
+ >>> A.__doc__
+ 'Main docstring'
+ >>> a = A(10)
+ >>> a.__doc__
+ 'My value of x is 10.'
+ def wrapper(fget):
+ return DocstringProperty(class_doc, fget)
+ return wrapper
+class DocstringProperty(object):
+ """Property for the `__doc__` attribute.
+ Different than `property` in the following two ways:
+ * When the attribute is accessed from the main class, it returns the value
+ of `class_doc`, *not* the property itself. This is necessary so Sphinx
+ and other documentation tools can access the class docstring.
+ * Only supports getting the attribute; setting and deleting raise an
+ `AttributeError`.
+ def __init__(self, class_doc, fget):
+ self.class_doc = class_doc
+ self.fget = fget
+ def __get__(self, obj, type=None):
+ if obj is None:
+ return self.class_doc
+ else:
+ return self.fget(obj)
+ def __set__(self, obj, value):
+ raise AttributeError("can't set attribute")
+ def __delete__(self, obj):
+ raise AttributeError("can't delete attribute")
Modified: grass/branches/releasebranch_7_0/lib/python/pygrass/modules/interface/flag.py
--- grass/branches/releasebranch_7_0/lib/python/pygrass/modules/interface/flag.py 2015-06-05 05:20:34 UTC (rev 65369)
+++ grass/branches/releasebranch_7_0/lib/python/pygrass/modules/interface/flag.py 2015-06-05 05:24:38 UTC (rev 65370)
@@ -1,7 +1,7 @@
from __future__ import (nested_scopes, generators, division, absolute_import,
with_statement, print_function, unicode_literals)
-from grass.pygrass.utils import docstring_property
+from grass.pygrass.modules.interface.docstring import docstring_property
from grass.pygrass.modules.interface import read
Modified: grass/branches/releasebranch_7_0/lib/python/pygrass/modules/interface/module.py
--- grass/branches/releasebranch_7_0/lib/python/pygrass/modules/interface/module.py 2015-06-05 05:20:34 UTC (rev 65369)
+++ grass/branches/releasebranch_7_0/lib/python/pygrass/modules/interface/module.py 2015-06-05 05:24:38 UTC (rev 65370)
@@ -15,7 +15,7 @@
from grass.exceptions import CalledModuleError
from grass.script.core import Popen, PIPE
from grass.pygrass.errors import GrassError, ParameterError
from grass.pygrass.modules.interface.parameter import Parameter
from grass.pygrass.modules.interface.flag import Flag
from grass.pygrass.modules.interface.typedict import TypeDict
Modified: grass/branches/releasebranch_7_0/lib/python/pygrass/modules/interface/parameter.py
--- grass/branches/releasebranch_7_0/lib/python/pygrass/modules/interface/parameter.py 2015-06-05 05:20:34 UTC (rev 65369)
+++ grass/branches/releasebranch_7_0/lib/python/pygrass/modules/interface/parameter.py 2015-06-05 05:24:38 UTC (rev 65370)
@@ -8,7 +8,7 @@
import re
from grass.pygrass.modules.interface.read import GETTYPE, element2dict, DOC
Modified: grass/branches/releasebranch_7_0/lib/python/pygrass/modules/interface/typedict.py
--- grass/branches/releasebranch_7_0/lib/python/pygrass/modules/interface/typedict.py 2015-06-05 05:20:34 UTC (rev 65369)
+++ grass/branches/releasebranch_7_0/lib/python/pygrass/modules/interface/typedict.py 2015-06-05 05:24:38 UTC (rev 65370)
@@ -12,7 +12,7 @@
except ImportError:
from grass.pygrass.orderdict import OrderedDict
class TypeDict(OrderedDict):
