[GRASS-SVN] r65406 - grass/branches/releasebranch_7_0/raster/r.profile
svn_grass at osgeo.org
Sun Jun 7 11:51:29 PDT 2015
Author: neteler
Date: 2015-06-07 11:51:29 -0700 (Sun, 07 Jun 2015)
New Revision: 65406
grass/branches/releasebranch_7_0/raster/r.profile/r.profile.html
r.profile manual: examples change to NC
Modified: grass/branches/releasebranch_7_0/raster/r.profile/r.profile.html
--- grass/branches/releasebranch_7_0/raster/r.profile/r.profile.html 2015-06-07 18:50:48 UTC (rev 65405)
+++ grass/branches/releasebranch_7_0/raster/r.profile/r.profile.html 2015-06-07 18:51:29 UTC (rev 65406)
@@ -49,16 +49,35 @@
If the units are not specified, current location units will be used.
In case of geographic locations (latitude/longitude), meters are used as default unit.
+<h2>NOTES</h2>
+The profile resolution is measured exactly from the supplied end or
+"turning" point along the profile. The end of a profile segment will be an
+exact multiple of the profile resolution and will therefore not always match
+the end point coordinates entered for the segmanet.
+<p>To extract the numbers in scripts, following parameters can be used:
+<div class="code"><pre>
+r.profile input=dgm12.5 coordinates=3570631,5763556 2>/dev/null
+</pre></div>
+This filters out the everything except the numbers.
<h2>EXAMPLES</h2>
-<b>Example 1</b><br>
-Extract a profile with coordinates provided on the command line:
+<h3>Extraction of values along profile defined by coordinates (variant 1)</h3>
+Extract a profile with coordinates (wayoints) provided on the command line
+(North Carolina data set):
-r.profile input=elevation output=profile_points coordinates=562517,7779433,562984,7779533,563875,7779800
+g.region raster=elevation -p
+r.profile -g input=elevation output=profile_points.csv \
+ coordinates=641712,226095,641546,224138,641546,222048,641049,221186
</pre></div>
This will extract a profile along the track defined by the three coordinate
-pairs.
+pairs. The output file "profile_points.csv" contains
+east,north,distance,value (here: elevation).
<p><br>
@@ -91,37 +110,36 @@
<p><br>
-<b>Example 2</b><br>
-Pipe coordinates into r.profile
+<h3>Extraction of values along profile defined by coordinates (variant 2)</h3>
+Coordinate pairs can also being "piped" into <em>r.profile</em>:
-r.profile elevation.dem res=1000 file=- << EOF
- 591243,4926344
- 592509,4922156
- 594100,4920793
- 599910,4919365
- 602929,4919235
- 604844,4918391
- 606468,4917190
- 607766,4915664
+r.profile elevation resolution=1000 file=- << EOF
+641712,226095
+641546,224138
+641546,222048
+641049,221186
EOF
</pre></div>
+The output is the following:
-<h2>NOTES</h2>
-The profile resolution is measured exactly from the supplied end or
-"turning" point along the profile. The end of a profile segment will be an
-exact multiple of the profile resolution and will therefore not always match
-the end point coordinates entered for the segmanet.
-<p>To extract the numbers in scripts, following parameters can be used:
-r.profile input=dgm12.5 coordinates=3570631,5763556 2>/dev/null
+Using resolution: 1000 [meters]
+Output columns:
+Along track dist. [meters], Elevation
+Approx. transect length: 1964.027749 [meters]
+ 0.000000 84.661507
+ 1000.000000 98.179062
+Approx. transect length: 2090.000000 [meters]
+ 1964.027749 83.638138
+ 2964.027749 89.141029
+ 3964.027749 78.497757
+Approx. transect length: 995.014070 [meters]
+ 4054.027749 73.988029
</pre></div>
-This filters out the everything except the numbers.
<h2>SEE ALSO</h2>
<em>
