[GRASS-SVN] r65506 - in grass/trunk/gui/wxpython: iclass iscatt
svn_grass at osgeo.org
Sat Jun 20 14:42:54 PDT 2015
Author: annakrat
Date: 2015-06-20 14:42:54 -0700 (Sat, 20 Jun 2015)
New Revision: 65506
grass/trunk/gui/wxpython/iclass/frame.py
grass/trunk/gui/wxpython/iscatt/controllers.py
grass/trunk/gui/wxpython/iscatt/core_c.py
grass/trunk/gui/wxpython/iscatt/iscatt_core.py
wxGUI/iclass: fix basic functionality for Windows
Modified: grass/trunk/gui/wxpython/iclass/frame.py
--- grass/trunk/gui/wxpython/iclass/frame.py 2015-06-20 12:01:04 UTC (rev 65505)
+++ grass/trunk/gui/wxpython/iclass/frame.py 2015-06-20 21:42:54 UTC (rev 65506)
@@ -676,7 +676,7 @@
layer = 1,
columns = ','.join(columns),
read = True)
- records = ret.strip().split('\n')
+ records = ret.strip().splitlines()
for record in records:
record = record.split('|')
listCtrl.AddCategory(cat = int(record[0]), name = record[1], color = record[2])
@@ -745,8 +745,8 @@
except KeyError:
wx.EndBusyCursor()
return False
- dbFile = tempfile.NamedTemporaryFile(mode = 'w')
+ dbFile = tempfile.NamedTemporaryFile(mode='w', delete=False)
if dbInfo['driver'] != 'dbf':
dbFile.write("BEGIN\n")
# populate table
@@ -768,15 +768,15 @@
dbFile.write("COMMIT\n")
- dbFile.file.flush()
- if 0 != RunCommand('db.execute', input=dbFile.name, driver=dbInfo['driver'], database=dbInfo['database']):
- wx.EndBusyCursor()
- return False
+ dbFile.file.close()
+ ret = RunCommand('db.execute', input=dbFile.name, driver=dbInfo['driver'], database=dbInfo['database'])
wx.EndBusyCursor()
+ os.remove(dbFile.name)
+ if ret != 0:
+ return False
return True
def _runDBUpdate(self, tmpFile, table, column, value, cat):
"""Helper function for UPDATE statement
@@ -1121,8 +1121,8 @@
flags = 'g',
group = group,
read = True, **kwargs).strip()
- if res.split('\n')[0]:
- return sorted(res.split('\n'))
+ if res.splitlines()[0]:
+ return sorted(res.splitlines())
return []
Modified: grass/trunk/gui/wxpython/iscatt/controllers.py
--- grass/trunk/gui/wxpython/iscatt/controllers.py 2015-06-20 12:01:04 UTC (rev 65505)
+++ grass/trunk/gui/wxpython/iscatt/controllers.py 2015-06-20 21:42:54 UTC (rev 65506)
@@ -1106,6 +1106,6 @@
group = group,
- bands = res.split('\n')
+ bands = res.splitlines()
self.scatt_mgr.SetBands(bands)
Modified: grass/trunk/gui/wxpython/iscatt/core_c.py
--- grass/trunk/gui/wxpython/iscatt/core_c.py 2015-06-20 12:01:04 UTC (rev 65505)
+++ grass/trunk/gui/wxpython/iscatt/core_c.py 2015-06-20 21:42:54 UTC (rev 65506)
@@ -155,7 +155,7 @@
'ewres' : 'ew_res'}
for k, v in region.iteritems():
- if k in ["rows", "cols", "cells"]:
+ if k in ["rows", "cols", "cells", "zone"]: # zone added in r65224
v = int(v)
else:
v = float(v)
Modified: grass/trunk/gui/wxpython/iscatt/iscatt_core.py
--- grass/trunk/gui/wxpython/iscatt/iscatt_core.py 2015-06-20 12:01:04 UTC (rev 65505)
+++ grass/trunk/gui/wxpython/iscatt/iscatt_core.py 2015-06-20 21:42:54 UTC (rev 65506)
@@ -831,7 +831,7 @@
if ret != 0:
raise GException("r.info failed:\n%s" % msg)
- out = out.split("\n")
+ out = out.splitlines()
raster_info = {}
for b in out:
