[GRASS-SVN] r65426 - grass/trunk/lib/gis/testsuite
svn_grass at osgeo.org
Tue Jun 9 15:37:24 PDT 2015
Author: wenzeslaus
Date: 2015-06-09 15:37:24 -0700 (Tue, 09 Jun 2015)
New Revision: 65426
Added:
grass/trunk/lib/gis/testsuite/gis_lib_tokenize.py
libgis: simple test for number of tokens from G_tokenize2
Added: grass/trunk/lib/gis/testsuite/gis_lib_tokenize.py
--- grass/trunk/lib/gis/testsuite/gis_lib_tokenize.py (rev 0)
+++ grass/trunk/lib/gis/testsuite/gis_lib_tokenize.py 2015-06-09 22:37:24 UTC (rev 65426)
@@ -0,0 +1,81 @@
+"""Test of gis library tokenizing of text
+ at author Vaclav Petras
+from grass.gunittest.case import TestCase
+from grass.gunittest.main import test
+import grass.lib.gis as libgis
+# TODO: add tests for content (now testing only number of items)
+class TokenizeTestCase(TestCase):
+ """Test C function G_tokenize() from gis library"""
+ def test_tokenize_comma(self):
+ """Test G_tokenize with comma as delim"""
+ tokens = libgis.G_tokenize("a,b,c,d", ",")
+ num_of_tokens = libgis.G_number_of_tokens(tokens)
+ self.assertEqual(num_of_tokens, 4, msg="Got wrong number of tokens")
+ def test_tokenize_alternative_delim(self):
+ """Test G_tokenize with semi colon as delim"""
+ tokens = libgis.G_tokenize("a;b;c", ";")
+ self.assertEqual(num_of_tokens, 3, msg="Got wrong number of tokens")
+ def test_tokenize_with_text_delim(self):
+ """Test G_tokenize with comma as delim and single quote text delim
+ Expecting the 'wrong' number of tokens here.
+ tokens = libgis.G_tokenize("a,'b,c',d", ",")
+ self.assertEqual(
+ num_of_tokens, 4,
+ msg="Got wrong number of tokens (expecting that the text"
+ "delimiter is ignored)")
+ # alternatively this can be done using test with expected failure
+class Tokenize2TestCase(TestCase):
+ """Test C function G_tokenize2() from gis library"""
+ def test_tokenize2_comma(self):
+ """Test G_tokenize2 without any text delim"""
+ tokens = libgis.G_tokenize2("a,b,c,d", ",", "'")
+ def test_tokenize2_with_text_delim(self):
+ """Test G_tokenize2 with , as delim and single quote text delim"""
+ tokens = libgis.G_tokenize2("a,'b,c',d", ",", "'")
+ def test_tokenize2_with_alternative_text_delim(self):
+ """Test G_tokenize2 with ; as delim and double quote text delim"""
+ tokens = libgis.G_tokenize2('a;"b;c";d', ';', '"')
+ def test_tokenize2_with_text_delim_more_text_tokens(self):
+ """Test G_tokenize2 with comma as delim and hash as text delim"""
+ tokens = libgis.G_tokenize2("a,#b,c#,#5,d#,#7,2#", ",", "#")
+ def test_tokenize2_with_real_text(self):
+ """Test G_tokenize2 with real world text"""
+ '440,617722.81,3464034.494,951.987,'
+ '"Low Erosion (1,5)","High Deposition (8,6)"',
+ self.assertEqual(num_of_tokens, 6, msg="Got wrong number of tokens")
+if __name__ == '__main__':
+ test()
