[GRASS-SVN] r65381 - grass-addons/tools/wingrass-packager
Fri Jun 5 14:17:01 PDT 2015
Author: martinl
Date: 2015-06-05 14:17:01 -0700 (Fri, 05 Jun 2015)
New Revision: 65381
   grass-addons/tools/wingrass-packager/grass_addons.sh
   grass-addons/tools/wingrass-packager/grass_compile.sh
   grass-addons/tools/wingrass-packager/grass_copy_wwwroot.sh
   grass-addons/tools/wingrass-packager/grass_md5sum.sh
   grass-addons/tools/wingrass-packager/grass_osgeo4w.sh
   grass-addons/tools/wingrass-packager/grass_packager.bat
   grass-addons/tools/wingrass-packager/grass_svn_info.sh
wingrass: enable grass70_release daily builds
Modified: grass-addons/tools/wingrass-packager/grass_addons.sh
--- grass-addons/tools/wingrass-packager/grass_addons.sh	2015-06-05 18:14:04 UTC (rev 65380)
+++ grass-addons/tools/wingrass-packager/grass_addons.sh	2015-06-05 21:17:01 UTC (rev 65381)
@@ -28,6 +28,7 @@
 function compile {
     export PATH=$PATH:/c/OSGeo4W$4/apps/msys/bin:/c/OSGeo4W$4/bin:$2/dist.i686-pc-mingw32/bin:$2/dist.i686-pc-mingw32/scripts:/c/subversion/bin/svn
     export PYTHONHOME=/c/OSGeo4W$4/apps/Python27
     rm -rf $3
     $SVN_PATH/tools/addons/compile.sh $1 $2 $3 1
     cd $3
@@ -65,7 +66,7 @@
     compile $SVN_PATH/grass6 $GISBASE_PATH/grass644        $ADDON_PATH/grass644/addons
     ### compile $SVN_PATH/grass6 $GISBASE_PATH/grass64_release $ADDON_PATH/grass64/addons
     compile $SVN_PATH/grass7 $GISBASE_PATH/grass700        $ADDON_PATH/grass700/addons
-    ### compile $SVN_PATH/grass7 $GISBASE_PATH/grass70_release $ADDON_PATH/grass70/addons
+    ###compile $SVN_PATH/grass7 $GISBASE_PATH/grass70_release $ADDON_PATH/grass70/addons
     compile $SVN_PATH/grass7 $GISBASE_PATH/grass_trunk     $ADDON_PATH/grass71/addons
 else
     compile $SVN_PATH/grass6 $GISBASE_PATH/grass$1         $ADDON_PATH/grass$1/addons
Modified: grass-addons/tools/wingrass-packager/grass_compile.sh
--- grass-addons/tools/wingrass-packager/grass_compile.sh	2015-06-05 18:14:04 UTC (rev 65380)
+++ grass-addons/tools/wingrass-packager/grass_compile.sh	2015-06-05 21:17:01 UTC (rev 65381)
@@ -38,7 +38,7 @@
     # dev packages
     ### compile grass64_release 64-dev
     ### compile grass6_devel    65-dev
-    ### compile grass70_release -dev
+    compile grass70_release -dev
     compile grass_trunk     -daily
 else
     compile grass$1         $2
Modified: grass-addons/tools/wingrass-packager/grass_copy_wwwroot.sh
--- grass-addons/tools/wingrass-packager/grass_copy_wwwroot.sh	2015-06-05 18:14:04 UTC (rev 65380)
+++ grass-addons/tools/wingrass-packager/grass_copy_wwwroot.sh	2015-06-05 21:17:01 UTC (rev 65381)
@@ -43,13 +43,19 @@
     cp -r addons/logs                 $ADDONDIR
+function create_zip {
+    echo "Creating zip..."
+    cd $WWWDIR
+    zip wingrass.zip grass64 grass70 grass71 -r -q
 export PATH=$PATH:/c/OSGeo4W/apps/msys/bin
 if test -z $1 ; then
     # daily builds
     ### copy 64 6.4.5svn
     ### copy 65
-    ### copy 70 7.0.1svn
+    copy 70 7.0.1svn
     copy 71 7.1.svn
     # releases
     copy_addon 644      6.4.4
@@ -58,4 +64,6 @@
     copy $1 $2
 fi
+create_zip
 exit 0
Modified: grass-addons/tools/wingrass-packager/grass_md5sum.sh
--- grass-addons/tools/wingrass-packager/grass_md5sum.sh	2015-06-05 18:14:04 UTC (rev 65380)
+++ grass-addons/tools/wingrass-packager/grass_md5sum.sh	2015-06-05 21:17:01 UTC (rev 65381)
@@ -16,7 +16,7 @@
     # dev packages
     ### create_md5sum grass64
     ### create_md5sum grass65
-    ### create_md5sum grass70
+    create_md5sum grass70
     create_md5sum grass71
 else
     create_md5sum grass$1
Modified: grass-addons/tools/wingrass-packager/grass_osgeo4w.sh
--- grass-addons/tools/wingrass-packager/grass_osgeo4w.sh	2015-06-05 18:14:04 UTC (rev 65380)
+++ grass-addons/tools/wingrass-packager/grass_osgeo4w.sh	2015-06-05 21:17:01 UTC (rev 65381)
@@ -25,7 +25,7 @@
     # dev packages
     ### rsync_package 64
     ### rsync_package 65
-    ### rsync_package 70
+    rsync_package 70
     rsync_package 71
 else
     rsync_package $1 $2 $3
Modified: grass-addons/tools/wingrass-packager/grass_packager.bat
--- grass-addons/tools/wingrass-packager/grass_packager.bat	2015-06-05 18:14:04 UTC (rev 65380)
+++ grass-addons/tools/wingrass-packager/grass_packager.bat	2015-06-05 21:17:01 UTC (rev 65381)
@@ -22,8 +22,8 @@
 REM xcopy C:\OSGeo4W\usr\src\grass64_release\mswindows\* .\grass64 /S/V/F/I
 REM if exist .\grass65 rmdir /S/Q .\grass65
 REM xcopy C:\OSGeo4W\usr\src\grass6_devel\mswindows\* .\grass65 /S/V/F/I
-REM if exist .\grass70 rmdir /S/Q .\grass70
-REM xcopy C:\OSGeo4W\usr\src\grass70_release\mswindows\* .\grass70 /S/V/F/I
+if exist .\grass70 rmdir /S/Q .\grass70
+xcopy C:\OSGeo4W\usr\src\grass70_release\mswindows\* .\grass70 /S/V/F/I
 if exist .\grass71 rmdir /S/Q .\grass71
 xcopy C:\OSGeo4W\usr\src\grass_trunk\mswindows\* .\grass71 /S/V/F/I
@@ -36,9 +36,9 @@
 REM cd .\grass65
 REM call .\GRASS-Packager.bat
 REM cd ..
-REM cd .\grass70
-REM call .\GRASS-Packager.bat > .\GRASS-Packager.log
-REM cd ..
+cd .\grass70
+call .\GRASS-Packager.bat > .\GRASS-Packager.log
+cd ..
 cd .\grass71
 cd ..
@@ -51,7 +51,7 @@
 REM
 REM C:\DevTools\makensis.exe .\grass64\GRASS-Installer.nsi > .\grass64\GRASS-Installer.log
 REM C:\DevTools\makensis.exe .\grass65\GRASS-Installer.nsi
-REM C:\DevTools\makensis.exe .\grass70\GRASS-Installer.nsi > .\grass70\GRASS-Installer.log
+C:\DevTools\makensis.exe .\grass70\GRASS-Installer.nsi > .\grass70\GRASS-Installer.log
 C:\DevTools\makensis.exe .\grass71\GRASS-Installer.nsi > .\grass71\GRASS-Installer.log
 REM
Modified: grass-addons/tools/wingrass-packager/grass_svn_info.sh
--- grass-addons/tools/wingrass-packager/grass_svn_info.sh	2015-06-05 18:14:04 UTC (rev 65380)
+++ grass-addons/tools/wingrass-packager/grass_svn_info.sh	2015-06-05 21:17:01 UTC (rev 65381)
@@ -63,7 +63,7 @@
     # dev packages
     ### update grass64_release grass64
     ### update grass6_devel    grass65
-    ### update grass70_release grass70
+    update grass70_release grass70
     update grass_trunk     grass71
 else
     update grass$VERSION   grass$VERSION $NUM
