[GRASS-SVN] r64880 - grass/branches/develbranch_6/lib/vector/Vlib
svn_grass at osgeo.org
Tue Mar 17 01:43:33 PDT 2015
Author: mmetz
Date: 2015-03-17 01:43:33 -0700 (Tue, 17 Mar 2015)
New Revision: 64880
grass/branches/develbranch_6/lib/vector/Vlib/break_polygons.c
grass/branches/develbranch_6/lib/vector/Vlib/build_nat.c
grass/branches/develbranch_6/lib/vector/Vlib/header.c
grass/branches/develbranch_6/lib/vector/Vlib/poly.c
Vlib: sync 64, 65
Modified: grass/branches/develbranch_6/lib/vector/Vlib/break_polygons.c
--- grass/branches/develbranch_6/lib/vector/Vlib/break_polygons.c 2015-03-17 08:43:21 UTC (rev 64879)
+++ grass/branches/develbranch_6/lib/vector/Vlib/break_polygons.c 2015-03-17 08:43:33 UTC (rev 64880)
@@ -63,9 +63,11 @@
static int fpoint;
/* Function called from RTreeSearch for point found */
-void srch(int id, int *arg)
+int srch(int id, int *arg)
fpoint = id;
+ return 0;
Modified: grass/branches/develbranch_6/lib/vector/Vlib/build_nat.c
--- grass/branches/develbranch_6/lib/vector/Vlib/build_nat.c 2015-03-17 08:43:21 UTC (rev 64879)
+++ grass/branches/develbranch_6/lib/vector/Vlib/build_nat.c 2015-03-17 08:43:33 UTC (rev 64880)
@@ -313,6 +313,10 @@
for (i = 0; i < List->n_values; i++) {
isle = List->value[i];
+ if (plus->Isle[isle]->area > 0) {
+ dig_area_del_isle(plus, plus->Isle[isle]->area, isle);
+ plus->Isle[isle]->area = 0;
Vect_attach_isle(Map, isle);
return 0;
@@ -364,10 +368,6 @@
* to check if original area exist, unregister centroid from previous area.
* To simplify code, this is implemented so that centroid is always firs unregistered
* and if new area is found, it is registered again.
- * This problem can be avoided altogether if properly attached centroids
- * are skipped
- * MM 2009
Vect_select_lines_by_box(Map, box, GV_CENTROID, List);
@@ -378,15 +378,14 @@
centr = List->value[i];
Line = plus->Line[centr];
- /* only attach unregistered and duplicate centroids because
- * 1) all properly attached centroids are properly attached, really! Don't touch.
- * 2) Vect_find_area() below does not always return the correct area
- * 3) it's faster
- if (Line->left > 0)
- continue;
+ /* Unregister centroid */
orig_area = Line->left;
+ if (orig_area > 0) {
+ if (plus->Area[orig_area] != NULL) {
+ plus->Area[orig_area]->centroid = 0;
+ Line->left = 0;
sel_area = Vect_find_area(Map, Line->E, Line->N);
G_debug(3, " centroid %d is in area %d", centr, sel_area);
@@ -410,6 +409,8 @@
dig_line_add_updated(plus, centr);
+ else if (orig_area != 0 && plus->do_uplist)
+ dig_line_add_updated(plus, centr);
return 0;
@@ -510,7 +511,6 @@
/* register lines, create nodes */
Vect_rewind(Map);
G_message(_("Registering primitives..."));
i = 1;
npoints = 0;
Modified: grass/branches/develbranch_6/lib/vector/Vlib/header.c
--- grass/branches/develbranch_6/lib/vector/Vlib/header.c 2015-03-17 08:43:21 UTC (rev 64879)
+++ grass/branches/develbranch_6/lib/vector/Vlib/header.c 2015-03-17 08:43:33 UTC (rev 64880)
@@ -493,7 +493,7 @@
\param Map vector map
- \return poiter to projection name
+ \return pointer to projection name
const char *Vect_get_proj_name(struct Map_info *Map)
Modified: grass/branches/develbranch_6/lib/vector/Vlib/poly.c
--- grass/branches/develbranch_6/lib/vector/Vlib/poly.c 2015-03-17 08:43:21 UTC (rev 64879)
+++ grass/branches/develbranch_6/lib/vector/Vlib/poly.c 2015-03-17 08:43:33 UTC (rev 64880)
@@ -636,7 +636,7 @@
x_inter = dig_x_intersect(x1, x2, y1, y2, Y);
G_debug(3, "x_inter = %f", x_inter);
if (x_inter == X)
- return 1;
+ return -1; /* point on segment, do not assume inside/outside */
else if (x_inter > X)
n_intersects++;
