[GRASS-SVN] r64870 - grass/trunk/vector/v.in.ogr
svn_grass at osgeo.org
Sun Mar 15 13:14:38 PDT 2015
Author: mmetz
Date: 2015-03-15 13:14:38 -0700 (Sun, 15 Mar 2015)
New Revision: 64870
grass/trunk/vector/v.in.ogr/geom.c
grass/trunk/vector/v.in.ogr/main.c
v.in.ogr: fix r64353
Modified: grass/trunk/vector/v.in.ogr/geom.c
--- grass/trunk/vector/v.in.ogr/geom.c 2015-03-15 18:00:23 UTC (rev 64869)
+++ grass/trunk/vector/v.in.ogr/geom.c 2015-03-15 20:14:38 UTC (rev 64870)
@@ -140,7 +140,7 @@
in = 1;
for (j = 0; j < valid_isles; j++) {
ret = Vect_point_in_poly(x, y, IPoints[j]);
- if (ret == 1) { /* centroid in inner ring */
+ if (ret > 0) { /* centroid in inner ring */
in = 0;
break; /* inside isle */
Modified: grass/trunk/vector/v.in.ogr/main.c
--- grass/trunk/vector/v.in.ogr/main.c 2015-03-15 18:00:23 UTC (rev 64869)
+++ grass/trunk/vector/v.in.ogr/main.c 2015-03-15 20:14:38 UTC (rev 64870)
@@ -180,7 +180,7 @@
param.min_area->required = NO;
param.min_area->answer = "0.0001";
param.min_area->label =
- _("Minimum size of area to be imported (square units)");
+ _("Minimum size of area to be imported (square meters)");
param.min_area->guisection = _("Selection");
param.min_area->description = _("Smaller areas and "
"islands are ignored. Should be greater than snap^2");
@@ -204,7 +204,7 @@
param.snap->type = TYPE_DOUBLE;
param.snap->required = NO;
param.snap->answer = "-1";
- param.snap->label = _("Snapping threshold for boundaries");
+ param.snap->label = _("Snapping threshold for boundaries (map units)");
param.snap->description = _("'-1' for no snap");
param.outloc = G_define_option();
@@ -533,8 +533,44 @@
proj_units = NULL;
Ogr_projection = OGR_L_GetSpatialRef(Ogr_layer); /* should not be freed later */
- /* Do we need to create a new location? */
+ /* fetch boundaries */
G_get_window(&cellhd);
+ if ((OGR_L_GetExtent(Ogr_layer, &oExt, 1)) == OGRERR_NONE) {
+ cellhd.north = ymax = oExt.MaxY;
+ cellhd.south = ymin = oExt.MinY;
+ cellhd.west = xmin = oExt.MinX;
+ cellhd.east = xmax = oExt.MaxX;
+ cellhd.rows = 20; /* TODO - calculate useful values */
+ cellhd.cols = 20;
+ cellhd.ns_res = (cellhd.north - cellhd.south) / cellhd.rows;
+ cellhd.ew_res = (cellhd.east - cellhd.west) / cellhd.cols;
+ /* use OGR extents if possible, needed to skip corrupted data
+ * in OGR dsn/layer */
+ have_ogr_extent = 1;
+ if (!have_ogr_extent) {
+ cellhd.north = 1.;
+ cellhd.south = 0.;
+ cellhd.west = 0.;
+ cellhd.east = 1.;
+ cellhd.top = 1.;
+ cellhd.bottom = 1.;
+ cellhd.rows = 1;
+ cellhd.rows3 = 1;
+ cellhd.cols = 1;
+ cellhd.cols3 = 1;
+ cellhd.depths = 1;
+ cellhd.ns_res = 1.;
+ cellhd.ns_res3 = 1.;
+ cellhd.ew_res = 1.;
+ cellhd.ew_res3 = 1.;
+ cellhd.tb_res = 1.;
+ /* Do we need to create a new location? */
if (param.outloc->answer != NULL) {
/* Convert projection information non-interactively as we can't
* assume the user has a terminal open */
@@ -555,9 +591,8 @@
- /* If the i flag is set, clean up? and exit here */
- if(flag.no_import->answer)
+ /* If the i flag is set, clean up and exit here */
+ if (flag.no_import->answer) {
OGR_DS_Destroy(Ogr_ds);
exit(EXIT_SUCCESS);
@@ -667,47 +702,8 @@
- G_begin_polygon_area_calculations(); /* Used in geom() */
+ G_begin_polygon_area_calculations(); /* Used in geom() and centroid() */
- /* TODO: threshold might be recalculated with optional geodesic support to meters */
- if (G_projection() == PROJECTION_LL)
- G_important_message(_("Note: In latitude-longitude coordinate system specify threshold in degree unit"));
- /* fetch boundaries */
- if ((OGR_L_GetExtent(Ogr_layer, &oExt, 1)) == OGRERR_NONE) {
- cellhd.north = ymax = oExt.MaxY;
- cellhd.south = ymin = oExt.MinY;
- cellhd.west = xmin = oExt.MinX;
- cellhd.east = xmax = oExt.MaxX;
- cellhd.rows = 20; /* TODO - calculate useful values */
- cellhd.cols = 20;
- cellhd.ns_res = (cellhd.north - cellhd.south) / cellhd.rows;
- cellhd.ew_res = (cellhd.east - cellhd.west) / cellhd.cols;
- /* use OGR extents if possible, needed to skip corrupted data
- * in OGR dsn/layer */
- have_ogr_extent = 1;
- if (!have_ogr_extent) {
- cellhd.north = 1.;
- cellhd.south = 0.;
- cellhd.west = 0.;
- cellhd.east = 1.;
- cellhd.top = 1.;
- cellhd.bottom = 1.;
- cellhd.rows = 1;
- cellhd.rows3 = 1;
- cellhd.cols = 1;
- cellhd.cols3 = 1;
- cellhd.depths = 1;
- cellhd.ns_res = 1.;
- cellhd.ns_res3 = 1.;
- cellhd.ew_res = 1.;
- cellhd.ew_res3 = 1.;
- cellhd.tb_res = 1.;
/* set spatial filter */
if (flag.region->answer) {
if (param.spat->answer)
@@ -715,6 +711,9 @@
if (nlayers > 1)
G_warning(_("The region flag is applied only to the first OGR layer"));
+ /* TODO: does not make sense if a new location has been created:
+ * the current window has been set from the extents of the first
+ * OGR layer */
G_get_window(&cur_wind);
if (have_ogr_extent) {
/* check for any overlap */
