[GRASS-SVN] r65372 - grass/branches/releasebranch_7_0/lib/python/pygrass/modules/interface
svn_grass at osgeo.org
Thu Jun 4 22:29:32 PDT 2015
Author: zarch
Date: 2015-06-04 22:29:32 -0700 (Thu, 04 Jun 2015)
New Revision: 65372
grass/branches/releasebranch_7_0/lib/python/pygrass/modules/interface/module.py
pygrass: backport r65289, Remove unused code: mdebug decorator
Modified: grass/branches/releasebranch_7_0/lib/python/pygrass/modules/interface/module.py
--- grass/branches/releasebranch_7_0/lib/python/pygrass/modules/interface/module.py 2015-06-05 05:27:22 UTC (rev 65371)
+++ grass/branches/releasebranch_7_0/lib/python/pygrass/modules/interface/module.py 2015-06-05 05:29:32 UTC (rev 65372)
@@ -23,37 +23,6 @@
from grass.pygrass.messages import get_msgr
-def mdebug(level, msg='', extra=None):
- """Debug decorators for class methods.
- :param level: the debug level
- :type level: int
- :param msg: Debug message
- :type msg: str
- :param extra: Function that return a string
- :type msg: func
- msgr = get_msgr()
- def decorator(method):
- @wraps(method)
- def wrapper(self, *args, **kargs):
- sargs = ', ' + ' , '.join([repr(a) for a in args]) if args else ''
- skargs = (' , '.join(['%s=%r' % (k, v) for k, v in kargs.items()])
- if kargs else '')
- opts = "%s%s%s" % (sargs, ',' if sargs and skargs else '', skargs)
- dmsg = "%s.%s(self%s): %s %s" % (self.__class__.__name__,
- method.__name__,
- opts, msg,
- extra(self, *args, **kargs)
- if extra else '')
- msgr.debug(level, dmsg)
- return method(self, *args, **kargs)
- return wrapper
- return decorator
def _get_bash(self, *args, **kargs):
return self.get_bash()
@@ -697,7 +666,6 @@
args.append(str(self.flags[flg]))
return args
- # @mdebug(1, extra=_get_bash)
def run(self):
"""Run the module
