[GRASS-SVN] r64774 - grass-addons/grass6/vector/v.profile
svn_grass at osgeo.org
Sun Mar 1 11:49:38 PST 2015
Author: neteler
Date: 2015-03-01 11:49:38 -0800 (Sun, 01 Mar 2015)
New Revision: 64774
Added:
grass-addons/grass6/vector/v.profile/description.html
Removed:
grass-addons/grass6/vector/v.profile/v.profile.html
v.profile Addon: minor HTML fix
Copied: grass-addons/grass6/vector/v.profile/description.html (from rev 64704, grass-addons/grass6/vector/v.profile/v.profile.html)
--- grass-addons/grass6/vector/v.profile/description.html (rev 0)
+++ grass-addons/grass6/vector/v.profile/description.html 2015-03-01 19:49:38 UTC (rev 64774)
@@ -0,0 +1,74 @@
+<h2>DESCRIPTION</h2>
+This module will print out distance and attributes to points/lines
+along profiling line. Distance is calculated from first profiling line
+coordinate pair or from the beginning of vector line (use "Line
+directions" feature in gis.m to see distance calculation direction).
+Output can go to file or stdout. Output file will be overwritten
+without warning. Buffer (tolerance) parameter sets how far point can be
+located from profiling line and still be included in output data set.
+Output map option can be used to visualy check which points are
+profiled. Buffer (tolerance) setting does not affect lines. Lines are
+sampled at their crossing point with profiling line. By default Z
+values are printed if input vector is a 3D map. It can be disabled with
+-z flag. Profiling line can be provided as N,E coordinate pairs or can
+come from input vector map. As currently profiling line must be single
+line, one should use profile_where parameter to select single line from
+profile input map if it contains multiple features.
+<h2>NOTE</h2>
+Currently module can profile only points and lines (including 3D ones).
+Areas and other complex features are not supported. If one can provide
+reasonable examples how area sampling should work and why it's
+important, area (or any other feature type) sampling can be added.
+<h2>EXAMPLES</h2>
+Get point values and distance from the city and save into file for
+later usage. Will use ; as delimiter and three numbers after decimal
+separator for distance. Output file will contain data for all points,
+that are within 100m range to profiling line.
+<div class="code"><pre>
+v.profile input=archsites at PERMANENT map_output=profiling_line buffer=100 \
+ east_north=591518.55,4925722.38,592110.14,4920989.67 \
+ out_file=/home/user/archsites.distance dp=3 fs=';'
+# Now let's see the output:
+$cat archsites.distance
+Number;Distance;cat;str1
+1;446.958;24;"Hanson Ranch"
+2;1386.149;11;"No Name"
+3;2754.872;2;"No Name"
+4;4559.578;13;"No Name"
+</pre></div>
+<p>Create river valley crossection and provide river marker:
+# Take elevation samples
+r.profile input=elevation.dem at PERMANENT output=/home/user/elevation.profile \
+ profile=600570.27364,4920613.41838,600348.034348,4920840.38617
+# Now get distance to place where river marker should be set
+v.profile input=streams at PERMANENT out_file=/home/user/river.profile \
+ east_north=600570.27364,4920613.41838,600348.034348,4920840.38617
+</pre></div>
+<h2>BUGS</h2>
+Strings are enclosed in double quotes ", still quotes within string are
+not escaped.
+<p>
+Vector CAT values are not outputed. Only way how to get CAT value is from
+attribute table.
+<h2>SEE ALSO</h2>
+<a href="r.profile.html">r.profile</a>
+<h2>AUTHOR</h2>
+Maris Nartiss
+<p><i>Last changed: $Date$</i>
Deleted: grass-addons/grass6/vector/v.profile/v.profile.html
--- grass-addons/grass6/vector/v.profile/v.profile.html 2015-03-01 09:34:49 UTC (rev 64773)
+++ grass-addons/grass6/vector/v.profile/v.profile.html 2015-03-01 19:49:38 UTC (rev 64774)
@@ -1,52 +0,0 @@
-<h2>DESCRIPTION</h2>
-<p>This module will print out distance and attributes to points/lines along profiling
-line. Distance is calculated from first profiling line coordinate pair or from the
-beginning of vector line (use "Line directions" feature in gis.m to see distance calculation
-direction). Output can go to file or stdout. Output file will be overwritten without warning.
-Buffer (tolerance) parameter sets how far point
-can be located from profiling line and still be included in output data set. Output map
-option can be used to visualy check which points are profiled. Buffer (tolerance) setting
-does not affect lines. Lines are sampled at their crossing point with profiling line.
-By default Z values are printed if input vector is a 3D map. It can be disabled with -z
-flag. Profiling line can be provided as N,E coordinate pairs or can come from input vector
-map. As currently profiling line must be single line, one should use profile_where parameter
-to select single line from profile input map if it contains multiple features.</p>
-<h2>NOTE</h2>
-<p>Currently module can profile only points and lines (including 3D ones). Areas and other
-complex features are not supported. If one can provide reasonable examples how area
-sampling should work and why it's important, area (or any other feature type) sampling can
-be added.</p>
-<h2>EXAMPLES</h2>
-<p>
-Get point values and distance from the city and save into file for later usage. Will use
-; as delimiter and three numbers after decimal separator for distance. Output file will contain
-data for all points, that are within 100m range to profiling line.
-<div class="code"><pre>
-v.profile input=archsites at PERMANENT map_output=profiling_line buffer=100 \
-east_north=591518.55,4925722.38,592110.14,4920989.67 out_file=/home/user/archsites.distance dp=3 fs=';'
-# Now let's see output:
-$cat archsites.distance
-Number;Distance;cat;str1
-1;446.958;24;"Hanson Ranch"
-2;1386.149;11;"No Name"
-3;2754.872;2;"No Name"
-4;4559.578;13;"No Name"
-</pre></div>
-</p>
-<p>Create river valley crossection and provide river marker
-# Take elevation samples
-r.profile input=elevation.dem at PERMANENT output=/home/user/elevation.profile \
-profile=600570.27364,4920613.41838,600348.034348,4920840.38617
-# Now get distance to place where river marker should be set
-v.profile input=streams at PERMANENT out_file=/home/user/river.profile \
-east_north=600570.27364,4920613.41838,600348.034348,4920840.38617
-</pre></div>
-</p>
-<h2>BUGS</h2>
-<p>Strings are enclosed in double quotes ", still quotes within string are not escaped.</p>
-<p>Vector CAT values are not outputed. Only way how to get CAT value is from attribute table.</p>
-<h2>SEE ALSO</h2>
-<p><a href="r.profile.html">r.profile</a></p>
-<h2>AUTHOR</h2>
-<p>Maris Nartiss</p>
