[GRASS-SVN] r65438 - grass/trunk/lib/python/pygrass/modules/interface
svn_grass at osgeo.org
Thu Jun 11 03:12:15 PDT 2015
Author: zarch
Date: 2015-06-11 03:12:15 -0700 (Thu, 11 Jun 2015)
New Revision: 65438
grass/trunk/lib/python/pygrass/modules/interface/env.py
pygrass: Remove dictionary comprehension for backward compatibility with python2.6
Modified: grass/trunk/lib/python/pygrass/modules/interface/env.py
--- grass/trunk/lib/python/pygrass/modules/interface/env.py 2015-06-10 19:17:13 UTC (rev 65437)
+++ grass/trunk/lib/python/pygrass/modules/interface/env.py 2015-06-11 10:12:15 UTC (rev 65438)
@@ -15,8 +15,8 @@
if gisrc is None:
raise RuntimeError('You are not in a GRASS session, GISRC not found.')
with open(gisrc, mode='r') as grc:
- env = {k.strip(): v.strip() for k, v in [row.split(':')
- for row in grc if row]}
+ env = dict([(k.strip(), v.strip())
+ for k, v in [row.split(':') for row in grc if row]])
return env
