[GRASS-SVN] r65421 - grass/trunk/lib/python/pygrass
Mon Jun 8 02:18:44 PDT 2015
Author: zarch
Date: 2015-06-08 02:18:44 -0700 (Mon, 08 Jun 2015)
New Revision: 65421
   grass/trunk/lib/python/pygrass/utils.py
pygrass: remove duplicated code, the code is now in: pygrass.modules.interface.docstring
Modified: grass/trunk/lib/python/pygrass/utils.py
--- grass/trunk/lib/python/pygrass/utils.py	2015-06-08 08:03:27 UTC (rev 65420)
+++ grass/trunk/lib/python/pygrass/utils.py	2015-06-08 09:18:44 UTC (rev 65421)
@@ -344,57 +344,3 @@
             return False
     one = cursor.fetchone() if cursor else None
     return True if one and one[0] else False
-def docstring_property(class_doc):
-    """Property attribute for docstrings.
-    Took from: https://gist.github.com/bfroehle/4041015
-    >>> class A(object):
-    ...     '''Main docstring'''
-    ...     def __init__(self, x):
-    ...         self.x = x
-    ...     @docstring_property(__doc__)
-    ...     def __doc__(self):
-    ...         return "My value of x is %s." % self.x
-    >>> A.__doc__
-    'Main docstring'
-    >>> a = A(10)
-    >>> a.__doc__
-    'My value of x is 10.'
-    def wrapper(fget):
-        return DocstringProperty(class_doc, fget)
-    return wrapper
-class DocstringProperty(object):
-    """Property for the `__doc__` attribute.
-    Different than `property` in the following two ways:
-    * When the attribute is accessed from the main class, it returns the value
-      of `class_doc`, *not* the property itself. This is necessary so Sphinx
-      and other documentation tools can access the class docstring.
-    * Only supports getting the attribute; setting and deleting raise an
-      `AttributeError`.
-    def __init__(self, class_doc, fget):
-        self.class_doc = class_doc
-        self.fget = fget
-    def __get__(self, obj, type=None):
-        if obj is None:
-            return self.class_doc
-        else:
-            return self.fget(obj)
-    def __set__(self, obj, value):
-        raise AttributeError("can't set attribute")
-    def __delete__(self, obj):
-        raise AttributeError("can't delete attribute")
