[GRASS-SVN] r64832 - grass/branches/releasebranch_7_0/lib/python/script
svn_grass at osgeo.org
Tue Mar 10 07:53:31 PDT 2015
Author: annakrat
Date: 2015-03-10 07:53:31 -0700 (Tue, 10 Mar 2015)
New Revision: 64832
grass/branches/releasebranch_7_0/lib/python/script/array.py
script.array: make it into real doctest (merge from trunk, r64831)
Modified: grass/branches/releasebranch_7_0/lib/python/script/array.py
--- grass/branches/releasebranch_7_0/lib/python/script/array.py 2015-03-10 14:49:46 UTC (rev 64831)
+++ grass/branches/releasebranch_7_0/lib/python/script/array.py 2015-03-10 14:53:31 UTC (rev 64832)
@@ -29,7 +29,6 @@
>>> # This will write the numpy array as GRASS raster map
... # with name map2d_1
... map2d_1.write(mapname="map2d_1", overwrite=True)
- 100%
0
>>> # We create a new array and read map2d_1 to modify it
@@ -47,7 +46,6 @@
[ 0. 1. 2. 0. 1. 2.]]
>>> # Write the result as new raster map with name map2d_2
... map2d_2.write(mapname="map2d_2", overwrite=True)
- 100%
0
>>> # Here we create a 3D raster map numpy array
@@ -67,10 +65,12 @@
[ 1. 2. 3. 4. 5. 6.]
[ 2. 3. 4. 5. 6. 7.]
[ 3. 4. 5. 6. 7. 8.]]
+<BLANKLINE>
[[ 1. 2. 3. 4. 5. 6.]
[ 4. 5. 6. 7. 8. 9.]]
+<BLANKLINE>
[[ 2. 3. 4. 5. 6. 7.]
@@ -78,8 +78,6 @@
>>> # This will write the numpy array as GRASS 3D raster map
... # with name map3d_1
... map3d_1.write(mapname="map3d_1", overwrite=True)
-Loading floating point data with 8 bytes ... (6x4x3)
- 100%
0
>>> # We create a new 3D array and read map3d_1 to modify it
... map3d_2 = garray.array3d()
@@ -94,18 +92,18 @@
[ 1. 2. 0. 1. 2. 0.]
[ 2. 0. 1. 2. 0. 1.]
+<BLANKLINE>
[[ 1. 2. 0. 1. 2. 0.]
[ 1. 2. 0. 1. 2. 0.]]
+<BLANKLINE>
[[ 2. 0. 1. 2. 0. 1.]
[ 2. 0. 1. 2. 0. 1.]]]
>>> # Write the result as new 3D raster map with name map3d_2
... map3d_2.write(mapname="map3d_2", overwrite=True)
- 100%
0
(C) 2010-2012 by Glynn Clements and the GRASS Development Team
