[GRASS-SVN] r65519 - in grass/trunk/lib: python/temporal temporal/lib
Wed Jun 24 15:23:40 PDT 2015
Author: huhabla
Date: 2015-06-24 15:23:40 -0700 (Wed, 24 Jun 2015)
New Revision: 65519
   grass/trunk/lib/python/temporal/c_libraries_interface.py
   grass/trunk/lib/python/temporal/core.py
   grass/trunk/lib/temporal/lib/default_name.c
temporal library: Store the default database connection as shell variable substitude to avoid wrong temporal database path's in cases the location was renamed or the path to the grass database changed.
Modified: grass/trunk/lib/python/temporal/c_libraries_interface.py
--- grass/trunk/lib/python/temporal/c_libraries_interface.py	2015-06-23 16:19:25 UTC (rev 65518)
+++ grass/trunk/lib/python/temporal/c_libraries_interface.py	2015-06-24 22:23:40 UTC (rev 65519)
@@ -136,7 +136,7 @@
         # This behavior is in conjunction with db.connect
         dbstring = dbstring.replace("$GISDBASE", libgis.G_gisdbase())
         dbstring = dbstring.replace("$LOCATION_NAME", libgis.G_location())
-        dbstring = dbstring.replace("$MAPSET", libgis.G_mapset())
+        dbstring = dbstring.replace("$MAPSET", mapset)
     conn.send(dbstring)
Modified: grass/trunk/lib/python/temporal/core.py
--- grass/trunk/lib/python/temporal/core.py	2015-06-23 16:19:25 UTC (rev 65518)
+++ grass/trunk/lib/python/temporal/core.py	2015-06-24 22:23:40 UTC (rev 65519)
@@ -860,7 +860,8 @@
             driver,  dbstring = self.tgis_mapsets[mapset]
             if dbstring not in self.unique_connections.keys():
-                self.unique_connections[dbstring] = DBConnection(driver)
+                self.unique_connections[dbstring] = DBConnection(backend=driver,
+        dbstring=dbstring)
             self.connections[mapset] = self.unique_connections[dbstring]
@@ -904,7 +905,7 @@
            close all temporal databases that have been opened.
         for key in self.unique_connections.keys():
-            self.unique_connections[key] .close()
+            self.unique_connections[key].close()
         self.connected = False
@@ -1014,16 +1015,20 @@
 class DBConnection(object):
     """This class represents the database interface connection
-       and provides access to the chisen backend modules.
+       and provides access to the chosen backend modules.
        The following DBMS are supported:
          - sqlite via the sqlite3 standard library
          - postgresql via psycopg2
-    def __init__(self, backend=None):
+    def __init__(self, backend=None, dbstring=None):
+        """ Constructor of a database connection
+            param backend:The database backend sqlite or pg
+            param dbstring: The database connection string
         if backend is None:
             global tgis_backend
@@ -1037,6 +1042,10 @@
             else:
                 self.dbmi = psycopg2
+        if dbstring is None:
+            global tgis_database_string
+            self.dbstring = tgis_database_string
         self.msgr = get_tgis_message_interface()
         self.msgr.debug(1, "SQLDatabaseInterfaceConnection constructor")
@@ -1061,13 +1070,13 @@
     def connect(self,  dbstring=None):
         """Connect to the DBMI to execute SQL statements
-           Supported backends are sqlite3 and postgresql
+            Supported backends are sqlite3 and postgresql
         # Connection in the current mapset
-            global tgis_database_string
-            dbstring = tgis_database_string
+            dbstring = self.dbstring
         try:
             if self.dbmi.__name__ == "sqlite3":
                 self.connection = self.dbmi.connect(dbstring,
Modified: grass/trunk/lib/temporal/lib/default_name.c
--- grass/trunk/lib/temporal/lib/default_name.c	2015-06-23 16:19:25 UTC (rev 65518)
+++ grass/trunk/lib/temporal/lib/default_name.c	2015-06-24 22:23:40 UTC (rev 65519)
@@ -40,8 +40,8 @@
     char default_connection[2048];
-    G_snprintf(default_connection, 2048, "%s/%s/%s/%s", G_gisdbase(), G_location(),
-               G_mapset(), TGISDB_DEFAULT_SQLITE_PATH);
+    G_snprintf(default_connection, 2048, "$GISDBASE/$LOCATION_NAME/$MAPSET/%s",
+               TGISDB_DEFAULT_SQLITE_PATH);
     return G_store(default_connection);
