[GRASS-SVN] r65510 - grass-addons/grass7/vector/v.nnstat
svn_grass at osgeo.org
Mon Jun 22 01:00:18 PDT 2015
Author: evas
Date: 2015-06-22 01:00:18 -0700 (Mon, 22 Jun 2015)
New Revision: 65510
Removed:
grass-addons/grass7/vector/v.nnstat/getval.cpp
grass-addons/grass7/vector/v.nnstat/main.cpp
grass-addons/grass7/vector/v.nnstat/mbb.cpp
grass-addons/grass7/vector/v.nnstat/mbr.cpp
grass-addons/grass7/vector/v.nnstat/nearest_neighbour.cpp
grass-addons/grass7/vector/v.nnstat/utils.cpp
v.nnstat: deleted *.cpp files
Deleted: grass-addons/grass7/vector/v.nnstat/getval.cpp
--- grass-addons/grass7/vector/v.nnstat/getval.cpp 2015-06-22 02:47:05 UTC (rev 65509)
+++ grass-addons/grass7/vector/v.nnstat/getval.cpp 2015-06-22 08:00:18 UTC (rev 65510)
@@ -1,145 +0,0 @@
-#include "local_proto.h"
-extern "C" {
- /* get array of values from attribute column (function based on part of v.buffer2 (Radim Blazek, Rosen Matev)) */
- double *get_col_values(struct Map_info *map, int field, const char *column)
- int i, nrec, ctype;
- struct field_info *Fi;
- dbCatValArray cvarr;
- dbDriver *Driver;
- double *values, *vals;
- db_CatValArray_init(&cvarr); /* array of categories and values initialised */
- Fi = Vect_get_field(map, field); /* info about call of DB */
- if (Fi == NULL)
- G_fatal_error(_("Database connection not defined for layer %d"),
- field);
- Driver = db_start_driver_open_database(Fi->driver, Fi->database); /* started connection to DB */
- if (Driver == NULL)
- G_fatal_error(_("Unable to open database <%s> by driver <%s>"),
- Fi->database, Fi->driver);
- /* Note do not check if the column exists in the table because it may be expression */
- /* TODO: only select values we need instead of all in column */
- /* Select pairs key/value to array, values are sorted by key (must be integer) */
- nrec =
- db_select_CatValArray(Driver, Fi->table, Fi->key, column, NULL,
- &cvarr);
- if (nrec < 0)
- G_fatal_error(_("Unable to select data from table <%s>"), Fi->table);
- G_message(_("Reading elevations from attribute table: %d records selected"), nrec);
- ctype = cvarr.ctype;
- db_close_database_shutdown_driver(Driver);
- values = (double *) G_malloc(cvarr.n_values * sizeof(double));
- vals = &values[0];
- for (i = 0; i < cvarr.n_values; i++) {
- if (ctype == DB_C_TYPE_INT) {
- *vals = (double) cvarr.value[i].val.i;
- if (ctype == DB_C_TYPE_DOUBLE) {
- *vals = cvarr.value[i].val.d;
- if (ctype == DB_C_TYPE_STRING) {
- G_fatal_error(_("The column must be numeric..."));
- vals++;
- return values;
-/* get coordinates of input points */
- void read_points(struct Map_info *map, int field, struct nna_par *xD,
- const char *zcol, struct points *point)
- int ctrl, n, type, nskipped, pass;
- struct line_pnts *Points; /* structures to hold line *Points (map) */
- double *rx, *ry, *rz;
- double *z_attr, *z;
- Points = Vect_new_line_struct();
- n = point->n = Vect_get_num_primitives(map, GV_POINT); /* topology required */
- point->r = (double *) G_malloc(n*3 * sizeof(double));
- rx = &point->r[0];
- ry = &point->r[1];
- rz = &point->r[2];
- /* Get 3rd coordinate of 2D points from attribute column -> 3D interpolation */
- if (xD->v3 == FALSE && zcol != NULL) {
- xD->zcol = (char *) G_malloc(strlen(zcol) * sizeof(char));
- strcpy(xD->zcol, zcol);
- z_attr = get_col_values(map, field, zcol);
- z = &z_attr[0];
- else {
- xD->zcol = NULL;
- nskipped = ctrl = pass = 0;
- while (TRUE) {
- type = Vect_read_next_line(map, Points, NULL);
- if (type == -1)
- G_fatal_error(_("Unable to read vector map"));
- if (type == -2)
- break;
- if (type != GV_POINT) {
- nskipped++;
- continue;
- *rx = Points->x[0];
- *ry = Points->y[0];
- // 3D points or 2D points without attribute column -> 2D interpolation
- if (xD->zcol == NULL) {
- if (xD->v3 == TRUE && xD->i3 == FALSE) {
- *rz = 0.;
- else {
- *rz = Points->z[0];
- else {
- *rz = *z;
- z++;
- /* Find extends */
- if (ctrl == 0) {
- point->r_min = point->r_max = triple(*rx, *ry, *rz);
- else {
- point->r_min = triple(MIN(*point->r_min, *rx), MIN(*(point->r_min+1), *ry), MIN(*(point->r_min+2), *rz));
- point->r_max = triple(MAX(*point->r_max, *rx), MAX(*(point->r_max+1), *ry), MAX(*(point->r_max+2), *rz));
- if (ctrl < point->n - 1) {
- rx += 3;
- ry += 3;
- rz += 3;
- ctrl++;
- if (nskipped > 0)
- G_warning(_("%d features skipped, only points are accepted"),
- nskipped);
- Vect_destroy_line_struct(Points);
- if (ctrl <= 0)
- G_fatal_error(_("Unable to read coordinates of point layer"));
-} // end extern "C"
Deleted: grass-addons/grass7/vector/v.nnstat/main.cpp
--- grass-addons/grass7/vector/v.nnstat/main.cpp 2015-06-22 02:47:05 UTC (rev 65509)
+++ grass-addons/grass7/vector/v.nnstat/main.cpp 2015-06-22 08:00:18 UTC (rev 65510)
@@ -1,120 +0,0 @@
- * MODULE: v.nnstat
- * AUTHOR(S): Eva Stopková
- * functions in files mbr.cpp and mbb.cpp are mostly taken
- * from the module
- * v.hull (Aime, A., Neteler, M., Ducke, B., Landa, M.)
- * PURPOSE: Module indicates clusters, separations or random distribution of point set in 2D or 3D space.
- * COPYRIGHT: (C) 2013-2014 by Eva Stopková and the GRASS Development Team
- * This program is free software under the
- * GNU General Public License (>=v2).
- * Read the file COPYING that comes with GRASS
- * for details.
-extern "C" {
- int main(int argc, char *argv[])
- /* Vector layer and module */
- struct Map_info map; // input vector map
- struct GModule *module;
- struct nna_par xD; // 2D or 3D NNA to be performed
- struct points pnts; // points: coordinates, number etc.
- struct nearest nna; // structure to save results
- int field, pass;
- struct {
- struct Option *map, *A, *type, *field, *lyr, *desc, *zcol; /* A - area (minimum enclosing rectangle or specified by user) */
- } opt;
- struct {
- struct Flag *d23;
- } flg;
- /* Module creation */
- module = G_define_module();
- G_add_keyword(_("vector"));
- G_add_keyword(_("nearest neighbour analysis"));
- module->description = _("Indicates clusters, separations or random distribution of point set in 2D or 3D space.");
- /* Setting options */
- opt.map = G_define_standard_option(G_OPT_V_INPUT); /* vector input layer */
- flg.d23 = G_define_flag(); /* to process 2D or 3D Nearest Neighbour Analysis */
- flg.d23->key = '2';
- flg.d23->description =
- _("Force 2D NNA even if input is 3D");
- opt.A = G_define_option();
- opt.A->key = "area";
- opt.A->type = TYPE_DOUBLE;
- opt.A->description = _("2D: Area. If not specified, area of Minimum Enclosing Rectangle will be used.\n3D: Volume. If not specified, volume of Minimum Enclosing Box will be used.");
- opt.A->required = NO;
- opt.field = G_define_standard_option(G_OPT_V_FIELD);
- opt.zcol = G_define_standard_option(G_OPT_DB_COLUMN);
- opt.zcol->key = "zcolumn";
- opt.zcol->required = NO;
- opt.zcol->guisection = _("Fields");
- opt.zcol->description = _("Column with z coordinate (set for 2D vectors only if 3D NNA is required to be performed)");
- G_gisinit(argv[0]);
- if (G_parser(argc, argv))
- exit(EXIT_FAILURE);
- /* get parameters from the parser */
- field = opt.field->answer ? atoi(opt.field->answer) : -1;
- /* open input vector map */
- Vect_set_open_level(2);
- if (0 > Vect_open_old2(&map, opt.map->answer, "", opt.field->answer))
- G_fatal_error(_("Unable to open vector map <%s>"), opt.map->answer);
- Vect_set_error_handler_io(&map, NULL);
- /* perform 2D or 3D NNA ? */
- xD.v3 = Vect_is_3d(&map); // test if vector layer is 2D or 3D
- xD.i3 = (flg.d23->answer || (xD.v3 == FALSE && opt.zcol->answer == NULL)) ? FALSE : TRUE; // if -2 flag or input layer is 2D (without zcolumn), perform 2D NNA, otherwise 3D
- /* Fatal error */
- /*if (xD.i3 == TRUE) { // if 3D NNA is to be performed...
- if (xD.v3 == FALSE && opt.zcol->answer == NULL) { // ... and column with elevations for 2D input is missing
- G_fatal_error(_("To process 3D Nearest Neighbour Analysis based on 2D input, "
- "please set attribute column containing z coordinates "
- "or switch to 2D NNA."));
- /* Warnings */
- if (flg.d23->answer && opt.zcol->answer) { // -2 flag (2D) vs. zcolumn (3D)
- G_warning(_("Flag -2 has higher priority than zcolumn considered in 2D layer. 2D Nearest Neighbour Analysis will be performed instead of 3D. If you wish to perform 3D Nearest Neighbour Analysis, please remove flag -2."));
- if (xD.v3 == TRUE && opt.zcol->answer) {
- G_warning(_("Input layer <%s> is 3D - it was not necessary to set up attribute column. 3D Nearest Neighbour Analysis is being performed..."), opt.map->answer);
- read_points(&map, field, &xD, opt.zcol->answer, &pnts);
- /* Nearest Neighbour Analysis */
- pass = nn_average_distance_real(&pnts, &nna); // Average distance (AD) between NN in pointset
- density(&pnts, &xD, opt.A->answer, &nna); // Number of points per area/volume unit
- nn_average_distance_expected(&xD, &nna); // Expected AD of NN in a randomly distributed pointset
- nna.R = nna.rA / nna.rE; // Ratio of real and expected AD
- nn_statistics(&pnts, &xD, &nna); // Student's t-test of significance of the mean
- Vect_close(&map);
- exit(EXIT_SUCCESS);
Deleted: grass-addons/grass7/vector/v.nnstat/mbb.cpp
--- grass-addons/grass7/vector/v.nnstat/mbb.cpp 2015-06-22 02:47:05 UTC (rev 65509)
+++ grass-addons/grass7/vector/v.nnstat/mbb.cpp 2015-06-22 08:00:18 UTC (rev 65510)
@@ -1,750 +0,0 @@
-#include "macros.h"
-#include "mbb.h"
-These functions are mostly taken from the module v.hull (Aime, A., Neteler, M., Ducke, B., Landa, M.)
-Minimum Bounding Block (MBB)
- - obtain vertices of 3D convex hull,
- - transform coordinates of vertices into coordinate system with axes parallel to hull's edges,
- - find extents,
- - compute volumes and find minimum of them.
-extern "C" {
- /* Release all memory allocated for edges, faces and vertices */
- void freeMem(void)
- tEdge e; /* Primary index into edge list. */
- tFace f; /* Primary pointer into face list. */
- tVertex v;
- tEdge te; /* Temporary edge pointer. */
- tFace tf; /* Temporary face pointer. */
- tVertex tv; /* Temporary vertex pointer. */
- e = edges;
- do {
- te = e;
- e = e->next;
- DELETE(edges, te);
- } while (e != edges);
- f = faces;
- do {
- tf = f;
- f = f->next;
- DELETE(faces, tf);
- } while (f != faces);
- v = vertices;
- do {
- tv = v;
- v = v->next;
- DELETE(vertices, tv);
- } while (v != vertices);
- FREE(te);
- FREE(tf);
- FREE(tv);
- DELETE(edges, e);
- DELETE(faces, f);
- DELETE(vertices, v);
- FREE(edges);
- FREE(faces);
- FREE(vertices);
- int make3DHull(struct points *pnts, struct convex *hull)
- int error;
- ReadVertices(pnts);
- error = DoubleTriangle();
- if (error < 0) {
- G_fatal_error
- ("All points of 3D input map are in the same plane.\n Cannot create a 3D hull.");
- ConstructHull();
- write_coord_faces(pnts, hull);
- freeMem();
- return (0);
- MakeNullVertex: Makes a vertex, nulls out fields.
- tVertex MakeNullVertex(void)
- tVertex v;
- NEW(v, tsVertex); /* If memory not allocated => out of memory*/
- v->duplicate = NULL;
- v->onhull = !ONHULL;
- v->mark = !PROCESSED;
- ADD(vertices, v);
- return v;
- ReadVertices: Reads in the vertices, and links them into a circular
- list with MakeNullVertex. There is no need for the # of vertices to be
- the first line: the function looks for EOF instead. Sets the global
- variable vertices via the ADD macro.
- void ReadVertices(struct points *pnts)
- tVertex v;
- int vnum = 0;
- int i;
- double *r;
- r = &pnts->r[0];
- G_message(_("Reading 3D vertices..."));
- for (i = 0; i < pnts->n; i++) {
- v = MakeNullVertex();
- v->v[X] = *r;
- v->v[Y] = *(r+1);
- v->v[Z] = *(r+2);
- v->vnum = vnum++;
- r +=3;
- G_percent(i, (pnts->n - 1), 1);
- fflush(stdout);
- Outputs coordinates of 3D hull to matrix [n x 3]
- void write_coord_faces(struct points *pnts, struct convex *hull)
- int n = pnts->n;
- /* Pointers to vertices, edges, faces. */
- tVertex v;
- tFace f;
- int nv = 0, nf = 0;
- double *hc, *hf;
- hull->coord = (double *) malloc(n * 3 * sizeof(double));
- hull->faces = (double *) malloc(3*n * 3 * sizeof(double));
- hc = &hull->coord[0];
- hf = &hull->faces[0];
- v = vertices;
- f = faces;
- do {
- /* Write vertex coordinates */
- *hc = ((double)(v->v[X]));
- *(hc+1) = ((double)(v->v[Y]));
- *(hc+2) = ((double)(v->v[Z]));
- v = v->next;
- hc += 3;
- nv += 3;
- } while (v!=vertices);
- do {
- /* write one triangular face */
- *hf = ((double)(f->vertex[0]->v[X]));
- *(hf+1) = ((double)(f->vertex[0]->v[Y]));
- *(hf+2) = ((double)(f->vertex[0]->v[Z]));
- *(hf+3) = ((double)(f->vertex[1]->v[X]));
- *(hf+4) = ((double)(f->vertex[1]->v[Y]));
- *(hf+5) = ((double)(f->vertex[1]->v[Z]));
- *(hf+6) = ((double)(f->vertex[2]->v[X]));
- *(hf+7) = ((double)(f->vertex[2]->v[Y]));
- *(hf+8) = ((double)(f->vertex[2]->v[Z]));
- f = f->next;
- hf += 9;
- nf += 9;
- } while (f!=faces);
- /* reclaim uneeded memory */
- hull->n = nv;
- hull->n_faces = nf;
- hull->coord = (double *) G_realloc(hull->coord, nv*3 * sizeof(double));
- hull->faces = (double *) G_realloc(hull->faces, nf*3 * sizeof(double));
- fflush(stdout);
- DoubleTriangle builds the initial double triangle. It first finds 3
- noncollinear points and makes two faces out of them, in opposite order.
- It then finds a fourth point that is not coplanar with that face. The
- vertices are stored in the face structure in counterclockwise order so
- that the volume between the face and the point is negative. Lastly, the
- 3 newfaces to the fourth point are constructed and the data structures
- are cleaned up.
- /* RETURN: 0 if OK */
- /* -1 if all points collinear */
- /* -2 if all points coplanar */
- int DoubleTriangle(void)
- tVertex v0, v1, v2, v3;
- tFace f0, f1 = NULL;
- long int vol;
- /* Find 3 noncollinear points. */
- v0 = vertices;
- while (Collinear(v0, v0->next, v0->next->next)) {
- if ((v0 = v0->next) == vertices) {
- G_warning("DoubleTriangle: All points are collinear!\n");
- return (-1);
- v1 = v0->next;
- v2 = v1->next;
- /* Mark the vertices as processed. */
- v0->mark = PROCESSED;
- v1->mark = PROCESSED;
- v2->mark = PROCESSED;
- /* Create the two "twin" faces. */
- f0 = MakeFace(v0, v1, v2, f1);
- f1 = MakeFace(v2, v1, v0, f0);
- /* Link adjacent face fields. */
- f0->edge[0]->adjface[1] = f1;
- f0->edge[1]->adjface[1] = f1;
- f0->edge[2]->adjface[1] = f1;
- f1->edge[0]->adjface[1] = f0;
- f1->edge[1]->adjface[1] = f0;
- f1->edge[2]->adjface[1] = f0;
- /* Find a fourth, noncoplanar point to form tetrahedron. */
- v3 = v2->next;
- vol = VolumeSign(f0, v3);
- while (!vol) {
- if ((v3 = v3->next) == v0) {
- G_warning("DoubleTriangle: All points are coplanar!\n");
- return (-2);
- /* Insure that v3 will be the first added. */
- vertices = v3;
- return (0);
- ConstructHull adds the vertices to the hull one at a time. The hull
- vertices are those in the list marked as onhull.
- int ConstructHull(void)
- tVertex v, vnext;
- bool changed; /* T if addition changes hull; not used. */
- int i;
- int numVertices;
- G_message(_("Constructing 3D hull..."));
- v = vertices;
- i = 0;
- do {
- vnext = v->next;
- v = vnext;
- i++;
- numVertices = i;
- v = vertices;
- i = 0;
- do {
- vnext = v->next;
- if (!v->mark) {
- v->mark = PROCESSED;
- changed = AddOne(v);
- CleanUp();
- v = vnext;
- i++;
- G_percent(i, numVertices, 1);
- fflush(stdout);
- return numVertices;
- AddOne is passed a vertex. It first determines all faces visible from
- that point. If none are visible then the point is marked as not
- onhull. Next is a loop over edges. If both faces adjacent to an edge
- are visible, then the edge is marked for deletion. If just one of the
- adjacent faces is visible then a new face is constructed.
- bool AddOne(tVertex p)
- tFace f;
- tEdge e, temp;
- long int vol;
- bool vis = FALSE;
- /* Mark faces visible from p. */
- f = faces;
- do {
- vol = VolumeSign(f, p);
- if (vol < 0) {
- f->visible = VISIBLE;
- vis = TRUE;
- f = f->next;
- /* If no faces are visible from p, then p is inside the hull. */
- if (!vis) {
- p->onhull = !ONHULL;
- return FALSE;
- /* Mark edges in interior of visible region for deletion.
- Erect a newface based on each border edge. */
- e = edges;
- do {
- temp = e->next;
- if (e->adjface[0]->visible && e->adjface[1]->visible)
- /* e interior: mark for deletion. */
- e->del = REMOVED;
- else if (e->adjface[0]->visible || e->adjface[1]->visible)
- /* e border: make a new face. */
- e->newface = MakeConeFace(e, p);
- e = temp;
- return TRUE;
- VolumeSign returns the sign of the volume of the tetrahedron determined by f
- and p. VolumeSign is +1 iff p is on the negative side of f,
- where the positive side is determined by the rh-rule. So the volume
- is positive if the ccw normal to f points outside the tetrahedron.
- The final fewer-multiplications form is due to Bob Williamson.
- int VolumeSign(tFace f, tVertex p)
- double vol;
- double ax, ay, az, bx, by, bz, cx, cy, cz;
- ax = f->vertex[0]->v[X] - p->v[X];
- ay = f->vertex[0]->v[Y] - p->v[Y];
- az = f->vertex[0]->v[Z] - p->v[Z];
- bx = f->vertex[1]->v[X] - p->v[X];
- by = f->vertex[1]->v[Y] - p->v[Y];
- bz = f->vertex[1]->v[Z] - p->v[Z];
- cx = f->vertex[2]->v[X] - p->v[X];
- cy = f->vertex[2]->v[Y] - p->v[Y];
- cz = f->vertex[2]->v[Z] - p->v[Z];
- vol = ax * (by * cz - bz * cy)
- + ay * (bz * cx - bx * cz)
- + az * (bx * cy - by * cx);
- /* The volume should be an integer. */
- if (vol > 0.0)
- return 1;
- else if (vol < -0.0)
- return -1;
- else
- return 0;
- MakeConeFace makes a new face and two new edges between the
- edge and the point that are passed to it. It returns a pointer to
- the new face.
- tFace MakeConeFace(tEdge e, tVertex p)
- tEdge new_edge[2];
- tFace new_face;
- int i, j;
- /* Make two new edges (if don't already exist). */
- for (i = 0; i < 2; ++i)
- /* If the edge exists, copy it into new_edge. */
- if (!(new_edge[i] = e->endpts[i]->duplicate)) {
- /* Otherwise (duplicate is NULL), MakeNullEdge. */
- new_edge[i] = MakeNullEdge();
- new_edge[i]->endpts[0] = e->endpts[i];
- new_edge[i]->endpts[1] = p;
- e->endpts[i]->duplicate = new_edge[i];
- /* Make the new face. */
- new_face = MakeNullFace();
- new_face->edge[0] = e;
- new_face->edge[1] = new_edge[0];
- new_face->edge[2] = new_edge[1];
- MakeCcw(new_face, e, p);
- /* Set the adjacent face pointers. */
- for (j = 0; j < 2; ++j)
- /* Only one NULL link should be set to new_face. */
- if (!new_edge[i]->adjface[j]) {
- new_edge[i]->adjface[j] = new_face;
- break;
- return new_face;
- MakeCcw puts the vertices in the face structure in counterclock wise
- order. We want to store the vertices in the same
- order as in the visible face. The third vertex is always p.
- void MakeCcw(tFace f, tEdge e, tVertex p)
- tFace fv; /* The visible face adjacent to e */
- int i; /* Index of e->endpoint[0] in fv. */
- tEdge s; /* Temporary, for swapping */
- if (e->adjface[0]->visible)
- fv = e->adjface[0];
- else
- fv = e->adjface[1];
- /* Set vertex[0] & [1] of f to have the same orientation
- as do the corresponding vertices of fv. */
- for (i = 0; fv->vertex[i] != e->endpts[0]; ++i) ;
- /* Orient f the same as fv. */
- if (fv->vertex[(i + 1) % 3] != e->endpts[1]) {
- f->vertex[0] = e->endpts[1];
- f->vertex[1] = e->endpts[0];
- else {
- f->vertex[0] = e->endpts[0];
- f->vertex[1] = e->endpts[1];
- SWAP(s, f->edge[1], f->edge[2]);
- /* This swap is tricky. e is edge[0]. edge[1] is based on endpt[0],
- edge[2] on endpt[1]. So if e is oriented "forwards," we
- need to move edge[1] to follow [0], because it precedes. */
- f->vertex[2] = p;
- MakeNullEdge creates a new cell and initializes all pointers to NULL
- and sets all flags to off. It returns a pointer to the empty cell.
- tEdge MakeNullEdge(void)
- tEdge e;
- NEW(e, tsEdge);
- e->adjface[0] = e->adjface[1] = e->newface = NULL;
- e->endpts[0] = e->endpts[1] = NULL;
- e->del = !REMOVED;
- ADD(edges, e);
- return e;
- MakeNullFace creates a new face structure and initializes all of its
- flags to NULL and sets all the flags to off. It returns a pointer
- to the empty cell.
- tFace MakeNullFace(void)
- tFace f;
- int i;
- NEW(f, tsFace);
- for (i = 0; i < 3; ++i) {
- f->edge[i] = NULL;
- f->vertex[i] = NULL;
- f->visible = !VISIBLE;
- ADD(faces, f);
- return f;
- MakeFace creates a new face structure from three vertices (in ccw
- order). It returns a pointer to the face.
- tFace MakeFace(tVertex v0, tVertex v1, tVertex v2, tFace fold)
- tFace f;
- tEdge e0, e1, e2;
- /* Create edges of the initial triangle. */
- if (!fold) {
- e0 = MakeNullEdge();
- e1 = MakeNullEdge();
- e2 = MakeNullEdge();
- else { /* Copy from fold, in reverse order. */
- e0 = fold->edge[2];
- e1 = fold->edge[1];
- e2 = fold->edge[0];
- e0->endpts[0] = v0;
- e0->endpts[1] = v1;
- e1->endpts[0] = v1;
- e1->endpts[1] = v2;
- e2->endpts[0] = v2;
- e2->endpts[1] = v0;
- /* Create face for triangle. */
- f = MakeNullFace();
- f->edge[0] = e0;
- f->edge[1] = e1;
- f->edge[2] = e2;
- f->vertex[0] = v0;
- f->vertex[1] = v1;
- f->vertex[2] = v2;
- /* Link edges to face. */
- e0->adjface[0] = e1->adjface[0] = e2->adjface[0] = f;
- return f;
- CleanUp goes through each data structure list and clears all
- flags and NULLs out some pointers. The order of processing
- (edges, faces, vertices) is important.
- void CleanUp(void)
- CleanEdges();
- CleanFaces();
- CleanVertices();
- CleanEdges runs through the edge list and cleans up the structure.
- If there is a newface then it will put that face in place of the
- visible face and NULL out newface. It also deletes so marked edges.
- void CleanEdges(void)
- tEdge t; /* Temporary edge pointer. */
- /* Integrate the newface's into the data structure. */
- /* Check every edge. */
- e = edges;
- do {
- if (e->newface) {
- e->adjface[0] = e->newface;
- else
- e->adjface[1] = e->newface;
- e->newface = NULL;
- e = e->next;
- /* Delete any edges marked for deletion. */
- while (edges && edges->del) {
- e = edges;
- DELETE(edges, e);
- e = edges->next;
- do {
- if (e->del) {
- t = e;
- e = e->next;
- DELETE(edges, t);
- else
- e = e->next;
- CleanFaces runs through the face list and deletes any face marked visible.
- void CleanFaces(void)
- tFace t; /* Temporary pointer, for deleting. */
- while (faces && faces->visible) {
- f = faces;
- DELETE(faces, f);
- f = faces->next;
- do {
- if (f->visible) {
- t = f;
- f = f->next;
- DELETE(faces, t);
- else
- f = f->next;
- CleanVertices runs through the vertex list and deletes the
- vertices that are marked as processed but are not incident to any
- undeleted edges.
- void CleanVertices(void)
- tEdge e;
- tVertex v, t;
- /* Mark all vertices incident to some undeleted edge as on the hull. */
- e = edges;
- do {
- e->endpts[0]->onhull = e->endpts[1]->onhull = ONHULL;
- e = e->next;
- /* Delete all vertices that have been processed but
- are not on the hull. */
- while (vertices && vertices->mark && !vertices->onhull) {
- v = vertices;
- v = vertices->next;
- do {
- if (v->mark && !v->onhull) {
- t = v;
- v = v->next;
- DELETE(vertices, t)
- else
- v = v->next;
- /* Reset flags. */
- v = vertices;
- do {
- v = v->next;
- Collinear checks to see if the three points given are collinear,
- by checking to see if each element of the cross product is zero.
- bool Collinear(tVertex a, tVertex b, tVertex c)
- return
- (c->v[Z] - a->v[Z]) * (b->v[Y] - a->v[Y]) -
- (b->v[Z] - a->v[Z]) * (c->v[Y] - a->v[Y]) == 0
- && (b->v[Z] - a->v[Z]) * (c->v[X] - a->v[X]) -
- (b->v[X] - a->v[X]) * (c->v[Z] - a->v[Z]) == 0
- && (b->v[X] - a->v[X]) * (c->v[Y] - a->v[Y]) -
- (b->v[Y] - a->v[Y]) * (c->v[X] - a->v[X]) == 0;
- void convexHull3d(struct points *pnts, struct convex *hull)
- int error;
- error = make3DHull(pnts, hull); /* make 3D hull */
- if (error < 0) {
- G_fatal_error(_("Simple planar hulls not implemented yet"));
-} // end of extern "C"
- * MBR area estimation
-double MBB(struct points *pnts)
- int i, k;
- double usx, usy, cosusx, sinusx, cosusy, sinusy, V, V_min;
- double *hc_k, *hf, *ht; // pointers to hull_trans and hull->faces
- double *r_min, *r_max;
- r_min = (double *) G_malloc(3 * sizeof(double));
- r_max = (double *) G_malloc(3 * sizeof(double));
- double *hull_trans; /* Coordinates of hull vertices transformed into coordinate system with axes parallel to hull's edges */
- hull_trans = (double *) malloc(3 * sizeof(double));
- ht = &hull_trans[0];
- struct convex hull;
- convexHull3d(pnts, &hull);
- hc_k = &hull.coord[0];
- hf = &hull.faces[0];
- V_min = (pnts->r_max[0] - pnts->r_min[0]) * (pnts->r_max[1] - pnts->r_min[1]) * (pnts->r_max[2] - pnts->r_min[2]); /* Volume of extent */
- for (i=0; i < hull.n_faces-2; i += 3) { /* n = number of vertices (n/3 = number of faces)*/
- /* Bearings of hull edges */
- usx = bearing(*(hull.faces+1), *(hull.faces+4), *(hull.faces+2), *(hull.faces+5));
- usy = bearing(*hull.faces, *(hull.faces+6), *(hull.faces+2), *(hull.faces+8));
- if (usx == -9999 || usy == -9999) /* Identical points */
- continue;
- cosusx = cos(usx);
- sinusx = sin(usx);
- cosusy = cos(usy);
- sinusy = sin(usy);
- hc_k = &hull.coord[0]; // original coords
- for (k=0; k < hull.n; k++) {
- /* Coordinate transformation */
- *ht = *hc_k * cos(usy) + 0 - *(hc_k+2) * sin(usy);
- *(ht+1) = *hc_k * sinusx * sinusy + *(hc_k+1) * cosusx + *(hc_k+2) * sinusx * cosusy;
- *(ht+2) = *hc_k * cosusx * sinusy - *(hc_k+1) * sinusx + *(hc_k+2) * cosusx * cosusy;
- /* Transformed extent */
- switch (k) {
- case 0: r_min = r_max = triple(*ht, *(ht+1), *(ht+2)); break;
- default:
- r_min = triple(MIN(*ht, *r_min), MIN(*(ht+1), *(r_min+1)), MIN(*(ht+2), *(r_min+2)));
- r_max = triple(MAX(*ht, *r_max), MAX(*(ht+1), *(r_max+1)), MAX(*(ht+2), *(r_max+2)));
- hc_k += 3;
- } // end k
- hf += 9;
- V = (*r_max - *r_min) * (*(r_max+1) - *(r_min+1)) * (*(r_max+2) - *(r_min+2)); /* Area of transformed extent */
- V_min = MIN(V, V_min);
- } // end i
- return V_min;
Deleted: grass-addons/grass7/vector/v.nnstat/mbr.cpp
--- grass-addons/grass7/vector/v.nnstat/mbr.cpp 2015-06-22 02:47:05 UTC (rev 65509)
+++ grass-addons/grass7/vector/v.nnstat/mbr.cpp 2015-06-22 08:00:18 UTC (rev 65510)
@@ -1,208 +0,0 @@
-#define PI M_PI
-Minimum Bounding Rectangle (MBR)
- - obtain vertices of convex hull,
- - find extents,
- - compute areas and find minimum of them.
- * Obtain convex hull vertices: functions from hull.c (Andrea Aime)
- * Theoretical background: Andrew's variant of Graham Scan
- * Source: Mark Nelson, 2007: http://marknelson.us/2007/08/22/convex/
-/* Function to determine whether a point is above or below the line
- * connecting the leftmost and the rightmost points */
-extern "C" {
- int rightTurn(double (*P)[3], int i, int j, int k)
- double a, b, c, d;
- /* Coordinate translation: P[j] = 0.0 */
- a = P[i][0] - P[j][0];
- b = P[i][1] - P[j][1];
- c = P[k][0] - P[j][0];
- d = P[k][1] - P[j][1];
- /* Determinant of P[i] and P[k] */
- return a * d - b * c < 0; /* Returns |det| < 0 => P[k] is angled off in left direction */
- /* Function to compare two points (for sorting points in convexHull) */
- int cmpPoints(const void *v1, const void *v2)
- double *p1, *p2;
- p1 = (double *)v1;
- p2 = (double *)v2;
- if (p1[0] > p2[0])
- return 1;
- else if (p1[0] < p2[0])
- return -1;
- else
- return 0;
-/* Function to obtain vertices of convex hull */
-int convexHull(struct points *pnts, struct convex *hull)
- int pointIdx, upPoints, loPoints;
- int i, *upHull, *loHull;
- int n = pnts->n;
- double *ro, (*ri)[3], (*r)[3]; /* r = [xyz] */
- r = (double (*)[3]) malloc(n * 3 * sizeof(double));
- ri = &r[0];
- ro = &pnts->r[0];
- for (i=0; i<n; i++) {
- (*ri)[0] = *ro;
- (*ri)[1] = *(ro+1);
- (*ri)[2] = *(ro+2);
- ri++;
- ro += 3;
- /* sort points in ascending x order
- * modified according to http://www.physicsforums.com/showthread.php?t=546209 */
- qsort(&r[0][0], n, 3 * sizeof(double), cmpPoints);
- hull->hull = (int *) G_malloc(n * 3 * sizeof(int));
- /* compute upper hull */
- upHull = hull->hull;
- upHull[0] = 0;
- upHull[1] = 1;
- upPoints = 1; /* number of points in upper hull */
- for (pointIdx = 2; pointIdx < n; pointIdx++) {
- upPoints++;
- upHull[upPoints] = pointIdx;
- while (upPoints > 1 &&
- !rightTurn(r, upHull[upPoints], upHull[upPoints - 1],
- upHull[upPoints - 2])
- upHull[upPoints - 1] = upHull[upPoints];
- upPoints--;
- /* compute lower hull, overwrite last point of upper hull */
- loHull = &(upHull[upPoints]);
- loHull[0] = n - 1;
- loHull[1] = n - 2;
- loPoints = 1; /* number of points in lower hull */
- for (pointIdx = n - 3; pointIdx >= 0; pointIdx--) {
- loPoints++;
- loHull[loPoints] = pointIdx;
- while (loPoints > 1 &&
- !rightTurn(r, loHull[loPoints], loHull[loPoints - 1],
- loHull[loPoints - 2])
- loHull[loPoints - 1] = loHull[loPoints];
- loPoints--;
- hull->n = loPoints + upPoints;
- G_debug(3, "numPoints:%d loPoints:%d upPoints:%d",
- n, loPoints, upPoints);
- hull->hull = (int *) G_realloc(hull->hull, (hull->n + 1) * sizeof(int));
- /* Obtain coordinates of hull vertices */
- hull->coord = (double *) G_malloc((hull->n + 1) * 3 * sizeof(double)); /* 1st = last pnt */
- int *hh, *hh0;
- double *hc, (*r0)[3];
- hh = &hull->hull[0];
- for (i=0; i <= hull->n; i++) {
- if (i < hull->n) {
- *hc = (*(r+*hh))[0];
- *(hc+1) = (*(r+*hh))[1];
- *(hc+2) = (*(r+*hh))[2];
- //G_debug(0,"%f %f %f", *hc, *(hc+1), *(hc+2));
- hc += 3;
- hh++;
- else { // coords of 1st equal to coords of last hull vertex
- r0 = &r[0];
- hh0 = &hull->hull[0];
- *hc = (*(r0+*hh0))[0];
- *(hc+1) = (*(r0+*hh0))[1];
- *(hc+2) = (*(r0+*hh0))[2];
- return hull->n;
-double MBR(struct points *pnts)
- int i, k;
- double us, cosus, sinus, S, S_min;
- double *hc, *hc_k; // original and to be transformed vertices of hull
- double *hull_trans, *ht; /* Coordinates of hull vertices transformed into coordinate system with axes parallel to hull's edges */
- hull_trans = (double *) G_malloc(3 * sizeof(double));
- hull.n = convexHull(pnts, &hull);
- hc = &hull.coord[0];
- S_min = (pnts->r_max[0] - pnts->r_min[0]) * (pnts->r_max[1] - pnts->r_min[1]); /* Area of extent */
- for (i=0; i < hull.n; i++) {
- /* Bearings of each hull edge */
- us = bearing(*hc, *(hc+3), *(hc+1), *(hc+4)); // x0, x1, y0, y1
- if (us == -9999) // Identical points
- continue;
- cosus = cos(us);
- sinus = sin(us);
- hc_k = &hull.coord[0]; // original coords of k-point of hull
- for (k=0; k <= hull.n; k++) {
- // all the points into coordinate system with x axis parallel with i-edge
- *ht = *hc_k * cosus + *(hc_k+1) * sinus;
- *(ht+1) = -1. * (*hc_k) * sinus + *(hc_k+1) * cosus;
- *(ht+2) = *(hc_k+2);
- //G_debug(0, "%f %f %f", *ht,*(ht+1),*(ht+2));
- switch (k) {
- case 0:
- r_min = r_max = triple(*ht, *(ht+1), *(ht+2));
- break;
- default:
- hc_k += 3;
- } // end k
- hc += 3; // next point
- //G_debug(0, "%f %f %f %f %f %f", *r_min, *(r_min+1), *(r_min+2), *r_max, *(r_max+1), *(r_max+2));
- S = (*r_max - *r_min) * (*(r_max+1) - *(r_min+1)); /* Area of transformed extent */
- S_min = MIN(S, S_min);
- } // end i
- return S_min;
Deleted: grass-addons/grass7/vector/v.nnstat/nearest_neighbour.cpp
--- grass-addons/grass7/vector/v.nnstat/nearest_neighbour.cpp 2015-06-22 02:47:05 UTC (rev 65509)
+++ grass-addons/grass7/vector/v.nnstat/nearest_neighbour.cpp 2015-06-22 08:00:18 UTC (rev 65510)
@@ -1,158 +0,0 @@
-using namespace std;
-using namespace pcl;
-int nn_average_distance_real(struct points *pnts, struct nearest *nna)
- int i, n = pnts->n, k=2, ind0 = 0;
- double sum_r;
- double *r;
- pcl::PointXYZ *pcl_r;
- r = (double *) G_malloc(n*3 * sizeof(double));
- memcpy(r, pnts->r, n*3 * sizeof(double));
- /* create new vector of 3D points (use template PointCloud from namespace pcl) */
- pcl::PointCloud<pcl::PointXYZ>::Ptr pcl_pnts (new pcl::PointCloud<pcl::PointXYZ>);
- pcl_pnts->width = n;
- pcl_pnts->height = 1;
- pcl_pnts->points.resize (pcl_pnts->width * pcl_pnts->height);
- pcl_r = &pcl_pnts->points[0];
- pcl_r->x = *r;
- pcl_r->y = *(r+1);
- pcl_r->z = *(r+2);
- pcl_r++;
- r += 3;
- pcl::KdTreeFLANN<pcl::PointXYZ> kd_tree; /* create kd-tree */
- kd_tree.setInputCloud(pcl_pnts);
- std::vector<int> ind(k);
- std::vector<float> sqDist(k);
- double dx, dy, dz, dist;
- double *ri, *r0, *rk;
- /* Average distance to NN */
- sum_r = 0.;
- ri = &pnts->r[0];
- r0 = &pnts->r[0];
- for (size_t i=0; i < pcl_pnts->points.size (); i++) {
- if (kd_tree.nearestKSearch(pcl_pnts->points[i], k, ind, sqDist) > 0) {
- /* sqDist not used because double precision is needed (in PCL not supported yet) */
- rk = r0 + 3*ind[1];
- //dist = distance(ri, rk);
- dx = *rk - *ri;
- dy = *(rk+1) - *(ri+1);
- dz = *(rk+2) - *(ri+2);
- dist = sqrt(dx*dx + dy*dy + dz*dz);
- sum_r += dist;
- } // end nearestKSearch
- ri+=3;
- } // end i
- nna->rA = sum_r / pcl_pnts->points.size ();
- int pass=1;
- return pass;
-extern "C" {
- void density(struct points *pnts, struct nna_par *xD, const char *Acol, struct nearest *nna)
- if (xD->i3 == TRUE) { /* Minimum Enclosing Block */
- nna->A = Acol != NULL ? atof(Acol) : MBB(pnts); /* set volume specified by user or MBB volume */
- if (nna->A <= 0.)
- G_fatal_error(_("Volume must be greater than 0"));
- if (xD->i3 == FALSE) { /* Minimum Enclosing Rectangle */
- nna->A = Acol != NULL ? atof(Acol) : MBR(pnts); /* set area specified by user or MBR area */
- if (nna->A <= 0.)
- G_fatal_error(_("Area must be greater than 0"));
- nna->rho = pnts->n / nna->A; /* number of points per area/volume unit */
- void nn_average_distance_expected(struct nna_par *xD, struct nearest *nna)
- if (xD->i3 == TRUE) /* 3D */
- nna->rE = 0.55396/pow(nna->rho,1./3.); /* according to Chandrasekhar */
- if (xD->i3 == FALSE) /* 2D */
- nna->rE = 0.5/sqrt(nna->rho); /* according to Clark & Evans */
- * Two-tailed Student's test of significance of the mean
- void nn_results(struct points *pnts, struct nna_par *xD, struct nearest *nna)
- G_message(_("\n*** Nearest Neighbour Analysis results ***\n"));
- if (xD->zcol != NULL) {
- G_message(_("Input settings .. 3D layer: %d .. 3D NNA: %d .. zcolumn: %s"), xD->v3, xD->i3, xD->zcol);
- else {
- G_message(_("Input settings .. 3D layer: %d 3D NNA: %d"), xD->v3, xD->i3);
- G_message(_("Number of points .......... %d"), pnts->n);
- G_message(_("Volume .................... %f [units^3]"), nna->A);
- else {
- G_message(_("Area ...................... %f [units^2]"), nna->A);
- G_message(_("Density of points ......... %f"), nna->rho);
- G_message(_("Average distance between the nearest neighbours ........... %.3f [units]"), nna->rA);
- G_message(_("Average expected distance between the nearest neighbours .. %.3f [units]"), nna->rE);
- G_message(_("Ratio rA/rE ............... %f"), nna->R);
- G_message(_("\n*** Results of two-tailed test of the mean ***"));
- G_message(_("Null hypothesis: Point set is randomly distributed within the region."));
- G_message(_("Standard variate of the normal curve> c = %f"), nna->c);
- /* two-tailed test of the mean */
- if (-1.96 < nna->c && nna->c < 1.96) {
- G_message(_("Null hypothesis IS NOT REJECTED at the significance level alpha = 0.05"));
- if (-2.58 < nna->c && nna->c <= -1.96) {
- G_message(_("Null hypothesis IS NOT REJECTED at the significance level alpha = 0.01 => point set is clustered"));
- G_message(_("Null hypothesis CAN BE REJECTED at the significance level alpha = 0.05 => point set is randomly distributed"));
- if (1.96 <= nna->c && nna->c < 2.58) {
- G_message(_("Null hypothesis IS NOT REJECTED at the significance level alpha = 0.01 => point set is dispersed"));
- if (nna->c <= -2.58) {
- G_message(_("Null hypothesis CAN BE REJECTED at the significance levels alpha = 0.05 and alpha = 0.01 => point set is clustered"));
- if (nna->c >= 2.58) {
- G_message(_("Null hypothesis CAN BE REJECTED at the significance levels alpha = 0.05 and alpha = 0.01 => point set is dispersed"));
- G_message(" ");
- void nn_statistics(struct points *pnts, struct nna_par *xD, struct nearest *nna)
- double disp_rE, var_rE, sig_rE;
- if (xD->i3 == TRUE) { /* 3D */
- disp_rE = 0.347407742479038/pow(nna->rho,2./3.); /* disperzia, odvodene */
- var_rE = 0.0405357524727094/pow(nna->rho,2./3.); /* variancia, odvodene */
- if (xD->i3 == FALSE) { /* 2D */
- disp_rE = 1./(nna->rho*PI); /* disperzia */
- var_rE = (4.0 - PI)/(4.0 * PI * pnts->n * nna->rho); /* variancia */
- sig_rE = sqrt(var_rE); /* standard error of the mean distance */
- nna->c = (nna->rA - nna->rE) / sig_rE; /* standard variate of the normal curve */
- nn_results(pnts, xD, nna);
Deleted: grass-addons/grass7/vector/v.nnstat/utils.cpp
--- grass-addons/grass7/vector/v.nnstat/utils.cpp 2015-06-22 02:47:05 UTC (rev 65509)
+++ grass-addons/grass7/vector/v.nnstat/utils.cpp 2015-06-22 08:00:18 UTC (rev 65510)
@@ -1,50 +0,0 @@
-double *triple(double x, double y, double z)
- double *t;
- t = (double *) G_malloc(3 * sizeof(double));
- *t = x;
- *(t+1) = y;
- *(t+2) = z;
- return t;
-/* Bearing */
-double bearing(double x0, double x1, double y0, double y1)
- double dy, dx, us;
- dy = y1 - y0;
- dx = x1 - x0;
- if (dy == 0. && dx == 0.)
- return -9999;
- us = atan(fabsf(dy/dx));
- if (dx==0. && dy>0.)
- us = 0.5*PI;
- if (dx<0. && dy>0.)
- us = PI-us;
- if (dx<0. && dy==0.)
- us = PI;
- if (dx<0. && dy<0.)
- us = PI+us;
- if (dx==0. && dy<0.)
- us = 1.5*PI;
- if (dx>0. && dy<0.)
- us = 2.0*PI-us;
- return us;
-/*double distance(double *r0, double *r1)
- dx = *r1 - *r0;
- dy = *(r1+1) - *(r0+1);
- dz = *(r1+2) - *(r0+2);
- return dist;
