[GRASS-SVN] r65467 - grass/branches/releasebranch_7_0
svn_grass at osgeo.org
Sun Jun 14 13:19:10 PDT 2015
Author: neteler
Date: 2015-06-14 13:19:10 -0700 (Sun, 14 Jun 2015)
New Revision: 65467
grass/branches/releasebranch_7_0/config.guess
grass/branches/releasebranch_7_0/config.sub
config.guess + config.sub: updated from http://git.savannah.gnu.org/cgit/config.git/plain/
Modified: grass/branches/releasebranch_7_0/config.guess
--- grass/branches/releasebranch_7_0/config.guess 2015-06-14 11:12:56 UTC (rev 65466)
+++ grass/branches/releasebranch_7_0/config.guess 2015-06-14 20:19:10 UTC (rev 65467)
@@ -2,7 +2,7 @@
# Attempt to guess a canonical system name.
# Copyright 1992-2015 Free Software Foundation, Inc.
-timestamp='2015-01-01'
+timestamp='2015-03-04'
# This file is free software; you can redistribute it and/or modify it
# under the terms of the GNU General Public License as published by
@@ -168,20 +168,27 @@
# Note: NetBSD doesn't particularly care about the vendor
# portion of the name. We always set it to "unknown".
sysctl="sysctl -n hw.machine_arch"
- UNAME_MACHINE_ARCH=`(/sbin/$sysctl 2>/dev/null || \
- /usr/sbin/$sysctl 2>/dev/null || echo unknown)`
+ UNAME_MACHINE_ARCH=`(uname -p 2>/dev/null || \
+ /sbin/$sysctl 2>/dev/null || \
+ /usr/sbin/$sysctl 2>/dev/null || \
+ echo unknown)`
case "${UNAME_MACHINE_ARCH}" in
armeb) machine=armeb-unknown ;;
arm*) machine=arm-unknown ;;
sh3el) machine=shl-unknown ;;
sh3eb) machine=sh-unknown ;;
sh5el) machine=sh5le-unknown ;;
+ earmv*)
+ arch=`echo ${UNAME_MACHINE_ARCH} | sed -e 's,^e\(armv[0-9]\).*$,\1,'`
+ endian=`echo ${UNAME_MACHINE_ARCH} | sed -ne 's,^.*\(eb\)$,\1,p'`
+ machine=${arch}${endian}-unknown
*) machine=${UNAME_MACHINE_ARCH}-unknown ;;
esac
# The Operating System including object format, if it has switched
# to ELF recently, or will in the future.
- arm*|i386|m68k|ns32k|sh3*|sparc|vax)
+ arm*|earm*|i386|m68k|ns32k|sh3*|sparc|vax)
eval $set_cc_for_build
if echo __ELF__ | $CC_FOR_BUILD -E - 2>/dev/null \
| grep -q __ELF__
@@ -197,6 +204,13 @@
os=netbsd
esac
+ # Determine ABI tags.
+ case "${UNAME_MACHINE_ARCH}" in
+ earm*)
+ expr='s/^earmv[0-9]/-eabi/;s/eb$//'
+ abi=`echo ${UNAME_MACHINE_ARCH} | sed -e "$expr"`
+ esac
# The OS release
# Debian GNU/NetBSD machines have a different userland, and
# thus, need a distinct triplet. However, they do not need
@@ -213,7 +227,7 @@
# Since CPU_TYPE-MANUFACTURER-KERNEL-OPERATING_SYSTEM:
# contains redundant information, the shorter form:
# CPU_TYPE-MANUFACTURER-OPERATING_SYSTEM is used.
- echo "${machine}-${os}${release}"
+ echo "${machine}-${os}${release}${abi}"
exit ;;
*:Bitrig:*:*)
UNAME_MACHINE_ARCH=`arch | sed 's/Bitrig.//'`
@@ -933,6 +947,9 @@
crisv32:Linux:*:*)
echo ${UNAME_MACHINE}-axis-linux-${LIBC}
exit ;;
+ e2k:Linux:*:*)
+ echo ${UNAME_MACHINE}-unknown-linux-${LIBC}
+ exit ;;
frv:Linux:*:*)
exit ;;
Modified: grass/branches/releasebranch_7_0/config.sub
--- grass/branches/releasebranch_7_0/config.sub 2015-06-14 11:12:56 UTC (rev 65466)
+++ grass/branches/releasebranch_7_0/config.sub 2015-06-14 20:19:10 UTC (rev 65467)
@@ -2,7 +2,7 @@
# Configuration validation subroutine script.
+timestamp='2015-03-08'
@@ -117,7 +117,7 @@
case $maybe_os in
nto-qnx* | linux-gnu* | linux-android* | linux-dietlibc | linux-newlib* | \
linux-musl* | linux-uclibc* | uclinux-uclibc* | uclinux-gnu* | kfreebsd*-gnu* | \
- knetbsd*-gnu* | netbsd*-gnu* | \
+ knetbsd*-gnu* | netbsd*-gnu* | netbsd*-eabi* | \
kopensolaris*-gnu* | \
storm-chaos* | os2-emx* | rtmk-nova*)
os=-$maybe_os
@@ -259,7 +259,7 @@
| bfin \
| c4x | c8051 | clipper \
| d10v | d30v | dlx | dsp16xx \
- | epiphany \
+ | e2k | epiphany \
| fido | fr30 | frv | ft32 \
| h8300 | h8500 | hppa | hppa1.[01] | hppa2.0 | hppa2.0[nw] | hppa64 \
| hexagon \
@@ -381,7 +381,7 @@
| c[123]* | c30-* | [cjt]90-* | c4x-* \
| c8051-* | clipper-* | craynv-* | cydra-* \
| d10v-* | d30v-* | dlx-* \
- | elxsi-* \
+ | e2k-* | elxsi-* \
| f30[01]-* | f700-* | fido-* | fr30-* | frv-* | fx80-* \
| h8300-* | h8500-* \
| hppa-* | hppa1.[01]-* | hppa2.0-* | hppa2.0[nw]-* | hppa64-* \
@@ -518,6 +518,9 @@
basic_machine=i386-pc
os=-aros
+ asmjs)
+ basic_machine=asmjs-unknown
aux)
basic_machine=m68k-apple
os=-aux
@@ -1373,7 +1376,7 @@
| -hpux* | -unos* | -osf* | -luna* | -dgux* | -auroraux* | -solaris* \
| -sym* | -kopensolaris* | -plan9* \
| -amigaos* | -amigados* | -msdos* | -newsos* | -unicos* | -aof* \
- | -aos* | -aros* \
+ | -aos* | -aros* | -cloudabi* \
| -nindy* | -vxsim* | -vxworks* | -ebmon* | -hms* | -mvs* \
| -clix* | -riscos* | -uniplus* | -iris* | -rtu* | -xenix* \
| -hiux* | -386bsd* | -knetbsd* | -mirbsd* | -netbsd* \
