[GRASS-SVN] r65448 - in grass/branches/releasebranch_7_0: . lib/python/script
Fri Jun 12 12:42:30 PDT 2015
Author: wenzeslaus
Date: 2015-06-12 12:42:30 -0700 (Fri, 12 Jun 2015)
New Revision: 65448
Added:
   grass/branches/releasebranch_7_0/lib/python/script/setup.py
Removed:
   grass/branches/releasebranch_7_0/lib/python/script/setup.py.sed
   grass/branches/releasebranch_7_0/lib/python/script/Makefile
pythonlib: document and redo compilation in grass.setup (backport r65345, r65346, r65429)
Property changes on: grass/branches/releasebranch_7_0
___________________________________________________________________
Deleted: svn:mergeinfo
   - /grass/trunk:64971,65076-65077,65096,65119,65190,65287,65289-65290,65336-65337,65438
Modified: grass/branches/releasebranch_7_0/lib/python/script/Makefile
--- grass/branches/releasebranch_7_0/lib/python/script/Makefile	2015-06-12 14:09:12 UTC (rev 65447)
+++ grass/branches/releasebranch_7_0/lib/python/script/Makefile	2015-06-12 19:42:30 UTC (rev 65448)
@@ -18,10 +18,12 @@
 $(DSTDIR)/%: % | $(DSTDIR)
 	$(INSTALL_DATA) $< $@
-$(DSTDIR)/setup.py: $(OBJDIR)/setup.py | $(DSTDIR)
+EXTRA_CLEAN_FILES = setup.py.tmp
+$(DSTDIR)/setup.py: setup.py.tmp | $(DSTDIR)
-$(OBJDIR)/setup.py: setup.py.sed | $(OBJDIR)
+setup.py.tmp: setup.py
 	sed \
 	-e 's#@LD_LIBRARY_PATH_VAR@#$(LD_LIBRARY_PATH_VAR)#' \
Copied: grass/branches/releasebranch_7_0/lib/python/script/setup.py (from rev 65345, grass/trunk/lib/python/script/setup.py)
--- grass/branches/releasebranch_7_0/lib/python/script/setup.py	                        (rev 0)
+++ grass/branches/releasebranch_7_0/lib/python/script/setup.py	2015-06-12 19:42:30 UTC (rev 65448)
@@ -0,0 +1,191 @@
+"""Setup and initialization functions
+Function can be used in Python scripts to setup a GRASS environment
+without starting an actual GRASS session.
+Usage::
+    import os
+    import sys
+    import subprocess
+    # define GRASS Database
+    # add your path to grassdata (GRASS GIS database) directory
+    gisdb = os.path.join(os.path.expanduser("~"), "grassdata")
+    # the following path is the default path on MS Windows
+    # gisdb = os.path.join(os.path.expanduser("~"), "Documents/grassdata")
+    # specify (existing) Location and Mapset
+    location = "nc_spm_08"
+    mapset = "user1"
+    # path to the GRASS GIS launch script
+    # we assume that the GRASS GIS start script is available and on PATH
+    # query GRASS itself for its GISBASE
+    # (with fixes for specific platforms)
+    # needs to be edited by the user
+    grass7bin = 'grass70'
+    if sys.platform.startswith('win'):
+        # MS Windows
+        grass7bin = r'C:\OSGeo4W\bin\grass70.bat'
+        # uncomment when using standalone WinGRASS installer
+        # grass7bin = r'C:\Program Files (x86)\GRASS GIS 7.0.0\grass70.bat'
+        # this can be avoided if GRASS executable is added to PATH
+    elif sys.platform == 'darwin':
+        # Mac OS X
+        # TODO: this have to be checked, maybe unix way is good enough
+        grass7bin = '/Applications/GRASS/GRASS-7.0.app/'
+    # query GRASS GIS itself for its GISBASE
+    startcmd = [grass7bin, '--config', 'path']
+    try:
+        p = subprocess.Popen(startcmd, shell=False,
+                             stdout=subprocess.PIPE, stderr=subprocess.PIPE)
+        out, err = p.communicate()
+    except OSError as error:
+        sys.exit("ERROR: Cannot find GRASS GIS start script"
+                 " {cmd}: {error}".format(cmd=startcmd[0], error=error))
+    if p.returncode != 0:
+        sys.exit("ERROR: Issues running GRASS GIS start script"
+                 " {cmd}: {error}"
+                 .format(cmd=' '.join(startcmd), error=err))
+    gisbase = out.strip(os.linesep)
+    # set GISBASE environment variable
+    os.environ['GISBASE'] = gisbase
+    # define GRASS-Python environment
+    grass_pydir = os.path.join(gisbase, "etc", "python")
+    sys.path.append(grass_pydir)
+    # import (some) GRASS Python bindings
+    import grass.script as gscript
+    # launch session
+    rcfile = gscript.setup.init(gisbase, gisdb, location, mapset)
+    # example calls
+    gscript.message('Current GRASS GIS 7 environment:')
+    print gscript.gisenv()
+    gscript.message('Available raster maps:')
+    for rast in gscript.list_strings(type='raster'):
+        print rast
+    gscript.message('Available vector maps:')
+    for vect in gscript.list_strings(type='vector'):
+        print vect
+    # delete the rcfile
+    os.remove(rcfile)
+(C) 2010-2012 by the GRASS Development Team
+This program is free software under the GNU General Public
+License (>=v2). Read the file COPYING that comes with GRASS
+for details.
+ at author Martin Landa <landa.martin gmail.com>
+ at author Vaclav Petras <wenzeslaus gmail.com>
+# TODO: this should share code from lib/init/grass.py
+# perhaps grass.py can import without much trouble once GISBASE
+# is known, this would allow moving things from there, here
+# then this could even do locking
+import os
+import sys
+import tempfile as tmpfile
+def write_gisrc(dbase, location, mapset):
+    """Write the ``gisrc`` file and return its path."""
+    fd, gisrc = tmpfile.mkstemp()
+    os.write(fd, "GISDBASE: %s\n" % dbase)
+    os.write(fd, "LOCATION_NAME: %s\n" % location)
+    os.write(fd, "MAPSET: %s\n" % mapset)
+    os.close(fd)
+    return gisrc
+# TODO: there should be a function to do the clean up
+# (unset the GISRC and delete the file)
+def init(gisbase, dbase='', location='demolocation', mapset='PERMANENT'):
+    """Initialize system variables to run GRASS modules
+    This function is for running GRASS GIS without starting it
+    explicitly. No GRASS modules shall be called before call of this
+    function but any module or user script can be called afterwards
+    as if it would be called in an actual GRASS session. GRASS Python
+    libraries are usable as well in general but the ones using
+    C libraries through ``ctypes`` are not (which is caused by
+    library path not being updated for the current process
+    which is a common operating system limitation).
+    To create a (fake) GRASS session a ``gisrc`` file is created.
+    Caller is resposible for deleting the ``gisrc`` file.
+    Basic usage::
+        # ... setup GISBASE and PYTHON path before import
+        gisrc = gscript.setup.init("/usr/lib/grass64",
+                                   "/home/john/grassdata",
+                                   "nc_spm_08", "user1")
+        # ... use GRASS modules here
+        # remove the session's gisrc file to end the session
+        os.remove(gisrc)
+    :param gisbase: path to GRASS installation
+    :param dbase: path to GRASS database (default: '')
+    :param location: location name (default: 'demolocation')
+    :param mapset: mapset within given location (default: 'PERMANENT')
+    :returns: path to ``gisrc`` file (to be deleted later)
+    # TODO: why we don't set GISBASE?
+    mswin = sys.platform.startswith('win')
+    # define PATH
+    os.environ['PATH'] += os.pathsep + os.path.join(gisbase, 'bin')
+    os.environ['PATH'] += os.pathsep + os.path.join(gisbase, 'scripts')
+    if mswin:  # added for winGRASS
+        os.environ['PATH'] += os.pathsep + os.path.join(gisbase, 'extrabin')
+    # add addons to the PATH
+    # copied and simplified from lib/init/grass.py
+    if mswin:
+        config_dirname = "GRASS7"
+        config_dir = os.path.join(os.getenv('APPDATA'), config_dirname)
+    else:
+        config_dirname = ".grass7"
+        config_dir = os.path.join(os.getenv('HOME'), config_dirname)
+    addon_base = os.path.join(config_dir, 'addons')
+    os.environ['GRASS_ADDON_BASE'] = addon_base
+    if not mswin:
+        os.environ['PATH'] += os.pathsep + os.path.join(addon_base, 'scripts')
+    # define LD_LIBRARY_PATH
+    if '@LD_LIBRARY_PATH_VAR@' not in os.environ:
+        os.environ['@LD_LIBRARY_PATH_VAR@'] = ''
+    os.environ['@LD_LIBRARY_PATH_VAR@'] += os.pathsep + os.path.join(gisbase, 'lib')
+    os.environ['GIS_LOCK'] = str(os.getpid())
+    # Set PYTHONPATH to find GRASS Python modules
+    # TODO: isn't this useless? user already imported this somehow
+    path = os.getenv('PYTHONPATH')
+    etcpy = os.path.join(gisbase, 'etc', 'python')
+    if path:
+        path = etcpy + os.pathsep + path
+    else:
+        path = etcpy
+    os.environ['PYTHONPATH'] = path
+    # TODO: isn't this contra-productive? may fail soon since we cannot
+    # write to the installation (applies also to defaults for Location
+    # and mapset) I don't see what would be the use case here.
+    if not dbase:
+        dbase = gisbase
+    os.environ['GISRC'] = write_gisrc(dbase, location, mapset)
+    return os.environ['GISRC']
Deleted: grass/branches/releasebranch_7_0/lib/python/script/setup.py.sed
--- grass/branches/releasebranch_7_0/lib/python/script/setup.py.sed	2015-06-12 14:09:12 UTC (rev 65447)
+++ grass/branches/releasebranch_7_0/lib/python/script/setup.py.sed	2015-06-12 19:42:30 UTC (rev 65448)
@@ -1,77 +0,0 @@
-"""!@package grass.script.setup
- at brief GRASS Python scripting module (setup)
-Setup functions to be used in Python scripts.
-Usage:
- at code
-from grass.script import setup as grass
-grass.init()
- at endcode
-(C) 2010-2012 by the GRASS Development Team
-This program is free software under the GNU General Public
-License (>=v2). Read the file COPYING that comes with GRASS
-for details.
- at author Martin Landa <landa.martin gmail.com>
-import os
-import sys
-import tempfile as tmpfile
-def write_gisrc(dbase, location, mapset):
-    """Write the gisrc file and return the gisrc path."""
-    fd, gisrc = tmpfile.mkstemp()
-    os.write(fd, "GISDBASE: %s\n" % dbase)
-    os.write(fd, "LOCATION_NAME: %s\n" % location)
-    os.write(fd, "MAPSET: %s\n" % mapset)
-    os.close(fd)
-    return gisrc
-def init(gisbase, dbase='', location='demolocation', mapset='PERMANENT'):
-    """!Initialize system variables to run scripts without starting
-    GRASS explicitly.
-    User is resposible to delete gisrc file.
-    @param gisbase path to GRASS installation
-    @param dbase   path to GRASS database (default: '')
-    @param location location name (default: 'demolocation')
-    @param mapset   mapset within given location (default: 'PERMANENT')
-    @return path to gisrc file
-    # define PATH
-    os.environ['PATH'] += os.pathsep + os.path.join(gisbase, 'bin')
-    os.environ['PATH'] += os.pathsep + os.path.join(gisbase, 'scripts')
-    if sys.platform.startswith('win'):  # added for winGRASS
-        os.environ['PATH'] += os.pathsep + os.path.join(gisbase, 'extrabin')
-    # define LD_LIBRARY_PATH
-    if '@LD_LIBRARY_PATH_VAR@' not in os.environ:
-        os.environ['@LD_LIBRARY_PATH_VAR@'] = ''
-    os.environ['@LD_LIBRARY_PATH_VAR@'] += os.pathsep + os.path.join(gisbase, 'lib')
-    os.environ['GIS_LOCK'] = str(os.getpid())
-    # Set PYTHONPATH to find GRASS Python modules
-    path = os.getenv('PYTHONPATH')
-    etcpy = os.path.join(gisbase, 'etc', 'python')
-    if path:
-        path = etcpy + os.pathsep + path
-    else:
-        path = etcpy
-    os.environ['PYTHONPATH'] = path
-    if not dbase:
-        dbase = gisbase
-    os.environ['GISRC'] = write_gisrc(dbase, location, mapset)
-    return os.environ['GISRC']
