[GRASS-SVN] r64864 - grass-addons/grass7/raster/r.maxent.lambdas
svn_grass at osgeo.org
Sun Mar 15 07:50:23 PDT 2015
Author: pvanbosgeo
Date: 2015-03-15 07:50:22 -0700 (Sun, 15 Mar 2015)
New Revision: 64864
grass-addons/grass7/raster/r.maxent.lambdas/r.maxent.lambdas
correct for new G7 r.mapcalc syntax
Modified: grass-addons/grass7/raster/r.maxent.lambdas/r.maxent.lambdas
--- grass-addons/grass7/raster/r.maxent.lambdas/r.maxent.lambdas 2015-03-15 14:42:33 UTC (rev 64863)
+++ grass-addons/grass7/raster/r.maxent.lambdas/r.maxent.lambdas 2015-03-15 14:50:22 UTC (rev 64864)
@@ -190,7 +190,7 @@
densityNormalizer=$(cat ${LAMBDAS_FILE} | grep densityNormalizer | sed 's/ //g' | tr -d '\r' | cut -f2 -d",")
entropy=$(cat ${LAMBDAS_FILE} | grep entropy | sed 's/ //g' | tr -d '\r' | cut -f2 -d",")
###Create file with initial part of mapcalc-expression
-echo "${OUTPUT_PREFIX}_raw=exp(((\\" > "$temp1"
+echo "${OUTPUT_PREFIX}_raw = exp(((\\" > "$temp1"
###Extract raw features
cat -v "${LAMBDAS_FILE}" | awk '$0 !~ /\^|\(|\*/' | grep -vP "\`" | grep -vP "\'" | sed 's/\^M//g' | sed 's/,//g' | awk 'NF==4{print "if(isnull(" $1 "),0,(" $2 "*(" $1 "-" $3 ")/(" $4 "-" $3 ")))" "+" "\\"}' | sed 's/--/+/g' | sed 's/+-/-/g' >> $temp1
###Extract quadratic features
@@ -251,21 +251,21 @@
###Compute logistic output map if not suppressed
if [ "${FLAG_ONLY_RAW}" -eq 0 ] ; then
if [ "${INTEGER_OUTPUT}" -le 0 ] ; then
- echo "${OUTPUT_PREFIX}_logistic=(${OUTPUT_PREFIX}_raw*exp(${entropy}))/(1.0+(${OUTPUT_PREFIX}_raw*exp(${entropy})))" >> "$temp1"
- r.mapcalc "${OUTPUT_PREFIX}_logistic=(${OUTPUT_PREFIX}_raw*exp(${entropy}))/(1.0+(${OUTPUT_PREFIX}_raw*exp(${entropy})))"
+ echo "${OUTPUT_PREFIX}_logistic = (${OUTPUT_PREFIX}_raw*exp(${entropy}))/(1.0+(${OUTPUT_PREFIX}_raw*exp(${entropy})))" >> "$temp1"
+ r.mapcalc "${OUTPUT_PREFIX}_logistic = (${OUTPUT_PREFIX}_raw*exp(${entropy}))/(1.0+(${OUTPUT_PREFIX}_raw*exp(${entropy})))"
else
if [ "${INTEGER_OUTPUT}" -lt 5 ] ; then
- echo "${OUTPUT_PREFIX}_logistic=round(((${OUTPUT_PREFIX}_raw*exp(${entropy}))/(1.0+(${OUTPUT_PREFIX}_raw*exp(${entropy}))))*(10^${INTEGER_OUTPUT}))" >> "$temp1"
- r.mapcalc "${OUTPUT_PREFIX}_logistic=round(((${OUTPUT_PREFIX}_raw*exp(${entropy}))/(1.0+(${OUTPUT_PREFIX}_raw*exp(${entropy}))))*(10^${INTEGER_OUTPUT}))"
+ echo "${OUTPUT_PREFIX}_logistic = round(((${OUTPUT_PREFIX}_raw*exp(${entropy}))/(1.0+(${OUTPUT_PREFIX}_raw*exp(${entropy}))))*(10^${INTEGER_OUTPUT}))" >> "$temp1"
+ r.mapcalc "${OUTPUT_PREFIX}_logistic = round(((${OUTPUT_PREFIX}_raw*exp(${entropy}))/(1.0+(${OUTPUT_PREFIX}_raw*exp(${entropy}))))*(10^${INTEGER_OUTPUT}))"
else
- echo "${OUTPUT_PREFIX}_logistic=round(((${OUTPUT_PREFIX}_raw*exp(${entropy}))/(1.0+(${OUTPUT_PREFIX}_raw*exp(${entropy}))))*100000.0)" >> "$temp1"
- r.mapcalc "${OUTPUT_PREFIX}_logistic=round(((${OUTPUT_PREFIX}_raw*exp(${entropy}))/(1.0+(${OUTPUT_PREFIX}_raw*exp(${entropy}))))*100000.0)"
+ echo "${OUTPUT_PREFIX}_logistic = round(((${OUTPUT_PREFIX}_raw*exp(${entropy}))/(1.0+(${OUTPUT_PREFIX}_raw*exp(${entropy}))))*100000.0)" >> "$temp1"
+ r.mapcalc "${OUTPUT_PREFIX}_logistic = round(((${OUTPUT_PREFIX}_raw*exp(${entropy}))/(1.0+(${OUTPUT_PREFIX}_raw*exp(${entropy}))))*100000.0)"
fi
fi
fi
###Remove raw output map if requested
if [ "${FLAG_ONLY_LOGISTIC}" -eq 1 ] ; then
- g.remove -f rast="${OUTPUT_PREFIX}"_raw
+ g.remove -f type='rast' name="${OUTPUT_PREFIX}"_raw
fi
###Remove tmp-file containing r.mapcalc expressions (if save to file not requested)
if [ -z "$OUTPUT_MAPCALC" ] ; then
