[GRASS-SVN] r65452 - grass/branches/releasebranch_7_0/mswindows
svn_grass at osgeo.org
Fri Jun 12 14:19:22 PDT 2015
Author: annakrat
Date: 2015-06-12 14:19:22 -0700 (Fri, 12 Jun 2015)
New Revision: 65452
grass/branches/releasebranch_7_0/mswindows/GRASS-Installer.nsi.tmpl
mswindows installer: attempt to fix #2448 by providing dummy GISRC (merge from trunk, r65440)
Modified: grass/branches/releasebranch_7_0/mswindows/GRASS-Installer.nsi.tmpl
--- grass/branches/releasebranch_7_0/mswindows/GRASS-Installer.nsi.tmpl 2015-06-12 21:11:26 UTC (rev 65451)
+++ grass/branches/releasebranch_7_0/mswindows/GRASS-Installer.nsi.tmpl 2015-06-12 21:19:22 UTC (rev 65452)
@@ -551,6 +551,9 @@
FileWrite $0 'rem set dependecies path$\r$\n'
FileWrite $0 'set PATH=%FREETYPEBASE%;%PATH%$\r$\n'
FileWrite $0 '$\r$\n'
+ FileWrite $0 'rem GISRC must be set$\r$\n'
+ FileWrite $0 'set GISRC=dummy$\r$\n'
+ FileWrite $0 '$\r$\n'
FileWrite $0 'rem run g.mkfontcap outside a grass session$\r$\n'
FileWrite $0 '"%GISBASE%\bin\g.mkfontcap.exe" -o$\r$\n'
FileWrite $0 'exit$\r$\n'
