[GRASS-SVN] r64855 - in grass/trunk/gui/wxpython: gui_core lmgr
svn_grass at osgeo.org
Sat Mar 14 10:55:55 PDT 2015
Author: martinl
Date: 2015-03-14 10:55:55 -0700 (Sat, 14 Mar 2015)
New Revision: 64855
grass/trunk/gui/wxpython/gui_core/forms.py
grass/trunk/gui/wxpython/lmgr/giface.py
wxGUI: gselect.Select() - show grouped maps from map display
Modified: grass/trunk/gui/wxpython/gui_core/forms.py
--- grass/trunk/gui/wxpython/gui_core/forms.py 2015-03-14 14:46:29 UTC (rev 64854)
+++ grass/trunk/gui/wxpython/gui_core/forms.py 2015-03-14 17:55:55 UTC (rev 64855)
@@ -1199,11 +1199,20 @@
if maps_param and orig_elem == 'stds':
element_dict = {'raster': 'strds', 'vector': 'stvds', 'raster_3d': 'str3ds'}
elem = element_dict[type_param.get('default')]
- if self._giface and hasattr(self._giface, "_model"):
- extraItems = {_('Graphical Modeler') : self._giface.GetLayerList(p.get('prompt'))}
- else:
- extraItems = None
+ extraItems = None
+ if self._giface:
+ if hasattr(self._giface, "_model"):
+ extraItems = {_('Graphical Modeler') : self._giface.GetLayerList(p.get('prompt'))}
+ else:
+ layers = self._giface.GetLayerList()
+ if layers:
+ mapList = []
+ extraItems = {_('Map Display') : mapList}
+ for layer in layers:
+ if layer.type != p.get('prompt'):
+ continue
+ mapList.append(str(layer))
selection = gselect.Select(parent = which_panel, id = wx.ID_ANY,
size = globalvar.DIALOG_GSELECT_SIZE,
type = elem, multiple = multiple, nmaps = len(p.get('key_desc', [])),
Modified: grass/trunk/gui/wxpython/lmgr/giface.py
--- grass/trunk/gui/wxpython/lmgr/giface.py 2015-03-14 14:46:29 UTC (rev 64854)
+++ grass/trunk/gui/wxpython/lmgr/giface.py 2015-03-14 17:55:55 UTC (rev 64855)
@@ -49,9 +49,11 @@
def __iter__(self):
"""Iterates over the contents of the list."""
- for item in self._tree.GetSelectedLayer(multi=True):
+ item = self._tree.GetFirstChild(self._tree.root)[0]
+ while item and item.IsOk():
yield Layer(self._tree.GetPyData(item))
+ item = self._tree.GetNextItem(item)
def __getitem__(self, index):
"""Select a layer from the LayerList using the index."""
return [l for l in self][index]
