[GRASS-SVN] r64887 - grass-addons/grass7/gui/wxpython/wx.mwprecip
svn_grass at osgeo.org
Fri Mar 20 05:18:23 PDT 2015
Author: krejcmat
Date: 2015-03-20 05:18:23 -0700 (Fri, 20 Mar 2015)
New Revision: 64887
Removed:
grass-addons/grass7/gui/wxpython/wx.mwprecip/wx.mwprecip.py
grass-addons/grass7/gui/wxpython/wx.mwprecip/g.gui.mwprecip.py
grass-addons/grass7/gui/wxpython/wx.mwprecip/mw3.py
grass-addons/grass7/gui/wxpython/wx.mwprecip/mw_util.py
grass-addons/grass7/gui/wxpython/wx.mwprecip/pgwrapper.py
save-load fix
Modified: grass-addons/grass7/gui/wxpython/wx.mwprecip/g.gui.mwprecip.py
--- grass-addons/grass7/gui/wxpython/wx.mwprecip/g.gui.mwprecip.py 2015-03-19 18:24:26 UTC (rev 64886)
+++ grass-addons/grass7/gui/wxpython/wx.mwprecip/g.gui.mwprecip.py 2015-03-20 12:18:23 UTC (rev 64887)
@@ -2,15 +2,13 @@
import os
import sys
-from grass.script import core as grass
-sys.path.insert(1, os.path.join(os.path.dirname(sys.path[0]), 'etc', 'g.gui.mwprecip'))
from mw_util import *
+from mw3 import *
+sys.path.insert(1, os.path.join(os.path.dirname(sys.path[0]), 'etc', 'g.gui.mwprecip'))
from core.gcmd import GMessage, GError
from gui_core import gselect
class DBconn(wx.Panel):
def __init__(self, parent, settings={}):
wx.Panel.__init__(self, parent=parent, id=wx.ID_ANY)
@@ -47,31 +45,18 @@
if sett:
self.settings = sett
- try:
+ if 'database' in self.settings:
self.database.SetValue(self.settings['database'])
- except:
- print 'err'
- pass
- try:
+ if 'schema' in self.settings:
self.schema.SetValue(self.settings['schema'])
- except:
- pass
- try:
+ if 'host' in self.settings:
self.host.SetValue(self.settings['host'])
- except:
- pass
- try:
+ if 'user' in self.settings:
self.user.SetValue(self.settings['user'])
- except:
- pass
- try:
+ if 'port' in self.settings:
self.port.SetValue(self.settings['port'])
- except:
- pass
- try:
+ if 'passwd' in self.settings:
self.passwd.SetValue(self.settings['passwd'])
- except:
- pass
def saveSettings(self, settings=None):
if settings is not None:
@@ -119,14 +104,10 @@
def loadSettings(self, sett=None):
if sett:
- try:
+ if 'pitypeDist' in self.settings:
self.rb1.SetValue(self.settings['pitypeDist'])
- except:
- pass
- try:
+ if 'pivalue' in self.settings:
self.val.SetValue(self.settings['pivalue'])
- except:
- pass
@@ -164,39 +145,22 @@
if sett is not None:
- try:
+ if 'fromFile' in self.settings:
self.fromFile.SetValue(self.settings['fromFile'])
- except:
- pass
- try:
+ if 'dryWin' in self.settings:
self.dryWin.SetValue(self.settings['dryWin'])
- except:
- pass
- try:
+ if 'quantile' in self.settings:
self.quantile.SetValue(self.settings['quantile'])
- except:
- pass
- try:
+ if 'baselType' in self.settings:
self.baselType.SetValue(self.settings['baselType'])
- except:
- pass
- try:
+ if 'round' in self.settings:
self.round.SetValue(self.settings['round'])
- except:
- pass
- try:
+ if 'aw' in self.settings:
self.aw.SetValue(self.settings['aw'])
- except:
- pass
- try:
+ if 'dryInterval' in self.settings:
self.dryInterval.SetPath(self.settings['dryInterval'])
- except:
- pass
- try:
+ if 'fromFileVal' in self.settings:
self.fromFileVal.SetPath(self.settings['fromFileVal'])
- except:
- pass
self.onChangeMethod()
def saveSettings(self, evt=None, sett=None):
@@ -269,13 +233,13 @@
self.linksAll.Bind(wx.EVT_RADIOBUTTON, self.refreshLinkSet)
self.linksIngnore.Bind(wx.EVT_RADIOBUTTON, self.refreshLinkSet)
self.linksOnly.Bind(wx.EVT_RADIOBUTTON, self.refreshLinkSet)
- self.vectorMap = wx.RadioButton(self,label='Vector map')
- self.vectorMap.Bind(wx.EVT_RADIOBUTTON,self.refreshLinkSet)
+ self.vectorMap = wx.RadioButton(self, label='Vector map')
+ self.vectorMap.Bind(wx.EVT_RADIOBUTTON, self.refreshLinkSet)
# self.links = BaseInput(self,'Set links according to radio above',True)
self.links = BaseInput(self, 'Set links according to radio above')
- self.mapLabel=wx.StaticText(self,label='Select vector map')
- self.map = gselect.Select(self, type='vector',multiple=False)
+ self.mapLabel = wx.StaticText(self, label='Select vector map')
+ self.map = gselect.Select(self, type='vector', multiple=False)
self.start = BaseInput(self, label='Start time')
self.end = BaseInput(self, label='End time')
@@ -285,14 +249,14 @@
self.stBoxGauge = wx.StaticBox(self, wx.ID_ANY, 'Rain gauge')
self.inpRainGauge = FileInput(self, 'Select folder with raingauges data')
- self.inpRainGauge.pathInput.Bind(wx.EVT_TEXT,self.disableLinksInp)
+ self.inpRainGauge.pathInput.Bind(wx.EVT_TEXT, self.disableLinksInp)
# self.sb1 = wx.StaticBox(self, wx.ID_ANY, 'Baseline')
# self.type = self.rb1 = wx.RadioButton(self, label='Number of points', style=wx.RB_GROUP)
if len(settings) > 0:
self.loadSettings()
self._layout()
- def disableLinksInp(self,evt=None):
+ def disableLinksInp(self, evt=None):
if self.inpRainGauge.GetPath() is not None:
self.linksAll.Disable()
self.linksOnly.Disable()
@@ -344,39 +308,24 @@
if sett:
- try:
- self.map.SetValue(eval(self.settings['linksMap']))
- except:
- pass
- try:
- self.linksOnly.SetValue(eval(self.settings['linksOnly']))
- except:
- pass
- try:
- self.linksIngnore.SetValue(eval(self.settings['linksIngnore']))
- except:
- pass
- try:
+ if 'linksMap' in self.settings:
+ self.map.SetValue(self.settings['linksMap'])
+ if 'linksOnly' in self.settings:
+ self.linksOnly.SetValue(self.settings['linksOnly'])
+ if 'linksIgnore' in self.settings:
+ self.linksIngnore.SetValue(self.settings['linksIngnore'])
+ if 'links' in self.settings:
self.links.SetValue(self.settings['links'])
- except:
- pass
- try:
+ if 'start' in self.settings:
self.start.SetValue(self.settings['start'])
- except:
- pass
- try:
+ if 'end' in self.settings:
self.end.SetValue(self.settings['end'])
- except:
- pass
- try:
+ if 'sumStep' in self.settings:
self.sumStep.SetValue(self.settings['sumStep'])
- except:
- pass
- try:
+ if 'inpRainGauge' in self.settings:
self.inpRainGauge.SetPath(self.settings['inpRainGauge'])
- except:
- pass
def _layout(self):
panelSizer = wx.BoxSizer(wx.VERTICAL)
self.SetSizerAndFit(panelSizer)
@@ -417,26 +366,22 @@
self.refreshLinkSet()
class GrassLayers(wx.Panel):
self.settings = settings
- self.colorRules = TextInput(self,label='Color table')
- self.colorsName = BaseInput(self,label='Name of color table')
+ self.colorRules = TextInput(self, label='Color table')
+ self.colorsName = BaseInput(self, label='Name of color table')
self.layout()
if sett:
- try:
+ if 'colorRules' in self.settings:
self.colorRules.SetValue(self.settings['colorRules'])
- except:
- pass
- try:
+ if 'colorName' in self.settings:
self.colorsName.SetValue(self.settings['colorsName'])
- except:
- pass
if sett:
@@ -447,73 +392,76 @@
def layout(self):
- panelSizer.Add(self.colorsName,flag= wx.EXPAND )
- panelSizer.Add(self.colorRules, flag=wx.EXPAND )
+ panelSizer.Add(self.colorsName, flag=wx.EXPAND)
+ panelSizer.Add(self.colorRules, flag=wx.EXPAND)
class GeometryPanel(wx.Panel):
- self.label=wx.StaticText(self,label='Create vector geometry map')
+ self.label = wx.StaticText(self, label='Create vector geometry map')
self.linksExp = wx.RadioButton(self, label='Links', style=wx.RB_GROUP)
self.nodesExp = wx.RadioButton(self, label='Nodes')
- self.mapName=BaseInput(self,'Map name')
- self.bttExport=wx.Button(self,label='Export')
+ self.mapName = BaseInput(self, 'Map name')
+ self.bttExport = wx.Button(self, label='Export')
self.layout()
def layout(self):
- panelSizer.Add(self.label,flag=wx.EXPAND)
- panelSizer.Add(self.linksExp,flag=wx.EXPAND)
- panelSizer.Add(self.nodesExp,flag=wx.EXPAND)
- panelSizer.Add(self.mapName,flag=wx.EXPAND)
- panelSizer.Add(self.bttExport,flag=wx.EXPAND)
+ panelSizer.Add(self.label, flag=wx.EXPAND)
+ panelSizer.Add(self.linksExp, flag=wx.EXPAND)
+ panelSizer.Add(self.nodesExp, flag=wx.EXPAND)
+ panelSizer.Add(self.mapName, flag=wx.EXPAND)
+ panelSizer.Add(self.bttExport, flag=wx.EXPAND)
def GetOptions(self):
if self.linksExp.GetValue():
- type='links'
+ type = 'links'
else:
- type='nodes'
- return type,self.mapName.GetValue()
+ type = 'nodes'
+ return type, self.mapName.GetValue()
class ExportData(wx.Panel):
def __init__(self, parent):
- self.chkid=wx.CheckBox(self,label='linkid')
+ self.chkid = wx.CheckBox(self, label='linkid')
self.chkid.SetValue(True)
self.chkid.Disable()
- self.chktime=wx.CheckBox(self,label='time')
+ self.chktime = wx.CheckBox(self, label='time')
self.chktime.SetValue(True)
self.chktime.Disable()
- self.chkprecip=wx.CheckBox(self,label='precipitation')
- self.chkrx=wx.CheckBox(self,label='rx')
- self.chktx=wx.CheckBox(self,label='tx')
- self.chkfreq=wx.CheckBox(self,label='frequency')
- self.chkpol=wx.CheckBox(self,label='polarization')
- self.okBtt=wx.Button(self,label='export')
+ self.chkprecip = wx.CheckBox(self, label='precipitation')
+ self.chkrx = wx.CheckBox(self, label='rx')
+ self.chktx = wx.CheckBox(self, label='tx')
+ self.chkfreq = wx.CheckBox(self, label='frequency')
+ self.chkpol = wx.CheckBox(self, label='polarization')
+ self.okBtt = wx.Button(self, label='export')
self.layout()
- #self.chkprecip.Bind(wx.EVT_CHECKBOX,self.onChckPrec)
+ # self.chkprecip.Bind(wx.EVT_CHECKBOX,self.onChckPrec)
def layout(self):
- mainSizer=wx.BoxSizer(wx.VERTICAL)
+ mainSizer = wx.BoxSizer(wx.VERTICAL)
- mainSizer.Add(self.chkid,wx.EXPAND)
- mainSizer.Add(self.chktime,wx.EXPAND)
- mainSizer.Add(self.chkprecip,wx.EXPAND)
- mainSizer.Add(self.chkrx,wx.EXPAND)
- mainSizer.Add(self.chktx,wx.EXPAND)
- mainSizer.Add(self.chkfreq,wx.EXPAND)
- mainSizer.Add(self.chkpol,wx.EXPAND)
- mainSizer.Add(self.okBtt,wx.EXPAND)
+ mainSizer.Add(self.chkid, wx.EXPAND)
+ mainSizer.Add(self.chktime, wx.EXPAND)
+ mainSizer.Add(self.chkprecip, wx.EXPAND)
+ mainSizer.Add(self.chkrx, wx.EXPAND)
+ mainSizer.Add(self.chktx, wx.EXPAND)
+ mainSizer.Add(self.chkfreq, wx.EXPAND)
+ mainSizer.Add(self.chkpol, wx.EXPAND)
+ mainSizer.Add(self.okBtt, wx.EXPAND)
self.SetSizerAndFit(mainSizer)
class MyFrame(wx.Frame):
def __init__(self, parent, id, title):
wx.Frame.__init__(self, parent, id, title, size=(480, 640))
@@ -528,11 +476,11 @@
fileMenu = wx.Menu()
databaseItem = settMenu.Append(wx.ID_ANY, 'Database', 'Set database')
baselineItem = settMenu.Append(wx.ID_ANY, 'Baseline', 'Set baseline methods')
- geometry = settMenu.Append(wx.ID_ANY,'Geometry', 'Create vector geometry')
+ geometry = settMenu.Append(wx.ID_ANY, 'Geometry', 'Create vector geometry')
quitItem = settMenu.Append(wx.ID_EXIT, 'Quit', 'Quit application')
menubar.Append(settMenu, '&Options')
- #geoMenu = wx.Menu()
+ # geoMenu = wx.Menu()
#menubar.Append(geoMenu, '&Settings')
@@ -582,7 +530,6 @@
self.OnSaveSettings(toFile=False)
interface = Gui2Model(self, self.settings) # TODO optimalize init
if interface.connStatus:
self.dataMgrMW.start.SetValue(interface.dbConn.minTimestamp())
def getMaxTime(self, evt=None):
@@ -595,7 +542,7 @@
- return interface.dbConn
+ return interface.dbConn
def OnSchemeTxtChange(self, evt=None):
if self.schema.GetValue() is not None:
@@ -626,7 +573,6 @@
self.grassLayers.loadSettings(self.settings)
except:
pass
def OnSaveSettings(self, evt=None, toFile=True):
try:
self.settings = self.dataMgrMW.saveSettings(sett=self.settings)
@@ -648,12 +594,7 @@
self.settings = self.grassLayers.saveSettings(sett=self.settings)
except:
pass
- try:
- self.settings['workSchema'] = self.profilSelection.GetValue()
- except:
- pass
+ self.settings['workSchema'] = self.profilSelection.GetValue()
self.settings['workSchema'] = self.schema.GetValue()
@@ -663,11 +604,11 @@
self.findProject()
def initWorkingFoldrs(self):
- savePath=os.path.join(self.workPath,'save')
+ savePath = os.path.join(self.workPath, 'save')
if not os.path.exists(savePath):
os.makedirs(savePath)
- tmpPath=os.path.join(self.workPath,'temp')
+ tmpPath = os.path.join(self.workPath, 'temp')
if not os.path.exists(tmpPath):
os.makedirs(tmpPath)
@@ -688,7 +629,7 @@
else:
return
- def onSetGeometry(self,evt):
+ def onSetGeometry(self, evt):
self.geDialog = wx.Dialog(self, id=wx.ID_ANY,
title='Geometry creator',
style=wx.DEFAULT_DIALOG_STYLE | wx.RESIZE_BORDER,
@@ -711,15 +652,15 @@
self.geDialog.Destroy()
def _onSetGeomDLG(self, evt):
- type,name=self.geometryPnl.GetOptions()
+ type, name = self.geometryPnl.GetOptions()
if name == '':
GMessage('Please set name of map')
else:
- self.createGeometry(type,name)
- #self.addMapToLay()#TODO giface
+ self.createGeometry(type, name)
+ # self.addMapToLay()#TODO giface
- def addMapToLay(self,map):
- #TODO giface
+ def addMapToLay(self, map):
+ # TODO giface
tree = self._giface.GetLayerTree()
@@ -737,7 +678,7 @@
size=wx.DefaultSize,
pos=wx.DefaultPosition)
- #self.bsDialog.SetSize((500, 500))
+ # self.bsDialog.SetSize((500, 500))
if self.settings:
self.baselinePnl = BaselinePanel(self.bsDialog, self.settings)
@@ -785,17 +726,17 @@
print self.settings
self.dbDialog.Destroy()
- def createGeometry(self,type, name):
+ def createGeometry(self, type, name):
- interface.initVectorGrass(type=type,name=name)
+ interface.initVectorGrass(type=type, name=name)
def exportData(self, evt):
self.exportDialog = wx.Dialog(self, id=wx.ID_ANY,
- title='Database connection settings',
- style=wx.DEFAULT_DIALOG_STYLE | wx.RESIZE_BORDER,
- size=wx.DefaultSize,
- pos=wx.DefaultPosition)
+ title='Database connection settings',
+ style=wx.DEFAULT_DIALOG_STYLE | wx.RESIZE_BORDER,
+ size=wx.DefaultSize,
+ pos=wx.DefaultPosition)
self.exportDialog.SetSize((500, 500))
self.exportDMgr = ExportData(self.exportDialog)
@@ -808,15 +749,15 @@
self.exportDialog.ShowModal()
self.exportDialog.Destroy()
- def _onExport(self,evt=None):
- path=OnSaveAs(self)
+ def _onExport(self, evt=None):
+ path = OnSaveAs(self)
if not self.exportDMgr.chkprecip.GetValue():
- attrTmp1=[]
+ attrTmp1 = []
attrTmp1.append('link.linkid')
- attrTmp2=[]
- attrTmp3=[]
- #attrTmp2.append('public.linkid')
+ attrTmp2 = []
+ attrTmp3 = []
+ # attrTmp2.append('public.linkid')
if self.exportDMgr.chkfreq.GetValue():
attrTmp1.append('link.frequency')
if self.exportDMgr.chkpol.GetValue():
@@ -828,85 +769,85 @@
if self.exportDMgr.chktx.GetValue():
attrTmp2.append('record.txpower')
- attrTmp4='WHERE'
+ attrTmp4 = 'WHERE'
if len(attrTmp1) > 0:
attrTmp3.append('link')
if len(attrTmp2) > 0:
attrTmp3.append('record')
if len(attrTmp1) > 0 and len(attrTmp2) > 0:
- attrTmp4='WHERE link.linkid=record.linkid AND'
- attrTmp0=attrTmp1+attrTmp2
+ attrTmp4 = 'WHERE link.linkid=record.linkid AND'
+ attrTmp0 = attrTmp1 + attrTmp2
attrTmp0 = ",".join(attrTmp0)
elif len(attrTmp1) > 0:
attrTmp0 = ",".join(attrTmp1)
elif len(attrTmp2) > 0:
attrTmp0 = ",".join(attrTmp2)
- if len(attrTmp3)>1:
+ if len(attrTmp3) > 1:
attrTmp3 = ",".join(attrTmp3)
else:
- attrTmp3=attrTmp3[0]
+ attrTmp3 = attrTmp3[0]
- sql="SELECT %s FROM %s %s record.time>'%s' and record.time< '%s' "%(attrTmp0,
- attrTmp3,
- attrTmp4,
- self.dataMgrMW.start.GetValue(),
- self.dataMgrMW.end.GetValue())
- conn=self.GetConnection()
- res=conn.connection.executeSql(sql, True, True)
- lines=''
+ sql = "SELECT %s FROM %s %s record.time>'%s' and record.time< '%s' " % (attrTmp0,
+ attrTmp3,
+ attrTmp4,
+ self.dataMgrMW.start.GetValue(),
+ self.dataMgrMW.end.GetValue())
+ conn = self.GetConnection()
+ res = conn.connection.executeSql(sql, True, True)
+ lines = ''
for r in res:
- lines+=str(r)[1:][:-1].replace('datetime.datetime','').replace("'","") +'\n'
+ lines += str(r)[1:][:-1].replace('datetime.datetime', '').replace("'", "") + '\n'
print conn.pathworkSchemaDir
#path=os.path.join(conn.pathworkSchemaDir, "export")
io0 = open(path, "wr")
io0.writelines(lines)
io0.close()
- GMessage('Data exported<%s>'%path)
+ GMessage('Data exported<%s>' % path)
else:
- exportData = {'getData':True,'dataOnly':False}
+ exportData = {'getData': True, 'dataOnly': False}
if YesNo(self, 'Export data only?'):
exportData['dataOnly'] = True
self.settings['dataExport'] = exportData
- #if rain gauges
+ # if rain gauges
if self.dataMgrMW.inpRainGauge.GetPath() is not None:
- self.settings['IDtype']='gaugeid'
+ self.settings['IDtype'] = 'gaugeid'
else:
- self.settings['IDtype']='linkid'
+ self.settings['IDtype'] = 'linkid'
interface.initVectorGrass()
interface.initTimeWinMW()
interface.initBaseline()
interface.doCompute()
- sql='SELECT * FROM %s.%s'%(interface.dbConn.schema,interface.dbConn.computedPrecip)
- lines=''
+ sql = 'SELECT * FROM %s.%s' % (interface.dbConn.schema, interface.dbConn.computedPrecip)
+ lines = ''
for r in res:
- lines+=str(r)[1:][:-1] +'\n'
+ lines += str(r)[1:][:-1] + '\n'
io0.close()
def runCompute(self, evt):
- exportData = {'getData':False,'dataOnly':False}
+ exportData = {'getData': False, 'dataOnly': False}
- #if rain gauges
+ # if rain gauges
else:
@@ -938,55 +879,43 @@
def onQuit(self, e):
self.Close()
class Gui2Model():
def __init__(self, wxParent, settings):
parent = wxParent
self.dbConn = None
- self.connStatus=False
+ self.connStatus = False
self.initConnection()
def initConnection(self, info=False):
- conninfo=None
+ conninfo = None
try:
conninfo = {'name': self.settings['database']}
except:
GMessage('name of database is missing')
return
- try:
+ if 'workSchema' in self.settings:
conninfo['workSchema'] = self.settings['workSchema']
- except:
- pass
- try:
conninfo['dataSchema'] = self.settings['schema']
- except:
- pass
- try:
conninfo['host'] = self.settings['host']
- except:
- pass
- try:
conninfo['user'] = self.settings['user']
- except:
- pass
- try:
conninfo['port'] = self.settings['port']
- except:
- pass
- try:
conninfo['password'] = self.settings['passwd']
- except:
- pass
if conninfo is None:
GMessage('Database connection failed')
return
if not info: # prepare for computing
self.dbConn = Database(**conninfo)
- self.connStatus=True
+ self.connStatus = True
self.dbConn.firstPreparation()
self.dbConn.prepareDB()
self.dbConn.prepareDir()
@@ -994,78 +923,68 @@
return self.dbConn
else: # just get info about curr database state
return self.dbConn
- def initVectorGrass(self,type=None,name=None):
+ def initVectorGrass(self, type=None, name=None):
convertor = VectorLoader(self.dbConn)
if name:
- self.dbConn.nodeVecMapName=name
- self.dbConn.linkVecMapName=name
+ self.dbConn.nodeVecMapName = name
+ self.dbConn.linkVecMapName = name
- if type=='nodes' or type is None:
+ if type == 'nodes' or type is None:
# create native vector map(nodes)
pointsSQL = convertor.selectNodes()
# print pointsSQL
pointsASCII = convertor.getASCIInodes(pointsSQL)
convertor.grass_vinASCII(pointsASCII, self.dbConn.nodeVecMapName)
# create native vector map(links)
- if type=='links'or type is None:
+ if type == 'links' or type is None:
linksSQL = convertor.selectLinks()
linksASCII = convertor.getASCIIlinks(linksSQL)
convertor.grass_vinASCII(linksASCII, self.dbConn.linkVecMapName)
def initPInterpolation(self):
- try:
pitypeDist = self.settings['pitypeDist']
- except:
- pass
- try:
pivalue = self.settings['pivalue']
- except:
+ else:
self.errMsg('Missing value for interpolating points along lines')
PointInterpolation(self.dbConn, pivalue, pitypeDist)
def initBaseline(self):
baselInit = {}
- try:
baselInit['statFce'] = self.settings['baselType']
- except:
- pass
- try:
baselInit['quantile'] = self.settings['quantile']
- except:
- pass
- try:
baselInit['roundMode'] = self.settings['round']
- except:
- pass
- try:
baselInit['aw'] = self.settings['aw']
- except:
- pass
methodSel = False
- try:
if self.settings['fromFile']:
baselInit['type'] = 'values'
- try:
baselInit['pathToFile'] = self.settings['fromFileVal']
- except:
+ else:
self.errMsg('Path to file with baseline values is not defined')
methodSel = True
- except:
- pass
- try:
if self.settings['dryWin']:
baselInit['type'] = 'fromDryWin'
- try:
baselInit['pathToFile'] = self.settings['dryInterval']
- except:
+ else:
self.errMsg('Dry interval is not defined')
methodSel = True
- except:
- pass
if not methodSel:
self.errMsg('Baseline method is not selected')
@@ -1074,38 +993,24 @@
def initTimeWinMW(self):
winInit = {}
- try:
- winInit['linksOnly'] = eval(self.settings['linksOnly'])
- except:
- pass
- try:
- winInit['linksOnly'] = eval(self.settings['linksMap'])
- except:
- pass
- try:
- winInit['linksIngnore'] = eval(self.settings['linksIngnore'])
- except:
- pass
- try:
+ winInit['linksOnly'] = self.settings['linksOnly']
+ winInit['linksOnly'] = self.settings['linksMap']
+ if 'linksIngnore' in self.settings:
+ winInit['linksIgnored'] = self.settings['linksIngnore']
winInit['links'] = self.settings['links']
- except:
- pass
- try:
winInit['startTime'] = self.settings['start']
- except:
- pass
- try:
winInit['endTime'] = self.settings['end']
- except:
- pass
- try:
winInit['sumStep'] = self.settings['sumStep']
- except:
- pass
- try:
+ if 'IDtype' in self.settings:
winInit['IDtype'] = self.settings['IDtype']
- except:
- pass
winInit['database'] = self.dbConn
self.twin = TimeWindows(**winInit)
@@ -1113,26 +1018,22 @@
def doCompute(self):
# GMessage('OK')
- # sys.exit()
- comp=Computor(self.baseline, self.twin, self.dbConn, self.settings['dataExport'])
- bool,msg=comp.GetStatus()
+ comp = Computor(self.baseline, self.twin, self.dbConn, self.settings['dataExport'])
+ bool, msg = comp.GetStatus()
if bool:
self.initGrassLayerMgr()
self.initTemporalMgr()
GMessage(msg)
- #elf.initgrassManagement()
+ self.initgrassManagement()
def initGrassLayerMgr(self):
grassLayerMgr = {}
- try:
grassLayerMgr['rules'] = self.settings['colorRules']
- except:
- pass
- try:
grassLayerMgr['color'] = self.settings['colorName']
- except:
- pass
grassLayerMgr['database'] = self.dbConn
GrassLayerMgr(**grassLayerMgr)
@@ -1146,9 +1047,10 @@
print label
GError(label)
class MyApp(wx.App):
def OnInit(self):
- frame = MyFrame(None, -1, "MW worker")
+ frame = MyFrame(None, -1, "MW manager")
frame.Show(True)
self.SetTopWindow(frame)
return True
@@ -1163,5 +1065,3 @@
if __name__ == "__main__":
main()
Modified: grass-addons/grass7/gui/wxpython/wx.mwprecip/mw3.py
--- grass-addons/grass7/gui/wxpython/wx.mwprecip/mw3.py 2015-03-19 18:24:26 UTC (rev 64886)
+++ grass-addons/grass7/gui/wxpython/wx.mwprecip/mw3.py 2015-03-20 12:18:23 UTC (rev 64887)
@@ -2,18 +2,16 @@
# -*- coding: utf-8
# __author__ = 'matt'
-from pgwrapper import pgwrapper as pg
-from math import sin, cos, atan2, degrees, radians, tan, sqrt, fabs
-import sys, os, shutil
+from math import sin, cos, atan2, degrees, tan, sqrt
+import shutil
import psycopg2
import time
-from datetime import datetime, timedelta
import math
+from subprocess import PIPE
+from pgwrapper import pgwrapper as pg
from core.gcmd import RunCommand
from grass.pygrass.modules import Module
-from subprocess import PIPE
-from core.gcmd import GMessage, GError, GWarning
try:
@@ -230,6 +228,7 @@
overwrite=True)
os.remove(tmpFile)
class RainGauge():
def __init__(self, database, pathfile):
self.db = database
@@ -273,7 +272,7 @@
except IOError as (errno, strerror):
print "I/O error({0}): {1}".format(errno, strerror)
- #write list of string to database
+ # write list of string to database
try:
with open(os.path.join(self.schemaPath, gaugeTMPfile), 'wr') as io:
io.writelines(tmp)
@@ -309,6 +308,7 @@
io.close()
os.remove(os.path.join(self.schemaPath, gaugeTMPfile))
class Baseline():
def __init__(self, type, pathToFile, statFce='mode', quantile=97, roundMode=3, aw=0):
self.quantile = quantile
@@ -333,6 +333,7 @@
print self.pathToFile
class TimeWindows():
def __init__(self, database, IDtype, sumStep, startTime=None,
endTime=None, linksIgnored=False, linksOnly=False, links=None, linksMap=None):
@@ -492,7 +493,7 @@
# sql = "SELECT (timestamp'%s')+ %s* interval '1 second'" % (cur_timestamp, self.intervalStr)
# cur_timestamp = self.database.connection.executeSql(sql)[0][0]
- #rint cur_timestamp
+ # rint cur_timestamp
#print timedelta(seconds=1)
#print self.intervalStr
cur_timestamp = cur_timestamp + self.intervalStr * timedelta(seconds=1)
@@ -526,6 +527,7 @@
# sql = "DROP TABLE %s.%s" % (self.schema, self.database.recordTableName)
grass.message('creating time windows-done')
class Computor():
def __init__(self, baseline, timeWin, database, exportData):
self.awConst = baseline.aw
@@ -547,7 +549,7 @@
return self.status.get('bool'), self.status.get('msg')
def ExportData(self):
- pass
+ pass
def cleanDatabase(self):
sql = "DROP schema IF EXISTS %s CASCADE" % self.database.schema
@@ -561,8 +563,8 @@
'''@note returns disct - key:linkid'''
baseline = self.baseline
database = self.database
- tMin=self.timeWin.timestamp_min
- tMax=self.timeWin.timestamp_max
+ tMin = self.timeWin.timestamp_min
+ tMax = self.timeWin.timestamp_max
def computeBaselinFromMode(recordTable):
sql = "SELECT linkid from %s group by 1" % recordTable
@@ -594,10 +596,10 @@
def computeBaselineFromTime():
def chckTimeValidity(tIn):
- #print tIn
- tIn=str(tIn).replace("\n", "")
+ # print tIn
+ tIn = str(tIn).replace("\n", "")
- tIn=datetime.strptime(tIn, "%Y-%m-%d %H:%M:%S")
+ tIn = datetime.strptime(tIn, "%Y-%m-%d %H:%M:%S")
if tIn > tMax or tIn < tMin:
return False
return True
@@ -613,7 +615,7 @@
# 2013-09-11 04:00:00
- #@typestr choose statistical method for baseline computing.
+ # @typestr choose statistical method for baseline computing.
# typestr='avg'
# typestr='mode'
# typestr='quantile'
@@ -634,11 +636,11 @@
st += line.replace("\n", "")
if 'i' in line.split("\n")[0]: #get baseline form interval
fromt = f.next()
- if not chckTimeValidity( fromt):
+ if not chckTimeValidity(fromt):
return False
st += fromt.replace("\n", "")
tot = f.next()
- if not chckTimeValidity( tot):
+ if not chckTimeValidity(tot):
return False
#validate input data
if not isTimeValid(fromt) or not isTimeValid(tot):
@@ -690,7 +692,7 @@
length = len(tmp)
links = len(tmp[0])
i = 0
- # print mydict1
+ # print mydict1
#compute avg(divide sum by num of datasets)
for dataset in tmp:
for link in dataset:
@@ -818,8 +820,8 @@
limit 1" % (baseline.quantile, recordTable, linkid)
resu = database.connection.executeSql(sql, True, True)
- #print resu
- resu=resu[0][0]
+ # print resu
+ resu = resu[0][0]
tmp.append(str(linkid) + ',' + str(resu) + '\n')
io0 = open(os.path.join(database.pathworkSchemaDir, "baseline"), "wr")
@@ -837,7 +839,7 @@
return mydict
if self.baseline.type == 'values':
- #print 'valuesDirectly'
+ # print 'valuesDirectly'
self.baselineDict = readBaselineFromText(self.baseline.pathTofile)
elif self.baseline.type == 'fromDryWin':
@@ -851,7 +853,7 @@
def logMsg(self, msg):
if self.status.get('msg') == 'Done':
- self.status['msg']=''
+ self.status['msg'] = ''
self.status['msg'] += msg + '\n'
grass.warning(msg)
@@ -924,7 +926,7 @@
self.database.connection.executeSql(sql, False, True)
# optimalization of commits
- self.database.connection.setIsoLvl(0) #TODO dont know what is that
+ # self.database.connection.setIsoLvl(0) #TODO dont know what is that
# choose baseline source (quantile, user values, ) get dict linkid, baseline
grass.message("Computing baseline")
@@ -949,7 +951,7 @@
temp = []
grass.message("Computing precipitation")
- skippedList=[]
+ skippedList = []
for record in resu:
curLinkData = linksDict[record[0]] # record[0] is linkid
@@ -960,7 +962,7 @@
#skippedList.append(record[0])
continue
# if missing baseline. Link will be skip
- if record[0] in self.baselineDict and (curLinkData[2] / 1000000) > 10: #TODO
+ if record[0] in self.baselineDict and (curLinkData[2] / 1000000) > 10: #TODO
# coef_a_k[alpha, k]
coef_a_k = self.computeAlphaK(curLinkData[2], curLinkData[1])
@@ -1080,6 +1082,7 @@
return av, kv
class GrassLayerMgr():
def __init__(self, database, color=None, rules=None):
self.color = color
@@ -1094,7 +1097,7 @@
# print map
# print self.database.linkVecMapName
# print self.database.precipColName
- #print self.color
+ # print self.color
if self.color is not None:
for lay in range(1, self.getNumLayer(self.database.linkVecMapName), 1):
@@ -1244,7 +1247,7 @@
temporaltype=temporalType,
semantictype=semanticType,
overwrite=True)
- #getErrorMsg=True)
+ # getErrorMsg=True)
#print ret
#print err
@@ -1287,7 +1290,7 @@
self.host = host
if workSchema is None:
workSchema = 'tmp_' + randomWord(3)
- self.schema = workSchema
+ self.schema = workSchema
if dataSchema is None:
dataSchema = 'public'
self.dataSchema = dataSchema
@@ -1342,7 +1345,7 @@
driver='pg',
database=conninfo) != 0:
grass.warning("Unable to connect to the database by temporal grass driver.")
- return False #TODO
+ return False # TODO
if db == 'sql':
grass.run_command('t.connect',
flags='d')
@@ -1439,7 +1442,7 @@
# grass.message("Optimalization of frequency attribute")
# sql = "UPDATE link\
# SET frequency = record.frequency\
- # FROM record\
+ # FROM record\
# WHERE record.linkid = link.linkid;"
#self.connection.executeSql(sql, False, True)
@@ -1525,6 +1528,7 @@
if not os.path.isdir(self.pathworkSchemaDir):
raise
def main():
db = Database(name='tyden')
Modified: grass-addons/grass7/gui/wxpython/wx.mwprecip/mw_util.py
--- grass-addons/grass7/gui/wxpython/wx.mwprecip/mw_util.py 2015-03-19 18:24:26 UTC (rev 64886)
+++ grass-addons/grass7/gui/wxpython/wx.mwprecip/mw_util.py 2015-03-20 12:18:23 UTC (rev 64887)
@@ -1,11 +1,16 @@
#!/usr/bin/env python
-import re, os, sys
+__author__ = 'matt'
+import re
+import os
+import sys
import random
import string
import wx
import csv
-from gui_core import gselect
+from datetime import timedelta
+import wx.lib.filebrowsebutton as filebrowse
+import codecs
+from core.gcmd import GMessage, GError
class SaveLoad(wx.Panel):
@@ -21,7 +26,7 @@
class BaseInput(wx.Panel):
- #def __init__(self, parent, label,key, cats=False):
+ # def __init__(self, parent, label,key, cats=False):
def __init__(self, parent, label):
statText = wx.StaticText(self, id=wx.ID_ANY, label=label)
@@ -39,15 +44,206 @@
return self.key
def GetValue(self):
- value=self.text.GetValue()
- if value=='':
+ value = self.text.GetValue()
+ if value == '':
return None
else:
return value
def SetValue(self, value):
self.text.SetValue((str(value)))
+class TextInput1(wx.Panel):
+ def __init__(self, parent, label, tmpPath=None):
+ wx.Panel.__init__(self, parent=parent, id=wx.ID_ANY)
+ self.sizer=wx.BoxSizer(wx.VERTICAL)
+ fExt = None
+ if not fExt:
+ fMask = '*'
+ else:
+ fMask = '%s files (*%s)|*%s|Files (*)|*' % (fExt[1:].upper(), fExt, fExt)
+ fbb = filebrowse.FileBrowseButton(parent = self, id = wx.ID_ANY, fileMask = fMask,
+ labelText = '',
+ dialogTitle = 'Choose file',
+ buttonText = 'Browse',
+ startDirectory = os.getcwd(), fileMode = 'file',
+ changeCallback = self.OnSetValue)
+ self.sizer.Add(item = fbb, proportion = 0,
+ flag = wx.EXPAND | wx.RIGHT, border = 5)
+ # A file browse button is a combobox with two children:
+ # a textctl and a button;
+ # we have to target the button here
+ # widget for interactive input
+ ifbb = wx.TextCtrl(parent = self, id = wx.ID_ANY,
+ style = wx.TE_MULTILINE,
+ size = (-1, 75))
+ #if p.get('value', '') and os.path.isfile(p['value']):
+ # f = open(p['value'])
+ # ifbb.SetValue(''.join(f.readlines()))
+ # f.close()
+ ifbb.Bind(wx.EVT_TEXT, self.OnFileText)
+ btnLoad = wx.Button(parent = self, id = wx.ID_ANY, label = _("&Load"))
+ btnLoad.SetToolTipString(_("Load and edit content of a file"))
+ btnLoad.Bind(wx.EVT_BUTTON, self.OnFileLoad)
+ btnSave = wx.Button(parent = self, id = wx.ID_ANY, label = _("&Save as"))
+ btnSave.SetToolTipString(_("Save content to a file for further use"))
+ btnSave.Bind(wx.EVT_BUTTON, self.OnFileSave)
+ fileContentLabel = wx.StaticText(parent=self,
+ id=wx.ID_ANY,
+ label=_('or enter values directly:'))
+ fileContentLabel.SetToolTipString(
+ _("Enter file content directly instead of specifying"
+ " a file."
+ " Temporary file will be automatically created."))
+ self.sizer.Add(item=fileContentLabel,
+ proportion = 0,
+ flag = wx.EXPAND | wx.RIGHT | wx.LEFT | wx.BOTTOM, border = 5)
+ self.sizer.Add(item = ifbb, proportion = 1,
+ flag = wx.EXPAND | wx.RIGHT | wx.LEFT, border = 5)
+ btnSizer = wx.BoxSizer(wx.HORIZONTAL)
+ btnSizer.Add(item = btnLoad, proportion = 0,
+ flag = wx.ALIGN_RIGHT | wx.RIGHT, border = 10)
+ btnSizer.Add(item = btnSave, proportion = 0,
+ flag = wx.ALIGN_RIGHT)
+ self.sizer.Add(item = btnSizer, proportion = 0,
+ flag = wx.ALIGN_RIGHT | wx.RIGHT | wx.TOP, border = 5)
+ def OnFileText(self, event):
+ """File input interactively entered"""
+ text = event.GetString()
+ #p = self.task.get_param(value = event.GetId(), element = 'wxId', raiseError = False)
+ #if not p:
+ # return # should not happen
+ #win = self.FindWindowById(p['wxId'][0])
+ if text:
+ # filename = win.GetValue()
+ if not filename : # m.proj has - as default
+ # filename = grass.tempfile()
+ # win.SetValue(filename)
+ # enc = locale.getdefaultlocale()[1]
+ f = codecs.open(filename, encoding = enc, mode = 'w', errors='replace')
+ try:
+ f.write(text)
+ if text[-1] != os.linesep:
+ f.write(os.linesep)
+ finally:
+ f.close()
+ else:
+ # win.SetValue('')
+ def OnFileSave(self, event):
+ """Save interactive input to the file"""
+ wId = event.GetId()
+ win = {}
+ for p in self.task.params:
+ if wId in p.get('wxId', []):
+ win['file'] = self.FindWindowById(p['wxId'][0])
+ win['text'] = self.FindWindowById(p['wxId'][1])
+ break
+ if not win:
+ return
+ text = win['text'].GetValue()
+ if not text:
+ GMessage(parent = self,
+ message = _("Nothing to save."))
+ return
+ dlg = wx.FileDialog(parent = self,
+ message = "Save input as...",
+ defaultDir = os.getcwd(),
+ style = wx.FD_SAVE | wx.FD_OVERWRITE_PROMPT)
+ if dlg.ShowModal() == wx.ID_OK:
+ path = dlg.GetPath()
+ #enc = locale.getdefaultlocale()[1]
+ f = codecs.open(path, mode = 'w', errors='replace')
+ try:
+ f.write(text + os.linesep)
+ finally:
+ f.close()
+ win['file'].SetValue(path)
+ dlg.Destroy()
+ def OnFileLoad(self, event):
+ """Load file to interactive input"""
+ me = event.GetId()
+ win = dict()
+ if 'wxId' in p and me in p['wxId']:
+ break
+ if not win:
+ return
+ path = win['file'].GetValue()
+ if not path:
+ gcmd.GMessage(parent = self,
+ message = _("Nothing to load."))
+ return
+ data = ''
+ try:
+ f = open(path, "r")
+ except IOError as e:
+ gcmd.GError(parent = self, showTraceback = False,
+ message = _("Unable to load file.\n\nReason: %s") % e)
+ return
+ try:
+ data = f.read()
+ finally:
+ f.close()
+ win['text'].SetValue(data)
+ def OnSetValue(self, event):
+ """Retrieve the widget value and set the task value field
+ accordingly.
+ Use for widgets that have a proper GetValue() method, i.e. not
+ for selectors.
+ myId = event.GetId()
+ me = wx.FindWindowById(myId)
+ name = me.GetName()
+ found = False
+ for porf in self.task.params + self.task.flags:
+ if 'wxId' not in porf:
+ continue
+ if myId in porf['wxId']:
+ found = True
+ break
+ if not found:
+ return
+ if name == 'GdalSelect':
+ porf['value'] = event.dsn
+ elif name == 'ModelParam':
+ porf['parameterized'] = me.IsChecked()
+ else:
+ if isinstance(me, wx.SpinCtrl):
+ porf['value'] = str(me.GetValue())
+ else:
+ porf['value'] = me.GetValue()
+ self.OnUpdateValues(event)
+ event.Skip()
class TextInput(wx.Panel):
@@ -82,13 +278,11 @@
self.firstDirInp = True
if self.tmpPath is None:
self.tmpPath=os.path.join(os.path.dirname(os.path.realpath(__file__)), 'tmp%s' % randomWord(3))
- print self.tmpPath
- self.pathInput.SetValue(str(self.tmpPath))
+ self.pathInput.SetValue(str(self.tmpPath))
io=open(self.tmpPath,'w')
io.writelines(self.directInp.GetValue())
io.close()
- print self.directInp.GetValue()
def onBrowse(self, event):
openFileDialog = wx.FileDialog(self, "Open text file", style=wx.FD_OPEN | wx.FD_FILE_MUST_EXIST)
@@ -105,6 +299,8 @@
return self.directInp.GetValue()
def SetValue(self):
+ if not os.path.isfile(self.pathInput.GetValue()):
+ return -1
io = open(self.pathInput.GetValue(), 'r')
str = io.read()
try:
@@ -119,6 +315,8 @@
except:
print "Unexpected error:", sys.exc_info()[0]
raise
+ return -1
io.close()
def GetPath(self):
@@ -129,6 +327,8 @@
return path
def SetPath(self, value):
+ if value is None:
+ return
self.firstDirInpActive = True
self.pathInput.SetValue(value)
if self.SetValue() == -1:
@@ -164,8 +364,6 @@
return # the user changed idea...
path = openFileDialog.GetPath()
self.pathInput.SetValue(path)
else:
openFileDialog = wx.FileDialog(self, "Choose a file:", style=wx.FD_OPEN | wx.FD_FILE_MUST_EXIST)
if openFileDialog.ShowModal() == wx.ID_CANCEL:
@@ -185,6 +383,57 @@
+class FileInput(wx.Panel):
+ def __init__(self, parent, label, dir=False, tmpPath=None):
+ self.dir = dir
+ self.tmpPath = tmpPath
+ statText = wx.StaticText(self, id=wx.ID_ANY, label=label)
+ self.pathInput = wx.TextCtrl(self, id=wx.ID_ANY)
+ self.browseBtt = wx.Button(self, id=wx.ID_ANY, label='Browse')
+ sizer = wx.BoxSizer(wx.VERTICAL)
+ sizer2 = wx.BoxSizer(wx.HORIZONTAL)
+ sizer2.Add(self.pathInput, flag=wx.EXPAND, proportion=1)
+ sizer2.Add(self.browseBtt, flag=wx.EXPAND)
+ sizer.Add(statText, flag=wx.EXPAND)
+ sizer.Add(sizer2, flag=wx.EXPAND)
+ self.SetSizer(sizer)
+ self.browseBtt.Bind(wx.EVT_BUTTON, self.onBrowse)
+ def onBrowse(self, event):
+ if self.dir:
+ openFileDialog = wx.DirDialog(self, "Choose a directory:",
+ style=wx.DD_DEFAULT_STYLE | wx.DD_DIR_MUST_EXIST | wx.DD_CHANGE_DIR)
+ if openFileDialog.ShowModal() == wx.ID_CANCEL:
+ return # the user changed idea...
+ path = openFileDialog.GetPath()
+ self.pathInput.SetValue(path)
+ else:
+ openFileDialog = wx.FileDialog(self, "Choose a file:", style=wx.FD_OPEN | wx.FD_FILE_MUST_EXIST)
+ def GetPath(self):
+ path = self.pathInput.GetValue()
+ if len(path) != 0:
+ return path
+ else:
+ return None
+ def SetPath(self, value):
+ self.pathInput.SetValue(value)
def YesNo(parent, question, caption='Yes or no?'):
dlg = wx.MessageDialog(parent, question, caption, wx.YES_NO | wx.ICON_QUESTION)
result = dlg.ShowModal() == wx.ID_YES
@@ -196,7 +445,7 @@
try:
lis = os.listdir(fpath)
except:
- #GError('canot find folder%s'%fpath)
+ # GError('canot find folder%s'%fpath)
return 0
tmp = []
for path in lis:
@@ -234,18 +483,20 @@
temp_list[len(temp_list):] = data_list[end:len(data_list)]
open(new_file, 'wr').writelines(temp_list)
def OnSaveAs(parent):
- saveFileDialog = wx.FileDialog(parent, "Save file","", "",
- "files (*.*)|*.*", wx.FD_SAVE | wx.FD_OVERWRITE_PROMPT)
+ saveFileDialog = wx.FileDialog(parent, "Save file", "", "",
+ "files (*.*)|*.*", wx.FD_SAVE | wx.FD_OVERWRITE_PROMPT)
if saveFileDialog.ShowModal() == wx.ID_CANCEL:
- return # the user changed idea...
# save the current contents in the file
# this can be done with e.g. wxPython output streams:
output_stream = (saveFileDialog.GetPath())
return output_stream
def saveDict(fn, dict_rap):
f = open(fn, "wb")
w = csv.writer(f)
Modified: grass-addons/grass7/gui/wxpython/wx.mwprecip/pgwrapper.py
--- grass-addons/grass7/gui/wxpython/wx.mwprecip/pgwrapper.py 2015-03-19 18:24:26 UTC (rev 64886)
+++ grass-addons/grass7/gui/wxpython/wx.mwprecip/pgwrapper.py 2015-03-20 12:18:23 UTC (rev 64887)
@@ -6,11 +6,11 @@
# import psycopg2.extensions
class pgwrapper:
- def __init__(self, dbname, host='', user='', passwd='',port=''):
+ def __init__(self, dbname, host='', user='', passwd='', port=''):
self.dbname = dbname # Database name which connect to.
self.host = host # Host name (default is "localhost")
self.user = user # User name for login to the database.
- self.port=port
+ self.port = port
self.password = passwd # Password for login to the database.
self.connection = self.setConnect() # Set a connection to the database
self.cursor = self.setCursor() # Generate cursor.
@@ -38,13 +38,14 @@
except:
print 'cannot set cursor'
def setIsoLvl(self, lvl='0'):
if lvl == 0:
self.connection.set_session('read committed')
elif lvl == 1:
self.connection.set_session(readonly=True, autocommit=False)
def copyfrom(self, afile, table, sep='|'):
try:
self.cursor.copy_from(afile, table, sep=sep)
@@ -81,17 +82,16 @@
# Excute the SQL statement.
# self.print_message (sql)
- print '*'*50
+ print '*' * 50
print sql
- print '*'*50
+ print '*' * 50
try:
self.cursor.execute(sql)
except Exception, e:
self.connection.rollback()
- self.print_message( e.pgerror)
+ self.print_message(e.pgerror)
if commit:
self.connection.commit()
Deleted: grass-addons/grass7/gui/wxpython/wx.mwprecip/wx.mwprecip.py
--- grass-addons/grass7/gui/wxpython/wx.mwprecip/wx.mwprecip.py 2015-03-19 18:24:26 UTC (rev 64886)
+++ grass-addons/grass7/gui/wxpython/wx.mwprecip/wx.mwprecip.py 2015-03-20 12:18:23 UTC (rev 64887)
@@ -1,1157 +0,0 @@
-#!/usr/bin/env python
-from mw_util import *
-class DBconn(wx.Panel):
- def __init__(self, parent, settings={}):
- wx.Panel.__init__(self, parent=parent, id=wx.ID_ANY)
- self.settings = settings
- self.database = BaseInput(self, label='Name of database')
- self.schema = BaseInput(self, label='Name of schema')
- self.host = BaseInput(self, label='Host name')
- self.user = BaseInput(self, label='User name')
- self.port = BaseInput(self, label='Port')
- self.passwd = BaseInput(self, label='Password')
- # self.saveLoad = SaveLoad(self)
- self.okBtt = wx.Button(self, wx.ID_OK, label='ok and close')
- self.okBtt.Bind(wx.EVT_BUTTON, self.saveSettings)
- if len(settings) > 0:
- self.loadSettings()
- self._layout()
- def _layout(self):
- panelSizer = wx.BoxSizer(wx.VERTICAL)
- panelSizer.Add(self.database, flag=wx.EXPAND)
- panelSizer.Add(self.schema, flag=wx.EXPAND)
- panelSizer.Add(self.host, flag=wx.EXPAND)
- panelSizer.Add(self.user, flag=wx.EXPAND)
- panelSizer.Add(self.port, flag=wx.EXPAND)
- panelSizer.Add(self.passwd, flag=wx.EXPAND)
- panelSizer.AddSpacer(10, 0, wx.EXPAND)
- # panelSizer.Add(self.saveLoad, flag=wx.EXPAND)
- panelSizer.Add(self.okBtt, flag=wx.EXPAND)
- self.SetSizerAndFit(panelSizer)
- def loadSettings(self, sett=None):
- if sett:
- try:
- self.database.SetValue(self.settings['database'])
- except:
- print 'err'
- pass
- try:
- self.schema.SetValue(self.settings['schema'])
- except:
- pass
- try:
- self.host.SetValue(self.settings['host'])
- except:
- pass
- try:
- self.user.SetValue(self.settings['user'])
- except:
- pass
- try:
- self.port.SetValue(self.settings['port'])
- except:
- pass
- try:
- self.passwd.SetValue(self.settings['passwd'])
- except:
- pass
- def saveSettings(self, settings=None):
- if settings is not None:
- self.settings['database'] = self.database.GetValue()
- self.settings['schema'] = self.schema.GetValue()
- self.settings['host'] = self.host.GetValue()
- self.settings['user'] = self.user.GetValue()
- self.settings['port'] = self.port.GetValue()
- self.settings['passwd'] = self.passwd.GetValue()
- return self.settings
-class PointInterpolationPanel(wx.Panel):
- def __init__(self, parent, settings=None):
- self.interpolState = wx.CheckBox(self, label='interpolate points along links')
- self.interpolState.Bind(wx.EVT_CHECKBOX, self.onCheckInterpol)
- self.interpolState.SetValue(False)
- self.rb1 = wx.RadioButton(self, label='Number of points', style=wx.RB_GROUP)
- self.rb2 = wx.RadioButton(self, label='Distance')
- self.val = BaseInput(self, label='Value')
- panelSizer.Add(self.interpolState, flag=wx.EXPAND)
- panelSizer.Add(self.rb1, flag=wx.EXPAND)
- panelSizer.Add(self.rb2, flag=wx.EXPAND)
- panelSizer.Add(self.val, flag=wx.EXPAND)
- self.onCheckInterpol()
- def onCheckInterpol(self, evt=None):
- if self.interpolState.GetValue():
- self.rb1.Enable()
- self.rb2.Enable()
- self.val.Enable()
- else:
- self.rb1.Disable()
- self.rb2.Disable()
- self.val.Disable()
- if sett:
- try:
- self.rb1.SetValue(self.settings['pitypeDist'])
- except:
- pass
- try:
- self.val.SetValue(self.settings['pivalue'])
- except:
- pass
- self.settings['pitypeDist'] = self.rb1.GetValue()
- self.settings['pivalue'] = self.val.GetValue()
-class BaselinePanel(wx.Panel):
- self.dryWin = wx.RadioButton(self, label='Compute from dry windows', style=wx.RB_GROUP)
- self.fromFile = wx.RadioButton(self, label='Direct text input')
- self.baselTypeTxt = wx.StaticText(self, label='Select statistic method')
- self.baselType = wx.ComboBox(self, id=wx.ID_ANY, value="quantile", choices=['avg', 'mode', 'quantile'])
- self.round = BaseInput(self, 'Round data to "n" of decimal places') # TODO MODE disable
- self.quantile = BaseInput(self, 'Set quantile in %') # TODO quantile disable
- self.aw = BaseInput(self, 'Antena wetting value')
- self.dryInterval = TextInput(self, 'Set interval of dry period')
- self.fromFileVal = TextInput(self, 'Set baseline values in csv format')
- # self.SLpanel = SaveLoad(self)
- self.onChangeMethod(None)
- self.fromFile.Bind(wx.EVT_RADIOBUTTON, self.onChangeMethod)
- self.dryWin.Bind(wx.EVT_RADIOBUTTON, self.onChangeMethod)
- self.loadSettings(None)
- self._layout()
- if sett is not None:
- try:
- self.fromFile.SetValue(self.settings['fromFile'])
- except:
- pass
- try:
- self.dryWin.SetValue(self.settings['dryWin'])
- except:
- pass
- try:
- self.quantile.SetValue(self.settings['quantile'])
- except:
- pass
- try:
- self.baselType.SetValue(self.settings['baselType'])
- except:
- pass
- try:
- self.round.SetValue(self.settings['round'])
- except:
- pass
- try:
- self.aw.SetValue(self.settings['aw'])
- except:
- pass
- try:
- self.dryInterval.SetPath(self.settings['dryInterval'])
- except:
- pass
- try:
- self.fromFileVal.SetPath(self.settings['fromFileVal'])
- except:
- pass
- self.onChangeMethod()
- def saveSettings(self, evt=None, sett=None):
- if sett:
- self.settings['fromFile'] = self.fromFile.GetValue()
- self.settings['dryWin'] = self.dryWin.GetValue()
- self.settings['baselType'] = self.baselType.GetValue()
- self.settings['round'] = self.round.GetValue()
- self.settings['quantile'] = self.quantile.GetValue()
- self.settings['aw'] = self.aw.GetValue()
- self.settings['dryInterval'] = self.dryInterval.GetPath()
- self.settings['fromFileVal'] = self.fromFileVal.GetPath()
- def onChangeMethod(self, evt=None):
- if self.dryWin.GetValue() is False:
- self.baselType.Disable()
- self.round.Disable()
- self.aw.Disable()
- self.dryInterval.Disable()
- self.quantile.Disable()
- self.fromFileVal.Enable()
- else:
- self.baselType.Enable()
- self.round.Enable()
- self.aw.Enable()
- self.quantile.Enable()
- self.dryInterval.Enable()
- self.fromFileVal.Disable()
- sizer = wx.BoxSizer(wx.VERTICAL)
- sizer.Add(self.dryWin, flag=wx.EXPAND)
- sizer.Add(self.fromFile, flag=wx.EXPAND)
- sizer.Add(self.baselTypeTxt, flag=wx.EXPAND)
- sizer.Add(self.baselType, flag=wx.EXPAND)
- sizer.Add(self.round, flag=wx.EXPAND)
- sizer.Add(self.quantile, flag=wx.EXPAND)
- sizer.Add(self.aw, flag=wx.EXPAND)
- sizer.Add(self.dryInterval, flag=wx.EXPAND)
- sizer.AddSpacer(10, 0, wx.EXPAND)
- sizer.Add(self.fromFileVal, flag=wx.EXPAND)
- # sizer.Add(self.SLpanel, flag=wx.EXPAND)
- sizer.Add(self.okBtt, flag=wx.EXPAND)
- self.SetSizerAndFit(sizer)
-class DataMgrRG(wx.Panel):
- self.sett = settings
-class DataMgrMW(wx.Panel):
- self.stBoxTWIN = wx.StaticBox(self, wx.ID_ANY, 'Time windows MW')
- # =================DATA=========================
- self.linksAll = wx.RadioButton(self, label='All', style=wx.RB_GROUP)
- self.linksOnly = wx.RadioButton(self, label='Use links')
- self.linksIngnore = wx.RadioButton(self, label='Ignore links')
- self.linksAll.Bind(wx.EVT_RADIOBUTTON, self.refreshLinkSet)
- self.linksIngnore.Bind(wx.EVT_RADIOBUTTON, self.refreshLinkSet)
- self.linksOnly.Bind(wx.EVT_RADIOBUTTON, self.refreshLinkSet)
- # self.links = BaseInput(self,'Set links according to radio above',True)
- self.links = BaseInput(self, 'Set links according to radio above')
- self.start = BaseInput(self, label='Start time')
- self.end = BaseInput(self, label='End time')
- self.getStartBtt = wx.Button(self, label='Get min')
- self.getEndBtt = wx.Button(self, label='Get max')
- self.sumStep = wx.ComboBox(self, id=wx.ID_ANY, value="minute", choices=['minute', 'hour', 'day'])
- self.stBoxGauge = wx.StaticBox(self, wx.ID_ANY, 'Rain gauge')
- self.inpRainGauge = FileInput(self, 'Select folder with raingauges data')
- # self.sb1 = wx.StaticBox(self, wx.ID_ANY, 'Baseline')
- # self.type = self.rb1 = wx.RadioButton(self, label='Number of points', style=wx.RB_GROUP)
- self._layout()
- if self.inpRainGauge.GetPath() is not None:
- self.linksAll.Disable()
- self.linksOnly.Disable()
- self.linksIngnore.Disable()
- self.links.Disable()
- self.vectorMap.Disable()
- self.mapLabel.Disable()
- self.map.Disable()
- else:
- self.linksAll.Enable()
- self.linksOnly.Enable()
- self.linksIngnore.Enable()
- self.vectorMap.Enable()
- self.mapLabel.Enable()
- self.map.Enable()
- if not self.linksAll.GetValue():
- self.links.Enable()
- def refreshLinkSet(self, evt=None):
- if self.linksAll.GetValue():
- else:
- if self.vectorMap.GetValue():
- self.links.Hide()
- self.mapLabel.Show()
- self.map.Show()
- else:
- self.links.Show()
- self.mapLabel.Hide()
- self.map.Hide()
- self.Fit()
- if sett:
- self.settings['linksOnly'] = self.linksOnly.GetValue()
- self.settings['linksIngnore'] = self.linksIngnore.GetValue()
- self.settings['linksMap'] = self.map.GetValue()
- self.settings['links'] = self.links.GetValue()
- self.settings['start'] = self.start.GetValue()
- self.settings['end'] = self.end.GetValue()
- self.settings['sumStep'] = self.sumStep.GetValue()
- self.settings['inpRainGauge'] = self.inpRainGauge.GetPath()
- if sett:
- try:
- except:
- pass
- try:
- except:
- pass
- try:
- except:
- pass
- try:
- self.links.SetValue(self.settings['links'])
- except:
- pass
- try:
- self.start.SetValue(self.settings['start'])
- except:
- pass
- try:
- self.end.SetValue(self.settings['end'])
- except:
- pass
- try:
- self.sumStep.SetValue(self.settings['sumStep'])
- except:
- pass
- try:
- self.inpRainGauge.SetPath(self.settings['inpRainGauge'])
- except:
- pass
- linksSizer = wx.BoxSizer(wx.HORIZONTAL)
- linksSizer.Add(self.linksAll, flag=wx.EXPAND, proportion=1)
- linksSizer.Add(self.linksOnly, flag=wx.EXPAND, proportion=1)
- linksSizer.Add(self.linksIngnore, flag=wx.EXPAND, proportion=1)
- linksSizer.Add(self.vectorMap, flag=wx.EXPAND, proportion=1)
- stBoxSizerTWIN = wx.StaticBoxSizer(self.stBoxTWIN, orient=wx.VERTICAL)
- stBoxSizerTWIN.Add(linksSizer, flag=wx.EXPAND, proportion=1)
- stBoxSizerTWIN.Add(self.links, flag=wx.EXPAND, proportion=1)
- stBoxSizerTWIN.Add(self.mapLabel, flag=wx.EXPAND)
- stBoxSizerTWIN.Add(self.map, flag=wx.EXPAND)
- stBoxSizerTWIN.AddSpacer(5, 5, 1, wx.EXPAND)
- stBoxSizerTWIN.Add(self.start, flag=wx.EXPAND, proportion=1)
- stBoxSizerTWIN.Add(self.getStartBtt)
- stBoxSizerTWIN.Add(self.end, flag=wx.EXPAND, proportion=1)
- stBoxSizerTWIN.Add(self.getEndBtt)
- stBoxSizerTWIN.Add(wx.StaticText(self, id=wx.ID_ANY, label='Time increment'))
- stBoxSizerTWIN.Add(self.sumStep, flag=wx.EXPAND)
- gaugeSizer = wx.BoxSizer(wx.HORIZONTAL)
- gaugeSizer.Add(self.inpRainGauge, flag=wx.EXPAND, proportion=1)
- stBoxSizerRGAUGE = wx.StaticBoxSizer(self.stBoxGauge, orient=wx.VERTICAL)
- stBoxSizerRGAUGE.Add(gaugeSizer, flag=wx.EXPAND, proportion=1)
- panelSizer.Add(stBoxSizerTWIN, flag=wx.EXPAND)
- panelSizer.Add(stBoxSizerRGAUGE, flag=wx.EXPAND)
- # panelSizer.Add(self.exportDataBtt, flag=wx.EXPAND)
- # panelSizer.Add(self.computeBtt, flag=wx.EXPAND)
- self.refreshLinkSet()
-class GrassLayers(wx.Panel):
- self.layout()
- if sett:
- try:
- self.colorRules.SetValue(self.settings['colorRules'])
- except:
- pass
- try:
- self.colorsName.SetValue(self.settings['colorsName'])
- except:
- pass
- if sett:
- self.settings['colorName'] = self.colorsName.GetValue()
- self.settings['colorRules'] = self.colorRules.GetPath()
- def layout(self):
-class GeometryPanel(wx.Panel):
- self.linksExp = wx.RadioButton(self, label='Links', style=wx.RB_GROUP)
- self.nodesExp = wx.RadioButton(self, label='Nodes')
- self.layout()
- def layout(self):
- def GetOptions(self):
- if self.linksExp.GetValue():
- type='links'
- else:
- type='nodes'
-class ExportData(wx.Panel):
- def __init__(self, parent):
- self.chkid.SetValue(True)
- self.chkid.Disable()
- self.chktime.SetValue(True)
- self.chktime.Disable()
- self.layout()
- def layout(self):
- self.SetSizerAndFit(mainSizer)
-class MyFrame(wx.Frame):
- def __init__(self, parent, id, title):
- wx.Frame.__init__(self, parent, id, title, size=(480, 640))
- self.workPath = os.path.dirname(os.path.realpath(__file__))
- self.initWorkingFoldrs()
- self.settings = {}
- self.settingsLst = []
- self.mainSizer = wx.BoxSizer(wx.VERTICAL)
- menubar = wx.MenuBar()
- settMenu = wx.Menu()
- fileMenu = wx.Menu()
- databaseItem = settMenu.Append(wx.ID_ANY, 'Database', 'Set database')
- baselineItem = settMenu.Append(wx.ID_ANY, 'Baseline', 'Set baseline methods')
- quitItem = settMenu.Append(wx.ID_EXIT, 'Quit', 'Quit application')
- menubar.Append(settMenu, '&Options')
- #menubar.Append(geoMenu, '&Settings')
- self.SetMenuBar(menubar)
- self.Bind(wx.EVT_MENU, self.onQuit, quitItem)
- self.Bind(wx.EVT_MENU, self.onSetDatabase, databaseItem)
- self.Bind(wx.EVT_MENU, self.onSetBaseline, baselineItem)
- self.Bind(wx.EVT_MENU, self.onSetGeometry, geometry)
- #def initNotebook(self):
- self.ntb = wx.Notebook(self, id=wx.ID_ANY)
- self.dataMgrMW = DataMgrMW(self.ntb)
- self.dataMgrMW.getEndBtt.Bind(wx.EVT_BUTTON, self.getMaxTime)
- self.dataMgrMW.getStartBtt.Bind(wx.EVT_BUTTON, self.getMinTime)
- #self.dataMgrRG = DataMgrMW(self.ntb )
- self.pointInter = PointInterpolationPanel(self.ntb)
- self.ntb.AddPage(page=self.dataMgrMW, text='MW data')
- #self.ntb.AddPage(page=self.dataMgrRG, text='RG data')
- self.ntb.AddPage(page=self.pointInter, text='Points Interpolation')
- self.grassLayers = GrassLayers(self.ntb, self.settings)
- self.ntb.AddPage(page=self.grassLayers, text='Layers')
- #def initProfileSett(self):
- self.loadScheme = wx.StaticText(self, label='Load settings', id=wx.ID_ANY)
- self.profilSelection = wx.ComboBox(self)
- self.schema = BaseInput(self, 'Name of new working profile')
- self.schema.text.Bind(wx.EVT_TEXT, self.OnSchemeTxtChange)
- self.newScheme = wx.Button(self, label='Save new profile')
- self.newScheme.Bind(wx.EVT_BUTTON, self.OnSaveSettings)
- self.newScheme.Disable()
- self.profilSelection.Bind(wx.EVT_COMBOBOX, self.OnLoadSettings)
- #def initRunBtt(self):
- self.computeBtt = wx.Button(self, label='Compute')
- self.exportDataBtt = wx.Button(self, label='Export data')
- self.computeBtt.Bind(wx.EVT_BUTTON, self.runCompute)
- self.exportDataBtt.Bind(wx.EVT_BUTTON, self.exportData)
- self.findProject()
- self.layout()
- def getMinTime(self, evt=None):
- self.OnSaveSettings(toFile=False)
- interface = Gui2Model(self, self.settings) # TODO optimalize init
- if interface.connStatus:
- self.dataMgrMW.start.SetValue(interface.dbConn.minTimestamp())
- def getMaxTime(self, evt=None):
- self.dataMgrMW.end.SetValue(interface.dbConn.maxTimestamp())
- def GetConnection(self):
- def OnSchemeTxtChange(self, evt=None):
- if self.schema.GetValue() is not None:
- self.newScheme.Enable()
- else:
- def OnLoadSettings(self, evt=None):
- currSelId = self.profilSelection.GetSelection()
- self.settings = self.settingsLst[currSelId]
- try:
- self.dataMgrMW.loadSettings(self.settings)
- except:
- pass
- try:
- self.dataMgrRG.loadSettings(self.settings)
- except:
- pass
- try:
- self.databasePnl.loadSettings(self.settings)
- except:
- pass
- try:
- self.baselinePnl.loadSettings(self.settings)
- except:
- pass
- try:
- self.grassLayers.loadSettings(self.settings)
- except:
- pass
- def OnSaveSettings(self, evt=None, toFile=True):
- try:
- self.settings = self.dataMgrMW.saveSettings(sett=self.settings)
- except:
- pass
- # try:
- # self.settings=self.dataMgrRG.saveSettings(sett=self.settings)
- # except:
- # pass
- try:
- self.settings = self.databasePnl.saveSettings(sett=self.settings)
- except:
- pass
- try:
- self.settings = self.baselinePnl.saveSettings(sett=self.settings)
- except:
- pass
- try:
- self.settings = self.grassLayers.saveSettings(sett=self.settings)
- except:
- pass
- try:
- except:
- pass
- self.settings['workSchema'] = self.schema.GetValue()
- if toFile:
- tmpPath = os.path.join(self.workPath, "save", self.settings['workSchema'])
- saveDict(tmpPath, self.settings)
- def initWorkingFoldrs(self):
- if not os.path.exists(savePath):
- os.makedirs(savePath)
- if not os.path.exists(tmpPath):
- os.makedirs(tmpPath)
- def findProject(self):
- try:
- projectDir = os.path.join(self.workPath, "save")
- except:
- GMessage('Cannot find "save" folder')
- return
- filePathList = getFilesInFoldr(projectDir, True)
- # print 'filePathList',filePathList
- if filePathList != 0:
- self.profilSelection.Clear()
- for n, path in enumerate(filePathList):
- tmpDict = readDict(path)
- self.settingsLst.append(tmpDict)
- self.profilSelection.Append(str(tmpDict['workSchema']))
- else:
- return
- self.geDialog = wx.Dialog(self, id=wx.ID_ANY,
- title='Geometry creator',
- self.geDialog.SetSize((500, 500))
- if self.settings:
- self.geometryPnl = GeometryPanel(self.geDialog, self.settings)
- else:
- self.geometryPnl = GeometryPanel(self.geDialog)
- self.geometryPnl.bttExport.Bind(wx.EVT_BUTTON, self._onSetGeomDLG)
- dbSizer = wx.BoxSizer(wx.VERTICAL)
- dbSizer.Add(self.geometryPnl, flag=wx.EXPAND)
- self.geDialog.SetSizer(dbSizer)
- self.geDialog.SetBestFittingSize()
- self.geDialog.ShowModal()
- self.geDialog.Destroy()
- def _onSetGeomDLG(self, evt):
- if name == '':
- GMessage('Please set name of map')
- else:
- #TODO giface
- tree = self._giface.GetLayerTree()
- if tree:
- tree.AddLayer(ltype='vector', lname=map,
- lcmd=['d.vect', 'map=%s' % map],
- lchecked=True)
- pass
- def onSetBaseline(self, evt):
- self.bsDialog = wx.Dialog(self, id=wx.ID_ANY,
- title='Baseline settings',
- if self.settings:
- self.baselinePnl = BaselinePanel(self.bsDialog, self.settings)
- else:
- self.baselinePnl = BaselinePanel(self.bsDialog)
- self.baselinePnl.okBtt.Bind(wx.EVT_BUTTON, self._onSetBaselineDLG)
- dbSizer.Add(self.baselinePnl, flag=wx.EXPAND)
- self.bsDialog.SetSizer(dbSizer)
- self.bsDialog.SetBestFittingSize()
- self.bsDialog.ShowModal()
- self.bsDialog.Destroy()
- def _onSetBaselineDLG(self, evt):
- self.settings = self.baselinePnl.saveSettings()
- print self.settings
- def onSetDatabase(self, evt):
- self.dbDialog = wx.Dialog(self, id=wx.ID_ANY,
- self.dbDialog.SetSize((500, 500))
- if self.settings:
- self.databasePnl = DBconn(self.dbDialog, self.settings)
- else:
- self.databasePnl = DBconn(self.dbDialog)
- self.databasePnl.okBtt.Bind(wx.EVT_BUTTON, self._onSetDatabaseDLG)
- dbSizer.Add(self.databasePnl, flag=wx.EXPAND)
- self.dbDialog.SetSizer(dbSizer)
- self.dbDialog.SetBestFittingSize()
- self.dbDialog.ShowModal()
- self.dbDialog.Destroy()
- def _onSetDatabaseDLG(self, evt):
- self.settings = self.databasePnl.saveSettings()
- def exportData(self, evt):
- self.exportDialog = wx.Dialog(self, id=wx.ID_ANY,
- self.exportDialog.SetSize((500, 500))
- self.exportDMgr = ExportData(self.exportDialog)
- self.exportDMgr.okBtt.Bind(wx.EVT_BUTTON, self._onExport)
- dbSizer.Add(self.exportDMgr, flag=wx.EXPAND)
- self.exportDialog.SetSizer(dbSizer)
- self.exportDialog.SetBestFittingSize()
- self.exportDialog.ShowModal()
- self.exportDialog.Destroy()
- if not self.exportDMgr.chkprecip.GetValue():
- attrTmp1=[]
- attrTmp1.append('link.linkid')
- attrTmp2=[]
- attrTmp3=[]
- if self.exportDMgr.chkfreq.GetValue():
- attrTmp1.append('link.frequency')
- if self.exportDMgr.chkpol.GetValue():
- attrTmp1.append('link.polarization')
- attrTmp2.append('record.time')
- if self.exportDMgr.chkrx.GetValue():
- attrTmp2.append('record.rxpower')
- if self.exportDMgr.chktx.GetValue():
- attrTmp2.append('record.txpower')
- attrTmp4='WHERE'
- if len(attrTmp1) > 0:
- attrTmp3.append('link')
- if len(attrTmp2) > 0:
- attrTmp3.append('record')
- if len(attrTmp1) > 0 and len(attrTmp2) > 0:
- attrTmp0 = ",".join(attrTmp0)
- elif len(attrTmp1) > 0:
- attrTmp0 = ",".join(attrTmp1)
- elif len(attrTmp2) > 0:
- attrTmp0 = ",".join(attrTmp2)
- attrTmp3 = ",".join(attrTmp3)
- else:
- attrTmp3,
- attrTmp4,
- lines=''
- for r in res:
- print conn.pathworkSchemaDir
- #path=os.path.join(conn.pathworkSchemaDir, "export")
- io0 = open(path, "wr")
- io0.writelines(lines)
- io0.close()
- else:
- if YesNo(self, 'Export data only?'):
- exportData['dataOnly'] = True
- self.settings['dataExport'] = exportData
- #if rain gauges
- if self.dataMgrMW.inpRainGauge.GetPath() is not None:
- else:
- interface.initVectorGrass()
- interface.initTimeWinMW()
- interface.initBaseline()
- interface.doCompute()
- lines=''
- for r in res:
- io0.close()
- def runCompute(self, evt):
- #if rain gauges
- else:
- #if interpolate points along lines
- if self.pointInter.interpolState.GetValue():
- interface.initPInterpolation()
- def layout(self):
- self.mainSizer.Add(self.loadScheme, flag=wx.EXPAND)
- self.mainSizer.Add(self.profilSelection, flag=wx.EXPAND)
- self.mainSizer.Add(self.schema, flag=wx.EXPAND)
- self.mainSizer.Add(self.newScheme, flag=wx.EXPAND)
- self.mainSizer.AddSpacer(10, 0, wx.EXPAND)
- self.mainSizer.Add(self.ntb, flag=wx.EXPAND)
- self.mainSizer.Add(self.computeBtt, flag=wx.EXPAND)
- self.mainSizer.Add(self.exportDataBtt, flag=wx.EXPAND)
- self.SetSizer(self.mainSizer)
- # self.Fit()
- def onQuit(self, e):
- self.Close()
-class Gui2Model():
- def __init__(self, wxParent, settings):
- parent = wxParent
- self.dbConn = None
- self.initConnection()
- def initConnection(self, info=False):
- conninfo=None
- try:
- conninfo = {'name': self.settings['database']}
- except:
- GMessage('name of database is missing')
- return
- try:
- conninfo['workSchema'] = self.settings['workSchema']
- except:
- pass
- try:
- conninfo['dataSchema'] = self.settings['schema']
- except:
- pass
- try:
- conninfo['host'] = self.settings['host']
- except:
- pass
- try:
- conninfo['user'] = self.settings['user']
- except:
- pass
- try:
- conninfo['port'] = self.settings['port']
- except:
- pass
- try:
- conninfo['password'] = self.settings['passwd']
- except:
- pass
- if conninfo is None:
- GMessage('Database connection failed')
- return
- if not info: # prepare for computing
- self.dbConn = Database(**conninfo)
- self.dbConn.firstPreparation()
- self.dbConn.prepareDB()
- self.dbConn.prepareDir()
- return self.dbConn
- else: # just get info about curr database state
- convertor = VectorLoader(self.dbConn)
- if name:
- # create native vector map(nodes)
- pointsSQL = convertor.selectNodes()
- # print pointsSQL
- pointsASCII = convertor.getASCIInodes(pointsSQL)
- convertor.grass_vinASCII(pointsASCII, self.dbConn.nodeVecMapName)
- # create native vector map(links)
- linksSQL = convertor.selectLinks()
- linksASCII = convertor.getASCIIlinks(linksSQL)
- convertor.grass_vinASCII(linksASCII, self.dbConn.linkVecMapName)
- def initPInterpolation(self):
- try:
- pitypeDist = self.settings['pitypeDist']
- except:
- pass
- try:
- pivalue = self.settings['pivalue']
- except:
- self.errMsg('Missing value for interpolating points along lines')
- PointInterpolation(self.dbConn, pivalue, pitypeDist)
- def initBaseline(self):
- baselInit = {}
- try:
- baselInit['statFce'] = self.settings['baselType']
- except:
- pass
- try:
- baselInit['quantile'] = self.settings['quantile']
- except:
- pass
- try:
- baselInit['roundMode'] = self.settings['round']
- except:
- pass
- try:
- baselInit['aw'] = self.settings['aw']
- except:
- pass
- methodSel = False
- try:
- if self.settings['fromFile']:
- baselInit['type'] = 'values'
- try:
- baselInit['pathToFile'] = self.settings['fromFileVal']
- except:
- self.errMsg('Path to file with baseline values is not defined')
- methodSel = True
- except:
- pass
- try:
- if self.settings['dryWin']:
- baselInit['type'] = 'fromDryWin'
- try:
- baselInit['pathToFile'] = self.settings['dryInterval']
- except:
- self.errMsg('Dry interval is not defined')
- methodSel = True
- except:
- pass
- if not methodSel:
- self.errMsg('Baseline method is not selected')
- print baselInit
- self.baseline = Baseline(**baselInit)
- def initTimeWinMW(self):
- winInit = {}
- try:
- except:
- pass
- try:
- except:
- pass
- try:
- except:
- pass
- try:
- winInit['links'] = self.settings['links']
- except:
- pass
- try:
- winInit['startTime'] = self.settings['start']
- except:
- pass
- try:
- winInit['endTime'] = self.settings['end']
- except:
- pass
- try:
- winInit['sumStep'] = self.settings['sumStep']
- except:
- pass
- try:
- winInit['IDtype'] = self.settings['IDtype']
- except:
- pass
- winInit['database'] = self.dbConn
- self.twin = TimeWindows(**winInit)
- def doCompute(self):
- # GMessage('OK')
- # sys.exit()
- if bool:
- self.initGrassLayerMgr()
- self.initTemporalMgr()
- GMessage(msg)
- def initGrassLayerMgr(self):
- grassLayerMgr = {}
- try:
- grassLayerMgr['rules'] = self.settings['colorRules']
- except:
- pass
- try:
- grassLayerMgr['color'] = self.settings['colorName']
- except:
- pass
- grassLayerMgr['database'] = self.dbConn
- GrassLayerMgr(**grassLayerMgr)
- def initTemporalMgr(self):
- GrassTemporalMgr(self.dbConn, self.twin)
- GMessage('Finish')
- def errMsg(self, label):
- print label
- GError(label)
-class MyApp(wx.App):
- def OnInit(self):
- frame.Show(True)
- self.SetTopWindow(frame)
- return True
-app = MyApp(0) # Create an instance of the application class
-app.MainLoop() # Tell it to start processing events
