[GRASS-SVN] r65477 - grass-addons/grass7/raster/r.seg
svn_grass at osgeo.org
Tue Jun 16 02:24:07 PDT 2015
Author: avitti
Date: 2015-06-16 02:24:07 -0700 (Tue, 16 Jun 2015)
New Revision: 65477
grass-addons/grass7/raster/r.seg/Makefile
grass-addons/grass7/raster/r.seg/main.c
Service commit before module rename [from r.seg to r.smooth.seg]
Modified: grass-addons/grass7/raster/r.seg/Makefile
--- grass-addons/grass7/raster/r.seg/Makefile 2015-06-15 15:30:08 UTC (rev 65476)
+++ grass-addons/grass7/raster/r.seg/Makefile 2015-06-16 09:24:07 UTC (rev 65477)
@@ -1,6 +1,6 @@
MODULE_TOPDIR = ../..
-PGM = r.seg
+PGM = r.smooth.seg
LIBES = $(RASTERLIB) $(GISLIB)
DEPENDENCIES = $(RASTERDEP) $(GISDEP)
Modified: grass-addons/grass7/raster/r.seg/main.c
--- grass-addons/grass7/raster/r.seg/main.c 2015-06-15 15:30:08 UTC (rev 65476)
+++ grass-addons/grass7/raster/r.seg/main.c 2015-06-16 09:24:07 UTC (rev 65477)
@@ -1,18 +1,22 @@
- * MODULE: r.seg
+ * MODULE: r.smooth.seg
+ * [ !!! GRASS6 name was r.seg;
+ * GRASS7 former name was r.segment !!! ]
* AUTHOR: Alfonso Vitti <alfonso.vitti unitn.it>
+ * Porting from GRASS6 to GRASS7 by Markus Neteler and Alfonso Vitti
- * PURPOSE: generates a piece-wise smooth approximation of the input
+ * PURPOSE: Generate a piece-wise smooth approximation of the input
* raster map and a raster map of the discontinuities (edges) of
* the output approximation. The discontinuities of the output
* approximation are preserved from being smoothed.
* REFERENCE: http://www.ing.unitn.it/~vittia/phd/vitti_phd.pdf
- * COPYRIGHT: (C) 2007-2015
+ * COPYRIGHT: (C) 2007-2015 by Alfonso Vitti, and the GRASS Development Team
* This program is free software under the GNU General Public
* License (>=v2). Read the file COPYING that comes with GRASS
@@ -28,7 +32,6 @@
#include <grass/glocale.h>
#include "varseg.h"
int main(int argc, char *argv[])
char *in_g; /* input, raster map to be segmented */
@@ -44,61 +47,49 @@
int iter; /* iteration index */
const char *mapset; /* current mapset */
void *g_row; /* input row buffer */
- void *out_u_row, *out_z_row; /* output row buffers */
+ void *out_u_row, *out_z_row;/* output row buffers */
int nr, nc, nrc; /* number of rows and colums */
int i, j; /* row and column indexes: i=colum=x, j=row=y */
int jnc; /* row sequential position, for pointers */
- int g_fd, out_u_fd, out_z_fd; /* file descriptors */
+ int g_fd, out_u_fd, out_z_fd;/* file descriptors */
int usek; /* use MSK (MS with the curvature term) */
double *g, *u, *z; /* the variables for the actual computation */
- struct Cell_head cellhd; /* GRASS region information */
struct History history; /* for map history */
struct GModule *module; /* GRASS module for parsing */
- struct
+ struct {
struct Option *in_g, *out_z, *out_u; /* parameters */
} parm;
- struct
- struct Option *lambda, *kepsilon, *alpha, *beta, *tol, *max_iter; /* other parameters */
+ struct {
+ struct Option *lambda, *kepsilon, *alpha, *beta, *tol, *max_iter; /* other parameters */
} opts;
struct Flag *flag_k; /* flag, k = use MSK instead of MS */
- RASTER_MAP_TYPE dcell_data_type; /* GRASS raster data type (for DCELL raster) */
+ RASTER_MAP_TYPE dcell_data_type;/* GRASS raster data type (for DCELL raster) */
- /* initialize GRASS environment */
G_gisinit(argv[0]);
/* initialize module */
module = G_define_module();
- G_add_keyword(_("image segmentation"));
+ G_add_keyword(_("imagery"));
+ G_add_keyword(_("segmentation"));
G_add_keyword(_("edge detection"));
- G_add_keyword(_("smooth"));
+ G_add_keyword(_("smoothing"));
module->description =
- _("Generates a smooth approximation of the input raster and a discontinuity map");
+ _("Generates a piece-wise smooth approximation of the input raster and a discontinuity map.");
- parm.in_g = G_define_option();
+ parm.in_g = G_define_standard_option(G_OPT_R_INPUTS);
parm.in_g->key = "in_g";
- parm.in_g->type = TYPE_STRING;
- parm.in_g->required = YES;
parm.in_g->description = _("Input raster map to segment");
- parm.in_g->gisprompt = "old,cell,raster";
- parm.out_u = G_define_option();
+ parm.out_u = G_define_standard_option(G_OPT_R_OUTPUT);
parm.out_u->key = "out_u";
- parm.out_u->type = TYPE_STRING;
- parm.out_u->required = YES;
parm.out_u->description = _("Output segmented raster map");
- parm.out_u->gisprompt = "new,cell,raster";
- parm.out_z = G_define_option();
+ parm.out_z = G_define_standard_option(G_OPT_R_OUTPUT);
parm.out_z->key = "out_z";
- parm.out_z->type = TYPE_STRING;
- parm.out_z->required = YES;
parm.out_z->description =
_("Output raster map with detected discontinuities");
- parm.out_z->gisprompt = "new,cell,raster";
opts.lambda = G_define_option();
opts.lambda->key = "lambda";
@@ -106,6 +97,7 @@
opts.lambda->required = NO;
opts.lambda->answer = "1.0";
opts.lambda->description = _("Smoothness coefficient [>0]");
+ opts.lambda->guisection = _("Settings");
opts.alpha = G_define_option();
opts.alpha->key = "alpha";
@@ -113,6 +105,7 @@
opts.alpha->required = NO;
opts.alpha->answer = "1.0";
opts.alpha->description = _("Discontinuity coefficient [>0]");
+ opts.alpha->guisection = _("Settings");
opts.max_iter = G_define_option();
opts.max_iter->key = "mxi";
@@ -120,6 +113,7 @@
opts.max_iter->required = NO;
opts.max_iter->answer = "100";
opts.max_iter->description = _("Maximal number of numerical iterations");
+ opts.max_iter->guisection = _("Settings");
opts.tol = G_define_option();
opts.tol->key = "tol";
@@ -127,6 +121,7 @@
opts.tol->required = NO;
opts.tol->answer = "0.001";
opts.tol->description = _("Convergence tolerance [>0]");
+ opts.tol->guisection = _("Settings");
opts.kepsilon = G_define_option();
opts.kepsilon->key = "kepsilon";
@@ -134,6 +129,7 @@
opts.kepsilon->required = NO;
opts.kepsilon->answer = "1.0";
opts.kepsilon->description = _("Discontinuity thickness [>0]");
+ opts.kepsilon->guisection = _("Settings");
opts.beta = G_define_option();
opts.beta->key = "beta";
@@ -141,6 +137,7 @@
opts.beta->required = NO;
opts.beta->answer = "0.0";
opts.beta->description = _("Curvature coefficient [>=0]");
+ opts.beta->guisection = _("Settings");
* beta = 0 leads to MS
* beta > 0 leads to MSK
@@ -149,12 +146,13 @@
* have to be set independently from the values used in MS
flag_k = G_define_flag();
flag_k->key = 'k';
flag_k->description =
_("Activate MSK model (Mumford-Shah with curvature term)");
+ flag_k->guisection = _("Settings");
/* parameters and flags parser */
if (G_parser(argc, argv))
exit(EXIT_FAILURE);
@@ -173,24 +171,27 @@
if (((usek = (flag_k->answer) == 0) && (beta != 0.0)))
G_warning(_("Beta is not zero and you have not activated the MSK formulation: \n \
- beta will be ignored and MS (default) will be used."));
+ beta will be ignored and MS (default) will be used."));
if (((usek = (flag_k->answer) == 1) && (beta == 0.0)))
G_warning(_("You have activated the MSK formulation, but beta is zero:\n \
- beta should be greater than zero in MSK."));
+ beta should be greater than zero in MSK."));
/* check existence and names of raster maps */
mapset = G_find_raster2(in_g, "");
- if (!mapset)
- G_fatal_error(_("raster file [%s] not found"), in_g);
+ if (mapset == NULL)
+ G_fatal_error(_("Raster map <%s> not found"), in_g);
+ /* still needed in GRASS 7?
if (G_legal_filename(out_u) < 0)
G_fatal_error(_("[%s] is an illegal file name"), out_u);
- G_check_input_output_name(in_g, out_u, G_FATAL_EXIT);
+ G_check_input_output_name(in_g, out_u, G_FATAL_EXIT);
if (G_legal_filename(out_z) < 0)
G_fatal_error(_("[%s] is an illegal file name"), out_z);
- G_check_input_output_name(in_g, out_z, G_FATAL_EXIT);
+ G_check_input_output_name(in_g, out_z, G_FATAL_EXIT);
if (strcmp(out_u, out_z) == 0)
G_fatal_error(_("Output raster maps have the same name [%s]"), out_u);
@@ -216,9 +217,7 @@
/* open the input raster map for reading */
- if ((g_fd = Rast_open_old(in_g, mapset)) < 0)
- G_fatal_error(_("cannot open raster file [%s]"), in_g);
- Rast_get_cellhd(in_g, mapset, &cellhd);
+ g_fd = Rast_open_old(in_g, mapset);
/* allocate the buffer for storing the values of the input raster map */
@@ -270,14 +269,11 @@
/* print the total number of iteration performed */
- G_message("\nr.seg iterations: %i\n", iter);
- G_message("\n");
+ G_message("Total number of iterations: %i", iter);
/* open the output raster maps for writing */
- if ((out_u_fd = Rast_open_new(out_u, dcell_data_type)) < 0)
- G_fatal_error(_("cannot open raster file [%s]"), out_u);
- if ((out_z_fd = Rast_open_new(out_z, dcell_data_type)) < 0)
- G_fatal_error(_("cannot open raster file [%s]"), out_z);
+ out_u_fd = Rast_open_new(out_u, dcell_data_type);
+ out_z_fd = Rast_open_new(out_z, dcell_data_type);
/* allocate the buffer for storing the values of the output raster maps */
@@ -306,15 +302,14 @@
G_free(u);
G_free(z);
- /* write history file */
+ /* write map history (meta data) */
Rast_short_history(out_u, "raster", &history);
+ Rast_set_history(&history, HIST_DATSRC_1, in_g);
+ Rast_append_format_history(&history, "iterations = %i", iter);
Rast_command_history(&history);
- Rast_append_format_history(&history, "\nIterations = %i", iter);
Rast_write_history(out_u, &history);
Rast_write_history(out_z, &history);
/* exit */
exit(EXIT_SUCCESS);
