[GRASS-SVN] r64898 - grass/trunk/scripts/r.unpack
svn_grass at osgeo.org
Tue Mar 24 02:23:17 PDT 2015
Author: lucadelu
Date: 2015-03-24 02:23:17 -0700 (Tue, 24 Mar 2015)
New Revision: 64898
grass/trunk/scripts/r.unpack/r.unpack.py
r.unpack: added -o flag to overwrite project system; thanks to Nikos Alexandris
Modified: grass/trunk/scripts/r.unpack/r.unpack.py
--- grass/trunk/scripts/r.unpack/r.unpack.py 2015-03-23 21:59:44 UTC (rev 64897)
+++ grass/trunk/scripts/r.unpack/r.unpack.py 2015-03-24 09:23:17 UTC (rev 64898)
@@ -30,7 +30,7 @@
#%end
#%flag
#% key: o
-#% description: Override projection check (use current location's projection)
+#% description: Override projection check (use location's projection)
#% guisection: Output settings
#%end
@@ -53,10 +53,10 @@
global tmp_dir
tmp_dir = grass.tempdir()
- grass.debug('tmp_dir = %s' % tmp_dir)
+ grass.debug('tmp_dir = {tmpdir}'.format(tmpdir=tmp_dir))
if not os.path.exists(infile):
- grass.fatal(_("File <%s> not found") % infile)
+ grass.fatal(_('File {name} not found.'.format(name=infile)))
gisenv = grass.gisenv()
mset_dir = os.path.join(gisenv['GISDBASE'],
@@ -79,9 +79,9 @@
gfile = grass.find_file(name=map_name, element='cell', mapset='.')
if gfile['file']:
if os.environ.get('GRASS_OVERWRITE', '0') != '1':
- grass.fatal(_("Raster map <%s> already exists") % map_name)
+ grass.fatal(_('Raster map <{name}> already exists'.format(name=map_name)))
else:
- grass.warning(_("Raster map <%s> already exists and will be overwritten") % map_name)
+ grass.warning(_('Raster map <{name}> already exists and will be overwritten'.format(name=map_name)))
# extract data
tar.extractall()
@@ -90,31 +90,38 @@
if os.path.exists('cell'):
pass
elif os.path.exists('coor'):
- grass.fatal(_("This GRASS GIS pack file contains vector data. Use "
- "v.unpack to unpack <%s>" % map_name))
+ grass.fatal(_('This GRASS GIS pack file contains vector data. Use '
+ 'v.unpack to unpack <{name}>'.format(name=map_name)))
else:
grass.fatal(_("Pack file unreadable"))
# check projection compatibility in a rather crappy way
- diff_result_1 = diff_result_2 = None
- proj_info_file_1 = 'PROJ_INFO'
- proj_info_file_2 = os.path.join(mset_dir, '..', 'PERMANENT', 'PROJ_INFO')
- if not grass.compare_key_value_text_files(filename_a=proj_info_file_1,
- filename_b=proj_info_file_2,
- proj=True):
- diff_result_1 = diff_files(proj_info_file_1, proj_info_file_2)
- proj_units_file_1 = 'PROJ_UNITS'
- proj_units_file_2 = os.path.join(mset_dir, '..', 'PERMANENT', 'PROJ_UNITS')
- if not grass.compare_key_value_text_files(filename_a=proj_units_file_1,
- filename_b=proj_units_file_2,
- units=True):
- diff_result_2 = diff_files(proj_units_file_1, proj_units_file_2)
- if diff_result_1 or diff_result_2:
- if flags['o']:
- grass.warning(_("Projection information does not match. Proceeding..."))
- else:
+ if flags['o']:
+ grass.warning(_("Overriding projection check (using current location's projection)."))
+ else:
+ diff_result_1 = diff_result_2 = None
+ proj_info_file_1 = 'PROJ_INFO'
+ proj_info_file_2 = os.path.join(mset_dir, '..', 'PERMANENT', 'PROJ_INFO')
+ if not grass.compare_key_value_text_files(filename_a=proj_info_file_1,
+ filename_b=proj_info_file_2,
+ proj=True):
+ diff_result_1 = diff_files(proj_info_file_1, proj_info_file_2)
+ proj_units_file_1 = 'PROJ_UNITS'
+ proj_units_file_2 = os.path.join(mset_dir, '..', 'PERMANENT', 'PROJ_UNITS')
+ if not grass.compare_key_value_text_files(filename_a=proj_units_file_1,
+ filename_b=proj_units_file_2,
+ units=True):
+ diff_result_2 = diff_files(proj_units_file_1, proj_units_file_2)
+ if diff_result_1 or diff_result_2:
if diff_result_1:
grass.warning(_("Difference between PROJ_INFO file of packed map "
"and of current location:\n{diff}").format(diff=''.join(diff_result_1)))
@@ -138,7 +145,7 @@
else:
shutil.copyfile(element, os.path.join(mset_dir, element, map_name))
- grass.message(_("Raster map <%s> unpacked") % map_name)
+ grass.message(_('Raster map <{name}> unpacked'.format(name=map_name)))
if __name__ == "__main__":
options, flags = grass.parser()
