[GRASS-SVN] r65436 - in grass/trunk: include/defs lib/gis lib/init lib/vector/Vlib
svn_grass at osgeo.org
Wed Jun 10 12:00:04 PDT 2015
Author: martinl
Date: 2015-06-10 12:00:04 -0700 (Wed, 10 Jun 2015)
New Revision: 65436
grass/trunk/include/defs/gis.h
grass/trunk/lib/gis/file_name.c
grass/trunk/lib/gis/tempfile.c
grass/trunk/lib/init/clean_temp.c
grass/trunk/lib/init/variables.html
grass/trunk/lib/vector/Vlib/open.c
change GRASS_TMPDIR_MAPSET to be accepted only by vector library
(see https://trac.osgeo.org/grass/ticket/2349#comment:36)
Modified: grass/trunk/include/defs/gis.h
--- grass/trunk/include/defs/gis.h 2015-06-10 18:48:44 UTC (rev 65435)
+++ grass/trunk/include/defs/gis.h 2015-06-10 19:00:04 UTC (rev 65436)
@@ -652,6 +652,7 @@
char *G_tempfile(void);
char *G_tempfile_pid(int);
void G_temp_element(char *);
+void G__temp_element(char *, int);
/* mkstemp.c */
char *G_mktemp(char *);
Modified: grass/trunk/lib/gis/file_name.c
--- grass/trunk/lib/gis/file_name.c 2015-06-10 18:48:44 UTC (rev 65435)
+++ grass/trunk/lib/gis/file_name.c 2015-06-10 19:00:04 UTC (rev 65436)
@@ -60,7 +60,7 @@
- \brief Builds full path names to GIS data files in temporary directory
+ \brief Builds full path names to GIS data files in temporary directory (for internal use only)
By default temporary directory is located
$LOCATION/$MAPSET/.tmp/$HOSTNAME. If GRASS_TMPDIR_MAPSET is set to
Modified: grass/trunk/lib/gis/tempfile.c
--- grass/trunk/lib/gis/tempfile.c 2015-06-10 18:48:44 UTC (rev 65435)
+++ grass/trunk/lib/gis/tempfile.c 2015-06-10 19:00:04 UTC (rev 65436)
@@ -85,7 +85,7 @@
do {
int uniq = G_counter_next(&unique);
sprintf(name, "%d.%d", pid, uniq);
- G_file_name_tmp(path, element, name, G_mapset());
+ G_file_name(path, element, name, G_mapset());
while (access(path, F_OK) == 0);
@@ -101,8 +101,19 @@
void G_temp_element(char *element)
- const char *machine, *env;
+ G__temp_element(element, FALSE);
+ * \brief Populates element with a path string (internal use only!)
+ * \param[out] element element name
+ * \param tmp TRUE to use G_make_mapset_element_tmp() instead of G_make_mapset_element()
+void G__temp_element(char *element, int tmp)
+ const char *machine;
strcpy(element, ".tmp");
machine = G__machine_name();
if (machine != NULL && *machine != 0) {
@@ -110,12 +121,10 @@
strcat(element, machine);
- env = getenv("GRASS_TMPDIR_MAPSET");
- if (!env || strcmp(env, "0") != 0)
+ if (!tmp)
G_make_mapset_element(element);
else
G_make_mapset_element_tmp(element);
- G_debug(2, "G_temp_element(): %s (GRASS_TMPDIR_MAPSET=%s)",
- element, env ? env : "");
+ G_debug(2, "G__temp_element(): %s (tmp=%d)", element, tmp);
Modified: grass/trunk/lib/init/clean_temp.c
--- grass/trunk/lib/init/clean_temp.c 2015-06-10 18:48:44 UTC (rev 65435)
+++ grass/trunk/lib/init/clean_temp.c 2015-06-10 19:00:04 UTC (rev 65436)
@@ -135,7 +135,7 @@
/* Get the mapset temp directory */
G_temp_element(element);
- G_file_name_tmp(tmppath, element, "", mapset = G_mapset());
+ G_file_name(tmppath, element, "", mapset = G_mapset());
/* get user id and current time in seconds */
#ifdef __MINGW32__
Modified: grass/trunk/lib/init/variables.html
--- grass/trunk/lib/init/variables.html 2015-06-10 18:48:44 UTC (rev 65435)
+++ grass/trunk/lib/init/variables.html 2015-06-10 19:00:04 UTC (rev 65436)
@@ -352,7 +352,13 @@
<tt>$LOCATION/$MAPSET/.tmp/$HOSTNAME</tt>. If GRASS_TMPDIR_MAPSET is
set to '0', the temporary directory is located in TMPDIR
(environmental variable defined by the user or GRASS initialization
- script if not given).</dd>
+ script if not given).
+ <p>
+ Important note: This variable is currently used only in vector
+ library. In other words the variable is ignored by raster or
+ raster3d library.
+ </dd>
<dt>TMPDIR, TEMP, TMP</dt>
<dd>[Various GRASS GIS commands and wxGUI]<br>
Modified: grass/trunk/lib/vector/Vlib/open.c
--- grass/trunk/lib/vector/Vlib/open.c 2015-06-10 18:48:44 UTC (rev 65435)
+++ grass/trunk/lib/vector/Vlib/open.c 2015-06-10 19:00:04 UTC (rev 65436)
@@ -1438,7 +1438,7 @@
if (Map->temporary) {
char path_tmp[GPATH_MAX];
- G_temp_element(path_tmp);
+ G__temp_element(path_tmp, TRUE);
sprintf(path, "%s/%s/%s", path_tmp, GV_DIRECTORY, Map->name);
else {
