[GRASS-SVN] r65429 - grass/trunk/lib/python/script
svn_grass at osgeo.org
Tue Jun 9 21:16:17 PDT 2015
Author: wenzeslaus
Date: 2015-06-09 21:16:17 -0700 (Tue, 09 Jun 2015)
New Revision: 65429
grass/trunk/lib/python/script/Makefile
grass/trunk/lib/python/script/setup.py
pythonlib: use non-py extension for tmp file (r65345) to avoid picking of the file by autodoc, fix syntax in r65346
Modified: grass/trunk/lib/python/script/Makefile
--- grass/trunk/lib/python/script/Makefile 2015-06-10 03:43:30 UTC (rev 65428)
+++ grass/trunk/lib/python/script/Makefile 2015-06-10 04:16:17 UTC (rev 65429)
@@ -18,12 +18,12 @@
$(DSTDIR)/%: % | $(DSTDIR)
$(INSTALL_DATA) $< $@
-EXTRA_CLEAN_FILES = setup.tmp.py
+EXTRA_CLEAN_FILES = setup.py.tmp
-$(DSTDIR)/setup.py: setup.tmp.py | $(DSTDIR)
+$(DSTDIR)/setup.py: setup.py.tmp | $(DSTDIR)
-setup.tmp.py: setup.py
+setup.py.tmp: setup.py
sed \
-e 's#@LD_LIBRARY_PATH_VAR@#$(LD_LIBRARY_PATH_VAR)#' \
Modified: grass/trunk/lib/python/script/setup.py
--- grass/trunk/lib/python/script/setup.py 2015-06-10 03:43:30 UTC (rev 65428)
+++ grass/trunk/lib/python/script/setup.py 2015-06-10 04:16:17 UTC (rev 65429)
@@ -47,9 +47,9 @@
" {cmd}: {error}".format(cmd=startcmd[0], error=error))
if p.returncode != 0:
sys.exit("ERROR: Issues running GRASS GIS start script"
- " {cmd}:\n{error}"
+ " {cmd}: {error}"
.format(cmd=' '.join(startcmd), error=err))
- gisbase = out.strip('\n\r')
+ gisbase = out.strip(os.linesep)
# set GISBASE environment variable
os.environ['GISBASE'] = gisbase
@@ -109,6 +109,8 @@
return gisrc
+# TODO: there should be a function to do the clean up
+# (unset the GISRC and delete the file)
def init(gisbase, dbase='', location='demolocation', mapset='PERMANENT'):
"""Initialize system variables to run GRASS modules
@@ -126,12 +128,13 @@
Basic usage::
- # ... setup GISBASE and PYTHON path
- grass.script as gscript
+ # ... setup GISBASE and PYTHON path before import
+ import grass.script as gscript
gisrc = gscript.setup.init("/usr/lib/grass64",
"/home/john/grassdata",
"nc_spm_08", "user1")
- # ... use GRASS modules
+ # ... use GRASS modules here
+ # remove the session's gisrc file to end the session
os.remove(gisrc)
:param gisbase: path to GRASS installation
