[GRASS-SVN] r64861 - grass/branches/releasebranch_7_0/display/d.vect.chart
Sun Mar 15 06:01:07 PDT 2015
Author: mmetz
Date: 2015-03-15 06:01:07 -0700 (Sun, 15 Mar 2015)
New Revision: 64861
   grass/branches/releasebranch_7_0/display/d.vect.chart/main.c
   grass/branches/releasebranch_7_0/display/d.vect.chart/pie.c
d.vect.chart: bug fixes
Modified: grass/branches/releasebranch_7_0/display/d.vect.chart/main.c
--- grass/branches/releasebranch_7_0/display/d.vect.chart/main.c	2015-03-15 09:13:02 UTC (rev 64860)
+++ grass/branches/releasebranch_7_0/display/d.vect.chart/main.c	2015-03-15 13:01:07 UTC (rev 64861)
@@ -189,7 +189,7 @@
     colors = (COLOR *) G_malloc(ncols * sizeof(COLOR));
     /* Fill max_reference values */
-    max_reference = (double *)G_malloc(ncols * sizeof(double));
+    max_reference = NULL;
     /* default colors */
     j = 0;
@@ -247,6 +247,7 @@
     /* should we plot the maximum reference on bar plots? */
     if (max_reference_opt->answer != NULL) {
+	max_reference = (double *)G_malloc(ncols * sizeof(double));
 	/* loop through the given values */
 	for (i = 0; i < ncols; i++) {
Modified: grass/branches/releasebranch_7_0/display/d.vect.chart/pie.c
--- grass/branches/releasebranch_7_0/display/d.vect.chart/pie.c	2015-03-15 09:13:02 UTC (rev 64860)
+++ grass/branches/releasebranch_7_0/display/d.vect.chart/pie.c	2015-03-15 13:01:07 UTC (rev 64861)
@@ -32,14 +32,16 @@
     sum = 0;
     ang = 0;
+	if (val[i] == 0)
+	    continue;
 	sum += val[i];
-	if (tot_sum > 0.0)
-           end_ang = 2 * PI * sum / tot_sum;
-        else
-           end_ang = 0;
+	end_ang = 2 * PI * sum / tot_sum;
 	Vect_reset_line(Points);
-	if (val[0] != tot_sum)	/* all in one slice, don't draw line to center */
+	if (val[i] != tot_sum)    /* all in one slice, don't draw line to center */
 	    Vect_append_point(Points, cx, cy, 0);
 	n = (int)ceil((end_ang - ang) / step);
@@ -52,7 +54,7 @@
 	ang = end_ang;
 	if (!colors[i].none) {
