[GRASS-SVN] r64816 - grass/branches/releasebranch_7_0
svn_grass at osgeo.org
Sun Mar 8 10:12:25 PDT 2015
Author: neteler
Date: 2015-03-08 10:12:25 -0700 (Sun, 08 Mar 2015)
New Revision: 64816
grass/branches/releasebranch_7_0/REQUIREMENTS.html
REQUIREMENTS.html: cosmetics
Modified: grass/branches/releasebranch_7_0/REQUIREMENTS.html
--- grass/branches/releasebranch_7_0/REQUIREMENTS.html 2015-03-08 17:11:55 UTC (rev 64815)
+++ grass/branches/releasebranch_7_0/REQUIREMENTS.html 2015-03-08 17:12:25 UTC (rev 64816)
@@ -75,15 +75,15 @@
<a href="http://www.fftw.org">http://www.fftw.org</a>
</li>
-<li><b>GEOS</b> (Geometry Engine library), adds extended options to the v.select module<br>
+<li><b>GEOS</b> (Geometry Engine library), needed for v.buffer and adds extended options
+to the v.select module<br>
<a href="http://trac.osgeo.org/geos">http://trac.osgeo.org/geos</a>
</li>
<li><b>LAPACK / BLAS</b> (libraries for numerical computing) for GMATH library (GRASS Numerical Library)<br>
<a href="http://www.netlib.org/lapack">http://www.netlib.org/lapack</a> (usually available on Linux distros)
<br>
-<i>Note:</i> LAPACK/BLAS support is intended for future module
-implementations, no need to use it at time!
+<i>Note:</i> LAPACK/BLAS support is at time only needed for selected Addons
<li><b>NetCDF</b> (for 3D raster netcdf export)<br>
<a href="http://www.unidata.ucar.edu/software/netcdf/">http://www.unidata.ucar.edu/software/netcdf/</a>
