[GRASS-SVN] r65374 - grass/branches/releasebranch_7_0/lib/python/pygrass/modules/interface
Thu Jun 4 22:33:55 PDT 2015
Author: zarch
Date: 2015-06-04 22:33:55 -0700 (Thu, 04 Jun 2015)
New Revision: 65374
Added:
   grass/branches/releasebranch_7_0/lib/python/pygrass/modules/interface/env.py
   grass/branches/releasebranch_7_0/lib/python/pygrass/modules/interface/Makefile
   grass/branches/releasebranch_7_0/lib/python/pygrass/modules/interface/module.py
pygrass: backport r65336, rm get_msgr from modules to avoid the ctypes use
Modified: grass/branches/releasebranch_7_0/lib/python/pygrass/modules/interface/Makefile
--- grass/branches/releasebranch_7_0/lib/python/pygrass/modules/interface/Makefile	2015-06-05 05:31:15 UTC (rev 65373)
+++ grass/branches/releasebranch_7_0/lib/python/pygrass/modules/interface/Makefile	2015-06-05 05:33:55 UTC (rev 65374)
@@ -9,7 +9,7 @@
 PGDIR = $(GDIR)/pygrass
 DSTDIR= $(PGDIR)/modules/interface
-MODULES = docstring read typedict flag parameter module
+MODULES = docstring read typedict flag parameter module env
 PYFILES := $(patsubst %,$(DSTDIR)/%.py,$(MODULES) __init__)
 PYCFILES := $(patsubst %,$(DSTDIR)/%.pyc,$(MODULES) __init__)
Copied: grass/branches/releasebranch_7_0/lib/python/pygrass/modules/interface/env.py (from rev 65336, grass/trunk/lib/python/pygrass/modules/interface/env.py)
--- grass/branches/releasebranch_7_0/lib/python/pygrass/modules/interface/env.py	                        (rev 0)
+++ grass/branches/releasebranch_7_0/lib/python/pygrass/modules/interface/env.py	2015-06-05 05:33:55 UTC (rev 65374)
@@ -0,0 +1,36 @@
+# -*- coding: utf-8 -*-
+Created on Thu May 28 17:41:32 2015
+ at author: pietro
+from __future__ import print_function
+import os
+import sys
+def get_env():
+    """Parse the GISRC file and return the GRASS variales"""
+    gisrc = os.environ.get('GISRC')
+    if gisrc is None:
+        raise RuntimeError('You are not in a GRASS session, GISRC not found.')
+    with open(gisrc, mode='r') as grc:
+        env = {k.strip(): v.strip() for k, v in [row.split(':')
+                                                 for row in grc if row]}
+    return env
+def get_debug_level():
+    """Return the debug level"""
+    debug = get_env().get('DEBUG')
+    return int(debug) if debug else 0
+def G_debug(level, *msg):
+    """Print or write a debug message, this is a pure python implementation
+    of the G_debug function in the C API."""
+    debug_level = get_debug_level()
+    if debug_level >= level:
+        dfile = os.environ.get("GRASS_DEBUG_FILE")
+        fd = sys.stderr if dfile is None else open(dfile, mode='a')
+        print("D%d/%d: " % (level, debug_level), *msg, end='\n', file=fd)
Modified: grass/branches/releasebranch_7_0/lib/python/pygrass/modules/interface/module.py
--- grass/branches/releasebranch_7_0/lib/python/pygrass/modules/interface/module.py	2015-06-05 05:31:15 UTC (rev 65373)
+++ grass/branches/releasebranch_7_0/lib/python/pygrass/modules/interface/module.py	2015-06-05 05:33:55 UTC (rev 65374)
@@ -3,13 +3,8 @@
                         with_statement, print_function, unicode_literals)
 import sys
 from multiprocessing import cpu_count
-if sys.version_info[0] == 2:
-    from itertools import izip_longest as zip_longest
-else:
-    from itertools import zip_longest
+import time
 from xml.etree.ElementTree import fromstring
-import time
 from grass.exceptions import CalledModuleError, GrassError, ParameterError
 from grass.script.core import Popen, PIPE
@@ -18,9 +13,15 @@
 from .flag import Flag
 from .typedict import TypeDict
 from .read import GETFROMTAG, DOC
-from grass.pygrass.messages import get_msgr
+from .env import G_debug
+if sys.version_info[0] == 2:
+    from itertools import izip_longest as zip_longest
+else:
+    from itertools import zip_longest
 def _get_bash(self, *args, **kargs):
     return self.get_bash()
@@ -677,7 +678,7 @@
         termination. The handling of stdout and stderr must then be done
         outside of this function.
-        get_msgr().debug(1, self.get_bash())
+        G_debug(1, self.get_bash())
         if self.inputs['stdin'].value:
             self.stdin = self.inputs['stdin'].value
             self.stdin_ = PIPE
