[GRASS-SVN] r64837 - grass-addons/grass7/raster/r.stream.segment
Thu Mar 12 02:36:23 PDT 2015
Author: mmetz
Date: 2015-03-12 02:36:23 -0700 (Thu, 12 Mar 2015)
New Revision: 64837
   grass-addons/grass7/raster/r.stream.segment/local_vars.h
   grass-addons/grass7/raster/r.stream.segment/main.c
   grass-addons/grass7/raster/r.stream.segment/stream_segment.c
   grass-addons/grass7/raster/r.stream.segment/stream_topology.c
   grass-addons/grass7/raster/r.stream.segment/stream_vector.c
r.stream.segment: fix nodata in attribute table, fix stream ID handling, add TODOs
Modified: grass-addons/grass7/raster/r.stream.segment/local_vars.h
--- grass-addons/grass7/raster/r.stream.segment/local_vars.h	2015-03-12 09:10:17 UTC (rev 64836)
+++ grass-addons/grass7/raster/r.stream.segment/local_vars.h	2015-03-12 09:36:23 UTC (rev 64837)
@@ -10,6 +10,8 @@
 #define SQRT2 1.414214
+/* TODO: do not use long int to store row, col
+ * long int must be 8 byte but is often 4 byte, better use int r, c */
 typedef struct {
 	int stream;
 	int next_stream;
@@ -18,8 +20,8 @@
 	long int * points;
 	float * elevation;
 	double * distance;
-	unsigned long int init;
-	unsigned long int outlet; /* outlet is cell from next stream */
+	long int init;
+	long int outlet; /* outlet is cell from next stream */
 	int last_cell_dir; /* to add outlet to vector */
 	float direction;
 	float length;
Modified: grass-addons/grass7/raster/r.stream.segment/main.c
--- grass-addons/grass7/raster/r.stream.segment/main.c	2015-03-12 09:10:17 UTC (rev 64836)
+++ grass-addons/grass7/raster/r.stream.segment/main.c	2015-03-12 09:36:23 UTC (rev 64837)
@@ -164,6 +164,9 @@
 	    ram_number_of_streams(streams, dirs, &ordered) + 1;
 	ram_build_streamlines(streams, dirs, elevation, number_of_streams);
+	/* TODO: either always create unique streams
+	 * or keep current mechanism of identify_next_stream,
+	 * then unique streams are not needed */
 	if (ordered) {
 	    ram_create_map(&map_unique_streams, CELL_TYPE);
 	    unique_streams = (CELL **) map_unique_streams.map;
@@ -217,6 +220,9 @@
 	    seg_number_of_streams(streams, dirs, &ordered) + 1;
 	seg_build_streamlines(streams, dirs, elevation, number_of_streams);
 	if (ordered) {
 	    seg_create_map(&map_unique_streams, SROWS, SCOLS, number_of_segs,
 			   CELL_TYPE);
@@ -235,7 +241,7 @@
     for (i = 1; i < number_of_streams; ++i)
-	G_message("%d %d %d", stream_attributes[i].stream,
+	G_debug(1, "%d %d %d", stream_attributes[i].stream,
 		  stream_attributes[i].next_stream,
 		  stream_attributes[i].last_cell_dir);
Modified: grass-addons/grass7/raster/r.stream.segment/stream_segment.c
--- grass-addons/grass7/raster/r.stream.segment/stream_segment.c	2015-03-12 09:10:17 UTC (rev 64836)
+++ grass-addons/grass7/raster/r.stream.segment/stream_segment.c	2015-03-12 09:36:23 UTC (rev 64837)
@@ -80,12 +80,12 @@
 	cell_down = i > number_of_cells - 1 - seg_length ?
 	    number_of_cells - 1 - i : seg_length;
-	r = (int)P[i] / ncols;
-	c = (int)P[i] % ncols;
-	r_up = (int)P[i - cell_up] / ncols;
-	c_up = (int)P[i - cell_up] % ncols;
-	r_down = (int)P[i + cell_down] / ncols;
-	c_down = (int)P[i + cell_down] % ncols;
+	r = (int)(P[i] / ncols);
+	c = (int)(P[i] % ncols);
+	r_up = (int)(P[i - cell_up] / ncols);
+	c_up = (int)(P[i - cell_up] % ncols);
+	r_down = (int)(P[i + cell_down] / ncols);
+	c_down = (int)(P[i + cell_down] % ncols);
 	dir_down = calc_dir(r, c, r_down, c_down);
 	dir_up = calc_dir(r, c, r_up, c_up);
@@ -99,12 +99,12 @@
 	cell_down = i > number_of_cells - 1 - seg_length_short ?
 	    number_of_cells - 1 - i : seg_length_short;
@@ -175,10 +175,10 @@
     for (i = 0, prev_i = 0; i < number_of_cells + 1; ++i) {
 	if (streamline[i].decision == 1 || i == (number_of_cells - 1)) {
-	    r_up = (int)P[prev_i] / ncols;
-	    c_up = (int)P[prev_i] % ncols;
+	    r_up = (int)(P[prev_i] / ncols);
+	    c_up = (int)(P[prev_i] % ncols);
 	    cur_stream->sector_breakpoints[sector_index] = i;
@@ -231,10 +231,10 @@
     G_debug(3, "calc_tangents(): number_streams=%d", number_streams);
     /*before calc tangents add rest of streamline attributes */
-    r_up = (int)P[1] / ncols;
-    c_up = (int)P[1] % ncols;
-    r_down = (int)P[last_cell] / ncols;
-    c_down = (int)P[last_cell] % ncols;
+    r_up = (int)(P[1] / ncols);
+    c_up = (int)(P[1] % ncols);
+    r_down = (int)(P[last_cell] / ncols);
+    c_down = (int)(P[last_cell] % ncols);
     cur_stream->direction = calc_dir(r_up, c_up, r_down, c_down);
     cur_stream->length = calc_length(cur_stream->distance, 1, last_cell);
@@ -248,7 +248,7 @@
     /* find location of outlet in next stream */
-    for (i = 1; i < SA[next_stream].number_of_cells; ++i) {
+    for (i = 0; i < SA[next_stream].number_of_cells; ++i) {
 	if (SA[next_stream].points[i] == outlet) {
 	    reached_end = 0;
 	    break;
@@ -259,6 +259,7 @@
     if (reached_end) {
 	G_warning(_("Network topology error: cannot identify stream join for stream %d"),
 		  cur_stream->stream);
+	G_fatal_error("stream %d, outlet %u", cur_stream->stream, outlet);
 	cur_stream->tangent = -1;
 	cur_stream->continuation = -1;
 	return 0;
@@ -268,12 +269,12 @@
     cell_down = i >= (SA[next_stream].number_of_cells - seg_length) ?
 	SA[next_stream].number_of_cells - seg_length - 1 : seg_length;
-    r = (int)SA[next_stream].points[i] / ncols;
-    c = (int)SA[next_stream].points[i] % ncols;
-    r_up = (int)SA[next_stream].points[i - cell_up] / ncols;
-    c_up = (int)SA[next_stream].points[i - cell_up] % ncols;
-    r_down = (int)SA[next_stream].points[i + cell_down] / ncols;
-    c_down = (int)SA[next_stream].points[i + cell_down] % ncols;
+    r = (int)(SA[next_stream].points[i] / ncols);
+    c = (int)(SA[next_stream].points[i] % ncols);
+    r_up = (int)(SA[next_stream].points[i - cell_up] / ncols);
+    c_up = (int)(SA[next_stream].points[i - cell_up] % ncols);
+    r_down = (int)(SA[next_stream].points[i + cell_down] / ncols);
+    c_down = (int)(SA[next_stream].points[i + cell_down] % ncols);
     cur_stream->continuation = calc_dir(r, c, r_down, c_down);
     cur_stream->tangent = i == 1 ? -1 :
Modified: grass-addons/grass7/raster/r.stream.segment/stream_topology.c
--- grass-addons/grass7/raster/r.stream.segment/stream_topology.c	2015-03-12 09:10:17 UTC (rev 64836)
+++ grass-addons/grass7/raster/r.stream.segment/stream_topology.c	2015-03-12 09:36:23 UTC (rev 64837)
@@ -21,7 +21,11 @@
     int trib_num = 0;
     int i, j;
     int next_r, next_c;
+    int streams_cell;
+    int same_id;
+    streams_cell = streams[r][c];
+    same_id = 0;
     for (i = 1; i < 9; ++i) {
 	if (NOT_IN_REGION(i))
 	    continue;
@@ -30,29 +34,23 @@
 	next_r = NR(i);
 	next_c = NC(i);
-	if (streams[next_r][next_c] > 0 && dirs[next_r][next_c] == j)
+	if (streams[next_r][next_c] > 0 && dirs[next_r][next_c] == j) {
 	    trib_num++;
+	    if (streams[next_r][next_c] == streams_cell)
+		same_id++;
-    if (trib_num > 1)
-	for (i = 1; i < 9; ++i) {
-	    if (NOT_IN_REGION(i))
-		continue;
-	    j = DIAG(i);
-	    next_r = NR(i);
-	    next_c = NC(i);
-	    if (streams[next_r][next_c] == streams[r][c] &&
-		dirs[next_r][next_c] == j)
-		trib_num--;
     if (trib_num > 5)
 	G_fatal_error(_("Error finding inits. Stream and direction maps probably do not match"));
     if (trib_num > 3)
 	G_warning(_("Stream network may be too dense"));
+    if (same_id > 1)
+	G_warning(_("Too many stream segments with the same ID %d"), streams_cell);
+    else if (same_id == 1)
+	trib_num = 1;
     return trib_num;
 }				/* end trib_num */
@@ -64,8 +62,10 @@
     int i, j;
     int next_r, next_c;
     int streams_cell, streams_next_cell, dirs_next_cell;
+    int same_id;
     Segment_get(streams, &streams_cell, r, c);
+    same_id = 0;
 	    continue;
@@ -77,31 +77,24 @@
 	Segment_get(streams, &streams_next_cell, next_r, next_c);
 	Segment_get(dirs, &dirs_next_cell, next_r, next_c);
-	if (streams_next_cell > 0 && dirs_next_cell == j)
+	if (streams_next_cell > 0 && dirs_next_cell == j) {
 	    trib_num++;
+	    if (streams_next_cell == streams_cell)
+		same_id++;
-    if (trib_num > 1)
-		continue;
-	    j = DIAG(i);
-	    next_r = NR(i);
-	    next_c = NC(i);
-	    Segment_get(streams, &streams_next_cell, next_r, next_c);
-	    Segment_get(dirs, &dirs_next_cell, next_r, next_c);
-	    if (streams_next_cell == streams_cell && dirs_next_cell == j)
-		trib_num--;
     if (trib_num > 5)
     if (trib_num > 3)
+    if (same_id > 1)
+	trib_num = 1;
     return trib_num;
@@ -112,9 +105,9 @@
     int stream_num = 0;
     int one = 0, two = 0;
-    for (r = 0; r < nrows; ++r)
-	for (c = 0; c < ncols; ++c)
-	    if (streams[r][c] > 0)
+    for (r = 0; r < nrows; ++r) {
+	for (c = 0; c < ncols; ++c) {
+	    if (streams[r][c] > 0) {
 		if (ram_trib_nums(r, c, streams, dirs) != 1) {
 		    stream_num++;
 		    if (streams[r][c] == 1)
@@ -122,6 +115,9 @@
 		    if (streams[r][c] == 2)
 			two++;
     *ordered = (one > 1 || two > 1) ? 1 : 0;
     /* if there is more than 1 stream with identifier 1 or 2  network is ordered */
@@ -135,10 +131,10 @@
     int streams_cell;
-	    if (streams_cell > 0)
+	    if (streams_cell > 0) {
 		if (seg_trib_nums(r, c, streams, dirs) != 1) {
 		    stream_num++;
 		    if (streams_cell == 1)
@@ -146,7 +142,9 @@
 		    if (streams_cell == 2)
 			two++;
@@ -166,12 +164,12 @@
     stream_attributes =
 	(STREAM *) G_malloc(number_of_streams * sizeof(STREAM));
     G_message(_("Finding inits..."));
     SA = stream_attributes;
-	    if (streams[r][c])
+	    if (streams[r][c]) {
 		if (ram_trib_nums(r, c, streams, dirs) != 1) {	/* adding inits */
 		    if (stream_num > number_of_streams)
@@ -180,12 +178,14 @@
 		    SA[stream_num].init = INDEX(r, c);
 		    stream_num++;
     for (i = 1; i < stream_num; ++i) {
-	r = (int)SA[i].init / ncols;
-	c = (int)SA[i].init % ncols;
+	r = (int)(SA[i].init / ncols);
+	c = (int)(SA[i].init % ncols);
 	SA[i].order = streams[r][c];
 	SA[i].number_of_cells = 0;
 	do {
@@ -196,7 +196,7 @@
 		break;
 	    r = NR(d);
 	    c = NC(d);
-	} while (streams[r][c] == SA[i].order);
+	} while (streams[r][c] == SA[i].order && ram_trib_nums(r, c, streams, dirs) == 1);
 	SA[i].number_of_cells += 2;	/* add two extra points for init+ and outlet+ */
@@ -210,8 +210,8 @@
 	SA[i].distance = (double *)
 	    G_malloc((SA[i].number_of_cells) * sizeof(double));
 	contrib_cell = ram_find_contributing_cell(r, c, dirs, elevation);
 	prev_r = NR(contrib_cell);
 	prev_c = NC(contrib_cell);
@@ -254,7 +254,7 @@
 	    cell_num++;
 	    if (cell_num > SA[i].number_of_cells)
 		G_fatal_error(_("To many points in stream line"));
 	if (SA[i].elevation[0] == -99999)
 	    SA[i].elevation[0] = 2 * SA[i].elevation[1] - SA[i].elevation[2];
@@ -280,15 +280,14 @@
     stream_attributes =
-    /* finding inits */
-	    if (streams_cell)
+	    if (streams_cell) {
 		if (seg_trib_nums(r, c, streams, dirs) != 1) {	/* adding inits */
@@ -297,13 +296,14 @@
 		    stream_num++;
-    /* building streamline */
 	SA[i].order = streams_cell;
@@ -318,7 +318,7 @@
 	    r = NR(d);
 	    c = NC(d);
-	} while (streams_cell == SA[i].order);
+	} while (streams_cell == SA[i].order && seg_trib_nums(r, c, streams, dirs) == 1);
 	SA[i].number_of_cells += 2;	/* add two extra points for point before init and after outlet */
@@ -332,8 +332,8 @@
 	contrib_cell = seg_find_contributing_cell(r, c, dirs, elevation);
@@ -385,7 +385,7 @@
 		G_fatal_error(_("To much points in stream line"));
@@ -450,8 +450,8 @@
     for (i = 1; i < number_of_streams; ++i) {
 	for (j = 1; j < SA[i].number_of_cells - 1; ++j) {
-	    r = (int)SA[i].points[j] / ncols;
-	    c = (int)SA[i].points[j] % ncols;
+	    r = (int)(SA[i].points[j] / ncols);
+	    c = (int)(SA[i].points[j] % ncols);
 	    unique_streams[r][c] = SA[i].stream;
@@ -468,8 +468,8 @@
 	    Segment_put(unique_streams, &SA[i].stream, r, c);
@@ -478,47 +478,67 @@
 int ram_identify_next_stream(CELL **streams, int number_of_streams)
-    int r, c;
-    int i;
+    int i, j, k, n;
     STREAM *SA;
-	if (SA[i].points[SA[i].number_of_cells - 1] == -1) {
-	    SA[i].next_stream = -1;
-	    SA[i].outlet = -1;
+	SA[i].next_stream = -1;
+	SA[i].outlet = SA[i].points[SA[i].number_of_cells - 1];
+	if (SA[i].outlet >= 0) {
+	    /* go through all streams
+	     * do not use raster stream ID because it might not be unique */
+	    for (j = 1; j < number_of_streams; ++j) {
+		/* skip first point = contributing cell and
+		 * last point = outlet (next stream of next stream) */
+		n = SA[j].number_of_cells - 1;
+		for (k = 1; k < n; k++) {
+		    if (SA[j].points[k] == SA[i].outlet) {
+			SA[i].next_stream = j;
+			break;
+		if (SA[i].next_stream > 0)
+		    break;
-	else {
-	    r = (int)SA[i].points[SA[i].number_of_cells - 1] / ncols;
-	    c = (int)SA[i].points[SA[i].number_of_cells - 1] % ncols;
-	    SA[i].next_stream = streams[r][c];
-	    SA[i].outlet = SA[i].points[SA[i].number_of_cells - 1];
     return 0;
 int seg_identify_next_stream(SEGMENT *streams, int number_of_streams)
-    int r, c;
-    int i;
+    int i, j, k, n;
     STREAM *SA;
+			break;
+		    break;
-	else {
-	    Segment_get(streams, &SA[i].next_stream, r, c);
     return 0;
Modified: grass-addons/grass7/raster/r.stream.segment/stream_vector.c
--- grass-addons/grass7/raster/r.stream.segment/stream_vector.c	2015-03-12 09:10:17 UTC (rev 64836)
+++ grass-addons/grass7/raster/r.stream.segment/stream_vector.c	2015-03-12 09:36:23 UTC (rev 64837)
@@ -16,7 +16,7 @@
     dbDriver *driver;
     dbHandle handle;
     char *cat_col_name = "cat";
-    char buf[1000];
+    char buf[1000], buf2[1000];
     int sector_category, segment, sector, order;
     double direction, azimuth, length, stright, sinusoid;
@@ -44,8 +44,8 @@
 		    c = NC(d);
 		else {
-		    r = (int)SA[i].points[k] / ncols;
-		    c = (int)SA[i].points[k] % ncols;
+		    r = (int)(SA[i].points[k] / ncols);
+		    c = (int)(SA[i].points[k] % ncols);
 		easting = window.west + (c + .5) * window.ew_res;
 		northing = window.north - (r + .5) * window.ns_res;
@@ -127,12 +127,71 @@
 		azimuth = RAD2DEG(azimuth);
+#if 0
 	    sprintf(buf, "insert into %s values( %d, %d, %d, %d, "
                     "%f, %f, %f, %f, %f, "
                     "%f, %f, %f, %f)", Fi->table, sector_category, segment, sector, order,	/*4 */
 		    direction, azimuth, length, stright, sinusoid,	/*9 */
 		    elev_max, elev_min, drop, gradient);	/*13 */
+#endif
+	    sprintf(buf, "insert into %s values( %d, %d, %d, %d, ",
+	            Fi->table, sector_category, segment, sector, order);
+	    if (Rast_is_d_null_value(&direction))
+		sprintf(buf2, "null, ");
+	    else
+		sprintf(buf2, "%g, ", direction);
+	    strcat(buf, buf2);
+	    if (Rast_is_d_null_value(&azimuth))
+	    else
+		sprintf(buf2, "%g, ", azimuth);
+	    if (Rast_is_d_null_value(&length))
+	    else
+		sprintf(buf2, "%g, ", length);
+	    if (Rast_is_d_null_value(&stright))
+	    else
+		sprintf(buf2, "%g, ", stright);
+	    if (Rast_is_d_null_value(&sinusoid))
+	    else
+		sprintf(buf2, "%g, ", sinusoid);
+	    if (Rast_is_d_null_value(&elev_max))
+	    else
+		sprintf(buf2, "%g, ", elev_max);
+	    if (Rast_is_d_null_value(&elev_min))
+	    else
+		sprintf(buf2, "%g, ", elev_min);
+	    if (Rast_is_d_null_value(&drop))
+	    else
+		sprintf(buf2, "%g, ", drop);
+	    if (Rast_is_d_null_value(&gradient))
+		sprintf(buf2, "null )");
+	    else
+		sprintf(buf2, "%g )", gradient);
 	    db_set_string(&db_sql, buf);
 	    if (db_execute_immediate(driver, &db_sql) != DB_OK) {
@@ -171,7 +230,7 @@
     dbDriver *driver;
     dbHandle handle;
-    char buf[1000];
     /* variables to store table attributes */
     int last;
@@ -302,6 +361,7 @@
 	    next_azimuth = RAD2DEG(next_azimuth);
+#if 0
 	sprintf(buf, "insert into %s values( %d, %d, %d, %d, %d, "
                 "%f, %f, %f, %f, "
@@ -311,7 +371,119 @@
 		elev_max, elev_min, drop, gradient,	/*14 */
 		out_direction, out_azimuth, out_length, out_drop, out_gradient,	/*19 */
 		tangent_dir, tangent_azimuth, next_direction, next_azimuth);	/*23 */
+#endif
+	sprintf(buf, "insert into %s values( %d, %d, %d, %d, %d, ",
+	        Fi->table, i, segment, next_segment, order, next_order);
+	else
+	else
+	else
+	else
+	else
+	else
+	else
+	else
+	else
+	    sprintf(buf2, "%g, ", gradient);
+	if (Rast_is_d_null_value(&out_direction))
+	else
+	    sprintf(buf2, "%g, ", out_direction);
+	if (Rast_is_d_null_value(&out_azimuth))
+	else
+	    sprintf(buf2, "%g, ", out_azimuth);
+	if (Rast_is_d_null_value(&out_length))
+	else
+	    sprintf(buf2, "%g, ", out_length);
+	if (Rast_is_d_null_value(&out_drop))
+	else
+	    sprintf(buf2, "%g, ", out_drop);
+	if (Rast_is_d_null_value(&out_gradient))
+	else
+	    sprintf(buf2, "%g, ", out_gradient);
+	if (Rast_is_d_null_value(&tangent_dir))
+	else
+	    sprintf(buf2, "%g, ", tangent_dir);
+	if (Rast_is_d_null_value(&tangent_azimuth))
+	else
+	    sprintf(buf2, "%g, ", tangent_azimuth);
+	if (Rast_is_d_null_value(&next_direction))
+	else
+	    sprintf(buf2, "%g, ", next_direction);
+	if (Rast_is_d_null_value(&next_azimuth))
+	else
+	    sprintf(buf2, "%g )", next_azimuth);
