[GRASS-SVN] r65480 - grass-addons/grass7/raster/r.seg
svn_grass at osgeo.org
Tue Jun 16 02:42:55 PDT 2015
Author: avitti
Date: 2015-06-16 02:42:55 -0700 (Tue, 16 Jun 2015)
New Revision: 65480
Removed:
grass-addons/grass7/raster/r.seg/r.seg.html
Deleted 'r.seg.html' [before module rename].
Deleted: grass-addons/grass7/raster/r.seg/r.seg.html
--- grass-addons/grass7/raster/r.seg/r.seg.html 2015-06-16 09:41:27 UTC (rev 65479)
+++ grass-addons/grass7/raster/r.seg/r.seg.html 2015-06-16 09:42:55 UTC (rev 65480)
@@ -1,168 +0,0 @@
-<h2>DESCRIPTION</h2>
-<em><b>r.smooth.seg</b></em> generates a piece-wise smooth approximation of the
-input raster map and a raster map of the discontinuities of the output
-approximation. <br>
-The discontinuities of the output approximation are preserved from being
-smoothed. The values of the discontinuity map are close to one where the
-output approximation is "homogeneous", where the output approximation
-has discontinuities (edges) the values are close to zero. <br>
-The module makes use of the <em>varseg</em> library which implements
-the Mumford-Shah [1] variational model for image segmentation. The
-Mumford-Shah variational model with curvature term [2] is also implemented
-in the library. The curvature term prevents the discontinuities from being
-shortened too much when the parameter alpha is set to very high values,
-(this happens very rarely). <br>
-An overview of the underlying theory with some applications cab be found in
-<a href="http://dx.doi.org/10.1016/j.isprsjprs.2012.02.005">[3]</a>.<br>
-Other examples of use of the module can be found
-<a href="http://www.ing.unitn.it/~vittia/sw/sw_index.html">here</a>
-and in
-<a href="http://download.osgeo.org/osgeo/foss4g/2009/SPREP/2Thu/Parkside%20GO4/1500/Thu%20G04%201545%20Zatelli.pdf"
->this presentation [FOSS4G 2009 - pdf]</a>. <br>
-For details on the numerical implementation see [4].
-<h2>NOTES</h2>
-Remove any MASK before the execution of the module.
-<br><br>
-Replace any NULL data (using <em>r.null</em>) with the map average value (get it with <em>r.univar</em>).
-<br><br>
-The segmentation depends on the parameters alpha and lambda:
-<ul>
-<li> alpha controls how many discontinuities are allowed to exist.
-<li> lambda controls the smoothness of the solution.
-<li> It is not possible to select the values of the parameters in an
- automatic way. Test some different values to understand their
- influence on the results.<br>
- Try the following procedure:
-<ul>
- <li> run the module with both alpha and lambda set to 1.0
- <li> run the module with alpha set to 1.0 and different values for lambda<br>
- e.g., 0.01, 0.1, 1, 10, 100
- <li> run the module with lambda set to 1.0 and different values for alpha<br>
- <li> see how the segmentations change and select the values that
- produce the result that best fits your requirements.
-</ul>
-</ul>
-The module computes the segmentation by means of an iterative
-procedure.<br>
-The module stops either when the number of iterations reaches the maximum
-number of iterations [mxi] or when the maximum difference between the solutions
-of two successive iterations is less than the convergence tolerance [tol].<br>
-To stop the iteration procedure, it is easier to act on the maximum number of
-iterations parameter [mxi] than on the convergence tolerance parameter [tol].<br>
-The number of iterations needed to reach the convergence tolerance increases
-for high values of the parameter lambda. The larger the total number of pixels
-of the input raster map the larger the number of iterations will be.<br>
-<br>
-The data type of the output raster maps is DOUBLE PRECISION. <br><br>
-The module works on one raster map at a time, imagery groups are not
-supported. <br><br>
-To avoid to inappropriately re-sampled the input raster map, the settings
-for the current region should be set so that:
-<ul>
-<li> the resolution of the region matches the resolution of the input raster map;
-<li> the boundaries of the region are lined up along the edges of the nearest
- cells in the input raster map.
-</ul>
-The discontinuity thickness should be changed for test purposes only.<br>
-<br>
-The actual need to use the MSK model should be very rare, see [4].
-Due to a different implementation of the MSK model with respect to MS
-one, the values of the parameters lambda and alpha in MSK have to be
-set independently from the values used in MS.
-<h2>EXAMPLE</h2>
-This example is based the <a
-href="http://grass.OSGeo.org/download/data.php">North Carolina GRASS sample
-data set</a>, [complete GRASS location].
-<div><pre class="code">
-# set the region to match the <em>ortho_2001_t792_1m</em> raster map:
-g.region rast=ortho_2001_t792_1m
-# select a smaller region:
-g.region n=221725 s=220225 w=638350 e=639550
-# run r.smooth.seg:
-r.smooth.seg in_g=ortho_2001_t792_1m at PERMANENT out_u=u_OF out_z=z_OF lambda=10 alpha=200 mxi=250
-# for a better visualization of the output raster map <em>u_OF</em>, set its color table to:
-r.colors u_OF rast=ortho_2001_t792_1m
-# compute the difference between the input raster map and the output raster map <em>u_OF</em>:
-r.mapcalc "diff = abs(ortho_2001_t792_1m at PERMANENT - u_OF)"
-# for a better visualization of the differences, compute the natural logarithm of the <em>diff</em> map:
-r.mapcalc "log_diff = log(1 + diff)"
-# and set its color table to the "differences" style:
-r.colors log_diff color=differences
-r.colors z_OF color=bgyr
-# run r.smooth.seg with different parameter values:
-r.smooth.seg in_g=ortho_2001_t792_1m at PERMANENT out_u=u1_OF out_z=z1_OF lambda=10 alpha=65 mxi=250
-r.smooth.seg in_g=ortho_2001_t792_1m at PERMANENT out_u=u2_OF out_z=z2_OF lambda=10 alpha=600 mxi=250
-r.smooth.seg in_g=ortho_2001_t792_1m at PERMANENT out_u=u3_OF out_z=z3_OF lambda=0.1 alpha=200 mxi=250
-r.smooth.seg in_g=ortho_2001_t792_1m at PERMANENT out_u=u4_OF out_z=z4_OF lambda=1 alpha=200 mxi=250
-# visualize and compare the different results
-</pre></div>
-<h2>REFERENCES</h2>
-<ul>
-<li> <b>[1]</b> D. Mumford and J. Shah. <em>Optimal Approximation by
-Piecewise Smooth Functions and Associated Variational Problems</em>. <br>
-Communications on Pure Applied Mathematics, 42(5):577-685, 1989.<br>
-DOI: 10.1002/cpa.3160420503
-<li> <b>[2]</b> R. March and M. Dozio. <em>A variational method for the
-recovery of smooth boundaries</em>. <br> Image and Vision Computing,
-15(9):705-712, 1997.<br>
-DOI: 10.1016/S0262-8856(97)00002-4
-<li> <b>[3]</b> A. Vitti. <em>The Mumford-Shah variational model
-for image segmentation: An overview of the theory, implementation and use</em>. <br>
-ISPRS Journal of Photogrammetry and Remote Sensing, 69:50-64, 2012.<br>
-DOI: 10.1016/j.isprsjprs.2012.02.005
-<li> <b>[4]</b> A. Vitti. <em>Free discontinuity
-problems in image and signal segmentatiion</em>. <br>
-Ph.D. Thesis - University of Trento (Italy), 2008. <br> <a
-href="http://www.ing.unitn.it/~vittia/misc/vitti_phd.pdf">http://www.ing.unitn.it/~vittia/misc/vitti_phd.pdf</a>
-</ul>
-<h2>SEE ALSO</h2>
-<em><a href="r.clump.html">r.clump</a></em>,
-<em><a href="i.smap.html">i.smap</a></em>,
-<em><a href="i.zc.html">i.zc</a></em>,
-<em><a href="r.mfilter.html">r.mfilter</a></em>
-<h2>AUTHOR</h2>
-Alfonso Vitti <br>
- Dept. Civil, Environmental and Mechanical Engineering <br>
- University of Trento - Italy<br>
- alfonso.vitti [at] unitn.it
-<p><i>Last changed: $Date: 2015-06-16 12:00:00 +0200 (Tue, 16 Jun 2015)$</i>
